[U-Boot] [PATCH] configs: icorem6: Use imx6 cratch register for bootcount
SRAM address used for bootcount on exiting code is erasing previous count value when system reset from Linux. So use the dedicated imx6 scratch register, GPR2 to preserve the contents even if the system reset from Linux.
Fixes: 4eb9aa39350e ("configs: imx6qdl_icore_mmc: Enable watchdog and bootcounter") Signed-off-by: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6qdl_icore_mmc_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 68ad1c6d20..24e99718e6 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -16,7 +16,7 @@ CONFIG_CMD_BOOTCOUNT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_SYS_BOOTCOUNT_ADDR=0x00900000 +CONFIG_SYS_BOOTCOUNT_ADDR=0x020D8024 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_IMX_WATCHDOG=y CONFIG_DEBUG_UART=y
I tested this on Engicam imx6q-icore, so
Tested-by: Shyam Saini shyam.saini@amarulasolutions.com
Hi Jagan,
nitpick: cratch ==> scratch
Just as info: I confirm that using start address of SRAM does not work. Rather even the GPRx registers are not a common solution. I have already seen that even the GPRx registers are touched and cannot be used on some i.MX6 variant. Anyway, if this works on your board, fine.
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Stefano,
Thanks a lot for reviewing this
Since GPRx registers are common to i.MX6, I think it can work irrespective of boards, please correct me if I am missing something here.
Did you come across any generic and robust solution for this ? It would be great if we can use more generic or better solution. Please let us know.
Thanks a lot, Shyam
Jagan Teki
Shyam Saini
Stefano Babic
