[U-Boot-Users] [PATCH v2] pci: Add CONFIG_PCI_SKIP_HOST_BRIDGE
In current source code, when the device number of PCI is 0, process PCI bridge without fail. However, when the device number is 0, it is not PCI always bridge. There are times when device of PCI allocates.
When CONFIG_PCI_SKIP_HOST_BRIDGE is enable, this problem is solved when use this patch.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/pci/pci.c | 13 ++++++++++--- 1 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 50ca6b0..7944b66 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -425,6 +425,9 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) dev < PCI_BDF(bus,PCI_MAX_PCI_DEVICES-1,PCI_MAX_PCI_FUNCTIONS-1); dev += PCI_BDF(0,0,1)) { + + /* Bus 0 is not necessarily PCI bridge. */ +#if defined(CONFIG_PCI_SKIP_HOST_BRIDGE) /* Skip our host bridge */ if ( dev == PCI_BDF(hose->first_busno,0,0) ) { #if defined(CONFIG_PCI_CONFIG_HOST_BRIDGE) /* don't skip host bridge */ @@ -434,10 +437,11 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) if (getenv("pciconfighost") == NULL) { continue; /* Skip our host bridge */ } -#else +#else /* CONFIG_PCI_CONFIG_HOST_BRIDGE */ continue; /* Skip our host bridge */ -#endif +#endif /* CONFIG_PCI_CONFIG_HOST_BRIDGE */ } +#endif /* CONFIG_PCI_SKIP_HOST_BRIDGE */
if (PCI_FUNC(dev) && !found_multi) continue; @@ -473,8 +477,11 @@ int pci_hose_scan_bus(struct pci_controller *hose, int bus) hose->fixup_irq(hose, dev);
#ifdef CONFIG_PCI_SCAN_SHOW +#if defined(CONFIG_PCI_SKIP_HOST_BRIDGE) /* Skip our host bridge */ - if ( dev != PCI_BDF(hose->first_busno,0,0) ) { + if ( dev != PCI_BDF(hose->first_busno,0,0) ) +#endif + { unsigned char int_line;
pci_hose_read_config_byte(hose, dev, PCI_INTERRUPT_LINE,
Applied, thanks.
Nobuhiro Iwamatsu
