[PATCH v2 1/1] doc: man-page for bootefi command
Provide a description of the bootefi command.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: Replace ".. code-block::" by "::" as the build-system on Gitlab does not like code-block without language. The problem did not occur locally. --- MAINTAINERS | 1 + doc/usage/bootefi.rst | 135 ++++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 3 files changed, 137 insertions(+) create mode 100644 doc/usage/bootefi.rst
diff --git a/MAINTAINERS b/MAINTAINERS index 127e30c0a5..8675965fe5 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -679,6 +679,7 @@ S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git F: doc/api/efi.rst F: doc/uefi/* +F: doc/usage/bootefi.rst F: drivers/rtc/emul_rtc.c F: include/capitalization.h F: include/charset.h diff --git a/doc/usage/bootefi.rst b/doc/usage/bootefi.rst new file mode 100644 index 0000000000..282f22aac9 --- /dev/null +++ b/doc/usage/bootefi.rst @@ -0,0 +1,135 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright 2020, Heinrich Schuchardt xypron.glpk@gmx.de + +bootefi command +=============== + +Synopsis +-------- + +:: + + bootefi [image_addr] [fdt_addr] + bootefi bootmgr [fdt_addr] + bootefi hello [fdt_addr] + bootefi selftest [fdt_addr] + +Description +----------- + +The *bootefi* command is used to launch a UEFI binary which can be either of + +* UEFI application +* UEFI boot services driver +* UEFI run-time services driver + +An operating system requires a hardware description which can either be +presented as ACPI table (CONFIG_GENERATE_ACPI_TABLE=y) or as device-tree +The load address of the device-tree may be provided as parameter *fdt_addr*. If +this address is not specified, the bootefi command will try to fall back in +sequence to: + +* the device-tree specified by environment variable *fdt_addr* +* the device-tree specified by environment variable *fdtcontroladdr* + +The load address of the binary is specified by parameter *image_address*. A +command sequence to run a UEFI application might look like + +:: + + load mmc 0:2 $fdt_addr_r dtb + load mmc 0:1 $kernel_addr_r /EFI/grub/grubaa64.efi + bootefi $kernel_addr_r $fdt_addr_r + +The last file loaded defines the image file path in the loaded image protocol. +Hence the executable should always be loaded last. + +The value of the environment variable *bootargs* is converted from UTF-8 to +UTF-16 and passed as load options in the loaded image protocol to the UEFI +binary. + +Note + UEFI binaries that are contained in FIT images are launched via the + *bootm* command. + +UEFI boot manager +''''''''''''''''' + +The UEFI boot manager is invoked by the *bootefi bootmgr* sub-command. +Here boot options are defined by UEFI variables with a name consisting of the +letters *Boot* followed by a four digit hexadecimal number, e.g. *Boot0001* or +*BootA03E*. The boot variable defines a label, the device path of the binary to +execute as well as the load options passed in the loaded image protocol. + +If the UEFI variable *BootNext* is defined, it specifies the number of the boot +option to execute next. If no binary can be loaded via *BootNext* the variable +*BootOrder* specifies in which sequence boot options shalled be tried. + +The values of these variables can be managed using the U-Boot command +*efidebug*. + +UEFI hello world application +'''''''''''''''''''''''''''' + +U-Boot can be compiled with a hello world application that can be launched using +the *bootefi hello* sub-command. A session might look like + +:: + + => setenv bootargs 'Greetings to the world' + => bootefi hello + Booting /MemoryMapped(0x0,0x10001000,0x1000) + Hello, world! + Running on UEFI 2.8 + Have SMBIOS table + Have device tree + Load options: Greetings to the world + +UEFI selftest +''''''''''''' + +U-Boot can be compiled with UEFI unit tests. These unit tests are invoked using +the *bootefi selftest* sub-command. + +Which unit test is executed is controlled by the environment variable +*efi_selftest*. If this variable is not set, all unit tests that are not marked +as 'on request' are executed. + +To show a list of the available unit tests the value *list* can be used + +:: + + => setenv efi_selftest list + => bootefi selftest + + Available tests: + 'block image transfer' - on request + 'block device' + 'configuration tables' + ... + +A single test is selected for execution by setting the *efi_selftest* +environment variable to match one of the listed identifiers + +:: + + => setenv efi_selftest 'block image transfer' + => bootefi selftest + +Some of the tests execute the ExitBootServices() UEFI boot service and will not +return to the command line but require a board reset. + +Configuration +------------- + +To use the *bootefi* command you must specify CONFIG_CMD_BOOTEFI=y. +The *bootefi hello* sub-command requries CMD_BOOTEFI_HELLO=y. +The *bootefi selftest* sub-command depends on CMD_BOOTEFI_SELFTEST=y. + +See also +-------- + +* *bootm* for launching UEFI binaries packed in FIT images +* *booti*, *bootm*, *bootz* for launching a Linux kernel without using the + UEFI sub-system +* *efidebug* for setting UEFI boot variables diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 6c4b5b9240..fbb2c0481c 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -11,6 +11,7 @@ Shell commands .. toctree:: :maxdepth: 1
+ bootefi bootmenu button pstore -- 2.29.2
