[U-Boot] [PATCH] image: push default arch values to arch headers
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/arm/include/asm/u-boot.h | 3 ++ arch/avr32/include/asm/u-boot.h | 3 ++ arch/blackfin/include/asm/u-boot.h | 3 ++ arch/m68k/include/asm/u-boot.h | 3 ++ arch/microblaze/include/asm/u-boot.h | 2 + arch/mips/include/asm/u-boot.h | 3 ++ arch/nios2/include/asm/u-boot.h | 2 + arch/powerpc/include/asm/u-boot.h | 4 ++ arch/sh/include/asm/u-boot.h | 3 ++ arch/sparc/include/asm/u-boot.h | 4 ++ arch/x86/include/asm/u-boot.h | 3 ++ common/cmd_bootm.c | 26 +-------------- include/image.h | 58 +-------------------------------- 13 files changed, 36 insertions(+), 81 deletions(-)
diff --git a/arch/arm/include/asm/u-boot.h b/arch/arm/include/asm/u-boot.h index ed33327..f30b9fc 100644 --- a/arch/arm/include/asm/u-boot.h +++ b/arch/arm/include/asm/u-boot.h @@ -48,4 +48,7 @@ typedef struct bd_info { } bi_dram[CONFIG_NR_DRAM_BANKS]; } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_ARM + #endif /* _U_BOOT_H_ */ diff --git a/arch/avr32/include/asm/u-boot.h b/arch/avr32/include/asm/u-boot.h index 8acd056..ff1ed23 100644 --- a/arch/avr32/include/asm/u-boot.h +++ b/arch/avr32/include/asm/u-boot.h @@ -40,4 +40,7 @@ typedef struct bd_info { #define bi_memstart bi_dram[0].start #define bi_memsize bi_dram[0].size
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_AVR32 + #endif /* __ASM_U_BOOT_H__ */ diff --git a/arch/blackfin/include/asm/u-boot.h b/arch/blackfin/include/asm/u-boot.h index a6e6cf0f..9712fc0 100644 --- a/arch/blackfin/include/asm/u-boot.h +++ b/arch/blackfin/include/asm/u-boot.h @@ -45,4 +45,7 @@ typedef struct bd_info { unsigned long bi_sclk; } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_BLACKFIN + #endif /* _U_BOOT_H_ */ diff --git a/arch/m68k/include/asm/u-boot.h b/arch/m68k/include/asm/u-boot.h index a0f2983..0a48bbd 100644 --- a/arch/m68k/include/asm/u-boot.h +++ b/arch/m68k/include/asm/u-boot.h @@ -64,4 +64,7 @@ typedef struct bd_info {
#endif /* __ASSEMBLY__ */
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_M68K + #endif /* __U_BOOT_H__ */ diff --git a/arch/microblaze/include/asm/u-boot.h b/arch/microblaze/include/asm/u-boot.h index 543a6b1..21c72d5 100644 --- a/arch/microblaze/include/asm/u-boot.h +++ b/arch/microblaze/include/asm/u-boot.h @@ -44,5 +44,7 @@ typedef struct bd_info { unsigned long bi_baudrate; /* Console Baudrate */ } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_MICROBLAZE
#endif /* _U_BOOT_H_ */ diff --git a/arch/mips/include/asm/u-boot.h b/arch/mips/include/asm/u-boot.h index e839ca1..edb87bb 100644 --- a/arch/mips/include/asm/u-boot.h +++ b/arch/mips/include/asm/u-boot.h @@ -43,4 +43,7 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_MIPS + #endif /* _U_BOOT_H_ */ diff --git a/arch/nios2/include/asm/u-boot.h b/arch/nios2/include/asm/u-boot.h index ec844d0..f7c70ff 100644 --- a/arch/nios2/include/asm/u-boot.h +++ b/arch/nios2/include/asm/u-boot.h @@ -43,5 +43,7 @@ typedef struct bd_info { unsigned long bi_baudrate; /* Console Baudrate */ } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_NIOS2
#endif /* __ASM_NIOS2_U_BOOT_H_ */ diff --git a/arch/powerpc/include/asm/u-boot.h b/arch/powerpc/include/asm/u-boot.h index 721692a..b2fa2b5 100644 --- a/arch/powerpc/include/asm/u-boot.h +++ b/arch/powerpc/include/asm/u-boot.h @@ -143,4 +143,8 @@ typedef struct bd_info { } bd_t;
#endif /* __ASSEMBLY__ */ + +/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_PPC + #endif /* __U_BOOT_H__ */ diff --git a/arch/sh/include/asm/u-boot.h b/arch/sh/include/asm/u-boot.h index 27d43b9..4574512 100644 --- a/arch/sh/include/asm/u-boot.h +++ b/arch/sh/include/asm/u-boot.h @@ -38,4 +38,7 @@ typedef struct bd_info { unsigned long bi_boot_params; /* where this board expects params */ } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_SH + #endif diff --git a/arch/sparc/include/asm/u-boot.h b/arch/sparc/include/asm/u-boot.h index 209873f..1d94087 100644 --- a/arch/sparc/include/asm/u-boot.h +++ b/arch/sparc/include/asm/u-boot.h @@ -59,4 +59,8 @@ typedef struct bd_info { } bd_t;
#endif /* __ASSEMBLY__ */ + +/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_SPARC + #endif /* __U_BOOT_H__ */ diff --git a/arch/x86/include/asm/u-boot.h b/arch/x86/include/asm/u-boot.h index a43b3aa..26450eb 100644 --- a/arch/x86/include/asm/u-boot.h +++ b/arch/x86/include/asm/u-boot.h @@ -58,4 +58,7 @@ typedef struct bd_info { }bi_dram[CONFIG_NR_DRAM_BANKS]; } bd_t;
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_I386 + #endif /* _U_BOOT_H_ */ diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 8909ee7..c2e8038 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -165,31 +165,7 @@ void __arch_preboot_os(void) } void arch_preboot_os(void) __attribute__((weak, alias("__arch_preboot_os")));
-#if defined(__ARM__) - #define IH_INITRD_ARCH IH_ARCH_ARM -#elif defined(__avr32__) - #define IH_INITRD_ARCH IH_ARCH_AVR32 -#elif defined(__bfin__) - #define IH_INITRD_ARCH IH_ARCH_BLACKFIN -#elif defined(__I386__) - #define IH_INITRD_ARCH IH_ARCH_I386 -#elif defined(__M68K__) - #define IH_INITRD_ARCH IH_ARCH_M68K -#elif defined(__microblaze__) - #define IH_INITRD_ARCH IH_ARCH_MICROBLAZE -#elif defined(__mips__) - #define IH_INITRD_ARCH IH_ARCH_MIPS -#elif defined(__nios2__) - #define IH_INITRD_ARCH IH_ARCH_NIOS2 -#elif defined(__PPC__) - #define IH_INITRD_ARCH IH_ARCH_PPC -#elif defined(__sh__) - #define IH_INITRD_ARCH IH_ARCH_SH -#elif defined(__sparc__) - #define IH_INITRD_ARCH IH_ARCH_SPARC -#else -# error Unknown CPU type -#endif +#define IH_INITRD_ARCH IH_ARCH_DEFAULT
static void bootm_start_lmb(void) { diff --git a/include/image.h b/include/image.h index 352e4a0..cbb6669 100644 --- a/include/image.h +++ b/include/image.h @@ -484,34 +484,7 @@ void image_print_contents (const void *hdr); #ifndef USE_HOSTCC static inline int image_check_target_arch (const image_header_t *hdr) { -#if defined(__ARM__) - if (!image_check_arch (hdr, IH_ARCH_ARM)) -#elif defined(__avr32__) - if (!image_check_arch (hdr, IH_ARCH_AVR32)) -#elif defined(__bfin__) - if (!image_check_arch (hdr, IH_ARCH_BLACKFIN)) -#elif defined(__I386__) - if (!image_check_arch (hdr, IH_ARCH_I386)) -#elif defined(__M68K__) - if (!image_check_arch (hdr, IH_ARCH_M68K)) -#elif defined(__microblaze__) - if (!image_check_arch (hdr, IH_ARCH_MICROBLAZE)) -#elif defined(__mips__) - if (!image_check_arch (hdr, IH_ARCH_MIPS)) -#elif defined(__nios2__) - if (!image_check_arch (hdr, IH_ARCH_NIOS2)) -#elif defined(__PPC__) - if (!image_check_arch (hdr, IH_ARCH_PPC)) -#elif defined(__sh__) - if (!image_check_arch (hdr, IH_ARCH_SH)) -#elif defined(__sparc__) - if (!image_check_arch (hdr, IH_ARCH_SPARC)) -#else -# error Unknown CPU type -#endif - return 0; - - return 1; + return image_check_arch(hdr, IH_ARCH_DEFAULT); } #endif /* USE_HOSTCC */
@@ -636,34 +609,7 @@ void fit_conf_print (const void *fit, int noffset, const char *p); #ifndef USE_HOSTCC static inline int fit_image_check_target_arch (const void *fdt, int node) { -#if defined(__ARM__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_ARM)) -#elif defined(__avr32__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_AVR32)) -#elif defined(__bfin__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_BLACKFIN)) -#elif defined(__I386__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_I386)) -#elif defined(__M68K__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_M68K)) -#elif defined(__microblaze__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_MICROBLAZE)) -#elif defined(__mips__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_MIPS)) -#elif defined(__nios2__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_NIOS2)) -#elif defined(__PPC__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_PPC)) -#elif defined(__sh__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_SH)) -#elif defined(__sparc__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_SPARC)) -#else -# error Unknown CPU type -#endif - return 0; - - return 1; + return !fit_image_check_arch(fdt, node, IH_ARCH_DEFAULT)); } #endif /* USE_HOSTCC */
Dear Mike Frysinger,
I appreciate this change in general, but ...
- return 1;
- return !fit_image_check_arch(fdt, node, IH_ARCH_DEFAULT));
...here you change a compile time error check into a runtim error.
Please fix this.
- return 1;
no, it'll still be a build time error as IH_ARCH_DEFAULT will be undefined
it just might not be as clean an error ... gcc will complain about IH_ARCH_DEFAULT not being defined rather than a helpful "Unknown CPU type" message. -mike
Should it not be trivial to add a
#ifndef IH_ARCH_DEFAULT # error Unknown CPU type: IH_ARCH_DEFAULT not set #endif
or similar to include/image.h ?
it'd certainly be easy to do. i just pointed out that you still get a build failure after my change :). so if you want the #error, i'll resend w/it. -mike
Yes, please do. I think it's easier to decode for most people.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - add a friendly #error when the define is missing
arch/arm/include/asm/u-boot.h | 3 ++ arch/avr32/include/asm/u-boot.h | 3 ++ arch/blackfin/include/asm/u-boot.h | 3 ++ arch/m68k/include/asm/u-boot.h | 3 ++ arch/microblaze/include/asm/u-boot.h | 2 + arch/mips/include/asm/u-boot.h | 3 ++ arch/nios2/include/asm/u-boot.h | 2 + arch/powerpc/include/asm/u-boot.h | 4 ++ arch/sh/include/asm/u-boot.h | 3 ++ arch/sparc/include/asm/u-boot.h | 4 ++ arch/x86/include/asm/u-boot.h | 3 ++ common/cmd_bootm.c | 26 +-------------- include/image.h | 59 ++------------------------------- 13 files changed, 38 insertions(+), 80 deletions(-)
static void bootm_start_lmb(void) { diff --git a/include/image.h b/include/image.h index 352e4a0..62ce38d 100644 --- a/include/image.h +++ b/include/image.h @@ -484,34 +484,10 @@ void image_print_contents (const void *hdr); #ifndef USE_HOSTCC static inline int image_check_target_arch (const image_header_t *hdr) { -#if defined(__ARM__) - if (!image_check_arch (hdr, IH_ARCH_ARM)) -#elif defined(__avr32__) - if (!image_check_arch (hdr, IH_ARCH_AVR32)) -#elif defined(__bfin__) - if (!image_check_arch (hdr, IH_ARCH_BLACKFIN)) -#elif defined(__I386__) - if (!image_check_arch (hdr, IH_ARCH_I386)) -#elif defined(__M68K__) - if (!image_check_arch (hdr, IH_ARCH_M68K)) -#elif defined(__microblaze__) - if (!image_check_arch (hdr, IH_ARCH_MICROBLAZE)) -#elif defined(__mips__) - if (!image_check_arch (hdr, IH_ARCH_MIPS)) -#elif defined(__nios2__) - if (!image_check_arch (hdr, IH_ARCH_NIOS2)) -#elif defined(__PPC__) - if (!image_check_arch (hdr, IH_ARCH_PPC)) -#elif defined(__sh__) - if (!image_check_arch (hdr, IH_ARCH_SH)) -#elif defined(__sparc__) - if (!image_check_arch (hdr, IH_ARCH_SPARC)) -#else -# error Unknown CPU type +#ifndef IH_ARCH_DEFAULT +# error "please define IH_ARCH_DEFAULT in your arch asm/u-boot.h" #endif - return 0; - - return 1; + return image_check_arch(hdr, IH_ARCH_DEFAULT); } #endif /* USE_HOSTCC */
@@ -636,34 +612,7 @@ void fit_conf_print (const void *fit, int noffset, const char *p); #ifndef USE_HOSTCC static inline int fit_image_check_target_arch (const void *fdt, int node) { -#if defined(__ARM__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_ARM)) -#elif defined(__avr32__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_AVR32)) -#elif defined(__bfin__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_BLACKFIN)) -#elif defined(__I386__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_I386)) -#elif defined(__M68K__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_M68K)) -#elif defined(__microblaze__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_MICROBLAZE)) -#elif defined(__mips__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_MIPS)) -#elif defined(__nios2__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_NIOS2)) -#elif defined(__PPC__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_PPC)) -#elif defined(__sh__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_SH)) -#elif defined(__sparc__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_SPARC)) -#else -# error Unknown CPU type -#endif - return 0; - - return 1; + return !fit_image_check_arch(fdt, node, IH_ARCH_DEFAULT)); } #endif /* USE_HOSTCC */
Hi Mike,
Signed-off-by: Mike Frysingervapier@gentoo.org
v2
Compiled and tested on nios2 boards using gcc4 and gcc3 with McNutt's "Add missing header for gcc3" patch applied. Thanks.
Tested-by: Thomas Chou thomas@wytron.com.tw
Best regards, Thomas
Acked-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org Tested-by: Thomas Chou thomas@wytron.com.tw Signed-off-by: Mike Frysinger vapier@gentoo.org --- v3 - fix typo in fdt-specific code path
static void bootm_start_lmb(void) { diff --git a/include/image.h b/include/image.h index 352e4a0..cca1cc5 100644 --- a/include/image.h +++ b/include/image.h @@ -484,34 +484,10 @@ void image_print_contents (const void *hdr); #ifndef USE_HOSTCC static inline int image_check_target_arch (const image_header_t *hdr) { -#if defined(__ARM__) - if (!image_check_arch (hdr, IH_ARCH_ARM)) -#elif defined(__avr32__) - if (!image_check_arch (hdr, IH_ARCH_AVR32)) -#elif defined(__bfin__) - if (!image_check_arch (hdr, IH_ARCH_BLACKFIN)) -#elif defined(__I386__) - if (!image_check_arch (hdr, IH_ARCH_I386)) -#elif defined(__M68K__) - if (!image_check_arch (hdr, IH_ARCH_M68K)) -#elif defined(__microblaze__) - if (!image_check_arch (hdr, IH_ARCH_MICROBLAZE)) -#elif defined(__mips__) - if (!image_check_arch (hdr, IH_ARCH_MIPS)) -#elif defined(__nios2__) - if (!image_check_arch (hdr, IH_ARCH_NIOS2)) -#elif defined(__PPC__) - if (!image_check_arch (hdr, IH_ARCH_PPC)) -#elif defined(__sh__) - if (!image_check_arch (hdr, IH_ARCH_SH)) -#elif defined(__sparc__) - if (!image_check_arch (hdr, IH_ARCH_SPARC)) -#else -# error Unknown CPU type +#ifndef IH_ARCH_DEFAULT +# error "please define IH_ARCH_DEFAULT in your arch asm/u-boot.h" #endif - return 0; - - return 1; + return image_check_arch(hdr, IH_ARCH_DEFAULT); } #endif /* USE_HOSTCC */
@@ -636,34 +612,7 @@ void fit_conf_print (const void *fit, int noffset, const char *p); #ifndef USE_HOSTCC static inline int fit_image_check_target_arch (const void *fdt, int node) { -#if defined(__ARM__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_ARM)) -#elif defined(__avr32__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_AVR32)) -#elif defined(__bfin__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_BLACKFIN)) -#elif defined(__I386__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_I386)) -#elif defined(__M68K__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_M68K)) -#elif defined(__microblaze__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_MICROBLAZE)) -#elif defined(__mips__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_MIPS)) -#elif defined(__nios2__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_NIOS2)) -#elif defined(__PPC__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_PPC)) -#elif defined(__sh__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_SH)) -#elif defined(__sparc__) - if (!fit_image_check_arch (fdt, node, IH_ARCH_SPARC)) -#else -# error Unknown CPU type -#endif - return 0; - - return 1; + return !fit_image_check_arch(fdt, node, IH_ARCH_DEFAULT); } #endif /* USE_HOSTCC */
v3
Applied, thanks.
Mike Frysinger
Thomas Chou
