[PATCH 1/1] clk: scmi: fix scmi_clk_get_attibute()
Local variable out.name lives on the stack and therefore cannot be returned directly. Move the strdup() call into the function. (Coverity 352460)
Fixes: 7c33f78983c3 ("clk: scmi: register scmi clocks with CCF") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/clk/clk_scmi.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/clk/clk_scmi.c b/drivers/clk/clk_scmi.c index 57022685e2..5aaabcf0b4 100644 --- a/drivers/clk/clk_scmi.c +++ b/drivers/clk/clk_scmi.c @@ -53,7 +53,7 @@ static int scmi_clk_get_attibute(struct udevice *dev, int clkid, char **name) if (ret) return ret;
- *name = out.clock_name; + *name = strdup(out.clock_name);
return 0; } @@ -152,11 +152,9 @@ static int scmi_clk_probe(struct udevice *dev) return ret;
for (i = 0; i < num_clocks; i++) { - char *name; - - if (!scmi_clk_get_attibute(dev, i, &name)) { - char *clock_name = strdup(name); + char *clock_name;
+ if (!scmi_clk_get_attibute(dev, i, &clock_name)) { clk = kzalloc(sizeof(*clk), GFP_KERNEL); if (!clk || !clock_name) ret = -ENOMEM;
return 0; }
char *name;
char *clock_name;
Addressing the same issue as [1]. Either will work, though your patch looks cleaner.
[1] https://lore.kernel.org/u-boot/20220426094938.21320-1-etienne.carriere@linar...
Reviewed-by: Sean Anderson seanga2@gmail.com
Fixes: 7c33f78983c3 ("clk: scmi: register scmi clocks with CCF") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Sean Anderson seanga2@gmail.com
Sean Anderson
