[U-Boot] FDT include file problems
Hello,
on some systems (for example Fedora Core 4) U-Boot builds with the following wanrings only:
... In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead! In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt_ro.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead! In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt_rw.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead! In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt_strerror.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead! In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt_wip.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead! ...
The suggested change works in image.h, for example like this:
diff --git a/include/image.h b/include/image.h index 82e6345..1598b61 100644 --- a/include/image.h +++ b/include/image.h @@ -33,27 +33,29 @@ #ifndef __IMAGE_H__ #define __IMAGE_H__
-#include <asm/byteorder.h> -#include <command.h> - -#ifndef USE_HOSTCC -#include <lmb.h> -#include <linux/string.h> -#include <asm/u-boot.h> - -#else +#if USE_HOSTCC +#include <endian.h>
/* new uImage format support enabled on host */ #define CONFIG_FIT 1 #define CONFIG_OF_LIBFDT 1 #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */
+#else + +#include <lmb.h> +#include <linux/string.h> +#include <asm/u-boot.h> +#include <asm/byteorder.h> + #endif /* USE_HOSTCC */
#if defined(CONFIG_FIT) && !defined(CONFIG_OF_LIBFDT) #error "CONFIG_OF_LIBFDT not enabled, required by CONFIG_FIT!" #endif
+#include <command.h> + #if defined(CONFIG_FIT) #include <fdt.h> #include <libfdt.h>
However, for the FDT code this doesn't help, as we then will get unresolved references for fdt32_to_cpu(), cpu_to_fdt32(), fdt64_to_cpu() and cpu_to_fdt64().
The 32 bit accesses couldbe worked around by using htonl() resp. ntohl(), but I don't know a good way for the 64 bit cases.
Is there a clean and portable way to do this?
On Mon, Oct 20, 2008 at 12:01:59AM +0200, Wolfgang Denk wrote:
Hello,
[snip]
Hi Wolfgang,
Does this work better?
Best regards, gvb
From 0d33fb368acac6f88c0940ff2d1c77856900abcd Mon Sep 17 00:00:00 2001
From: Gerald Van Baren vanbaren@cideas.com Date: Sun, 19 Oct 2008 22:50:07 -0400 Subject: [PATCH] libfdt: Use endian.h instead of asm/byteorder.h
Using asm/byteorder.h directly is strongly discouraged since it is a private kernel header.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- include/libfdt_env.h | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/include/libfdt_env.h b/include/libfdt_env.h index 671c3a8..728a248 100644 --- a/include/libfdt_env.h +++ b/include/libfdt_env.h @@ -33,10 +33,17 @@ #include <asm/byteorder.h> extern struct fdt_header *working_fdt; /* Pointer to the working fdt */
-#define fdt32_to_cpu(x) __be32_to_cpu(x) -#define cpu_to_fdt32(x) __cpu_to_be32(x) -#define fdt64_to_cpu(x) __be64_to_cpu(x) -#define cpu_to_fdt64(x) __cpu_to_be64(x) +#if __BYTE_ORDER == __LITTLE_ENDIAN +#define fdt32_to_cpu(x) __swab32(x) +#define cpu_to_fdt32(x) __swab32(x) +#define fdt64_to_cpu(x) __swab64(x) +#define cpu_to_fdt64(x) __swab64(x) +#else +#define fdt32_to_cpu(x) (x) +#define cpu_to_fdt32(x) (x) +#define fdt64_to_cpu(x) (x) +#define cpu_to_fdt64(x) (x) +#endif
/* * Types for `void *' pointers.
Dear Jerry Van Baren,
Not really:
From 0d33fb368acac6f88c0940ff2d1c77856900abcd Mon Sep 17 00:00:00 2001 From: Gerald Van Baren vanbaren@cideas.com Date: Sun, 19 Oct 2008 22:50:07 -0400 Subject: [PATCH] libfdt: Use endian.h instead of asm/byteorder.h
Hm... but you still use it?
This has not changed?
If I change the code to include <asm/byteorder.h> only for the U-Boot code but use <endian.h>, I get warnings:
../include/libfdt.h:162: warning: implicit declaration of function '__swab32'
and finally a "undefined reference to `__swab32'" error. Seems __swab32 and __swab64 are defined only in linux/byteorder/swab.h
Not really:
[snip]
Oops, I was rushing too much. I missed changing this to endian.h.
[snip]
...and if I were not rushing so much, I would have found that myself instead of looking stupid. :-(
Google hasn't been very helpful for answering the question of how to handle endian issues in userland (non-kernel) code. Hmmm. Grrr. Maybe I'm not asking it the right question.
Maybe we need to make our own copy of linux/byteorder/swab.h in u-boot? That doesn't seem right.
Best regards, gvb
Well, I have to admit that you did not perform better, because I've been searching before, and I didn't find a good solution myself either. Normally, I use the network macros for such stuff, but these don't have any 64 bit conversions...
No, that would not be right.
This patch seems to work for me:
diff --git a/include/libfdt_env.h b/include/libfdt_env.h index 671c3a8..355ebf2 100644 --- a/include/libfdt_env.h +++ b/include/libfdt_env.h @@ -24,19 +24,28 @@ #ifdef USE_HOSTCC #include <stdint.h> #include <string.h> +#include <endian.h> +#include <byteswap.h> #else #include <linux/string.h> #include <linux/types.h> +#include <asm/byteorder.h> #endif /* USE_HOSTCC */
#include <stddef.h> -#include <asm/byteorder.h> extern struct fdt_header *working_fdt; /* Pointer to the working fdt */
-#define fdt32_to_cpu(x) __be32_to_cpu(x) -#define cpu_to_fdt32(x) __cpu_to_be32(x) -#define fdt64_to_cpu(x) __be64_to_cpu(x) -#define cpu_to_fdt64(x) __cpu_to_be64(x) +#if __BYTE_ORDER == __LITTLE_ENDIAN +#define fdt32_to_cpu(x) bswap_32(x) +#define cpu_to_fdt32(x) bswap_32(x) +#define fdt64_to_cpu(x) bswap_64(x) +#define cpu_to_fdt64(x) bswap_64(x) +#else +#define fdt32_to_cpu(x) (x) +#define cpu_to_fdt32(x) (x) +#define fdt64_to_cpu(x) (x) +#define cpu_to_fdt64(x) (x) +#endif
- Types for `void *' pointers.
Dear Wolfgang,
This works for me too. Do you want to apply it directly? That would be fastest and easiest.
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, gvb
Thanks - I'll post a proper patch first, including theother change (in include/image.h).
Jerry Van Baren
