[U-Boot] [PATCH] powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set
Add ifdef protection around fman specific code related to device tree clock setup. If we dont have CONFIG_SYS_DPAA_FMAN defined we shouldn't be executing this code.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/fdt.c | 4 ++++ arch/powerpc/cpu/mpc85xx/portals.c | 5 ++++- 2 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 8f13cd8..d20c94c 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -361,6 +361,7 @@ void fdt_add_enet_stashing(void *fdt) }
#if defined(CONFIG_SYS_DPAA_FMAN) || defined(CONFIG_SYS_DPAA_PME) +#ifdef CONFIG_SYS_DPAA_FMAN static void ft_fixup_clks(void *blob, const char *compat, u32 offset, unsigned long freq) { @@ -374,12 +375,14 @@ static void ft_fixup_clks(void *blob, const char *compat, u32 offset, "for %s: %s\n", compat, fdt_strerror(off)); } } +#endif
static void ft_fixup_dpaa_clks(void *blob) { sys_info_t sysinfo;
get_sys_info(&sysinfo); +#ifdef CONFIG_SYS_DPAA_FMAN ft_fixup_clks(blob, "fsl,fman", CONFIG_SYS_FSL_FM1_OFFSET, sysinfo.freqFMan[0]);
@@ -387,6 +390,7 @@ static void ft_fixup_dpaa_clks(void *blob) ft_fixup_clks(blob, "fsl,fman", CONFIG_SYS_FSL_FM2_OFFSET, sysinfo.freqFMan[1]); #endif +#endif
#ifdef CONFIG_SYS_DPAA_PME do_fixup_by_compat_u32(blob, "fsl,pme", diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index ecaa30d..65635e7 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -198,7 +198,10 @@ void fdt_fixup_qportals(void *blob) u32 liodns[2]; #endif const int *ci = fdt_getprop(blob, off, "cell-index", NULL); - int j, i = *ci; + int i = *ci; +#ifdef CONFIG_SYS_DPAA_FMAN + int j; +#endif
err = fdt_setprop(blob, off, "compatible", compat, compat_len); if (err < 0)
applied to 85xx next
- k
Kumar Gala
