[PATCH] configs: ls1088aqds: add COMMON_ENV to fix distroboot
Add COMMON_ENV to fix distroboot, boot log as follows, Found U-Boot script /ls1088aqds_boot.scr 961 bytes read in 18 ms (51.8 KiB/s) ## Executing script at 80000000 load - load binary file from a filesystemUsage: load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] - Load binary file filename from partition part on device type interface instance dev to address addr in memory. bytes gives the size to load in bytes. If bytes is 0 or omitted, the file is read until the end. pos gives the file byte position to start reading from. If pos is 0 or omitted, the file is read from the start. load - load binary file from a filesystemUsage: load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] - Load binary file filename from partition part on device type interface instance dev to address addr in memory. bytes gives the size to load in bytes. If bytes is 0 or omitted, the file is read until the end. pos gives the file byte position to start reading from. If pos is 0 or omitted, the file is read from the start. Bad Linux ARM64 Image magic! SCRIPT FAILED: continuing...
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls1088aqds.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 59757120fc..0dd6bb9f32 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -384,10 +384,18 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ESDHC_DETECT_QUIRK ((readb(QIXIS_BASE + QIXIS_STAT_PRES1) & \ QIXIS_SDID_MASK) != QIXIS_ESDHC_NO_ADAPTER)
+#define COMMON_ENV \ + "kernelheader_addr_r=0x80200000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernel_addr_r=0x81000000\0" \ + "fdt_addr_r=0x90000000\0" \ + "load_addr=0xa0000000\0" + /* Initial environment variables */ #ifdef CONFIG_NXP_ESBC #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ + COMMON_ENV \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x90100000\0" \ "kernel_addr=0x100000\0" \ @@ -419,6 +427,7 @@ unsigned long get_board_ddr_clk(void);
#undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ + COMMON_ENV \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x90100000\0" \ "kernel_addr=0x100000\0" \ @@ -480,6 +489,7 @@ unsigned long get_board_ddr_clk(void); #if defined(CONFIG_QSPI_BOOT) #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ + COMMON_ENV \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x90100000\0" \ "kernel_addr=0x100000\0" \ @@ -497,6 +507,7 @@ unsigned long get_board_ddr_clk(void); #elif defined(CONFIG_SD_BOOT) #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ + COMMON_ENV \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x90100000\0" \ "kernel_addr=0x800\0" \ @@ -514,6 +525,7 @@ unsigned long get_board_ddr_clk(void); #else /* NOR BOOT */ #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ + COMMON_ENV \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x90100000\0" \ "kernel_addr=0x100000\0" \
Biwen Li
