[PATCH] LynxOS is no longer supported
LynxOS needed the do_bootm_lynxkdi() function that got removed in 7e713067ee ("Remove LYNX KDI remainders") - and that function needed a lynxkdi_boot() function, where the last implementation had been removed in 98f705c9ce ("powerpc: remove 4xx support") already. Looks like this OS is definitely not supported anymore, so remove it from the corresponding lists.
Signed-off-by: Thomas Huth thuth@redhat.com --- README | 3 +-- boot/image.c | 3 --- 2 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/README b/README index 9606a8b3ac..064e781d45 100644 --- a/README +++ b/README @@ -3359,8 +3359,7 @@ details; basically, the header defines the following image properties: * Target Operating System (Provisions for OpenBSD, NetBSD, FreeBSD, 4.4BSD, Linux, SVR4, Esix, Solaris, Irix, SCO, Dell, NCR, VxWorks, LynxOS, pSOS, QNX, RTEMS, INTEGRITY; - Currently supported: Linux, NetBSD, VxWorks, QNX, RTEMS, LynxOS, - INTEGRITY). + Currently supported: Linux, NetBSD, VxWorks, QNX, RTEMS, INTEGRITY). * Target CPU Architecture (Provisions for Alpha, ARM, Intel x86, IA64, MIPS, NDS32, Nios II, PowerPC, IBM S390, SuperH, Sparc, Sparc 64 Bit; Currently supported: ARM, Intel x86, MIPS, NDS32, Nios II, PowerPC). diff --git a/boot/image.c b/boot/image.c index 992e72991d..6ab827b2d4 100644 --- a/boot/image.c +++ b/boot/image.c @@ -106,9 +106,6 @@ static const table_entry_t uimage_os[] = { { IH_OS_INVALID, "invalid", "Invalid OS", }, { IH_OS_ARM_TRUSTED_FIRMWARE, "arm-trusted-firmware", "ARM Trusted Firmware" }, { IH_OS_LINUX, "linux", "Linux", }, -#if defined(USE_HOSTCC) - { IH_OS_LYNXOS, "lynxos", "LynxOS", }, -#endif { IH_OS_NETBSD, "netbsd", "NetBSD", }, { IH_OS_OSE, "ose", "Enea OSE", }, { IH_OS_PLAN9, "plan9", "Plan 9", },
Thanks, Stefan
- Target Operating System (Provisions for OpenBSD, NetBSD, FreeBSD, 4.4BSD, Linux, SVR4, Esix, Solaris, Irix, SCO, Dell, NCR, VxWorks, LynxOS, pSOS, QNX, RTEMS, INTEGRITY;
- INTEGRITY).
- Currently supported: Linux, NetBSD, VxWorks, QNX, RTEMS, INTEGRITY).
- Target CPU Architecture (Provisions for Alpha, ARM, Intel x86,
Viele Grüße, Stefan Roese
- INTEGRITY).
Friendly ping!
Could someone pick this patch up? Thanks!
Happy new year, Thomas
Signed-off-by: Thomas Huth thuth@redhat.com Reviewed-by: Stefan Roese sr@denx.de
Stefan Roese
Thomas Huth
