[PATCH v2 0/2] riscv: spacemit: bananapi_f3: add support for Banana Pi F3 board
Banana Pi F3 board is a industrial grade RISC-V development board, it design with SpacemiT K1 8 core RISC-V chip, CPU integrates 2.0 TOPs AI computing power. 4G DDR and 16G eMMC onboard.2x GbE Ethernet prot, 4x USB 3.0 and PCIe for M.2 interface, support HDMI and Dual MIPI-CSI Camera.
This patch introduces fundamental support for the Banana Pi F3 board, encompassing UART, CPU, and PLIC support. This ensures that U-Boot can operate in serial console mode.
Changes in v2: - Change license to GPL-2.0-or-later - Add memory node for dts - Add ft_board_setup function for kernel memory init - Use default prompt
Kongyang Liu (2): riscv: spacemit: bananapi_f3: initial support added doc: spacemit: bananapi_f3: document Banana Pi F3 board
arch/riscv/Kconfig | 5 + arch/riscv/cpu/k1/Kconfig | 18 ++ arch/riscv/cpu/k1/Makefile | 6 + arch/riscv/cpu/k1/cpu.c | 9 + arch/riscv/cpu/k1/dram.c | 54 ++++ arch/riscv/dts/Makefile | 1 + arch/riscv/dts/k1-bananapi-f3.dts | 25 ++ arch/riscv/dts/k1.dtsi | 375 +++++++++++++++++++++++++ board/spacemit/bananapi_f3/Kconfig | 25 ++ board/spacemit/bananapi_f3/MAINTAINERS | 6 + board/spacemit/bananapi_f3/Makefile | 5 + board/spacemit/bananapi_f3/board.c | 9 + configs/bananapi_f3_defconfig | 20 ++ doc/board/index.rst | 1 + doc/board/spacemit/bananapi_f3.rst | 78 +++++ doc/board/spacemit/index.rst | 8 + include/configs/bananapi_f3.h | 15 + 17 files changed, 660 insertions(+) create mode 100644 arch/riscv/cpu/k1/Kconfig create mode 100644 arch/riscv/cpu/k1/Makefile create mode 100644 arch/riscv/cpu/k1/cpu.c create mode 100644 arch/riscv/cpu/k1/dram.c create mode 100644 arch/riscv/dts/k1-bananapi-f3.dts create mode 100644 arch/riscv/dts/k1.dtsi create mode 100644 board/spacemit/bananapi_f3/Kconfig create mode 100644 board/spacemit/bananapi_f3/MAINTAINERS create mode 100644 board/spacemit/bananapi_f3/Makefile create mode 100644 board/spacemit/bananapi_f3/board.c create mode 100644 configs/bananapi_f3_defconfig create mode 100644 doc/board/spacemit/bananapi_f3.rst create mode 100644 doc/board/spacemit/index.rst create mode 100644 include/configs/bananapi_f3.h
Add basic support for SpacemiT's Banana Pi F3 board
Signed-off-by: Kongyang Liu seashell11234455@gmail.com
arch/riscv/Kconfig | 5 + arch/riscv/cpu/k1/Kconfig | 18 ++ arch/riscv/cpu/k1/Makefile | 6 + arch/riscv/cpu/k1/cpu.c | 9 + arch/riscv/cpu/k1/dram.c | 54 ++++ arch/riscv/dts/Makefile | 1 + arch/riscv/dts/k1-bananapi-f3.dts | 25 ++ arch/riscv/dts/k1.dtsi | 375 +++++++++++++++++++++++++ board/spacemit/bananapi_f3/Kconfig | 25 ++ board/spacemit/bananapi_f3/MAINTAINERS | 6 + board/spacemit/bananapi_f3/Makefile | 5 + board/spacemit/bananapi_f3/board.c | 9 + configs/bananapi_f3_defconfig | 20 ++ include/configs/bananapi_f3.h | 15 + 14 files changed, 573 insertions(+) create mode 100644 arch/riscv/cpu/k1/Kconfig create mode 100644 arch/riscv/cpu/k1/Makefile create mode 100644 arch/riscv/cpu/k1/cpu.c create mode 100644 arch/riscv/cpu/k1/dram.c create mode 100644 arch/riscv/dts/k1-bananapi-f3.dts create mode 100644 arch/riscv/dts/k1.dtsi create mode 100644 board/spacemit/bananapi_f3/Kconfig create mode 100644 board/spacemit/bananapi_f3/MAINTAINERS create mode 100644 board/spacemit/bananapi_f3/Makefile create mode 100644 board/spacemit/bananapi_f3/board.c create mode 100644 configs/bananapi_f3_defconfig create mode 100644 include/configs/bananapi_f3.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fa3b016c52..211f19a585 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -11,6 +11,9 @@ choice config TARGET_ANDES_AE350 bool "Support Andes ae350"
+config TARGET_BANANAPI_F3 + bool "Support BananaPi F3 Board" + config TARGET_MICROCHIP_ICICLE bool "Support Microchip PolarFire-SoC Icicle Board"
@@ -88,6 +91,7 @@ source "board/sifive/unleashed/Kconfig" source "board/sifive/unmatched/Kconfig" source "board/sipeed/maix/Kconfig" source "board/sophgo/milkv_duo/Kconfig" +source "board/spacemit/bananapi_f3/Kconfig" source "board/starfive/visionfive2/Kconfig" source "board/thead/th1520_lpi4a/Kconfig" source "board/xilinx/mbv/Kconfig" @@ -99,6 +103,7 @@ source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig" source "arch/riscv/cpu/jh7110/Kconfig" +source "arch/riscv/cpu/k1/Kconfig"
# architecture-specific options below
diff --git a/arch/riscv/cpu/k1/Kconfig b/arch/riscv/cpu/k1/Kconfig new file mode 100644 index 0000000000..d9cd8dce96 --- /dev/null +++ b/arch/riscv/cpu/k1/Kconfig @@ -0,0 +1,18 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (C) 2024, Kongyang Liu seashell11234455@gmail.com + +config SPACEMIT_K1 + bool + select BINMAN + select ARCH_EARLY_INIT_R + select SYS_CACHE_SHIFT_6 + imply CPU + imply CPU_RISCV + imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) + imply RISCV_ACLINT if RISCV_MMODE + imply SPL_RISCV_ACLINT if SPL_RISCV_MMODE + imply CMD_CPU + imply SPL_CPU + imply SPL_OPENSBI + imply SPL_LOAD_FIT diff --git a/arch/riscv/cpu/k1/Makefile b/arch/riscv/cpu/k1/Makefile new file mode 100644 index 0000000000..bad4f4cf46 --- /dev/null +++ b/arch/riscv/cpu/k1/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + +obj-y += dram.o +obj-y += cpu.o diff --git a/arch/riscv/cpu/k1/cpu.c b/arch/riscv/cpu/k1/cpu.c new file mode 100644 index 0000000000..41a4a1b95e --- /dev/null +++ b/arch/riscv/cpu/k1/cpu.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +int cleanup_before_linux(void) +{ + return 0; +} diff --git a/arch/riscv/cpu/k1/dram.c b/arch/riscv/cpu/k1/dram.c new file mode 100644 index 0000000000..c477c15cbf --- /dev/null +++ b/arch/riscv/cpu/k1/dram.c @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +#include <asm/global_data.h> +#include <config.h> +#include <fdt_support.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_base = CFG_SYS_SDRAM_BASE; + /* TODO get ram size from ddr controller */ + gd->ram_size = SZ_4G; + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = min_t(phys_size_t, gd->ram_size, SZ_2G); + + if (gd->ram_size > SZ_2G && CONFIG_NR_DRAM_BANKS > 1) { + gd->bd->bi_dram[1].start = 0x100000000; + gd->bd->bi_dram[1].size = gd->ram_size - SZ_2G; + } + + return 0; +} + +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) +{ + if (gd->ram_size > SZ_2G) + return SZ_2G; + + return gd->ram_size; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + u64 start[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + int i; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + start[i] = gd->bd->bi_dram[i].start; + size[i] = gd->bd->bi_dram[i].size; + } + + return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); +} diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 17cda483e1..71267f96f8 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-$(CONFIG_TARGET_ANDES_AE350) += ae350_32.dtb ae350_64.dtb +dtb-$(CONFIG_TARGET_BANANAPI_F3) += k1-bananapi-f3.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += mpfs-icicle-kit.dtb dtb-$(CONFIG_TARGET_MILKV_DUO) += cv1800b-milkv-duo.dtb dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt32.dtb qemu-virt64.dtb diff --git a/arch/riscv/dts/k1-bananapi-f3.dts b/arch/riscv/dts/k1-bananapi-f3.dts new file mode 100644 index 0000000000..06fd26578f --- /dev/null +++ b/arch/riscv/dts/k1-bananapi-f3.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2024 Yangyu Chen cyy@cyyself.name + */ + +#include "k1.dtsi" +#include "binman.dtsi" + +/ { + model = "Banana Pi BPI-F3"; + compatible = "bananapi,bpi-f3", "spacemit,k1"; + + chosen { + stdout-path = "serial0"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x00000000 0x00000000 0x00000000 0x80000000>; + }; +}; + +&uart0 { + status = "okay"; +}; diff --git a/arch/riscv/dts/k1.dtsi b/arch/riscv/dts/k1.dtsi new file mode 100644 index 0000000000..b301f45fd5 --- /dev/null +++ b/arch/riscv/dts/k1.dtsi @@ -0,0 +1,375 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2024 Yangyu Chen cyy@cyyself.name + */ + +/dts-v1/; +/ { + #address-cells = <2>; + #size-cells = <2>; + model = "SpacemiT K1"; + compatible = "spacemit,k1"; + + aliases { + serial0 = &uart0; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + serial4 = &uart5; + serial5 = &uart6; + serial6 = &uart7; + serial7 = &uart8; + serial8 = &uart9; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <24000000>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu_0>; + }; + core1 { + cpu = <&cpu_1>; + }; + core2 { + cpu = <&cpu_2>; + }; + core3 { + cpu = <&cpu_3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu_4>; + }; + core1 { + cpu = <&cpu_5>; + }; + core2 { + cpu = <&cpu_6>; + }; + core3 { + cpu = <&cpu_7>; + }; + }; + }; + + cpu_0: cpu@0 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <0>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu0_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_1: cpu@1 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <1>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu1_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_2: cpu@2 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <2>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu2_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_3: cpu@3 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <3>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu3_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_4: cpu@4 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <4>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu4_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_5: cpu@5 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <5>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu5_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_6: cpu@6 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <6>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu6_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_7: cpu@7 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <7>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + mmu-type = "riscv,sv39"; + + cpu7_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + }; + + soc { + compatible = "simple-bus"; + interrupt-parent = <&plic>; + #address-cells = <2>; + #size-cells = <2>; + dma-noncoherent; + ranges; + + uart0: serial@d4017000 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017000 0x0 0x100>; + interrupts = <42>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart2: serial@d4017100 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017100 0x0 0x100>; + interrupts = <44>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart3: serial@d4017200 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017200 0x0 0x100>; + interrupts = <45>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart4: serial@d4017300 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017300 0x0 0x100>; + interrupts = <46>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart5: serial@d4017400 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017400 0x0 0x100>; + interrupts = <47>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart6: serial@d4017500 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017500 0x0 0x100>; + interrupts = <48>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart7: serial@d4017600 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017600 0x0 0x100>; + interrupts = <49>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart8: serial@d4017700 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017700 0x0 0x100>; + interrupts = <50>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart9: serial@d4017800 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017800 0x0 0x100>; + interrupts = <51>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + plic: interrupt-controller@e0000000 { + compatible = "spacemit,k1-plic", "sifive,plic-1.0.0"; + reg = <0x0 0xe0000000 0x0 0x4000000>; + interrupts-extended = <&cpu0_intc 11>, <&cpu0_intc 9>, + <&cpu1_intc 11>, <&cpu1_intc 9>, + <&cpu2_intc 11>, <&cpu2_intc 9>, + <&cpu3_intc 11>, <&cpu3_intc 9>, + <&cpu4_intc 11>, <&cpu4_intc 9>, + <&cpu5_intc 11>, <&cpu5_intc 9>, + <&cpu6_intc 11>, <&cpu6_intc 9>, + <&cpu7_intc 11>, <&cpu7_intc 9>; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + riscv,ndev = <159>; + }; + + clint: timer@e4000000 { + compatible = "spacemit,k1-clint", "sifive,clint0"; + reg = <0x0 0xe4000000 0x0 0x10000>; + interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>, + <&cpu1_intc 3>, <&cpu1_intc 7>, + <&cpu2_intc 3>, <&cpu2_intc 7>, + <&cpu3_intc 3>, <&cpu3_intc 7>, + <&cpu4_intc 3>, <&cpu4_intc 7>, + <&cpu5_intc 3>, <&cpu5_intc 7>, + <&cpu6_intc 3>, <&cpu6_intc 7>, + <&cpu7_intc 3>, <&cpu7_intc 7>; + }; + }; +}; diff --git a/board/spacemit/bananapi_f3/Kconfig b/board/spacemit/bananapi_f3/Kconfig new file mode 100644 index 0000000000..0082a0d2af --- /dev/null +++ b/board/spacemit/bananapi_f3/Kconfig @@ -0,0 +1,25 @@ +if TARGET_BANANAPI_F3 + +config SYS_BOARD + default "bananapi_f3" + +config SYS_VENDOR + default "spacemit" + +config SYS_CPU + default "k1" + +config SYS_CONFIG_NAME + default "bananapi_f3" + +config TEXT_BASE + default 0x00200000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x00000000 + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select SPACEMIT_K1 + +endif diff --git a/board/spacemit/bananapi_f3/MAINTAINERS b/board/spacemit/bananapi_f3/MAINTAINERS new file mode 100644 index 0000000000..fc0f8487e6 --- /dev/null +++ b/board/spacemit/bananapi_f3/MAINTAINERS @@ -0,0 +1,6 @@ +BananaPi F3 +M: Kongyang Liu seashell11234455@gmail.com +S: Maintained +F: board/spacemit/bananapi_f3/ +F: configs/bananapi_f3_defconfig +F: doc/board/spacemit/bananapi_f3.rst diff --git a/board/spacemit/bananapi_f3/Makefile b/board/spacemit/bananapi_f3/Makefile new file mode 100644 index 0000000000..2168698402 --- /dev/null +++ b/board/spacemit/bananapi_f3/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + +obj-y := board.o diff --git a/board/spacemit/bananapi_f3/board.c b/board/spacemit/bananapi_f3/board.c new file mode 100644 index 0000000000..2631cdd49e --- /dev/null +++ b/board/spacemit/bananapi_f3/board.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +int board_init(void) +{ + return 0; +} diff --git a/configs/bananapi_f3_defconfig b/configs/bananapi_f3_defconfig new file mode 100644 index 0000000000..6363620208 --- /dev/null +++ b/configs/bananapi_f3_defconfig @@ -0,0 +1,20 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000000 +CONFIG_DEFAULT_DEVICE_TREE="k1-bananapi-f3" +CONFIG_SYS_LOAD_ADDR=0x200000 +CONFIG_TARGET_BANANAPI_F3=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_FIT=y +CONFIG_SYS_BOOTM_LEN=0xa000000 +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_CBSIZE=256 +CONFIG_SYS_PBSIZE=276 +CONFIG_HUSH_PARSER=y +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_NS16550=y +CONFIG_SYS_NS16550_MEM32=y diff --git a/include/configs/bananapi_f3.h b/include/configs/bananapi_f3.h new file mode 100644 index 0000000000..723bbaab69 --- /dev/null +++ b/include/configs/bananapi_f3.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + * + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/serial_reg.h> + +#define CFG_SYS_SDRAM_BASE 0x0 +#define CFG_SYS_NS16550_IER UART_IER_UUE + +#endif /* __CONFIG_H */
Changes in v2:
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Changes in v2:
Hi Kongyang,
`$ make bananapi_f3_defconfig && make` produces the following warning.
In file included from drivers/serial/ns16550.c:13: include/ns16550.h:205:9: warning: "UART_IIR_ID" redefined 205 | #define UART_IIR_ID 0x06 /* Mask for the interrupt ID */ | ^~~~~~~~~~~ In file included from include/configs/bananapi_f3.h:10, from include/config.h:3, from drivers/serial/ns16550.c:8: include/linux/serial_reg.h:33:9: note: this is the location of the previous definition 33 | #define UART_IIR_ID 0x0e /* Mask for the interrupt ID */ | ^~~~~~~~~~~
There seems to be Macro redefinition. Could you please take a look?
Best regards, Leo
- Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com
Changes in v2:
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fa3b016c52..211f19a585 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -11,6 +11,9 @@ choice config TARGET_ANDES_AE350 bool "Support Andes ae350" +config TARGET_BANANAPI_F3
- bool "Support BananaPi F3 Board"
config TARGET_MICROCHIP_ICICLE bool "Support Microchip PolarFire-SoC Icicle Board" @@ -88,6 +91,7 @@ source "board/sifive/unleashed/Kconfig" source "board/sifive/unmatched/Kconfig" source "board/sipeed/maix/Kconfig" source "board/sophgo/milkv_duo/Kconfig" +source "board/spacemit/bananapi_f3/Kconfig"
Other Banana Pi stuff already upstream uses dash rather than underscore:
user@host:~/u-boot.git$ find doc/board/ -name '*banana*' doc/board/amlogic/bananapi-cm4io.rst doc/board/amlogic/bananapi-m2pro.rst doc/board/amlogic/bananapi-m2s.rst doc/board/amlogic/bananapi-m5.rst doc/board/spacemit/bananapi_f3.rst
source "board/starfive/visionfive2/Kconfig" source "board/thead/th1520_lpi4a/Kconfig" source "board/xilinx/mbv/Kconfig" @@ -99,6 +103,7 @@ source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig" source "arch/riscv/cpu/jh7110/Kconfig" +source "arch/riscv/cpu/k1/Kconfig" # architecture-specific options below diff --git a/arch/riscv/cpu/k1/Kconfig b/arch/riscv/cpu/k1/Kconfig new file mode 100644 index 0000000000..d9cd8dce96 --- /dev/null +++ b/arch/riscv/cpu/k1/Kconfig @@ -0,0 +1,18 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (C) 2024, Kongyang Liu seashell11234455@gmail.com
+config SPACEMIT_K1
- bool
- select BINMAN
- select ARCH_EARLY_INIT_R
- select SYS_CACHE_SHIFT_6
- imply CPU
- imply CPU_RISCV
- imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE)
- imply RISCV_ACLINT if RISCV_MMODE
- imply SPL_RISCV_ACLINT if SPL_RISCV_MMODE
- imply CMD_CPU
- imply SPL_CPU
- imply SPL_OPENSBI
- imply SPL_LOAD_FIT
- gd->ram_base = CFG_SYS_SDRAM_BASE;
- /* TODO get ram size from ddr controller */
- gd->ram_size = SZ_4G;
- gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE;
- gd->bd->bi_dram[0].size = min_t(phys_size_t, gd->ram_size, SZ_2G);
- if (gd->ram_size > SZ_2G && CONFIG_NR_DRAM_BANKS > 1) {
- if (gd->ram_size > SZ_2G)
return SZ_2G;
- return gd->ram_size;
- u64 start[CONFIG_NR_DRAM_BANKS];
- u64 size[CONFIG_NR_DRAM_BANKS];
- int i;
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) {
- return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS);
+} diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 17cda483e1..71267f96f8 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ dtb-$(CONFIG_TARGET_ANDES_AE350) += ae350_32.dtb ae350_64.dtb +dtb-$(CONFIG_TARGET_BANANAPI_F3) += k1-bananapi-f3.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += mpfs-icicle-kit.dtb dtb-$(CONFIG_TARGET_MILKV_DUO) += cv1800b-milkv-duo.dtb dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt32.dtb qemu-virt64.dtb diff --git a/arch/riscv/dts/k1-bananapi-f3.dts b/arch/riscv/dts/k1-bananapi-f3.dts new file mode 100644 index 0000000000..06fd26578f --- /dev/null +++ b/arch/riscv/dts/k1-bananapi-f3.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT
Usually device tree sources use: GPL-2.0-or-later OR MIT
- Copyright (C) 2024 Yangyu Chen cyy@cyyself.name
- model = "Banana Pi BPI-F3";
- compatible = "bananapi,bpi-f3", "spacemit,k1";
- chosen {
- memory@0 {
+&uart0 {
- status = "okay";
Ditto.
+/dts-v1/; +/ {
- #address-cells = <2>;
- #size-cells = <2>;
- model = "SpacemiT K1";
- compatible = "spacemit,k1";
- aliases {
serial0 = &uart0;
serial1 = &uart2;
Intentional to skip uart1?
serial2 = &uart3;
serial3 = &uart4;
serial4 = &uart5;
serial5 = &uart6;
serial6 = &uart7;
serial7 = &uart8;
serial8 = &uart9;
- cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&cpu_0>;
core1 {
cpu = <&cpu_1>;
core2 {
cpu = <&cpu_2>;
core3 {
cpu = <&cpu_3>;
cluster1 {
core0 {
cpu = <&cpu_4>;
core1 {
cpu = <&cpu_5>;
core2 {
cpu = <&cpu_6>;
core3 {
cpu = <&cpu_7>;
cpu_0: cpu@0 {
reg = <0>;
riscv,isa =
"rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh _zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt";
cpu_1: cpu@1 {
reg = <1>;
riscv,isa =
cpu_2: cpu@2 {
reg = <2>;
riscv,isa =
cpu_3: cpu@3 {
reg = <3>;
riscv,isa =
cpu_4: cpu@4 {
reg = <4>;
riscv,isa =
cpu_5: cpu@5 {
reg = <5>;
riscv,isa =
cpu_6: cpu@6 {
reg = <6>;
riscv,isa =
cpu_7: cpu@7 {
reg = <7>;
riscv,isa =
- soc {
#size-cells = <2>;
dma-noncoherent;
ranges;
interrupts = <42>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <44>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <45>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <46>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <47>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <48>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <49>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <50>;
reg-shift = <2>;
reg-io-width = <4>;
interrupts = <51>;
reg-shift = <2>;
reg-io-width = <4>;
riscv,ndev = <159>;
Ditto with the underscore vs. dash in the file resp. folder name.
+config SYS_BOARD
- default "bananapi_f3"
+config SYS_VENDOR
- default "spacemit"
+config SYS_CPU
- default "k1"
+config TEXT_BASE
- default 0x00200000
- default 0x00000000
- def_bool y
- select SPACEMIT_K1
do.
do.
Add document for Banana Pi F3 board which based on SpacemiT's K1 SoC.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com ---
(no changes since v1)
doc/board/index.rst | 1 + doc/board/spacemit/bananapi_f3.rst | 78 ++++++++++++++++++++++++++++++ doc/board/spacemit/index.rst | 8 +++ 3 files changed, 87 insertions(+) create mode 100644 doc/board/spacemit/bananapi_f3.rst create mode 100644 doc/board/spacemit/index.rst
diff --git a/doc/board/index.rst b/doc/board/index.rst index 417c128c7a..367da2d623 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -51,6 +51,7 @@ Board-specific doc sipeed/index socionext/index sophgo/index + spacemit/index st/index starfive/index ste/index diff --git a/doc/board/spacemit/bananapi_f3.rst b/doc/board/spacemit/bananapi_f3.rst new file mode 100644 index 0000000000..cf3041085f --- /dev/null +++ b/doc/board/spacemit/bananapi_f3.rst @@ -0,0 +1,78 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later + +Banana Pi F3 +============ + +About This +---------- +Banana Pi F3 board is a industrial grade RISC-V development board, it +design with SpacemiT K1 8 core RISC-V chip, CPU integrates 2.0 TOPs AI +computing power. 4G DDR and 16G eMMC onboard.2x GbE Ethernet prot, 4x USB +3.0 and PCIe for M.2 interface, support HDMI and Dual MIPI-CSI Camera. + +Building +~~~~~~~~ +1. Add the RISC-V toolchain to your PATH. +2. Setup ARCH & cross compilation environment variable: + +.. code-block:: console + + export CROSS_COMPILE=<riscv64 toolchain prefix> + +3. Before building U-Boot, OpenSBI should be built first. OpenSBI can be +built for SpacemiT K1 SoC as below: + +.. code-block:: console + + git clone https://github.com/cyyself/opensbi -b k1-opensbi + cd opensbi + make PLATFORM=generic + +4. Then build U-Boot as following: + +.. code-block:: console + + cd <U-Boot-dir> + make bananapi_f3_defconfig + make OPENSBI=<OpenSBI-dir>/build/platform/generic/firmware/fw_dynamic.bin + +This will generate u-boot.itb + +Booting +~~~~~~~ +Currently, we use a modified vendor's U-Boot SPL to load a FIT image that +includes OpenSBI and U-Boot. Fully describing how to boot into U-Boot is a +challenging task. And the booting method will be added after the SPL +support is available. + +Sample boot log from Banana Pi F3 board +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ +.. code-block:: none + + U-Boot 2024.07-00686-g608f2d51760c (Jul 08 2024 - 14:53:51 +0800) + + DRAM: 4 GiB + Core: 18 devices, 7 uclasses, devicetree: separate + Loading Environment from nowhere... OK + In: serial@d4017000 + Out: serial@d4017000 + Err: serial@d4017000 + Net: No ethernet found. + bananapi_f3# cpu detail + 0: cpu@0 spacemit,x60 + ID = 0, freq = 0 Hz: MMU + 1: cpu@1 spacemit,x60 + ID = 1, freq = 0 Hz: MMU + 2: cpu@2 spacemit,x60 + ID = 2, freq = 0 Hz: MMU + 3: cpu@3 spacemit,x60 + ID = 3, freq = 0 Hz: MMU + 4: cpu@4 spacemit,x60 + ID = 4, freq = 0 Hz: MMU + 5: cpu@5 spacemit,x60 + ID = 5, freq = 0 Hz: MMU + 6: cpu@6 spacemit,x60 + ID = 6, freq = 0 Hz: MMU + 7: cpu@7 spacemit,x60 + ID = 7, freq = 0 Hz: MMU + bananapi_f3# diff --git a/doc/board/spacemit/index.rst b/doc/board/spacemit/index.rst new file mode 100644 index 0000000000..78081a47ff --- /dev/null +++ b/doc/board/spacemit/index.rst @@ -0,0 +1,8 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later + +SpacemiT +======== +.. toctree:: + :maxdepth: 1 + + bananapi_f3
do. missing space before 2x and port rather than prot
+ git clone https://github.com/cyyself/opensbi%C2%A0-b k1-opensbi + cd opensbi + make PLATFORM=generic
Hm, would be great if one could at least test it somehow on real hardware. We do have boards available BTW (;- p).
+ bananapi_f3
do.
Changes in v2:
Kongyang Liu
Leo Liang
Marcel Ziswiler
