[U-Boot-Users] [PATCH] USB: fix those pesky aliasing warnings caused by gcc-4.2
Signed-off-by: Markus Klotzbuecher mk@denx.de Signed-off-by: Detlev Zundel dzu@denx.de
drivers/usb/usb_ohci.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/usb_ohci.c b/drivers/usb/usb_ohci.c index 5c201b3..d37a037 100644 --- a/drivers/usb/usb_ohci.c +++ b/drivers/usb/usb_ohci.c @@ -86,11 +86,11 @@ * e.g. PCI controllers need this */ #ifdef CFG_OHCI_SWAP_REG_ACCESS -# define readl(a) __swap_32(*((vu_long *)(a))) -# define writel(a, b) (*((vu_long *)(b)) = __swap_32((vu_long)a)) +# define readl(a) __swap_32(*((volatile u32 *)(a))) +# define writel(a, b) (*((volatile u32 *)(b)) = __swap_32((volatile u32)a)) #else -# define readl(a) (*((vu_long *)(a))) -# define writel(a, b) (*((vu_long *)(b)) = ((vu_long)a)) +# define readl(a) (*((volatile u32 *)(a))) +# define writel(a, b) (*((volatile u32 *)(b)) = ((volatile u32)a)) #endif /* CFG_OHCI_SWAP_REG_ACCESS */
#define min_t(type,x,y) ({ type __x = (x); type __y = (y); __x < __y ? __x: __y; })
Best regards
Markus Klotzbuecher
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
USB: remove a cpu bug workaround for an unsupported architecture.
drivers/usb/usb_ohci.c | 22 ++++------------------ 1 files changed, 4 insertions(+), 18 deletions(-)
diff --git a/drivers/usb/usb_ohci.c b/drivers/usb/usb_ohci.c index d37a037..ee0f2e4 100644 --- a/drivers/usb/usb_ohci.c +++ b/drivers/usb/usb_ohci.c @@ -138,28 +138,14 @@ int got_rhsc; /* device which was disconnected */ struct usb_device *devgone;
-/*-------------------------------------------------------------------------*/ - -/* AMD-756 (D2 rev) reports corrupt register contents in some cases. - * The erratum (#4) description is incorrect. AMD's workaround waits - * till some bits (mostly reserved) are clear; ok for all revs. - */ -#define OHCI_QUIRK_AMD756 0xabcd -#define read_roothub(hc, register, mask) ({ \ - u32 temp = readl (&hc->regs->roothub.register); \ - if (hc->flags & OHCI_QUIRK_AMD756) \ - while (temp & mask) \ - temp = readl (&hc->regs->roothub.register); \ - temp; }) - -static u32 roothub_a (struct ohci *hc) - { return read_roothub (hc, a, 0xfc0fe000); } +static inline u32 roothub_a (struct ohci *hc) + { return readl (&hc->regs->roothub.a); } static inline u32 roothub_b (struct ohci *hc) { return readl (&hc->regs->roothub.b); } static inline u32 roothub_status (struct ohci *hc) { return readl (&hc->regs->roothub.status); } -static u32 roothub_portstatus (struct ohci *hc, int i) - { return read_roothub (hc, portstatus [i], 0xffe0fce0); } +static inline u32 roothub_portstatus (struct ohci *hc, int i) + { return readl (&hc->regs->roothub.portstatus[i]); }
/* forward declaration */ static int hc_interrupt (void);
Best regards
Markus
Applied, thanks.
Please do not duplicate the subject line, or it will end up twice in the commit log.
And - GCC just prints the warnings, they are caused by coding issues :-)
Applied - thanks a lot!
Markus Klotzbücher
