[U-Boot] Please pull ARC fixes for v2020.01-rc2
Hi Tom,
The following changes since commit 82679624f9aa6d1be733c46f3555d5166b6f5b72:
Merge branch '2019-10-30-master-imports' (2019-11-01 09:23:21 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-arc.git tags/arc-fixes-for-2020.01-rc2
for you to fetch changes up to 3f6b4ea225656b41613fd538925e29141f22c4a7:
arc: emsdp: docs: Prefer Degilent over Opella-XD (2019-11-01 16:45:40 +0300)
Please note that there's something new in this pull-request which is reset driver for ARC HSDK board. Due to ELCE and preparations [as always :(] I completely forgot to send out ARC changes in time of merge window.
That said if you prefer I may re-send you the same pull-request with HSDK reset driver removed so that only real fixes will be in.
Sorry for that anyways.
---------------------------------------------------------------- ARC fixes for v2020.01-rc2
The main change is move to DM_MMC of yet 2 another ARC boards: AXS101 & IoTDK.
Among that we improve handling of stock-formatted SD-cards of high volume on EM SDP as well as introduction of reset driver for HSDK which is required for prepser reinitialization of some peripherals like USB etc.
---------------------------------------------------------------- Alexey Brodkin (3): arc: emsdp: Increase max FAT cluster size arc: emsdp/iotdk: Switch to DM_MMC arc: emsdp: docs: Prefer Degilent over Opella-XD
Eugeniy Paltsev (3): ARC: HSDK: introduce reset driver MAINTAINERS: add info about ARC HSDK reset driver ARC: [plat-axs101]: migrate to DM_MMC
MAINTAINERS | 7 +++++++ arch/arc/dts/emsdp.dts | 23 +++++++++++++++++++++++ arch/arc/dts/iot_devkit.dts | 22 ++++++++++++++++++++++ board/synopsys/emsdp/README | 2 +- board/synopsys/emsdp/emsdp.c | 29 ----------------------------- board/synopsys/iot_devkit/iot_devkit.c | 32 -------------------------------- configs/axs101_defconfig | 2 ++ configs/emsdp_defconfig | 4 +++- configs/iot_devkit_defconfig | 2 ++ drivers/reset/Kconfig | 7 +++++++ drivers/reset/Makefile | 1 + drivers/reset/reset-hsdk.c | 116 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/dt-bindings/reset/snps,hsdk-reset.h | 17 +++++++++++++++++ 13 files changed, 201 insertions(+), 63 deletions(-) create mode 100644 drivers/reset/reset-hsdk.c create mode 100644 include/dt-bindings/reset/snps,hsdk-reset.h
Regards, Alexey
On Fri, Nov 01, 2019 at 02:04:44PM +0000, Alexey Brodkin wrote:
Hi Tom,
Alexey Brodkin
