[PATCH 1/1] doc: describe exit command
Man-page for exit shell command.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/usage/exit.rst | 40 ++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 41 insertions(+) create mode 100644 doc/usage/exit.rst
diff --git a/doc/usage/exit.rst b/doc/usage/exit.rst new file mode 100644 index 0000000000..c220e30236 --- /dev/null +++ b/doc/usage/exit.rst @@ -0,0 +1,40 @@ +exit command +============ + +Synopsis +-------- + +:: + + exit + +Description +----------- + +The exit command terminates a script started via the run or source command. +If scripts are nested, only the innermost script is left. + +:: + + => setenv inner 'echo entry inner; exit; echo inner done' + => setenv outer 'echo entry outer; run inner; echo outer done' + => run outer + entry outer + entry inner + outer done + => + +When executed outside a script a warning is written. Following commands are not +executed. + +:: + + => echo first; exit; echo last + first + exit not allowed from main input shell. + => + +Return value +------------ + +$? is always set to 0. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index eedcdb110b..b8f216b713 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -17,6 +17,7 @@ Shell commands bootefi bootmenu button + exit mbr pstore sbi -- 2.29.2
