why do we have two files(env_nand.c and env_flash.c) to manipulate environmental variables?
According to my knowledge nand is also a flash type then why we have separate file called env_flash.c or is this file will be used for nor flash?
chandru
Dear Chandra Sekar,
In message 67b11d980912162018j3febe826l91c6b52134123d37@mail.gmail.com you wrote:
Because NAND flahrequires diofferent handling than NOR flash.
Note there is also common/env_dataflash.c, common/env_eeprom.c, common/env_mgdisk.c, common/env_nowhere.c, common/env_nvram.c, common/env_onenand.c, and common/env_sf.c
NOR flash is a memory device which is byte-addressable by the processor. NAND flash is no memory, but a storage device instead, which needs to be read in buffers into RAM before you can access arbitrary bytes of it's content.
Chandra Sekar
