[U-Boot] [ppc4xx] Please pull git://www.denx.de/git/u-boot-ppc4xx.git
The following changes since commit f158c3d51838474c4c36af365af145fbaf92b694: Wolfgang Denk (1): Merge branch 'master' of ssh://10.10.0.7/home/wd/git/u-boot/master
git://www.denx.de/git/u-boot-ppc4xx.git master
Adam Graham (2): ppc4xx: IBM Memory Controller DDR autocalibration routines ppc4xx: Update Kilauea to use PPC4xx DDR autocalibration routines
Matthias Fuchs (3): ppc4xx: Update CPCI405 variants handling ppc4xx: Cleanup CPCI405 linker script ppc4xx: Update CPCI405(AB) configuration
Ricardo Ribalda Delgado (1): ppc44x: Unification of virtex5 pp440 boards
Stefan Roese (4): ppc4xx: Fix compilation warning for canyonlands & glacier ppc4xx: Fix compilation warning for PIP405 ppc4xx: Remove CONFIG_CS8952_PHY define ppc4xx: Move ppc4xx specific prototypes to ppc4xx header
Victor Gallardo (1): ppc4xx: Add support for GPCS, SGMII and M88E1112 PHY
CREDITS | 3 +- MAINTAINERS | 2 + MAKEALL | 4 + Makefile | 47 +- board/avnet/v5fx30teval/.gitignore | 1 + .../ml507/config.mk => avnet/v5fx30teval/Makefile} | 12 +- board/avnet/v5fx30teval/v5fx30teval.c | 28 + board/avnet/v5fx30teval/xparameters.h | 33 + board/esd/cpci405/config.mk | 16 +- board/esd/cpci405/u-boot.lds | 15 - board/xilinx/ml507/.gitignore | 1 + board/xilinx/ml507/Makefile | 41 +- board/xilinx/ml507/init.S | 53 - board/xilinx/ml507/ml507.c | 21 +- board/xilinx/ml507/xparameters.h | 17 +- board/xilinx/ppc440-generic/.gitignore | 1 + board/xilinx/ppc440-generic/Makefile | 62 + board/xilinx/ppc440-generic/init.S | 45 + .../{ml507 => ppc440-generic}/u-boot-ram.lds | 0 .../{ml507 => ppc440-generic}/u-boot-rom.lds | 0 .../xilinx/ppc440-generic/xilinx_ppc440_generic.c | 52 + board/xilinx/ppc440-generic/xparameters.h | 34 + cpu/ppc4xx/44x_spd_ddr2.c | 158 ++- cpu/ppc4xx/4xx_enet.c | 168 +++- cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c | 1212 ++++++++++++++++++++ cpu/ppc4xx/Makefile | 3 + cpu/ppc4xx/miiphy.c | 37 +- include/asm-ppc/ppc4xx-sdram.h | 3 +- include/configs/CPCI4052.h | 6 + include/configs/CPCI405AB.h | 6 + include/configs/PIP405.h | 1 - include/configs/kilauea.h | 19 + include/configs/ml507.h | 91 +-- include/configs/v5fx30teval.h | 49 + include/configs/xilinx-ppc440-generic.h | 49 + include/configs/xilinx-ppc440.h | 106 ++ include/ppc440.h | 13 - include/ppc4xx.h | 13 + include/ppc4xx_enet.h | 3 + 41 files changed, 2112 insertions(+), 336 deletions(-) create mode 100644 board/avnet/v5fx30teval/.gitignore rename board/{xilinx/ml507/config.mk => avnet/v5fx30teval/Makefile} (76%) create mode 100644 board/avnet/v5fx30teval/v5fx30teval.c create mode 100644 board/avnet/v5fx30teval/xparameters.h create mode 100644 board/xilinx/ml507/.gitignore delete mode 100644 board/xilinx/ml507/init.S create mode 100644 board/xilinx/ppc440-generic/.gitignore create mode 100644 board/xilinx/ppc440-generic/Makefile create mode 100644 board/xilinx/ppc440-generic/init.S rename board/xilinx/{ml507 => ppc440-generic}/u-boot-ram.lds (100%) rename board/xilinx/{ml507 => ppc440-generic}/u-boot-rom.lds (100%) create mode 100644 board/xilinx/ppc440-generic/xilinx_ppc440_generic.c create mode 100644 board/xilinx/ppc440-generic/xparameters.h create mode 100644 cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c create mode 100644 include/configs/v5fx30teval.h create mode 100644 include/configs/xilinx-ppc440-generic.h create mode 100644 include/configs/xilinx-ppc440.h
Dear Stefan Roese,
Applied, thanks.
Dear Stefan Roese,
This merge...
...and actually most probably these commits:
... break out-of-tree building:
========== CPCI4052 ========== System not configured - see README make: *** [all] Error 1 ========== CPCI405AB ========== System not configured - see README make: *** [all] Error 1 ========== CPCI405DT ========== System not configured - see README make: *** [all] Error 1
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- Makefile | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index 73421db..251cdec 100644 --- a/Makefile +++ b/Makefile @@ -1248,6 +1248,7 @@ CPCI405_config: unconfig CPCI4052_config \ CPCI405DT_config \ CPCI405AB_config: unconfig + @mkdir -p $(obj)board/esd/cpci405 @echo "TEXT_BASE = 0xFFFC0000" > $(obj)board/esd/cpci405/config.tmp @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpci405 esd
Acked-by: Stefan Roese sr@denx.de
Matthias, thanks for the quick fix.
Best regards, Stefan
Dear Matthias Fuchs,
Applied, thanks.
Matthias Fuchs
Stefan Roese
