[U-Boot] [PATCH] ARM: dts: da850-lcdk: Update DTS files for SPL device tree support
Currently, the da850-lcdk uses SPL_OF_PLATDATA and manually loads the necessary source code instead of using the auto-generated, because the drivers don't properly autogenerate the code.
This patch simply enables the various device tree options to mimic the da850-evm which doesn't need or use OF_PLATDATA for device tree support. It does not disable OF_PLATDATA.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/da850-lcdk-u-boot.dtsi b/arch/arm/dts/da850-lcdk-u-boot.dtsi index 541f4ca200..b372d06ca9 100644 --- a/arch/arm/dts/da850-lcdk-u-boot.dtsi +++ b/arch/arm/dts/da850-lcdk-u-boot.dtsi @@ -8,9 +8,23 @@ / { aliases { i2c0 = &i2c0; + mmc0 = &mmc0; + serial2 = &serial2; + }; + + soc@1c00000 { + u-boot,dm-spl; };
nand { compatible = "ti,davinci-nand"; }; }; + +&mmc0 { + u-boot,dm-spl; +}; + +&serial2 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/da850-lcdk.dts b/arch/arm/dts/da850-lcdk.dts index 0177e3ed20..db8ae566f3 100644 --- a/arch/arm/dts/da850-lcdk.dts +++ b/arch/arm/dts/da850-lcdk.dts @@ -18,7 +18,7 @@ };
chosen { - stdout-path = "serial2:115200n8"; + stdout-path = &serial2; };
memory@c0000000 {
mmc0 = &mmc0;
serial2 = &serial2;
soc@1c00000 {
u-boot,dm-spl; }; nand { compatible = "ti,davinci-nand"; };
+&mmc0 {
u-boot,dm-spl;
+&serial2 {
u-boot,dm-spl;
chosen {
stdout-path = &serial2; }; memory@c0000000 {
-- 2.20.1
Hi Adam,
the generated platdata has wrong driver names. I'm not sure how these are generated but at first glance it looks like the compatible string is transformed by converting commas and hyphens into underscores. This of course won't work as the real driver names are different and the lookup fails (with your patch - if I remove the serial U_BOOT_DEVICE() from the board file, the serial stops working). Are you aware of how other SPL users handle this?
Bart
Merged into u-boot-ti.
Thanks and regards, Lokesh
Adam Ford
Bartosz Golaszewski
Lokesh Vutla
