[PATCH 1/2] arm64: dts: rockchip: Fix spl-boot-order for edgeble-ncm6b
Edgeble NCM6B SoM has built-in eMMC so make sdhci has first boot priority.
Fix it for NCM6A, NCM6B SoM.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi | 6 +----- arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi | 11 ++++++----- 2 files changed, 7 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi b/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi index dd0058262b..88f3f7eee2 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi +++ b/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi @@ -6,12 +6,8 @@ #include "rk3588-u-boot.dtsi"
/ { - aliases { - mmc0 = &sdmmc; - }; - chosen { - u-boot,spl-boot-order = &sdmmc; + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; }; };
diff --git a/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi b/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi index a45b3f5e86..289578803e 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi +++ b/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi @@ -6,11 +6,12 @@ #include "rk3588j-u-boot.dtsi"
/ { - aliases { - mmc0 = &sdmmc; - }; - chosen { - u-boot,spl-boot-order = &sdmmc; + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; }; }; + +&sdmmc { + bus-width = <4>; + status = "okay"; +};
Add support for USB OTG with UMS to program eMMC.
Add it for Edgeble NCM6A, NCM6B.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- .../dts/rk3588-edgeble-neu6a-io-u-boot.dtsi | 18 ++++++++++++++++++ .../dts/rk3588-edgeble-neu6b-io-u-boot.dtsi | 18 ++++++++++++++++++ configs/neu6a-io-rk3588_defconfig | 9 +++++++++ configs/neu6b-io-rk3588_defconfig | 9 +++++++++ 4 files changed, 54 insertions(+)
diff --git a/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi b/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi index 88f3f7eee2..534d9f8a2c 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi +++ b/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi @@ -15,3 +15,21 @@ bus-width = <4>; status = "okay"; }; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +&usb_host0_xhci { + dr_mode = "peripheral"; + maximum-speed = "high-speed"; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi b/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi index 289578803e..b3d17a60ce 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi +++ b/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi @@ -15,3 +15,21 @@ bus-width = <4>; status = "okay"; }; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +&usb_host0_xhci { + dr_mode = "peripheral"; + maximum-speed = "high-speed"; + status = "okay"; +}; diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index ac281e6539..6e50d06458 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_ATF=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y @@ -33,6 +34,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -42,6 +44,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_USBDP=y CONFIG_SPL_PINCTRL=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y @@ -49,4 +53,9 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_ERRNO_STR=y diff --git a/configs/neu6b-io-rk3588_defconfig b/configs/neu6b-io-rk3588_defconfig index c01e5fb0d0..f2eb650f19 100644 --- a/configs/neu6b-io-rk3588_defconfig +++ b/configs/neu6b-io-rk3588_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_ATF=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y @@ -33,6 +34,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -42,6 +44,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_USBDP=y CONFIG_SPL_PINCTRL=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y @@ -49,4 +53,9 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_ERRNO_STR=y
hi Jagan,
Reviewed-by: Anand Moon anand@edgeble.ai
+&u2phy0 {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&usbdp_phy0 {
status = "okay";
+&usb_host0_xhci {
status = "okay";
+&u2phy0 {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&usbdp_phy0 {
status = "okay";
+&usb_host0_xhci {
status = "okay";
+}; diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index ac281e6539..6e50d06458 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_ATF=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y @@ -33,6 +34,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -42,6 +44,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_USBDP=y CONFIG_SPL_PINCTRL=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y @@ -49,4 +53,9 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_ERRNO_STR=y diff --git a/configs/neu6b-io-rk3588_defconfig b/configs/neu6b-io-rk3588_defconfig index c01e5fb0d0..f2eb650f19 100644 --- a/configs/neu6b-io-rk3588_defconfig +++ b/configs/neu6b-io-rk3588_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_ATF=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y @@ -33,6 +34,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -42,6 +44,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_USBDP=y CONFIG_SPL_PINCTRL=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y @@ -49,4 +53,9 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_ERRNO_STR=y -- 2.34.1
Hi Jagan,
+&u2phy0 {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&usbdp_phy0 {
- status = "okay";
+&usb_host0_xhci {
- dr_mode = "peripheral";
- maximum-speed = "high-speed";
- status = "okay";
+&u2phy0 {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&usbdp_phy0 {
- status = "okay";
+&usb_host0_xhci {
- status = "okay";
I don't see those patches in v6.10-rc1. Have you sent those to upstream already? I assume we should cherry-pick patches in dts/upstream instead of piling stuff up in u-boot.dtsis. This should also bring the patches in rk3588(s).dtsi to add the missing bits for USB support we currently have in rk3588*-u-boot.dtsi?
Cheers, Quentin
On Mon, 27 May 2024 at 14:17, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Jagan,
+&u2phy0 {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&usbdp_phy0 {
status = "okay";
+&usb_host0_xhci {
status = "okay";
+&u2phy0 {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&usbdp_phy0 {
status = "okay";
+&usb_host0_xhci {
status = "okay";
These are -u-boot.dtsi and nothing to do with dts/upstream and can be removed or reconfigured once we sync the DT from Linux.
Jagan.
Hi Jagan,
Hi Jagan,
+&u2phy0 {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&usbdp_phy0 {
status = "okay";
+&usb_host0_xhci {
status = "okay";
+&u2phy0 {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&usbdp_phy0 {
status = "okay";
+&usb_host0_xhci {
status = "okay";
This answer seems to suggest there are no patches in the kernel yet. Do you not want working USB in Linux? Is something broken in Linux?
I think we're also aiming at only having U-Boot specific stuff in -u-boot.dtsi wherever we have OF_UPSTREAM enabled, and enabling USB doesn't seem to be typically the thing that should be U-Boot specific? I know that we have most rk3588/rk3588s boards with those nodes defined already, but they predates the move to OF_UPSTREAM.
As far as I remember, we've always asked people to upstream DT stuff they could upstream first and then import them in -u-boot.dtsi later, except for things that are U-Boot specific (e.g. different representation at a given point in time between U-Boot and kernel, or simple support in U-Boot but nothing in kernel yet). We could be a bit more aggressive with this policy now that we have dts/upstream as well. Ultimately this is up to Kever/Tom to decide where we want to go with this and how strict we want the policy to be.
Cheers, Quentin
Hi Jagan,
aliases {
mmc0 = &sdmmc;
chosen {
aliases {
mmc0 = &sdmmc;
chosen {
+&sdmmc {
bus-width = <4>;
status = "okay";
2.34.1
Hi Jagan,
- aliases {
mmc0 = &sdmmc;
- chosen {
}; };u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc;
- aliases {
mmc0 = &sdmmc;
- chosen {
+&sdmmc {
- bus-width = <4>;
- status = "okay";
The sdmmc parts are already part of dts/upstream/src/arm64/rockchip/rk3588-edgeble-neu6b-io.dts, are you sure this is actually needed?
Cheers, Quentin
Anand Moon
Jagan Teki
Quentin Schulz
