[U-Boot] [PATCH] ARM: rmobile: Update H2 Stout
The H2 Stout port was broken since some time. This patch updates the H2 Stout port to use modern frameworks, DM, DT probing, SPL and TPL for the preloading and puts it on par with the M2 Porter board.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/mach-rmobile/Kconfig.32 | 3 + board/renesas/stout/Makefile | 6 +- board/renesas/stout/cpld.c | 16 +- board/renesas/stout/stout.c | 135 ++--------- board/renesas/stout/stout_spl.c | 481 +++++++++++++++++++++++++++++++++++++++ configs/stout_defconfig | 70 +++++- include/configs/stout.h | 55 ++--- 7 files changed, 597 insertions(+), 169 deletions(-) create mode 100644 board/renesas/stout/stout_spl.c
diff --git a/arch/arm/mach-rmobile/Kconfig.32 b/arch/arm/mach-rmobile/Kconfig.32 index 97260dfefb..37e0cbab79 100644 --- a/arch/arm/mach-rmobile/Kconfig.32 +++ b/arch/arm/mach-rmobile/Kconfig.32 @@ -78,6 +78,9 @@ config TARGET_STOUT bool "Stout board" select DM select DM_SERIAL + select SUPPORT_TPL + select SUPPORT_SPL + select SPL_DM if SPL
endchoice
diff --git a/board/renesas/stout/Makefile b/board/renesas/stout/Makefile index cb7c61d020..b8875bb7b9 100644 --- a/board/renesas/stout/Makefile +++ b/board/renesas/stout/Makefile @@ -8,4 +8,8 @@ # SPDX-License-Identifier: GPL-2.0 #
-obj-y := stout.o cpld.o qos.o ../rcar-common/common.o +ifdef CONFIG_SPL_BUILD +obj-y := stout_spl.o +else +obj-y := stout.o cpld.o qos.o +endif diff --git a/board/renesas/stout/cpld.c b/board/renesas/stout/cpld.c index 5640e1d28e..fc1e30ca57 100644 --- a/board/renesas/stout/cpld.c +++ b/board/renesas/stout/cpld.c @@ -13,10 +13,10 @@ #include <asm/gpio.h> #include "cpld.h"
-#define SCLK GPIO_GP_3_24 -#define SSTBZ GPIO_GP_3_25 -#define MOSI GPIO_GP_3_26 -#define MISO GPIO_GP_3_27 +#define SCLK (92 + 24) +#define SSTBZ (92 + 25) +#define MOSI (92 + 26) +#define MISO (92 + 27)
#define CPLD_ADDR_MODE 0x00 /* RW */ #define CPLD_ADDR_MUX 0x01 /* RW */ @@ -91,10 +91,10 @@ void cpld_init(void) val |= PUPR3_SD3_DAT1; writel(val, PUPR3);
- gpio_request(SCLK, NULL); - gpio_request(SSTBZ, NULL); - gpio_request(MOSI, NULL); - gpio_request(MISO, NULL); + gpio_request(SCLK, "SCLK"); + gpio_request(SSTBZ, "SSTBZ"); + gpio_request(MOSI, "MOSI"); + gpio_request(MISO, "MISO");
gpio_direction_output(SCLK, 0); gpio_direction_output(SSTBZ, 1); diff --git a/board/renesas/stout/stout.c b/board/renesas/stout/stout.c index 3cb16db10f..d7e81292a0 100644 --- a/board/renesas/stout/stout.c +++ b/board/renesas/stout/stout.c @@ -59,14 +59,7 @@ void s_init(void) qos_init(); }
-#define TMU0_MSTP125 (1 << 25) -#define SCIFA0_MSTP204 (1 << 4) -#define SDHI0_MSTP314 (1 << 14) -#define SDHI2_MSTP312 (1 << 12) -#define ETHER_MSTP813 (1 << 13) - -#define MSTPSR3 0xE6150048 -#define SMSTPCR3 0xE615013C +#define TMU0_MSTP125 BIT(25)
#define SD2CKCR 0xE6150078 #define SD2_97500KHZ 0x7 @@ -75,12 +68,6 @@ int board_early_init_f(void) { /* TMU0 */ mstp_clrbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); - /* SCIFA0 */ - mstp_clrbits_le32(MSTPSR2, SMSTPCR2, SCIFA0_MSTP204); - /* ETHER */ - mstp_clrbits_le32(MSTPSR8, SMSTPCR8, ETHER_MSTP813); - /* SDHI0,2 */ - mstp_clrbits_le32(MSTPSR3, SMSTPCR3, SDHI0_MSTP314 | SDHI2_MSTP312);
/* * SD0 clock is set to 97.5MHz by default. @@ -91,66 +78,37 @@ int board_early_init_f(void) return 0; }
+#define ETHERNET_PHY_RESET 123 /* GPIO 3 31 */ + int board_init(void) { /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- /* Init PFC controller */ - r8a7790_pinmux_init(); - cpld_init();
-#ifdef CONFIG_SH_ETHER - /* ETHER Enable */ - gpio_request(GPIO_FN_ETH_CRS_DV, NULL); - gpio_request(GPIO_FN_ETH_RX_ER, NULL); - gpio_request(GPIO_FN_ETH_RXD0, NULL); - gpio_request(GPIO_FN_ETH_RXD1, NULL); - gpio_request(GPIO_FN_ETH_LINK, NULL); - gpio_request(GPIO_FN_ETH_REF_CLK, NULL); - gpio_request(GPIO_FN_ETH_MDIO, NULL); - gpio_request(GPIO_FN_ETH_TXD1, NULL); - gpio_request(GPIO_FN_ETH_TX_EN, NULL); - gpio_request(GPIO_FN_ETH_MAGIC, NULL); - gpio_request(GPIO_FN_ETH_TXD0, NULL); - gpio_request(GPIO_FN_ETH_MDC, NULL); - gpio_request(GPIO_FN_IRQ1, NULL); - - gpio_request(GPIO_GP_3_31, NULL); /* PHY_RST */ - gpio_direction_output(GPIO_GP_3_31, 0); + /* Force ethernet PHY out of reset */ + gpio_request(ETHERNET_PHY_RESET, "phy_reset"); + gpio_direction_output(ETHERNET_PHY_RESET, 0); mdelay(20); - gpio_set_value(GPIO_GP_3_31, 1); - udelay(1); -#endif + gpio_direction_output(ETHERNET_PHY_RESET, 1);
return 0; }
-#define CXR24 0xEE7003C0 /* MAC address high register */ -#define CXR25 0xEE7003C8 /* MAC address low register */ -int board_eth_init(bd_t *bis) +int dram_init(void) { - int ret = -ENODEV; - -#ifdef CONFIG_SH_ETHER - u32 val; - unsigned char enetaddr[6]; - - ret = sh_eth_initialize(bis); - if (!eth_env_get_enetaddr("ethaddr", enetaddr)) - return ret; + if (fdtdec_setup_memory_size() != 0) + return -EINVAL;
- /* Set Mac address */ - val = enetaddr[0] << 24 | enetaddr[1] << 16 | - enetaddr[2] << 8 | enetaddr[3]; - writel(val, CXR24); + return 0; +}
- val = enetaddr[4] << 8 | enetaddr[5]; - writel(val, CXR25); -#endif +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize();
- return ret; + return 0; }
/* Stout has KSZ8041NL/RNL */ @@ -167,67 +125,6 @@ int board_phy_config(struct phy_device *phydev) return 0; }
-int board_mmc_init(bd_t *bis) -{ - int ret = -ENODEV; - -#ifdef CONFIG_SH_SDHI - gpio_request(GPIO_FN_SD0_DAT0, NULL); - gpio_request(GPIO_FN_SD0_DAT1, NULL); - gpio_request(GPIO_FN_SD0_DAT2, NULL); - gpio_request(GPIO_FN_SD0_DAT3, NULL); - gpio_request(GPIO_FN_SD0_CLK, NULL); - gpio_request(GPIO_FN_SD0_CMD, NULL); - gpio_request(GPIO_FN_SD0_CD, NULL); - gpio_request(GPIO_FN_SD2_DAT0, NULL); - gpio_request(GPIO_FN_SD2_DAT1, NULL); - gpio_request(GPIO_FN_SD2_DAT2, NULL); - gpio_request(GPIO_FN_SD2_DAT3, NULL); - gpio_request(GPIO_FN_SD2_CLK, NULL); - gpio_request(GPIO_FN_SD2_CMD, NULL); - gpio_request(GPIO_FN_SD2_CD, NULL); - - /* SDHI0 - needs CPLD mux setup */ - gpio_request(GPIO_GP_3_30, NULL); - gpio_direction_output(GPIO_GP_3_30, 1); /* VLDO3=3.3V */ - gpio_request(GPIO_GP_5_24, NULL); - gpio_direction_output(GPIO_GP_5_24, 1); /* power on */ - - ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI0_BASE, 0, - SH_SDHI_QUIRK_16BIT_BUF); - if (ret) - return ret; - - /* SDHI2 - needs CPLD mux setup */ - gpio_request(GPIO_GP_3_29, NULL); - gpio_direction_output(GPIO_GP_3_29, 1); /* VLDO4=3.3V */ - gpio_request(GPIO_GP_5_25, NULL); - gpio_direction_output(GPIO_GP_5_25, 1); /* power on */ - - ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI2_BASE, 2, 0); -#endif - return ret; -} - - -int dram_init(void) -{ - gd->ram_size = CONFIG_SYS_SDRAM_SIZE; - - return 0; -} - const struct rmobile_sysinfo sysinfo = { CONFIG_ARCH_RMOBILE_BOARD_STRING }; - -static const struct sh_serial_platdata serial_platdata = { - .base = SCIFA0_BASE, - .type = PORT_SCIFA, - .clk = CONFIG_MP_CLK_FREQ, -}; - -U_BOOT_DEVICE(stout_serials) = { - .name = "serial_sh", - .platdata = &serial_platdata, -}; diff --git a/board/renesas/stout/stout_spl.c b/board/renesas/stout/stout_spl.c new file mode 100644 index 0000000000..1b061756bc --- /dev/null +++ b/board/renesas/stout/stout_spl.c @@ -0,0 +1,481 @@ +/* + * board/renesas/stout/stout_spl.c + * + * Copyright (C) 2018 Marek Vasut marek.vasut@gmail.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <dm/platform_data/serial_sh.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <linux/errno.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> + +#include <spl.h> + +#define TMU0_MSTP125 BIT(25) +#define SCIFA0_MSTP204 BIT(4) +#define QSPI_MSTP917 BIT(17) + +#define SD2CKCR 0xE615026C +#define SD_97500KHZ 0x7 + +#ifdef CONFIG_TPL_BUILD +struct reg_config { + u16 off; + u32 val; +}; + +static void dbsc_wait(u16 reg) +{ + static const u32 dbsc3_0_base = DBSC3_0_BASE; + static const u32 dbsc3_1_base = DBSC3_0_BASE + 0x10000; + + while (!(readl(dbsc3_0_base + reg) & BIT(0))) + ; + + while (!(readl(dbsc3_1_base + reg) & BIT(0))) + ; +} + +static void tpl_init_sys(void) +{ + u32 r0 = 0; + + writel(0xa5a5a500, 0xe6020004); + writel(0xa5a5a500, 0xe6030004); + + asm volatile( + /* ICIALLU - Invalidate I$ to PoU */ + "mcr 15, 0, %0, cr7, cr5, 0 \n" + /* BPIALL - Invalidate branch predictors */ + "mcr 15, 0, %0, cr7, cr5, 6 \n" + /* Set SCTLR[IZ] */ + "mrc 15, 0, %0, cr1, cr0, 0 \n" + "orr %0, #0x1800 \n" + "mcr 15, 0, %0, cr1, cr0, 0 \n" + "isb sy \n" + :"=r"(r0)); +} + +static void tpl_init_pfc(void) +{ + static const struct reg_config pfc_with_unlock[] = { + { 0x0090, 0x00140300 }, + { 0x0094, 0x09500000 }, + { 0x0098, 0xc0000084 }, + { 0x0020, 0x01a33492 }, + { 0x0024, 0x10000000 }, + { 0x0028, 0x08449252 }, + { 0x002c, 0x2925b322 }, + { 0x0030, 0x0c311249 }, + { 0x0034, 0x10124000 }, + { 0x0038, 0x00001295 }, + { 0x003c, 0x50890000 }, + { 0x0040, 0x0eaa56aa }, + { 0x0044, 0x55550000 }, + { 0x0048, 0x00000005 }, + { 0x004c, 0x54800000 }, + { 0x0050, 0x3736db55 }, + { 0x0054, 0x29148da3 }, + { 0x0058, 0x48c446e1 }, + { 0x005c, 0x2a3a54dc }, + { 0x0160, 0x00000023 }, + { 0x0004, 0xfca0ffff }, + { 0x0008, 0x3fbffbf0 }, + { 0x000c, 0x3ffdffff }, + { 0x0010, 0x00ffffff }, + { 0x0014, 0xfc3ffff3 }, + { 0x0018, 0xe4fdfff7 }, + }; + + static const struct reg_config pfc_without_unlock[] = { + { 0x0104, 0xffffbfff }, + { 0x0108, 0xb1ffffe1 }, + { 0x010c, 0xffffffff }, + { 0x0110, 0xffffffff }, + { 0x0114, 0xe047beab }, + { 0x0118, 0x00000203 }, + }; + + static const u32 pfc_base = 0xe6060000; + + unsigned int i; + + for (i = 0; i < ARRAY_SIZE(pfc_with_unlock); i++) { + writel(~pfc_with_unlock[i].val, pfc_base); + writel(pfc_with_unlock[i].val, + pfc_base | pfc_with_unlock[i].off); + } + + for (i = 0; i < ARRAY_SIZE(pfc_without_unlock); i++) + writel(pfc_without_unlock[i].val, + pfc_base | pfc_without_unlock[i].off); +} + +static void tpl_init_gpio(void) +{ + static const u16 gpio_offs[] = { + 0x1000, 0x3000, 0x4000, 0x5000 + }; + + static const struct reg_config gpio_set[] = { + { 0x4000, 0x00c00000 }, + { 0x5000, 0x63020000 }, + }; + + static const struct reg_config gpio_clr[] = { + { 0x1000, 0x00000000 }, + { 0x3000, 0x00000000 }, + { 0x4000, 0x00c00000 }, + { 0x5000, 0xe3020000 }, + }; + + static const u32 gpio_base = 0xe6050000; + + unsigned int i; + + for (i = 0; i < ARRAY_SIZE(gpio_offs); i++) + writel(0, gpio_base | 0x20 | gpio_offs[i]); + + for (i = 0; i < ARRAY_SIZE(gpio_offs); i++) + writel(0, gpio_base | 0x00 | gpio_offs[i]); + + for (i = 0; i < ARRAY_SIZE(gpio_set); i++) + writel(gpio_set[i].val, gpio_base | 0x08 | gpio_set[i].off); + + for (i = 0; i < ARRAY_SIZE(gpio_clr); i++) + writel(gpio_clr[i].val, gpio_base | 0x04 | gpio_clr[i].off); +} + +static void tpl_init_lbsc(void) +{ + static const struct reg_config lbsc_config[] = { + { 0x00, 0x00000020 }, + { 0x08, 0x00002020 }, + { 0x30, 0x02150326 }, + { 0x38, 0x077f077f }, + }; + + static const u16 lbsc_offs[] = { + 0x80, 0x84, 0x88, 0x8c, 0xa0, 0xc0, 0xc4, 0xc8, 0x180 + }; + + static const u32 lbsc_base = 0xfec00200; + + unsigned int i; + + for (i = 0; i < ARRAY_SIZE(lbsc_config); i++) { + writel(lbsc_config[i].val, + lbsc_base | lbsc_config[i].off); + writel(lbsc_config[i].val, + lbsc_base | (lbsc_config[i].off + 4)); + } + + for (i = 0; i < ARRAY_SIZE(lbsc_offs); i++) + writel(0, lbsc_base | lbsc_offs[i]); +} + +static void tpl_init_dbsc(void) +{ + static const struct reg_config dbsc_config1[] = { + { 0x0280, 0x0000a55a }, + { 0x0018, 0x21000000 }, + { 0x0018, 0x11000000 }, + { 0x0018, 0x10000000 }, + { 0x0290, 0x00000001 }, + { 0x02a0, 0x80000000 }, + { 0x0290, 0x00000004 }, + }; + + static const struct reg_config dbsc_config2[] = { + { 0x0290, 0x00000006 }, + { 0x02a0, 0x0001c000 }, + }; + + static const struct reg_config dbsc_config3r0d0[] = { + { 0x0290, 0x0000000f }, + { 0x02a0, 0x00181885 }, + { 0x0290, 0x00000070 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x00000080 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x00000090 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x000000a0 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x000000b0 }, + { 0x02a0, 0x7c000880 }, + { 0x0290, 0x000000c0 }, + { 0x02a0, 0x7c000880 }, + { 0x0290, 0x000000d0 }, + { 0x02a0, 0x7c000880 }, + { 0x0290, 0x000000e0 }, + { 0x02a0, 0x7c000880 }, + }; + + static const struct reg_config dbsc_config3r0d1[] = { + { 0x0290, 0x0000000f }, + { 0x02a0, 0x00181885 }, + { 0x0290, 0x00000070 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x00000080 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x00000090 }, + { 0x02a0, 0x7c000887 }, + { 0x0290, 0x000000a0 }, + { 0x02a0, 0x7c000887 }, + }; + + static const struct reg_config dbsc_config3r2[] = { + { 0x0290, 0x0000000f }, + { 0x02a0, 0x00181224 }, + }; + + static const struct reg_config dbsc_config4[] = { + { 0x0290, 0x00000010 }, + { 0x02a0, 0xf004649b }, + { 0x0290, 0x00000061 }, + { 0x02a0, 0x0000006d }, + { 0x0290, 0x00000001 }, + { 0x02a0, 0x00000073 }, + { 0x0020, 0x00000007 }, + { 0x0024, 0x0f030a02 }, + { 0x0030, 0x00000001 }, + { 0x00b0, 0x00000000 }, + { 0x0040, 0x0000000b }, + { 0x0044, 0x00000008 }, + { 0x0048, 0x00000000 }, + { 0x0050, 0x0000000b }, + { 0x0054, 0x000c000b }, + { 0x0058, 0x00000027 }, + { 0x005c, 0x0000001c }, + { 0x0060, 0x00000006 }, + { 0x0064, 0x00000020 }, + { 0x0068, 0x00000008 }, + { 0x006c, 0x0000000c }, + { 0x0070, 0x00000009 }, + { 0x0074, 0x00000012 }, + { 0x0078, 0x000000d0 }, + { 0x007c, 0x00140005 }, + { 0x0080, 0x00050004 }, + { 0x0084, 0x70233005 }, + { 0x0088, 0x000c0000 }, + { 0x008c, 0x00000200 }, + { 0x0090, 0x00000040 }, + { 0x0100, 0x00000001 }, + { 0x00c0, 0x00020001 }, + { 0x00c8, 0x20042004 }, + { 0x0380, 0x00020002 }, + { 0x0390, 0x0000001f }, + }; + + static const struct reg_config dbsc_config5[] = { + { 0x0244, 0x00000011 }, + { 0x0290, 0x00000003 }, + { 0x02a0, 0x0300c4e1 }, + { 0x0290, 0x00000023 }, + { 0x02a0, 0x00fcdb60 }, + { 0x0290, 0x00000011 }, + { 0x02a0, 0x1000040b }, + { 0x0290, 0x00000012 }, + { 0x02a0, 0x9d9cbb66 }, + { 0x0290, 0x00000013 }, + { 0x02a0, 0x1a868400 }, + { 0x0290, 0x00000014 }, + { 0x02a0, 0x300214d8 }, + { 0x0290, 0x00000015 }, + { 0x02a0, 0x00000d70 }, + { 0x0290, 0x00000016 }, + { 0x02a0, 0x00000006 }, + { 0x0290, 0x00000017 }, + { 0x02a0, 0x00000018 }, + { 0x0290, 0x0000001a }, + { 0x02a0, 0x910035c7 }, + { 0x0290, 0x00000004 }, + }; + + static const struct reg_config dbsc_config6[] = { + { 0x0290, 0x00000001 }, + { 0x02a0, 0x00000181 }, + { 0x0018, 0x11000000 }, + { 0x0290, 0x00000004 }, + }; + + static const struct reg_config dbsc_config7[] = { + { 0x0290, 0x00000001 }, + { 0x02a0, 0x0000fe01 }, + { 0x0304, 0x00000000 }, + { 0x00f4, 0x01004c20 }, + { 0x00f8, 0x014000aa }, + { 0x00e0, 0x00000140 }, + { 0x00e4, 0x00081860 }, + { 0x00e8, 0x00010000 }, + { 0x0290, 0x00000004 }, + }; + + static const struct reg_config dbsc_config8[] = { + { 0x0014, 0x00000001 }, + { 0x0010, 0x00000001 }, + { 0x0280, 0x00000000 }, + }; + + static const u32 dbsc3_0_base = DBSC3_0_BASE; + static const u32 dbsc3_1_base = DBSC3_0_BASE + 0x10000; + static const u32 prr_base = 0xff000044; + const u16 prr_rev = readl(prr_base) & 0x7fff; + unsigned int i; + + for (i = 0; i < ARRAY_SIZE(dbsc_config1); i++) { + writel(dbsc_config1[i].val, dbsc3_0_base | dbsc_config1[i].off); + writel(dbsc_config1[i].val, dbsc3_1_base | dbsc_config1[i].off); + } + + dbsc_wait(0x2a0); + + for (i = 0; i < ARRAY_SIZE(dbsc_config2); i++) { + writel(dbsc_config2[i].val, dbsc3_0_base | dbsc_config2[i].off); + writel(dbsc_config2[i].val, dbsc3_1_base | dbsc_config2[i].off); + } + + if (prr_rev == 0x4500) { + for (i = 0; i < ARRAY_SIZE(dbsc_config3r0d0); i++) { + writel(dbsc_config3r0d0[i].val, + dbsc3_0_base | dbsc_config3r0d0[i].off); + } + for (i = 0; i < ARRAY_SIZE(dbsc_config3r0d1); i++) { + writel(dbsc_config3r0d1[i].val, + dbsc3_1_base | dbsc_config3r0d1[i].off); + } + } else if (prr_rev != 0x4510) { + for (i = 0; i < ARRAY_SIZE(dbsc_config3r2); i++) { + writel(dbsc_config3r2[i].val, + dbsc3_0_base | dbsc_config3r2[i].off); + writel(dbsc_config3r2[i].val, + dbsc3_1_base | dbsc_config3r2[i].off); + } + } + + for (i = 0; i < ARRAY_SIZE(dbsc_config4); i++) { + writel(dbsc_config4[i].val, dbsc3_0_base | dbsc_config4[i].off); + writel(dbsc_config4[i].val, dbsc3_1_base | dbsc_config4[i].off); + } + + dbsc_wait(0x240); + + for (i = 0; i < ARRAY_SIZE(dbsc_config5); i++) { + writel(dbsc_config5[i].val, dbsc3_0_base | dbsc_config5[i].off); + writel(dbsc_config5[i].val, dbsc3_1_base | dbsc_config5[i].off); + } + + dbsc_wait(0x2a0); + + for (i = 0; i < ARRAY_SIZE(dbsc_config6); i++) { + writel(dbsc_config6[i].val, dbsc3_0_base | dbsc_config6[i].off); + writel(dbsc_config6[i].val, dbsc3_1_base | dbsc_config6[i].off); + } + + dbsc_wait(0x2a0); + + for (i = 0; i < ARRAY_SIZE(dbsc_config7); i++) { + writel(dbsc_config7[i].val, dbsc3_0_base | dbsc_config7[i].off); + writel(dbsc_config7[i].val, dbsc3_1_base | dbsc_config7[i].off); + } + + dbsc_wait(0x2a0); + + for (i = 0; i < ARRAY_SIZE(dbsc_config8); i++) { + writel(dbsc_config8[i].val, dbsc3_0_base | dbsc_config8[i].off); + writel(dbsc_config8[i].val, dbsc3_1_base | dbsc_config8[i].off); + } + +} + +static void tpl_init_qspi(void) +{ + mstp_clrbits_le32(MSTPSR9, SMSTPCR9, QSPI_MSTP917); + + static const u32 qspi_base = 0xe6b10000; + + writeb(0x08, qspi_base + 0x00); + writeb(0x00, qspi_base + 0x01); + writeb(0x06, qspi_base + 0x02); + writeb(0x01, qspi_base + 0x0a); + writeb(0x00, qspi_base + 0x0b); + writeb(0x00, qspi_base + 0x0c); + writeb(0x00, qspi_base + 0x0d); + writeb(0x00, qspi_base + 0x0e); + + writew(0xe080, qspi_base + 0x10); + + writeb(0xc0, qspi_base + 0x18); + writeb(0x00, qspi_base + 0x18); + writeb(0x00, qspi_base + 0x08); + writeb(0x48, qspi_base + 0x00); +} + +void board_init_f(ulong dummy) +{ + mstp_clrbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); + mstp_clrbits_le32(MSTPSR2, SMSTPCR2, SCIFA0_MSTP204); + + /* + * SD0 clock is set to 97.5MHz by default. + * Set SD2 to the 97.5MHz as well. + */ + writel(SD_97500KHZ, SD2CKCR); + + tpl_init_sys(); + tpl_init_pfc(); + tpl_init_gpio(); + tpl_init_lbsc(); + tpl_init_dbsc(); + tpl_init_qspi(); +} +#endif + +void spl_board_init(void) +{ + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); +} + +void board_boot_order(u32 *spl_boot_list) +{ +#ifdef CONFIG_TPL_BUILD + const u32 jtag_magic = 0x1337c0de; + const u32 load_magic = 0xb33fc0de; + + /* + * If JTAG probe sets special word at 0xe6300020, then it must + * put U-Boot into RAM and TPL will start it from RAM. + */ + if (readl(CONFIG_TPL_TEXT_BASE + 0x20) == jtag_magic) { + printf("JTAG boot detected!\n"); + + while (readl(CONFIG_TPL_TEXT_BASE + 0x24) != load_magic) + ; + + spl_boot_list[0] = BOOT_DEVICE_RAM; + spl_boot_list[1] = BOOT_DEVICE_NONE; + + return; + } +#endif + + /* Boot from SPI NOR with YMODEM UART fallback. */ + spl_boot_list[0] = BOOT_DEVICE_SPI; + spl_boot_list[1] = BOOT_DEVICE_UART; + spl_boot_list[2] = BOOT_DEVICE_NONE; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/configs/stout_defconfig b/configs/stout_defconfig index fd7e2dc453..bc5c561c21 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -1,17 +1,50 @@ CONFIG_ARM=y +CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_ARCH_RMOBILE=y -CONFIG_SYS_TEXT_BASE=0xE8080000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_R8A7790=y CONFIG_TARGET_STOUT=y +CONFIG_TPL_TEXT_BASE=0xe6300000 +CONFIG_TPL_MAX_SIZE=16384 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-stout-u-boot" +CONFIG_TPL_SYS_MALLOC_F_LEN=0x2000 +CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_TPL=y +CONFIG_TPL_BOARD_INIT=y +CONFIG_TPL_NEEDS_SEPARATE_TEXT_BASE=y +CONFIG_TPL_RAM_SUPPORT=y +CONFIG_TPL_RAM_DEVICE=y +CONFIG_TPL_SERIAL_SUPPORT=y +CONFIG_TPL_SPI_FLASH_SUPPORT=y +CONFIG_TPL_SPI_LOAD=y +CONFIG_TPL_SPI_SUPPORT=y +CONFIG_TPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y @@ -19,21 +52,50 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas power-domains" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_DM_GPIO=y +CONFIG_RCAR_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_DM_MMC=y +CONFIG_RENESAS_SDHI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MICREL=y -CONFIG_NETDEVICES=y +CONFIG_DM_ETH=y CONFIG_SH_ETHER=y -CONFIG_BAUDRATE=38400 +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_RCAR_GEN2=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_PFC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +# CONFIG_TPL_DM_SERIAL is not set CONFIG_SCIF_CONSOLE=y CONFIG_SH_QSPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y +CONFIG_TPL_TINY_MEMSET=y diff --git a/include/configs/stout.h b/include/configs/stout.h index b81103e8a7..226bea8140 100644 --- a/include/configs/stout.h +++ b/include/configs/stout.h @@ -17,14 +17,9 @@
#include "rcar-gen2-common.h"
-/* STACK */ -#if defined(CONFIGF_RMOBILE_EXTRAM_BOOT) -#define CONFIG_SYS_INIT_SP_ADDR 0xB003FFFC -#else -#define CONFIG_SYS_INIT_SP_ADDR 0xE827FFFC -#endif -#define STACK_AREA_SIZE 0xC000 -#define LOW_LEVEL_MERAM_STACK \ +#define CONFIG_SYS_INIT_SP_ADDR 0x4f000000 +#define STACK_AREA_SIZE 0x00100000 +#define LOW_LEVEL_MERAM_STACK \ (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4)
/* MEMORY */ @@ -43,47 +38,33 @@ #define CONFIG_SH_ETHER_USE_PORT 0 #define CONFIG_SH_ETHER_PHY_ADDR 0x1 #define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RMII -#define CONFIG_SH_ETHER_ALIGNE_SIZE 64 #define CONFIG_SH_ETHER_CACHE_WRITEBACK #define CONFIG_SH_ETHER_CACHE_INVALIDATE +#define CONFIG_SH_ETHER_ALIGNE_SIZE 64 #define CONFIG_BITBANGMII #define CONFIG_BITBANGMII_MULTI
-/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_RCAR -#define CONFIG_SYS_RCAR_I2C0_SPEED 400000 -#define CONFIG_SYS_RCAR_I2C1_SPEED 400000 -#define CONFIG_SYS_RCAR_I2C2_SPEED 400000 -#define CONFIG_SYS_RCAR_I2C3_SPEED 400000 -#define CONFIF_SYS_RCAR_I2C_NUM_CONTROLLERS 4 - -#define CONFIG_SYS_I2C_POWERIC_ADDR 0x58 /* da9063 */ - /* Board Clock */ #define RMOBILE_XTAL_CLK 20000000u #define CONFIG_SYS_CLK_FREQ RMOBILE_XTAL_CLK -#define CONFIG_SH_TMU_CLK_FREQ (CONFIG_SYS_CLK_FREQ / 2) /* EXT / 2 */ -#define CONFIG_PLL1_CLK_FREQ (CONFIG_SYS_CLK_FREQ * 156 / 2) -#define CONFIG_PLL1_DIV2_CLK_FREQ (CONFIG_PLL1_CLK_FREQ / 2) -#define CONFIG_MP_CLK_FREQ (CONFIG_PLL1_DIV2_CLK_FREQ / 15) -#define CONFIG_HP_CLK_FREQ (CONFIG_PLL1_CLK_FREQ / 12) +#define CONFIG_SH_TMU_CLK_FREQ (CONFIG_SYS_CLK_FREQ / 2)
#define CONFIG_SYS_TMU_CLK_DIV 4
-/* USB */ -#define CONFIG_USB_EHCI_RMOBILE -#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0"
-/* Module stop status bits */ -/* INTC-RT */ -#define CONFIG_SMSTP0_ENA 0x00400000 -/* MSIF, SCIFA0 */ -#define CONFIG_SMSTP2_ENA 0x00002010 -/* INTC-SYS, IRQC */ -#define CONFIG_SMSTP4_ENA 0x00000180 +/* SPL support */ +#define CONFIG_SPL_TEXT_BASE 0xe6304000 +#define CONFIG_SPL_STACK 0xe6340000 +#define CONFIG_SPL_MAX_SIZE 0x40000 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000
-/* SDHI */ -#define CONFIG_SH_SDHI_FREQ 97500000 +/* TPL support */ +#ifdef CONFIG_TPL_BUILD +#define CONFIG_CONS_SCIFA0 +#define CONFIG_SH_SCIF_CLK_FREQ 52000000 +#endif
#endif /* __STOUT_H */
