[PATCH v11 1/2] dt-bindings: mtd: fixed-partitions: Add alignment properties
Add three properties for controlling alignment of partitions, aka 'entries' in fixed-partition.
For now there is no explicit mention of hierarchy, so a 'section' is just the 'fixed-partitions' node.
These new properties are inputs to the Binman packaging process, but are also needed if the firmware is repacked, to ensure that alignment constraints are not violated. Therefore they are provided as part of the schema.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Rob Herring robh@kernel.org ---
Changes in v11: - Drop mention of Binman - Use 'content' instead of 'contents'
Changes in v10: - Update the minimum to 2
Changes in v9: - Move binding example to next batch to avoid build error
Changes in v7: - Drop patch 'Add binman compatible' - Put the alignment properties into the fixed-partition binding
Changes in v6: - Correct schema-validation errors missed due to older dt-schema (enum fix and reg addition)
Changes in v5: - Add value ranges - Consistently mention alignment must be power-of-2 - Mention that alignment refers to bytes
Changes in v2: - Fix 'a' typo in commit message
.../bindings/mtd/partitions/partition.yaml | 51 +++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/Documentation/devicetree/bindings/mtd/partitions/partition.yaml b/Documentation/devicetree/bindings/mtd/partitions/partition.yaml index 1ebe9e2347ea..31bbeb161396 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/partition.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/partition.yaml @@ -57,6 +57,57 @@ properties: user space from type: boolean
+ align: + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 2 + maximum: 0x80000000 + multipleOf: 2 + description: + This sets the alignment of the entry in bytes. + + The entry offset is adjusted so that the entry starts on an aligned + boundary within the containing section or image. For example ‘align = + <16>’ means that the entry will start on a 16-byte boundary. This may + mean that padding is added before the entry. The padding is part of + the containing section but is not included in the entry, meaning that + an empty space may be created before the entry starts. Alignment + must be a power of 2. If ‘align’ is not provided, no alignment is + performed. + + align-size: + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 2 + maximum: 0x80000000 + multipleOf: 2 + description: + This sets the alignment of the entry size in bytes. It must be a power + of 2. + + For example, to ensure that the size of an entry is a multiple of 64 + bytes, set this to 64. While this does not affect the content of the + entry itself (the padding is performed only when its parent section is + assembled), the end result is that the entry ends with the padding + bytes, so may grow. If ‘align-size’ is not provided, no alignment is + performed. + + align-end: + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 2 + maximum: 0x80000000 + multipleOf: 2 + description: + This sets the alignment (in bytes) of the end of an entry with respect + to the containing section. It must be a power of 2. + + Some entries require that they end on an alignment boundary, + regardless of where they start. This does not move the start of the + entry, so the content of the entry will still start at the beginning. + But there may be padding at the end. While this does not affect the + content of the entry itself (the padding is performed only when its + parent section is assembled), the end result is that the entry ends + with the padding bytes, so may grow. If ‘align-end’ is not provided, + no alignment is performed. + if: not: required: [ reg ]
Add two compatibles for binman entries, as a starting point for the schema.
Note that, after discussion on v2, we decided to keep the existing meaning of label so as not to require changes to existing userspace software when moving to use binman nodes to specify the firmware layout.
Note also that, after discussion on v6, we decided to use the same 'fixed-partition' schema for the binman features, so this version adds a new 'binman.yaml' file providing the new compatibles to the existing partition.yaml binding.
(no changes since v10)
Changes in v10: - Drop binman,entry since it is likely not necessary - Put the description back
Changes in v8: - Switch the patch ordering so the partition change comes first
Changes in v7: - Adjust MAINTAINERS entry - Put compatible strings into the 'fixed-partition' binding
Changes in v5: - Add mention of why 'binman' is the vendor - Drop 'select: false' - Tidy up the compatible setings - Use 'tfa-bl31' instead of 'atf-bl31'
Changes in v4: - Correct selection of multiple compatible strings
Changes in v3: - Drop fixed-partitions from the example - Use compatible instead of label
Changes in v2: - Use plain partition@xxx for the node name
.../bindings/mtd/partitions/binman.yaml | 53 +++++++++++++++++++ .../bindings/mtd/partitions/partition.yaml | 21 ++++++++ MAINTAINERS | 5 ++ 3 files changed, 79 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml new file mode 100644 index 000000000000..bb4b08546184 --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml @@ -0,0 +1,53 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Binman entries + +description: | + This corresponds to a binman 'entry'. It is a single partition which holds + data of a defined type. + + Binman uses the type to indicate what data file / type to place in the + partition. There are quite a number of binman-specific entry types, such as + section, fill and files, to be added later. + +maintainers: + - Simon Glass sjg@chromium.org + +allOf: + - $ref: /schemas/mtd/partitions/partition.yaml# + +properties: + compatible: + enum: + - u-boot # u-boot.bin from U-Boot project + - tfa-bl31 # bl31.bin or bl31.elf from TF-A project + +required: + - compatible + +unevaluatedProperties: false + +examples: + - | + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@100000 { + compatible = "u-boot"; + reg = <0x100000 0xf00000>; + align-size = <0x1000>; + align-end = <0x10000>; + }; + + partition@200000 { + compatible = "tfa-bl31"; + reg = <0x200000 0x100000>; + align = <0x4000>; + }; + }; diff --git a/Documentation/devicetree/bindings/mtd/partitions/partition.yaml b/Documentation/devicetree/bindings/mtd/partitions/partition.yaml index 31bbeb161396..80d0452a2a33 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/partition.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/partition.yaml @@ -118,3 +118,24 @@ then:
# This is a generic file other binding inherit from and extend additionalProperties: true + +examples: + - | + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@100000 { + compatible = "u-boot"; + reg = <0x100000 0xf00000>; + align-size = <0x1000>; + align-end = <0x10000>; + }; + + partition@200000 { + compatible = "tfa-bl31"; + reg = <0x200000 0x100000>; + align = <0x4000>; + }; + }; diff --git a/MAINTAINERS b/MAINTAINERS index b1b074ce2cf3..b1a4ca692578 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -3684,6 +3684,11 @@ F: Documentation/filesystems/bfs.rst F: fs/bfs/ F: include/uapi/linux/bfs_fs.h
+BINMAN +M: Simon Glass sjg@chromium.org +S: Supported +F: Documentation/devicetree/bindings/mtd/partitions/binman* + BITMAP API M: Yury Norov yury.norov@gmail.com R: Rasmus Villemoes linux@rasmusvillemoes.dk
Applied to https://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux.git mtd/next, thanks.
Miquel
Miquel
Miquel Raynal
