[U-Boot] [PATCH v3 0/4] dm: video: Correct color ANSI escape sequence support
Support special rendition code 0 - reset attributes. Support special rendition code 1 - increased intensity (bold). Get RGB sequence in pixels right (swap blue and red). Do not set reserved bits. Use u32 instead of unsigned for color bit mask.
qemu-system-i386 -display sdl -vga virtio and qemu-system-i386 -display sdl -vga cirrus now display the same colors as qemu-system-i386 -nographic
Testing is possible via
setenv efi_selftest test output bootefi selftest --- v3: Split single patch up into a series Use constants for colors v2: SGR 0 should reset the colors and the attributes. --- Heinrich Schuchardt (4): dm: video: show correct colors in graphical console dm: video: correctly clean background in 16bit mode dm: video: use constants to refer to colors dm: video: support increased intensity (bold)
drivers/video/vidconsole-uclass.c | 86 ++++++++++++++++++++++++++------------- drivers/video/video-uclass.c | 38 +++++++++++++---- include/video.h | 13 +++++- include/video_console.h | 39 ++++++++++++++++++ test/dm/video.c | 2 +- 5 files changed, 138 insertions(+), 40 deletions(-)
qemu-system-i386 -display sdl -vga virtio and qemu-system-i386 -display sdl -vga cirrus now display the similar colors (highlighting still missing) as qemu-system-i386 -nographic
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 no change v2 no change --- drivers/video/vidconsole-uclass.c | 13 ++++++------- test/dm/video.c | 2 +- 2 files changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index 5f63c12d6c..8a2a377161 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -127,15 +127,14 @@ static void set_color(struct video_priv *priv, unsigned idx, unsigned *c) { switch (priv->bpix) { case VIDEO_BPP16: - *c = ((colors[idx].r >> 3) << 0) | - ((colors[idx].g >> 2) << 5) | - ((colors[idx].b >> 3) << 11); + *c = ((colors[idx].r >> 3) << 11) | + ((colors[idx].g >> 2) << 5) | + ((colors[idx].b >> 3) << 0); break; case VIDEO_BPP32: - *c = 0xff000000 | - (colors[idx].r << 0) | - (colors[idx].g << 8) | - (colors[idx].b << 16); + *c = (colors[idx].r << 16) | + (colors[idx].g << 8) | + (colors[idx].b << 0); break; default: /* unsupported, leave current color in place */ diff --git a/test/dm/video.c b/test/dm/video.c index 29917d0c2d..d158f1fcb3 100644 --- a/test/dm/video.c +++ b/test/dm/video.c @@ -186,7 +186,7 @@ static int dm_test_video_ansi(struct unit_test_state *uts) /* test colors (30-37 fg color, 40-47 bg color) */ vidconsole_put_string(con, ANSI_ESC"[30;41mfoo"); /* black on red */ vidconsole_put_string(con, ANSI_ESC"[33;44mbar"); /* yellow on blue */ - ut_asserteq(268, compress_frame_buffer(dev)); + ut_asserteq(267, compress_frame_buffer(dev));
return 0; }
In 16 bit mode we have to copy two bytes per pixels repeatedly and not four. Otherwise we will see a striped pattern.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 no change v2 no change --- drivers/video/video-uclass.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index dcaceed42c..9a980ea3a1 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -91,14 +91,26 @@ void video_clear(struct udevice *dev) { struct video_priv *priv = dev_get_uclass_priv(dev);
- if (priv->bpix == VIDEO_BPP32) { + switch (priv->bpix) { + case VIDEO_BPP16: { + u16 *ppix = priv->fb; + u16 *end = priv->fb + priv->fb_size; + + while (ppix < end) + *ppix++ = priv->colour_bg; + break; + } + case VIDEO_BPP32: { u32 *ppix = priv->fb; u32 *end = priv->fb + priv->fb_size;
while (ppix < end) *ppix++ = priv->colour_bg; - } else { + break; + } + default: memset(priv->fb, priv->colour_bg, priv->fb_size); + break; } }
Use constants to refer to colors. Adjust initialization of foreground and background color to avoid setting reserved bits. Consistently u32 instead of unsigned for color bit mask.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 Use color constants for initalizing the console. v2 no change --- drivers/video/vidconsole-uclass.c | 55 +++++++++++++++++++++++---------------- drivers/video/video-uclass.c | 19 +++++++++----- include/video.h | 11 ++++++-- include/video_console.h | 31 ++++++++++++++++++++++ 4 files changed, 85 insertions(+), 31 deletions(-)
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index 8a2a377161..44f557c46a 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -15,6 +15,15 @@ #include <video_console.h> #include <video_font.h> /* Get font data, width and height */
+/* + * Structure to describe a console color + */ +struct vid_rgb { + u32 r; + u32 g; + u32 b; +}; + /* By default we scroll by a single line */ #ifndef CONFIG_CONSOLE_SCROLL_LINES #define CONFIG_CONSOLE_SCROLL_LINES 1 @@ -108,11 +117,7 @@ static void vidconsole_newline(struct udevice *dev) video_sync(dev->parent); }
-static const struct { - unsigned r; - unsigned g; - unsigned b; -} colors[] = { +static const struct vid_rgb colors[VID_COLOR_COUNT] = { { 0x00, 0x00, 0x00 }, /* black */ { 0xff, 0x00, 0x00 }, /* red */ { 0x00, 0xff, 0x00 }, /* green */ @@ -123,22 +128,26 @@ static const struct { { 0xff, 0xff, 0xff }, /* white */ };
-static void set_color(struct video_priv *priv, unsigned idx, unsigned *c) +u32 vid_console_color(struct video_priv *priv, unsigned int idx) { switch (priv->bpix) { case VIDEO_BPP16: - *c = ((colors[idx].r >> 3) << 11) | - ((colors[idx].g >> 2) << 5) | - ((colors[idx].b >> 3) << 0); - break; + return ((colors[idx].r >> 3) << 11) | + ((colors[idx].g >> 2) << 5) | + ((colors[idx].b >> 3) << 0); case VIDEO_BPP32: - *c = (colors[idx].r << 16) | - (colors[idx].g << 8) | - (colors[idx].b << 0); - break; + return (colors[idx].r << 16) | + (colors[idx].g << 8) | + (colors[idx].b << 0); default: - /* unsupported, leave current color in place */ - break; + /* + * For unknown bit arrangements just support + * black and white. + */ + if (idx) + return 0xffffff; /* white */ + else + return 0x000000; /* black */ } }
@@ -270,17 +279,17 @@ static void vidconsole_escape_char(struct udevice *dev, char ch)
switch (val) { case 30 ... 37: - /* fg color */ - set_color(vid_priv, val - 30, - (unsigned *)&vid_priv->colour_fg); + /* foreground color */ + vid_priv->colour_fg = vid_console_color( + vid_priv, val - 30); break; case 40 ... 47: - /* bg color */ - set_color(vid_priv, val - 40, - (unsigned *)&vid_priv->colour_bg); + /* background color */ + vid_priv->colour_bg = vid_console_color( + vid_priv, val - 40); break; default: - /* unknown/unsupported */ + /* ignore unsupported SGR parameter */ break; } } diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 9a980ea3a1..945b20ddfd 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -114,6 +114,17 @@ void video_clear(struct udevice *dev) } }
+void video_set_default_colors(struct video_priv *priv) +{ +#ifdef CONFIG_SYS_WHITE_ON_BLACK + priv->colour_fg = vid_console_color(priv, VID_WHITE); + priv->colour_bg = vid_console_color(priv, VID_BLACK); +#else + priv->colour_fg = vid_console_color(priv, VID_BLACK); + priv->colour_bg = vid_console_color(priv, VID_WHITE); +#endif +} + /* Flush video activity to the caches */ void video_sync(struct udevice *vid) { @@ -203,12 +214,8 @@ static int video_post_probe(struct udevice *dev) priv->line_length = priv->xsize * VNBYTES(priv->bpix); priv->fb_size = priv->line_length * priv->ysize;
- /* Set up colours - we could in future support other colours */ -#ifdef CONFIG_SYS_WHITE_ON_BLACK - priv->colour_fg = 0xffffff; -#else - priv->colour_bg = 0xffffff; -#endif + /* Set up colors */ + video_set_default_colors(priv);
if (!CONFIG_IS_ENABLED(NO_FB_CLEAR)) video_clear(dev); diff --git a/include/video.h b/include/video.h index 61ff653121..841f3dc56b 100644 --- a/include/video.h +++ b/include/video.h @@ -84,8 +84,8 @@ struct video_priv { void *fb; int fb_size; int line_length; - int colour_fg; - int colour_bg; + u32 colour_fg; + u32 colour_bg; bool flush_dcache; ushort *cmap; }; @@ -183,6 +183,13 @@ int video_get_ysize(struct udevice *dev); */ void video_set_flush_dcache(struct udevice *dev, bool flush);
+/** + * Set default colors and attributes + * + * @priv device information + */ +void video_set_default_colors(struct video_priv *priv); + #endif /* CONFIG_DM_VIDEO */
#ifndef CONFIG_DM_VIDEO diff --git a/include/video_console.h b/include/video_console.h index 9dce234bd9..9505db1dc3 100644 --- a/include/video_console.h +++ b/include/video_console.h @@ -7,11 +7,29 @@ #ifndef __video_console_h #define __video_console_h
+#include <video.h> + #define VID_FRAC_DIV 256
#define VID_TO_PIXEL(x) ((x) / VID_FRAC_DIV) #define VID_TO_POS(x) ((x) * VID_FRAC_DIV)
+/* + * The 8 colors supported by the console + */ +enum color_idx { + VID_BLACK = 0, + VID_RED, + VID_GREEN, + VID_YELLOW, + VID_BLUE, + VID_MAGENTA, + VID_CYAN, + VID_WHITE, + + VID_COLOR_COUNT +}; + /** * struct vidconsole_priv - uclass-private data about a console device * @@ -196,4 +214,17 @@ int vidconsole_put_char(struct udevice *dev, char ch); void vidconsole_position_cursor(struct udevice *dev, unsigned col, unsigned row);
+/** + * vid_console_color() - convert a color code to a pixel's internal + * representation + * + * The caller has to guarantee that the color index is less than + * VID_COLOR_COUNT. + * + * @priv private data of the console device + * @idx color index + * @return color value + */ +u32 vid_console_color(struct video_priv *priv, unsigned int idx); + #endif
Hi Heinrich,
Regarding my point about using u32 in function return values and args, I don't think I explained it very well.
IMO is makes no sense to structure all the intermediate code which generates pixel values to use u32, when an unsigned int is enough on all machines that U-Boot supports. The packing / unpacking into a 32-bit word in memory is something that is done once when the pixel is accessed. Thereafter I don't see a need to push things around in a particular format.
I have an aversion to code which forces the compiler to mask every variable access just to pass the data around.
So I would prefer to use u32 only when accessing the hardware, or for pointers which do that.
Reards, Simon
On 02/04/2018 02:40 PM, Simon Glass wrote:
Hi Heinrich,
The definition I found was typedef unsigned int u32;
What makes you believe there is any packing and unpacking or masking overhead avoided by using unsigned int or any other 32bit integer type?
For struct vid_rgb other integer types could be used. I not sure if accessing a char is any faster in this context than using 32bit integers.
Regards
Heinrich
Reards, Simon
Hi Heinrich,
Hi Heinrich,
A machine with a 32-bit register has to mask its argument on entry to the function to ensure that the caller does not pass an invalid value.
In general the natural word size is best for arguments and return values I think (int or unsigned int).
Regards
Heinrich
Reards, Simon
On 02/07/2018 05:38 AM, Simon Glass wrote:
Hi Heinrich,
On 4 February 2018 at 15:55, Heinrich Schuchardt <xypron.glpk@gmx.de mailto:xypron.glpk@gmx.de> wrote:
Hi Heinrich,
On 29 January 2018 at 00:19, Heinrich Schuchardt <xypron.glpk@gmx.de
Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de
Reviewed-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
If this were true it would also hold true for unsigned int. See above typedef.
C does not check if a value is negative when copying int to unsigned int.
So I leave it as it is.
By the way: natural word size is size_t and not int.
Regards
Heinrich
Reards, Simon
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 Add color constants. v2 SGR 0 should reset the colors and the attributes. --- drivers/video/vidconsole-uclass.c | 32 ++++++++++++++++++++++++++------ drivers/video/video-uclass.c | 5 ++++- include/video.h | 2 ++ include/video_console.h | 12 ++++++++++-- test/dm/video.c | 2 +- 5 files changed, 43 insertions(+), 10 deletions(-)
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index 44f557c46a..a878eb402a 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -119,12 +119,20 @@ static void vidconsole_newline(struct udevice *dev)
static const struct vid_rgb colors[VID_COLOR_COUNT] = { { 0x00, 0x00, 0x00 }, /* black */ - { 0xff, 0x00, 0x00 }, /* red */ - { 0x00, 0xff, 0x00 }, /* green */ + { 0xc0, 0x00, 0x00 }, /* red */ + { 0x00, 0xc0, 0x00 }, /* green */ + { 0xc0, 0x60, 0x00 }, /* brown */ + { 0x00, 0x00, 0xc0 }, /* blue */ + { 0xc0, 0x00, 0xc0 }, /* magenta */ + { 0x00, 0xc0, 0xc0 }, /* cyan */ + { 0xc0, 0xc0, 0xc0 }, /* light gray */ + { 0x80, 0x80, 0x80 }, /* gray */ + { 0xff, 0x00, 0x00 }, /* bright red */ + { 0x00, 0xff, 0x00 }, /* bright green */ { 0xff, 0xff, 0x00 }, /* yellow */ - { 0x00, 0x00, 0xff }, /* blue */ - { 0xff, 0x00, 0xff }, /* magenta */ - { 0x00, 0xff, 0xff }, /* cyan */ + { 0x00, 0x00, 0xff }, /* bright blue */ + { 0xff, 0x00, 0xff }, /* bright magenta */ + { 0x00, 0xff, 0xff }, /* bright cyan */ { 0xff, 0xff, 0xff }, /* white */ };
@@ -278,10 +286,22 @@ static void vidconsole_escape_char(struct udevice *dev, char ch) s++;
switch (val) { + case 0: + /* all attributes off */ + video_set_default_colors(vid_priv); + break; + case 1: + /* bold */ + vid_priv->fg |= 8; + vid_priv->colour_fg = vid_console_color( + vid_priv, vid_priv->fg); + break; case 30 ... 37: /* foreground color */ + vid_priv->fg &= ~7; + vid_priv->fg |= val - 30; vid_priv->colour_fg = vid_console_color( - vid_priv, val - 30); + vid_priv, vid_priv->fg); break; case 40 ... 47: /* background color */ diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 945b20ddfd..43ab6f6b32 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -117,9 +117,12 @@ void video_clear(struct udevice *dev) void video_set_default_colors(struct video_priv *priv) { #ifdef CONFIG_SYS_WHITE_ON_BLACK - priv->colour_fg = vid_console_color(priv, VID_WHITE); + /* White is used when switching to bold, use light gray here */ + priv->fg = VID_LIGHT_GRAY; + priv->colour_fg = vid_console_color(priv, VID_LIGHT_GRAY); priv->colour_bg = vid_console_color(priv, VID_BLACK); #else + priv->fg = VID_BLACK; priv->colour_fg = vid_console_color(priv, VID_BLACK); priv->colour_bg = vid_console_color(priv, VID_WHITE); #endif diff --git a/include/video.h b/include/video.h index 841f3dc56b..3101459d2a 100644 --- a/include/video.h +++ b/include/video.h @@ -67,6 +67,7 @@ enum video_log2_bpp { * @flush_dcache: true to enable flushing of the data cache after * the LCD is updated * @cmap: Colour map for 8-bit-per-pixel displays + * @fg: Foreground color code (bit 3 = bold, bit 0-2 = color) */ struct video_priv { /* Things set up by the driver: */ @@ -88,6 +89,7 @@ struct video_priv { u32 colour_bg; bool flush_dcache; ushort *cmap; + u8 fg; };
/* Placeholder - there are no video operations at present */ diff --git a/include/video_console.h b/include/video_console.h index 9505db1dc3..a3ff176269 100644 --- a/include/video_console.h +++ b/include/video_console.h @@ -15,16 +15,24 @@ #define VID_TO_POS(x) ((x) * VID_FRAC_DIV)
/* - * The 8 colors supported by the console + * The 16 colors supported by the console */ enum color_idx { VID_BLACK = 0, VID_RED, VID_GREEN, - VID_YELLOW, + VID_BROWN, VID_BLUE, VID_MAGENTA, VID_CYAN, + VID_LIGHT_GRAY, + VID_GRAY, + VID_LIGHT_RED, + VID_LIGTH_GREEN, + VID_YELLOW, + VID_LIGHT_BLUE, + VID_LIGHT_MAGENTA, + VID_LIGHT_CYAN, VID_WHITE,
VID_COLOR_COUNT diff --git a/test/dm/video.c b/test/dm/video.c index d158f1fcb3..caca496902 100644 --- a/test/dm/video.c +++ b/test/dm/video.c @@ -186,7 +186,7 @@ static int dm_test_video_ansi(struct unit_test_state *uts) /* test colors (30-37 fg color, 40-47 bg color) */ vidconsole_put_string(con, ANSI_ESC"[30;41mfoo"); /* black on red */ vidconsole_put_string(con, ANSI_ESC"[33;44mbar"); /* yellow on blue */ - ut_asserteq(267, compress_frame_buffer(dev)); + ut_asserteq(265, compress_frame_buffer(dev));
return 0; }
Hi Heinrich,
Please can you rename 'fg' to something longer?
