Re: [DNX#2006040142000777] [U-Boot-Users] Ocotea with 512 megs of ram - ping [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000777] was created:
<snip>
Dale,
You've run into a problem where U-Boot maps the 2nd 256MB of physical memory into the same logical space as the 1st 256MB. It's a one line/one character typo that I've been meaning to post a patch for but I've been tied up on other projects. Here's the context diff:
--- ./board/amcc/ocotea/init.S 2005-12-19 18:14:46.000000000 -0800 +++ ../u-boot-git-ocotea-patch/board/amcc/ocotea/init.S 2005-12-22 13:38:38.000000000 -0800 @@ -92,5 +92,5 @@ tlbentry( CFG_ISRAM_BASE + 0x1000, SZ_4K, 0x80001000, 0, AC_R|AC_W|AC_X ) tlbentry( CFG_SDRAM_BASE, SZ_256M, 0x00000000, 0, AC_R|AC_W|AC_X|SA_G|SA_I )
- tlbentry( CFG_SDRAM_BASE+0x10000000, SZ_256M, 0x00000000, 0,
- tlbentry( CFG_SDRAM_BASE+0x10000000, SZ_256M, 0x10000000, 0,
AC_R|AC_W|AC_X|SA_G|SA_I ) tlbentry( CFG_PCI_BASE, SZ_256M, 0x00000000, 2, AC_R|AC_W|SA_G|SA_I ) tlbentry( CFG_PCI_MEMBASE, SZ_256M, 0x00000000, 3, AC_R|AC_W|SA_G|SA_I )
This should fix your problem.
Marc
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net] On Behalf Of Dale Dunlea Sent: Tuesday, February 14, 2006 8:32 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] Ocotea with 512 megs of ram - ping fails
I have an Ocotea (AMCC 440GX) test board which I have been using happily with U-Boot 1.1.4. In it's original configuration, it uses a single 256 meg dimm. This works fine and my kernel and initrd images are downloaded happily via tftp. I replaced this dimm with a 512 meg dimm and now the network interface is no longer functional. Has anyone else seen this issue?
Regards, Dale
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486& dat=121642 _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://sel.as-us.falkag.net/sel?cmd=lnk&kid%103432&bid#0486&dat%... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
</snip>
Your U-Boot support team
DENX Support System
