[U-Boot] [PATCH] nand: fix buffer alignment in new verification feature
On systems with caches enabled, NAND I/O may need to flush/invalidate the cache during read/write operations. For this to work correctly, all buffers must be cache-aligned. Fix nand_verify*() to allocate aligned buffers.
This prevents cache alignment warnings from being spewed when using U-Boot to write an updated version of itself to flash on NVIDIA Tegra Seaboard (after perturbation of stack/data layout in current u-boot-dm/next branch).
I have validatd (executed) nand_verify(), but I don't think I've executed nand_verify_page_oob(); testing of that would be useful.
Cc: Peter Tyser ptyser@xes-inc.com Cc: Heiko Schocher hs@denx.de Cc: Scott Wood scottwood@freescale.com Fixes: 59b5a2ad83df ("nand: Add verification functions") Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/mtd/nand/nand_util.c | 15 +++------------ 1 file changed, 3 insertions(+), 12 deletions(-)
diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index 12dd26a33fac..4e40952bf363 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -480,13 +480,11 @@ int nand_verify_page_oob(nand_info_t *nand, struct mtd_oob_ops *ops, loff_t ofs) int rval; struct mtd_oob_ops vops; size_t verlen = nand->writesize + nand->oobsize; + ALLOC_CACHE_ALIGN_BUFFER(uint8_t, verbuf, verlen);
memcpy(&vops, ops, sizeof(vops));
- vops.datbuf = malloc(verlen); - - if (!vops.datbuf) - return -ENOMEM; + vops.datbuf = verbuf;
vops.oobbuf = vops.datbuf + nand->writesize;
@@ -496,8 +494,6 @@ int nand_verify_page_oob(nand_info_t *nand, struct mtd_oob_ops *ops, loff_t ofs) if (!rval) rval = memcmp(ops->oobbuf, vops.oobbuf, vops.ooblen);
- free(vops.datbuf); - return rval ? -EIO : 0; }
@@ -520,10 +516,7 @@ int nand_verify(nand_info_t *nand, loff_t ofs, size_t len, u_char *buf) int rval = 0; size_t verofs; size_t verlen = nand->writesize; - uint8_t *verbuf = malloc(verlen); - - if (!verbuf) - return -ENOMEM; + ALLOC_CACHE_ALIGN_BUFFER(uint8_t, verbuf, verlen);
/* Read the NAND back in page-size groups to limit malloc size */ for (verofs = ofs; verofs < ofs + len; @@ -537,8 +530,6 @@ int nand_verify(nand_info_t *nand, loff_t ofs, size_t len, u_char *buf) break; }
- free(verbuf); - return rval ? -EIO : 0; }
- ALLOC_CACHE_ALIGN_BUFFER(uint8_t, verbuf, verlen);
Isn't this a bit big for the stack? Especially if NAND page sizes continue to grow. Can you use memalign() instead?
-Scott
Scott Wood
Stephen Warren
