[PATCH] Revert "spl: Drop bd_info in the data section"
This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75.
struct global_data contains a pointer to the bd_info structure. This pointer was populated spl_set_bd() to a pre-allocated bd_info in the ".data" section. The referenced commit replaced this mechanism to one that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. which very few boards do.
The result is that (struct global_data)->bd is NULL in SPL on most platforms. This breaks falcon mode, since arch_fixup_fdt() tries to access (struct global_data)->bd and set the "/memory" node in the devicetree. The result is that the "/memory" node contains garbage values, causing linux to panic() as it sets up the page table.
Instead of trying to fix the mess, potentially causing other issues, revert to the code that worked, while this change is reworked.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 5 +---- common/spl/Kconfig | 9 --------- common/spl/spl.c | 20 ++++++++------------ include/spl.h | 10 +--------- 4 files changed, 10 insertions(+), 34 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index d5131bcf4b..7d594a9f74 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -39,9 +39,6 @@ u32 spl_boot_device(void)
#ifdef CONFIG_SPL_BUILD
-/* Define board data structure */ -static struct bd_info bdata __attribute__ ((section(".data"))); - void spl_board_init(void) { #if defined(CONFIG_NXP_ESBC) && defined(CONFIG_FSL_LSCH2) @@ -78,7 +75,7 @@ void board_init_f(ulong dummy) get_clocks();
preloader_console_init(); - gd->bd = &bdata; + spl_set_bd();
#ifdef CONFIG_SYS_I2C #ifdef CONFIG_SPL_I2C_SUPPORT diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0711cbf951..75b4f45c01 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -113,15 +113,6 @@ config SPL_FSL_PBL Create boot binary having SPL binary in PBI format concatenated with u-boot binary.
-config SPL_ALLOC_BD - bool "Allocate memory for bd_info" - default y if X86 || SANDBOX - help - Some boards don't allocate space for this in their board_init_f() - code. In this case U-Boot can allocate space for gd->bd in the - standard SPL flow (board_init_r()). Enable this option to support - this feature. - endmenu
config HANDOFF diff --git a/common/spl/spl.c b/common/spl/spl.c index 556a91ab53..fb37d71959 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -55,6 +55,9 @@ binman_sym_declare(ulong, spl, image_pos); binman_sym_declare(ulong, spl, size); #endif
+/* Define board data structure */ +static struct bd_info bdata __attribute__ ((section(".data"))); + /* * Board-specific Platform code can reimplement show_boot_progress () if needed */ @@ -464,19 +467,14 @@ static int spl_common_init(bool setup_malloc) return 0; }
-int spl_alloc_bd(void) +void spl_set_bd(void) { /* * NOTE: On some platforms (e.g. x86) bdata may be in flash and not * writeable. */ - if (!gd->bd) { - gd->bd = malloc(sizeof(*gd->bd)); - if (!gd->bd) - return -ENOMEM; - } - - return 0; + if (!gd->bd) + gd->bd = &bdata; }
int spl_early_init(void) @@ -626,6 +624,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
debug(">>" SPL_TPL_PROMPT "board_init_r()\n");
+ spl_set_bd(); + #if defined(CONFIG_SYS_SPL_MALLOC_START) mem_malloc_init(CONFIG_SYS_SPL_MALLOC_START, CONFIG_SYS_SPL_MALLOC_SIZE); @@ -635,10 +635,6 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (spl_init()) hang(); } - if (IS_ENABLED(CONFIG_SPL_ALLOC_BD) && spl_alloc_bd()) { - puts("Cannot alloc bd\n"); - hang(); - } #if !defined(CONFIG_PPC) && !defined(CONFIG_ARCH_MX6) /* * timer_init() does not exist on PPC systems. The timer is initialized diff --git a/include/spl.h b/include/spl.h index 4f6e0e53f5..cee9a42ddb 100644 --- a/include/spl.h +++ b/include/spl.h @@ -357,15 +357,7 @@ u32 spl_mmc_boot_mode(const u32 boot_device); * If not overridden, it is weakly defined in common/spl/spl_mmc.c. */ int spl_mmc_boot_partition(const u32 boot_device); - -/** - * spl_alloc_bd() - Allocate space for bd_info - * - * This sets up the gd->bd pointer by allocating memory for it - * - * @return 0 if OK, -ENOMEM if out of memory - */ -int spl_alloc_bd(void); +void spl_set_bd(void);
/** * spl_set_header_raw_uboot() - Set up a standard SPL image structure
Hi Alexandru,
The goal here is to drop a feature that few boards use and reduce memory usage in SPL. It has been in place for two releases now.
If Falcon mode needs it, perhaps you could add an 'imply' in the Kconfig for that feature? Is there one? Or perhaps CONFIG_ARCH_FIXUP_FDT_MEMORY ?
One option would be to return an error in arch_fixup_fdt(). In general, fixups make things tricky because there is no way to determine when they are used but at least this one has a CONFIG.
Hi Simon
On 4/8/21 6:55 PM, Simon Glass wrote:
Hi Alexandru,
The argument that this has been in place for two releases is incorrect. Commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75 was only introduced with the v2021.04 release. It definitely was not in 2021.01. It's only in the last release, which is four days old t the time of this writing.
Although I was able to find one example, the reality is that we don't know the full extent of the breakage. The prudent thing at this point is to revert.
The knowledge of how to init the platform is in the devicetree and code. Why should kconfig also be involved in storing this knowledge? By this model, as the number of boards increases without bounds, every "if" predicate tends to be Kconfig driven. That is not maintainable, and why I think the original change --and the proposed fixes-- are broken by design.
Furthermore, I'm happy to discuss what to do about Falcon mode, and if we should kill it entirely (I have an alternative proposal). But we shouldn't have that discussion in a manner holding my platform hostage. To be fair to you, I don't think reverting a 64-byte savings in .data will hold your platform hostage either.
Alex
On Fri, Apr 9, 2021 at 2:20 PM Alex G. mr.nuke.me@gmail.com wrote:
Hi Simon
Hi Alexandru,
That original patch broke a bunch of OMAP boards, but enabling SPL_ALLOC_BD was the solution to fix the issue. Can you try enabling SPL_ALLOC_BD and see if that fixes it? Maybe we can make falcon mode imply it.
adam
Alex
Hi Simon
Hi Alexandru,
Yes. But another way of saying that is that we're 4 days in to the merge window. That's a bit early to say we must revert the change. If this was just before the release, yes, revert would be the right answer. It's also the case the original commit fixes some cases while also saving size, if I read it right. So a strict revert isn't right, we'd need to also probably also default y SPL_ALLOC_BD in some cases.
It would be "select" since it needs it rather than imply.
Hi Simon
Hi Alexandru,
I just ran into this as well finding that commit 38d6b7ebdaee ("spl: Drop bd_info in the data section") breaks Gateworks Ventana and defining SPL_ALLOC_BD does resolve it. In this case, Falcon mode is not being used and the breakage is because arch/arm/mach-imx/spl.c dram_init_banksize() accesses gd->bd which is NULL.
So I would guess that this probably broke a whole lot of IMX based boards that use SPL.
I don't quite know what the best solution is... we now have a v2021.04 that is broken for several or many boards and I dont' know if its clear what cases break.
Tim
Hi Simon
Hi Alexandru,
Looking forward, I think we need to rework this. Simon, I gather you have some platforms where we need to set gd->bd to something that we malloc() ? So perhaps spl_set_bd() should have been __weak so that architectures / platforms could override as needed, but also move it just past mem_malloc_init().
Hi Simon
Hi Alexandru,
On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: > > This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. > > struct global_data contains a pointer to the bd_info structure. This > pointer was populated spl_set_bd() to a pre-allocated bd_info in the > ".data" section. The referenced commit replaced this mechanism to one > that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. > which very few boards do. > > The result is that (struct global_data)->bd is NULL in SPL on most > platforms. This breaks falcon mode, since arch_fixup_fdt() tries to > access (struct global_data)->bd and set the "/memory" node in the > devicetree. The result is that the "/memory" node contains garbage > values, causing linux to panic() as it sets up the page table. > > Instead of trying to fix the mess, potentially causing other issues, > revert to the code that worked, while this change is reworked.
Let's try and avoid making new weak functions. Why not introduce a spl_platform_alloc_bd(), that each plat- *must* implement? No diversion to Kconfig and no __weak__ required.
Alex
Hi Simon
On 4/8/21 6:55 PM, Simon Glass wrote: > Hi Alexandru, > > On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: > > > > This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. > > > > struct global_data contains a pointer to the bd_info structure. This > > pointer was populated spl_set_bd() to a pre-allocated bd_info in the > > ".data" section. The referenced commit replaced this mechanism to one > > that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. > > which very few boards do. > > > > The result is that (struct global_data)->bd is NULL in SPL on most > > platforms. This breaks falcon mode, since arch_fixup_fdt() tries to > > access (struct global_data)->bd and set the "/memory" node in the > > devicetree. The result is that the "/memory" node contains garbage > > values, causing linux to panic() as it sets up the page table. > > > > Instead of trying to fix the mess, potentially causing other issues, > > revert to the code that worked, while this change is reworked. > > The goal here is to drop a feature that few boards use and reduce > memory usage in SPL. It has been in place for two releases now. > > If Falcon mode needs it, perhaps you could add an 'imply' in the > Kconfig for that feature? Is there one? Or perhaps > CONFIG_ARCH_FIXUP_FDT_MEMORY ? > > One option would be to return an error in arch_fixup_fdt(). In > general, fixups make things tricky because there is no way to > determine when they are used but at least this one has a CONFIG. >
Well, who needs something different than what we had before exactly? This shouldn't be kicked up to "every SoC must define...", but maybe "every architecture must define..." is OK. Or maybe it's really just "a few unusual platforms need" and so a weak function makes sense.
On Fri, Apr 9, 2021 at 2:20 PM Alex G. mr.nuke.me@gmail.com wrote: > > Hi Simon > > On 4/8/21 6:55 PM, Simon Glass wrote: >> Hi Alexandru, >> >> On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: >>> >>> This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. >>> >>> struct global_data contains a pointer to the bd_info structure. This >>> pointer was populated spl_set_bd() to a pre-allocated bd_info in the >>> ".data" section. The referenced commit replaced this mechanism to one >>> that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. >>> which very few boards do. >>> >>> The result is that (struct global_data)->bd is NULL in SPL on most >>> platforms. This breaks falcon mode, since arch_fixup_fdt() tries to >>> access (struct global_data)->bd and set the "/memory" node in the >>> devicetree. The result is that the "/memory" node contains garbage >>> values, causing linux to panic() as it sets up the page table. >>> >>> Instead of trying to fix the mess, potentially causing other issues, >>> revert to the code that worked, while this change is reworked. >> >> The goal here is to drop a feature that few boards use and reduce >> memory usage in SPL. It has been in place for two releases now. >> >> If Falcon mode needs it, perhaps you could add an 'imply' in the >> Kconfig for that feature? Is there one? Or perhaps >> CONFIG_ARCH_FIXUP_FDT_MEMORY ? >> >> One option would be to return an error in arch_fixup_fdt(). In >> general, fixups make things tricky because there is no way to >> determine when they are used but at least this one has a CONFIG. >> > > The argument that this has been in place for two releases is incorrect. > Commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75 was only introduced with > the v2021.04 release. It definitely was not in 2021.01. It's only in the > last release, which is four days old t the time of this writing.
> Although I was able to find one example, the reality is that we don't > know the full extent of the breakage. The prudent thing at this point is > to revert. > > The knowledge of how to init the platform is in the devicetree and code. > Why should kconfig also be involved in storing this knowledge? By this > model, as the number of boards increases without bounds, every "if" > predicate tends to be Kconfig driven. That is not maintainable, and why > I think the original change --and the proposed fixes-- are broken by design. > > Furthermore, I'm happy to discuss what to do about Falcon mode, and if > we should kill it entirely (I have an alternative proposal). But we > shouldn't have that discussion in a manner holding my platform hostage. > To be fair to you, I don't think reverting a 64-byte savings in .data > will hold your platform hostage either.
I'm not sure. From reading the commit message of the broken change, it seems the main driver was to save 64 bytes on coral. I'm assuming coral is the codename for a platform.
We can can have arch_spl_alloc_bd() instead of plat_(). I don't believe in weak functins, as I see them as the problems that "made sense at the time".
Alex
On Fri, Apr 09, 2021 at 03:24:41PM -0500, Adam Ford wrote: > On Fri, Apr 9, 2021 at 2:20 PM Alex G. mr.nuke.me@gmail.com wrote: > > > > Hi Simon > > > > On 4/8/21 6:55 PM, Simon Glass wrote: > > > Hi Alexandru, > > > > > > On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: > > > > > > > > This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. > > > > > > > > struct global_data contains a pointer to the bd_info structure. This > > > > pointer was populated spl_set_bd() to a pre-allocated bd_info in the > > > > ".data" section. The referenced commit replaced this mechanism to one > > > > that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. > > > > which very few boards do. > > > > > > > > The result is that (struct global_data)->bd is NULL in SPL on most > > > > platforms. This breaks falcon mode, since arch_fixup_fdt() tries to > > > > access (struct global_data)->bd and set the "/memory" node in the > > > > devicetree. The result is that the "/memory" node contains garbage > > > > values, causing linux to panic() as it sets up the page table. > > > > > > > > Instead of trying to fix the mess, potentially causing other issues, > > > > revert to the code that worked, while this change is reworked. > > > > > > The goal here is to drop a feature that few boards use and reduce > > > memory usage in SPL. It has been in place for two releases now. > > > > > > If Falcon mode needs it, perhaps you could add an 'imply' in the > > > Kconfig for that feature? Is there one? Or perhaps > > > CONFIG_ARCH_FIXUP_FDT_MEMORY ? > > > > > > One option would be to return an error in arch_fixup_fdt(). In > > > general, fixups make things tricky because there is no way to > > > determine when they are used but at least this one has a CONFIG. > > > > > > > The argument that this has been in place for two releases is incorrect. > > Commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75 was only introduced with > > the v2021.04 release. It definitely was not in 2021.01. It's only in the > > last release, which is four days old t the time of this writing.
> > Although I was able to find one example, the reality is that we don't > > know the full extent of the breakage. The prudent thing at this point is > > to revert. > > > > The knowledge of how to init the platform is in the devicetree and code. > > Why should kconfig also be involved in storing this knowledge? By this > > model, as the number of boards increases without bounds, every "if" > > predicate tends to be Kconfig driven. That is not maintainable, and why > > I think the original change --and the proposed fixes-- are broken by design. > > > > Furthermore, I'm happy to discuss what to do about Falcon mode, and if > > we should kill it entirely (I have an alternative proposal). But we > > shouldn't have that discussion in a manner holding my platform hostage. > > To be fair to you, I don't think reverting a 64-byte savings in .data > > will hold your platform hostage either. > > That original patch broke a bunch of OMAP boards, but enabling > SPL_ALLOC_BD was the solution to fix the issue. > Can you try enabling SPL_ALLOC_BD and see if that fixes it? Maybe we > can make falcon mode imply it.
Yes, coral is an x86 chromebook. It also says: This uses up space in the SPL binary but it always starts as zero. Also some boards cannot support data in TPL (e.g. Intel Apollo Lake).
and defaults the new feature to enabled on all x86. And there's a comment about x86 in the function (that with the changes made isn't so helpful/correct?) now too. So yes, I want to see what Simon
I see weak functions as a good solution when the problem is something where the majority of the (cross-platform) cases require the same solution, but there's one or two oddities out there. But regardless, we need to have the problem better defined before we can propose a solution.
Hi Tom, Alex,
On Fri, Apr 9, 2021 at 1:53 PM Tom Rini trini@konsulko.com wrote: > > On Fri, Apr 09, 2021 at 03:24:41PM -0500, Adam Ford wrote: > > On Fri, Apr 9, 2021 at 2:20 PM Alex G. mr.nuke.me@gmail.com wrote: > > > > > > Hi Simon > > > > > > On 4/8/21 6:55 PM, Simon Glass wrote: > > > > Hi Alexandru, > > > > > > > > On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: > > > > > > > > > > This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. > > > > > > > > > > struct global_data contains a pointer to the bd_info structure. This > > > > > pointer was populated spl_set_bd() to a pre-allocated bd_info in the > > > > > ".data" section. The referenced commit replaced this mechanism to one > > > > > that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. > > > > > which very few boards do. > > > > > > > > > > The result is that (struct global_data)->bd is NULL in SPL on most > > > > > platforms. This breaks falcon mode, since arch_fixup_fdt() tries to > > > > > access (struct global_data)->bd and set the "/memory" node in the > > > > > devicetree. The result is that the "/memory" node contains garbage > > > > > values, causing linux to panic() as it sets up the page table. > > > > > > > > > > Instead of trying to fix the mess, potentially causing other issues, > > > > > revert to the code that worked, while this change is reworked. > > > > > > > > The goal here is to drop a feature that few boards use and reduce > > > > memory usage in SPL. It has been in place for two releases now. > > > > > > > > If Falcon mode needs it, perhaps you could add an 'imply' in the > > > > Kconfig for that feature? Is there one? Or perhaps > > > > CONFIG_ARCH_FIXUP_FDT_MEMORY ? > > > > > > > > One option would be to return an error in arch_fixup_fdt(). In > > > > general, fixups make things tricky because there is no way to > > > > determine when they are used but at least this one has a CONFIG. > > > > > > > > > > The argument that this has been in place for two releases is incorrect. > > > Commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75 was only introduced with > > > the v2021.04 release. It definitely was not in 2021.01. It's only in the > > > last release, which is four days old t the time of this writing. > > Yes. But another way of saying that is that we're 4 days in to the > merge window. That's a bit early to say we must revert the change. If > this was just before the release, yes, revert would be the right answer. > It's also the case the original commit fixes some cases while also > saving size, if I read it right. So a strict revert isn't right, we'd > need to also probably also default y SPL_ALLOC_BD in some cases. > > > > Although I was able to find one example, the reality is that we don't > > > know the full extent of the breakage. The prudent thing at this point is > > > to revert. > > > > > > The knowledge of how to init the platform is in the devicetree and code. > > > Why should kconfig also be involved in storing this knowledge? By this > > > model, as the number of boards increases without bounds, every "if" > > > predicate tends to be Kconfig driven. That is not maintainable, and why > > > I think the original change --and the proposed fixes-- are broken by design. > > > > > > Furthermore, I'm happy to discuss what to do about Falcon mode, and if > > > we should kill it entirely (I have an alternative proposal). But we > > > shouldn't have that discussion in a manner holding my platform hostage. > > > To be fair to you, I don't think reverting a 64-byte savings in .data > > > will hold your platform hostage either. > > > > That original patch broke a bunch of OMAP boards, but enabling > > SPL_ALLOC_BD was the solution to fix the issue. > > Can you try enabling SPL_ALLOC_BD and see if that fixes it? Maybe we > > can make falcon mode imply it. > > It would be "select" since it needs it rather than imply. >
So how about enabling the Kconfig for iMX? I am not sure how many platforms do actually need this feature?
Another option might be to (just as a test) take the 'bd' out of global_data when the Kconfig is not defined, to find out which platforms use it?
As to a weak function, what would the default behaviour be? If we can define that, then it would be better IMO.
When we try to refactor things, weak functions and undefined (or arch-specific behaviour) can really make things tough.
On Tue, Apr 13, 2021 at 05:49:19AM +1200, Simon Glass wrote:
Hi Tom, Alex,
On Fri, Apr 09, 2021 at 05:29:36PM -0700, Tim Harvey wrote: > On Fri, Apr 9, 2021 at 1:53 PM Tom Rini trini@konsulko.com wrote: > > > > On Fri, Apr 09, 2021 at 03:24:41PM -0500, Adam Ford wrote: > > > On Fri, Apr 9, 2021 at 2:20 PM Alex G. mr.nuke.me@gmail.com wrote: > > > > > > > > Hi Simon > > > > > > > > On 4/8/21 6:55 PM, Simon Glass wrote: > > > > > Hi Alexandru, > > > > > > > > > > On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: > > > > > > > > > > > > This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. > > > > > > > > > > > > struct global_data contains a pointer to the bd_info structure. This > > > > > > pointer was populated spl_set_bd() to a pre-allocated bd_info in the > > > > > > ".data" section. The referenced commit replaced this mechanism to one > > > > > > that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. > > > > > > which very few boards do. > > > > > > > > > > > > The result is that (struct global_data)->bd is NULL in SPL on most > > > > > > platforms. This breaks falcon mode, since arch_fixup_fdt() tries to > > > > > > access (struct global_data)->bd and set the "/memory" node in the > > > > > > devicetree. The result is that the "/memory" node contains garbage > > > > > > values, causing linux to panic() as it sets up the page table. > > > > > > > > > > > > Instead of trying to fix the mess, potentially causing other issues, > > > > > > revert to the code that worked, while this change is reworked. > > > > > > > > > > The goal here is to drop a feature that few boards use and reduce > > > > > memory usage in SPL. It has been in place for two releases now. > > > > > > > > > > If Falcon mode needs it, perhaps you could add an 'imply' in the > > > > > Kconfig for that feature? Is there one? Or perhaps > > > > > CONFIG_ARCH_FIXUP_FDT_MEMORY ? > > > > > > > > > > One option would be to return an error in arch_fixup_fdt(). In > > > > > general, fixups make things tricky because there is no way to > > > > > determine when they are used but at least this one has a CONFIG. > > > > > > > > > > > > > The argument that this has been in place for two releases is incorrect. > > > > Commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75 was only introduced with > > > > the v2021.04 release. It definitely was not in 2021.01. It's only in the > > > > last release, which is four days old t the time of this writing. > > > > Yes. But another way of saying that is that we're 4 days in to the > > merge window. That's a bit early to say we must revert the change. If > > this was just before the release, yes, revert would be the right answer. > > It's also the case the original commit fixes some cases while also > > saving size, if I read it right. So a strict revert isn't right, we'd > > need to also probably also default y SPL_ALLOC_BD in some cases. > > > > > > Although I was able to find one example, the reality is that we don't > > > > know the full extent of the breakage. The prudent thing at this point is > > > > to revert. > > > > > > > > The knowledge of how to init the platform is in the devicetree and code. > > > > Why should kconfig also be involved in storing this knowledge? By this > > > > model, as the number of boards increases without bounds, every "if" > > > > predicate tends to be Kconfig driven. That is not maintainable, and why > > > > I think the original change --and the proposed fixes-- are broken by design. > > > > > > > > Furthermore, I'm happy to discuss what to do about Falcon mode, and if > > > > we should kill it entirely (I have an alternative proposal). But we > > > > shouldn't have that discussion in a manner holding my platform hostage. > > > > To be fair to you, I don't think reverting a 64-byte savings in .data > > > > will hold your platform hostage either. > > > > > > That original patch broke a bunch of OMAP boards, but enabling > > > SPL_ALLOC_BD was the solution to fix the issue. > > > Can you try enabling SPL_ALLOC_BD and see if that fixes it? Maybe we > > > can make falcon mode imply it. > > > > It would be "select" since it needs it rather than imply. > > > > I just ran into this as well finding that commit 38d6b7ebdaee ("spl: > Drop bd_info in the data section") breaks Gateworks Ventana and > defining SPL_ALLOC_BD does resolve it. In this case, Falcon mode is > not being used and the breakage is because arch/arm/mach-imx/spl.c > dram_init_banksize() accesses gd->bd which is NULL. > > So I would guess that this probably broke a whole lot of IMX based > boards that use SPL. > > I don't quite know what the best solution is... we now have a v2021.04 > that is broken for several or many boards and I dont' know if its > clear what cases break.
That was an OK answer for the first group we hit this on.
And that might help us figure out the second grouping of platforms, yes.
Well, what was the problem you were trying to solve here? I assumed there was a case where things actively broke, with the previous design, and it's not just the 64byte savings in some cases. But is it?
Hi Tom,
Hi Tom, Alex,
On 4/12/21 8:25 AM, Tom Rini wrote: > On Fri, Apr 09, 2021 at 05:29:36PM -0700, Tim Harvey wrote: > > On Fri, Apr 9, 2021 at 1:53 PM Tom Rini trini@konsulko.com wrote: > > > > > > On Fri, Apr 09, 2021 at 03:24:41PM -0500, Adam Ford wrote: > > > > On Fri, Apr 9, 2021 at 2:20 PM Alex G. mr.nuke.me@gmail.com wrote: > > > > > > > > > > Hi Simon > > > > > > > > > > On 4/8/21 6:55 PM, Simon Glass wrote: > > > > > > Hi Alexandru, > > > > > > > > > > > > On Fri, 9 Apr 2021 at 04:56, Alexandru Gagniuc mr.nuke.me@gmail.com wrote: > > > > > > > > > > > > > > This reverts commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75. > > > > > > > > > > > > > > struct global_data contains a pointer to the bd_info structure. This > > > > > > > pointer was populated spl_set_bd() to a pre-allocated bd_info in the > > > > > > > ".data" section. The referenced commit replaced this mechanism to one > > > > > > > that uses malloc(). That new mechanism is only used if SPL_ALLOC_BD=y. > > > > > > > which very few boards do. > > > > > > > > > > > > > > The result is that (struct global_data)->bd is NULL in SPL on most > > > > > > > platforms. This breaks falcon mode, since arch_fixup_fdt() tries to > > > > > > > access (struct global_data)->bd and set the "/memory" node in the > > > > > > > devicetree. The result is that the "/memory" node contains garbage > > > > > > > values, causing linux to panic() as it sets up the page table. > > > > > > > > > > > > > > Instead of trying to fix the mess, potentially causing other issues, > > > > > > > revert to the code that worked, while this change is reworked. > > > > > > > > > > > > The goal here is to drop a feature that few boards use and reduce > > > > > > memory usage in SPL. It has been in place for two releases now. > > > > > > > > > > > > If Falcon mode needs it, perhaps you could add an 'imply' in the > > > > > > Kconfig for that feature? Is there one? Or perhaps > > > > > > CONFIG_ARCH_FIXUP_FDT_MEMORY ? > > > > > > > > > > > > One option would be to return an error in arch_fixup_fdt(). In > > > > > > general, fixups make things tricky because there is no way to > > > > > > determine when they are used but at least this one has a CONFIG. > > > > > > > > > > > > > > > > The argument that this has been in place for two releases is incorrect. > > > > > Commit 38d6b7ebdaee3e0e8426ef1b9df88bdce8ae2e75 was only introduced with > > > > > the v2021.04 release. It definitely was not in 2021.01. It's only in the > > > > > last release, which is four days old t the time of this writing. > > > > > > Yes. But another way of saying that is that we're 4 days in to the > > > merge window. That's a bit early to say we must revert the change. If > > > this was just before the release, yes, revert would be the right answer. > > > It's also the case the original commit fixes some cases while also > > > saving size, if I read it right. So a strict revert isn't right, we'd > > > need to also probably also default y SPL_ALLOC_BD in some cases. > > > > > > > > Although I was able to find one example, the reality is that we don't > > > > > know the full extent of the breakage. The prudent thing at this point is > > > > > to revert. > > > > > > > > > > The knowledge of how to init the platform is in the devicetree and code. > > > > > Why should kconfig also be involved in storing this knowledge? By this > > > > > model, as the number of boards increases without bounds, every "if" > > > > > predicate tends to be Kconfig driven. That is not maintainable, and why > > > > > I think the original change --and the proposed fixes-- are broken by design. > > > > > > > > > > Furthermore, I'm happy to discuss what to do about Falcon mode, and if > > > > > we should kill it entirely (I have an alternative proposal). But we > > > > > shouldn't have that discussion in a manner holding my platform hostage. > > > > > To be fair to you, I don't think reverting a 64-byte savings in .data > > > > > will hold your platform hostage either. > > > > > > > > That original patch broke a bunch of OMAP boards, but enabling > > > > SPL_ALLOC_BD was the solution to fix the issue. > > > > Can you try enabling SPL_ALLOC_BD and see if that fixes it? Maybe we > > > > can make falcon mode imply it. > > > > > > It would be "select" since it needs it rather than imply. > > > > > > > I just ran into this as well finding that commit 38d6b7ebdaee ("spl: > > Drop bd_info in the data section") breaks Gateworks Ventana and > > defining SPL_ALLOC_BD does resolve it. In this case, Falcon mode is > > not being used and the breakage is because arch/arm/mach-imx/spl.c > > dram_init_banksize() accesses gd->bd which is NULL. > > > > So I would guess that this probably broke a whole lot of IMX based > > boards that use SPL. > > > > I don't quite know what the best solution is... we now have a v2021.04 > > that is broken for several or many boards and I dont' know if its > > clear what cases break. > > Looking forward, I think we need to rework this. Simon, I gather you > have some platforms where we need to set gd->bd to something that we > malloc() ? So perhaps spl_set_bd() should have been __weak so that > architectures / platforms could override as needed, but also move it > just past mem_malloc_init().
OK I will take a look at that.
Yes the region of memory is not writable, so must be allocated at runtime.
Regards, SImon
On Tue, Apr 13, 2021 at 06:26:08AM +1200, Simon Glass wrote:
Hi Tom,
[snip]
Where, on x86? Some ARM cases? That's one of the other things to sort out here.
Hi Tom,
Hi Tom,
[snip]
Yes, on coral and likely newer things to come...For ARM I don't know of any such problems.
On Mon, Apr 12, 2021 at 11:44 AM Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
[snip]
I'm not sure I understand if there is agreement on a solution to this patch breaking several or many boards? I count 58 IMX6 boards using SPL and none of them currently define CONFIG_SPL_ALLOC_BD=y. It sounds like Adam said OMAP boards were broken as well and I'm not clear if those boards are fixed yet either.
Tim
Hi Tom,
Hi Tom,
[snip]
I have already submitted a patch for the OMAP boards that I maintain to address the issue. I wonder if it would make sense to make these architectures select CONFIG_SPL_ALLOC_BD automatically instead of having a bunch of individual boards enable it. I have not checked any of the IMX8M or IMX6 boards that I maintain, but I am watching this thread. I can test the CONFIG_SPL_ALLOC_BD on my boards if people think there is value.
adam
Tim
Hi Tom,
Hi Tom,
[snip]
> As to a weak function, what would the default behaviour be? If we can > define that, then it would be better IMO. > > When we try to refactor things, weak functions and undefined (or > arch-specific behaviour) can really make things tough.
I've been thinking about what Simon said -- that the memory region is not writable on x86. But that memory is in .data, which should be writable. It doesn't make sense.
Alex
Hi Tom, Alex,
I started down the path of seeing what fails to build if in SPL we don't have gd->bd, but well, then we get back to the OP, where Alex notes it's all cases of falcon mode. And Tim noted that i.MX is widely broken due to setting up memory info as well more generally. It looks like Rockchip hits that and Marvell and probably a few others.
So I think the right answer is the revert, followed by figuring out how to let x86 instead have a malloc'd one. Perhaps spl_board_init() is OK?
participants (6)
Adam Ford
Alex G.
Alexandru Gagniuc
Tim Harvey
