[PATCHv2] Kconfig: Remove TARGET_TRICORDER references
These were missed when removing the rest of the tricorder platform.
Fixes: d137604c20a4 ("arm: Remove tricorder board") Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - Drop unrelated boot/Kconfig change noticed by Maciej W. Rozycki --- Kconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/Kconfig b/Kconfig index a7b2b6db7425..eb55f2511d95 100644 --- a/Kconfig +++ b/Kconfig @@ -599,7 +599,6 @@ config SYS_HAS_SRAM bool default y if TARGET_PIC32MZDASK default y if TARGET_DEVKIT8000 - default y if TARGET_TRICORDER help Enable this to allow support for the on board SRAM. SRAM base address is controlled by CONFIG_SYS_SRAM_BASE. @@ -609,14 +608,12 @@ config SYS_SRAM_BASE hex default 0x80000000 if TARGET_PIC32MZDASK default 0x40200000 if TARGET_DEVKIT8000 - default 0x40200000 if TARGET_TRICORDER default 0x0
config SYS_SRAM_SIZE hex default 0x00080000 if TARGET_PIC32MZDASK default 0x10000 if TARGET_DEVKIT8000 - default 0x10000 if TARGET_TRICORDER default 0x0
config SYS_MONITOR_LEN
