[U-Boot] [PATCH 0/8] ppc4xx: Update DLVision 10G support
Dirk Eibach (8): ppc4xx: Improve DLVision-10G PLL setup ppc4xx: Improve video board detection hwmon: Extend lm63.c to support LM64 ppc4xx: Adapt DLVision 10G to new FPGA firmware ppc4xx: Set DLVision 10G osd position to linux defaults ppc4xx: Enable MPC92469AC on DLVision 10G ppc4xx: Improve fan PWM curve on DLVision 10G ppc4xx: Do not stop booting on any keypress on dlvision-10g
board/gdsys/405ep/405ep.c | 9 +++++- board/gdsys/405ep/dlvision-10g.c | 41 ++++++++++++++++++++++----- board/gdsys/common/osd.c | 57 ++++++++++++++++++++++++++++++++++++-- drivers/hwmon/lm63.c | 28 ++++++++++++++++-- include/configs/dlvision-10g.h | 12 ++++++- include/gdsys_fpga.h | 13 +++++--- 6 files changed, 137 insertions(+), 23 deletions(-)
Signed-off-by: Dirk Eibach eibach@gdsys.de --- board/gdsys/common/osd.c | 55 +++++++++++++++++++++++++++++++++++++++++++-- 1 files changed, 52 insertions(+), 3 deletions(-)
diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index 4d8c046..6e4edae 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -30,7 +30,12 @@ #define CH7301_I2C_ADDR 0x75
#define ICS8N3QV01_I2C_ADDR 0x6E -#define ICS8N3QV01_FREF 114285 +#define ICS8N3QV01_FREF 114285000 +#define ICS8N3QV01_FREF_LL 114285000LL +#define ICS8N3QV01_F_DEFAULT_0 156250000LL +#define ICS8N3QV01_F_DEFAULT_1 125000000LL +#define ICS8N3QV01_F_DEFAULT_2 100000000LL +#define ICS8N3QV01_F_DEFAULT_3 25175000LL
#define SIL1178_MASTER_I2C_ADDRESS 0x38 #define SIL1178_SLAVE_I2C_ADDRESS 0x39 @@ -150,6 +155,41 @@ static void mpc92469ac_set(unsigned screen, unsigned int fout) #endif
#ifdef CONFIG_SYS_ICS8N3QV01 + +static unsigned int ics8n3qv01_get_fout_calc(unsigned screen, unsigned index) +{ + unsigned long long n; + unsigned long long mint; + unsigned long long mfrac; + u8 reg_a, reg_b, reg_c, reg_d, reg_f; + unsigned long long fout_calc; + + if (index > 3) + return 0; + + reg_a = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 0 + index); + reg_b = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 4 + index); + reg_c = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 8 + index); + reg_d = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 12 + index); + reg_f = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 20 + index); + + mint = ((reg_a >> 1) & 0x1f) | (reg_f & 0x20); + mfrac = ((reg_a & 0x01) << 17) | (reg_b << 9) | (reg_c << 1) + | (reg_d >> 7); + n = reg_d & 0x7f; + + fout_calc = (mint * ICS8N3QV01_FREF_LL + + mfrac * ICS8N3QV01_FREF_LL / 262144LL + + ICS8N3QV01_FREF_LL / 524288LL + + n / 2) + / n + * 1000000 + / (1000000 - 100); + + return fout_calc; +} + + static void ics8n3qv01_calc_parameters(unsigned int fout, unsigned int *_mint, unsigned int *_mfrac, unsigned int *_n) @@ -160,7 +200,7 @@ static void ics8n3qv01_calc_parameters(unsigned int fout, unsigned int mint; unsigned long long mfrac;
- n = 2550000000U / fout; + n = (2215000000U + fout / 2) / fout; if ((n & 1) && (n > 5)) n -= 1;
@@ -184,9 +224,18 @@ static void ics8n3qv01_set(unsigned screen, unsigned int fout) unsigned int n; unsigned int mint; unsigned int mfrac; + unsigned int fout_calc; + unsigned long long fout_prog; + long long off_ppm; u8 reg0, reg4, reg8, reg12, reg18, reg20;
- ics8n3qv01_calc_parameters(fout, &mint, &mfrac, &n); + fout_calc = ics8n3qv01_get_fout_calc(screen, 1); + off_ppm = (fout_calc - ICS8N3QV01_F_DEFAULT_1) * 1000000 + / ICS8N3QV01_F_DEFAULT_1; + printf(" PLL is off by %lld ppm\n", off_ppm); + fout_prog = (unsigned long long)fout * (unsigned long long)fout_calc + / ICS8N3QV01_F_DEFAULT_1; + ics8n3qv01_calc_parameters(fout_prog, &mint, &mfrac, &n);
reg0 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 0) & 0xc0; reg0 |= (mint & 0x1f) << 1;
Signed-off-by: Dirk Eibach eibach@gdsys.de --- board/gdsys/405ep/dlvision-10g.c | 26 ++++++++++++++++++-------- 1 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c index df7fb14..d7b4fb2 100644 --- a/board/gdsys/405ep/dlvision-10g.c +++ b/board/gdsys/405ep/dlvision-10g.c @@ -31,6 +31,9 @@
#include "../common/osd.h"
+#define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) +#define LATCH2_MC2_PRESENT_N 0x0080 + enum { UNITTYPE_VIDEO_USER = 0, UNITTYPE_MAIN_USER = 1, @@ -206,8 +209,8 @@ static void print_fpga_info(unsigned dev) */ int checkboard(void) { - unsigned k; char *s = getenv("serial#"); + u16 latch2 = in_le16((void *)LATCH2_BASE);
printf("Board: ");
@@ -220,20 +223,27 @@ int checkboard(void)
puts("\n");
- for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) - print_fpga_info(k); + print_fpga_info(0); + if (!(latch2 & LATCH2_MC2_PRESENT_N)) + print_fpga_info(1);
return 0; }
int last_stage_init(void) { - unsigned k; + ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); + u16 versions = in_le16(&fpga->versions); + u16 latch2 = in_le16((void *)LATCH2_BASE); + + if (((versions >> 4) & 0x000f) != UNITTYPE_MAIN_USER) + return 0; + + if (!get_fpga_state(0)) + osd_probe(0);
- for (k = 0; k < CONFIG_SYS_OSD_SCREENS; ++k) - if (!get_fpga_state(k) - || (get_fpga_state(k) == FPGA_STATE_DONE_FAILED)) - osd_probe(k); + if (!(latch2 & LATCH2_MC2_PRESENT_N) && !get_fpga_state(1)) + osd_probe(1);
return 0; }
This patch adds support for the National LM64 temperature sensor with integrated fan control to lm63.c. It's used on the GDSys DLVision-10G board (405EP).
Main difference between LM63 and LM64 is 16°C offset in sensor readings.
Signed-off-by: Dirk Eibach eibach@gdsys.de --- drivers/hwmon/lm63.c | 28 ++++++++++++++++++++++++---- include/configs/dlvision-10g.h | 2 +- 2 files changed, 25 insertions(+), 5 deletions(-)
diff --git a/drivers/hwmon/lm63.c b/drivers/hwmon/lm63.c index 03616e1..2f1f3cf 100644 --- a/drivers/hwmon/lm63.c +++ b/drivers/hwmon/lm63.c @@ -23,14 +23,15 @@ */
/* - * National LM63 Temperature Sensor + * National LM63/LM64 Temperature Sensor + * Main difference: LM 64 has -16 Kelvin temperature offset */
#include <common.h> #include <i2c.h> #include <dtt.h>
-#define DTT_I2C_DEV_CODE 0x4C /* National LM63 device */ +#define DTT_I2C_LM63_ADDR 0x4C /* National LM63 device */
#define DTT_READ_TEMP_RMT_MSB 0x01 #define DTT_CONFIG 0x03 @@ -58,7 +59,8 @@ int dtt_read(int sensor, int reg) /* * Calculate sensor address and register. */ - sensor = DTT_I2C_DEV_CODE; /* address of lm63 is not adjustable */ + if (!sensor) + sensor = DTT_I2C_LM63_ADDR; /* legacy config */
dlen = 1;
@@ -79,7 +81,8 @@ int dtt_write(int sensor, int reg, int val) /* * Calculate sensor address and register. */ - sensor = DTT_I2C_DEV_CODE; /* address of lm63 is not adjustable */ + if (!sensor) + sensor = DTT_I2C_LM63_ADDR; /* legacy config */
dlen = 1; data[0] = (char)(val & 0xff); @@ -93,6 +96,11 @@ int dtt_write(int sensor, int reg, int val) return 0; } /* dtt_write() */
+static int is_lm64(int sensor) +{ + return sensor && (sensor != DTT_I2C_LM63_ADDR); +} + static int _dtt_init(int sensor) { int i; @@ -117,14 +125,23 @@ static int _dtt_init(int sensor) return 1;
/* + * Make sure PWM Lookup-Table is writeable + */ + if (dtt_write(sensor, DTT_FAN_CONFIG, 0x20) != 0) + return 1; + + /* * Setup PWM Lookup-Table */ for (i = 0; i < sizeof(pwm_lookup) / sizeof(struct pwm_lookup_entry); i++) { int address = DTT_PWM_LOOKUP_BASE + 2 * i; val = pwm_lookup[i].temp; + if (is_lm64(sensor)) + val -= 16; if (dtt_write(sensor, address, val) != 0) return 1; + val = dtt_read(sensor, address); val = pwm_lookup[i].pwm; if (dtt_write(sensor, address + 1, val) != 0) return 1; @@ -152,6 +169,9 @@ int dtt_get_temp(int sensor) s16 temp = (dtt_read(sensor, DTT_READ_TEMP_RMT_MSB) << 8) | (dtt_read(sensor, DTT_READ_TEMP_RMT_LSB));
+ if (is_lm64(sensor)) + temp += 16 << 8; + /* Ignore LSB for now, U-Boot only prints natural numbers */ return temp >> 8; } diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index f7609d7..ae209fa 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -111,7 +111,7 @@
/* Temp sensor/hwmon/dtt */ #define CONFIG_DTT_LM63 1 /* National LM63 */ -#define CONFIG_DTT_SENSORS { 0 } /* Sensor addresses */ +#define CONFIG_DTT_SENSORS { 0x4c, 0x4e } /* Sensor addresses */ #define CONFIG_DTT_PWM_LOOKUPTABLE \ { { 40, 10 }, { 50, 20 }, { 60, 40 } } #define CONFIG_DTT_TACH_LIMIT 0xa10
Signed-off-by: Dirk Eibach eibach@gdsys.de --- board/gdsys/405ep/405ep.c | 9 ++++++++- board/gdsys/405ep/dlvision-10g.c | 25 ++++++++++++++++++++----- include/configs/dlvision-10g.h | 2 ++ include/gdsys_fpga.h | 8 +++----- 4 files changed, 33 insertions(+), 11 deletions(-)
diff --git a/board/gdsys/405ep/405ep.c b/board/gdsys/405ep/405ep.c index 86a3ec8..8b80533 100644 --- a/board/gdsys/405ep/405ep.c +++ b/board/gdsys/405ep/405ep.c @@ -110,6 +110,11 @@ int board_early_init_f(void)
for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) { ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(k); +#ifdef CONFIG_SYS_FPGA_NO_RFL_HI + u16 *reflection_target = &fpga->reflection_low; +#else + u16 *reflection_target = &fpga->reflection_high; +#endif /* * wait for fpga out of reset */ @@ -117,9 +122,11 @@ int board_early_init_f(void) while (1) { out_le16(&fpga->reflection_low, REFLECTION_TESTPATTERN); - if (in_le16(&fpga->reflection_high) == + + if (in_le16(reflection_target) == REFLECTION_TESTPATTERN_INV) break; + udelay(100000); if (ctr++ > 5) { gd->fpga_state[k] |= diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c index d7b4fb2..0388541 100644 --- a/board/gdsys/405ep/dlvision-10g.c +++ b/board/gdsys/405ep/dlvision-10g.c @@ -34,6 +34,8 @@ #define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) #define LATCH2_MC2_PRESENT_N 0x0080
+#define LATCH3_BASE (CONFIG_SYS_LATCH_BASE + 0x300) + enum { UNITTYPE_VIDEO_USER = 0, UNITTYPE_MAIN_USER = 1, @@ -63,6 +65,20 @@ enum { RAM_DDR2_64 = 2, };
+static unsigned int get_hwver(void) +{ + u16 latch3 = in_le16((void *)LATCH3_BASE); + + return latch3 & 0x0003; +} + +static unsigned int get_mc2_present(void) +{ + u16 latch2 = in_le16((void *)LATCH2_BASE); + + return !(latch2 & LATCH2_MC2_PRESENT_N); +} + static void print_fpga_info(unsigned dev) { ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(dev); @@ -210,7 +226,6 @@ static void print_fpga_info(unsigned dev) int checkboard(void) { char *s = getenv("serial#"); - u16 latch2 = in_le16((void *)LATCH2_BASE);
printf("Board: ");
@@ -224,7 +239,7 @@ int checkboard(void) puts("\n");
print_fpga_info(0); - if (!(latch2 & LATCH2_MC2_PRESENT_N)) + if (get_mc2_present()) print_fpga_info(1);
return 0; @@ -234,15 +249,15 @@ int last_stage_init(void) { ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); u16 versions = in_le16(&fpga->versions); - u16 latch2 = in_le16((void *)LATCH2_BASE);
if (((versions >> 4) & 0x000f) != UNITTYPE_MAIN_USER) return 0;
- if (!get_fpga_state(0)) + if (!get_fpga_state(0) || (get_hwver() == HWVER_101)) osd_probe(0);
- if (!(latch2 & LATCH2_MC2_PRESENT_N) && !get_fpga_state(1)) + if (get_mc2_present() && + (!get_fpga_state(1) || (get_hwver() == HWVER_101))) osd_probe(1);
return 0; diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index ae209fa..548b7eb 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -136,6 +136,8 @@ #define CONFIG_SYS_LATCH1_RESET 0xffcf #define CONFIG_SYS_LATCH1_BOOT 0xffff
+#define CONFIG_SYS_FPGA_NO_RFL_HI + /* * FLASH organization */ diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 1fccd27..eaf6daa 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -94,13 +94,11 @@ typedef struct ihs_fpga { u16 extended_interrupt; /* 0x001c */ u16 reserved_1[9]; /* 0x001e */ ihs_i2c_t i2c; /* 0x0030 */ - u16 reserved_2[35]; /* 0x0038 */ - u16 reflection_high; /* 0x007e */ - u16 reserved_3[15]; /* 0x0080 */ + u16 reserved_2[51]; /* 0x0038 */ u16 videocontrol; /* 0x009e */ - u16 reserved_4[176]; /* 0x00a0 */ + u16 reserved_3[176]; /* 0x00a0 */ ihs_osd_t osd; /* 0x0200 */ - u16 reserved_5[764]; /* 0x0208 */ + u16 reserved_4[764]; /* 0x0208 */ u16 videomem; /* 0x0800 */ } ihs_fpga_t; #endif
Signed-off-by: Dirk Eibach eibach@gdsys.de --- board/gdsys/common/osd.c | 2 ++ include/gdsys_fpga.h | 7 +++++-- 2 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index 6e4edae..5065f9d 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -376,6 +376,8 @@ int osd_probe(unsigned screen) out_le16(&osd->control, 0x0049);
out_le16(&osd->xy_size, ((32 - 1) << 8) | (16 - 1)); + out_le16(&osd->x_pos, 0x007f); + out_le16(&osd->y_pos, 0x005f);
return 0; } diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index eaf6daa..b02e28c 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -50,6 +50,9 @@ typedef struct ihs_osd { u16 features; u16 control; u16 xy_size; + u16 xy_scale; + u16 x_pos; + u16 y_pos; } ihs_osd_t;
#ifdef CONFIG_IO @@ -79,7 +82,7 @@ typedef struct ihs_fpga { u16 reserved_2[93]; /* 0x0044 */ u16 reflection_high; /* 0x00fe */ ihs_osd_t osd; /* 0x0100 */ - u16 reserved_3[892]; /* 0x0108 */ + u16 reserved_3[88]; /* 0x010e */ u16 videomem; /* 0x0800 */ } ihs_fpga_t; #endif @@ -98,7 +101,7 @@ typedef struct ihs_fpga { u16 videocontrol; /* 0x009e */ u16 reserved_3[176]; /* 0x00a0 */ ihs_osd_t osd; /* 0x0200 */ - u16 reserved_4[764]; /* 0x0208 */ + u16 reserved_4[761]; /* 0x020e */ u16 videomem; /* 0x0800 */ } ihs_fpga_t; #endif
Signed-off-by: Dirk Eibach eibach@gdsys.de --- include/configs/dlvision-10g.h | 1 + include/gdsys_fpga.h | 8 +++++--- 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 548b7eb..368aceb 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -312,6 +312,7 @@ * OSD Setup */ #define CONFIG_SYS_ICS8N3QV01 +#define CONFIG_SYS_MPC92469AC #define CONFIG_SYS_SIL1178 #define CONFIG_SYS_OSD_SCREENS CONFIG_SYS_FPGA_COUNT
diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index b02e28c..c0b1b5c 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -97,11 +97,13 @@ typedef struct ihs_fpga { u16 extended_interrupt; /* 0x001c */ u16 reserved_1[9]; /* 0x001e */ ihs_i2c_t i2c; /* 0x0030 */ - u16 reserved_2[51]; /* 0x0038 */ + u16 reserved_2[16]; /* 0x0038 */ + u16 mpc3w_control; /* 0x0058 */ + u16 reserved_3[34]; /* 0x005a */ u16 videocontrol; /* 0x009e */ - u16 reserved_3[176]; /* 0x00a0 */ + u16 reserved_4[176]; /* 0x00a0 */ ihs_osd_t osd; /* 0x0200 */ - u16 reserved_4[761]; /* 0x020e */ + u16 reserved_5[761]; /* 0x020e */ u16 videomem; /* 0x0800 */ } ihs_fpga_t; #endif
Signed-off-by: Dirk Eibach eibach@gdsys.de --- include/configs/dlvision-10g.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 368aceb..c3f7438 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -113,7 +113,8 @@ #define CONFIG_DTT_LM63 1 /* National LM63 */ #define CONFIG_DTT_SENSORS { 0x4c, 0x4e } /* Sensor addresses */ #define CONFIG_DTT_PWM_LOOKUPTABLE \ - { { 40, 10 }, { 50, 20 }, { 60, 40 } } + { { 40, 10 }, { 43, 13 }, { 46, 16 }, \ + { 50, 20 }, { 53, 27 }, { 56, 34 }, { 60, 40 } } #define CONFIG_DTT_TACH_LIMIT 0xa10
/* EBC peripherals */
Use CONFIG_AUTOBOOT_KEYED on dlvision-10g so that booting can only be stopped with well defined keypresses.
Signed-off-by: Dirk Eibach eibach@gdsys.de --- include/configs/dlvision-10g.h | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index c3f7438..4fc5262 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -42,6 +42,10 @@
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */
+#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ +#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ +#define CONFIG_AUTOBOOT_STOP_STR " " + /* * Configure PLL */
Hi Dirk,
Please split this patch, one patch to extend the lm63 driver and one to add its support to your board config header. This way I can apply the ppc4xx specific patches without the hwmon change.
And while at it, I suggest to remove the hwmon change from this patchset and send it as a separate patch.
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Signed-off-by: Dirk Eibach eibach@gdsys.de --- Changes since v1: - original Subject was "hwmon: Extend lm63.c to support LM64" - separated LM64 implementation from this patch series
include/configs/dlvision-10g.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
Applied whole patch series with the exception of patch 3 "hwmon: Extend lm63.c to support LM64". Here the 2nd ppc4xx specific version has been applied: "ppc4xx: Enable LM64 on DLVision 10G".
Thanks.
Cheers, Stefan
Dirk Eibach
Stefan Roese
