[U-Boot] Allowing rtt_nom to be configurable to all possible values
Currently we have in arch/arm/cpu/armv7/mx6/ddr.c:
/* MMDC Termination: rtt_nom:2 RZQ/2(120ohm), rtt_nom:1 RZQ/4(60ohm) */ val = (sysinfo->rtt_nom == 2) ? 0x00011117 : 0x00022227;
,but the mx6 reference manual states
rtt_nom = 1 ---> 120 ohm rtt_nom = 2 ---> 60 ohm
which is the opposite of what the code and comment do.
Also, it is currently not possible to set rtt_nom to any other values other than 1 and 2.
On mx6sl evk, for example, we need rtt_nom = 0, which is not possible to be achieved currently.
Shouldn't we do like this instead?
--- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -834,11 +834,12 @@ void mx6_ddr3_cfg(const struct mx6_ddr_sysinfo *sysinfo, MMDC1(mprddqby3dl, 0x33333333); }
- /* MMDC Termination: rtt_nom:2 RZQ/2(120ohm), rtt_nom:1 RZQ/4(60ohm) */ - val = (sysinfo->rtt_nom == 2) ? 0x00011117 : 0x00022227; - mmdc0->mpodtctrl = val; + /* MMDC Termination */ + val = sysinfo->rtt_nom; + mmdc0->mpodtctrl = (val << 16) | (val << 12) | (val << 8) | (val << 4) | + 0x7; if (sysinfo->dsize > 1) - MMDC1(mpodtctrl, val); + MMDC1(mpodtctrl, mmdc0->mpodtctrl);
Regards,
Fabio Estevam
Hi Fabio,
Yes.
The only thing I would add here is a set of constants to prevent the need to refer to the manual.
The values differ in the i.MX6SDL to allow different meanings for DDR2, so this should suffice:
#define RTT_NOM_Disabled 0 #define RTT_NOM_120_OHM_75_OHM_DDR2 1 #define RTT_NOM_60_OHM_150_OHM_DDR2 2 #define RTT_NOM_40_OHM_50_OHM_DDR2 3 #define RTT_NOM_30_OHM_37.5_OHM_DDR2 4 #define RTT_NOM_24_OHM_30_OHM_DDR2 5 #define RTT_NOM_20_OHM_25_OHM_DDR2 6 #define RTT_NOM_17_OHM_21_OHM_DDR2 7
(or an enum of the same)...
Regards,
Eric
Hi Eric,
Thanks for your feedback.
Will submit such patch after 2016.01 is out.
Eric Nelson
Fabio Estevam
