[PATCH] ARM: imx: Revert "dh_imx6: Switch to full DM-aware"
This reverts commit 03a673cf49e ("dh_imx6: Switch to full DM-aware"). According to discussion [1], the patch is known to break the dh_imx6 board, however it made it upstream just before 2021.01-rc4, likely by mistake. Revert this patch to put the board back into working order.
Also note that this board has no DM SPL support due to OCRAM size limitations, but that is fine, as SPL DM support is optional.
[1] https://lists.denx.de/pipermail/u-boot/2020-June/417986.html
Signed-off-by: Marek Vasut marex@denx.de Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Ludwig Zenz lzenz@dh-electronics.de Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com --- configs/dh_imx6_defconfig | 3 --- include/configs/dh_imx6.h | 6 ++++++ 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 7bb6ce168ae..0a667fbae97 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -54,14 +54,12 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2" CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y @@ -108,5 +106,4 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 CONFIG_IMX_WATCHDOG=y -# CONFIG_SPL_WDT is not set CONFIG_BZIP2=y diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index fce5b0dd451..6c7c7171a4a 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -52,6 +52,12 @@ /* SATA Configs */ #define CONFIG_LBA48
+/* SPI Flash Configs */ +#if defined(CONFIG_SPL_BUILD) +#undef CONFIG_DM_SPI +#undef CONFIG_DM_SPI_FLASH +#endif + /* UART */ #define CONFIG_MXC_UART_BASE UART1_BASE
Is this hunk needed since there is both CONFIG_SPL_DM_SPI{_FLASH,} and CONFIG_DM_SPI{_FLASH,} ?
Yes, we want to disable this only in SPL, not in U-Boot.
This reverts commit 03a673cf49e ("dh_imx6: Switch to full DM-aware"). According to discussion [1], the patch is known to break the dh_imx6 board, however it made it upstream just before 2021.01-rc4, likely by mistake. Revert this patch to put the board back into working order. Also note that this board has no DM SPL support due to OCRAM size limitations, but that is fine, as SPL DM support is optional. [1] https://lists.denx.de/pipermail/u-boot/2020-June/417986.html Signed-off-by: Marek Vasut marex@denx.de Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Ludwig Zenz lzenz@dh-electronics.de Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com
Best regards, Stefano Babic
sbabic@denx.de
