[PATCH v3 0/8] Add support for the i.MXRT1170
This patchset contains: - i.MXRT1170 clock driver adaption - i.MXRT1170-evk basic support
Jesse Taube (8): imx: imxrt1170-evk: Add support for the NXP i.MXRT1170-EVK ARM: dts: imxrt11170-pinfunc: Add pinctrl binding header dt-bindings: imx: Add clock binding for i.MXRT1170 clk: imx: Add i.MXRT11xx pllv3 variant clk: imx: Add initial support for i.MXRT1170 clock driver RAM: Add changes for i.MXRT11xx series ARM: dts: imx: add i.MXRT1170-EVK support ARM: imxrt1170_defconfig: Add i.MXRT1170 defconfig
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imxrt1170-evk-u-boot.dtsi | 94 + arch/arm/dts/imxrt1170-evk.dts | 250 +++ arch/arm/dts/imxrt1170-pinfunc.h | 1561 +++++++++++++++++ arch/arm/dts/imxrt1170.dtsi | 257 +++ arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/mach-imx/imxrt/Kconfig | 9 + arch/arm/mach-imx/imxrt/soc.c | 2 + board/freescale/imxrt1170-evk/Kconfig | 22 + board/freescale/imxrt1170-evk/MAINTAINERS | 7 + board/freescale/imxrt1170-evk/Makefile | 6 + board/freescale/imxrt1170-evk/imximage.cfg | 31 + board/freescale/imxrt1170-evk/imxrt1170-evk.c | 80 + configs/imxrt1170-evk_defconfig | 70 + drivers/clk/imx/Kconfig | 16 + drivers/clk/imx/Makefile | 1 + drivers/clk/imx/clk-imxrt1170.c | 221 +++ drivers/clk/imx/clk-pllv3.c | 56 +- drivers/clk/imx/clk.h | 1 + drivers/ram/imxrt_sdram.c | 9 + include/configs/imxrt1170-evk.h | 29 + include/dt-bindings/clock/imxrt1170-clock.h | 48 + include/dt-bindings/memory/imxrt-sdram.h | 1 + 23 files changed, 2771 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/imxrt1170-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imxrt1170-evk.dts create mode 100644 arch/arm/dts/imxrt1170-pinfunc.h create mode 100644 arch/arm/dts/imxrt1170.dtsi create mode 100644 board/freescale/imxrt1170-evk/Kconfig create mode 100644 board/freescale/imxrt1170-evk/MAINTAINERS create mode 100644 board/freescale/imxrt1170-evk/Makefile create mode 100644 board/freescale/imxrt1170-evk/imximage.cfg create mode 100644 board/freescale/imxrt1170-evk/imxrt1170-evk.c create mode 100644 configs/imxrt1170-evk_defconfig create mode 100644 drivers/clk/imx/clk-imxrt1170.c create mode 100644 include/configs/imxrt1170-evk.h create mode 100644 include/dt-bindings/clock/imxrt1170-clock.h
This commit adds board support for i.MXRT1170-EVK from NXP. This board is an evaluation kit provided by NXP for i.MXRT117x processor family.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Nothing done V2 -> V3: * Rebase --- arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/mach-imx/imxrt/Kconfig | 9 +++ arch/arm/mach-imx/imxrt/soc.c | 2 + board/freescale/imxrt1170-evk/Kconfig | 22 +++++ board/freescale/imxrt1170-evk/MAINTAINERS | 7 ++ board/freescale/imxrt1170-evk/Makefile | 6 ++ board/freescale/imxrt1170-evk/imximage.cfg | 31 +++++++ board/freescale/imxrt1170-evk/imxrt1170-evk.c | 80 +++++++++++++++++++ 8 files changed, 158 insertions(+) create mode 100644 board/freescale/imxrt1170-evk/Kconfig create mode 100644 board/freescale/imxrt1170-evk/MAINTAINERS create mode 100644 board/freescale/imxrt1170-evk/Makefile create mode 100644 board/freescale/imxrt1170-evk/imximage.cfg create mode 100644 board/freescale/imxrt1170-evk/imxrt1170-evk.c
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 4f63803765..09767be1ca 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -56,6 +56,7 @@
#define MXC_CPU_IMXRT1020 0xB4 /* dummy ID */ #define MXC_CPU_IMXRT1050 0xB6 /* dummy ID */ +#define MXC_CPU_IMXRT1170 0xBA /* dummy ID */
#define MXC_CPU_MX7ULP 0xE1 /* Temporally hard code */ #define MXC_CPU_VF610 0xF6 /* dummy ID */ diff --git a/arch/arm/mach-imx/imxrt/Kconfig b/arch/arm/mach-imx/imxrt/Kconfig index 8c89133965..c1d6b09e77 100644 --- a/arch/arm/mach-imx/imxrt/Kconfig +++ b/arch/arm/mach-imx/imxrt/Kconfig @@ -12,6 +12,10 @@ config IMXRT1050 bool select IMXRT
+config IMXRT1170 + bool + select IMXRT + config SYS_SOC default "imxrt"
@@ -27,9 +31,14 @@ config TARGET_IMXRT1050_EVK bool "Support imxrt1050 EVK board" select IMXRT1050
+config TARGET_IMXRT1170_EVK + bool "Support imxrt1170 EVK board" + select IMXRT1170 + endchoice
source "board/freescale/imxrt1020-evk/Kconfig" source "board/freescale/imxrt1050-evk/Kconfig" +source "board/freescale/imxrt1170-evk/Kconfig"
endif diff --git a/arch/arm/mach-imx/imxrt/soc.c b/arch/arm/mach-imx/imxrt/soc.c index ba015992ee..34162a3976 100644 --- a/arch/arm/mach-imx/imxrt/soc.c +++ b/arch/arm/mach-imx/imxrt/soc.c @@ -43,6 +43,8 @@ u32 get_cpu_rev(void) return MXC_CPU_IMXRT1020 << 12; #elif defined(CONFIG_IMXRT1050) return MXC_CPU_IMXRT1050 << 12; +#elif defined(CONFIG_IMXRT1170) + return MXC_CPU_IMXRT1170 << 12; #else #error This IMXRT SoC is not supported #endif diff --git a/board/freescale/imxrt1170-evk/Kconfig b/board/freescale/imxrt1170-evk/Kconfig new file mode 100644 index 0000000000..c61fc57971 --- /dev/null +++ b/board/freescale/imxrt1170-evk/Kconfig @@ -0,0 +1,22 @@ +if TARGET_IMXRT1170_EVK + +config SYS_BOARD + string + default "imxrt1170-evk" + +config SYS_VENDOR + string + default "freescale" + +config SYS_SOC + string + default "imxrt1170" + +config SYS_CONFIG_NAME + string + default "imxrt1170-evk" + +config IMX_CONFIG + default "board/freescale/imxrt1170-evk/imximage.cfg" + +endif diff --git a/board/freescale/imxrt1170-evk/MAINTAINERS b/board/freescale/imxrt1170-evk/MAINTAINERS new file mode 100644 index 0000000000..1fc3179c00 --- /dev/null +++ b/board/freescale/imxrt1170-evk/MAINTAINERS @@ -0,0 +1,7 @@ +IMXRT1170 EVALUATION KIT +M: Giulio Benetti giulio.benetti@benettiengineering.com +M: Jesse Taube Mr.Bossman075@gmail.com +S: Maintained +F: board/freescale/imxrt1170-evk +F: include/configs/imxrt1170-evk.h +F: configs/imxrt1170-evk_defconfig diff --git a/board/freescale/imxrt1170-evk/Makefile b/board/freescale/imxrt1170-evk/Makefile new file mode 100644 index 0000000000..857a168b09 --- /dev/null +++ b/board/freescale/imxrt1170-evk/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 +# Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + +obj-y := imxrt1170-evk.o diff --git a/board/freescale/imxrt1170-evk/imximage.cfg b/board/freescale/imxrt1170-evk/imximage.cfg new file mode 100644 index 0000000000..57583d04ce --- /dev/null +++ b/board/freescale/imxrt1170-evk/imximage.cfg @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + * Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ diff --git a/board/freescale/imxrt1170-evk/imxrt1170-evk.c b/board/freescale/imxrt1170-evk/imxrt1170-evk.c new file mode 100644 index 0000000000..4b82ee5e9c --- /dev/null +++ b/board/freescale/imxrt1170-evk/imxrt1170-evk.c @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <dm.h> +#include <init.h> +#include <log.h> +#include <ram.h> +#include <spl.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/armv7m.h> +#include <serial.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ +#ifndef CONFIG_SUPPORT_SPL + int rv; + struct udevice *dev; + + rv = uclass_get_device(UCLASS_RAM, 0, &dev); + if (rv) { + debug("DRAM init failed: %d\n", rv); + return rv; + } + +#endif + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_SPL_OS_BOOT +int spl_start_uboot(void) +{ + debug("SPL: booting kernel\n"); + /* break into full u-boot on 'c' */ + return serial_tstc() && serial_getc() == 'c'; +} +#endif + +int spl_dram_init(void) +{ + struct udevice *dev; + int rv; + + rv = uclass_get_device(UCLASS_RAM, 0, &dev); + if (rv) + debug("DRAM init failed: %d\n", rv); + return rv; +} + +void spl_board_init(void) +{ + preloader_console_init(); + spl_dram_init(); + arch_cpu_init(); /* to configure mpu for sdram rw permissions */ +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} +#endif + +int board_init(void) +{ + gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + + return 0; +}
This commit adds board support for i.MXRT1170-EVK from NXP. This board is an evaluation kit provided by NXP for i.MXRT117x processor family. Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
Best regards, Stefano Babic
Add binding header for i.MXRT1170 pinctrl device tree.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Nothing done V2 -> V3: * Nothing done --- arch/arm/dts/imxrt1170-pinfunc.h | 1561 ++++++++++++++++++++++++++++++ 1 file changed, 1561 insertions(+) create mode 100644 arch/arm/dts/imxrt1170-pinfunc.h
diff --git a/arch/arm/dts/imxrt1170-pinfunc.h b/arch/arm/dts/imxrt1170-pinfunc.h new file mode 100644 index 0000000000..fba5483a08 --- /dev/null +++ b/arch/arm/dts/imxrt1170-pinfunc.h @@ -0,0 +1,1561 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2021 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + */ + +#ifndef _DT_BINDINGS_PINCTRL_IMXRT1170_PINFUNC_H +#define _DT_BINDINGS_PINCTRL_IMXRT1170_PINFUNC_H + +#define IMX_PAD_SION 0x40000000 + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ + +#define IOMUXC_GPIO_LPSR_00_FLEXCAN3_TX 0x000 0x040 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_00_MIC_CLK 0x000 0x040 0x0 0x1 0x0 +#define IOMUXC_GPIO_LPSR_00_MQS_RIGHT 0x000 0x040 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_00_ARM_CM4_EVENTO 0x000 0x040 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_00_GPIO_MUX6_IO00 0x000 0x040 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_00_LPUART12_TXD 0x000 0x040 0x0B0 0x6 0x0 +#define IOMUXC_GPIO_LPSR_00_SAI4_MCLK 0x000 0x040 0x0C8 0x7 0x0 +#define IOMUXC_GPIO_LPSR_00_GPIO12_IO00 0x000 0x040 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_01_FLEXCAN3_RX 0x004 0x044 0x080 0x0 0x0 +#define IOMUXC_GPIO_LPSR_01_MIC_BITSTREAM0 0x004 0x044 0x0B4 0x1 0x0 +#define IOMUXC_GPIO_LPSR_01_MQS_LEFT 0x004 0x044 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_01_ARM_CM4_EVENTI 0x004 0x044 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_01_GPIO_MUX6_IO01 0x004 0x044 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_01_LPUART12_RXD 0x004 0x044 0x0AC 0x6 0x0 +#define IOMUXC_GPIO_LPSR_01_GPIO12_IO01 0x004 0x044 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_02_GPIO12_IO02 0x008 0x048 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_02_SRC_BOOT_MODE00 0x008 0x048 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_02_LPSPI5_SCK 0x008 0x048 0x098 0x1 0x0 +#define IOMUXC_GPIO_LPSR_02_SAI4_TX_DATA 0x008 0x048 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_02_MQS_RIGHT 0x008 0x048 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_02_GPIO_MUX6_IO02 0x008 0x048 0x0 0x5 0x0 + +#define IOMUXC_GPIO_LPSR_03_SRC_BOOT_MODE01 0x00C 0x04C 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_03_LPSPI5_PCS0 0x00C 0x04C 0x094 0x1 0x0 +#define IOMUXC_GPIO_LPSR_03_SAI4_TX_SYNC 0x00C 0x04C 0x0DC 0x2 0x0 +#define IOMUXC_GPIO_LPSR_03_MQS_LEFT 0x00C 0x04C 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_03_GPIO_MUX6_IO03 0x00C 0x04C 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_03_GPIO12_IO03 0x00C 0x04C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_04_LPI2C5_SDA 0x010 0x050 0x088 0x0 0x0 +#define IOMUXC_GPIO_LPSR_04_LPSPI5_SOUT 0x010 0x050 0x0A0 0x1 0x0 +#define IOMUXC_GPIO_LPSR_04_SAI4_TX_BCLK 0x010 0x050 0x0D8 0x2 0x0 +#define IOMUXC_GPIO_LPSR_04_LPUART12_RTS_B 0x010 0x050 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_04_GPIO_MUX6_IO04 0x010 0x050 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_04_LPUART11_TXD 0x010 0x050 0x0A8 0x6 0x0 +#define IOMUXC_GPIO_LPSR_04_GPIO12_IO04 0x010 0x050 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_05_GPIO12_IO05 0x014 0x054 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_05_LPI2C5_SCL 0x014 0x054 0x084 0x0 0x0 +#define IOMUXC_GPIO_LPSR_05_LPSPI5_SIN 0x014 0x054 0x09C 0x1 0x0 +#define IOMUXC_GPIO_LPSR_05_SAI4_MCLK 0x014 0x054 0x0C8 0x2 0x1 +#define IOMUXC_GPIO_LPSR_05_LPUART12_CTS_B 0x014 0x054 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_05_GPIO_MUX6_IO05 0x014 0x054 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_05_LPUART11_RXD 0x014 0x054 0x0A4 0x6 0x0 +#define IOMUXC_GPIO_LPSR_05_NMI_GLUE_NMI 0x014 0x054 0x0C4 0x7 0x0 + +#define IOMUXC_GPIO_LPSR_06_LPI2C6_SDA 0x018 0x058 0x090 0x0 0x0 +#define IOMUXC_GPIO_LPSR_06_SAI4_RX_DATA 0x018 0x058 0x0D0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_06_LPUART12_TXD 0x018 0x058 0x0B0 0x3 0x1 +#define IOMUXC_GPIO_LPSR_06_LPSPI6_PCS3 0x018 0x058 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_06_GPIO_MUX6_IO06 0x018 0x058 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_06_FLEXCAN3_TX 0x018 0x058 0x0 0x6 0x0 +#define IOMUXC_GPIO_LPSR_06_PIT2_TRIGGER3 0x018 0x058 0x0 0x7 0x0 +#define IOMUXC_GPIO_LPSR_06_LPSPI5_PCS1 0x018 0x058 0x0 0x8 0x0 +#define IOMUXC_GPIO_LPSR_06_GPIO12_IO06 0x018 0x058 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_07_LPI2C6_SCL 0x01C 0x05C 0x08C 0x0 0x0 +#define IOMUXC_GPIO_LPSR_07_SAI4_RX_BCLK 0x01C 0x05C 0x0CC 0x2 0x0 +#define IOMUXC_GPIO_LPSR_07_LPUART12_RXD 0x01C 0x05C 0x0AC 0x3 0x1 +#define IOMUXC_GPIO_LPSR_07_LPSPI6_PCS2 0x01C 0x05C 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_07_GPIO_MUX6_IO07 0x01C 0x05C 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_07_FLEXCAN3_RX 0x01C 0x05C 0x080 0x6 0x1 +#define IOMUXC_GPIO_LPSR_07_PIT2_TRIGGER2 0x01C 0x05C 0x0 0x7 0x0 +#define IOMUXC_GPIO_LPSR_07_LPSPI5_PCS2 0x01C 0x05C 0x0 0x8 0x0 +#define IOMUXC_GPIO_LPSR_07_GPIO12_IO07 0x01C 0x05C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_08_GPIO12_IO08 0x020 0x060 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_08_LPUART11_TXD 0x020 0x060 0x0A8 0x0 0x1 +#define IOMUXC_GPIO_LPSR_08_FLEXCAN3_TX 0x020 0x060 0x0 0x1 0x0 +#define IOMUXC_GPIO_LPSR_08_SAI4_RX_SYNC 0x020 0x060 0x0D4 0x2 0x0 +#define IOMUXC_GPIO_LPSR_08_MIC_CLK 0x020 0x060 0x0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_08_LPSPI6_PCS1 0x020 0x060 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_08_GPIO_MUX6_IO08 0x020 0x060 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_08_LPI2C5_SDA 0x020 0x060 0x088 0x6 0x1 +#define IOMUXC_GPIO_LPSR_08_PIT2_TRIGGER1 0x020 0x060 0x0 0x7 0x0 +#define IOMUXC_GPIO_LPSR_08_LPSPI5_PCS3 0x020 0x060 0x0 0x8 0x0 + +#define IOMUXC_GPIO_LPSR_09_GPIO12_IO09 0x024 0x064 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_09_LPUART11_RXD 0x024 0x064 0x0A4 0x0 0x1 +#define IOMUXC_GPIO_LPSR_09_FLEXCAN3_RX 0x024 0x064 0x080 0x1 0x2 +#define IOMUXC_GPIO_LPSR_09_PIT2_TRIGGER0 0x024 0x064 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_09_MIC_BITSTREAM0 0x024 0x064 0x0B4 0x3 0x1 +#define IOMUXC_GPIO_LPSR_09_LPSPI6_PCS0 0x024 0x064 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_09_GPIO_MUX6_IO09 0x024 0x064 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_09_LPI2C5_SCL 0x024 0x064 0x084 0x6 0x1 +#define IOMUXC_GPIO_LPSR_09_SAI4_TX_DATA 0x024 0x064 0x0 0x7 0x0 + +#define IOMUXC_GPIO_LPSR_10_GPIO12_IO10 0x028 0x068 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_10_JTAG_MUX_TRSTB 0x028 0x068 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_10_LPUART11_CTS_B 0x028 0x068 0x0 0x1 0x0 +#define IOMUXC_GPIO_LPSR_10_LPI2C6_SDA 0x028 0x068 0x090 0x2 0x1 +#define IOMUXC_GPIO_LPSR_10_MIC_BITSTREAM1 0x028 0x068 0x0B8 0x3 0x0 +#define IOMUXC_GPIO_LPSR_10_LPSPI6_SCK 0x028 0x068 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_10_GPIO_MUX6_IO10 0x028 0x068 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_10_LPI2C5_SCLS 0x028 0x068 0x0 0x6 0x0 +#define IOMUXC_GPIO_LPSR_10_SAI4_TX_SYNC 0x028 0x068 0x0DC 0x7 0x1 +#define IOMUXC_GPIO_LPSR_10_LPUART12_TXD 0x028 0x068 0x0B0 0x8 0x2 + +#define IOMUXC_GPIO_LPSR_11_JTAG_MUX_TDO 0x02C 0x06C 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_11_LPUART11_RTS_B 0x02C 0x06C 0x0 0x1 0x0 +#define IOMUXC_GPIO_LPSR_11_LPI2C6_SCL 0x02C 0x06C 0x08C 0x2 0x1 +#define IOMUXC_GPIO_LPSR_11_MIC_BITSTREAM2 0x02C 0x06C 0x0BC 0x3 0x0 +#define IOMUXC_GPIO_LPSR_11_LPSPI6_SOUT 0x02C 0x06C 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_11_GPIO_MUX6_IO11 0x02C 0x06C 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_11_LPI2C5_SDAS 0x02C 0x06C 0x0 0x6 0x0 +#define IOMUXC_GPIO_LPSR_11_ARM_TRACE_SWO 0x02C 0x06C 0x0 0x7 0x0 +#define IOMUXC_GPIO_LPSR_11_LPUART12_RXD 0x02C 0x06C 0x0AC 0x8 0x2 +#define IOMUXC_GPIO_LPSR_11_GPIO12_IO11 0x02C 0x06C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_12_GPIO12_IO12 0x030 0x070 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_12_JTAG_MUX_TDI 0x030 0x070 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_12_PIT2_TRIGGER0 0x030 0x070 0x0 0x1 0x0 +#define IOMUXC_GPIO_LPSR_12_MIC_BITSTREAM3 0x030 0x070 0x0C0 0x3 0x0 +#define IOMUXC_GPIO_LPSR_12_LPSPI6_SIN 0x030 0x070 0x0 0x4 0x0 +#define IOMUXC_GPIO_LPSR_12_GPIO_MUX6_IO12 0x030 0x070 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_12_LPI2C5_HREQ 0x030 0x070 0x0 0x6 0x0 +#define IOMUXC_GPIO_LPSR_12_SAI4_TX_BCLK 0x030 0x070 0x0D8 0x7 0x1 +#define IOMUXC_GPIO_LPSR_12_LPSPI5_SCK 0x030 0x070 0x098 0x8 0x1 + +#define IOMUXC_GPIO_LPSR_13_GPIO12_IO13 0x034 0x074 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_13_JTAG_MUX_MOD 0x034 0x074 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_13_MIC_BITSTREAM1 0x034 0x074 0x0B8 0x1 0x1 +#define IOMUXC_GPIO_LPSR_13_PIT2_TRIGGER1 0x034 0x074 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_13_GPIO_MUX6_IO13 0x034 0x074 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_13_SAI4_RX_DATA 0x034 0x074 0x0D0 0x7 0x1 +#define IOMUXC_GPIO_LPSR_13_LPSPI5_PCS0 0x034 0x074 0x094 0x8 0x1 + +#define IOMUXC_GPIO_LPSR_14_JTAG_MUX_TCK 0x038 0x078 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_14_MIC_BITSTREAM2 0x038 0x078 0x0BC 0x1 0x1 +#define IOMUXC_GPIO_LPSR_14_PIT2_TRIGGER2 0x038 0x078 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_14_GPIO_MUX6_IO14 0x038 0x078 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_14_SAI4_RX_BCLK 0x038 0x078 0x0CC 0x7 0x1 +#define IOMUXC_GPIO_LPSR_14_LPSPI5_SOUT 0x038 0x078 0x0A0 0x8 0x1 +#define IOMUXC_GPIO_LPSR_14_GPIO12_IO14 0x038 0x078 0x0 0xA 0x0 + +#define IOMUXC_GPIO_LPSR_15_GPIO12_IO15 0x03C 0x07C 0x0 0xA 0x0 +#define IOMUXC_GPIO_LPSR_15_JTAG_MUX_TMS 0x03C 0x07C 0x0 0x0 0x0 +#define IOMUXC_GPIO_LPSR_15_MIC_BITSTREAM3 0x03C 0x07C 0x0C0 0x1 0x1 +#define IOMUXC_GPIO_LPSR_15_PIT2_TRIGGER3 0x03C 0x07C 0x0 0x2 0x0 +#define IOMUXC_GPIO_LPSR_15_GPIO_MUX6_IO15 0x03C 0x07C 0x0 0x5 0x0 +#define IOMUXC_GPIO_LPSR_15_SAI4_RX_SYNC 0x03C 0x07C 0x0D4 0x7 0x1 +#define IOMUXC_GPIO_LPSR_15_LPSPI5_SIN 0x03C 0x07C 0x09C 0x8 0x1 + +#define IOMUXC_WAKEUP_DIG_GPIO13_IO00 0x40C94000 0x40C94040 0x0 0x5 0x0 +#define IOMUXC_WAKEUP_DIG_NMI_GLUE_NMI 0x40C94000 0x40C94040 0x0C4 0x7 0x1 + +#define IOMUXC_PMIC_ON_REQ_DIG_SNVS_LP_PMIC_ON_REQ 0x40C94004 0x40C94044 0x0 0x0 0x0 +#define IOMUXC_PMIC_ON_REQ_DIG_GPIO13_IO01 0x40C94004 0x40C94044 0x0 0x5 0x0 + +#define IOMUXC_PMIC_STBY_REQ_DIG_CCM_PMIC_VSTBY_REQ 0x40C94008 0x40C94048 0x0 0x0 0x0 +#define IOMUXC_PMIC_STBY_REQ_DIG_GPIO13_IO02 0x40C94008 0x40C94048 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_00_DIG_SNVS_TAMPER0 0x40C9400C 0x40C9404C 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_00_DIG_GPIO13_IO03 0x40C9400C 0x40C9404C 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_01_DIG_SNVS_TAMPER1 0x40C94010 0x40C94050 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_01_DIG_GPIO13_IO04 0x40C94010 0x40C94050 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_02_DIG_SNVS_TAMPER2 0x40C94014 0x40C94054 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_02_DIG_GPIO13_IO05 0x40C94014 0x40C94054 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_03_DIG_SNVS_TAMPER3 0x40C94018 0x40C94058 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_03_DIG_GPIO13_IO06 0x40C94018 0x40C94058 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_04_DIG_SNVS_TAMPER4 0x40C9401C 0x40C9405C 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_04_DIG_GPIO13_IO07 0x40C9401C 0x40C9405C 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_05_DIG_SNVS_TAMPER5 0x40C94020 0x40C94060 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_05_DIG_GPIO13_IO08 0x40C94020 0x40C94060 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_06_DIG_SNVS_TAMPER6 0x40C94024 0x40C94064 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_06_DIG_GPIO13_IO09 0x40C94024 0x40C94064 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_07_DIG_SNVS_TAMPER7 0x40C94028 0x40C94068 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_07_DIG_GPIO13_IO10 0x40C94028 0x40C94068 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_08_DIG_SNVS_TAMPER8 0x40C9402C 0x40C9406C 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_08_DIG_GPIO13_IO11 0x40C9402C 0x40C9406C 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SNVS_09_DIG_SNVS_TAMPER9 0x40C94030 0x40C94070 0x0 0x0 0x0 +#define IOMUXC_GPIO_SNVS_09_DIG_GPIO13_IO12 0x40C94030 0x40C94070 0x0 0x5 0x0 + +#define IOMUXC_TEST_MODE_DIG 0x0 0x40C94034 0x0 0x0 0x0 + +#define IOMUXC_POR_B_DIG 0x0 0x40C94038 0x0 0x0 0x0 + +#define IOMUXC_ONOFF_DIG 0x0 0x40C9403C 0x0 0x0 0x0 + +#define IOMUXC_GPIO_EMC_B1_00_SEMC_DATA00 0x010 0x254 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_00_FLEXPWM4_PWM0_A 0x010 0x254 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_00_GPIO_MUX1_IO00 0x010 0x254 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_00_FLEXIO1_D00 0x010 0x254 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_00_GPIO7_IO00 0x010 0x254 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_01_GPIO7_IO01 0x014 0x258 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_01_SEMC_DATA01 0x014 0x258 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_01_FLEXPWM4_PWM0_B 0x014 0x258 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_01_GPIO_MUX1_IO01 0x014 0x258 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_01_FLEXIO1_D01 0x014 0x258 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_02_SEMC_DATA02 0x018 0x25C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_02_FLEXPWM4_PWM1_A 0x018 0x25C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_02_GPIO_MUX1_IO02 0x018 0x25C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_02_FLEXIO1_D02 0x018 0x25C 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_02_GPIO7_IO02 0x018 0x25C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_03_SEMC_DATA03 0x01C 0x260 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_03_FLEXPWM4_PWM1_B 0x01C 0x260 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_03_GPIO_MUX1_IO03 0x01C 0x260 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_03_FLEXIO1_D03 0x01C 0x260 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_03_GPIO7_IO03 0x01C 0x260 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_04_GPIO7_IO04 0x020 0x264 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_04_SEMC_DATA04 0x020 0x264 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_04_FLEXPWM4_PWM2_A 0x020 0x264 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_04_GPIO_MUX1_IO04 0x020 0x264 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_04_FLEXIO1_D04 0x020 0x264 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_05_SEMC_DATA05 0x024 0x268 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_05_FLEXPWM4_PWM2_B 0x024 0x268 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_05_GPIO_MUX1_IO05 0x024 0x268 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_05_FLEXIO1_D05 0x024 0x268 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_05_GPIO7_IO05 0x024 0x268 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_06_SEMC_DATA06 0x028 0x26C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_06_FLEXPWM2_PWM0_A 0x028 0x26C 0x518 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_06_GPIO_MUX1_IO06 0x028 0x26C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_06_FLEXIO1_D06 0x028 0x26C 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_06_GPIO7_IO06 0x028 0x26C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_07_GPIO7_IO07 0x02C 0x270 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_07_SEMC_DATA07 0x02C 0x270 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_07_FLEXPWM2_PWM0_B 0x02C 0x270 0x524 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_07_GPIO_MUX1_IO07 0x02C 0x270 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_07_FLEXIO1_D07 0x02C 0x270 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_08_SEMC_DM00 0x030 0x274 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_08_FLEXPWM2_PWM1_A 0x030 0x274 0x51C 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_08_GPIO_MUX1_IO08 0x030 0x274 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_08_FLEXIO1_D08 0x030 0x274 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_08_GPIO7_IO08 0x030 0x274 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_09_SEMC_ADDR00 0x034 0x278 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_09_FLEXPWM2_PWM1_B 0x034 0x278 0x528 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_09_GPT5_CAPTURE1 0x034 0x278 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_09_GPIO_MUX1_IO09 0x034 0x278 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_09_FLEXIO1_D09 0x034 0x278 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_09_GPIO7_IO09 0x034 0x278 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_10_SEMC_ADDR01 0x038 0x27C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_10_FLEXPWM2_PWM2_A 0x038 0x27C 0x520 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_10_GPT5_CAPTURE2 0x038 0x27C 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_10_GPIO_MUX1_IO10 0x038 0x27C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_10_FLEXIO1_D10 0x038 0x27C 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_10_GPIO7_IO10 0x038 0x27C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_11_GPIO7_IO11 0x03C 0x280 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_11_SEMC_ADDR02 0x03C 0x280 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_11_FLEXPWM2_PWM2_B 0x03C 0x280 0x52C 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_11_GPT5_COMPARE1 0x03C 0x280 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_11_GPIO_MUX1_IO11 0x03C 0x280 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_11_FLEXIO1_D11 0x03C 0x280 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_12_SEMC_ADDR03 0x040 0x284 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_12_XBAR1_INOUT04 0x040 0x284 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_12_GPT5_COMPARE2 0x040 0x284 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_12_GPIO_MUX1_IO12 0x040 0x284 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_12_FLEXIO1_D12 0x040 0x284 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_12_GPIO7_IO12 0x040 0x284 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_13_SEMC_ADDR04 0x044 0x288 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_13_XBAR1_INOUT05 0x044 0x288 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_13_GPT5_COMPARE3 0x044 0x288 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_13_GPIO_MUX1_IO13 0x044 0x288 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_13_FLEXIO1_D13 0x044 0x288 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_13_GPIO7_IO13 0x044 0x288 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_14_GPIO7_IO14 0x048 0x28C 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_14_SEMC_ADDR05 0x048 0x28C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_14_XBAR1_INOUT06 0x048 0x28C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_14_GPT5_CLK 0x048 0x28C 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_14_GPIO_MUX1_IO14 0x048 0x28C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_14_FLEXIO1_D14 0x048 0x28C 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_15_SEMC_ADDR06 0x04C 0x290 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_15_XBAR1_INOUT07 0x04C 0x290 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_15_GPIO_MUX1_IO15 0x04C 0x290 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_15_FLEXIO1_D15 0x04C 0x290 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_15_GPIO7_IO15 0x04C 0x290 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_16_SEMC_ADDR07 0x050 0x294 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_16_XBAR1_INOUT08 0x050 0x294 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_16_GPIO_MUX1_IO16 0x050 0x294 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_16_FLEXIO1_D16 0x050 0x294 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_16_GPIO7_IO16 0x050 0x294 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_17_GPIO7_IO17 0x054 0x298 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_17_SEMC_ADDR08 0x054 0x298 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_17_FLEXPWM4_PWM3_A 0x054 0x298 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_17_TMR1_TIMER0 0x054 0x298 0x63C 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_17_GPIO_MUX1_IO17 0x054 0x298 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_17_FLEXIO1_D17 0x054 0x298 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_18_SEMC_ADDR09 0x058 0x29C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_18_FLEXPWM4_PWM3_B 0x058 0x29C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_18_TMR2_TIMER0 0x058 0x29C 0x648 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_18_GPIO_MUX1_IO18 0x058 0x29C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_18_FLEXIO1_D18 0x058 0x29C 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_18_GPIO7_IO18 0x058 0x29C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_19_SEMC_ADDR11 0x05C 0x2A0 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_19_FLEXPWM2_PWM3_A 0x05C 0x2A0 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_19_TMR3_TIMER0 0x05C 0x2A0 0x654 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_19_GPIO_MUX1_IO19 0x05C 0x2A0 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_19_FLEXIO1_D19 0x05C 0x2A0 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_19_GPIO7_IO19 0x05C 0x2A0 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_20_SEMC_ADDR12 0x060 0x2A4 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_20_FLEXPWM2_PWM3_B 0x060 0x2A4 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_20_TMR4_TIMER0 0x060 0x2A4 0x660 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_20_GPIO_MUX1_IO20 0x060 0x2A4 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_20_FLEXIO1_D20 0x060 0x2A4 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_20_GPIO7_IO20 0x060 0x2A4 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_21_GPIO7_IO21 0x064 0x2A8 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_21_SEMC_BA0 0x064 0x2A8 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_21_FLEXPWM3_PWM3_A 0x064 0x2A8 0x53C 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_21_GPIO_MUX1_IO21 0x064 0x2A8 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_21_FLEXIO1_D21 0x064 0x2A8 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_22_GPIO7_IO22 0x068 0x2AC 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_22_SEMC_BA1 0x068 0x2AC 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_22_FLEXPWM3_PWM3_B 0x068 0x2AC 0x54C 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_22_GPIO_MUX1_IO22 0x068 0x2AC 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_22_FLEXIO1_D22 0x068 0x2AC 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_23_SEMC_ADDR10 0x06C 0x2B0 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_23_FLEXPWM1_PWM0_A 0x06C 0x2B0 0x500 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_23_GPIO_MUX1_IO23 0x06C 0x2B0 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_23_FLEXIO1_D23 0x06C 0x2B0 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_23_GPIO7_IO23 0x06C 0x2B0 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_24_GPIO7_IO24 0x070 0x2B4 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_24_SEMC_CAS 0x070 0x2B4 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_24_FLEXPWM1_PWM0_B 0x070 0x2B4 0x50C 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_24_GPIO_MUX1_IO24 0x070 0x2B4 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_24_FLEXIO1_D24 0x070 0x2B4 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_25_GPIO7_IO25 0x074 0x2B8 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_25_SEMC_RAS 0x074 0x2B8 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_25_FLEXPWM1_PWM1_A 0x074 0x2B8 0x504 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_25_GPIO_MUX1_IO25 0x074 0x2B8 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_25_FLEXIO1_D25 0x074 0x2B8 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_26_SEMC_CLK 0x078 0x2BC 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_26_FLEXPWM1_PWM1_B 0x078 0x2BC 0x510 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_26_GPIO_MUX1_IO26 0x078 0x2BC 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_26_FLEXIO1_D26 0x078 0x2BC 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_26_GPIO7_IO26 0x078 0x2BC 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_27_GPIO7_IO27 0x07C 0x2C0 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_27_SEMC_CKE 0x07C 0x2C0 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_27_FLEXPWM1_PWM2_A 0x07C 0x2C0 0x508 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_27_GPIO_MUX1_IO27 0x07C 0x2C0 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_27_FLEXIO1_D27 0x07C 0x2C0 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_28_GPIO7_IO28 0x080 0x2C4 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_28_SEMC_WE 0x080 0x2C4 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_28_FLEXPWM1_PWM2_B 0x080 0x2C4 0x514 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_28_GPIO_MUX1_IO28 0x080 0x2C4 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_28_FLEXIO1_D28 0x080 0x2C4 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_29_SEMC_CS0 0x084 0x2C8 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_29_FLEXPWM3_PWM0_A 0x084 0x2C8 0x530 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_29_GPIO_MUX1_IO29 0x084 0x2C8 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_29_FLEXIO1_D29 0x084 0x2C8 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_29_GPIO7_IO29 0x084 0x2C8 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_30_SEMC_DATA08 0x088 0x2CC 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_30_FLEXPWM3_PWM0_B 0x088 0x2CC 0x540 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_30_GPIO_MUX1_IO30 0x088 0x2CC 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_30_FLEXIO1_D30 0x088 0x2CC 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B1_30_GPIO7_IO30 0x088 0x2CC 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_31_GPIO7_IO31 0x08C 0x2D0 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_31_SEMC_DATA09 0x08C 0x2D0 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_31_FLEXPWM3_PWM1_A 0x08C 0x2D0 0x534 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_31_GPIO_MUX1_IO31 0x08C 0x2D0 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_31_FLEXIO1_D31 0x08C 0x2D0 0x0 0x8 0x0 + +#define IOMUXC_GPIO_EMC_B1_32_GPIO8_IO00 0x090 0x2D4 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_32_SEMC_DATA10 0x090 0x2D4 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_32_FLEXPWM3_PWM1_B 0x090 0x2D4 0x544 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_32_GPIO_MUX2_IO00 0x090 0x2D4 0x0 0x5 0x0 + +#define IOMUXC_GPIO_EMC_B1_33_SEMC_DATA11 0x094 0x2D8 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_33_FLEXPWM3_PWM2_A 0x094 0x2D8 0x538 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_33_GPIO_MUX2_IO01 0x094 0x2D8 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_33_GPIO8_IO01 0x094 0x2D8 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_34_GPIO8_IO02 0x098 0x2DC 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_34_SEMC_DATA12 0x098 0x2DC 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_34_FLEXPWM3_PWM2_B 0x098 0x2DC 0x548 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_34_GPIO_MUX2_IO02 0x098 0x2DC 0x0 0x5 0x0 + +#define IOMUXC_GPIO_EMC_B1_35_GPIO8_IO03 0x09C 0x2E0 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_35_SEMC_DATA13 0x09C 0x2E0 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_35_XBAR1_INOUT09 0x09C 0x2E0 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_35_GPIO_MUX2_IO03 0x09C 0x2E0 0x0 0x5 0x0 + +#define IOMUXC_GPIO_EMC_B1_36_SEMC_DATA14 0x0A0 0x2E4 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_36_XBAR1_INOUT10 0x0A0 0x2E4 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_36_GPIO_MUX2_IO04 0x0A0 0x2E4 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_36_GPIO8_IO04 0x0A0 0x2E4 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_37_GPIO8_IO05 0x0A4 0x2E8 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_37_SEMC_DATA15 0x0A4 0x2E8 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_37_XBAR1_INOUT11 0x0A4 0x2E8 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_37_GPIO_MUX2_IO05 0x0A4 0x2E8 0x0 0x5 0x0 + +#define IOMUXC_GPIO_EMC_B1_38_GPIO8_IO06 0x0A8 0x2EC 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_38_SEMC_DM01 0x0A8 0x2EC 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_38_FLEXPWM1_PWM3_A 0x0A8 0x2EC 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_38_TMR1_TIMER1 0x0A8 0x2EC 0x640 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_38_GPIO_MUX2_IO06 0x0A8 0x2EC 0x0 0x5 0x0 + +#define IOMUXC_GPIO_EMC_B1_39_SEMC_DQS 0x0AC 0x2F0 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_39_FLEXPWM1_PWM3_B 0x0AC 0x2F0 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_39_TMR2_TIMER1 0x0AC 0x2F0 0x64C 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_39_GPIO_MUX2_IO07 0x0AC 0x2F0 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_39_GPIO8_IO07 0x0AC 0x2F0 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_40_SEMC_RDY 0x0B0 0x2F4 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_40_XBAR1_INOUT12 0x0B0 0x2F4 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_40_MQS_RIGHT 0x0B0 0x2F4 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_40_LPUART6_TXD 0x0B0 0x2F4 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B1_40_GPIO_MUX2_IO08 0x0B0 0x2F4 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_40_ENET_1G_MDC 0x0B0 0x2F4 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B1_40_CCM_CLKO1 0x0B0 0x2F4 0x0 0x9 0x0 +#define IOMUXC_GPIO_EMC_B1_40_GPIO8_IO08 0x0B0 0x2F4 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B1_41_GPIO8_IO09 0x0B4 0x2F8 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B1_41_SEMC_CSX00 0x0B4 0x2F8 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B1_41_XBAR1_INOUT13 0x0B4 0x2F8 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B1_41_MQS_LEFT 0x0B4 0x2F8 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B1_41_LPUART6_RXD 0x0B4 0x2F8 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B1_41_FLEXSPI2_B_DATA07 0x0B4 0x2F8 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B1_41_GPIO_MUX2_IO09 0x0B4 0x2F8 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B1_41_ENET_1G_MDIO 0x0B4 0x2F8 0x4C8 0x7 0x0 +#define IOMUXC_GPIO_EMC_B1_41_CCM_CLKO2 0x0B4 0x2F8 0x0 0x9 0x0 + +#define IOMUXC_GPIO_EMC_B2_00_SEMC_DATA16 0x0B8 0x2FC 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_00_CCM_ENET_REF_CLK_25M 0x0B8 0x2FC 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_00_TMR3_TIMER1 0x0B8 0x2FC 0x658 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_00_LPUART6_CTS_B 0x0B8 0x2FC 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_00_FLEXSPI2_B_DATA06 0x0B8 0x2FC 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_00_GPIO_MUX2_IO10 0x0B8 0x2FC 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_00_XBAR1_INOUT20 0x0B8 0x2FC 0x6D8 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_00_ENET_QOS_1588_EVENT1_OUT 0x0B8 0x2FC 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_00_LPSPI1_SCK 0x0B8 0x2FC 0x5D0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_00_LPI2C2_SCL 0x0B8 0x2FC 0x5B4 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_00_GPIO8_IO10 0x0B8 0x2FC 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_00_FLEXPWM3_PWM0_A 0x0B8 0x2FC 0x530 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_01_SEMC_DATA17 0x0BC 0x300 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_01_USDHC2_CD_B 0x0BC 0x300 0x6D0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_01_TMR4_TIMER1 0x0BC 0x300 0x664 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_01_LPUART6_RTS_B 0x0BC 0x300 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_01_FLEXSPI2_B_DATA05 0x0BC 0x300 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_01_GPIO_MUX2_IO11 0x0BC 0x300 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_01_XBAR1_INOUT21 0x0BC 0x300 0x6DC 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_01_ENET_QOS_1588_EVENT1_IN 0x0BC 0x300 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_01_LPSPI1_PCS0 0x0BC 0x300 0x5CC 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_01_LPI2C2_SDA 0x0BC 0x300 0x5B8 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_01_GPIO8_IO11 0x0BC 0x300 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_01_FLEXPWM3_PWM0_B 0x0BC 0x300 0x540 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_02_SEMC_DATA18 0x0C0 0x304 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_02_USDHC2_WP 0x0C0 0x304 0x6D4 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_02_VIDEO_MUX_CSI_DATA23 0x0C0 0x304 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_02_FLEXSPI2_B_DATA04 0x0C0 0x304 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_02_GPIO_MUX2_IO12 0x0C0 0x304 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_02_XBAR1_INOUT22 0x0C0 0x304 0x6E0 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_02_ENET_QOS_1588_EVENT1_AUX_IN 0x0C0 0x304 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_02_LPSPI1_SOUT 0x0C0 0x304 0x5D8 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_02_GPIO8_IO12 0x0C0 0x304 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_02_FLEXPWM3_PWM1_A 0x0C0 0x304 0x534 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_03_SEMC_DATA19 0x0C4 0x308 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_03_USDHC2_VSELECT 0x0C4 0x308 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_03_VIDEO_MUX_CSI_DATA22 0x0C4 0x308 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_03_FLEXSPI2_B_DATA03 0x0C4 0x308 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_03_GPIO_MUX2_IO13 0x0C4 0x308 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_03_XBAR1_INOUT23 0x0C4 0x308 0x6E4 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_03_ENET_1G_TX_DATA03 0x0C4 0x308 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_03_LPSPI1_SIN 0x0C4 0x308 0x5D4 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_03_GPIO8_IO13 0x0C4 0x308 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_03_FLEXPWM3_PWM1_B 0x0C4 0x308 0x544 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_04_SEMC_DATA20 0x0C8 0x30C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_04_USDHC2_RESET_B 0x0C8 0x30C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_04_SAI2_MCLK 0x0C8 0x30C 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_04_VIDEO_MUX_CSI_DATA21 0x0C8 0x30C 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_04_FLEXSPI2_B_DATA02 0x0C8 0x30C 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_04_GPIO_MUX2_IO14 0x0C8 0x30C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_04_XBAR1_INOUT24 0x0C8 0x30C 0x6E8 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_04_ENET_1G_TX_DATA02 0x0C8 0x30C 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_04_LPSPI3_SCK 0x0C8 0x30C 0x600 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_04_GPIO8_IO14 0x0C8 0x30C 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_04_FLEXPWM3_PWM2_A 0x0C8 0x30C 0x538 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_05_SEMC_DATA21 0x0CC 0x310 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_05_GPT3_CLK 0x0CC 0x310 0x598 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_05_SAI2_RX_SYNC 0x0CC 0x310 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_05_VIDEO_MUX_CSI_DATA20 0x0CC 0x310 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_05_FLEXSPI2_B_DATA01 0x0CC 0x310 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_05_GPIO_MUX2_IO15 0x0CC 0x310 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_05_XBAR1_INOUT25 0x0CC 0x310 0x6EC 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_05_ENET_1G_RX_CLK 0x0CC 0x310 0x4CC 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_05_LPSPI3_PCS0 0x0CC 0x310 0x5F0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_05_PIT1_TRIGGER0 0x0CC 0x310 0x0 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_05_GPIO8_IO15 0x0CC 0x310 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_05_FLEXPWM3_PWM2_B 0x0CC 0x310 0x548 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_06_SEMC_DATA22 0x0D0 0x314 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_06_GPT3_CAPTURE1 0x0D0 0x314 0x590 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_06_GPIO8_IO16 0x0D0 0x314 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_06_SAI2_RX_BCLK 0x0D0 0x314 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_06_FLEXPWM3_PWM3_A 0x0D0 0x314 0x53C 0xB 0x1 +#define IOMUXC_GPIO_EMC_B2_06_VIDEO_MUX_CSI_DATA19 0x0D0 0x314 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_06_FLEXSPI2_B_DATA00 0x0D0 0x314 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_06_GPIO_MUX2_IO16 0x0D0 0x314 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_06_XBAR1_INOUT26 0x0D0 0x314 0x6F0 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_06_ENET_1G_TX_ER 0x0D0 0x314 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_06_LPSPI3_SOUT 0x0D0 0x314 0x608 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_06_PIT1_TRIGGER1 0x0D0 0x314 0x0 0x9 0x0 + +#define IOMUXC_GPIO_EMC_B2_07_SEMC_DATA23 0x0D4 0x318 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_07_GPT3_CAPTURE2 0x0D4 0x318 0x594 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_07_SAI2_RX_DATA 0x0D4 0x318 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_07_VIDEO_MUX_CSI_DATA18 0x0D4 0x318 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_07_FLEXSPI2_B_DQS 0x0D4 0x318 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_07_GPIO_MUX2_IO17 0x0D4 0x318 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_07_XBAR1_INOUT27 0x0D4 0x318 0x6F4 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_07_ENET_1G_RX_DATA03 0x0D4 0x318 0x4DC 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_07_LPSPI3_SIN 0x0D4 0x318 0x604 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_07_PIT1_TRIGGER2 0x0D4 0x318 0x0 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_07_GPIO8_IO17 0x0D4 0x318 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_07_FLEXPWM3_PWM3_B 0x0D4 0x318 0x54C 0xB 0x1 + +#define IOMUXC_GPIO_EMC_B2_08_SEMC_DM02 0x0D8 0x31C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_08_GPT3_COMPARE1 0x0D8 0x31C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_08_SAI2_TX_DATA 0x0D8 0x31C 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_08_VIDEO_MUX_CSI_DATA17 0x0D8 0x31C 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_08_FLEXSPI2_B_SS0_B 0x0D8 0x31C 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_08_GPIO_MUX2_IO18 0x0D8 0x31C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_08_XBAR1_INOUT28 0x0D8 0x31C 0x6F8 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_08_ENET_1G_RX_DATA02 0x0D8 0x31C 0x4D8 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_08_LPSPI3_PCS1 0x0D8 0x31C 0x5F4 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_08_PIT1_TRIGGER3 0x0D8 0x31C 0x0 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_08_GPIO8_IO18 0x0D8 0x31C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_09_GPIO8_IO19 0x0DC 0x320 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_09_SEMC_DATA24 0x0DC 0x320 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_09_GPT3_COMPARE2 0x0DC 0x320 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_09_SAI2_TX_BCLK 0x0DC 0x320 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_09_VIDEO_MUX_CSI_DATA16 0x0DC 0x320 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_09_FLEXSPI2_B_SCLK 0x0DC 0x320 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_09_GPIO_MUX2_IO19 0x0DC 0x320 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_09_XBAR1_INOUT29 0x0DC 0x320 0x6FC 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_09_ENET_1G_CRS 0x0DC 0x320 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_09_LPSPI3_PCS2 0x0DC 0x320 0x5F8 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_09_TMR1_TIMER0 0x0DC 0x320 0x63C 0x9 0x1 + +#define IOMUXC_GPIO_EMC_B2_10_GPIO8_IO20 0x0E0 0x324 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_10_SEMC_DATA25 0x0E0 0x324 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_10_GPT3_COMPARE3 0x0E0 0x324 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_10_SAI2_TX_SYNC 0x0E0 0x324 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_10_VIDEO_MUX_CSI_FIELD 0x0E0 0x324 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_10_FLEXSPI2_A_SCLK 0x0E0 0x324 0x58C 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_10_GPIO_MUX2_IO20 0x0E0 0x324 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_10_XBAR1_INOUT30 0x0E0 0x324 0x700 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_10_ENET_1G_COL 0x0E0 0x324 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_10_LPSPI3_PCS3 0x0E0 0x324 0x5FC 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_10_TMR1_TIMER1 0x0E0 0x324 0x640 0x9 0x1 + +#define IOMUXC_GPIO_EMC_B2_11_SEMC_DATA26 0x0E4 0x328 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_11_SPDIF_IN 0x0E4 0x328 0x6B4 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_11_ENET_1G_TX_DATA00 0x0E4 0x328 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_11_SAI3_RX_SYNC 0x0E4 0x328 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_11_FLEXSPI2_A_SS0_B 0x0E4 0x328 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_11_GPIO_MUX2_IO21 0x0E4 0x328 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_11_XBAR1_INOUT31 0x0E4 0x328 0x704 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_11_EMVSIM1_IO 0x0E4 0x328 0x69C 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_11_TMR1_TIMER2 0x0E4 0x328 0x644 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_11_GPIO8_IO21 0x0E4 0x328 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_12_SEMC_DATA27 0x0E8 0x32C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_12_SPDIF_OUT 0x0E8 0x32C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_12_ENET_1G_TX_DATA01 0x0E8 0x32C 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_12_SAI3_RX_BCLK 0x0E8 0x32C 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_12_FLEXSPI2_A_DQS 0x0E8 0x32C 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_12_GPIO_MUX2_IO22 0x0E8 0x32C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_12_XBAR1_INOUT32 0x0E8 0x32C 0x708 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_12_EMVSIM1_CLK 0x0E8 0x32C 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_12_TMR1_TIMER3 0x0E8 0x32C 0x0 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_12_GPIO8_IO22 0x0E8 0x32C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_13_GPIO8_IO23 0x0EC 0x330 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_13_SEMC_DATA28 0x0EC 0x330 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_13_ENET_1G_TX_EN 0x0EC 0x330 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_13_SAI3_RX_DATA 0x0EC 0x330 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_13_FLEXSPI2_A_DATA00 0x0EC 0x330 0x57C 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_13_GPIO_MUX2_IO23 0x0EC 0x330 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_13_XBAR1_INOUT33 0x0EC 0x330 0x70C 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_13_EMVSIM1_RST 0x0EC 0x330 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_13_TMR2_TIMER0 0x0EC 0x330 0x648 0x9 0x1 + +#define IOMUXC_GPIO_EMC_B2_14_SEMC_DATA29 0x0F0 0x334 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_14_ENET_1G_TX_CLK_IO 0x0F0 0x334 0x4E8 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_14_SAI3_TX_DATA 0x0F0 0x334 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_14_FLEXSPI2_A_DATA01 0x0F0 0x334 0x580 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_14_GPIO_MUX2_IO24 0x0F0 0x334 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_14_XBAR1_INOUT34 0x0F0 0x334 0x710 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_14_SFA_ipp_do_atx_clk_under_test 0x0F0 0x334 0x0 0x7 0x0 +#define IOMUXC_GPIO_EMC_B2_14_EMVSIM1_SVEN 0x0F0 0x334 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_14_TMR2_TIMER1 0x0F0 0x334 0x64C 0x9 0x1 +#define IOMUXC_GPIO_EMC_B2_14_GPIO8_IO24 0x0F0 0x334 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_15_SEMC_DATA30 0x0F4 0x338 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_15_ENET_1G_RX_DATA00 0x0F4 0x338 0x4D0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_15_SAI3_TX_BCLK 0x0F4 0x338 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_15_FLEXSPI2_A_DATA02 0x0F4 0x338 0x584 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_15_GPIO_MUX2_IO25 0x0F4 0x338 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_15_XBAR1_INOUT35 0x0F4 0x338 0x714 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_15_EMVSIM1_PD 0x0F4 0x338 0x6A0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_15_TMR2_TIMER2 0x0F4 0x338 0x650 0x9 0x0 +#define IOMUXC_GPIO_EMC_B2_15_GPIO8_IO25 0x0F4 0x338 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_16_GPIO8_IO26 0x0F8 0x33C 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_16_SEMC_DATA31 0x0F8 0x33C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_16_XBAR1_INOUT14 0x0F8 0x33C 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_16_ENET_1G_RX_DATA01 0x0F8 0x33C 0x4D4 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_16_SAI3_TX_SYNC 0x0F8 0x33C 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_16_FLEXSPI2_A_DATA03 0x0F8 0x33C 0x588 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_16_GPIO_MUX2_IO26 0x0F8 0x33C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_16_EMVSIM1_POWER_FAIL 0x0F8 0x33C 0x6A4 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_16_TMR2_TIMER3 0x0F8 0x33C 0x0 0x9 0x0 + +#define IOMUXC_GPIO_EMC_B2_17_SEMC_DM03 0x0FC 0x340 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_17_XBAR1_INOUT15 0x0FC 0x340 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_17_ENET_1G_RX_EN 0x0FC 0x340 0x4E0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_17_SAI3_MCLK 0x0FC 0x340 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_17_FLEXSPI2_A_DATA04 0x0FC 0x340 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_17_GPIO_MUX2_IO27 0x0FC 0x340 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_17_WDOG1_ANY 0x0FC 0x340 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_17_TMR3_TIMER0 0x0FC 0x340 0x654 0x9 0x1 +#define IOMUXC_GPIO_EMC_B2_17_GPIO8_IO27 0x0FC 0x340 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_18_SEMC_DQS4 0x100 0x344 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_18_XBAR1_INOUT16 0x100 0x344 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_18_ENET_1G_RX_ER 0x100 0x344 0x4E4 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_18_EWM_OUT_B 0x100 0x344 0x0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_18_FLEXSPI2_A_DATA05 0x100 0x344 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_18_GPIO_MUX2_IO28 0x100 0x344 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_18_FLEXSPI1_A_DQS 0x100 0x344 0x550 0x6 0x0 +#define IOMUXC_GPIO_EMC_B2_18_WDOG1_B 0x100 0x344 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_18_TMR3_TIMER1 0x100 0x344 0x658 0x9 0x1 +#define IOMUXC_GPIO_EMC_B2_18_GPIO8_IO28 0x100 0x344 0x0 0xA 0x0 + +#define IOMUXC_GPIO_EMC_B2_19_GPIO8_IO29 0x104 0x348 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_19_SEMC_CLKX00 0x104 0x348 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_19_ENET_MDC 0x104 0x348 0x0 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_19_ENET_1G_MDC 0x104 0x348 0x0 0x2 0x0 +#define IOMUXC_GPIO_EMC_B2_19_ENET_1G_REF_CLK 0x104 0x348 0x4C4 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_19_FLEXSPI2_A_DATA06 0x104 0x348 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_19_GPIO_MUX2_IO29 0x104 0x348 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_19_ENET_QOS_MDC 0x104 0x348 0x0 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_19_TMR3_TIMER2 0x104 0x348 0x65C 0x9 0x0 + +#define IOMUXC_GPIO_EMC_B2_20_GPIO8_IO30 0x108 0x34C 0x0 0xA 0x0 +#define IOMUXC_GPIO_EMC_B2_20_SEMC_CLKX01 0x108 0x34C 0x0 0x0 0x0 +#define IOMUXC_GPIO_EMC_B2_20_ENET_MDIO 0x108 0x34C 0x4AC 0x1 0x0 +#define IOMUXC_GPIO_EMC_B2_20_ENET_1G_MDIO 0x108 0x34C 0x4C8 0x2 0x1 +#define IOMUXC_GPIO_EMC_B2_20_ENET_QOS_REF_CLK 0x108 0x34C 0x4A0 0x3 0x0 +#define IOMUXC_GPIO_EMC_B2_20_FLEXSPI2_A_DATA07 0x108 0x34C 0x0 0x4 0x0 +#define IOMUXC_GPIO_EMC_B2_20_GPIO_MUX2_IO30 0x108 0x34C 0x0 0x5 0x0 +#define IOMUXC_GPIO_EMC_B2_20_ENET_QOS_MDIO 0x108 0x34C 0x4EC 0x8 0x0 +#define IOMUXC_GPIO_EMC_B2_20_TMR3_TIMER3 0x108 0x34C 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_00_GPIO8_IO31 0x10C 0x350 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_00_EMVSIM1_IO 0x10C 0x350 0x69C 0x0 0x1 +#define IOMUXC_GPIO_AD_00_FLEXCAN2_TX 0x10C 0x350 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_00_ENET_1G_1588_EVENT1_IN 0x10C 0x350 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_00_GPT2_CAPTURE1 0x10C 0x350 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_00_FLEXPWM1_PWM0_A 0x10C 0x350 0x500 0x4 0x1 +#define IOMUXC_GPIO_AD_00_GPIO_MUX2_IO31 0x10C 0x350 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_00_LPUART7_TXD 0x10C 0x350 0x630 0x6 0x0 +#define IOMUXC_GPIO_AD_00_FLEXIO2_D00 0x10C 0x350 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_00_FLEXSPI2_B_SS1_B 0x10C 0x350 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_01_GPIO9_IO00 0x110 0x354 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_01_EMVSIM1_CLK 0x110 0x354 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_01_FLEXCAN2_RX 0x110 0x354 0x49C 0x1 0x0 +#define IOMUXC_GPIO_AD_01_ENET_1G_1588_EVENT1_OUT 0x110 0x354 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_01_GPT2_CAPTURE2 0x110 0x354 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_01_FLEXPWM1_PWM0_B 0x110 0x354 0x50C 0x4 0x1 +#define IOMUXC_GPIO_AD_01_GPIO_MUX3_IO00 0x110 0x354 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_01_LPUART7_RXD 0x110 0x354 0x62C 0x6 0x0 +#define IOMUXC_GPIO_AD_01_FLEXIO2_D01 0x110 0x354 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_01_FLEXSPI2_A_SS1_B 0x110 0x354 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_02_GPIO9_IO01 0x114 0x358 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_02_EMVSIM1_RST 0x114 0x358 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_02_LPUART7_CTS_B 0x114 0x358 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_02_ENET_1G_1588_EVENT2_IN 0x114 0x358 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_02_GPT2_COMPARE1 0x114 0x358 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_02_FLEXPWM1_PWM1_A 0x114 0x358 0x504 0x4 0x1 +#define IOMUXC_GPIO_AD_02_GPIO_MUX3_IO01 0x114 0x358 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_02_LPUART8_TXD 0x114 0x358 0x638 0x6 0x0 +#define IOMUXC_GPIO_AD_02_FLEXIO2_D02 0x114 0x358 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_02_VIDEO_MUX_EXT_DCIC1 0x114 0x358 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_03_GPIO9_IO02 0x118 0x35C 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_03_EMVSIM1_SVEN 0x118 0x35C 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_03_LPUART7_RTS_B 0x118 0x35C 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_03_ENET_1G_1588_EVENT2_OUT 0x118 0x35C 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_03_GPT2_COMPARE2 0x118 0x35C 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_03_FLEXPWM1_PWM1_B 0x118 0x35C 0x510 0x4 0x1 +#define IOMUXC_GPIO_AD_03_GPIO_MUX3_IO02 0x118 0x35C 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_03_LPUART8_RXD 0x118 0x35C 0x634 0x6 0x0 +#define IOMUXC_GPIO_AD_03_FLEXIO2_D03 0x118 0x35C 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_03_VIDEO_MUX_EXT_DCIC2 0x118 0x35C 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_04_EMVSIM1_PD 0x11C 0x360 0x6A0 0x0 0x1 +#define IOMUXC_GPIO_AD_04_LPUART8_CTS_B 0x11C 0x360 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_04_ENET_1G_1588_EVENT3_IN 0x11C 0x360 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_04_GPT2_COMPARE3 0x11C 0x360 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_04_FLEXPWM1_PWM2_A 0x11C 0x360 0x508 0x4 0x1 +#define IOMUXC_GPIO_AD_04_GPIO_MUX3_IO03 0x11C 0x360 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_04_WDOG1_B 0x11C 0x360 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_04_FLEXIO2_D04 0x11C 0x360 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_04_TMR4_TIMER0 0x11C 0x360 0x660 0x9 0x1 +#define IOMUXC_GPIO_AD_04_GPIO9_IO03 0x11C 0x360 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_05_EMVSIM1_POWER_FAIL 0x120 0x364 0x6A4 0x0 0x1 +#define IOMUXC_GPIO_AD_05_LPUART8_RTS_B 0x120 0x364 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_05_ENET_1G_1588_EVENT3_OUT 0x120 0x364 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_05_GPT2_CLK 0x120 0x364 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_05_FLEXPWM1_PWM2_B 0x120 0x364 0x514 0x4 0x1 +#define IOMUXC_GPIO_AD_05_GPIO_MUX3_IO04 0x120 0x364 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_05_WDOG2_B 0x120 0x364 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_05_FLEXIO2_D05 0x120 0x364 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_05_TMR4_TIMER1 0x120 0x364 0x664 0x9 0x1 +#define IOMUXC_GPIO_AD_05_GPIO9_IO04 0x120 0x364 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_06_USB_OTG2_OC 0x124 0x368 0x6B8 0x0 0x0 +#define IOMUXC_GPIO_AD_06_FLEXCAN1_TX 0x124 0x368 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_06_EMVSIM2_IO 0x124 0x368 0x6A8 0x2 0x0 +#define IOMUXC_GPIO_AD_06_GPT3_CAPTURE1 0x124 0x368 0x590 0x3 0x1 +#define IOMUXC_GPIO_AD_06_VIDEO_MUX_CSI_DATA15 0x124 0x368 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_06_GPIO_MUX3_IO05 0x124 0x368 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_06_ENET_1588_EVENT1_IN 0x124 0x368 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_06_FLEXIO2_D06 0x124 0x368 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_06_TMR4_TIMER2 0x124 0x368 0x668 0x9 0x0 +#define IOMUXC_GPIO_AD_06_GPIO9_IO05 0x124 0x368 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_06_FLEXPWM1_PWM0_X 0x124 0x368 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_07_USB_OTG2_PWR 0x128 0x36C 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_07_FLEXCAN1_RX 0x128 0x36C 0x498 0x1 0x0 +#define IOMUXC_GPIO_AD_07_EMVSIM2_CLK 0x128 0x36C 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_07_GPT3_CAPTURE2 0x128 0x36C 0x594 0x3 0x1 +#define IOMUXC_GPIO_AD_07_VIDEO_MUX_CSI_DATA14 0x128 0x36C 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_07_GPIO_MUX3_IO06 0x128 0x36C 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_07_ENET_1588_EVENT1_OUT 0x128 0x36C 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_07_FLEXIO2_D07 0x128 0x36C 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_07_TMR4_TIMER3 0x128 0x36C 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_07_GPIO9_IO06 0x128 0x36C 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_07_FLEXPWM1_PWM1_X 0x128 0x36C 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_08_USBPHY2_OTG_ID 0x12C 0x370 0x6C4 0x0 0x0 +#define IOMUXC_GPIO_AD_08_LPI2C1_SCL 0x12C 0x370 0x5AC 0x1 0x0 +#define IOMUXC_GPIO_AD_08_EMVSIM2_RST 0x12C 0x370 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_08_GPT3_COMPARE1 0x12C 0x370 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_08_VIDEO_MUX_CSI_DATA13 0x12C 0x370 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_08_GPIO_MUX3_IO07 0x12C 0x370 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_08_ENET_1588_EVENT2_IN 0x12C 0x370 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_08_FLEXIO2_D08 0x12C 0x370 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_08_GPIO9_IO07 0x12C 0x370 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_08_FLEXPWM1_PWM2_X 0x12C 0x370 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_09_USBPHY1_OTG_ID 0x130 0x374 0x6C0 0x0 0x0 +#define IOMUXC_GPIO_AD_09_LPI2C1_SDA 0x130 0x374 0x5B0 0x1 0x0 +#define IOMUXC_GPIO_AD_09_EMVSIM2_SVEN 0x130 0x374 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_09_GPT3_COMPARE2 0x130 0x374 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_09_VIDEO_MUX_CSI_DATA12 0x130 0x374 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_09_GPIO_MUX3_IO08 0x130 0x374 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_09_ENET_1588_EVENT2_OUT 0x130 0x374 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_09_FLEXIO2_D09 0x130 0x374 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_09_GPIO9_IO08 0x130 0x374 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_09_FLEXPWM1_PWM3_X 0x130 0x374 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_10_USB_OTG1_PWR 0x134 0x378 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_10_LPI2C1_SCLS 0x134 0x378 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_10_EMVSIM2_PD 0x134 0x378 0x6AC 0x2 0x0 +#define IOMUXC_GPIO_AD_10_GPT3_COMPARE3 0x134 0x378 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_10_VIDEO_MUX_CSI_DATA11 0x134 0x378 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_10_GPIO_MUX3_IO09 0x134 0x378 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_10_ENET_1588_EVENT3_IN 0x134 0x378 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_10_FLEXIO2_D10 0x134 0x378 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_10_GPIO9_IO09 0x134 0x378 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_10_FLEXPWM2_PWM0_X 0x134 0x378 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_11_USB_OTG1_OC 0x138 0x37C 0x6BC 0x0 0x0 +#define IOMUXC_GPIO_AD_11_LPI2C1_SDAS 0x138 0x37C 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_11_EMVSIM2_POWER_FAIL 0x138 0x37C 0x6B0 0x2 0x0 +#define IOMUXC_GPIO_AD_11_GPT3_CLK 0x138 0x37C 0x598 0x3 0x1 +#define IOMUXC_GPIO_AD_11_VIDEO_MUX_CSI_DATA10 0x138 0x37C 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_11_GPIO_MUX3_IO10 0x138 0x37C 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_11_ENET_1588_EVENT3_OUT 0x138 0x37C 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_11_FLEXIO2_D11 0x138 0x37C 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_11_GPIO9_IO10 0x138 0x37C 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_11_FLEXPWM2_PWM1_X 0x138 0x37C 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_12_SPDIF_LOCK 0x13C 0x380 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_12_LPI2C1_HREQ 0x13C 0x380 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_12_GPT1_CAPTURE1 0x13C 0x380 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_12_FLEXSPI1_B_DATA03 0x13C 0x380 0x570 0x3 0x0 +#define IOMUXC_GPIO_AD_12_VIDEO_MUX_CSI_PIXCLK 0x13C 0x380 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_12_GPIO_MUX3_IO11 0x13C 0x380 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_12_ENET_TX_DATA03 0x13C 0x380 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_12_FLEXIO2_D12 0x13C 0x380 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_12_EWM_OUT_B 0x13C 0x380 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_12_GPIO9_IO11 0x13C 0x380 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_12_FLEXPWM2_PWM2_X 0x13C 0x380 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_13_SPDIF_SR_CLK 0x140 0x384 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_13_PIT1_TRIGGER0 0x140 0x384 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_13_GPT1_CAPTURE2 0x140 0x384 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_13_FLEXSPI1_B_DATA02 0x140 0x384 0x56C 0x3 0x0 +#define IOMUXC_GPIO_AD_13_VIDEO_MUX_CSI_MCLK 0x140 0x384 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_13_GPIO_MUX3_IO12 0x140 0x384 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_13_ENET_TX_DATA02 0x140 0x384 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_13_FLEXIO2_D13 0x140 0x384 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_13_REF_CLK_32K 0x140 0x384 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_13_GPIO9_IO12 0x140 0x384 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_13_FLEXPWM2_PWM3_X 0x140 0x384 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_14_SPDIF_EXT_CLK 0x144 0x388 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_14_REF_CLK_24M 0x144 0x388 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_14_GPT1_COMPARE1 0x144 0x388 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_14_FLEXSPI1_B_DATA01 0x144 0x388 0x568 0x3 0x0 +#define IOMUXC_GPIO_AD_14_VIDEO_MUX_CSI_VSYNC 0x144 0x388 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_14_GPIO_MUX3_IO13 0x144 0x388 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_14_ENET_RX_CLK 0x144 0x388 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_14_FLEXIO2_D14 0x144 0x388 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_14_CCM_ENET_REF_CLK_25M 0x144 0x388 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_14_GPIO9_IO13 0x144 0x388 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_14_FLEXPWM3_PWM0_X 0x144 0x388 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_15_GPIO9_IO14 0x148 0x38C 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_15_FLEXPWM3_PWM1_X 0x148 0x38C 0x0 0xB 0x0 +#define IOMUXC_GPIO_AD_15_SPDIF_IN 0x148 0x38C 0x6B4 0x0 0x1 +#define IOMUXC_GPIO_AD_15_LPUART10_TXD 0x148 0x38C 0x628 0x1 0x0 +#define IOMUXC_GPIO_AD_15_GPT1_COMPARE2 0x148 0x38C 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_15_FLEXSPI1_B_DATA00 0x148 0x38C 0x564 0x3 0x0 +#define IOMUXC_GPIO_AD_15_VIDEO_MUX_CSI_HSYNC 0x148 0x38C 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_15_GPIO_MUX3_IO14 0x148 0x38C 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_15_ENET_TX_ER 0x148 0x38C 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_15_FLEXIO2_D15 0x148 0x38C 0x0 0x8 0x0 + +#define IOMUXC_GPIO_AD_16_SPDIF_OUT 0x14C 0x390 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_16_LPUART10_RXD 0x14C 0x390 0x624 0x1 0x0 +#define IOMUXC_GPIO_AD_16_GPT1_COMPARE3 0x14C 0x390 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_16_FLEXSPI1_B_SCLK 0x14C 0x390 0x578 0x3 0x0 +#define IOMUXC_GPIO_AD_16_VIDEO_MUX_CSI_DATA09 0x14C 0x390 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_16_GPIO_MUX3_IO15 0x14C 0x390 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_16_ENET_RX_DATA03 0x14C 0x390 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_16_FLEXIO2_D16 0x14C 0x390 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_16_ENET_1G_MDC 0x14C 0x390 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_16_GPIO9_IO15 0x14C 0x390 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_16_FLEXPWM3_PWM2_X 0x14C 0x390 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_17_SAI1_MCLK 0x150 0x394 0x66C 0x0 0x0 +#define IOMUXC_GPIO_AD_17_ACMP1_OUT 0x150 0x394 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_17_GPT1_CLK 0x150 0x394 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_17_FLEXSPI1_A_DQS 0x150 0x394 0x550 0x3 0x1 +#define IOMUXC_GPIO_AD_17_VIDEO_MUX_CSI_DATA08 0x150 0x394 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_17_GPIO_MUX3_IO16 0x150 0x394 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_17_ENET_RX_DATA02 0x150 0x394 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_17_FLEXIO2_D17 0x150 0x394 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_17_ENET_1G_MDIO 0x150 0x394 0x4C8 0x9 0x2 +#define IOMUXC_GPIO_AD_17_GPIO9_IO16 0x150 0x394 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_17_FLEXPWM3_PWM3_X 0x150 0x394 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_18_GPIO9_IO17 0x154 0x398 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_18_FLEXPWM4_PWM0_X 0x154 0x398 0x0 0xB 0x0 +#define IOMUXC_GPIO_AD_18_SAI1_RX_SYNC 0x154 0x398 0x678 0x0 0x0 +#define IOMUXC_GPIO_AD_18_ACMP2_OUT 0x154 0x398 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_18_LPSPI1_PCS1 0x154 0x398 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_18_FLEXSPI1_A_SS0_B 0x154 0x398 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_18_VIDEO_MUX_CSI_DATA07 0x154 0x398 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_18_GPIO_MUX3_IO17 0x154 0x398 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_18_ENET_CRS 0x154 0x398 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_18_FLEXIO2_D18 0x154 0x398 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_18_LPI2C2_SCL 0x154 0x398 0x5B4 0x9 0x1 + +#define IOMUXC_GPIO_AD_19_SAI1_RX_BCLK 0x158 0x39C 0x670 0x0 0x0 +#define IOMUXC_GPIO_AD_19_ACMP3_OUT 0x158 0x39C 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_19_LPSPI1_PCS2 0x158 0x39C 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_19_FLEXSPI1_A_SCLK 0x158 0x39C 0x574 0x3 0x0 +#define IOMUXC_GPIO_AD_19_VIDEO_MUX_CSI_DATA06 0x158 0x39C 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_19_GPIO_MUX3_IO18 0x158 0x39C 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_19_ENET_COL 0x158 0x39C 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_19_FLEXIO2_D19 0x158 0x39C 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_19_LPI2C2_SDA 0x158 0x39C 0x5B8 0x9 0x1 +#define IOMUXC_GPIO_AD_19_GPIO9_IO18 0x158 0x39C 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_19_FLEXPWM4_PWM1_X 0x158 0x39C 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_20_SAI1_RX_DATA00 0x15C 0x3A0 0x674 0x0 0x0 +#define IOMUXC_GPIO_AD_20_ACMP4_OUT 0x15C 0x3A0 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_20_LPSPI1_PCS3 0x15C 0x3A0 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_20_FLEXSPI1_A_DATA00 0x15C 0x3A0 0x554 0x3 0x0 +#define IOMUXC_GPIO_AD_20_VIDEO_MUX_CSI_DATA05 0x15C 0x3A0 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_20_GPIO_MUX3_IO19 0x15C 0x3A0 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_20_KPP_ROW07 0x15C 0x3A0 0x5A8 0x6 0x0 +#define IOMUXC_GPIO_AD_20_FLEXIO2_D20 0x15C 0x3A0 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_20_ENET_QOS_1588_EVENT2_OUT 0x15C 0x3A0 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_20_GPIO9_IO19 0x15C 0x3A0 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_20_FLEXPWM4_PWM2_X 0x15C 0x3A0 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_21_SAI1_TX_DATA00 0x160 0x3A4 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_21_LPSPI2_PCS1 0x160 0x3A4 0x5E0 0x2 0x0 +#define IOMUXC_GPIO_AD_21_FLEXSPI1_A_DATA01 0x160 0x3A4 0x558 0x3 0x0 +#define IOMUXC_GPIO_AD_21_VIDEO_MUX_CSI_DATA04 0x160 0x3A4 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_21_GPIO_MUX3_IO20 0x160 0x3A4 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_21_KPP_COL07 0x160 0x3A4 0x5A0 0x6 0x0 +#define IOMUXC_GPIO_AD_21_FLEXIO2_D21 0x160 0x3A4 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_21_ENET_QOS_1588_EVENT2_IN 0x160 0x3A4 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_21_GPIO9_IO20 0x160 0x3A4 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_21_FLEXPWM4_PWM3_X 0x160 0x3A4 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_22_GPIO9_IO21 0x164 0x3A8 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_22_SAI1_TX_BCLK 0x164 0x3A8 0x67C 0x0 0x0 +#define IOMUXC_GPIO_AD_22_LPSPI2_PCS2 0x164 0x3A8 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_22_FLEXSPI1_A_DATA02 0x164 0x3A8 0x55C 0x3 0x0 +#define IOMUXC_GPIO_AD_22_VIDEO_MUX_CSI_DATA03 0x164 0x3A8 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_22_GPIO_MUX3_IO21 0x164 0x3A8 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_22_KPP_ROW06 0x164 0x3A8 0x5A4 0x6 0x0 +#define IOMUXC_GPIO_AD_22_FLEXIO2_D22 0x164 0x3A8 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_22_ENET_QOS_1588_EVENT3_OUT 0x164 0x3A8 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_23_SAI1_TX_SYNC 0x168 0x3AC 0x680 0x0 0x0 +#define IOMUXC_GPIO_AD_23_LPSPI2_PCS3 0x168 0x3AC 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_23_FLEXSPI1_A_DATA03 0x168 0x3AC 0x560 0x3 0x0 +#define IOMUXC_GPIO_AD_23_VIDEO_MUX_CSI_DATA02 0x168 0x3AC 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_23_GPIO_MUX3_IO22 0x168 0x3AC 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_23_KPP_COL06 0x168 0x3AC 0x59C 0x6 0x0 +#define IOMUXC_GPIO_AD_23_FLEXIO2_D23 0x168 0x3AC 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_23_ENET_QOS_1588_EVENT3_IN 0x168 0x3AC 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_23_GPIO9_IO22 0x168 0x3AC 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_24_LPUART1_TXD 0x16C 0x3B0 0x620 0x0 0x0 +#define IOMUXC_GPIO_AD_24_LPSPI2_SCK 0x16C 0x3B0 0x5E4 0x1 0x0 +#define IOMUXC_GPIO_AD_24_VIDEO_MUX_CSI_DATA00 0x16C 0x3B0 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_24_ENET_RX_EN 0x16C 0x3B0 0x4B8 0x3 0x0 +#define IOMUXC_GPIO_AD_24_FLEXPWM2_PWM0_A 0x16C 0x3B0 0x518 0x4 0x1 +#define IOMUXC_GPIO_AD_24_GPIO_MUX3_IO23 0x16C 0x3B0 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_24_KPP_ROW05 0x16C 0x3B0 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_24_FLEXIO2_D24 0x16C 0x3B0 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_24_LPI2C4_SCL 0x16C 0x3B0 0x5C4 0x9 0x0 +#define IOMUXC_GPIO_AD_24_GPIO9_IO23 0x16C 0x3B0 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_25_GPIO9_IO24 0x170 0x3B4 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_25_LPUART1_RXD 0x170 0x3B4 0x61C 0x0 0x0 +#define IOMUXC_GPIO_AD_25_LPSPI2_PCS0 0x170 0x3B4 0x5DC 0x1 0x0 +#define IOMUXC_GPIO_AD_25_VIDEO_MUX_CSI_DATA01 0x170 0x3B4 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_25_ENET_RX_ER 0x170 0x3B4 0x4BC 0x3 0x0 +#define IOMUXC_GPIO_AD_25_FLEXPWM2_PWM0_B 0x170 0x3B4 0x524 0x4 0x1 +#define IOMUXC_GPIO_AD_25_GPIO_MUX3_IO24 0x170 0x3B4 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_25_KPP_COL05 0x170 0x3B4 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_25_FLEXIO2_D25 0x170 0x3B4 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_25_LPI2C4_SDA 0x170 0x3B4 0x5C8 0x9 0x0 + +#define IOMUXC_GPIO_AD_26_LPUART1_CTS_B 0x174 0x3B8 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_26_LPSPI2_SOUT 0x174 0x3B8 0x5EC 0x1 0x0 +#define IOMUXC_GPIO_AD_26_SEMC_CSX01 0x174 0x3B8 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_26_ENET_RX_DATA00 0x174 0x3B8 0x4B0 0x3 0x0 +#define IOMUXC_GPIO_AD_26_FLEXPWM2_PWM1_A 0x174 0x3B8 0x51C 0x4 0x1 +#define IOMUXC_GPIO_AD_26_GPIO_MUX3_IO25 0x174 0x3B8 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_26_KPP_ROW04 0x174 0x3B8 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_26_FLEXIO2_D26 0x174 0x3B8 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_26_ENET_QOS_MDC 0x174 0x3B8 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_26_GPIO9_IO25 0x174 0x3B8 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_26_USDHC2_CD_B 0x174 0x3B8 0x6D0 0xB 0x1 + +#define IOMUXC_GPIO_AD_27_LPUART1_RTS_B 0x178 0x3BC 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_27_LPSPI2_SIN 0x178 0x3BC 0x5E8 0x1 0x0 +#define IOMUXC_GPIO_AD_27_SEMC_CSX02 0x178 0x3BC 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_27_ENET_RX_DATA01 0x178 0x3BC 0x4B4 0x3 0x0 +#define IOMUXC_GPIO_AD_27_FLEXPWM2_PWM1_B 0x178 0x3BC 0x528 0x4 0x1 +#define IOMUXC_GPIO_AD_27_GPIO_MUX3_IO26 0x178 0x3BC 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_27_KPP_COL04 0x178 0x3BC 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_27_FLEXIO2_D27 0x178 0x3BC 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_27_ENET_QOS_MDIO 0x178 0x3BC 0x4EC 0x9 0x1 +#define IOMUXC_GPIO_AD_27_GPIO9_IO26 0x178 0x3BC 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_27_USDHC2_WP 0x178 0x3BC 0x6D4 0xB 0x1 + +#define IOMUXC_GPIO_AD_28_GPIO9_IO27 0x17C 0x3C0 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_28_USDHC2_VSELECT 0x17C 0x3C0 0x0 0xB 0x0 +#define IOMUXC_GPIO_AD_28_LPSPI1_SCK 0x17C 0x3C0 0x5D0 0x0 0x1 +#define IOMUXC_GPIO_AD_28_LPUART5_TXD 0x17C 0x3C0 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_28_SEMC_CSX03 0x17C 0x3C0 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_28_ENET_TX_EN 0x17C 0x3C0 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_28_FLEXPWM2_PWM2_A 0x17C 0x3C0 0x520 0x4 0x1 +#define IOMUXC_GPIO_AD_28_GPIO_MUX3_IO27 0x17C 0x3C0 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_28_KPP_ROW03 0x17C 0x3C0 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_28_FLEXIO2_D28 0x17C 0x3C0 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_28_VIDEO_MUX_EXT_DCIC1 0x17C 0x3C0 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_29_LPSPI1_PCS0 0x180 0x3C4 0x5CC 0x0 0x1 +#define IOMUXC_GPIO_AD_29_LPUART5_RXD 0x180 0x3C4 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_29_ENET_REF_CLK 0x180 0x3C4 0x4A8 0x2 0x0 +#define IOMUXC_GPIO_AD_29_ENET_TX_CLK 0x180 0x3C4 0x4C0 0x3 0x0 +#define IOMUXC_GPIO_AD_29_FLEXPWM2_PWM2_B 0x180 0x3C4 0x52C 0x4 0x1 +#define IOMUXC_GPIO_AD_29_GPIO_MUX3_IO28 0x180 0x3C4 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_29_KPP_COL03 0x180 0x3C4 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_29_FLEXIO2_D29 0x180 0x3C4 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_29_VIDEO_MUX_EXT_DCIC2 0x180 0x3C4 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_29_GPIO9_IO28 0x180 0x3C4 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_29_USDHC2_RESET_B 0x180 0x3C4 0x0 0xB 0x0 + +#define IOMUXC_GPIO_AD_30_LPSPI1_SOUT 0x184 0x3C8 0x5D8 0x0 0x1 +#define IOMUXC_GPIO_AD_30_USB_OTG2_OC 0x184 0x3C8 0x6B8 0x1 0x1 +#define IOMUXC_GPIO_AD_30_FLEXCAN2_TX 0x184 0x3C8 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_30_ENET_TX_DATA00 0x184 0x3C8 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_30_LPUART3_TXD 0x184 0x3C8 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_30_GPIO_MUX3_IO29 0x184 0x3C8 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_30_KPP_ROW02 0x184 0x3C8 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_30_FLEXIO2_D30 0x184 0x3C8 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_30_WDOG2_RESET_B_DEB 0x184 0x3C8 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_30_GPIO9_IO29 0x184 0x3C8 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_31_LPSPI1_SIN 0x188 0x3CC 0x5D4 0x0 0x1 +#define IOMUXC_GPIO_AD_31_USB_OTG2_PWR 0x188 0x3CC 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_31_FLEXCAN2_RX 0x188 0x3CC 0x49C 0x2 0x1 +#define IOMUXC_GPIO_AD_31_ENET_TX_DATA01 0x188 0x3CC 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_31_LPUART3_RXD 0x188 0x3CC 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_31_GPIO_MUX3_IO30 0x188 0x3CC 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_31_KPP_COL02 0x188 0x3CC 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_31_FLEXIO2_D31 0x188 0x3CC 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_31_WDOG1_RESET_B_DEB 0x188 0x3CC 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_31_GPIO9_IO30 0x188 0x3CC 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_32_GPIO9_IO31 0x18C 0x3D0 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_32_LPI2C1_SCL 0x18C 0x3D0 0x5AC 0x0 0x1 +#define IOMUXC_GPIO_AD_32_USBPHY2_OTG_ID 0x18C 0x3D0 0x6C4 0x1 0x1 +#define IOMUXC_GPIO_AD_32_PGMC_PMIC_RDY 0x18C 0x3D0 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_32_ENET_MDC 0x18C 0x3D0 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_32_USDHC1_CD_B 0x18C 0x3D0 0x6C8 0x4 0x0 +#define IOMUXC_GPIO_AD_32_GPIO_MUX3_IO31 0x18C 0x3D0 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_32_KPP_ROW01 0x18C 0x3D0 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_32_LPUART10_TXD 0x18C 0x3D0 0x628 0x8 0x1 +#define IOMUXC_GPIO_AD_32_ENET_1G_MDC 0x18C 0x3D0 0x0 0x9 0x0 + +#define IOMUXC_GPIO_AD_33_LPI2C1_SDA 0x190 0x3D4 0x5B0 0x0 0x1 +#define IOMUXC_GPIO_AD_33_USBPHY1_OTG_ID 0x190 0x3D4 0x6C0 0x1 0x1 +#define IOMUXC_GPIO_AD_33_XBAR1_INOUT17 0x190 0x3D4 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_33_ENET_MDIO 0x190 0x3D4 0x4AC 0x3 0x1 +#define IOMUXC_GPIO_AD_33_USDHC1_WP 0x190 0x3D4 0x6CC 0x4 0x0 +#define IOMUXC_GPIO_AD_33_GPIO_MUX4_IO00 0x190 0x3D4 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_33_KPP_COL01 0x190 0x3D4 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_33_LPUART10_RXD 0x190 0x3D4 0x624 0x8 0x1 +#define IOMUXC_GPIO_AD_33_ENET_1G_MDIO 0x190 0x3D4 0x4C8 0x9 0x3 +#define IOMUXC_GPIO_AD_33_GPIO10_IO00 0x190 0x3D4 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_34_ENET_1G_1588_EVENT0_IN 0x194 0x3D8 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_34_USB_OTG1_PWR 0x194 0x3D8 0x0 0x1 0x0 +#define IOMUXC_GPIO_AD_34_XBAR1_INOUT18 0x194 0x3D8 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_34_ENET_1588_EVENT0_IN 0x194 0x3D8 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_34_USDHC1_VSELECT 0x194 0x3D8 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_34_GPIO_MUX4_IO01 0x194 0x3D8 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_34_KPP_ROW00 0x194 0x3D8 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_34_LPUART10_CTS_B 0x194 0x3D8 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_34_WDOG1_ANY 0x194 0x3D8 0x0 0x9 0x0 +#define IOMUXC_GPIO_AD_34_GPIO10_IO01 0x194 0x3D8 0x0 0xA 0x0 + +#define IOMUXC_GPIO_AD_35_GPIO10_IO02 0x198 0x3DC 0x0 0xA 0x0 +#define IOMUXC_GPIO_AD_35_ENET_1G_1588_EVENT0_OUT 0x198 0x3DC 0x0 0x0 0x0 +#define IOMUXC_GPIO_AD_35_USB_OTG1_OC 0x198 0x3DC 0x6BC 0x1 0x1 +#define IOMUXC_GPIO_AD_35_XBAR1_INOUT19 0x198 0x3DC 0x0 0x2 0x0 +#define IOMUXC_GPIO_AD_35_ENET_1588_EVENT0_OUT 0x198 0x3DC 0x0 0x3 0x0 +#define IOMUXC_GPIO_AD_35_USDHC1_RESET_B 0x198 0x3DC 0x0 0x4 0x0 +#define IOMUXC_GPIO_AD_35_GPIO_MUX4_IO02 0x198 0x3DC 0x0 0x5 0x0 +#define IOMUXC_GPIO_AD_35_KPP_COL00 0x198 0x3DC 0x0 0x6 0x0 +#define IOMUXC_GPIO_AD_35_LPUART10_RTS_B 0x198 0x3DC 0x0 0x8 0x0 +#define IOMUXC_GPIO_AD_35_FLEXSPI1_B_SS1_B 0x198 0x3DC 0x0 0x9 0x0 + +#define IOMUXC_GPIO_SD_B1_00_USDHC1_CMD 0x19C 0x3E0 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B1_00_XBAR1_INOUT20 0x19C 0x3E0 0x6D8 0x2 0x1 +#define IOMUXC_GPIO_SD_B1_00_GPT4_CAPTURE1 0x19C 0x3E0 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B1_00_GPIO_MUX4_IO03 0x19C 0x3E0 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B1_00_FLEXSPI2_A_SS0_B 0x19C 0x3E0 0x0 0x6 0x0 +#define IOMUXC_GPIO_SD_B1_00_KPP_ROW07 0x19C 0x3E0 0x5A8 0x8 0x1 +#define IOMUXC_GPIO_SD_B1_00_GPIO10_IO03 0x19C 0x3E0 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B1_01_USDHC1_CLK 0x1A0 0x3E4 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B1_01_XBAR1_INOUT21 0x1A0 0x3E4 0x6DC 0x2 0x1 +#define IOMUXC_GPIO_SD_B1_01_GPT4_CAPTURE2 0x1A0 0x3E4 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B1_01_GPIO_MUX4_IO04 0x1A0 0x3E4 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B1_01_FLEXSPI2_A_SCLK 0x1A0 0x3E4 0x58C 0x6 0x1 +#define IOMUXC_GPIO_SD_B1_01_KPP_COL07 0x1A0 0x3E4 0x5A0 0x8 0x1 +#define IOMUXC_GPIO_SD_B1_01_GPIO10_IO04 0x1A0 0x3E4 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B1_02_GPIO10_IO05 0x1A4 0x3E8 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B1_02_USDHC1_DATA0 0x1A4 0x3E8 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B1_02_XBAR1_INOUT22 0x1A4 0x3E8 0x6E0 0x2 0x1 +#define IOMUXC_GPIO_SD_B1_02_GPT4_COMPARE1 0x1A4 0x3E8 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B1_02_GPIO_MUX4_IO05 0x1A4 0x3E8 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B1_02_FLEXSPI2_A_DATA00 0x1A4 0x3E8 0x57C 0x6 0x1 +#define IOMUXC_GPIO_SD_B1_02_KPP_ROW06 0x1A4 0x3E8 0x5A4 0x8 0x1 +#define IOMUXC_GPIO_SD_B1_02_FLEXSPI1_A_SS1_B 0x1A4 0x3E8 0x0 0x9 0x0 + +#define IOMUXC_GPIO_SD_B1_03_USDHC1_DATA1 0x1A8 0x3EC 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B1_03_XBAR1_INOUT23 0x1A8 0x3EC 0x6E4 0x2 0x1 +#define IOMUXC_GPIO_SD_B1_03_GPT4_COMPARE2 0x1A8 0x3EC 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B1_03_GPIO_MUX4_IO06 0x1A8 0x3EC 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B1_03_FLEXSPI2_A_DATA01 0x1A8 0x3EC 0x580 0x6 0x1 +#define IOMUXC_GPIO_SD_B1_03_KPP_COL06 0x1A8 0x3EC 0x59C 0x8 0x1 +#define IOMUXC_GPIO_SD_B1_03_FLEXSPI1_B_SS1_B 0x1A8 0x3EC 0x0 0x9 0x0 +#define IOMUXC_GPIO_SD_B1_03_GPIO10_IO06 0x1A8 0x3EC 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B1_04_USDHC1_DATA2 0x1AC 0x3F0 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B1_04_XBAR1_INOUT24 0x1AC 0x3F0 0x6E8 0x2 0x1 +#define IOMUXC_GPIO_SD_B1_04_GPT4_COMPARE3 0x1AC 0x3F0 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B1_04_GPIO_MUX4_IO07 0x1AC 0x3F0 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B1_04_FLEXSPI2_A_DATA02 0x1AC 0x3F0 0x584 0x6 0x1 +#define IOMUXC_GPIO_SD_B1_04_FLEXSPI1_B_SS0_B 0x1AC 0x3F0 0x0 0x8 0x0 +#define IOMUXC_GPIO_SD_B1_04_ENET_QOS_1588_EVENT2_AUX_IN 0x1AC 0x3F0 0x0 0x9 0x0 +#define IOMUXC_GPIO_SD_B1_04_GPIO10_IO07 0x1AC 0x3F0 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B1_05_GPIO10_IO08 0x1B0 0x3F4 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B1_05_USDHC1_DATA3 0x1B0 0x3F4 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B1_05_XBAR1_INOUT25 0x1B0 0x3F4 0x6EC 0x2 0x1 +#define IOMUXC_GPIO_SD_B1_05_GPT4_CLK 0x1B0 0x3F4 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B1_05_GPIO_MUX4_IO08 0x1B0 0x3F4 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B1_05_FLEXSPI2_A_DATA03 0x1B0 0x3F4 0x588 0x6 0x1 +#define IOMUXC_GPIO_SD_B1_05_FLEXSPI1_B_DQS 0x1B0 0x3F4 0x0 0x8 0x0 +#define IOMUXC_GPIO_SD_B1_05_ENET_QOS_1588_EVENT3_AUX_IN 0x1B0 0x3F4 0x0 0x9 0x0 + +#define IOMUXC_GPIO_SD_B2_00_GPIO10_IO09 0x1B4 0x3F8 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_00_USDHC2_DATA3 0x1B4 0x3F8 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_00_FLEXSPI1_B_DATA03 0x1B4 0x3F8 0x570 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_00_ENET_1G_RX_EN 0x1B4 0x3F8 0x4E0 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_00_LPUART9_TXD 0x1B4 0x3F8 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_00_LPSPI4_SCK 0x1B4 0x3F8 0x610 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_00_GPIO_MUX4_IO09 0x1B4 0x3F8 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SD_B2_01_USDHC2_DATA2 0x1B8 0x3FC 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_01_FLEXSPI1_B_DATA02 0x1B8 0x3FC 0x56C 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_01_ENET_1G_RX_CLK 0x1B8 0x3FC 0x4CC 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_01_LPUART9_RXD 0x1B8 0x3FC 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_01_LPSPI4_PCS0 0x1B8 0x3FC 0x60C 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_01_GPIO_MUX4_IO10 0x1B8 0x3FC 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_01_GPIO10_IO10 0x1B8 0x3FC 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B2_02_GPIO10_IO11 0x1BC 0x400 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_02_USDHC2_DATA1 0x1BC 0x400 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_02_FLEXSPI1_B_DATA01 0x1BC 0x400 0x568 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_02_ENET_1G_RX_DATA00 0x1BC 0x400 0x4D0 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_02_LPUART9_CTS_B 0x1BC 0x400 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_02_LPSPI4_SOUT 0x1BC 0x400 0x618 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_02_GPIO_MUX4_IO11 0x1BC 0x400 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SD_B2_03_GPIO10_IO12 0x1C0 0x404 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_03_USDHC2_DATA0 0x1C0 0x404 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_03_FLEXSPI1_B_DATA00 0x1C0 0x404 0x564 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_03_ENET_1G_RX_DATA01 0x1C0 0x404 0x4D4 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_03_LPUART9_RTS_B 0x1C0 0x404 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_03_LPSPI4_SIN 0x1C0 0x404 0x614 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_03_GPIO_MUX4_IO12 0x1C0 0x404 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SD_B2_04_USDHC2_CLK 0x1C4 0x408 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_04_FLEXSPI1_B_SCLK 0x1C4 0x408 0x578 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_04_ENET_1G_RX_DATA02 0x1C4 0x408 0x4D8 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_04_FLEXSPI1_A_SS1_B 0x1C4 0x408 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_04_LPSPI4_PCS1 0x1C4 0x408 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_04_GPIO_MUX4_IO13 0x1C4 0x408 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_04_GPIO10_IO13 0x1C4 0x408 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B2_05_GPIO10_IO14 0x1C8 0x40C 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_05_USDHC2_CMD 0x1C8 0x40C 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_05_FLEXSPI1_A_DQS 0x1C8 0x40C 0x550 0x1 0x2 +#define IOMUXC_GPIO_SD_B2_05_ENET_1G_RX_DATA03 0x1C8 0x40C 0x4DC 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_05_FLEXSPI1_B_SS0_B 0x1C8 0x40C 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_05_LPSPI4_PCS2 0x1C8 0x40C 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_05_GPIO_MUX4_IO14 0x1C8 0x40C 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SD_B2_06_GPIO10_IO15 0x1CC 0x410 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_06_USDHC2_RESET_B 0x1CC 0x410 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_06_FLEXSPI1_A_SS0_B 0x1CC 0x410 0x0 0x1 0x0 +#define IOMUXC_GPIO_SD_B2_06_ENET_1G_TX_DATA03 0x1CC 0x410 0x0 0x2 0x0 +#define IOMUXC_GPIO_SD_B2_06_LPSPI4_PCS3 0x1CC 0x410 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_06_GPT6_CAPTURE1 0x1CC 0x410 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_06_GPIO_MUX4_IO15 0x1CC 0x410 0x0 0x5 0x0 + +#define IOMUXC_GPIO_SD_B2_07_USDHC2_STROBE 0x1D0 0x414 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_07_FLEXSPI1_A_SCLK 0x1D0 0x414 0x574 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_07_ENET_1G_TX_DATA02 0x1D0 0x414 0x0 0x2 0x0 +#define IOMUXC_GPIO_SD_B2_07_LPUART3_CTS_B 0x1D0 0x414 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_07_GPT6_CAPTURE2 0x1D0 0x414 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_07_GPIO_MUX4_IO16 0x1D0 0x414 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_07_LPSPI2_SCK 0x1D0 0x414 0x5E4 0x6 0x1 +#define IOMUXC_GPIO_SD_B2_07_ENET_TX_ER 0x1D0 0x414 0x0 0x8 0x0 +#define IOMUXC_GPIO_SD_B2_07_ENET_QOS_REF_CLK 0x1D0 0x414 0x4A0 0x9 0x1 +#define IOMUXC_GPIO_SD_B2_07_GPIO10_IO16 0x1D0 0x414 0x0 0xA 0x0 + +#define IOMUXC_GPIO_SD_B2_08_GPIO10_IO17 0x1D4 0x418 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_08_USDHC2_DATA4 0x1D4 0x418 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_08_FLEXSPI1_A_DATA00 0x1D4 0x418 0x554 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_08_ENET_1G_TX_DATA01 0x1D4 0x418 0x0 0x2 0x0 +#define IOMUXC_GPIO_SD_B2_08_LPUART3_RTS_B 0x1D4 0x418 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_08_GPT6_COMPARE1 0x1D4 0x418 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_08_GPIO_MUX4_IO17 0x1D4 0x418 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_08_LPSPI2_PCS0 0x1D4 0x418 0x5DC 0x6 0x1 + +#define IOMUXC_GPIO_SD_B2_09_GPIO10_IO18 0x1D8 0x41C 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_09_USDHC2_DATA5 0x1D8 0x41C 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_09_FLEXSPI1_A_DATA01 0x1D8 0x41C 0x558 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_09_ENET_1G_TX_DATA00 0x1D8 0x41C 0x0 0x2 0x0 +#define IOMUXC_GPIO_SD_B2_09_LPUART5_CTS_B 0x1D8 0x41C 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_09_GPT6_COMPARE2 0x1D8 0x41C 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_09_GPIO_MUX4_IO18 0x1D8 0x41C 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_09_LPSPI2_SOUT 0x1D8 0x41C 0x5EC 0x6 0x1 + +#define IOMUXC_GPIO_SD_B2_10_GPIO10_IO19 0x1DC 0x420 0x0 0xA 0x0 +#define IOMUXC_GPIO_SD_B2_10_USDHC2_DATA6 0x1DC 0x420 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_10_FLEXSPI1_A_DATA02 0x1DC 0x420 0x55C 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_10_ENET_1G_TX_EN 0x1DC 0x420 0x0 0x2 0x0 +#define IOMUXC_GPIO_SD_B2_10_LPUART5_RTS_B 0x1DC 0x420 0x0 0x3 0x0 +#define IOMUXC_GPIO_SD_B2_10_GPT6_COMPARE3 0x1DC 0x420 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_10_GPIO_MUX4_IO19 0x1DC 0x420 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_10_LPSPI2_SIN 0x1DC 0x420 0x5E8 0x6 0x1 + +#define IOMUXC_GPIO_SD_B2_11_USDHC2_DATA7 0x1E0 0x424 0x0 0x0 0x0 +#define IOMUXC_GPIO_SD_B2_11_FLEXSPI1_A_DATA03 0x1E0 0x424 0x560 0x1 0x1 +#define IOMUXC_GPIO_SD_B2_11_ENET_1G_TX_CLK_IO 0x1E0 0x424 0x4E8 0x2 0x1 +#define IOMUXC_GPIO_SD_B2_11_ENET_1G_REF_CLK 0x1E0 0x424 0x4C4 0x3 0x1 +#define IOMUXC_GPIO_SD_B2_11_GPT6_CLK 0x1E0 0x424 0x0 0x4 0x0 +#define IOMUXC_GPIO_SD_B2_11_GPIO_MUX4_IO20 0x1E0 0x424 0x0 0x5 0x0 +#define IOMUXC_GPIO_SD_B2_11_LPSPI2_PCS1 0x1E0 0x424 0x5E0 0x6 0x1 +#define IOMUXC_GPIO_SD_B2_11_GPIO10_IO20 0x1E0 0x424 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_00_VIDEO_MUX_LCDIF_CLK 0x1E4 0x428 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_00_ENET_1G_RX_EN 0x1E4 0x428 0x4E0 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_00_TMR1_TIMER0 0x1E4 0x428 0x63C 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_00_XBAR1_INOUT26 0x1E4 0x428 0x6F0 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_00_GPIO_MUX4_IO21 0x1E4 0x428 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_00_ENET_QOS_RX_EN 0x1E4 0x428 0x4F8 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_00_GPIO10_IO21 0x1E4 0x428 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_01_VIDEO_MUX_LCDIF_ENABLE 0x1E8 0x42C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_01_ENET_1G_RX_CLK 0x1E8 0x42C 0x4CC 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_01_ENET_1G_RX_ER 0x1E8 0x42C 0x4E4 0x2 0x1 +#define IOMUXC_GPIO_DISP_B1_01_TMR1_TIMER1 0x1E8 0x42C 0x640 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_01_XBAR1_INOUT27 0x1E8 0x42C 0x6F4 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_01_GPIO_MUX4_IO22 0x1E8 0x42C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_01_ENET_QOS_RX_CLK 0x1E8 0x42C 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_01_ENET_QOS_RX_ER 0x1E8 0x42C 0x4FC 0x9 0x0 +#define IOMUXC_GPIO_DISP_B1_01_GPIO10_IO22 0x1E8 0x42C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_02_GPIO10_IO23 0x1EC 0x430 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B1_02_VIDEO_MUX_LCDIF_HSYNC 0x1EC 0x430 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_02_ENET_1G_RX_DATA00 0x1EC 0x430 0x4D0 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_02_LPI2C3_SCL 0x1EC 0x430 0x5BC 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_02_TMR1_TIMER2 0x1EC 0x430 0x644 0x3 0x1 +#define IOMUXC_GPIO_DISP_B1_02_XBAR1_INOUT28 0x1EC 0x430 0x6F8 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_02_GPIO_MUX4_IO23 0x1EC 0x430 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_02_ENET_QOS_RX_DATA00 0x1EC 0x430 0x4F0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_02_LPUART1_TXD 0x1EC 0x430 0x620 0x9 0x1 + +#define IOMUXC_GPIO_DISP_B1_03_VIDEO_MUX_LCDIF_VSYNC 0x1F0 0x434 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_03_ENET_1G_RX_DATA01 0x1F0 0x434 0x4D4 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_03_LPI2C3_SDA 0x1F0 0x434 0x5C0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_03_TMR2_TIMER0 0x1F0 0x434 0x648 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_03_XBAR1_INOUT29 0x1F0 0x434 0x6FC 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_03_GPIO_MUX4_IO24 0x1F0 0x434 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_03_ENET_QOS_RX_DATA01 0x1F0 0x434 0x4F4 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_03_LPUART1_RXD 0x1F0 0x434 0x61C 0x9 0x1 +#define IOMUXC_GPIO_DISP_B1_03_GPIO10_IO24 0x1F0 0x434 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_04_VIDEO_MUX_LCDIF_DATA00 0x1F4 0x438 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_04_ENET_1G_RX_DATA02 0x1F4 0x438 0x4D8 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_04_LPUART4_RXD 0x1F4 0x438 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_04_TMR2_TIMER1 0x1F4 0x438 0x64C 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_04_XBAR1_INOUT30 0x1F4 0x438 0x700 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_04_GPIO_MUX4_IO25 0x1F4 0x438 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_04_ENET_QOS_RX_DATA02 0x1F4 0x438 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_04_LPSPI3_SCK 0x1F4 0x438 0x600 0x9 0x1 +#define IOMUXC_GPIO_DISP_B1_04_GPIO10_IO25 0x1F4 0x438 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_05_GPIO10_IO26 0x1F8 0x43C 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B1_05_VIDEO_MUX_LCDIF_DATA01 0x1F8 0x43C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_05_ENET_1G_RX_DATA03 0x1F8 0x43C 0x4DC 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_05_LPUART4_CTS_B 0x1F8 0x43C 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_05_TMR2_TIMER2 0x1F8 0x43C 0x650 0x3 0x1 +#define IOMUXC_GPIO_DISP_B1_05_XBAR1_INOUT31 0x1F8 0x43C 0x704 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_05_GPIO_MUX4_IO26 0x1F8 0x43C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_05_ENET_QOS_RX_DATA03 0x1F8 0x43C 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_05_LPSPI3_SIN 0x1F8 0x43C 0x604 0x9 0x1 + +#define IOMUXC_GPIO_DISP_B1_06_VIDEO_MUX_LCDIF_DATA02 0x1FC 0x440 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_06_ENET_1G_TX_DATA03 0x1FC 0x440 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B1_06_LPUART4_TXD 0x1FC 0x440 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_06_TMR3_TIMER0 0x1FC 0x440 0x654 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_06_XBAR1_INOUT32 0x1FC 0x440 0x708 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_06_GPIO_MUX4_IO27 0x1FC 0x440 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_06_SRC_BT_CFG00 0x1FC 0x440 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B1_06_ENET_QOS_TX_DATA03 0x1FC 0x440 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_06_LPSPI3_SOUT 0x1FC 0x440 0x608 0x9 0x1 +#define IOMUXC_GPIO_DISP_B1_06_GPIO10_IO27 0x1FC 0x440 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_07_VIDEO_MUX_LCDIF_DATA03 0x200 0x444 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_07_ENET_1G_TX_DATA02 0x200 0x444 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B1_07_LPUART4_RTS_B 0x200 0x444 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_07_TMR3_TIMER1 0x200 0x444 0x658 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_07_XBAR1_INOUT33 0x200 0x444 0x70C 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_07_GPIO_MUX4_IO28 0x200 0x444 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_07_SRC_BT_CFG01 0x200 0x444 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B1_07_ENET_QOS_TX_DATA02 0x200 0x444 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_07_LPSPI3_PCS0 0x200 0x444 0x5F0 0x9 0x1 +#define IOMUXC_GPIO_DISP_B1_07_GPIO10_IO28 0x200 0x444 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_08_GPIO10_IO29 0x204 0x448 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B1_08_VIDEO_MUX_LCDIF_DATA04 0x204 0x448 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_08_ENET_1G_TX_DATA01 0x204 0x448 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B1_08_USDHC1_CD_B 0x204 0x448 0x6C8 0x2 0x1 +#define IOMUXC_GPIO_DISP_B1_08_TMR3_TIMER2 0x204 0x448 0x65C 0x3 0x1 +#define IOMUXC_GPIO_DISP_B1_08_XBAR1_INOUT34 0x204 0x448 0x710 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_08_GPIO_MUX4_IO29 0x204 0x448 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_08_SRC_BT_CFG02 0x204 0x448 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B1_08_ENET_QOS_TX_DATA01 0x204 0x448 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_08_LPSPI3_PCS1 0x204 0x448 0x5F4 0x9 0x1 + +#define IOMUXC_GPIO_DISP_B1_09_VIDEO_MUX_LCDIF_DATA05 0x208 0x44C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_09_ENET_1G_TX_DATA00 0x208 0x44C 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B1_09_USDHC1_WP 0x208 0x44C 0x6CC 0x2 0x1 +#define IOMUXC_GPIO_DISP_B1_09_TMR4_TIMER0 0x208 0x44C 0x660 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_09_XBAR1_INOUT35 0x208 0x44C 0x714 0x4 0x1 +#define IOMUXC_GPIO_DISP_B1_09_GPIO_MUX4_IO30 0x208 0x44C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_09_SRC_BT_CFG03 0x208 0x44C 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B1_09_ENET_QOS_TX_DATA00 0x208 0x44C 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_09_LPSPI3_PCS2 0x208 0x44C 0x5F8 0x9 0x1 +#define IOMUXC_GPIO_DISP_B1_09_GPIO10_IO30 0x208 0x44C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_10_VIDEO_MUX_LCDIF_DATA06 0x20C 0x450 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_10_ENET_1G_TX_EN 0x20C 0x450 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B1_10_USDHC1_RESET_B 0x20C 0x450 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B1_10_TMR4_TIMER1 0x20C 0x450 0x664 0x3 0x2 +#define IOMUXC_GPIO_DISP_B1_10_XBAR1_INOUT36 0x20C 0x450 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B1_10_GPIO_MUX4_IO31 0x20C 0x450 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_10_SRC_BT_CFG04 0x20C 0x450 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B1_10_ENET_QOS_TX_EN 0x20C 0x450 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_10_LPSPI3_PCS3 0x20C 0x450 0x5FC 0x9 0x1 +#define IOMUXC_GPIO_DISP_B1_10_GPIO10_IO31 0x20C 0x450 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B1_11_VIDEO_MUX_LCDIF_DATA07 0x210 0x454 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B1_11_ENET_1G_TX_CLK_IO 0x210 0x454 0x4E8 0x1 0x2 +#define IOMUXC_GPIO_DISP_B1_11_ENET_1G_REF_CLK 0x210 0x454 0x4C4 0x2 0x2 +#define IOMUXC_GPIO_DISP_B1_11_TMR4_TIMER2 0x210 0x454 0x668 0x3 0x1 +#define IOMUXC_GPIO_DISP_B1_11_XBAR1_INOUT37 0x210 0x454 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B1_11_GPIO_MUX5_IO00 0x210 0x454 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B1_11_SRC_BT_CFG05 0x210 0x454 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B1_11_ENET_QOS_TX_CLK 0x210 0x454 0x4A4 0x8 0x0 +#define IOMUXC_GPIO_DISP_B1_11_ENET_QOS_REF_CLK 0x210 0x454 0x4A0 0x9 0x2 +#define IOMUXC_GPIO_DISP_B1_11_GPIO11_IO00 0x210 0x454 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B2_00_GPIO11_IO01 0x214 0x458 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_00_VIDEO_MUX_LCDIF_DATA08 0x214 0x458 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_00_WDOG1_B 0x214 0x458 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_00_MQS_RIGHT 0x214 0x458 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_00_ENET_1G_TX_ER 0x214 0x458 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_00_SAI1_TX_DATA03 0x214 0x458 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_00_GPIO_MUX5_IO01 0x214 0x458 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_00_SRC_BT_CFG06 0x214 0x458 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_00_ENET_QOS_TX_ER 0x214 0x458 0x0 0x8 0x0 + +#define IOMUXC_GPIO_DISP_B2_01_VIDEO_MUX_LCDIF_DATA09 0x218 0x45C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_01_USDHC1_VSELECT 0x218 0x45C 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_01_MQS_LEFT 0x218 0x45C 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_01_WDOG2_B 0x218 0x45C 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_01_SAI1_TX_DATA02 0x218 0x45C 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_01_GPIO_MUX5_IO02 0x218 0x45C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_01_SRC_BT_CFG07 0x218 0x45C 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_01_EWM_OUT_B 0x218 0x45C 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_01_CCM_ENET_REF_CLK_25M 0x218 0x45C 0x0 0x9 0x0 +#define IOMUXC_GPIO_DISP_B2_01_GPIO11_IO02 0x218 0x45C 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B2_02_GPIO11_IO03 0x21C 0x460 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_02_VIDEO_MUX_LCDIF_DATA10 0x21C 0x460 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_02_ENET_TX_DATA00 0x21C 0x460 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_02_PIT1_TRIGGER3 0x21C 0x460 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_02_ARM_TRACE00 0x21C 0x460 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_02_SAI1_TX_DATA01 0x21C 0x460 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_02_GPIO_MUX5_IO03 0x21C 0x460 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_02_SRC_BT_CFG08 0x21C 0x460 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_02_ENET_QOS_TX_DATA00 0x21C 0x460 0x0 0x8 0x0 + +#define IOMUXC_GPIO_DISP_B2_03_GPIO11_IO04 0x220 0x464 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_03_VIDEO_MUX_LCDIF_DATA11 0x220 0x464 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_03_ENET_TX_DATA01 0x220 0x464 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_03_PIT1_TRIGGER2 0x220 0x464 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_03_ARM_TRACE01 0x220 0x464 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_03_SAI1_MCLK 0x220 0x464 0x66C 0x4 0x1 +#define IOMUXC_GPIO_DISP_B2_03_GPIO_MUX5_IO04 0x220 0x464 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_03_SRC_BT_CFG09 0x220 0x464 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_03_ENET_QOS_TX_DATA01 0x220 0x464 0x0 0x8 0x0 + +#define IOMUXC_GPIO_DISP_B2_04_VIDEO_MUX_LCDIF_DATA12 0x224 0x468 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_04_ENET_TX_EN 0x224 0x468 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_04_PIT1_TRIGGER1 0x224 0x468 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_04_ARM_TRACE02 0x224 0x468 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_04_SAI1_RX_SYNC 0x224 0x468 0x678 0x4 0x1 +#define IOMUXC_GPIO_DISP_B2_04_GPIO_MUX5_IO05 0x224 0x468 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_04_SRC_BT_CFG10 0x224 0x468 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_04_ENET_QOS_TX_EN 0x224 0x468 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_04_GPIO11_IO05 0x224 0x468 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B2_05_GPIO11_IO06 0x228 0x46C 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_05_VIDEO_MUX_LCDIF_DATA13 0x228 0x46C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_05_ENET_TX_CLK 0x228 0x46C 0x4C0 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_05_ENET_REF_CLK 0x228 0x46C 0x4A8 0x2 0x1 +#define IOMUXC_GPIO_DISP_B2_05_ARM_TRACE03 0x228 0x46C 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_05_SAI1_RX_BCLK 0x228 0x46C 0x670 0x4 0x1 +#define IOMUXC_GPIO_DISP_B2_05_GPIO_MUX5_IO06 0x228 0x46C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_05_SRC_BT_CFG11 0x228 0x46C 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_05_ENET_QOS_TX_CLK 0x228 0x46C 0x4A4 0x8 0x1 + +#define IOMUXC_GPIO_DISP_B2_06_GPIO11_IO07 0x22C 0x470 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_06_VIDEO_MUX_LCDIF_DATA14 0x22C 0x470 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_06_ENET_RX_DATA00 0x22C 0x470 0x4B0 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_06_LPUART7_TXD 0x22C 0x470 0x630 0x2 0x1 +#define IOMUXC_GPIO_DISP_B2_06_ARM_TRACE_CLK 0x22C 0x470 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_06_SAI1_RX_DATA00 0x22C 0x470 0x674 0x4 0x1 +#define IOMUXC_GPIO_DISP_B2_06_GPIO_MUX5_IO07 0x22C 0x470 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_06_ENET_QOS_RX_DATA00 0x22C 0x470 0x4F0 0x8 0x1 + +#define IOMUXC_GPIO_DISP_B2_07_VIDEO_MUX_LCDIF_DATA15 0x230 0x474 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_07_ENET_RX_DATA01 0x230 0x474 0x4B4 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_07_LPUART7_RXD 0x230 0x474 0x62C 0x2 0x1 +#define IOMUXC_GPIO_DISP_B2_07_ARM_TRACE_SWO 0x230 0x474 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_07_SAI1_TX_DATA00 0x230 0x474 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_07_GPIO_MUX5_IO08 0x230 0x474 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_07_ENET_QOS_RX_DATA01 0x230 0x474 0x4F4 0x8 0x1 +#define IOMUXC_GPIO_DISP_B2_07_GPIO11_IO08 0x230 0x474 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B2_08_GPIO11_IO09 0x234 0x478 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_08_VIDEO_MUX_LCDIF_DATA16 0x234 0x478 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_08_ENET_RX_EN 0x234 0x478 0x4B8 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_08_LPUART8_TXD 0x234 0x478 0x638 0x2 0x1 +#define IOMUXC_GPIO_DISP_B2_08_ARM_CM7_EVENTO 0x234 0x478 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_08_SAI1_TX_BCLK 0x234 0x478 0x67C 0x4 0x1 +#define IOMUXC_GPIO_DISP_B2_08_GPIO_MUX5_IO09 0x234 0x478 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_08_ENET_QOS_RX_EN 0x234 0x478 0x4F8 0x8 0x1 +#define IOMUXC_GPIO_DISP_B2_08_LPUART1_TXD 0x234 0x478 0x620 0x9 0x2 + +#define IOMUXC_GPIO_DISP_B2_09_GPIO11_IO10 0x238 0x47C 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_09_VIDEO_MUX_LCDIF_DATA17 0x238 0x47C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_09_ENET_RX_ER 0x238 0x47C 0x4BC 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_09_LPUART8_RXD 0x238 0x47C 0x634 0x2 0x1 +#define IOMUXC_GPIO_DISP_B2_09_ARM_CM7_EVENTI 0x238 0x47C 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_09_SAI1_TX_SYNC 0x238 0x47C 0x680 0x4 0x1 +#define IOMUXC_GPIO_DISP_B2_09_GPIO_MUX5_IO10 0x238 0x47C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_09_ENET_QOS_RX_ER 0x238 0x47C 0x4FC 0x8 0x1 +#define IOMUXC_GPIO_DISP_B2_09_LPUART1_RXD 0x238 0x47C 0x61C 0x9 0x2 + +#define IOMUXC_GPIO_DISP_B2_10_GPIO11_IO11 0x23C 0x480 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_10_VIDEO_MUX_LCDIF_DATA18 0x23C 0x480 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_10_EMVSIM2_IO 0x23C 0x480 0x6A8 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_10_LPUART2_TXD 0x23C 0x480 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_10_WDOG2_RESET_B_DEB 0x23C 0x480 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_10_XBAR1_INOUT38 0x23C 0x480 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_10_GPIO_MUX5_IO11 0x23C 0x480 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_10_LPI2C3_SCL 0x23C 0x480 0x5BC 0x6 0x1 +#define IOMUXC_GPIO_DISP_B2_10_ENET_QOS_RX_ER 0x23C 0x480 0x4FC 0x8 0x2 +#define IOMUXC_GPIO_DISP_B2_10_SPDIF_IN 0x23C 0x480 0x6B4 0x9 0x2 + +#define IOMUXC_GPIO_DISP_B2_11_VIDEO_MUX_LCDIF_DATA19 0x240 0x484 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_11_EMVSIM2_CLK 0x240 0x484 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_11_LPUART2_RXD 0x240 0x484 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_11_WDOG1_RESET_B_DEB 0x240 0x484 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_11_XBAR1_INOUT39 0x240 0x484 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_11_GPIO_MUX5_IO12 0x240 0x484 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_11_LPI2C3_SDA 0x240 0x484 0x5C0 0x6 0x1 +#define IOMUXC_GPIO_DISP_B2_11_ENET_QOS_CRS 0x240 0x484 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_11_SPDIF_OUT 0x240 0x484 0x0 0x9 0x0 +#define IOMUXC_GPIO_DISP_B2_11_GPIO11_IO12 0x240 0x484 0x0 0xA 0x0 + +#define IOMUXC_GPIO_DISP_B2_12_GPIO11_IO13 0x244 0x488 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_12_VIDEO_MUX_LCDIF_DATA20 0x244 0x488 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_12_EMVSIM2_RST 0x244 0x488 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_12_FLEXCAN1_TX 0x244 0x488 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_12_LPUART2_CTS_B 0x244 0x488 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_12_XBAR1_INOUT40 0x244 0x488 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_12_GPIO_MUX5_IO13 0x244 0x488 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_12_LPI2C4_SCL 0x244 0x488 0x5C4 0x6 0x1 +#define IOMUXC_GPIO_DISP_B2_12_ENET_QOS_COL 0x244 0x488 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_12_LPSPI4_SCK 0x244 0x488 0x610 0x9 0x1 + +#define IOMUXC_GPIO_DISP_B2_13_GPIO11_IO14 0x248 0x48C 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_13_VIDEO_MUX_LCDIF_DATA21 0x248 0x48C 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_13_EMVSIM2_SVEN 0x248 0x48C 0x0 0x1 0x0 +#define IOMUXC_GPIO_DISP_B2_13_FLEXCAN1_RX 0x248 0x48C 0x498 0x2 0x1 +#define IOMUXC_GPIO_DISP_B2_13_LPUART2_RTS_B 0x248 0x48C 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_13_ENET_REF_CLK 0x248 0x48C 0x4A8 0x4 0x2 +#define IOMUXC_GPIO_DISP_B2_13_GPIO_MUX5_IO14 0x248 0x48C 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_13_LPI2C4_SDA 0x248 0x48C 0x5C8 0x6 0x1 +#define IOMUXC_GPIO_DISP_B2_13_ENET_QOS_1588_EVENT0_OUT 0x248 0x48C 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_13_LPSPI4_SIN 0x248 0x48C 0x614 0x9 0x1 + +#define IOMUXC_GPIO_DISP_B2_14_GPIO_MUX5_IO15 0x24C 0x490 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_14_FLEXCAN1_TX 0x24C 0x490 0x0 0x6 0x0 +#define IOMUXC_GPIO_DISP_B2_14_ENET_QOS_1588_EVENT0_IN 0x24C 0x490 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_14_LPSPI4_SOUT 0x24C 0x490 0x618 0x9 0x1 +#define IOMUXC_GPIO_DISP_B2_14_GPIO11_IO15 0x24C 0x490 0x0 0xA 0x0 +#define IOMUXC_GPIO_DISP_B2_14_VIDEO_MUX_LCDIF_DATA22 0x24C 0x490 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_14_EMVSIM2_PD 0x24C 0x490 0x6AC 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_14_WDOG2_B 0x24C 0x490 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_14_VIDEO_MUX_EXT_DCIC1 0x24C 0x490 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_14_ENET_1G_REF_CLK 0x24C 0x490 0x4C4 0x4 0x3 + +#define IOMUXC_GPIO_DISP_B2_15_VIDEO_MUX_LCDIF_DATA23 0x250 0x494 0x0 0x0 0x0 +#define IOMUXC_GPIO_DISP_B2_15_EMVSIM2_POWER_FAIL 0x250 0x494 0x6B0 0x1 0x1 +#define IOMUXC_GPIO_DISP_B2_15_WDOG1_B 0x250 0x494 0x0 0x2 0x0 +#define IOMUXC_GPIO_DISP_B2_15_VIDEO_MUX_EXT_DCIC2 0x250 0x494 0x0 0x3 0x0 +#define IOMUXC_GPIO_DISP_B2_15_PIT1_TRIGGER0 0x250 0x494 0x0 0x4 0x0 +#define IOMUXC_GPIO_DISP_B2_15_GPIO_MUX5_IO16 0x250 0x494 0x0 0x5 0x0 +#define IOMUXC_GPIO_DISP_B2_15_FLEXCAN1_RX 0x250 0x494 0x498 0x6 0x2 +#define IOMUXC_GPIO_DISP_B2_15_ENET_QOS_1588_EVENT0_AUX_IN 0x250 0x494 0x0 0x8 0x0 +#define IOMUXC_GPIO_DISP_B2_15_LPSPI4_PCS0 0x250 0x494 0x60C 0x9 0x1 +#define IOMUXC_GPIO_DISP_B2_15_GPIO11_IO16 0x250 0x494 0x0 0xA 0x0 + +#endif /* _DT_BINDINGS_PINCTRL_IMXRT1170_PINFUNC_H */
Add binding header for i.MXRT1170 pinctrl device tree. Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
Best regards, Stefano Babic
Add the clock binding doc for i.MXRT1170.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Nothing done V2 -> V3: * Nothing done --- include/dt-bindings/clock/imxrt1170-clock.h | 48 +++++++++++++++++++++ 1 file changed, 48 insertions(+) create mode 100644 include/dt-bindings/clock/imxrt1170-clock.h
diff --git a/include/dt-bindings/clock/imxrt1170-clock.h b/include/dt-bindings/clock/imxrt1170-clock.h new file mode 100644 index 0000000000..8ab8018a15 --- /dev/null +++ b/include/dt-bindings/clock/imxrt1170-clock.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + */ + +#ifndef __DT_BINDINGS_CLOCK_IMXRT1170_H +#define __DT_BINDINGS_CLOCK_IMXRT1170_H + +#define IMXRT1170_CLK_DUMMY 0 +#define IMXRT1170_CLK_OSC 1 +#define IMXRT1170_CLK_OSC_32K 2 +#define IMXRT1170_CLK_RCOSC_16M 3 +#define IMXRT1170_CLK_RCOSC_48M 4 +#define IMXRT1170_CLK_RCOSC_48M_DIV2 5 +#define IMXRT1170_CLK_RCOSC_400M 6 +#define IMXRT1170_CLK_PLL_ARM 7 +#define IMXRT1170_CLK_PLL_AUDIO 8 +#define IMXRT1170_CLK_PLL_VIDEO 9 +#define IMXRT1170_CLK_PLL1 10 +#define IMXRT1170_CLK_PLL1_DIV2 11 +#define IMXRT1170_CLK_PLL1_DIV5 12 +#define IMXRT1170_CLK_PLL2 13 +#define IMXRT1170_CLK_PLL2_PFD0 14 +#define IMXRT1170_CLK_PLL2_PFD1 15 +#define IMXRT1170_CLK_PLL2_PFD2 16 +#define IMXRT1170_CLK_PLL2_PFD3 17 +#define IMXRT1170_CLK_PLL3 18 +#define IMXRT1170_CLK_PLL3_DIV2 19 +#define IMXRT1170_CLK_PLL3_PFD0 20 +#define IMXRT1170_CLK_PLL3_PFD1 21 +#define IMXRT1170_CLK_PLL3_PFD2 22 +#define IMXRT1170_CLK_PLL3_PFD3 23 +#define IMXRT1170_CLK_M7 24 +#define IMXRT1170_CLK_M4 25 +#define IMXRT1170_CLK_BUS 26 +#define IMXRT1170_CLK_BUS_LPSR 27 +#define IMXRT1170_CLK_LPUART1_SEL 28 +#define IMXRT1170_CLK_LPUART1 29 +#define IMXRT1170_CLK_USDHC1_SEL 30 +#define IMXRT1170_CLK_USDHC1 31 +#define IMXRT1170_CLK_GPT1_SEL 32 +#define IMXRT1170_CLK_GPT1 33 +#define IMXRT1170_CLK_SEMC_SEL 34 +#define IMXRT1170_CLK_SEMC 35 +#define IMXRT1170_CLK_END 36 + +#endif /* __DT_BINDINGS_CLOCK_IMXRT1170_H */
Add the clock binding doc for i.MXRT1170. Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
The i.MXRT11 series has two new pll types but are variants of existing. This patch adds the ability to read one of the pll types' frequency as it can't be changed unlike the generic pll it also has the division factors swapped.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Change BM_PLL_POWER and BM_PLL_LOCK bit to variable * Use different lock and power bit for new pll V2 -> V3: * Nothing done --- drivers/clk/imx/clk-pllv3.c | 56 +++++++++++++++++++++++++++++++++++-- drivers/clk/imx/clk.h | 1 + 2 files changed, 54 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/imx/clk-pllv3.c b/drivers/clk/imx/clk-pllv3.c index 077757efcb..fad306aeed 100644 --- a/drivers/clk/imx/clk-pllv3.c +++ b/drivers/clk/imx/clk-pllv3.c @@ -21,19 +21,23 @@ #define UBOOT_DM_CLK_IMX_PLLV3_USB "imx_clk_pllv3_usb" #define UBOOT_DM_CLK_IMX_PLLV3_AV "imx_clk_pllv3_av" #define UBOOT_DM_CLK_IMX_PLLV3_ENET "imx_clk_pllv3_enet" +#define UBOOT_DM_CLK_IMX_PLLV3_GENV2 "imx_clk_pllv3_genericv2"
#define PLL_NUM_OFFSET 0x10 #define PLL_DENOM_OFFSET 0x20
#define BM_PLL_POWER (0x1 << 12) +#define BM_PLL_POWER_V2 (0x1 << 21) #define BM_PLL_ENABLE (0x1 << 13) #define BM_PLL_LOCK (0x1 << 31) +#define BM_PLL_LOCK_V2 (0x1 << 29)
struct clk_pllv3 { struct clk clk; void __iomem *base; u32 power_bit; bool powerup_set; + u32 lock_bit; u32 enable_bit; u32 div_mask; u32 div_shift; @@ -42,6 +46,30 @@ struct clk_pllv3 {
#define to_clk_pllv3(_clk) container_of(_clk, struct clk_pllv3, clk)
+static ulong clk_pllv3_genericv2_get_rate(struct clk *clk) +{ + struct clk_pllv3 *pll = to_clk_pllv3(dev_get_clk_ptr(clk->dev)); + unsigned long parent_rate = clk_get_parent_rate(clk); + + u32 div = (readl(pll->base) >> pll->div_shift) & pll->div_mask; + + return (div == 0) ? parent_rate * 22 : parent_rate * 20; +} + +static ulong clk_pllv3_genericv2_set_rate(struct clk *clk, ulong rate) +{ + struct clk_pllv3 *pll = to_clk_pllv3(clk); + unsigned long parent_rate = clk_get_parent_rate(clk); + + u32 div = (readl(pll->base) >> pll->div_shift) & pll->div_mask; + u32 val = (div == 0) ? parent_rate * 22 : parent_rate * 20; + + if (rate == val) + return 0; + + return -EINVAL; +} + static ulong clk_pllv3_generic_get_rate(struct clk *clk) { struct clk_pllv3 *pll = to_clk_pllv3(dev_get_clk_ptr(clk->dev)); @@ -71,7 +99,7 @@ static ulong clk_pllv3_generic_set_rate(struct clk *clk, ulong rate) writel(val, pll->base);
/* Wait for PLL to lock */ - while (!(readl(pll->base) & BM_PLL_LOCK)) + while (!(readl(pll->base) & pll->lock_bit)) ;
return 0; @@ -120,6 +148,13 @@ static const struct clk_ops clk_pllv3_generic_ops = { .set_rate = clk_pllv3_generic_set_rate, };
+static const struct clk_ops clk_pllv3_genericv2_ops = { + .get_rate = clk_pllv3_genericv2_get_rate, + .enable = clk_pllv3_generic_enable, + .disable = clk_pllv3_generic_disable, + .set_rate = clk_pllv3_genericv2_set_rate, +}; + static ulong clk_pllv3_sys_get_rate(struct clk *clk) { struct clk_pllv3 *pll = to_clk_pllv3(clk); @@ -153,7 +188,7 @@ static ulong clk_pllv3_sys_set_rate(struct clk *clk, ulong rate) writel(val, pll->base);
return 0; @@ -221,7 +256,7 @@ static ulong clk_pllv3_av_set_rate(struct clk *clk, ulong rate) writel(mfd, pll->base + PLL_DENOM_OFFSET);
return 0; @@ -262,6 +297,7 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name,
pll->power_bit = BM_PLL_POWER; pll->enable_bit = BM_PLL_ENABLE; + pll->lock_bit = BM_PLL_LOCK;
switch (type) { case IMX_PLLV3_GENERIC: @@ -269,6 +305,13 @@ struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, pll->div_shift = 0; pll->powerup_set = false; break; + case IMX_PLLV3_GENERICV2: + pll->power_bit = BM_PLL_POWER_V2; + pll->lock_bit = BM_PLL_LOCK_V2; + drv_name = UBOOT_DM_CLK_IMX_PLLV3_GENV2; + pll->div_shift = 0; + pll->powerup_set = false; + break; case IMX_PLLV3_SYS: drv_name = UBOOT_DM_CLK_IMX_PLLV3_SYS; pll->div_shift = 0; @@ -313,6 +356,13 @@ U_BOOT_DRIVER(clk_pllv3_generic) = { .flags = DM_FLAG_PRE_RELOC, };
+U_BOOT_DRIVER(clk_pllv3_genericv2) = { + .name = UBOOT_DM_CLK_IMX_PLLV3_GENV2, + .id = UCLASS_CLK, + .ops = &clk_pllv3_genericv2_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + U_BOOT_DRIVER(clk_pllv3_sys) = { .name = UBOOT_DM_CLK_IMX_PLLV3_SYS, .id = UCLASS_CLK, diff --git a/drivers/clk/imx/clk.h b/drivers/clk/imx/clk.h index 0e1eaf03d4..46dee35a67 100644 --- a/drivers/clk/imx/clk.h +++ b/drivers/clk/imx/clk.h @@ -10,6 +10,7 @@
enum imx_pllv3_type { IMX_PLLV3_GENERIC, + IMX_PLLV3_GENERICV2, IMX_PLLV3_SYS, IMX_PLLV3_USB, IMX_PLLV3_USB_VF610,
The i.MXRT11 series has two new pll types but are variants of existing. This patch adds the ability to read one of the pll types' frequency as it can't be changed unlike the generic pll it also has the division factors swapped. Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
Add clock driver support for i.MXRT1170.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Use C file not dts for constant clock divider V2 -> V3: * Nothing done --- drivers/clk/imx/Kconfig | 16 +++ drivers/clk/imx/Makefile | 1 + drivers/clk/imx/clk-imxrt1170.c | 221 ++++++++++++++++++++++++++++++++ 3 files changed, 238 insertions(+) create mode 100644 drivers/clk/imx/clk-imxrt1170.c
diff --git a/drivers/clk/imx/Kconfig b/drivers/clk/imx/Kconfig index 04d252a1e0..abcb19ce6d 100644 --- a/drivers/clk/imx/Kconfig +++ b/drivers/clk/imx/Kconfig @@ -124,3 +124,19 @@ config CLK_IMXRT1050 select CLK_COMPOSITE_CCF help This enables support clock driver for i.MXRT1050 platforms. + +config SPL_CLK_IMXRT1170 + bool "SPL clock support for i.MXRT1170" + depends on ARCH_IMXRT && SPL + select SPL_CLK + select SPL_CLK_CCF + help + This enables SPL DM/DTS support for clock driver in i.MXRT1170. + +config CLK_IMXRT1170 + bool "Clock support for i.MXRT1170" + depends on ARCH_IMXRT + select CLK + select CLK_CCF + help + This enables support clock driver for i.MXRT1170 platforms. diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index c5766901f2..b9c197f952 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -21,3 +21,4 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MQ) += clk-imx8mq.o clk-pll14xx.o \
obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1020) += clk-imxrt1020.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1050) += clk-imxrt1050.o +obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1170) += clk-imxrt1170.o diff --git a/drivers/clk/imx/clk-imxrt1170.c b/drivers/clk/imx/clk-imxrt1170.c new file mode 100644 index 0000000000..077dd1bf02 --- /dev/null +++ b/drivers/clk/imx/clk-imxrt1170.c @@ -0,0 +1,221 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + */ + +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <dt-bindings/clock/imxrt1170-clock.h> + +#include "clk.h" + +static ulong imxrt1170_clk_get_rate(struct clk *clk) +{ + struct clk *c; + int ret; + + debug("%s(#%lu)\n", __func__, clk->id); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_get_rate(c); +} + +static ulong imxrt1170_clk_set_rate(struct clk *clk, ulong rate) +{ + struct clk *c; + int ret; + + debug("%s(#%lu), rate: %lu\n", __func__, clk->id, rate); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_set_rate(c, rate); +} + +static int __imxrt1170_clk_enable(struct clk *clk, bool enable) +{ + struct clk *c; + int ret; + + debug("%s(#%lu) en: %d\n", __func__, clk->id, enable); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + if (enable) + ret = clk_enable(c); + else + ret = clk_disable(c); + + return ret; +} + +static int imxrt1170_clk_disable(struct clk *clk) +{ + return __imxrt1170_clk_enable(clk, 0); +} + +static int imxrt1170_clk_enable(struct clk *clk) +{ + return __imxrt1170_clk_enable(clk, 1); +} + +static int imxrt1170_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct clk *c, *cp; + int ret; + + debug("%s(#%lu), parent: %lu\n", __func__, clk->id, parent->id); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + ret = clk_get_by_id(parent->id, &cp); + if (ret) + return ret; + + return clk_set_parent(c, cp); +} + +static struct clk_ops imxrt1170_clk_ops = { + .set_rate = imxrt1170_clk_set_rate, + .get_rate = imxrt1170_clk_get_rate, + .enable = imxrt1170_clk_enable, + .disable = imxrt1170_clk_disable, + .set_parent = imxrt1170_clk_set_parent, +}; + +static const char * const lpuart1_sels[] = {"rcosc48M_div2", "osc", "rcosc400M", "rcosc16M", +"pll3_div2", "pll1_div5", "pll2_sys", "pll2_pfd3"}; +static const char * const gpt1_sels[] = {"rcosc48M_div2", "osc", "rcosc400M", "rcosc16M", +"pll3_div2", "pll1_div5", "pll3_pfd2", "pll3_pfd3"}; +static const char * const usdhc1_sels[] = {"rcosc48M_div2", "osc", "rcosc400M", "rcosc16M", +"pll2_pfd2", "pll2_pfd0", "pll1_div5", "pll_arm"}; +static const char * const semc_sels[] = {"rcosc48M_div2", "osc", "rcosc400M", "rcosc16M", +"pll1_div5", "pll2_sys", "pll2_pfd2", "pll3_pfd0"}; + +static int imxrt1170_clk_probe(struct udevice *dev) +{ + void *base; + + /* Anatop clocks */ + base = (void *)ofnode_get_addr(ofnode_by_compatible(ofnode_null(), "fsl,imxrt-anatop")); + + + + clk_dm(IMXRT1170_CLK_RCOSC_48M, + imx_clk_fixed_factor("rcosc48M", "rcosc16M", 3, 1)); + clk_dm(IMXRT1170_CLK_RCOSC_400M, + imx_clk_fixed_factor("rcosc400M", "rcosc16M", 25, 1)); + clk_dm(IMXRT1170_CLK_RCOSC_48M_DIV2, + imx_clk_fixed_factor("rcosc48M_div2", "rcosc48M", 1, 2)); + + + clk_dm(IMXRT1170_CLK_PLL_ARM, + imx_clk_pllv3(IMX_PLLV3_SYS, "pll_arm", "osc", + base + 0x200, 0xff)); + clk_dm(IMXRT1170_CLK_PLL3, + imx_clk_pllv3(IMX_PLLV3_GENERICV2, "pll3_sys", "osc", + base + 0x210, 1)); + clk_dm(IMXRT1170_CLK_PLL2, + imx_clk_pllv3(IMX_PLLV3_GENERICV2, "pll2_sys", "osc", + base + 0x240, 1)); + + clk_dm(IMXRT1170_CLK_PLL3_PFD0, + imx_clk_pfd("pll3_pfd0", "pll3_sys", base + 0x230, 0)); + clk_dm(IMXRT1170_CLK_PLL3_PFD1, + imx_clk_pfd("pll3_pfd1", "pll3_sys", base + 0x230, 1)); + clk_dm(IMXRT1170_CLK_PLL3_PFD2, + imx_clk_pfd("pll3_pfd2", "pll3_sys", base + 0x230, 2)); + clk_dm(IMXRT1170_CLK_PLL3_PFD3, + imx_clk_pfd("pll3_pfd3", "pll3_sys", base + 0x230, 3)); + + clk_dm(IMXRT1170_CLK_PLL2_PFD0, + imx_clk_pfd("pll2_pfd0", "pll2_sys", base + 0x270, 0)); + clk_dm(IMXRT1170_CLK_PLL2_PFD1, + imx_clk_pfd("pll2_pfd1", "pll2_sys", base + 0x270, 1)); + clk_dm(IMXRT1170_CLK_PLL2_PFD2, + imx_clk_pfd("pll2_pfd2", "pll2_sys", base + 0x270, 2)); + clk_dm(IMXRT1170_CLK_PLL2_PFD3, + imx_clk_pfd("pll2_pfd3", "pll2_sys", base + 0x270, 3)); + + clk_dm(IMXRT1170_CLK_PLL3_DIV2, + imx_clk_fixed_factor("pll3_div2", "pll3_sys", 1, 2)); + + /* CCM clocks */ + base = dev_read_addr_ptr(dev); + if (base == (void *)FDT_ADDR_T_NONE) + return -EINVAL; + + clk_dm(IMXRT1170_CLK_LPUART1_SEL, + imx_clk_mux("lpuart1_sel", base + (25 * 0x80), 8, 3, + lpuart1_sels, ARRAY_SIZE(lpuart1_sels))); + clk_dm(IMXRT1170_CLK_LPUART1, + imx_clk_divider("lpuart1", "lpuart1_sel", + base + (25 * 0x80), 0, 8)); + + clk_dm(IMXRT1170_CLK_USDHC1_SEL, + imx_clk_mux("usdhc1_sel", base + (58 * 0x80), 8, 3, + usdhc1_sels, ARRAY_SIZE(usdhc1_sels))); + clk_dm(IMXRT1170_CLK_USDHC1, + imx_clk_divider("usdhc1", "usdhc1_sel", + base + (58 * 0x80), 0, 8)); + + clk_dm(IMXRT1170_CLK_GPT1_SEL, + imx_clk_mux("gpt1_sel", base + (14 * 0x80), 8, 3, + gpt1_sels, ARRAY_SIZE(gpt1_sels))); + clk_dm(IMXRT1170_CLK_GPT1, + imx_clk_divider("gpt1", "gpt1_sel", + base + (14 * 0x80), 0, 8)); + + clk_dm(IMXRT1170_CLK_SEMC_SEL, + imx_clk_mux("semc_sel", base + (4 * 0x80), 8, 3, + semc_sels, ARRAY_SIZE(semc_sels))); + clk_dm(IMXRT1170_CLK_SEMC, + imx_clk_divider("semc", "semc_sel", + base + (4 * 0x80), 0, 8)); + struct clk *clk, *clk1; + + clk_get_by_id(IMXRT1170_CLK_PLL2_PFD2, &clk); + + clk_get_by_id(IMXRT1170_CLK_SEMC_SEL, &clk1); + clk_enable(clk1); + clk_set_parent(clk1, clk); + + clk_get_by_id(IMXRT1170_CLK_SEMC, &clk); + clk_enable(clk); + clk_set_rate(clk, 132000000UL); + + clk_get_by_id(IMXRT1170_CLK_GPT1, &clk); + clk_enable(clk); + clk_set_rate(clk, 32000000UL); + + return 0; +} + +static const struct udevice_id imxrt1170_clk_ids[] = { + { .compatible = "fsl,imxrt1170-ccm" }, + { }, +}; + +U_BOOT_DRIVER(imxrt1170_clk) = { + .name = "clk_imxrt1170", + .id = UCLASS_CLK, + .of_match = imxrt1170_clk_ids, + .ops = &imxrt1170_clk_ops, + .probe = imxrt1170_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +};
Add clock driver support for i.MXRT1170. Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
The i.MXRT11 series has different offsets for IOCR_MUX, it also can address 64MiB of SDRAM so add a macro for that.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Nothing done V2 -> V3: * Nothing done --- drivers/ram/imxrt_sdram.c | 9 +++++++++ include/dt-bindings/memory/imxrt-sdram.h | 1 + 2 files changed, 10 insertions(+)
diff --git a/drivers/ram/imxrt_sdram.c b/drivers/ram/imxrt_sdram.c index ca2eec767d..d0a88845cf 100644 --- a/drivers/ram/imxrt_sdram.c +++ b/drivers/ram/imxrt_sdram.c @@ -87,12 +87,21 @@ struct imxrt_semc_regs { u32 sts[16]; };
+#if !defined(TARGET_IMXRT1170_EVK) #define SEMC_IOCR_MUX_A8_SHIFT 0 #define SEMC_IOCR_MUX_CSX0_SHIFT 3 #define SEMC_IOCR_MUX_CSX1_SHIFT 6 #define SEMC_IOCR_MUX_CSX2_SHIFT 9 #define SEMC_IOCR_MUX_CSX3_SHIFT 12 #define SEMC_IOCR_MUX_RDY_SHIFT 15 +#else +#define SEMC_IOCR_MUX_A8_SHIFT 0 +#define SEMC_IOCR_MUX_CSX0_SHIFT 4 +#define SEMC_IOCR_MUX_CSX1_SHIFT 8 +#define SEMC_IOCR_MUX_CSX2_SHIFT 12 +#define SEMC_IOCR_MUX_CSX3_SHIFT 16 +#define SEMC_IOCR_MUX_RDY_SHIFT 20 +#endif
struct imxrt_sdram_mux { u8 a8; diff --git a/include/dt-bindings/memory/imxrt-sdram.h b/include/dt-bindings/memory/imxrt-sdram.h index acb35bce27..4b3b0c2f50 100644 --- a/include/dt-bindings/memory/imxrt-sdram.h +++ b/include/dt-bindings/memory/imxrt-sdram.h @@ -82,6 +82,7 @@
#define MEM_WIDTH_8BITS 0x0 #define MEM_WIDTH_16BITS 0x1 +#define MEM_WIDTH_32BITS 0x2
#define BL_1 0x0 #define BL_2 0x1
The i.MXRT11 series has different offsets for IOCR_MUX, it also can address 64MiB of SDRAM so add a macro for that. Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
The NXP i.MXRT1170 Evaluation Kit (EVK) provides a platform for rapid evaluation of the i.MXRT, which features NXP's implementation of the Arm Cortex-M7 and Cortex-M4 core.
The EVK provides 64 MB SDRAM, Micro SD card socket, USB 2.0 OTG.
This patch aims to support the preliminary booting up features as follows: GPIO LPUART SD/MMC SDRAM
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Remove unused constant clocks V2 -> V3: * Nothing done --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/imxrt1170-evk-u-boot.dtsi | 94 +++++++++ arch/arm/dts/imxrt1170-evk.dts | 250 ++++++++++++++++++++++++ arch/arm/dts/imxrt1170.dtsi | 257 +++++++++++++++++++++++++ 4 files changed, 603 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imxrt1170-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imxrt1170-evk.dts create mode 100644 arch/arm/dts/imxrt1170.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7fa275ea7c..ccdf643c86 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -974,7 +974,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-kontron-pitx-imx8m.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ - imxrt1020-evk.dtb + imxrt1020-evk.dtb \ + imxrt1170-evk.dtb \
dtb-$(CONFIG_RCAR_GEN2) += \ r8a7790-lager-u-boot.dtb \ diff --git a/arch/arm/dts/imxrt1170-evk-u-boot.dtsi b/arch/arm/dts/imxrt1170-evk-u-boot.dtsi new file mode 100644 index 0000000000..88ff986ba0 --- /dev/null +++ b/arch/arm/dts/imxrt1170-evk-u-boot.dtsi @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + * Giulio Benetti giulio.benetti@benettiengineering.com + */ + +/ { + chosen { + u-boot,dm-spl; + }; + + clocks { + u-boot,dm-spl; + }; + + soc { + u-boot,dm-spl; + }; +}; + +&osc { + u-boot,dm-spl; +}; + +&rcosc16M { + u-boot,dm-spl; +}; + +&osc32k { + u-boot,dm-spl; +}; + +&clks { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&gpt1 { + u-boot,dm-spl; +}; + +&lpuart1 { /* console */ + u-boot,dm-spl; +}; + +&semc { + u-boot,dm-spl; + + bank1: bank@0 { + u-boot,dm-spl; + }; +}; + +&iomuxc { + u-boot,dm-spl; + + imxrt1170-evk { + u-boot,dm-spl; + pinctrl_lpuart1: lpuart1grp { + u-boot,dm-spl; + }; + + pinctrl_usdhc0: usdhc0grp { + u-boot,dm-spl; + }; + pinctrl_semc: semcgrp { + u-boot,dm-spl; + }; + }; +}; + +&usdhc1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imxrt1170-evk.dts b/arch/arm/dts/imxrt1170-evk.dts new file mode 100644 index 0000000000..c2fd0c0392 --- /dev/null +++ b/arch/arm/dts/imxrt1170-evk.dts @@ -0,0 +1,250 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + * Giulio Benetti giulio.benetti@benettiengineering.com + */ + +/dts-v1/; +#include "imxrt1170.dtsi" +#include "imxrt1170-evk-u-boot.dtsi" +#include "imxrt1170-pinfunc.h" + +/ { + model = "NXP imxrt1170-evk board"; + compatible = "fsl,imxrt1170-evk", "fsl,imxrt1170"; + + chosen { + stdout-path = "serial0:115200n8"; + tick-timer = &gpt1; + }; + + memory { + device_type = "memory"; + reg = <0x20240000 0xf0000 0x80000000 0x4000000>; + + ocram: ocram@20240000 { + device_type = "memory"; + reg = <0x20240000 0xf0000>; + }; + + sdram: sdram@80000000 { + device_type = "memory"; + reg = <0x80000000 0x4000000>; + }; + }; +}; + +&lpuart1 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + status = "okay"; +}; + +&semc { + /* + * Memory configuration from sdram datasheet IS42S16160J-6BLI + */ + fsl,sdram-mux = /bits/ 8 <MUX_A8_SDRAM_A8 + 0 + 0 + 0 + 0 + 0>; + fsl,sdram-control = /bits/ 8 <MEM_WIDTH_32BITS + BL_8 + COL_9BITS + CL_3>; + fsl,sdram-timing = /bits/ 8 <0x2 + 0x2 + 0xd + 0x0 + 0x8 + 0x7 + + 0x0d + 0x0b + 0x00 + 0x00 + + 0x00 + 0x0A + 0x08 + 0x09>; + + bank1: bank@0 { + fsl,base-address = <0x80000000>; + fsl,memory-size = <MEM_SIZE_64M>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + + imxrt1170-evk { + pinctrl_lpuart1: lpuart1grp { + fsl,pins = < + IOMUXC_GPIO_AD_24_LPUART1_TXD 0xf1 + IOMUXC_GPIO_AD_25_LPUART1_RXD 0xf1 + >; + }; + + pinctrl_usdhc0: usdhc0grp { + fsl,pins = < + IOMUXC_GPIO_AD_32_USDHC1_CD_B + 0x1B000 + IOMUXC_GPIO_AD_34_USDHC1_VSELECT + 0xB069 + IOMUXC_GPIO_SD_B1_00_USDHC1_CMD + 0x17061 + IOMUXC_GPIO_SD_B1_01_USDHC1_CLK + 0x17061 + IOMUXC_GPIO_SD_B1_05_USDHC1_DATA3 + 0x17061 + IOMUXC_GPIO_SD_B1_04_USDHC1_DATA2 + 0x17061 + IOMUXC_GPIO_SD_B1_03_USDHC1_DATA1 + 0x17061 + IOMUXC_GPIO_SD_B1_02_USDHC1_DATA0 + 0x17061 + >; + }; + pinctrl_semc: semcgrp { + fsl,pins = < + IOMUXC_GPIO_EMC_B1_00_SEMC_DATA00 + 8 /* SEMC_D0 */ + IOMUXC_GPIO_EMC_B1_01_SEMC_DATA01 + 8 /* SEMC_D1 */ + IOMUXC_GPIO_EMC_B1_02_SEMC_DATA02 + 8 /* SEMC_D2 */ + IOMUXC_GPIO_EMC_B1_03_SEMC_DATA03 + 8 /* SEMC_D3 */ + IOMUXC_GPIO_EMC_B1_04_SEMC_DATA04 + 8 /* SEMC_D4 */ + IOMUXC_GPIO_EMC_B1_05_SEMC_DATA05 + 8 /* SEMC_D5 */ + IOMUXC_GPIO_EMC_B1_06_SEMC_DATA06 + 8 /* SEMC_D6 */ + IOMUXC_GPIO_EMC_B1_07_SEMC_DATA07 + 8 /* SEMC_D7 */ + IOMUXC_GPIO_EMC_B1_08_SEMC_DM00 + 8 /* SEMC_DM0 */ + IOMUXC_GPIO_EMC_B1_09_SEMC_ADDR00 + 8 /* SEMC_A0 */ + IOMUXC_GPIO_EMC_B1_10_SEMC_ADDR01 + 8 /* SEMC_A1 */ + IOMUXC_GPIO_EMC_B1_11_SEMC_ADDR02 + 8 /* SEMC_A2 */ + IOMUXC_GPIO_EMC_B1_12_SEMC_ADDR03 + 8 /* SEMC_A3 */ + IOMUXC_GPIO_EMC_B1_13_SEMC_ADDR04 + 8 /* SEMC_A4 */ + IOMUXC_GPIO_EMC_B1_14_SEMC_ADDR05 + 8 /* SEMC_A5 */ + IOMUXC_GPIO_EMC_B1_15_SEMC_ADDR06 + 8 /* SEMC_A6 */ + IOMUXC_GPIO_EMC_B1_16_SEMC_ADDR07 + 8 /* SEMC_A7 */ + IOMUXC_GPIO_EMC_B1_17_SEMC_ADDR08 + 8 /* SEMC_A8 */ + IOMUXC_GPIO_EMC_B1_18_SEMC_ADDR09 + 8 /* SEMC_A9 */ + IOMUXC_GPIO_EMC_B1_19_SEMC_ADDR11 + 8 /* SEMC_A11 */ + IOMUXC_GPIO_EMC_B1_20_SEMC_ADDR12 + 8 /* SEMC_A12 */ + IOMUXC_GPIO_EMC_B1_21_SEMC_BA0 + 8 /* SEMC_BA0 */ + IOMUXC_GPIO_EMC_B1_22_SEMC_BA1 + 8 /* SEMC_BA1 */ + IOMUXC_GPIO_EMC_B1_23_SEMC_ADDR10 + 8 /* SEMC_A10 */ + IOMUXC_GPIO_EMC_B1_24_SEMC_CAS + 8 /* SEMC_CAS */ + IOMUXC_GPIO_EMC_B1_25_SEMC_RAS + 8 /* SEMC_RAS */ + IOMUXC_GPIO_EMC_B1_26_SEMC_CLK + 8 /* SEMC_CLK */ + IOMUXC_GPIO_EMC_B1_27_SEMC_CKE + 8 /* SEMC_CKE */ + IOMUXC_GPIO_EMC_B1_28_SEMC_WE + 8 /* SEMC_WE */ + IOMUXC_GPIO_EMC_B1_29_SEMC_CS0 + 8 /* SEMC_CS0 */ + IOMUXC_GPIO_EMC_B1_30_SEMC_DATA08 + 8 /* SEMC_D8 */ + IOMUXC_GPIO_EMC_B1_31_SEMC_DATA09 + 8 /* SEMC_D9 */ + IOMUXC_GPIO_EMC_B1_32_SEMC_DATA10 + 8 /* SEMC_D10 */ + IOMUXC_GPIO_EMC_B1_33_SEMC_DATA11 + 8 /* SEMC_D11 */ + IOMUXC_GPIO_EMC_B1_34_SEMC_DATA12 + 8 /* SEMC_D12 */ + IOMUXC_GPIO_EMC_B1_35_SEMC_DATA13 + 8 /* SEMC_D13 */ + IOMUXC_GPIO_EMC_B1_36_SEMC_DATA14 + 8 /* SEMC_D14 */ + IOMUXC_GPIO_EMC_B1_37_SEMC_DATA15 + 8 /* SEMC_D15 */ + IOMUXC_GPIO_EMC_B1_08_SEMC_DM00 + 8 /* SEMC_DM00 */ + IOMUXC_GPIO_EMC_B1_38_SEMC_DM01 + 8 /* SEMC_DM01 */ + IOMUXC_GPIO_EMC_B2_08_SEMC_DM02 + 4 /* SEMC_DM02 */ + IOMUXC_GPIO_EMC_B2_17_SEMC_DM03 + 8 /* SEMC_DM03 */ + IOMUXC_GPIO_EMC_B2_00_SEMC_DATA16 + 8 /* SEMC_D16 */ + IOMUXC_GPIO_EMC_B2_01_SEMC_DATA17 + 8 /* SEMC_D17 */ + IOMUXC_GPIO_EMC_B2_02_SEMC_DATA18 + 8 /* SEMC_D18 */ + IOMUXC_GPIO_EMC_B2_03_SEMC_DATA19 + 8 /* SEMC_D19 */ + IOMUXC_GPIO_EMC_B2_04_SEMC_DATA20 + 8 /* SEMC_D20 */ + IOMUXC_GPIO_EMC_B2_05_SEMC_DATA21 + 8 /* SEMC_D21 */ + IOMUXC_GPIO_EMC_B2_06_SEMC_DATA22 + 8 /* SEMC_D22 */ + IOMUXC_GPIO_EMC_B2_07_SEMC_DATA23 + 8 /* SEMC_D23 */ + IOMUXC_GPIO_EMC_B2_09_SEMC_DATA24 + 8 /* SEMC_D24 */ + IOMUXC_GPIO_EMC_B2_10_SEMC_DATA25 + 8 /* SEMC_D25 */ + IOMUXC_GPIO_EMC_B2_11_SEMC_DATA26 + 4 /* SEMC_D26 */ + IOMUXC_GPIO_EMC_B2_12_SEMC_DATA27 + 8 /* SEMC_D27 */ + IOMUXC_GPIO_EMC_B2_13_SEMC_DATA28 + 8 /* SEMC_D28 */ + IOMUXC_GPIO_EMC_B2_14_SEMC_DATA29 + 8 /* SEMC_D29 */ + IOMUXC_GPIO_EMC_B2_15_SEMC_DATA30 + 8 /* SEMC_D30 */ + IOMUXC_GPIO_EMC_B2_16_SEMC_DATA31 + 8 /* SEMC_D31 */ + IOMUXC_GPIO_EMC_B1_39_SEMC_DQS + (IMX_PAD_SION | 8) /* SEMC_DQS */ + >; + }; + }; +}; + +&gpt1 { + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; + pinctrl-0 = <&pinctrl_usdhc0>; + pinctrl-1 = <&pinctrl_usdhc0>; + pinctrl-2 = <&pinctrl_usdhc0>; + pinctrl-3 = <&pinctrl_usdhc0>; + status = "okay"; + broken-cd; +}; diff --git a/arch/arm/dts/imxrt1170.dtsi b/arch/arm/dts/imxrt1170.dtsi new file mode 100644 index 0000000000..2de775f043 --- /dev/null +++ b/arch/arm/dts/imxrt1170.dtsi @@ -0,0 +1,257 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + * Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include "armv7-m.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/imxrt1170-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/memory/imxrt-sdram.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + aliases { + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + gpio5 = &gpio6; + gpio6 = &gpio7; + gpio7 = &gpio8; + gpio8 = &gpio9; + gpio9 = &gpio10; + gpio10 = &gpio11; + gpio11 = &gpio12; + gpio12 = &gpio13; + mmc0 = &usdhc1; + serial0 = &lpuart1; + }; + + clocks { + osc: osc { + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + + rcosc16M: rcosc16M { + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <16000000>; + }; + + osc32k: osc32k { + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + + }; + + soc { + semc: semc@400d4000 { + compatible = "fsl,imxrt-semc"; + reg = <0x400d4000 0x4000>; + interrupts = <132>; + clocks = <&clks IMXRT1170_CLK_SEMC>; + pinctrl-0 = <&pinctrl_semc>; + pinctrl-names = "default"; + status = "okay"; + }; + + lpuart1: serial@4007c000 { + compatible = "fsl,imxrt-lpuart"; + reg = <0x4007c000 0x4000>; + interrupts = <20>; + clocks = <&clks IMXRT1170_CLK_LPUART1>; + clock-names = "per"; + status = "disabled"; + }; + + iomuxc: iomuxc@400e8000 { + compatible = "fsl,imxrt-iomuxc"; + reg = <0x400e8000 0x4000>; + fsl,mux_mask = <0x7>; + }; + + anatop: anatop@40c84000 { + compatible = "fsl,imxrt-anatop"; + reg = <0x40c84000 0x4000>; + }; + + clks: ccm@40cc0000 { + compatible = "fsl,imxrt1170-ccm"; + reg = <0x40cc0000 0x4000>; + #clock-cells = <1>; + }; + + usdhc1: usdhc@40418000 { + compatible = "fsl,imxrt-usdhc"; + reg = <0x40418000 0x10000>; + interrupts = <133>; + clocks = <&clks IMXRT1170_CLK_USDHC1>; + clock-names = "per"; + bus-width = <4>; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + status = "disabled"; + }; + + gpio1: gpio@4012c000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x4012c000 0x4000>; + interrupts = <100>, + <101>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@40130000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40130000 0x4000>; + interrupts = <102>, + <103>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@40134000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40134000 0x4000>; + interrupts = <104>, + <105>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@40138000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40138000 0x4000>; + interrupts = <106>, + <107>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio5: gpio@4013c000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x4013c000 0x4000>; + interrupts = <108>, + <109>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio6: gpio@40140000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40140000 0x4000>; + interrupts = <61>, + <62>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio7: gpio@40c5c000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40c5c000 0x4000>; + interrupts = <99>, + <99>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio8: gpio@40c60000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40c60000 0x4000>; + interrupts = <99>, + <99>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio9: gpio@40c64000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40c64000 0x4000>; + interrupts = <99>, + <99>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio10: gpio@40c68000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40c68000 0x4000>; + interrupts = <99>, + <99>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio11: gpio@40c6c000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40c6c000 0x4000>; + interrupts = <99>, + <99>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio12: gpio@40c70000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40c70000 0x4000>; + interrupts = <61>, + <62>; // only cm4 + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio13: gpio@40ca0000 { + compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + reg = <0x40ca0000 0x4000>; + interrupts = <93>, + <93>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpt1: gpt1@400ec000 { + compatible = "fsl,imxrt-gpt"; + reg = <0x400ec000 0x4000>; + interrupts = <119>; + clocks = <&clks IMXRT1170_CLK_GPT1>; + status = "disabled"; + }; + }; +};
The NXP i.MXRT1170 Evaluation Kit (EVK) provides a platform for rapid evaluation of the i.MXRT, which features NXP's implementation of the Arm Cortex-M7 and Cortex-M4 core. The EVK provides 64 MB SDRAM, Micro SD card socket, USB 2.0 OTG. This patch aims to support the preliminary booting up features as follows: GPIO LPUART SD/MMC SDRAM Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
Add a base defconfig for the i.MXRT1170
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1 -> V2: * Nothing done V2 -> V3: * Rebase --- configs/imxrt1170-evk_defconfig | 70 +++++++++++++++++++++++++++++++++ include/configs/imxrt1170-evk.h | 29 ++++++++++++++ 2 files changed, 99 insertions(+) create mode 100644 configs/imxrt1170-evk_defconfig create mode 100644 include/configs/imxrt1170-evk.h
diff --git a/configs/imxrt1170-evk_defconfig b/configs/imxrt1170-evk_defconfig new file mode 100644 index 0000000000..870ca115d5 --- /dev/null +++ b/configs/imxrt1170-evk_defconfig @@ -0,0 +1,70 @@ +CONFIG_ARM=y +CONFIG_SYS_DCACHE_OFF=y +# CONFIG_SPL_SYS_DCACHE_OFF is not set +CONFIG_ARCH_IMXRT=y +CONFIG_SYS_TEXT_BASE=0x20240000 +CONFIG_SYS_MALLOC_LEN=0x8000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_OFFSET=0x80000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imxrt1170-evk" +CONFIG_SPL_TEXT_BASE=0x202C0000 +CONFIG_TARGET_IMXRT1170_EVK=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_SIZE_LIMIT=0x20000 +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20340000 +CONFIG_SYS_LOAD_ADDR=0x202C0000 +CONFIG_SD_BOOT=y +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_NO_BSS_LIMIT=y +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 +# CONFIG_SPL_CRC32 is not set +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_MII is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_OF_TRANSLATE is not set +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMXRT1170=y +CONFIG_CLK_IMXRT1170=y +# CONFIG_SPL_DM_GPIO is not set +CONFIG_MXC_GPIO=y +# CONFIG_INPUT is not set +CONFIG_FSL_USDHC=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMXRT=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_IMXRT_SDRAM=y +CONFIG_FSL_LPUART=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_IMX_GPT_TIMER=y diff --git a/include/configs/imxrt1170-evk.h b/include/configs/imxrt1170-evk.h new file mode 100644 index 0000000000..2459fe24e2 --- /dev/null +++ b/include/configs/imxrt1170-evk.h @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 + * Author(s): Jesse Taube Mr.Bossman075@gmail.com + * Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef __IMXRT1170_EVK_H +#define __IMXRT1170_EVK_H + +#include <asm/arch/imx-regs.h> + +#define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE 1 + +/* + * Configuration of the external SDRAM memory + */ + +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE (64 * 1024 * 1024) + +#define DMAMEM_SZ_ALL (1 * 1024 * 1024) +#define DMAMEM_BASE (PHYS_SDRAM + PHYS_SDRAM_SIZE - \ + DMAMEM_SZ_ALL) +/* For SPL */ +#define CONFIG_SYS_UBOOT_START 0x202403FD +/* For SPL ends */ + +#endif /* __IMXRT1170_EVK_H */
Add a base defconfig for the i.MXRT1170 Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com
Jesse Taube
sbabic@denx.de
