[U-Boot] [PATCH V2] ARM: MX5: Fix broken leftover TO-2 errata workaround
This check was broken. r3 does not contain the silicon revision anymore, so we need to reload it. Also, this errata only applies to i.MX51.
Changed in this version: - Added #ifdef CONFIG_MX51 around the workaround
Signed-off-by: David Jander david@protonic.nl --- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/lowlevel_init.S b/arch/arm/cpu/armv7/mx5/lowlevel_init.S index ee4150d..6c66b42 100644 --- a/arch/arm/cpu/armv7/mx5/lowlevel_init.S +++ b/arch/arm/cpu/armv7/mx5/lowlevel_init.S @@ -39,10 +39,14 @@ orr r0, r0, #(1 << 23) /* disable write allocate combine */ orr r0, r0, #(1 << 22) /* disable write allocate */
- cmp r3, #0x10 /* r3 contains the silicon rev */ +#if defined(CONFIG_MX51) + ldr r1, =0x0 + ldr r3, [r1, #ROM_SI_REV] + cmp r3, #0x10
/* disable write combine for TO 2 and lower revs */ orrls r0, r0, #(1 << 25) +#endif
mcr 15, 1, r0, c9, c0, 2 .endm /* init_l2cc */
Acked-by : Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi David,
Please keep patch history below the commit message line '---' so that the history does not appear in the Git tree.
Signed-off-by: David Janderdavid@protonic.nl
Put history here.
(please post a V3 for fixing this, not an amended V2!)
Amicalement,
Albert ARIBAUD
David Jander
Stefano Babic
