[U-Boot] [PATCH 1/2] efi_loader: implement GetNextVariableName()
The current GetNextVariableName() is a placeholder. With this patch, it works well as expected.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_variable.c | 116 +++++++++++++++++++++++++++++++++- 1 file changed, 115 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index 19d9cb865f25..dac2f49aa1cc 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -8,6 +8,9 @@ #include <malloc.h> #include <charset.h> #include <efi_loader.h> +#include <environment.h> +#include <search.h> +#include <uuid.h>
#define READ_ONLY BIT(31)
@@ -241,14 +244,125 @@ efi_status_t EFIAPI efi_get_variable(u16 *variable_name, efi_guid_t *vendor, return EFI_EXIT(EFI_SUCCESS); }
+static char *efi_variables_list; +static char *efi_cur_variable; + +static efi_status_t parse_uboot_variable(char *variable, + efi_uintn_t *variable_name_size, + u16 *variable_name, + efi_guid_t *vendor, + u32 *attribute) +{ + char *guid, *name, *end, c; + unsigned long name_size; + u16 *p; + + guid = strchr(variable, '_'); + if (!guid) + return EFI_NOT_FOUND; + guid++; + name = strchr(guid, '_'); + if (!name) + return EFI_NOT_FOUND; + name++; + end = strchr(name, '='); + if (!end) + return EFI_NOT_FOUND; + + /* FIXME: size is in byte or u16? */ + name_size = end - name; + if (*variable_name_size < (name_size + 1)) { + *variable_name_size = name_size + 1; + return EFI_BUFFER_TOO_SMALL; + } + end++; /* point to value */ + + p = variable_name; + utf8_utf16_strncpy(&p, name, name_size); + variable_name[name_size] = 0; + + c = *(name - 1); + *(name - 1) = '\0'; /* guid need be null-terminated here */ + uuid_str_to_bin(guid, (unsigned char *)vendor, UUID_STR_FORMAT_GUID); + *(name - 1) = c; + + parse_attr(end, attribute); + + return EFI_SUCCESS; +} + /* http://wiki.phoenix.com/wiki/index.php/EFI_RUNTIME_SERVICES#GetNextVariableN... */ efi_status_t EFIAPI efi_get_next_variable_name(efi_uintn_t *variable_name_size, u16 *variable_name, efi_guid_t *vendor) { + char *native_name, *variable; + ssize_t name_len, list_len; + char regex[256]; + char * const regexlist[] = {regex}; + u32 attribute; + int i; + efi_status_t ret; + EFI_ENTRY("%p "%ls" %pUl", variable_name_size, variable_name, vendor);
- return EFI_EXIT(EFI_DEVICE_ERROR); + if (!variable_name_size || !variable_name || !vendor) + EFI_EXIT(EFI_INVALID_PARAMETER); + + if (variable_name[0]) { + /* check null-terminated string */ + for (i = 0; i < *variable_name_size; i++) + if (!variable_name[i]) + break; + if (i >= *variable_name_size) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* search for the last-returned variable */ + ret = efi_to_native(&native_name, variable_name, vendor); + if (ret) + return EFI_EXIT(ret); + + name_len = strlen(native_name); + for (variable = efi_variables_list; variable && *variable;) { + if (!strncmp(variable, native_name, name_len) && + variable[name_len] == '=') + break; + + variable = strchr(variable, '\n'); + if (variable) + variable++; + } + + free(native_name); + if (!(variable && *variable)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* next variable */ + variable = strchr(variable, '\n'); + if (variable) + variable++; + if (!(variable && *variable)) + return EFI_EXIT(EFI_NOT_FOUND); + } else { + /* new search */ + free(efi_variables_list); + efi_variables_list = NULL; + efi_cur_variable = NULL; + + snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_.*"); + list_len = hexport_r(&env_htab, '\n', + H_MATCH_REGEX | H_MATCH_KEY, + &efi_variables_list, 0, 1, regexlist); + if (list_len <= 0) + return EFI_EXIT(EFI_NOT_FOUND); + + variable = efi_variables_list; + } + + ret = parse_uboot_variable(variable, variable_name_size, variable_name, + vendor, &attribute); + + return EFI_EXIT(ret); }
/* http://wiki.phoenix.com/wiki/index.php/EFI_RUNTIME_SERVICES#SetVariable.28.2... */
There is a bug in efi variables test. Fix it with some cosmetic improvements.
Please note that efi variables test still fails at QueryVariableInfo() and GetVariable(), but this is not due to a change in this patch. ==8<== Testing EFI API implementation
Selected test: 'variables'
Setting up 'variables' Setting up 'variables' succeeded
Executing 'variables' .../u-boot/lib/efi_selftest/efi_selftest_variables.c(60): TODO: QueryVariableInfo failed .../u-boot/lib/efi_selftest/efi_selftest_variables.c(131): TODO: GetVariable returned wrong length 7 .../u-boot/lib/efi_selftest/efi_selftest_variables.c(133): TODO: GetVariable returned wrong value Executing 'variables' succeeded
Boot services terminated
Summary: 0 failures ==>8==
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_selftest/efi_selftest_variables.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_variables.c b/lib/efi_selftest/efi_selftest_variables.c index e4c389a872fa..c58434289325 100644 --- a/lib/efi_selftest/efi_selftest_variables.c +++ b/lib/efi_selftest/efi_selftest_variables.c @@ -141,19 +141,22 @@ static int execute(void) if (ret == EFI_NOT_FOUND) break; if (ret != EFI_SUCCESS) { - efi_st_todo("GetNextVariableName failed\n"); - break; + efi_st_error("GetNextVariableName failed (%u)\n", + (unsigned int)ret); + return EFI_ST_FAILURE; } if (!efi_st_memcmp(&guid, &guid_vendor0, sizeof(efi_guid_t)) && !efi_st_strcmp_16_8(varname, "efi_st_var0")) - flag |= 2; + flag |= 1; if (!efi_st_memcmp(&guid, &guid_vendor1, sizeof(efi_guid_t)) && !efi_st_strcmp_16_8(varname, "efi_st_var1")) flag |= 2; } - if (flag != 3) - efi_st_todo( + if (flag != 3) { + efi_st_error( "GetNextVariableName did not return all variables\n"); + return EFI_ST_FAILURE; + } /* Delete variable 1 */ ret = runtime->set_variable(L"efi_st_var1", &guid_vendor1, 0, 0, NULL);
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Alex, Heinrich,
Please review this patch set.
Thanks, -Takahiro Akashi
u16 *variable_name,
efi_guid_t *vendor,
u32 *attribute)
- char *guid, *name, *end, c;
- unsigned long name_size;
- u16 *p;
- guid = strchr(variable, '_');
- if (!guid)
- guid++;
- name = strchr(guid, '_');
- if (!name)
- name++;
- end = strchr(name, '=');
- if (!end)
- /* FIXME: size is in byte or u16? */
- name_size = end - name;
- if (*variable_name_size < (name_size + 1)) {
- end++; /* point to value */
- p = variable_name;
- utf8_utf16_strncpy(&p, name, name_size);
- variable_name[name_size] = 0;
- c = *(name - 1);
- *(name - 1) = '\0'; /* guid need be null-terminated here */
- uuid_str_to_bin(guid, (unsigned char *)vendor, UUID_STR_FORMAT_GUID);
- *(name - 1) = c;
- parse_attr(end, attribute);
- return EFI_SUCCESS;
- char *native_name, *variable;
- ssize_t name_len, list_len;
- char regex[256];
- char * const regexlist[] = {regex};
- u32 attribute;
- int i;
- efi_status_t ret;
- EFI_ENTRY("%p "%ls" %pUl", variable_name_size, variable_name, vendor);
- if (!variable_name_size || !variable_name || !vendor)
- if (variable_name[0]) {
break;
if (ret)
break;
if (variable)
variable++;
free(native_name);
/* next variable */
if (variable)
variable++;
- } else {
/* new search */
if (list_len <= 0)
- ret = parse_uboot_variable(variable, variable_name_size, variable_name,
- return EFI_EXIT(ret);
2.19.1
Please, provide a comment describing what this function is meant to do.
Describe every parameter
Clearly state set variable_name_size is in bytes (cf. EmuGetNextVariableName() in EDK2)
This function duplicates some of the code in efi_get_variable. So, please, use it in efi_get_variable too.
u16 *variable_name,
efi_guid_t *vendor,
u32 *attribute)
- u16 *p;
- if (!guid)
- guid++;
- if (!name)
- name++;
- if (!end)
It is in bytes. See comment above.
- c = *(name - 1);
- *(name - 1) = c;
You have to update variable_name_size.
Please add a description of the function here like we have it in efi_bootefi.c
- char regex[256];
- u32 attribute;
- int i;
- efi_status_t ret;
This code partially duplicates code in in efi_get_variable. Please, carve out a common function.
break;
if (ret)
break;
You miss to compare the GUID.
Consider the case that the GUID changes between two calls.
if (variable)
variable++;
free(native_name);
With less parentheses I can read the logic more easily:
if (!variable || !*variable)
But that is just a question of taste.
Please, consider the case that the variable is not on the list because the variable has already been deleted.
/* next variable */
if (variable)
variable++;
- } else {
/* new search */
Please, put a comment here explaining that the list of the preceding search is freed here.
if (list_len <= 0)
You miss to compare the vendor GUIDs.
Please, assume that variables are deleted or inserted while the caller loops over the variables.
Thanks a lot for filling this gap in our EFI implementation.
Best regards
Heinrich
Heinrich,
Thank you for your quick review.
I think that the function name describes itself clearly, but OK.
Right.
Which part of code do you mean? I don't think so.
u16 *variable_name,
efi_guid_t *vendor,
u32 *attribute)
- u16 *p;
- if (!guid)
- guid++;
- if (!name)
- name++;
- if (!end)
OK
- c = *(name - 1);
- *(name - 1) = c;
Right.
OK, but not for efi_get/set_variable() as I didn't touch anything there.
- char regex[256];
- u32 attribute;
- int i;
- efi_status_t ret;
Which part of code do you mean? I don't see any duplication.
break;
if (ret)
break;
No, "native_name" already contains a given guid.
UEFI specification, section 8.2, clearly describes; When VariableName is a pointer to a Null character, VendorGuid is ignored. etNextVariableName() cannot be used as a filter to return variable names with a specific GUID. Instead, the entire list of variables must be retrieved, and the caller may act as a filter if it chooses.
if (variable)
variable++;
free(native_name);
Well, this "if" clause corresponds with a termination condition of the previous "for" clause and checks whether a for loop has been exhausted. So my expression would be better IMO.
ditto
/* next variable */
if (variable)
variable++;
- } else {
/* new search */
OK
if (list_len <= 0)
No. Please see UEFI specification quoted above.
Best regards
Heinrich
On 1/17/19 3:14 AM, AKASHI Takahiro wrote:
Heinrich,
Right.
Checking buffer size. Comparing vendor GUID. Extracting an EFI variable from a U-Boot variable.
u16 *variable_name,
efi_guid_t *vendor,
u32 *attribute)
- u16 *p;
- if (!guid)
- guid++;
- if (!name)
- name++;
- if (!end)
OK
- c = *(name - 1);
- *(name - 1) = c;
Right.
For the other functions we should do it in a separate patch.
- char regex[256];
- u32 attribute;
- int i;
- efi_status_t ret;
break;
if (ret)
break;
Look at the list of error codes. EFI_INVALID_PARAMETER has to be returned if name or GUID does not match an existing variable.
Regards
Heinrich
if (variable)
variable++;
free(native_name);
ditto
/* next variable */
if (variable)
variable++;
- } else {
/* new search */
OK
if (list_len <= 0)
Best regards
Heinrich
Heinrich,
Right.
Please specify exact line numbers on both side. Otherwise, I don't get you.
u16 *variable_name,
efi_guid_t *vendor,
u32 *attribute)
- u16 *p;
- if (!guid)
- guid++;
- if (!name)
- name++;
- if (!end)
OK
- c = *(name - 1);
- *(name - 1) = c;
Right.
Not me.
- char regex[256];
- u32 attribute;
- int i;
- efi_status_t ret;
What about this?
break;
if (ret)
break;
The code below behaves exactly as you mention: /* search for the last-returned variable */ ret = efi_to_native(&native_name, variable_name, vendor);
for (variable = efi_variables_list; variable && *variable;) { ... } free(native_name); if (!(variable && *variable)) return EFI_EXIT(EFI_INVALID_PARAMETER);
-Takahiro Akashi
Regards
Heinrich
if (variable)
variable++;
free(native_name);
ditto
/* next variable */
if (variable)
variable++;
- } else {
/* new search */
OK
if (list_len <= 0)
Best regards
Heinrich
AKASHI Takahiro
