[U-Boot] [PATCH v2] efi_loader: set image_base and image_size to correct values
Currently, image's image_base points to an address where the image was temporarily uploaded for further loading. Since efi_loader relocates the image to final destination, image_base and image_size should reflect that.
This bug was detected in UEFI SCT, "Loaded Image Protocol Test - test 2," which shows that 'Unload' function doesn't fit into a range suggested by image_base and image_size. TestCase/UEFI/EFI/Protocol/LoadedImage/BlackBoxTest/ LoadedImageBBTestMain.c:1002
Changes in this patch also includes: * reverts a patch, "efi_loader: save image relocation address and size" since newly added fields are no longer needed. * copy PE headers as well since those information will be needed for module loading, in particular, at gurb. (This bug was reported by Heinrich.)
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_image_loader.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index a18ce0a5705e..d1b6c0d3cdf2 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -59,10 +59,10 @@ static efi_status_t efi_print_image_info(struct efi_loaded_image_obj *obj, { printf("UEFI image"); printf(" [0x%p:0x%p]", - obj->reloc_base, obj->reloc_base + obj->reloc_size - 1); - if (pc && pc >= obj->reloc_base && - pc < obj->reloc_base + obj->reloc_size) - printf(" pc=0x%zx", pc - obj->reloc_base); + image->image_base, image->image_base + image->image_size - 1); + if (pc && pc >= image->image_base && + pc < image->image_base + image->image_size) + printf(" pc=0x%zx", pc - image->image_base); if (image->file_path) printf(" '%pD'", image->file_path); printf("\n"); @@ -212,7 +212,6 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, int rel_idx = IMAGE_DIRECTORY_ENTRY_BASERELOC; void *entry; uint64_t image_base; - uint64_t image_size; unsigned long virt_size = 0; int supported = 0;
@@ -256,7 +255,6 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, IMAGE_NT_HEADERS64 *nt64 = (void *)nt; IMAGE_OPTIONAL_HEADER64 *opt = &nt64->OptionalHeader; image_base = opt->ImageBase; - image_size = opt->SizeOfImage; efi_set_code_and_data_type(loaded_image_info, opt->Subsystem); efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type); @@ -272,7 +270,6 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, } else if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC) { IMAGE_OPTIONAL_HEADER32 *opt = &nt->OptionalHeader; image_base = opt->ImageBase; - image_size = opt->SizeOfImage; efi_set_code_and_data_type(loaded_image_info, opt->Subsystem); efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type); @@ -291,6 +288,11 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, return NULL; }
+ /* Copy PE headers */ + memcpy(efi_reloc, efi, sizeof(*dos) + sizeof(*nt) + + nt->FileHeader.SizeOfOptionalHeader + + num_sections * sizeof(IMAGE_SECTION_HEADER)); + /* Load sections into RAM */ for (i = num_sections - 1; i >= 0; i--) { IMAGE_SECTION_HEADER *sec = §ions[i]; @@ -315,10 +317,8 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, invalidate_icache_all();
/* Populate the loaded image interface bits */ - loaded_image_info->image_base = efi; - loaded_image_info->image_size = image_size; - handle->reloc_base = efi_reloc; - handle->reloc_size = virt_size; + loaded_image_info->image_base = efi_reloc; + loaded_image_info->image_size = virt_size;
return entry; }
- reverts a patch, "efi_loader: save image relocation address and size" since newly added fields are no longer needed.
- copy PE headers as well since those information will be needed for module loading, in particular, at gurb. (This bug was reported by Heinrich.)
- if (pc && pc >= image->image_base &&
if (image->file_path) printf(" '%pD'", image->file_path); printf("\n");printf(" pc=0x%zx", pc - image->image_base);
efi_set_code_and_data_type(loaded_image_info, opt->Subsystem); efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type);image_size = opt->SizeOfImage;
- /* Copy PE headers */
- memcpy(efi_reloc, efi, sizeof(*dos) + sizeof(*nt)
Why do we have to copy PE headers and the sections below separately? My understanding is that the relative positions do not need any adjustment.
Nothing in the spec requires the COFF header to be at offset sizeof(dos). You can put the COFF headder anywhere in the file. Please, read
https://media.blackhat.com/bh-us-11/Vuksan/BH_US_11_VuksanPericin_PECOFF_WP....
We should not assign new memory here. Nor should we copy anything here. We should simply use the relocation table to update the indicated memory locations.
Best regards
Heinrich
return entry;
I think I have already answered your questions here: https://lists.denx.de/pipermail/u-boot/2018-October/343876.html
Did you read it?
But as far as I look at grub code (that you pointed out in your e-mail), grub expects that PE headers be also "loaded" within an allocated region (more specifically at the beginning of the region) along with other sections in order to handle a (grub-specific? I don't know) "mods" section.
-Takahiro Akashi
Best regards
Heinrich
return entry;
Did you read it?
Is this patch still required?
Alex
Did you read it?
I think so as long as we want to make the code more compliant with UEFI spec, but Heinrich may have a different opinion about how to fix it.
Thanks, -Takahiro Akashi
Alex
Heinrich,
Did you read it?
Do you have any comment here?
-Takahiro Akashi
Alex
Why is it needed to copy the header? Did you experience any error related to this header not copied?
Best regards
Heinrich
return entry;
You made the same question before, and I answered already. https://lists.denx.de/pipermail/u-boot/2018-October/344165.html
-Takahiro Akashi
Best regards
Heinrich
return entry;
AKASHI Takahiro
Alexander Graf
