[U-Boot-Users] i368 / amd Sc520 Uboot
Hi All
im trying to use U-boot for i386/AMDSC520 implemetation ... Fixed a lot of files ..
last i had to worry with the implemtation of the mkimage and linux - do_bootm implementation I was not able to start a kernel now at all ..system hangs ..
know reason why ..any hints ? suggestions ..or anyone here how has fixed it ? any help would be very nice !!
best regards
Wolfgang k.
@ Wolfgang Denk : Hallo ! -- wer pflegt eigentlich den i368 code scheint sein jahren nix mehr passiert zu sein und im vergleich zum PPC um jahrhunderte zurück zu liegen :-(( geschweiged das der code so wie er im cvs is auch nur annähernd starten würde ...
---------------------------------------------------------------------------- int enter_realmode(u16 seg, u16 off, struct pt_regs *in, struct pt_regs *out) { printf("before bios_setup...\n");
/* setup out thin bios emulation */ if (bios_setup()) { return -1; }
printf("before realmode_setup...\n"); if (realmode_setup()) { return -1; }
printf("after bios_setup...\n"); in->eip = off; in->xcs = seg; if (3>(in->esp & 0xffff)) { printf("Warning: entering realmode with sp < 4 will fail\n"); }
printf("before memcpy...\n"); memcpy(REALMODE_MAILBOX, in, sizeof(struct pt_regs)); asm("wbinvd\n"); printf("after memcpy...\n");
__asm__ volatile ( "lcall $0x20,%0\n" : : "i" (&realmode_enter) );
asm("wbinvd\n"); memcpy(out, REALMODE_MAILBOX, sizeof(struct pt_regs)); return out->eax;
schould exec of teh kernel start here?????????????????????? }
LOG:
U-Boot 1.0.2 (Apr 28 2004 - 00:01:51)
######################################################### # Adopted for HOPF AMD SC520 Embbeded BOARD # ######################################################### U-Boot code: 08FC0000 -> 08FDF349 data: 03F00000 -> 03F017F3 BSS: 03F017F4 -> 03F0BCBF stack: 03F0BCC0 -> 03F13CBF DRAM Configuration: Bank #0: 00000000 64 MB Bank #0: Micron / Intel 28F640J3A Flash: 16 MB FLASH: 16 MB set_irq(): map INTA to IRQ9 00 11 8086 1209 0200 09 In: serial Out: serial Err: serial Net: i82559#0 ***SC520 hopf BOARD last stage init done*** boot => bootm 8000000 U-Boot Command_code_tabelle: 08FD7C36 -> 08FD80B8 U-Boot Cmd_table_start_search: 08FD7C38 ## Booting image at 08000000 ... Image Name: Hopf Embedded Linux Kernel Image Type: Intel x86 Linux Kernel Image (uncompressed) // fix for i368 mkimage ! Data Size: 752142 Bytes = 734.5 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK OK No initrd Using boot protocol version 2.03 Linux kernel version 2.4.21-NANO-rthal5 (rac@chicago) #2 Tue Apr 27 19:58:10 CEST 2004 Kernel command line: "console=ttyS0,9600 root=/dev/ram0 rw " Loading bzImage at address 0x00100000 (749070 bytes) ## Transferring control to Linux (at address 00090000) ...
Starting kernel ...
before bios_setup... before realmode_setup... after bios_setup... before memcpy... after memcpy...
Dear Wolfgang,
Please submit your patches...
@ Wolfgang Denk : Hallo ! -- wer pflegt eigentlich den i368 code scheint sein jahren nix mehr passiert zu sein und im vergleich zum PPC um jahrhunderte zurück zu liegen :-(( geschwei ged das der code so wie er im cvs is auch nur annähernd starten würde ...
I am aware that the x86 part of the U-Boot code it not very actively (if at all) maintained, but there is little I can do about it (I don't have much knowledge about x86 myself, and no such hardware). As you can see from the MAINTAINERS file, Daniel Engström was (is?) working on this. The best thing you can do is to contribute your patches.
Wolfgang Kanovsky
