[U-Boot] [PATCH RESEND] gadget: f_thor: properly enable 3rd endpoint defined by the protocol
This is needed to make Windows THOR flash tool happy, because it starts sending data only when interrupt packet is received on the 3rd endpoint.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com Acked-by: Lukasz Majewski lukma@denx.de --- Resend reason: stand alone patch, independent from the main patchset: https://patchwork.ozlabs.org/cover/994309/ --- drivers/usb/gadget/f_thor.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/usb/gadget/f_thor.c b/drivers/usb/gadget/f_thor.c index 8b3b19feaf..920fa5279c 100644 --- a/drivers/usb/gadget/f_thor.c +++ b/drivers/usb/gadget/f_thor.c @@ -941,6 +941,13 @@ static int thor_eps_setup(struct usb_function *f) dev->out_req = req; /* ACM control EP */ ep = dev->int_ep; + d = ep_desc(gadget, &hs_int_desc, &fs_int_desc); + debug("(d)bEndpointAddress: 0x%x\n", d->bEndpointAddress); + + result = usb_ep_enable(ep, d); + if (result) + goto err; + ep->driver_data = cdev; /* claim */
Marek Szyprowski
