[PATCH 00/15] board: ti: Add support for BeagleBone AI-64
Cleanups for J721e/J7200 and add support for BeagleBone AI-64
Based off: master 07fe79c93c5c Merge tag 'i2cfixes-for-v2024-01-rc2' of https://source.denx.de/u-boot/custodians/u-boot-i2c
Boot Logs: J721e-SK: https://gist.github.com/nmenon/c144e64f1da9fd49997ef5794b056bb0 J721e-EVM: https://gist.github.com/nmenon/e79bed6807da05c723e71687fb3c0b90 J7200-HSEVM: https://gist.github.com/nmenon/5658dd6fa2f67bce915c77b25c02f897
BeagleBone AI-64: SD/MMC boot: https://gist.github.com/nmenon/1e07858fb8ca39ca87e40d3894e4d9b7 eMMC boot: https://gist.github.com/nmenon/9b0602df1f1be2c6b512d135b0afae60 eMMC boot with SDcard detected: https://gist.github.com/nmenon/82058014f4b2f6b9ed21431bc675e12a
U-Boot CI: https://github.com/u-boot/u-boot/pull/444
BeagleBone AI-64 is introduced without EEPROM detection and cleanups to j721e evm configuration is done to facilitate that. based on when and timing of [1] is merged in, we can introduce an equivalent patch or squash similar patch in for beagleboneai64.
Boot uses stdboot as default - so we also transition j721e over to sdboot along with it.
Fixes a breakage with HBMC that was getting in my way of testing, but I have'nt focussed on converting j7200 to stdboot - but probably a minor patch similar to that in this series for j721e.
What works: * emmc, sd, dhcp, basic i2c gpio etc.. * DDR looks stable as well.
TODO: * PMIC support will need to be added for AVS to be active - something to do once upstream kernel gets that support * USB boot is broken (or was just noticed) - some sort of regression with serdes is my best guess. * We could potentially enable something like nvme boot as well if we can make PCIe work
Nishanth Menon (14): arm: mach-k3: j721e: Improve support for UDA FS configs: j7200: Remove HBMC_AM654 config board: ti: j721e: evm: Drop board check for ESM board: ti: j721e: evm: Drop unused headers board: ti: j721e: evm: Switch to using IS_ENABLED board: ti: j721e: evm: Drop board based serdes initialization board: ti: j721e: evm: Use IS_ENABLED with CONFIG_PHYS_64BIT board: ti: j721e: evm: Split code to isolate eeprom detected logic board: ti: j721e: j721e.env: Add explicit boot_targets configs: j721e_evm_a72_defconfig: Switch to bootstd arm: dts: k3-j721e-binman: Allow a single board configuration arm: dts: k3-j721e-binman: Use macros that can be overridden for dtbs board: ti: Add j721e_beagleboneai64_* config fragments and env file doc: board: ti: Add BeagleBone AI-64 documentation
Robert Nelson (1): arm: dts: Add k3-j721e-beagleboneai64
arch/arm/dts/Makefile | 5 +- .../dts/k3-j721e-beagleboneai64-u-boot.dtsi | 206 ++ arch/arm/dts/k3-j721e-beagleboneai64.dts | 993 ++++++++ arch/arm/dts/k3-j721e-binman.dtsi | 33 +- .../k3-j721e-common-proc-board-u-boot.dtsi | 2 + .../k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi | 2200 +++++++++++++++++ arch/arm/dts/k3-j721e-r5-beagleboneai64.dts | 96 + arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 2 + arch/arm/mach-k3/j721e_init.c | 9 +- board/ti/j721e/MAINTAINERS | 7 + board/ti/j721e/Makefile | 1 + board/ti/j721e/beagleboneai64.env | 19 + board/ti/j721e/beagleboneai64_a72.config | 55 + board/ti/j721e/beagleboneai64_r5.config | 19 + board/ti/j721e/{evm.c => board-variants.c} | 276 +-- board/ti/j721e/evm.c | 459 +--- board/ti/j721e/evm.h | 24 + board/ti/j721e/j721e.env | 1 + configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 1 - configs/j721e_evm_a72_defconfig | 5 +- doc/board/ti/j721e_beagleboneai64.rst | 327 +++ doc/board/ti/k3.rst | 1 + 23 files changed, 4083 insertions(+), 659 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-beagleboneai64-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-beagleboneai64.dts create mode 100644 arch/arm/dts/k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-beagleboneai64.dts create mode 100644 board/ti/j721e/beagleboneai64.env create mode 100644 board/ti/j721e/beagleboneai64_a72.config create mode 100644 board/ti/j721e/beagleboneai64_r5.config copy board/ti/j721e/{evm.c => board-variants.c} (63%) create mode 100644 board/ti/j721e/evm.h create mode 100644 doc/board/ti/j721e_beagleboneai64.rst
[1] https://lore.kernel.org/all/20231101170519.39627-1-afd@ti.com/
Commit 5019170970ad ("arch: arm: mach-k3: j721e: add support for UDA FS") introduced basic UDA FS support, however, we can Take approach similar to commit 0f1c1e8b368b ("arm: mach-k3: am625: Add support for UDA FS"). While boot partition support with EMMC boot is useful, it is constrained by the size of boot hardware partition itself.
In the case of K3 devices, tispl images can contain OP-TEE images that can substantially vary in size and the u-boot image itself can vary over time as we enable various features.
So use the CSD information in the case of EMMC_BOOT configuration being enabled to pick boot partition or UDA FS mode operation to pick.
If EMMC_BOOT is disabled, then depend on filesystem configuration to pick data from UDA.
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/mach-k3/j721e_init.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index b1f7e25ed092..bcdfbfc79c4a 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -294,7 +294,14 @@ u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) { switch (boot_device) { case BOOT_DEVICE_MMC1: - return (spl_mmc_emmc_boot_partition(mmc) ? MMCSD_MODE_EMMCBOOT : MMCSD_MODE_FS); + if (IS_ENABLED(CONFIG_SUPPORT_EMMC_BOOT)) { + if (spl_mmc_emmc_boot_partition(mmc)) + return MMCSD_MODE_EMMCBOOT; + return MMCSD_MODE_FS; + } + if (IS_ENABLED(CONFIG_SPL_FS_FAT) || IS_ENABLED(CONFIG_SPL_FS_EXT4)) + return MMCSD_MODE_FS; + return MMCSD_MODE_EMMCBOOT; case BOOT_DEVICE_MMC2: return MMCSD_MODE_FS; default:
I am thinking, in which case we have EMMC_BOOT disabled,
Case here I am considering, updating u-boot to eMMC from u-boot shell, If EMMC_BOOT
is not set then , we can not set CSD information
I had a view EMMC_BOOT should be needed config.
If you consider, to make EMMC_BOOT as needed config, then this is not needed
Yes, but we cannot use boot0 mode of operation for Beagle family. the size of u-boot and optee vary over time and SK's boot0 partition strategy does'nt work for Beagle platforms.
EMMC_BOOT is not a mandatory config.
Thanks, I was not aware of this limitation of Beagle family.
Let each board chose needed config with that
Reviewed-by: Udit Kumar u-kumar1@ti.com
Kernel commit 1b77265626a4 ("arm64: dts: ti: k3-j7200-mcu-wakeup: Add HyperBus node") was merged to kernel without its dependent patch [1]. Similar fix is needed in U-Boot, and hbmc currently breaks boot. Till this gets fixed in U-Boot, disable the config by default so that the hbmc probe that happens in board/ti/j721e/evm.c will not take place and lead to boot failure.
This is similar to the approach in commit 5b2671594b80 ("configs: j721e: Remove HBMC_AM654 config"), introduced to j7200 evm platform.
[1] https://lore.kernel.org/all/20230424184810.29453-1-afd@ti.com/
Signed-off-by: Nishanth Menon nm@ti.com --- configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index cb4a141675da..889358afc316 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -138,7 +138,6 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index d25dd8134b63..6452c60345fd 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -114,7 +114,6 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y
When config is enabled, the esm dt probe makes sense. Simplify by dropping board specific checks.
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/evm.c | 10 ++-------- 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index d4f7c1d9f938..75d51a0552c4 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -531,10 +531,8 @@ err_free_gpio:
void spl_board_init(void) { -#if defined(CONFIG_ESM_K3) || defined(CONFIG_ESM_PMIC) struct udevice *dev; int ret; -#endif
if ((IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM)) && @@ -543,24 +541,20 @@ void spl_board_init(void) probe_daughtercards(); }
-#ifdef CONFIG_ESM_K3 - if (board_ti_k3_is("J721EX-PM2-SOM")) { + if (IS_ENABLED(CONFIG_ESM_K3)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(k3_esm), &dev); if (ret) printf("ESM init failed: %d\n", ret); } -#endif
-#ifdef CONFIG_ESM_PMIC - if (board_ti_k3_is("J721EX-PM2-SOM")) { + if (IS_ENABLED(CONFIG_ESM_PMIC)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(pmic_esm), &dev); if (ret) printf("ESM PMIC init failed: %d\n", ret); } -#endif if ((IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM)) && IS_ENABLED(CONFIG_HBMC_AM654)) { struct udevice *dev;
- if (IS_ENABLED(CONFIG_ESM_K3)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(k3_esm), &dev); if (ret) printf("ESM init failed: %d\n", ret); }
Nothing related to this patch, but to get esm completely functional
Second k3_esm probing needs to be added in this file.
Also, DT changes are needed, in next sync
https://lore.kernel.org/all/20231013102941.548209-1-n-francis@ti.com/
-#endif
- if (IS_ENABLED(CONFIG_ESM_PMIC)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(pmic_esm), &dev); if (ret) printf("ESM PMIC init failed: %d\n", ret); }
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index d4f7c1d9f938..75d51a0552c4 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -531,10 +531,8 @@ err_free_gpio: void spl_board_init(void) { -#if defined(CONFIG_ESM_K3) || defined(CONFIG_ESM_PMIC) struct udevice *dev; int ret; -#endif if ((IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM)) && @@ -543,24 +541,20 @@ void spl_board_init(void) probe_daughtercards(); } -#ifdef CONFIG_ESM_K3
Understood. no action on the current series, I assume.
yes, no action on current series.
Drop headers that are no longer necessary for build
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/evm.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 75d51a0552c4..8f0996c32ee6 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -8,21 +8,13 @@ */
#include <common.h> -#include <env.h> -#include <fdt_support.h> #include <generic-phy.h> #include <image.h> -#include <init.h> -#include <log.h> #include <net.h> #include <asm/arch/hardware.h> -#include <asm/global_data.h> #include <asm/gpio.h> -#include <asm/io.h> #include <spl.h> #include <dm.h> -#include <dm/uclass-internal.h> -#include <linux/printk.h>
#include "../common/board_detect.h"
Switch to using IS_ENABLED() for inline function usage.
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/evm.c | 83 ++++++++++++++++++++++---------------------- 1 file changed, 42 insertions(+), 41 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 8f0996c32ee6..17640ae79665 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -300,53 +300,54 @@ static int probe_daughtercards(void) printf("Detected: %s rev %s\n", ep.name, ep.version); daughter_card_detect_flags[i] = true;
-#ifndef CONFIG_SPL_BUILD - int j; - /* - * Populate any MAC addresses from daughtercard into the U-Boot - * environment, starting with a card-specific offset so we can - * have multiple ext_cards contribute to the MAC pool in a well- - * defined manner. - */ - for (j = 0; j < mac_addr_cnt; j++) { - if (!is_valid_ethaddr((u8 *)mac_addr[j])) - continue; - - eth_env_set_enetaddr_by_index("eth", - ext_cards[i].eth_offset + j, - (uchar *)mac_addr[j]); + if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + int j; + /* + * Populate any MAC addresses from daughtercard into the U-Boot + * environment, starting with a card-specific offset so we can + * have multiple ext_cards contribute to the MAC pool in a well- + * defined manner. + */ + for (j = 0; j < mac_addr_cnt; j++) { + if (!is_valid_ethaddr((u8 *)mac_addr[j])) + continue; + + eth_env_set_enetaddr_by_index("eth", + ext_cards[i].eth_offset + j, + (uchar *)mac_addr[j]); + } } -#endif } -#ifndef CONFIG_SPL_BUILD - char name_overlays[1024] = { 0 };
- for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { - if (!daughter_card_detect_flags[i]) - continue; + if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + char name_overlays[1024] = { 0 };
- /* Skip if no overlays are to be added */ - if (!strlen(ext_cards[i].dtbo_name)) - continue; + for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { + if (!daughter_card_detect_flags[i]) + continue;
- /* - * Make sure we are not running out of buffer space by checking - * if we can fit the new overlay, a trailing space to be used - * as a separator, plus the terminating zero. - */ - if (strlen(name_overlays) + strlen(ext_cards[i].dtbo_name) + 2 > - sizeof(name_overlays)) - return -ENOMEM; - - /* Append to our list of overlays */ - strcat(name_overlays, ext_cards[i].dtbo_name); - strcat(name_overlays, " "); - } + /* Skip if no overlays are to be added */ + if (!strlen(ext_cards[i].dtbo_name)) + continue;
- /* Apply device tree overlay(s) to the U-Boot environment, if any */ - if (strlen(name_overlays)) - return env_set("name_overlays", name_overlays); -#endif + /* + * Make sure we are not running out of buffer space by checking + * if we can fit the new overlay, a trailing space to be used + * as a separator, plus the terminating zero. + */ + if (strlen(name_overlays) + strlen(ext_cards[i].dtbo_name) + 2 > + sizeof(name_overlays)) + return -ENOMEM; + + /* Append to our list of overlays */ + strcat(name_overlays, ext_cards[i].dtbo_name); + strcat(name_overlays, " "); + } + + /* Apply device tree overlay(s) to the U-Boot environment, if any */ + if (strlen(name_overlays)) + return env_set("name_overlays", name_overlays); + }
return 0; }
Serdes initialization should be compile flag based instead of being eeprom based.
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 17640ae79665..d49993fffe39 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -359,9 +359,6 @@ void configure_serdes_torrent(void) struct phy serdes; int ret;
- if (!IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) - return; - ret = uclass_get_device_by_driver(UCLASS_PHY, DM_DRIVER_GET(torrent_phy_provider), &dev); @@ -393,9 +390,6 @@ void configure_serdes_sierra(void) int ret, count, i; int link_count = 0;
- if (!IS_ENABLED(CONFIG_PHY_CADENCE_SIERRA)) - return; - ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(sierra_phy_provider), &dev); @@ -477,10 +471,10 @@ int board_late_init(void) probe_daughtercards(); }
- if (board_is_j7200_som()) + if (IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) configure_serdes_torrent();
- if (board_is_j721e_som()) + if (IS_ENABLED(CONFIG_PHY_CADENCE_SIERRA)) configure_serdes_sierra();
return;
return;
- if (IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) configure_serdes_torrent();
- if (IS_ENABLED(CONFIG_PHY_CADENCE_SIERRA)) configure_serdes_sierra();
Could be merged into one if condition
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 17640ae79665..d49993fffe39 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -359,9 +359,6 @@ void configure_serdes_torrent(void) struct phy serdes; int ret; - if (!IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) - return;
ret = uclass_get_device_by_driver(UCLASS_PHY, DM_DRIVER_GET(torrent_phy_provider), &dev); @@ -393,9 +390,6 @@ void configure_serdes_sierra(void) int ret, count, i; int link_count = 0; - if (!IS_ENABLED(CONFIG_PHY_CADENCE_SIERRA)) - return;
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(sierra_phy_provider), &dev); @@ -477,10 +471,10 @@ int board_late_init(void) probe_daughtercards(); } - if (board_is_j7200_som()) + if (IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) configure_serdes_torrent(); - if (board_is_j721e_som()) + if (IS_ENABLED(CONFIG_PHY_CADENCE_SIERRA)) configure_serdes_sierra();
Please ignore above comments
with that
Use IS_ENABLED to replace the #ifdeffery.
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/evm.c | 25 +++++++++++-------------- 1 file changed, 11 insertions(+), 14 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index d49993fffe39..0fc141776818 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -39,22 +39,19 @@ int board_init(void)
int dram_init(void) { -#ifdef CONFIG_PHYS_64BIT - gd->ram_size = 0x100000000; -#else - gd->ram_size = 0x80000000; -#endif + if (IS_ENABLED(CONFIG_PHYS_64BIT)) + gd->ram_size = 0x100000000; + else + gd->ram_size = 0x80000000;
return 0; }
phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { -#ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ - if (gd->ram_top > 0x100000000) + if (IS_ENABLED(CONFIG_PHYS_64BIT) && gd->ram_top > 0x100000000) return 0x100000000; -#endif
return gd->ram_top; } @@ -66,12 +63,12 @@ int dram_init_banksize(void) gd->bd->bi_dram[0].size = 0x80000000; gd->ram_size = 0x80000000;
-#ifdef CONFIG_PHYS_64BIT - /* Bank 1 declares the memory available in the DDR high region */ - gd->bd->bi_dram[1].start = CFG_SYS_SDRAM_BASE1; - gd->bd->bi_dram[1].size = 0x80000000; - gd->ram_size = 0x100000000; -#endif + if (IS_ENABLED(CONFIG_PHYS_64BIT)) { + /* Bank 1 declares the memory available in the DDR high region */ + gd->bd->bi_dram[1].start = CFG_SYS_SDRAM_BASE1; + gd->bd->bi_dram[1].size = 0x80000000; + gd->ram_size = 0x100000000; + }
return 0; }
Move code out of evm.c that is based on evm specific checks for board variants and initialization sequences there of.
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/Makefile | 1 + board/ti/j721e/{evm.c => board-variants.c} | 172 +-------- board/ti/j721e/evm.c | 409 +-------------------- board/ti/j721e/evm.h | 24 ++ 4 files changed, 53 insertions(+), 553 deletions(-) copy board/ti/j721e/{evm.c => board-variants.c} (75%) create mode 100644 board/ti/j721e/evm.h
diff --git a/board/ti/j721e/Makefile b/board/ti/j721e/Makefile index 97535f5d86d1..f42fcf5c463b 100644 --- a/board/ti/j721e/Makefile +++ b/board/ti/j721e/Makefile @@ -6,3 +6,4 @@ #
obj-y += evm.o +obj-${CONFIG_TI_I2C_BOARD_DETECT} += board-variants.o diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/board-variants.c similarity index 75% copy from board/ti/j721e/evm.c copy to board/ti/j721e/board-variants.c index 0fc141776818..ada0a9238981 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/board-variants.c @@ -1,22 +1,21 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Board specific initialization for J721E EVM + * Board variation detection and management based on EEPROM detect logic * - * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ - * Lokesh Vutla lokeshvutla@ti.com + * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ * */
#include <common.h> -#include <generic-phy.h> +#include <dm.h> #include <image.h> #include <net.h> +#include <spl.h> #include <asm/arch/hardware.h> #include <asm/gpio.h> -#include <spl.h> -#include <dm.h>
#include "../common/board_detect.h" +#include "evm.h"
#define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ board_ti_k3_is("J721EX-PM2-SOM")) @@ -30,49 +29,6 @@ /* Max number of MAC addresses that are parsed/processed per daughter card */ #define DAUGHTER_CARD_NO_OF_MAC_ADDR 8
-DECLARE_GLOBAL_DATA_PTR; - -int board_init(void) -{ - return 0; -} - -int dram_init(void) -{ - if (IS_ENABLED(CONFIG_PHYS_64BIT)) - gd->ram_size = 0x100000000; - else - gd->ram_size = 0x80000000; - - return 0; -} - -phys_addr_t board_get_usable_ram_top(phys_size_t total_size) -{ - /* Limit RAM used by U-Boot to the DDR low region */ - if (IS_ENABLED(CONFIG_PHYS_64BIT) && gd->ram_top > 0x100000000) - return 0x100000000; - - return gd->ram_top; -} - -int dram_init_banksize(void) -{ - /* Bank 0 declares the memory available in the DDR low region */ - gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE; - gd->bd->bi_dram[0].size = 0x80000000; - gd->ram_size = 0x80000000; - - if (IS_ENABLED(CONFIG_PHYS_64BIT)) { - /* Bank 1 declares the memory available in the DDR high region */ - gd->bd->bi_dram[1].start = CFG_SYS_SDRAM_BASE1; - gd->bd->bi_dram[1].size = 0x80000000; - gd->ram_size = 0x100000000; - } - - return 0; -} - #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { @@ -138,7 +94,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) } #endif
-#ifdef CONFIG_TI_I2C_BOARD_DETECT int do_board_detect(void) { int ret; @@ -348,74 +303,7 @@ static int probe_daughtercards(void)
return 0; } -#endif - -void configure_serdes_torrent(void) -{ - struct udevice *dev; - struct phy serdes; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_PHY, - DM_DRIVER_GET(torrent_phy_provider), - &dev); - if (ret) { - printf("Torrent init failed:%d\n", ret); - return; - } - - serdes.dev = dev; - serdes.id = 0; - - ret = generic_phy_init(&serdes); - if (ret) { - printf("phy_init failed!!: %d\n", ret); - return; - }
- ret = generic_phy_power_on(&serdes); - if (ret) { - printf("phy_power_on failed!!: %d\n", ret); - return; - } -} - -void configure_serdes_sierra(void) -{ - struct udevice *dev, *link_dev; - struct phy link; - int ret, count, i; - int link_count = 0; - - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_DRIVER_GET(sierra_phy_provider), - &dev); - if (ret) { - printf("Sierra init failed:%d\n", ret); - return; - } - - count = device_get_child_count(dev); - for (i = 0; i < count; i++) { - ret = device_get_child(dev, i, &link_dev); - if (ret) { - printf("probe of sierra child node %d failed: %d\n", i, ret); - return; - } - if (link_dev->driver->id == UCLASS_PHY) { - link.dev = link_dev; - link.id = link_count++; - - ret = generic_phy_power_on(&link); - if (ret) { - printf("phy_power_on failed!!: %d\n", ret); - return; - } - } - } -} - -#ifdef CONFIG_BOARD_LATE_INIT static void setup_board_eeprom_env(void) { char *name = "j721e"; @@ -457,27 +345,6 @@ static void setup_serial(void) env_set("serial#", serial_string); }
-int board_late_init(void) -{ - if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { - setup_board_eeprom_env(); - setup_serial(); - - /* Check for and probe any plugged-in daughtercards */ - if (board_is_j721e_som() || board_is_j7200_som()) - probe_daughtercards(); - } - - if (IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) - configure_serdes_torrent(); - - if (IS_ENABLED(CONFIG_PHY_CADENCE_SIERRA)) - configure_serdes_sierra(); - - return 0; -} -#endif - static int __maybe_unused detect_SW3_1_state(void) { if (IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM)) { @@ -513,11 +380,20 @@ err_free_gpio: } }
-void spl_board_init(void) +int variant_board_late_init(void) { - struct udevice *dev; - int ret; + setup_board_eeprom_env(); + setup_serial(); + + /* Check for and probe any plugged-in daughtercards */ + if (board_is_j721e_som() || board_is_j7200_som()) + probe_daughtercards();
+ return 0; +} + +void variant_spl_board_init(void) +{ if ((IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM)) && IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { @@ -525,20 +401,6 @@ void spl_board_init(void) probe_daughtercards(); }
- if (IS_ENABLED(CONFIG_ESM_K3)) { - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_DRIVER_GET(k3_esm), &dev); - if (ret) - printf("ESM init failed: %d\n", ret); - } - - if (IS_ENABLED(CONFIG_ESM_PMIC)) { - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_DRIVER_GET(pmic_esm), - &dev); - if (ret) - printf("ESM PMIC init failed: %d\n", ret); - } if ((IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM)) && IS_ENABLED(CONFIG_HBMC_AM654)) { struct udevice *dev; diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 0fc141776818..1c1cd106ba72 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -8,27 +8,10 @@ */
#include <common.h> -#include <generic-phy.h> -#include <image.h> -#include <net.h> -#include <asm/arch/hardware.h> -#include <asm/gpio.h> -#include <spl.h> #include <dm.h> +#include <generic-phy.h>
-#include "../common/board_detect.h" - -#define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ - board_ti_k3_is("J721EX-PM2-SOM")) - -#define board_is_j721e_sk() (board_ti_k3_is("J721EX-EAIK") || \ - board_ti_k3_is("J721EX-SK")) - -#define board_is_j7200_som() (board_ti_k3_is("J7200X-PM1-SOM") || \ - board_ti_k3_is("J7200X-PM2-SOM")) - -/* Max number of MAC addresses that are parsed/processed per daughter card */ -#define DAUGHTER_CARD_NO_OF_MAC_ADDR 8 +#include "evm.h"
@@ -73,283 +56,6 @@ int dram_init_banksize(void) return 0; }
-#ifdef CONFIG_SPL_LOAD_FIT -int board_fit_config_name_match(const char *name) -{ - bool eeprom_read = board_ti_was_eeprom_read(); - - if (!eeprom_read || board_is_j721e_som()) { - if (!strcmp(name, "k3-j721e-common-proc-board") || - !strcmp(name, "k3-j721e-r5-common-proc-board")) - return 0; - } else if (board_is_j721e_sk()) { - if (!strcmp(name, "k3-j721e-sk") || - !strcmp(name, "k3-j721e-r5-sk")) - return 0; - } - - return -1; -} -#endif - -#if CONFIG_IS_ENABLED(DM_GPIO) && CONFIG_IS_ENABLED(OF_LIBFDT) -/* Returns 1, if onboard mux is set to hyperflash */ -static void __maybe_unused detect_enable_hyperflash(void *blob) -{ - struct gpio_desc desc = {0}; - char *hypermux_sel_gpio = (board_is_j721e_som()) ? "8" : "6"; - - if (dm_gpio_lookup_name(hypermux_sel_gpio, &desc)) - return; - - if (dm_gpio_request(&desc, hypermux_sel_gpio)) - return; - - if (dm_gpio_set_dir_flags(&desc, GPIOD_IS_IN)) - return; - - if (dm_gpio_get_value(&desc)) { - int offset; - - do_fixup_by_compat(blob, "ti,am654-hbmc", "status", - "okay", sizeof("okay"), 0); - offset = fdt_node_offset_by_compatible(blob, -1, - "ti,am654-ospi"); - fdt_setprop(blob, offset, "status", "disabled", - sizeof("disabled")); - } -} -#endif - -#if defined(CONFIG_SPL_BUILD) && (defined(CONFIG_TARGET_J7200_A72_EVM) || defined(CONFIG_TARGET_J7200_R5_EVM) || \ - defined(CONFIG_TARGET_J721E_A72_EVM) || defined(CONFIG_TARGET_J721E_R5_EVM)) -void spl_perform_fixups(struct spl_image_info *spl_image) -{ - detect_enable_hyperflash(spl_image->fdt_addr); -} -#endif - -#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -int ft_board_setup(void *blob, struct bd_info *bd) -{ - detect_enable_hyperflash(blob); - - return 0; -} -#endif - -#ifdef CONFIG_TI_I2C_BOARD_DETECT -int do_board_detect(void) -{ - int ret; - - if (board_ti_was_eeprom_read()) - return 0; - - ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, - CONFIG_EEPROM_CHIP_ADDRESS); - if (ret) { - printf("EEPROM not available at 0x%02x, trying to read at 0x%02x\n", - CONFIG_EEPROM_CHIP_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS + 1); - ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, - CONFIG_EEPROM_CHIP_ADDRESS + 1); - if (ret) - pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", - CONFIG_EEPROM_CHIP_ADDRESS + 1, ret); - } - - return ret; -} - -int checkboard(void) -{ - struct ti_am6_eeprom *ep = TI_AM6_EEPROM_DATA; - - if (do_board_detect()) - /* EEPROM not populated */ - printf("Board: %s rev %s\n", "J721EX-PM1-SOM", "E2"); - else - printf("Board: %s rev %s\n", ep->name, ep->version); - - return 0; -} - -/* - * Declaration of daughtercards to probe. Note that when adding more - * cards they should be grouped by the 'i2c_addr' field to allow for a - * more efficient probing process. - */ -static const struct { - u8 i2c_addr; /* I2C address of card EEPROM */ - char *card_name; /* EEPROM-programmed card name */ - char *dtbo_name; /* Device tree overlay to apply */ - u8 eth_offset; /* ethXaddr MAC address index offset */ -} ext_cards[] = { - { - 0x51, - "J7X-BASE-CPB", - "", /* No dtbo for this board */ - 0, - }, - { - 0x52, - "J7X-INFOTAN-EXP", - "", /* No dtbo for this board */ - 0, - }, - { - 0x52, - "J7X-GESI-EXP", - "", /* No dtbo for this board */ - 5, /* Start populating from eth5addr */ - }, - { - 0x54, - "J7X-VSC8514-ETH", - "", /* No dtbo for this board */ - 1, /* Start populating from eth1addr */ - }, -}; - -static bool daughter_card_detect_flags[ARRAY_SIZE(ext_cards)]; - -const char *board_fit_get_additionnal_images(int index, const char *type) -{ - int i, j; - - if (strcmp(type, FIT_FDT_PROP)) - return NULL; - - j = 0; - for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { - if (daughter_card_detect_flags[i]) { - if (j == index) { - /* - * Return dtbo name only if populated, - * otherwise stop parsing here. - */ - if (strlen(ext_cards[i].dtbo_name)) - return ext_cards[i].dtbo_name; - else - return NULL; - }; - - j++; - } - } - - return NULL; -} - -static int probe_daughtercards(void) -{ - char mac_addr[DAUGHTER_CARD_NO_OF_MAC_ADDR][TI_EEPROM_HDR_ETH_ALEN]; - bool eeprom_read_success; - struct ti_am6_eeprom ep; - u8 previous_i2c_addr; - u8 mac_addr_cnt; - int i; - int ret; - - /* Mark previous I2C address variable as not populated */ - previous_i2c_addr = 0xff; - - /* No EEPROM data was read yet */ - eeprom_read_success = false; - - /* Iterate through list of daughtercards */ - for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { - /* Obtain card-specific I2C address */ - u8 i2c_addr = ext_cards[i].i2c_addr; - - /* Read card EEPROM if not already read previously */ - if (i2c_addr != previous_i2c_addr) { - /* Store I2C address so we can avoid reading twice */ - previous_i2c_addr = i2c_addr; - - /* Get and parse the daughter card EEPROM record */ - ret = ti_i2c_eeprom_am6_get(CONFIG_EEPROM_BUS_ADDRESS, - i2c_addr, - &ep, - (char **)mac_addr, - DAUGHTER_CARD_NO_OF_MAC_ADDR, - &mac_addr_cnt); - if (ret) { - debug("%s: No daughtercard EEPROM at 0x%02x found %d\n", - __func__, i2c_addr, ret); - eeprom_read_success = false; - /* Skip to the next daughtercard to probe */ - continue; - } - - /* EEPROM read successful, okay to further process. */ - eeprom_read_success = true; - } - - /* Only continue processing if EEPROM data was read */ - if (!eeprom_read_success) - continue; - - /* Only process the parsed data if we found a match */ - if (strncmp(ep.name, ext_cards[i].card_name, sizeof(ep.name))) - continue; - - printf("Detected: %s rev %s\n", ep.name, ep.version); - daughter_card_detect_flags[i] = true; - - if (!IS_ENABLED(CONFIG_SPL_BUILD)) { - int j; - /* - * Populate any MAC addresses from daughtercard into the U-Boot - * environment, starting with a card-specific offset so we can - * have multiple ext_cards contribute to the MAC pool in a well- - * defined manner. - */ - for (j = 0; j < mac_addr_cnt; j++) { - if (!is_valid_ethaddr((u8 *)mac_addr[j])) - continue; - - eth_env_set_enetaddr_by_index("eth", - ext_cards[i].eth_offset + j, - (uchar *)mac_addr[j]); - } - } - } - - if (!IS_ENABLED(CONFIG_SPL_BUILD)) { - char name_overlays[1024] = { 0 }; - - for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { - if (!daughter_card_detect_flags[i]) - continue; - - /* Skip if no overlays are to be added */ - if (!strlen(ext_cards[i].dtbo_name)) - continue; - - /* - * Make sure we are not running out of buffer space by checking - * if we can fit the new overlay, a trailing space to be used - * as a separator, plus the terminating zero. - */ - if (strlen(name_overlays) + strlen(ext_cards[i].dtbo_name) + 2 > - sizeof(name_overlays)) - return -ENOMEM; - - /* Append to our list of overlays */ - strcat(name_overlays, ext_cards[i].dtbo_name); - strcat(name_overlays, " "); - } - - /* Apply device tree overlay(s) to the U-Boot environment, if any */ - if (strlen(name_overlays)) - return env_set("name_overlays", name_overlays); - } - - return 0; -} -#endif - void configure_serdes_torrent(void) { struct udevice *dev; @@ -415,59 +121,8 @@ void configure_serdes_sierra(void) } }
-#ifdef CONFIG_BOARD_LATE_INIT -static void setup_board_eeprom_env(void) +int board_serdes_late_init(void) { - char *name = "j721e"; - - if (do_board_detect()) - goto invalid_eeprom; - - if (board_is_j721e_som()) - name = "j721e"; - else if (board_is_j721e_sk()) - name = "j721e-sk"; - else if (board_is_j7200_som()) - name = "j7200"; - else - printf("Unidentified board claims %s in eeprom header\n", - board_ti_get_name()); - -invalid_eeprom: - set_board_info_env_am6(name); -} - -static void setup_serial(void) -{ - struct ti_am6_eeprom *ep = TI_AM6_EEPROM_DATA; - unsigned long board_serial; - char *endp; - char serial_string[17] = { 0 }; - - if (env_get("serial#")) - return; - - board_serial = hextoul(ep->serial, &endp); - if (*endp != '\0') { - pr_err("Error: Can't set serial# to %s\n", ep->serial); - return; - } - - snprintf(serial_string, sizeof(serial_string), "%016lx", board_serial); - env_set("serial#", serial_string); -} - -int board_late_init(void) -{ - if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { - setup_board_eeprom_env(); - setup_serial(); - - /* Check for and probe any plugged-in daughtercards */ - if (board_is_j721e_som() || board_is_j7200_som()) - probe_daughtercards(); - } - if (IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) configure_serdes_torrent();
@@ -476,41 +131,18 @@ int board_late_init(void)
return 0; } -#endif
-static int __maybe_unused detect_SW3_1_state(void) +int board_late_init(void) { - if (IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM)) { - struct gpio_desc desc = {0}; - int ret; - char *hypermux_sel_gpio = (board_is_j721e_som()) ? "8" : "6"; - - ret = dm_gpio_lookup_name(hypermux_sel_gpio, &desc); - if (ret) { - printf("error getting GPIO lookup name: %d\n", ret); - return ret; - } - - ret = dm_gpio_request(&desc, hypermux_sel_gpio); - if (ret) { - printf("error requesting GPIO: %d\n", ret); - goto err_free_gpio; - } + int ret;
- ret = dm_gpio_set_dir_flags(&desc, GPIOD_IS_IN); - if (ret) { - printf("error setting direction flag of GPIO: %d\n", ret); - goto err_free_gpio; - } + ret = variant_board_late_init(); + if (ret) + return ret;
- ret = dm_gpio_get_value(&desc); - if (ret < 0) - printf("error getting value of GPIO: %d\n", ret); + board_serdes_late_init();
-err_free_gpio: - dm_gpio_free(desc.dev, &desc); - return ret; - } + return 0; }
void spl_board_init(void) @@ -518,13 +150,6 @@ void spl_board_init(void) struct udevice *dev; int ret;
- if ((IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM) || - IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM)) && - IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { - if (!board_is_j721e_sk()) - probe_daughtercards(); - } - if (IS_ENABLED(CONFIG_ESM_K3)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(k3_esm), &dev); @@ -539,18 +164,6 @@ void spl_board_init(void) if (ret) printf("ESM PMIC init failed: %d\n", ret); } - if ((IS_ENABLED(CONFIG_TARGET_J7200_A72_EVM) || IS_ENABLED(CONFIG_TARGET_J721E_A72_EVM)) && - IS_ENABLED(CONFIG_HBMC_AM654)) { - struct udevice *dev; - int ret;
- ret = detect_SW3_1_state(); - if (ret == 1) { - ret = uclass_get_device_by_driver(UCLASS_MTD, - DM_DRIVER_GET(hbmc_am654), - &dev); - if (ret) - debug("Failed to probe hyperflash\n"); - } - } + variant_spl_board_init(); } diff --git a/board/ti/j721e/evm.h b/board/ti/j721e/evm.h new file mode 100644 index 000000000000..8f8681817586 --- /dev/null +++ b/board/ti/j721e/evm.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Board detected logic initialization abstraction + * + * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ + * + */ + +#ifndef __J72E_EVM_H +#define __J72E_EVM_H + +#ifdef CONFIG_TI_I2C_BOARD_DETECT + +int variant_board_late_init(void); +void variant_spl_board_init(void); + +#else /* CONFIG_TI_I2C_BOARD_DETECT */ + +static inline int variant_board_late_init(void) { return 0; } +static inline void variant_spl_board_init(void) { } + +#endif /* CONFIG_TI_I2C_BOARD_DETECT */ + +#endif /* __J72E_EVM_H */
Add explicit boot_targets to indicate the specific boot sequence to follow.
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/j721e.env | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/ti/j721e/j721e.env b/board/ti/j721e/j721e.env index 8cc8232fc131..cb27bf5e2b24 100644 --- a/board/ti/j721e/j721e.env +++ b/board/ti/j721e/j721e.env @@ -31,6 +31,7 @@ addr_mcur5f0_0load=0x89000000 name_mcur5f0_0fw=/lib/firmware/j7200-mcu-r5f0_0-fw #endif
+boot_targets=mmc1 mmc0 usb pxe dhcp boot=mmc mmcdev=1 bootpart=1:2
Switch to using bootstd. Note with this change, we will stop using distro_bootcmd and instead depend entirely on bootflow method of starting the system up.
Signed-off-by: Nishanth Menon nm@ti.com --- configs/j721e_evm_a72_defconfig | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 99e0e168ebf7..98ac7ca59789 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -29,10 +29,11 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -CONFIG_BOOTCOMMAND="run envboot; run distro_bootcmd;" +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y
Hi Nishanth,
Coming back to [0], AM62x didn't have early remote procs but j721e does, do you have any alternatives in place before migrating J7 platforms to stdboot?
Regards, Manorit
[0]: https://lore.kernel.org/u-boot/20231005171010.zvza7uqyn4mcgp5g@handsaw/
CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -- 2.40.0
On 10:58-20231106, Manorit Chawdhry wrote:
Hi Nishanth,
As I have stated before. distro boot support for remote proc has been hacked up atm. what needs to happen is standardize it. Which is independent of this series.
Please discuss with stdboot folks how to get it in. WORST case, envboot is still supported, so in effect, what is achieved today can still continue to occur with envboot.
Regards, Manorit
Hi Nishanth,
There's not "stdboot folks" to talk with about this. The first step would be someone from TI posting some RFC patches about how exactly the remote proc support should be handled in that case, explaining where the what being run comes from and so forth. Maybe the answer is that "envboot" just keeps being defined and run before hand because that's the standard way to handle what needs doing on those processors? At least personally I feel like there's a gap in knowledge of what the use cases here are. Thanks.
Allow the reuse of k3-j721e-binman for other platforms such as BeagleBone-AI64. We don't need to build SK device tree blobs in-order to be able to build dtbs for single configuration platforms.
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/k3-j721e-binman.dtsi | 21 ++++++++++++++++++- .../k3-j721e-common-proc-board-u-boot.dtsi | 2 ++ arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 2 ++ 3 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi index 4f566c21a9af..d9c4fbf593af 100644 --- a/arch/arm/dts/k3-j721e-binman.dtsi +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -296,11 +296,14 @@
#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_J721E_EVM_DTB "spl/dts/k3-j721e-common-proc-board.dtb" -#define SPL_J721E_SK_DTB "spl/dts/k3-j721e-sk.dtb"
#define UBOOT_NODTB "u-boot-nodtb.bin" #define J721E_EVM_DTB "u-boot.dtb" + +#ifdef DUAL_DTB_BINMAN +#define SPL_J721E_SK_DTB "spl/dts/k3-j721e-sk.dtb" #define J721E_SK_DTB "arch/arm/dts/k3-j721e-sk.dtb" +#endif
&binman { ti-dm { @@ -400,6 +403,7 @@ }; };
+#ifdef DUAL_DTB_BINMAN fdt-1 { description = "k3-j721e-sk"; type = "flat_dt"; @@ -414,6 +418,7 @@ filename = SPL_J721E_SK_DTB; }; }; +#endif };
configurations { @@ -426,12 +431,14 @@ fdt = "fdt-0"; };
+#ifdef DUAL_DTB_BINMAN conf-1 { description = "k3-j721e-sk"; firmware = "atf"; loadables = "tee", "dm", "spl"; fdt = "fdt-1"; }; +#endif }; }; }; @@ -482,6 +489,7 @@ }; };
+#ifdef DUAL_DTB_BINMAN fdt-1 { description = "k3-j721e-sk"; type = "flat_dt"; @@ -499,6 +507,7 @@ algo = "crc32"; }; }; +#endif };
configurations { @@ -511,12 +520,14 @@ fdt = "fdt-0"; };
+#ifdef DUAL_DTB_BINMAN conf-1 { description = "k3-j721e-sk"; firmware = "uboot"; loadables = "uboot"; fdt = "fdt-1"; }; +#endif }; }; }; @@ -595,6 +606,7 @@ }; };
+#ifdef DUAL_DTB_BINMAN fdt-1 { description = "k3-j721e-sk"; type = "flat_dt"; @@ -604,6 +616,7 @@ filename = SPL_J721E_SK_DTB; }; }; +#endif };
configurations { @@ -616,12 +629,14 @@ fdt = "fdt-0"; };
+#ifdef DUAL_DTB_BINMAN conf-1 { description = "k3-j721e-sk"; firmware = "atf"; loadables = "tee", "dm", "spl"; fdt = "fdt-1"; }; +#endif }; }; }; @@ -664,6 +679,7 @@ }; };
+#ifdef DUAL_DTB_BINMAN fdt-1 { description = "k3-j721e-sk"; type = "flat_dt"; @@ -676,6 +692,7 @@ algo = "crc32"; }; }; +#endif };
configurations { @@ -688,12 +705,14 @@ fdt = "fdt-0"; };
+#ifdef DUAL_DTB_BINMAN conf-1 { description = "k3-j721e-sk"; firmware = "uboot"; loadables = "uboot"; fdt = "fdt-1"; }; +#endif }; }; }; diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index cd95907b981b..3317e902d677 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ */
+#define DUAL_DTB_BINMAN 1 + #include "k3-j721e-binman.dtsi"
&cbass_main { diff --git a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi index 370fe5190b2d..507964827547 100644 --- a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ */
&cbass_main {
Allow the reuse of k3-j721e-binman for other platforms such as BeagleBone-AI64. Provide a couple of macros to indicate the correct dtb to be able to re-use soc binman dtsi file
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/k3-j721e-binman.dtsi | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi index d9c4fbf593af..6166c931dea6 100644 --- a/arch/arm/dts/k3-j721e-binman.dtsi +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -295,16 +295,28 @@ #ifdef CONFIG_TARGET_J721E_A72_EVM
#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#ifndef SPL_J721E_EVM_DTB #define SPL_J721E_EVM_DTB "spl/dts/k3-j721e-common-proc-board.dtb" +#endif
#define UBOOT_NODTB "u-boot-nodtb.bin" + +#ifndef J721E_EVM_DTB #define J721E_EVM_DTB "u-boot.dtb" +#endif
#ifdef DUAL_DTB_BINMAN + +#ifndef SPL_J721E_SK_DTB #define SPL_J721E_SK_DTB "spl/dts/k3-j721e-sk.dtb" +#endif + +#ifndef J721E_SK_DTB #define J721E_SK_DTB "arch/arm/dts/k3-j721e-sk.dtb" #endif
+#endif + &binman { ti-dm { filename = "ti-dm.bin";
BeagleBoard.org BeagleBone AI-64 is an open source hardware single board computer based on the Texas Instruments TDA4VM SoC featuring dual-core 2.0GHz Arm Cortex-A72 processor, C7x+MMA and 2 C66x floating-point VLIW DSPs, 3x dual ARM Cortex-R5 co-processors, 2x 6-core Programmable Real-Time Unit and Industrial Communication SubSystem, PowerVR Rogue 8XE GE8430 3D GPU. The board features 4GB DDR4, USB3.0 Type-C, 2x USB SS Type-A, miniDisplayPort, 2x 4-lane CSI, DSI, 16GB eMMC flash, 1G Ethernet, M.2 E-key for WiFi/BT, and BeagleBone expansion headers.
This board family can be indentified by the BBONEAI-64-B0 in the at24 eeprom:
[aa 55 33 ee 01 37 00 10 2e 00 42 42 4f 4e 45 41 |.U3..7....BBONEA|] [49 2d 36 34 2d 42 30 2d 00 00 42 30 30 30 37 38 |I-64-B0-..B00078|]
Baseline of the devicetree is from v6.6-rc1
https://beagleboard.org/ai-64 https://git.beagleboard.org/beagleboard/beaglebone-ai-64
Signed-off-by: Robert Nelson robertcnelson@gmail.com Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/Makefile | 5 +- .../dts/k3-j721e-beagleboneai64-u-boot.dtsi | 206 ++ arch/arm/dts/k3-j721e-beagleboneai64.dts | 993 ++++++++ .../k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi | 2200 +++++++++++++++++ arch/arm/dts/k3-j721e-r5-beagleboneai64.dts | 96 + board/ti/j721e/MAINTAINERS | 7 + 6 files changed, 3506 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-j721e-beagleboneai64-u-boot.dtsi create mode 100644 arch/arm/dts/k3-j721e-beagleboneai64.dts create mode 100644 arch/arm/dts/k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-beagleboneai64.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 55aceb51cdb0..2a76acd312d8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1368,7 +1368,10 @@ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j7200-common-proc-board.dtb \ k3-j7200-r5-common-proc-board.dtb \ k3-j721e-sk.dtb \ - k3-j721e-r5-sk.dtb + k3-j721e-r5-sk.dtb \ + k3-j721e-beagleboneai64.dtb \ + k3-j721e-r5-beagleboneai64.dtb + dtb-$(CONFIG_SOC_K3_J721S2) += k3-am68-sk-base-board.dtb\ k3-am68-sk-r5-base-board.dtb\ k3-j721s2-common-proc-board.dtb\ diff --git a/arch/arm/dts/k3-j721e-beagleboneai64-u-boot.dtsi b/arch/arm/dts/k3-j721e-beagleboneai64-u-boot.dtsi new file mode 100644 index 000000000000..7080906ef8de --- /dev/null +++ b/arch/arm/dts/k3-j721e-beagleboneai64-u-boot.dtsi @@ -0,0 +1,206 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * https://beagleboard.org/ai-64 + * + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022 Jason Kridner, BeagleBoard.org Foundation + * Copyright (C) 2022-2023 Robert Nelson, BeagleBoard.org Foundation + */ + +/ { + memory@80000000 { + bootph-all; + }; + + /* Keep the LEDs on by default to indicate life */ + leds { + bootph-all; + led-0 { + default-state = "on"; + bootph-all; + }; + + led-1 { + default-state = "on"; + bootph-all; + }; + + led-2 { + default-state = "on"; + bootph-all; + }; + + led-3 { + default-state = "on"; + bootph-all; + }; + + led-4 { + default-state = "on"; + bootph-all; + }; + }; +}; + +&cbass_main { + bootph-all; +}; + +&main_navss { + bootph-all; +}; + +&cbass_mcu_wakeup { + bootph-all; + + chipid@43000014 { + bootph-all; + }; +}; + +&mcu_navss { + bootph-all; +}; + +&mcu_ringacc { + reg = <0x0 0x2b800000 0x0 0x400000>, + <0x0 0x2b000000 0x0 0x400000>, + <0x0 0x28590000 0x0 0x100>, + <0x0 0x2a500000 0x0 0x40000>, + <0x0 0x28440000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; + bootph-all; +}; + +&mcu_udmap { + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x284c0000 0x0 0x4000>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x284a0000 0x0 0x4000>, + <0x0 0x2aa00000 0x0 0x40000>, + <0x0 0x28400000 0x0 0x2000>; + reg-names = "gcfg", "rchan", "rchanrt", "tchan", + "tchanrt", "rflow"; + bootph-all; +}; + +&secure_proxy_main { + bootph-all; +}; + +&dmsc { + bootph-all; + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + bootph-all; + }; +}; + +&k3_pds { + bootph-all; +}; + +&k3_clks { + bootph-all; +}; + +&k3_reset { + bootph-all; +}; + +&wkup_pmx0 { + bootph-all; +}; + +&main_pmx0 { + bootph-all; +}; + +&main_uart0 { + bootph-all; +}; + +&main_gpio0 { + bootph-all; +}; + +&main_uart0_pins_default { + bootph-all; +}; + +&main_sdhci0 { + bootph-all; +}; + +&main_sdhci1 { + bootph-all; + sdhci-caps-mask = <0x00000007 0x00000000>; + /delete-property/ cd-gpios; + /delete-property/ cd-debounce-delay-ms; + /delete-property/ ti,fails-without-test-cd; + /delete-property/ no-1-8-v; +}; + +&main_mmc1_pins_default { + bootph-all; +}; + +&mcu_cpsw { + bootph-all; +}; + +&davinci_mdio { + bootph-all; +}; + +&phy0 { + bootph-all; +}; + +&serdes2 { + bootph-all; +}; + +&serdes_ln_ctrl { + bootph-all; +}; + +&serdes2_usb_link { + bootph-all; +}; + +&usb_serdes_mux { + bootph-all; +}; + +&serdes_wiz2 { + bootph-all; +}; + +&main_usbss1_pins_default { + bootph-all; +}; + +&mcu_usbss1_pins_default { + bootph-all; +}; + +&usbss1 { + bootph-all; +}; + +&usb1 { + bootph-all; +}; + +&wkup_i2c0_pins_default { + bootph-all; +}; + +&wkup_i2c0 { + bootph-all; +}; + +#define SPL_J721E_EVM_DTB "spl/dts/k3-j721e-beagleboneai64.dtb" +#define J721E_EVM_DTB "arch/arm/dts/k3-j721e-beagleboneai64.dtb" +#include "k3-j721e-binman.dtsi" diff --git a/arch/arm/dts/k3-j721e-beagleboneai64.dts b/arch/arm/dts/k3-j721e-beagleboneai64.dts new file mode 100644 index 000000000000..2f954729f353 --- /dev/null +++ b/arch/arm/dts/k3-j721e-beagleboneai64.dts @@ -0,0 +1,993 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * https://beagleboard.org/ai-64 + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022 Jason Kridner, BeagleBoard.org Foundation + * Copyright (C) 2022 Robert Nelson, BeagleBoard.org Foundation + */ + +/dts-v1/; + +#include "k3-j721e.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/net/ti-dp83867.h> +#include <dt-bindings/phy/phy-cadence.h> + +/ { + compatible = "beagle,j721e-beagleboneai64", "ti,j721e"; + model = "BeagleBoard.org BeagleBone AI-64"; + + aliases { + serial0 = &wkup_uart0; + serial2 = &main_uart0; + mmc0 = &main_sdhci0; + mmc1 = &main_sdhci1; + i2c0 = &wkup_i2c0; + i2c1 = &main_i2c6; + i2c2 = &main_i2c2; + i2c3 = &main_i2c4; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + memory@80000000 { + device_type = "memory"; + /* 4G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>, + <0x00000008 0x80000000 0x00000000 0x80000000>; + }; + + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + no-map; + }; + + mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa0000000 0x00 0x100000>; + no-map; + }; + + mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa0100000 0x00 0xf00000>; + no-map; + }; + + mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa1000000 0x00 0x100000>; + no-map; + }; + + mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa1100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa2000000 0x00 0x100000>; + no-map; + }; + + main_r5fss0_core0_memory_region: r5f-memory@a2100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa2100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa3000000 0x00 0x100000>; + no-map; + }; + + main_r5fss0_core1_memory_region: r5f-memory@a3100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa3100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss1_core0_dma_memory_region: r5f-dma-memory@a4000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa4000000 0x00 0x100000>; + no-map; + }; + + main_r5fss1_core0_memory_region: r5f-memory@a4100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa4100000 0x00 0xf00000>; + no-map; + }; + + main_r5fss1_core1_dma_memory_region: r5f-dma-memory@a5000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa5000000 0x00 0x100000>; + no-map; + }; + + main_r5fss1_core1_memory_region: r5f-memory@a5100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa5100000 0x00 0xf00000>; + no-map; + }; + + c66_1_dma_memory_region: c66-dma-memory@a6000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa6000000 0x00 0x100000>; + no-map; + }; + + c66_0_memory_region: c66-memory@a6100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa6100000 0x00 0xf00000>; + no-map; + }; + + c66_0_dma_memory_region: c66-dma-memory@a7000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa7000000 0x00 0x100000>; + no-map; + }; + + c66_1_memory_region: c66-memory@a7100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa7100000 0x00 0xf00000>; + no-map; + }; + + c71_0_dma_memory_region: c71-dma-memory@a8000000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa8000000 0x00 0x100000>; + no-map; + }; + + c71_0_memory_region: c71-memory@a8100000 { + compatible = "shared-dma-pool"; + reg = <0x00 0xa8100000 0x00 0xf00000>; + no-map; + }; + + rtos_ipc_memory_region: ipc-memories@aa000000 { + reg = <0x00 0xaa000000 0x00 0x01c00000>; + alignment = <0x1000>; + no-map; + }; + }; + + gpio_keys: gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&sw_pwr_pins_default>; + + button-1 { + label = "BOOT"; + linux,code = <BTN_0>; + gpios = <&wkup_gpio0 0 GPIO_ACTIVE_LOW>; + }; + + button-2 { + label = "POWER"; + linux,code = <KEY_POWER>; + gpios = <&wkup_gpio0 4 GPIO_ACTIVE_LOW>; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_default>; + + led-0 { + gpios = <&main_gpio0 96 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_HEARTBEAT; + linux,default-trigger = "heartbeat"; + }; + + led-1 { + gpios = <&main_gpio0 95 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_DISK_ACTIVITY; + linux,default-trigger = "mmc0"; + }; + + led-2 { + gpios = <&main_gpio0 97 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_CPU; + linux,default-trigger = "cpu"; + }; + + led-3 { + gpios = <&main_gpio0 110 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_DISK_ACTIVITY; + linux,default-trigger = "mmc1"; + }; + + led-4 { + gpios = <&main_gpio0 109 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_WLAN; + default-state = "off"; + }; + }; + + evm_12v0: regulator-0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "evm_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: regulator-1 { + /* Output of LMS140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_5v0: regulator-2 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_mmc1: regulator-3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&sd_pwr_en_pins_default>; + regulator-name = "vdd_mmc1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + enable-active-high; + vin-supply = <&vsys_3v3>; + gpio = <&main_gpio0 82 GPIO_ACTIVE_HIGH>; + }; + + vdd_sd_dv_alt: regulator-4 { + compatible = "regulator-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&vdd_sd_dv_alt_pins_default>; + regulator-name = "tlv71033"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + vin-supply = <&vsys_5v0>; + gpios = <&main_gpio0 117 GPIO_ACTIVE_HIGH>; + states = <1800000 0x0>, + <3300000 0x1>; + }; + + dp_pwr_3v3: regulator-5 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&dp0_3v3_en_pins_default>; + regulator-name = "dp-pwr"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&main_gpio0 49 GPIO_ACTIVE_HIGH>; /* DP0_PWR_SW_EN */ + enable-active-high; + }; + + dp0: connector { + compatible = "dp-connector"; + label = "DP0"; + type = "full-size"; + dp-pwr-supply = <&dp_pwr_3v3>; + + port { + dp_connector_in: endpoint { + remote-endpoint = <&dp0_out>; + }; + }; + }; +}; + +&main_pmx0 { + led_pins_default: led-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x184, PIN_INPUT, 7) /* (T23) RGMII5_RD0.GPIO0_96 */ + J721E_IOPAD(0x180, PIN_INPUT, 7) /* (R23) RGMII5_RD1.GPIO0_95 */ + J721E_IOPAD(0x188, PIN_INPUT, 7) /* (Y28) RGMII6_TX_CTL.GPIO0_97 */ + J721E_IOPAD(0x1bc, PIN_INPUT, 7) /* (V24) MDIO0_MDC.GPIO0_110 */ + J721E_IOPAD(0x1b8, PIN_INPUT, 7) /* (V26) MDIO0_MDIO.GPIO0_109 */ + >; + }; + + main_mmc1_pins_default: main-mmc1-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */ + J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */ + J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ + J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */ + J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */ + J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */ + J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */ + >; + }; + + main_uart0_pins_default: main-uart0-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x1e8, PIN_INPUT, 0) /* (AB2) UART0_RXD */ + J721E_IOPAD(0x1ec, PIN_OUTPUT, 0) /* (AB3) UART0_TXD */ + >; + }; + + sd_pwr_en_pins_default: sd-pwr-en-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x14c, PIN_INPUT, 7) /* (AA29) PRG0_PRU1_GPO19.GPIO0_82 */ + >; + }; + + vdd_sd_dv_alt_pins_default: vdd-sd-dv-alt-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x1d8, PIN_INPUT, 7) /* (W4) SPI1_CS1.GPIO0_117 */ + >; + }; + + main_usbss0_pins_default: main-usbss0-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 - USBC_DIR */ + >; + }; + + main_usbss1_pins_default: main-usbss1-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x290, INPUT_DISABLE, 1) /* (U6) USB0_DRVVBUS.USB1_DRVVBUS */ + >; + }; + + dp0_3v3_en_pins_default:dp0-3v3-en-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0xc8, PIN_INPUT, 7) /* (AE26) PRG0_PRU0_GPO6.GPIO0_49 */ + >; + }; + + dp0_pins_default: dp0-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* (Y4) SPI0_CS1.DP0_HPD */ + >; + }; + + main_i2c0_pins_default: main-i2c0-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */ + J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */ + >; + }; + + main_i2c1_pins_default: main-i2c1-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */ + J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */ + >; + }; + + main_i2c2_pins_default: main-i2c2-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x208, PIN_INPUT_PULLUP, 4) /* (W5) MCAN0_RX.I2C2_SCL */ + J721E_IOPAD(0x20c, PIN_INPUT_PULLUP, 4) /* (W6) MCAN0_TX.I2C2_SDA */ + J721E_IOPAD(0x138, PIN_INPUT, 7) /* (AE25) PRG0_PRU1_GPO14.GPIO0_77 */ + J721E_IOPAD(0x13c, PIN_INPUT, 7) /* (AF29) PRG0_PRU1_GPO15.GPIO0_78 */ + >; + }; + + main_i2c3_pins_default: main-i2c3-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */ + J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */ + >; + }; + + main_i2c4_pins_default: main-i2c4-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x1e0, PIN_INPUT_PULLUP, 2) /* (Y5) SPI1_D0.I2C4_SCL */ + J721E_IOPAD(0x1dc, PIN_INPUT_PULLUP, 2) /* (Y1) SPI1_CLK.I2C4_SDA */ + J721E_IOPAD(0x30, PIN_INPUT, 7) /* (AF24) PRG1_PRU0_GPO11.GPIO0_12 */ + J721E_IOPAD(0x34, PIN_INPUT, 7) /* (AJ24) PRG1_PRU0_GPO12.GPIO0_13 */ + >; + }; + + main_i2c5_pins_default: main-i2c5-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x150, PIN_INPUT_PULLUP, 2) /* (Y26) PRG0_MDIO0_MDIO.I2C5_SCL */ + J721E_IOPAD(0x154, PIN_INPUT_PULLUP, 2) /* (AA27) PRG0_MDIO0_MDC.I2C5_SDA */ + >; + }; + + main_i2c6_pins_default: main-i2c6-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x1d0, PIN_INPUT_PULLUP, 2) /* (AA3) SPI0_D1.I2C6_SCL */ + J721E_IOPAD(0x1e4, PIN_INPUT_PULLUP, 2) /* (Y2) SPI1_D1.I2C6_SDA */ + J721E_IOPAD(0x74, PIN_INPUT, 7) /* (AC21) PRG1_PRU1_GPO7.GPIO0_28 */ + J721E_IOPAD(0xa4, PIN_INPUT, 7) /* (AH22) PRG1_PRU1_GPO19.GPIO0_40 */ + >; + }; + + csi0_gpio_pins_default: csi0-gpio-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x19c, PIN_INPUT_PULLDOWN, 7) /* (W27) RGMII6_TD0.GPIO0_102 */ + J721E_IOPAD(0x1a0, PIN_INPUT_PULLDOWN, 7) /* (W29) RGMII6_TXC.GPIO0_103 */ + >; + }; + + csi1_gpio_pins_default: csi1-gpio-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x198, PIN_INPUT_PULLDOWN, 7) /* (V25) RGMII6_TD1.GPIO0_101 */ + J721E_IOPAD(0x1b0, PIN_INPUT_PULLDOWN, 7) /* (W24) RGMII6_RD1.GPIO0_107 */ + >; + }; + + pcie1_rst_pins_default: pcie1-rst-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x5c, PIN_INPUT, 7) /* (AG23) PRG1_PRU1_GPO1.GPIO0_22 */ + >; + }; +}; + +&wkup_pmx0 { + eeprom_wp_pins_default: eeprom-wp-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xc4, PIN_OUTPUT_PULLUP, 7) /* (G24) WKUP_GPIO0_5 */ + >; + }; + + mcu_adc0_pins_default: mcu-adc0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x130, PIN_INPUT, 0) /* (K25) MCU_ADC0_AIN0 */ + J721E_WKUP_IOPAD(0x134, PIN_INPUT, 0) /* (K26) MCU_ADC0_AIN1 */ + J721E_WKUP_IOPAD(0x138, PIN_INPUT, 0) /* (K28) MCU_ADC0_AIN2 */ + J721E_WKUP_IOPAD(0x13c, PIN_INPUT, 0) /* (L28) MCU_ADC0_AIN3 */ + J721E_WKUP_IOPAD(0x140, PIN_INPUT, 0) /* (K24) MCU_ADC0_AIN4 */ + J721E_WKUP_IOPAD(0x144, PIN_INPUT, 0) /* (K27) MCU_ADC0_AIN5 */ + J721E_WKUP_IOPAD(0x148, PIN_INPUT, 0) /* (K29) MCU_ADC0_AIN6 */ + >; + }; + + mcu_adc1_pins_default: mcu-adc1-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x150, PIN_INPUT, 0) /* (N23) MCU_ADC1_AIN0 */ + >; + }; + + mikro_bus_pins_default: mikro-bus-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x108, PIN_INPUT, 7) /* SDAPULLEN (E26) PMIC_POWER_EN0.WKUP_GPIO0_66 */ + J721E_WKUP_IOPAD(0xd4, PIN_INPUT, 7) /* SDA (G26) WKUP_GPIO0_9.MCU_I2C1_SDA */ + J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 7) /* SDA (D25) MCU_I3C0_SDA.WKUP_GPIO0_61 */ + J721E_WKUP_IOPAD(0xd0, PIN_INPUT, 7) /* SCL (G27) WKUP_GPIO0_8.MCU_I2C1_SCL */ + J721E_WKUP_IOPAD(0xf0, PIN_INPUT, 7) /* SCL (D26) MCU_I3C0_SCL.WKUP_GPIO0_60 */ + + J721E_WKUP_IOPAD(0xb8, PIN_INPUT, 7) /* MOSI (F28) WKUP_GPIO0_2.MCU_SPI1_D1 */ + J721E_WKUP_IOPAD(0xb4, PIN_INPUT, 7) /* MISO (F25) WKUP_GPIO0_1.MCU_SPI1_D0 */ + J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 7) /* CLK (F26) WKUP_GPIO0_0.MCU_SPI1_CLK */ + J721E_WKUP_IOPAD(0xbc, PIN_INPUT, 7) /* CS (F27) WKUP_GPIO0_3.MCU_SPI1_CS0 */ + + J721E_WKUP_IOPAD(0x44, PIN_INPUT, 7) /* RX (G22) MCU_OSPI1_D1.WKUP_GPIO0_33 */ + J721E_WKUP_IOPAD(0x48, PIN_INPUT, 7) /* TX (D23) MCU_OSPI1_D2.WKUP_GPIO0_34 */ + + J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 7) /* INT (C23) MCU_OSPI1_D3.WKUP_GPIO0_35 */ + J721E_WKUP_IOPAD(0x54, PIN_INPUT, 7) /* RST (E22) MCU_OSPI1_CSn1.WKUP_GPIO0_37 */ + J721E_WKUP_IOPAD(0xdc, PIN_INPUT, 7) /* PWM (H27) WKUP_GPIO0_11 */ + J721E_WKUP_IOPAD(0xac, PIN_INPUT, 7) /* AN (C29) MCU_MCAN0_RX.WKUP_GPIO0_59 */ + >; + }; + + mcu_cpsw_pins_default: mcu-cpsw-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x84, PIN_INPUT, 0) /* (B24) MCU_RGMII1_RD0 */ + J721E_WKUP_IOPAD(0x80, PIN_INPUT, 0) /* (A24) MCU_RGMII1_RD1 */ + J721E_WKUP_IOPAD(0x7c, PIN_INPUT, 0) /* (D24) MCU_RGMII1_RD2 */ + J721E_WKUP_IOPAD(0x78, PIN_INPUT, 0) /* (A25) MCU_RGMII1_RD3 */ + J721E_WKUP_IOPAD(0x74, PIN_INPUT, 0) /* (C24) MCU_RGMII1_RXC */ + J721E_WKUP_IOPAD(0x5c, PIN_INPUT, 0) /* (C25) MCU_RGMII1_RX_CTL */ + J721E_WKUP_IOPAD(0x6c, PIN_OUTPUT, 0) /* (B25) MCU_RGMII1_TD0 */ + J721E_WKUP_IOPAD(0x68, PIN_OUTPUT, 0) /* (A26) MCU_RGMII1_TD1 */ + J721E_WKUP_IOPAD(0x64, PIN_OUTPUT, 0) /* (A27) MCU_RGMII1_TD2 */ + J721E_WKUP_IOPAD(0x60, PIN_OUTPUT, 0) /* (A28) MCU_RGMII1_TD3 */ + J721E_WKUP_IOPAD(0x70, PIN_OUTPUT, 0) /* (B26) MCU_RGMII1_TXC */ + J721E_WKUP_IOPAD(0x58, PIN_OUTPUT, 0) /* (B27) MCU_RGMII1_TX_CTL */ + >; + }; + + mcu_mdio_pins_default: mcu-mdio1-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x8c, PIN_OUTPUT, 0) /* (F23) MCU_MDIO0_MDC */ + J721E_WKUP_IOPAD(0x88, PIN_INPUT, 0) /* (E23) MCU_MDIO0_MDIO */ + >; + }; + + sw_pwr_pins_default: sw-pwr-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xc0, PIN_INPUT, 7) /* (G25) WKUP_GPIO0_4 */ + >; + }; + + wkup_i2c0_pins_default: wkup-i2c0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf8, PIN_INPUT_PULLUP, 0) /* (J25) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0xfc, PIN_INPUT_PULLUP, 0) /* (H24) WKUP_I2C0_SDA */ + >; + }; + + wkup_uart0_pins_default: wkup-uart0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xa0, PIN_INPUT, 0) /* (J29) WKUP_UART0_RXD */ + J721E_WKUP_IOPAD(0xa4, PIN_OUTPUT, 0) /* (J28) WKUP_UART0_TXD */ + >; + }; + + mcu_usbss1_pins_default: mcu-usbss1-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x3c, PIN_OUTPUT_PULLUP, 5) /* (A23) MCU_OSPI1_LBCLKO.WKUP_GPIO0_30 */ + >; + }; +}; + +&wkup_uart0 { + /* Wakeup UART is used by TIFS firmware. */ + status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; +}; + +&main_uart0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; + /* Shared with ATF on this platform */ + power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; +}; + +&main_sdhci0 { + /* eMMC */ + status = "okay"; + non-removable; + ti,driver-strength-ohm = <50>; + disable-wp; +}; + +&main_sdhci1 { + /* SD Card */ + status = "okay"; + vmmc-supply = <&vdd_mmc1>; + vqmmc-supply = <&vdd_sd_dv_alt>; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; +}; + +&main_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c1_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c2 { + /* BBB Header: P9.19 and P9.20 */ + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c2_pins_default>; + clock-frequency = <100000>; +}; + +&main_i2c3 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c3_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c4 { + /* BBB Header: P9.24 and P9.26 */ + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c4_pins_default>; + clock-frequency = <100000>; +}; + +&main_i2c5 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c5_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c6 { + /* BBB Header: P9.17 and P9.18 */ + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c6_pins_default>; + clock-frequency = <100000>; + status = "okay"; +}; + +&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + eeprom@50 { + compatible = "atmel,24c04"; + reg = <0x50>; + pinctrl-names = "default"; + pinctrl-0 = <&eeprom_wp_pins_default>; + }; +}; + +&wkup_gpio0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_adc0_pins_default>, <&mcu_adc1_pins_default>, + <&mikro_bus_pins_default>; +}; + +&main_gpio0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&csi1_gpio_pins_default>, <&csi0_gpio_pins_default>; +}; + +&main_gpio1 { + status = "okay"; +}; + +&usb_serdes_mux { + idle-states = <1>, <1>; /* USB0 to SERDES3, USB1 to SERDES2 */ +}; + +&serdes_ln_ctrl { + idle-states = <J721E_SERDES0_LANE0_IP4_UNUSED>, <J721E_SERDES0_LANE1_IP4_UNUSED>, + <J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>, + <J721E_SERDES2_LANE0_IP1_UNUSED>, <J721E_SERDES2_LANE1_USB3_1>, + <J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>, + <J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>, + <J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>; +}; + +&serdes_wiz3 { + typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_LOW>; + typec-dir-debounce-ms = <700>; /* TUSB321, tCCB_DEFAULT 133 ms */ +}; + +&serdes3 { + serdes3_usb_link: phy@0 { + reg = <0>; + cdns,num-lanes = <2>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_USB3>; + resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>; + }; +}; + +&serdes4 { + torrent_phy_dp: phy@0 { + reg = <0>; + resets = <&serdes_wiz4 1>; + cdns,phy-type = <PHY_TYPE_DP>; + cdns,num-lanes = <4>; + cdns,max-bit-rate = <5400>; + #phy-cells = <0>; + }; +}; + +&mhdp { + phys = <&torrent_phy_dp>; + phy-names = "dpphy"; + pinctrl-names = "default"; + pinctrl-0 = <&dp0_pins_default>; +}; + +&usbss0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss0_pins_default>; + ti,vbus-divider; +}; + +&usb0 { + dr_mode = "peripheral"; + maximum-speed = "super-speed"; + phys = <&serdes3_usb_link>; + phy-names = "cdns3,usb3-phy"; +}; + +&serdes2 { + serdes2_usb_link: phy@1 { + reg = <1>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_USB3>; + resets = <&serdes_wiz2 2>; + }; +}; + +&usbss1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss1_pins_default>, <&mcu_usbss1_pins_default>; + ti,vbus-divider; +}; + +&usb1 { + dr_mode = "host"; + maximum-speed = "super-speed"; + phys = <&serdes2_usb_link>; + phy-names = "cdns3,usb3-phy"; +}; + +&tscadc0 { + status = "okay"; + /* BBB Header: P9.39, P9.40, P9.37, P9.38, P9.33, P9.36, P9.35 */ + adc { + ti,adc-channels = <0 1 2 3 4 5 6>; + }; +}; + +&tscadc1 { + status = "okay"; + /* MCU mikroBUS Header J10.1 - MCU_ADC1_AIN0 */ + adc { + ti,adc-channels = <0>; + }; +}; + +&mcu_cpsw { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_cpsw_pins_default>; +}; + +&davinci_mdio { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_mdio_pins_default>; + + phy0: ethernet-phy@0 { + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&phy0>; +}; + +&dss { + /* + * These clock assignments are chosen to enable the following outputs: + * + * VP0 - DisplayPort SST + * VP1 - DPI0 + * VP2 - DSI + * VP3 - DPI1 + */ + + assigned-clocks = <&k3_clks 152 1>, /* VP 1 pixel clock */ + <&k3_clks 152 4>, /* VP 2 pixel clock */ + <&k3_clks 152 9>, /* VP 3 pixel clock */ + <&k3_clks 152 13>; /* VP 4 pixel clock */ + assigned-clock-parents = <&k3_clks 152 2>, /* PLL16_HSDIV0 */ + <&k3_clks 152 6>, /* PLL19_HSDIV0 */ + <&k3_clks 152 11>, /* PLL18_HSDIV0 */ + <&k3_clks 152 18>; /* PLL23_HSDIV0 */ +}; + +&dss_ports { + port { + dpi0_out: endpoint { + remote-endpoint = <&dp0_in>; + }; + }; +}; + +&dp0_ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + dp0_in: endpoint { + remote-endpoint = <&dpi0_out>; + }; + }; + + port@4 { + reg = <4>; + dp0_out: endpoint { + remote-endpoint = <&dp_connector_in>; + }; + }; +}; + +&serdes0 { + serdes0_pcie_link: phy@0 { + reg = <0>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_PCIE>; + resets = <&serdes_wiz0 1>; + }; +}; + +&serdes1 { + serdes1_pcie_link: phy@0 { + reg = <0>; + cdns,num-lanes = <2>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_PCIE>; + resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>; + }; +}; + +&pcie1_rc { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&pcie1_rst_pins_default>; + phys = <&serdes1_pcie_link>; + phy-names = "pcie-phy"; + num-lanes = <2>; + max-link-speed = <3>; + reset-gpios = <&main_gpio0 22 GPIO_ACTIVE_HIGH>; +}; + +&ufs_wrapper { + status = "disabled"; +}; + +&mailbox0_cluster0 { + status = "okay"; + interrupts = <436>; + + mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster1 { + status = "okay"; + interrupts = <432>; + + mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster2 { + status = "okay"; + interrupts = <428>; + + mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster3 { + status = "okay"; + interrupts = <424>; + + mbox_c66_0: mbox-c66-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; + + mbox_c66_1: mbox-c66-1 { + ti,mbox-rx = <2 0 0>; + ti,mbox-tx = <3 0 0>; + }; +}; + +&mailbox0_cluster4 { + status = "okay"; + interrupts = <420>; + + mbox_c71_0: mbox-c71-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; +}; + +&mcu_r5fss0_core0 { + mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core0>; + memory-region = <&mcu_r5fss0_core0_dma_memory_region>, + <&mcu_r5fss0_core0_memory_region>; +}; + +&mcu_r5fss0_core1 { + mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core1>; + memory-region = <&mcu_r5fss0_core1_dma_memory_region>, + <&mcu_r5fss0_core1_memory_region>; +}; + +&main_r5fss0_core0 { + mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core0>; + memory-region = <&main_r5fss0_core0_dma_memory_region>, + <&main_r5fss0_core0_memory_region>; +}; + +&main_r5fss0_core1 { + mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core1>; + memory-region = <&main_r5fss0_core1_dma_memory_region>, + <&main_r5fss0_core1_memory_region>; +}; + +&main_r5fss1_core0 { + mboxes = <&mailbox0_cluster2>, <&mbox_main_r5fss1_core0>; + memory-region = <&main_r5fss1_core0_dma_memory_region>, + <&main_r5fss1_core0_memory_region>; +}; + +&main_r5fss1_core1 { + mboxes = <&mailbox0_cluster2>, <&mbox_main_r5fss1_core1>; + memory-region = <&main_r5fss1_core1_dma_memory_region>, + <&main_r5fss1_core1_memory_region>; +}; + +&c66_0 { + status = "okay"; + mboxes = <&mailbox0_cluster3>, <&mbox_c66_0>; + memory-region = <&c66_0_dma_memory_region>, + <&c66_0_memory_region>; +}; + +&c66_1 { + status = "okay"; + mboxes = <&mailbox0_cluster3>, <&mbox_c66_1>; + memory-region = <&c66_1_dma_memory_region>, + <&c66_1_memory_region>; +}; + +&c71_0 { + status = "okay"; + mboxes = <&mailbox0_cluster4>, <&mbox_c71_0>; + memory-region = <&c71_0_dma_memory_region>, + <&c71_0_memory_region>; +}; diff --git a/arch/arm/dts/k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi b/arch/arm/dts/k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi new file mode 100644 index 000000000000..89e17751ade3 --- /dev/null +++ b/arch/arm/dts/k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi @@ -0,0 +1,2200 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019-2023 Texas Instruments Incorporated - http://www.ti.com/ + * This file was generated by the Jacinto7_DDRSS_RegConfigTool, Revision: 0.10.1 + * This file was generated on 02/08/2023 + * Part Number: Kingston Q3222PM1WDGTK-U + * Configuration: LPDDR4-3200, wrDBI enabled, j721e-SK latencies + * Also common for: + * * Part Number: Samsung K4FBE3D4HM-MGC @ LPDDR4-3200 (instead of 3700) + */ + +#define DDRSS_PLL_FHS_CNT 10 +#define DDRSS_PLL_FREQUENCY_0 27500000 +#define DDRSS_PLL_FREQUENCY_1 800000000 +#define DDRSS_PLL_FREQUENCY_2 800000000 + +#define DDRSS_CTL_00_DATA 0x00000B00 +#define DDRSS_CTL_01_DATA 0x00000000 +#define DDRSS_CTL_02_DATA 0x00000000 +#define DDRSS_CTL_03_DATA 0x00000000 +#define DDRSS_CTL_04_DATA 0x00000000 +#define DDRSS_CTL_05_DATA 0x00000000 +#define DDRSS_CTL_06_DATA 0x00000000 +#define DDRSS_CTL_07_DATA 0x00002AF8 +#define DDRSS_CTL_08_DATA 0x0001ADAF +#define DDRSS_CTL_09_DATA 0x00000005 +#define DDRSS_CTL_10_DATA 0x0000006E +#define DDRSS_CTL_11_DATA 0x0004E200 +#define DDRSS_CTL_12_DATA 0x0030D400 +#define DDRSS_CTL_13_DATA 0x00000005 +#define DDRSS_CTL_14_DATA 0x00000C80 +#define DDRSS_CTL_15_DATA 0x0004E200 +#define DDRSS_CTL_16_DATA 0x0030D400 +#define DDRSS_CTL_17_DATA 0x00000005 +#define DDRSS_CTL_18_DATA 0x00000C80 +#define DDRSS_CTL_19_DATA 0x01010000 +#define DDRSS_CTL_20_DATA 0x02011001 +#define DDRSS_CTL_21_DATA 0x02010000 +#define DDRSS_CTL_22_DATA 0x00020100 +#define DDRSS_CTL_23_DATA 0x0000000B +#define DDRSS_CTL_24_DATA 0x0000001C +#define DDRSS_CTL_25_DATA 0x00000000 +#define DDRSS_CTL_26_DATA 0x00000000 +#define DDRSS_CTL_27_DATA 0x03020200 +#define DDRSS_CTL_28_DATA 0x00004040 +#define DDRSS_CTL_29_DATA 0x00100000 +#define DDRSS_CTL_30_DATA 0x00000000 +#define DDRSS_CTL_31_DATA 0x00000000 +#define DDRSS_CTL_32_DATA 0x00000000 +#define DDRSS_CTL_33_DATA 0x00000000 +#define DDRSS_CTL_34_DATA 0x040C0000 +#define DDRSS_CTL_35_DATA 0x0E380E38 +#define DDRSS_CTL_36_DATA 0x00050804 +#define DDRSS_CTL_37_DATA 0x09040008 +#define DDRSS_CTL_38_DATA 0x14000304 +#define DDRSS_CTL_39_DATA 0x15480068 +#define DDRSS_CTL_40_DATA 0x14004220 +#define DDRSS_CTL_41_DATA 0x15480068 +#define DDRSS_CTL_42_DATA 0x20004220 +#define DDRSS_CTL_43_DATA 0x000A0A09 +#define DDRSS_CTL_44_DATA 0x0400078A +#define DDRSS_CTL_45_DATA 0x17100D04 +#define DDRSS_CTL_46_DATA 0x0C00DB60 +#define DDRSS_CTL_47_DATA 0x17100D0C +#define DDRSS_CTL_48_DATA 0x0C00DB60 +#define DDRSS_CTL_49_DATA 0x0203040C +#define DDRSS_CTL_50_DATA 0x21040500 +#define DDRSS_CTL_51_DATA 0x08222122 +#define DDRSS_CTL_52_DATA 0x14000E0A +#define DDRSS_CTL_53_DATA 0x03010A0A +#define DDRSS_CTL_54_DATA 0x01010003 +#define DDRSS_CTL_55_DATA 0x04424208 +#define DDRSS_CTL_56_DATA 0x04252504 +#define DDRSS_CTL_57_DATA 0x00002525 +#define DDRSS_CTL_58_DATA 0x00010100 +#define DDRSS_CTL_59_DATA 0x03010000 +#define DDRSS_CTL_60_DATA 0x00001008 +#define DDRSS_CTL_61_DATA 0x000000CE +#define DDRSS_CTL_62_DATA 0x000001C0 +#define DDRSS_CTL_63_DATA 0x00001858 +#define DDRSS_CTL_64_DATA 0x000001C0 +#define DDRSS_CTL_65_DATA 0x00001858 +#define DDRSS_CTL_66_DATA 0x00000005 +#define DDRSS_CTL_67_DATA 0x00040000 +#define DDRSS_CTL_68_DATA 0x00700012 +#define DDRSS_CTL_69_DATA 0x00700304 +#define DDRSS_CTL_70_DATA 0x00400304 +#define DDRSS_CTL_71_DATA 0x00120103 +#define DDRSS_CTL_72_DATA 0x000C0005 +#define DDRSS_CTL_73_DATA 0x2408000C +#define DDRSS_CTL_74_DATA 0x05050124 +#define DDRSS_CTL_75_DATA 0x0301030A +#define DDRSS_CTL_76_DATA 0x03170C08 +#define DDRSS_CTL_77_DATA 0x0C080301 +#define DDRSS_CTL_78_DATA 0x00010317 +#define DDRSS_CTL_79_DATA 0x00100010 +#define DDRSS_CTL_80_DATA 0x01CC01CC +#define DDRSS_CTL_81_DATA 0x01CC01CC +#define DDRSS_CTL_82_DATA 0x03050505 +#define DDRSS_CTL_83_DATA 0x03010303 +#define DDRSS_CTL_84_DATA 0x18080C08 +#define DDRSS_CTL_85_DATA 0x03030C03 +#define DDRSS_CTL_86_DATA 0x18080C08 +#define DDRSS_CTL_87_DATA 0x03030C03 +#define DDRSS_CTL_88_DATA 0x03010000 +#define DDRSS_CTL_89_DATA 0x00010000 +#define DDRSS_CTL_90_DATA 0x00000000 +#define DDRSS_CTL_91_DATA 0x00000000 +#define DDRSS_CTL_92_DATA 0x01000000 +#define DDRSS_CTL_93_DATA 0x80104002 +#define DDRSS_CTL_94_DATA 0x00000000 +#define DDRSS_CTL_95_DATA 0x00040005 +#define DDRSS_CTL_96_DATA 0x00000000 +#define DDRSS_CTL_97_DATA 0x00050000 +#define DDRSS_CTL_98_DATA 0x00000004 +#define DDRSS_CTL_99_DATA 0x00000000 +#define DDRSS_CTL_100_DATA 0x00040005 +#define DDRSS_CTL_101_DATA 0x00000000 +#define DDRSS_CTL_102_DATA 0x00003380 +#define DDRSS_CTL_103_DATA 0x00003380 +#define DDRSS_CTL_104_DATA 0x00003380 +#define DDRSS_CTL_105_DATA 0x00003380 +#define DDRSS_CTL_106_DATA 0x00003380 +#define DDRSS_CTL_107_DATA 0x00000000 +#define DDRSS_CTL_108_DATA 0x000005A2 +#define DDRSS_CTL_109_DATA 0x00061600 +#define DDRSS_CTL_110_DATA 0x00061600 +#define DDRSS_CTL_111_DATA 0x00061600 +#define DDRSS_CTL_112_DATA 0x00061600 +#define DDRSS_CTL_113_DATA 0x00061600 +#define DDRSS_CTL_114_DATA 0x00000000 +#define DDRSS_CTL_115_DATA 0x0000AA68 +#define DDRSS_CTL_116_DATA 0x00061600 +#define DDRSS_CTL_117_DATA 0x00061600 +#define DDRSS_CTL_118_DATA 0x00061600 +#define DDRSS_CTL_119_DATA 0x00061600 +#define DDRSS_CTL_120_DATA 0x00061600 +#define DDRSS_CTL_121_DATA 0x00000000 +#define DDRSS_CTL_122_DATA 0x0000AA68 +#define DDRSS_CTL_123_DATA 0x00000000 +#define DDRSS_CTL_124_DATA 0x00000000 +#define DDRSS_CTL_125_DATA 0x00000000 +#define DDRSS_CTL_126_DATA 0x00000000 +#define DDRSS_CTL_127_DATA 0x00000000 +#define DDRSS_CTL_128_DATA 0x00000000 +#define DDRSS_CTL_129_DATA 0x00000000 +#define DDRSS_CTL_130_DATA 0x00000000 +#define DDRSS_CTL_131_DATA 0x08030500 +#define DDRSS_CTL_132_DATA 0x00030803 +#define DDRSS_CTL_133_DATA 0x0A090000 +#define DDRSS_CTL_134_DATA 0x0A090701 +#define DDRSS_CTL_135_DATA 0x0900000E +#define DDRSS_CTL_136_DATA 0x0907010A +#define DDRSS_CTL_137_DATA 0x00000E0A +#define DDRSS_CTL_138_DATA 0x07010A09 +#define DDRSS_CTL_139_DATA 0x000E0A09 +#define DDRSS_CTL_140_DATA 0x07000401 +#define DDRSS_CTL_141_DATA 0x00000000 +#define DDRSS_CTL_142_DATA 0x00000000 +#define DDRSS_CTL_143_DATA 0x00000000 +#define DDRSS_CTL_144_DATA 0x00000000 +#define DDRSS_CTL_145_DATA 0x00000000 +#define DDRSS_CTL_146_DATA 0x00000000 +#define DDRSS_CTL_147_DATA 0x00000000 +#define DDRSS_CTL_148_DATA 0x08080000 +#define DDRSS_CTL_149_DATA 0x01000000 +#define DDRSS_CTL_150_DATA 0x800000C0 +#define DDRSS_CTL_151_DATA 0x800000C0 +#define DDRSS_CTL_152_DATA 0x800000C0 +#define DDRSS_CTL_153_DATA 0x00000000 +#define DDRSS_CTL_154_DATA 0x00001500 +#define DDRSS_CTL_155_DATA 0x00000000 +#define DDRSS_CTL_156_DATA 0x00000001 +#define DDRSS_CTL_157_DATA 0x00000002 +#define DDRSS_CTL_158_DATA 0x0000100E +#define DDRSS_CTL_159_DATA 0x00000000 +#define DDRSS_CTL_160_DATA 0x00000000 +#define DDRSS_CTL_161_DATA 0x00000000 +#define DDRSS_CTL_162_DATA 0x00000000 +#define DDRSS_CTL_163_DATA 0x00000000 +#define DDRSS_CTL_164_DATA 0x000B0000 +#define DDRSS_CTL_165_DATA 0x000E0006 +#define DDRSS_CTL_166_DATA 0x000E0404 +#define DDRSS_CTL_167_DATA 0x00A00140 +#define DDRSS_CTL_168_DATA 0x0C0C0190 +#define DDRSS_CTL_169_DATA 0x01400190 +#define DDRSS_CTL_170_DATA 0x019000A0 +#define DDRSS_CTL_171_DATA 0x01900C0C +#define DDRSS_CTL_172_DATA 0x00000000 +#define DDRSS_CTL_173_DATA 0x00000000 +#define DDRSS_CTL_174_DATA 0x00000000 +#define DDRSS_CTL_175_DATA 0x2DD40084 +#define DDRSS_CTL_176_DATA 0xAB002DD4 +#define DDRSS_CTL_177_DATA 0x0000ABAB +#define DDRSS_CTL_178_DATA 0x45450000 +#define DDRSS_CTL_179_DATA 0x27272745 +#define DDRSS_CTL_180_DATA 0x0F0F0F00 +#define DDRSS_CTL_181_DATA 0x1D000000 +#define DDRSS_CTL_182_DATA 0x00841D1D +#define DDRSS_CTL_183_DATA 0x2DD42DD4 +#define DDRSS_CTL_184_DATA 0xABABAB00 +#define DDRSS_CTL_185_DATA 0x00000000 +#define DDRSS_CTL_186_DATA 0x27454545 +#define DDRSS_CTL_187_DATA 0x0F002727 +#define DDRSS_CTL_188_DATA 0x00000F0F +#define DDRSS_CTL_189_DATA 0x1D1D1D00 +#define DDRSS_CTL_190_DATA 0x00000020 +#define DDRSS_CTL_191_DATA 0x00000000 +#define DDRSS_CTL_192_DATA 0x00000001 +#define DDRSS_CTL_193_DATA 0x00000000 +#define DDRSS_CTL_194_DATA 0x01000000 +#define DDRSS_CTL_195_DATA 0x00000001 +#define DDRSS_CTL_196_DATA 0x00000000 +#define DDRSS_CTL_197_DATA 0x00000000 +#define DDRSS_CTL_198_DATA 0x00000000 +#define DDRSS_CTL_199_DATA 0x00000000 +#define DDRSS_CTL_200_DATA 0x00000000 +#define DDRSS_CTL_201_DATA 0x00000000 +#define DDRSS_CTL_202_DATA 0x00000000 +#define DDRSS_CTL_203_DATA 0x00000000 +#define DDRSS_CTL_204_DATA 0x00000000 +#define DDRSS_CTL_205_DATA 0x00000000 +#define DDRSS_CTL_206_DATA 0x02000000 +#define DDRSS_CTL_207_DATA 0x01080101 +#define DDRSS_CTL_208_DATA 0x00000000 +#define DDRSS_CTL_209_DATA 0x00000000 +#define DDRSS_CTL_210_DATA 0x00000000 +#define DDRSS_CTL_211_DATA 0x00000000 +#define DDRSS_CTL_212_DATA 0x00000000 +#define DDRSS_CTL_213_DATA 0x00000000 +#define DDRSS_CTL_214_DATA 0x00000000 +#define DDRSS_CTL_215_DATA 0x00000000 +#define DDRSS_CTL_216_DATA 0x00000000 +#define DDRSS_CTL_217_DATA 0x00000000 +#define DDRSS_CTL_218_DATA 0x00000000 +#define DDRSS_CTL_219_DATA 0x00000000 +#define DDRSS_CTL_220_DATA 0x00000000 +#define DDRSS_CTL_221_DATA 0x00000000 +#define DDRSS_CTL_222_DATA 0x00001000 +#define DDRSS_CTL_223_DATA 0x006403E8 +#define DDRSS_CTL_224_DATA 0x00000000 +#define DDRSS_CTL_225_DATA 0x00000000 +#define DDRSS_CTL_226_DATA 0x00000000 +#define DDRSS_CTL_227_DATA 0x15110000 +#define DDRSS_CTL_228_DATA 0x00040C18 +#define DDRSS_CTL_229_DATA 0xF000C000 +#define DDRSS_CTL_230_DATA 0x0000F000 +#define DDRSS_CTL_231_DATA 0x00000000 +#define DDRSS_CTL_232_DATA 0x00000000 +#define DDRSS_CTL_233_DATA 0xC0000000 +#define DDRSS_CTL_234_DATA 0xF000F000 +#define DDRSS_CTL_235_DATA 0x00000000 +#define DDRSS_CTL_236_DATA 0x00000000 +#define DDRSS_CTL_237_DATA 0x00000000 +#define DDRSS_CTL_238_DATA 0xF000C000 +#define DDRSS_CTL_239_DATA 0x0000F000 +#define DDRSS_CTL_240_DATA 0x00000000 +#define DDRSS_CTL_241_DATA 0x00000000 +#define DDRSS_CTL_242_DATA 0x00030000 +#define DDRSS_CTL_243_DATA 0x00000000 +#define DDRSS_CTL_244_DATA 0x00000000 +#define DDRSS_CTL_245_DATA 0x00000000 +#define DDRSS_CTL_246_DATA 0x00000000 +#define DDRSS_CTL_247_DATA 0x00000000 +#define DDRSS_CTL_248_DATA 0x00000000 +#define DDRSS_CTL_249_DATA 0x00000000 +#define DDRSS_CTL_250_DATA 0x00000000 +#define DDRSS_CTL_251_DATA 0x00000000 +#define DDRSS_CTL_252_DATA 0x00000000 +#define DDRSS_CTL_253_DATA 0x00000000 +#define DDRSS_CTL_254_DATA 0x00000000 +#define DDRSS_CTL_255_DATA 0x00000000 +#define DDRSS_CTL_256_DATA 0x00000000 +#define DDRSS_CTL_257_DATA 0x01000200 +#define DDRSS_CTL_258_DATA 0x00370040 +#define DDRSS_CTL_259_DATA 0x00020008 +#define DDRSS_CTL_260_DATA 0x00400100 +#define DDRSS_CTL_261_DATA 0x00300640 +#define DDRSS_CTL_262_DATA 0x01000200 +#define DDRSS_CTL_263_DATA 0x06400040 +#define DDRSS_CTL_264_DATA 0x00000030 +#define DDRSS_CTL_265_DATA 0x00500003 +#define DDRSS_CTL_266_DATA 0x01000050 +#define DDRSS_CTL_267_DATA 0x03030303 +#define DDRSS_CTL_268_DATA 0x01010000 +#define DDRSS_CTL_269_DATA 0x00000202 +#define DDRSS_CTL_270_DATA 0x00000FFF +#define DDRSS_CTL_271_DATA 0x1FFF1000 +#define DDRSS_CTL_272_DATA 0x01FF0000 +#define DDRSS_CTL_273_DATA 0x000101FF +#define DDRSS_CTL_274_DATA 0x0FFF0B00 +#define DDRSS_CTL_275_DATA 0x01010001 +#define DDRSS_CTL_276_DATA 0x01010101 +#define DDRSS_CTL_277_DATA 0x01180101 +#define DDRSS_CTL_278_DATA 0x00030000 +#define DDRSS_CTL_279_DATA 0x00000000 +#define DDRSS_CTL_280_DATA 0x00000000 +#define DDRSS_CTL_281_DATA 0x00000000 +#define DDRSS_CTL_282_DATA 0x00000000 +#define DDRSS_CTL_283_DATA 0x00000000 +#define DDRSS_CTL_284_DATA 0x00000000 +#define DDRSS_CTL_285_DATA 0x00000000 +#define DDRSS_CTL_286_DATA 0x00040101 +#define DDRSS_CTL_287_DATA 0x04010100 +#define DDRSS_CTL_288_DATA 0x00000000 +#define DDRSS_CTL_289_DATA 0x00000000 +#define DDRSS_CTL_290_DATA 0x03030300 +#define DDRSS_CTL_291_DATA 0x00000101 +#define DDRSS_CTL_292_DATA 0x00000000 +#define DDRSS_CTL_293_DATA 0x00000000 +#define DDRSS_CTL_294_DATA 0x00000000 +#define DDRSS_CTL_295_DATA 0x00000000 +#define DDRSS_CTL_296_DATA 0x00000000 +#define DDRSS_CTL_297_DATA 0x00000000 +#define DDRSS_CTL_298_DATA 0x00000000 +#define DDRSS_CTL_299_DATA 0x00000000 +#define DDRSS_CTL_300_DATA 0x00000000 +#define DDRSS_CTL_301_DATA 0x00000000 +#define DDRSS_CTL_302_DATA 0x00000000 +#define DDRSS_CTL_303_DATA 0x00000000 +#define DDRSS_CTL_304_DATA 0x00000000 +#define DDRSS_CTL_305_DATA 0x00000000 +#define DDRSS_CTL_306_DATA 0x00000000 +#define DDRSS_CTL_307_DATA 0x00000000 +#define DDRSS_CTL_308_DATA 0x00000000 +#define DDRSS_CTL_309_DATA 0x00000000 +#define DDRSS_CTL_310_DATA 0x00000000 +#define DDRSS_CTL_311_DATA 0x00000000 +#define DDRSS_CTL_312_DATA 0x00000000 +#define DDRSS_CTL_313_DATA 0x01000000 +#define DDRSS_CTL_314_DATA 0x00020201 +#define DDRSS_CTL_315_DATA 0x01000101 +#define DDRSS_CTL_316_DATA 0x01010001 +#define DDRSS_CTL_317_DATA 0x00010101 +#define DDRSS_CTL_318_DATA 0x05080803 +#define DDRSS_CTL_319_DATA 0x0C081818 +#define DDRSS_CTL_320_DATA 0x0009030C +#define DDRSS_CTL_321_DATA 0x090B030F +#define DDRSS_CTL_322_DATA 0x090B0306 +#define DDRSS_CTL_323_DATA 0x0B090006 +#define DDRSS_CTL_324_DATA 0x0100000B +#define DDRSS_CTL_325_DATA 0x06030601 +#define DDRSS_CTL_326_DATA 0x00000003 +#define DDRSS_CTL_327_DATA 0x00000000 +#define DDRSS_CTL_328_DATA 0x00010000 +#define DDRSS_CTL_329_DATA 0x00280D00 +#define DDRSS_CTL_330_DATA 0x00000001 +#define DDRSS_CTL_331_DATA 0x00030001 +#define DDRSS_CTL_332_DATA 0x00000000 +#define DDRSS_CTL_333_DATA 0x00000000 +#define DDRSS_CTL_334_DATA 0x00000000 +#define DDRSS_CTL_335_DATA 0x00000000 +#define DDRSS_CTL_336_DATA 0x00000000 +#define DDRSS_CTL_337_DATA 0x00000000 +#define DDRSS_CTL_338_DATA 0x00000000 +#define DDRSS_CTL_339_DATA 0x00000000 +#define DDRSS_CTL_340_DATA 0x01000000 +#define DDRSS_CTL_341_DATA 0x00000001 +#define DDRSS_CTL_342_DATA 0x00010100 +#define DDRSS_CTL_343_DATA 0x03030000 +#define DDRSS_CTL_344_DATA 0x00000000 +#define DDRSS_CTL_345_DATA 0x00000000 +#define DDRSS_CTL_346_DATA 0x00000000 +#define DDRSS_CTL_347_DATA 0x00000000 +#define DDRSS_CTL_348_DATA 0x00000000 +#define DDRSS_CTL_349_DATA 0x00000000 +#define DDRSS_CTL_350_DATA 0x00000000 +#define DDRSS_CTL_351_DATA 0x00000000 +#define DDRSS_CTL_352_DATA 0x00000000 +#define DDRSS_CTL_353_DATA 0x00000000 +#define DDRSS_CTL_354_DATA 0x00000000 +#define DDRSS_CTL_355_DATA 0x00000000 +#define DDRSS_CTL_356_DATA 0x00000000 +#define DDRSS_CTL_357_DATA 0x00000000 +#define DDRSS_CTL_358_DATA 0x00000000 +#define DDRSS_CTL_359_DATA 0x00000000 +#define DDRSS_CTL_360_DATA 0x000556AA +#define DDRSS_CTL_361_DATA 0x000AAAAA +#define DDRSS_CTL_362_DATA 0x000AA955 +#define DDRSS_CTL_363_DATA 0x00055555 +#define DDRSS_CTL_364_DATA 0x000B3133 +#define DDRSS_CTL_365_DATA 0x0004CD33 +#define DDRSS_CTL_366_DATA 0x0004CECC +#define DDRSS_CTL_367_DATA 0x000B32CC +#define DDRSS_CTL_368_DATA 0x00010300 +#define DDRSS_CTL_369_DATA 0x03000100 +#define DDRSS_CTL_370_DATA 0x00000000 +#define DDRSS_CTL_371_DATA 0x00000000 +#define DDRSS_CTL_372_DATA 0x00000000 +#define DDRSS_CTL_373_DATA 0x00000000 +#define DDRSS_CTL_374_DATA 0x00000000 +#define DDRSS_CTL_375_DATA 0x00000000 +#define DDRSS_CTL_376_DATA 0x00000000 +#define DDRSS_CTL_377_DATA 0x00010000 +#define DDRSS_CTL_378_DATA 0x00000404 +#define DDRSS_CTL_379_DATA 0x00000000 +#define DDRSS_CTL_380_DATA 0x00000000 +#define DDRSS_CTL_381_DATA 0x00000000 +#define DDRSS_CTL_382_DATA 0x00000000 +#define DDRSS_CTL_383_DATA 0x00000000 +#define DDRSS_CTL_384_DATA 0x00000000 +#define DDRSS_CTL_385_DATA 0x00000000 +#define DDRSS_CTL_386_DATA 0x00000000 +#define DDRSS_CTL_387_DATA 0x33331B00 +#define DDRSS_CTL_388_DATA 0x000A0000 +#define DDRSS_CTL_389_DATA 0x0000019C +#define DDRSS_CTL_390_DATA 0x00000200 +#define DDRSS_CTL_391_DATA 0x00000200 +#define DDRSS_CTL_392_DATA 0x00000200 +#define DDRSS_CTL_393_DATA 0x00000200 +#define DDRSS_CTL_394_DATA 0x000004D4 +#define DDRSS_CTL_395_DATA 0x00001018 +#define DDRSS_CTL_396_DATA 0x00000204 +#define DDRSS_CTL_397_DATA 0x000030B0 +#define DDRSS_CTL_398_DATA 0x00000200 +#define DDRSS_CTL_399_DATA 0x00000200 +#define DDRSS_CTL_400_DATA 0x00000200 +#define DDRSS_CTL_401_DATA 0x00000200 +#define DDRSS_CTL_402_DATA 0x00009210 +#define DDRSS_CTL_403_DATA 0x0001E6E0 +#define DDRSS_CTL_404_DATA 0x00000A10 +#define DDRSS_CTL_405_DATA 0x000030B0 +#define DDRSS_CTL_406_DATA 0x00000200 +#define DDRSS_CTL_407_DATA 0x00000200 +#define DDRSS_CTL_408_DATA 0x00000200 +#define DDRSS_CTL_409_DATA 0x00000200 +#define DDRSS_CTL_410_DATA 0x00009210 +#define DDRSS_CTL_411_DATA 0x0001E6E0 +#define DDRSS_CTL_412_DATA 0x02020A10 +#define DDRSS_CTL_413_DATA 0x03030202 +#define DDRSS_CTL_414_DATA 0x00000022 +#define DDRSS_CTL_415_DATA 0x00000000 +#define DDRSS_CTL_416_DATA 0x00000000 +#define DDRSS_CTL_417_DATA 0x00001403 +#define DDRSS_CTL_418_DATA 0x000007D0 +#define DDRSS_CTL_419_DATA 0x00000000 +#define DDRSS_CTL_420_DATA 0x00000000 +#define DDRSS_CTL_421_DATA 0x00030000 +#define DDRSS_CTL_422_DATA 0x0007001F +#define DDRSS_CTL_423_DATA 0x0016002E +#define DDRSS_CTL_424_DATA 0x0016002E +#define DDRSS_CTL_425_DATA 0x00000000 +#define DDRSS_CTL_426_DATA 0x00000000 +#define DDRSS_CTL_427_DATA 0x02000000 +#define DDRSS_CTL_428_DATA 0x01000404 +#define DDRSS_CTL_429_DATA 0x07160716 +#define DDRSS_CTL_430_DATA 0x00000105 +#define DDRSS_CTL_431_DATA 0x00010101 +#define DDRSS_CTL_432_DATA 0x00010101 +#define DDRSS_CTL_433_DATA 0x00010001 +#define DDRSS_CTL_434_DATA 0x00000101 +#define DDRSS_CTL_435_DATA 0x02000201 +#define DDRSS_CTL_436_DATA 0x02010000 +#define DDRSS_CTL_437_DATA 0x00000200 +#define DDRSS_CTL_438_DATA 0x1E060000 +#define DDRSS_CTL_439_DATA 0x0000011E +#define DDRSS_CTL_440_DATA 0xFFFFFFFF +#define DDRSS_CTL_441_DATA 0xFFFFFFFF +#define DDRSS_CTL_442_DATA 0x00000000 +#define DDRSS_CTL_443_DATA 0x00000000 +#define DDRSS_CTL_444_DATA 0x00000000 +#define DDRSS_CTL_445_DATA 0x00000000 +#define DDRSS_CTL_446_DATA 0x00000000 +#define DDRSS_CTL_447_DATA 0x00000000 +#define DDRSS_CTL_448_DATA 0x00000000 +#define DDRSS_CTL_449_DATA 0x00000000 +#define DDRSS_CTL_450_DATA 0x00000000 +#define DDRSS_CTL_451_DATA 0x00000000 +#define DDRSS_CTL_452_DATA 0x00000000 +#define DDRSS_CTL_453_DATA 0x00000000 +#define DDRSS_CTL_454_DATA 0x00000000 +#define DDRSS_CTL_455_DATA 0x00000000 +#define DDRSS_CTL_456_DATA 0x00000000 +#define DDRSS_CTL_457_DATA 0x00000000 +#define DDRSS_CTL_458_DATA 0x00000000 + +#define DDRSS_PI_00_DATA 0x00000B00 +#define DDRSS_PI_01_DATA 0x00000000 +#define DDRSS_PI_02_DATA 0x00000000 +#define DDRSS_PI_03_DATA 0x00000000 +#define DDRSS_PI_04_DATA 0x00000000 +#define DDRSS_PI_05_DATA 0x00000101 +#define DDRSS_PI_06_DATA 0x00640000 +#define DDRSS_PI_07_DATA 0x00000001 +#define DDRSS_PI_08_DATA 0x00000000 +#define DDRSS_PI_09_DATA 0x00000000 +#define DDRSS_PI_10_DATA 0x00000000 +#define DDRSS_PI_11_DATA 0x00000000 +#define DDRSS_PI_12_DATA 0x00000007 +#define DDRSS_PI_13_DATA 0x00010002 +#define DDRSS_PI_14_DATA 0x0800000F +#define DDRSS_PI_15_DATA 0x00000103 +#define DDRSS_PI_16_DATA 0x00000005 +#define DDRSS_PI_17_DATA 0x00000000 +#define DDRSS_PI_18_DATA 0x00000000 +#define DDRSS_PI_19_DATA 0x00000000 +#define DDRSS_PI_20_DATA 0x00000000 +#define DDRSS_PI_21_DATA 0x00000000 +#define DDRSS_PI_22_DATA 0x00000000 +#define DDRSS_PI_23_DATA 0x00000000 +#define DDRSS_PI_24_DATA 0x00000000 +#define DDRSS_PI_25_DATA 0x00000000 +#define DDRSS_PI_26_DATA 0x00010100 +#define DDRSS_PI_27_DATA 0x00280A00 +#define DDRSS_PI_28_DATA 0x00000000 +#define DDRSS_PI_29_DATA 0x0F000000 +#define DDRSS_PI_30_DATA 0x00003200 +#define DDRSS_PI_31_DATA 0x00000000 +#define DDRSS_PI_32_DATA 0x00000000 +#define DDRSS_PI_33_DATA 0x01010102 +#define DDRSS_PI_34_DATA 0x00000000 +#define DDRSS_PI_35_DATA 0x000000AA +#define DDRSS_PI_36_DATA 0x00000055 +#define DDRSS_PI_37_DATA 0x000000B5 +#define DDRSS_PI_38_DATA 0x0000004A +#define DDRSS_PI_39_DATA 0x00000056 +#define DDRSS_PI_40_DATA 0x000000A9 +#define DDRSS_PI_41_DATA 0x000000A9 +#define DDRSS_PI_42_DATA 0x000000B5 +#define DDRSS_PI_43_DATA 0x00000000 +#define DDRSS_PI_44_DATA 0x00000000 +#define DDRSS_PI_45_DATA 0x000F0F00 +#define DDRSS_PI_46_DATA 0x00000019 +#define DDRSS_PI_47_DATA 0x000007D0 +#define DDRSS_PI_48_DATA 0x00000300 +#define DDRSS_PI_49_DATA 0x00000000 +#define DDRSS_PI_50_DATA 0x00000000 +#define DDRSS_PI_51_DATA 0x01000000 +#define DDRSS_PI_52_DATA 0x00010101 +#define DDRSS_PI_53_DATA 0x00000000 +#define DDRSS_PI_54_DATA 0x00030000 +#define DDRSS_PI_55_DATA 0x0F000000 +#define DDRSS_PI_56_DATA 0x00000017 +#define DDRSS_PI_57_DATA 0x00000000 +#define DDRSS_PI_58_DATA 0x00000000 +#define DDRSS_PI_59_DATA 0x00000000 +#define DDRSS_PI_60_DATA 0x0A0A140A +#define DDRSS_PI_61_DATA 0x10020101 +#define DDRSS_PI_62_DATA 0x00020805 +#define DDRSS_PI_63_DATA 0x01000404 +#define DDRSS_PI_64_DATA 0x00000000 +#define DDRSS_PI_65_DATA 0x00000000 +#define DDRSS_PI_66_DATA 0x00000100 +#define DDRSS_PI_67_DATA 0x0001010F +#define DDRSS_PI_68_DATA 0x00340000 +#define DDRSS_PI_69_DATA 0x00000000 +#define DDRSS_PI_70_DATA 0x00000000 +#define DDRSS_PI_71_DATA 0x0000FFFF +#define DDRSS_PI_72_DATA 0x00000000 +#define DDRSS_PI_73_DATA 0x00080100 +#define DDRSS_PI_74_DATA 0x02000200 +#define DDRSS_PI_75_DATA 0x01000100 +#define DDRSS_PI_76_DATA 0x01000000 +#define DDRSS_PI_77_DATA 0x02000200 +#define DDRSS_PI_78_DATA 0x00000200 +#define DDRSS_PI_79_DATA 0x00000000 +#define DDRSS_PI_80_DATA 0x00000000 +#define DDRSS_PI_81_DATA 0x00000000 +#define DDRSS_PI_82_DATA 0x00000000 +#define DDRSS_PI_83_DATA 0x00000000 +#define DDRSS_PI_84_DATA 0x00000000 +#define DDRSS_PI_85_DATA 0x00000000 +#define DDRSS_PI_86_DATA 0x00000000 +#define DDRSS_PI_87_DATA 0x00000000 +#define DDRSS_PI_88_DATA 0x00000000 +#define DDRSS_PI_89_DATA 0x00000000 +#define DDRSS_PI_90_DATA 0x00000000 +#define DDRSS_PI_91_DATA 0x00000400 +#define DDRSS_PI_92_DATA 0x02010000 +#define DDRSS_PI_93_DATA 0x00080003 +#define DDRSS_PI_94_DATA 0x00080000 +#define DDRSS_PI_95_DATA 0x00000001 +#define DDRSS_PI_96_DATA 0x00000000 +#define DDRSS_PI_97_DATA 0x0000AA00 +#define DDRSS_PI_98_DATA 0x00000000 +#define DDRSS_PI_99_DATA 0x00000000 +#define DDRSS_PI_100_DATA 0x00010000 +#define DDRSS_PI_101_DATA 0x00000000 +#define DDRSS_PI_102_DATA 0x00000000 +#define DDRSS_PI_103_DATA 0x00000000 +#define DDRSS_PI_104_DATA 0x00000000 +#define DDRSS_PI_105_DATA 0x00000000 +#define DDRSS_PI_106_DATA 0x00000000 +#define DDRSS_PI_107_DATA 0x00000000 +#define DDRSS_PI_108_DATA 0x00000000 +#define DDRSS_PI_109_DATA 0x00000000 +#define DDRSS_PI_110_DATA 0x00000000 +#define DDRSS_PI_111_DATA 0x00000000 +#define DDRSS_PI_112_DATA 0x00000000 +#define DDRSS_PI_113_DATA 0x00000000 +#define DDRSS_PI_114_DATA 0x00000000 +#define DDRSS_PI_115_DATA 0x00000000 +#define DDRSS_PI_116_DATA 0x00000000 +#define DDRSS_PI_117_DATA 0x00000000 +#define DDRSS_PI_118_DATA 0x00000000 +#define DDRSS_PI_119_DATA 0x00000000 +#define DDRSS_PI_120_DATA 0x00000000 +#define DDRSS_PI_121_DATA 0x00000000 +#define DDRSS_PI_122_DATA 0x00000000 +#define DDRSS_PI_123_DATA 0x00000000 +#define DDRSS_PI_124_DATA 0x00000000 +#define DDRSS_PI_125_DATA 0x00000008 +#define DDRSS_PI_126_DATA 0x00000000 +#define DDRSS_PI_127_DATA 0x00000000 +#define DDRSS_PI_128_DATA 0x00000000 +#define DDRSS_PI_129_DATA 0x00000000 +#define DDRSS_PI_130_DATA 0x00000000 +#define DDRSS_PI_131_DATA 0x00000000 +#define DDRSS_PI_132_DATA 0x00000000 +#define DDRSS_PI_133_DATA 0x00000000 +#define DDRSS_PI_134_DATA 0x00000002 +#define DDRSS_PI_135_DATA 0x00000000 +#define DDRSS_PI_136_DATA 0x00000000 +#define DDRSS_PI_137_DATA 0x0000000A +#define DDRSS_PI_138_DATA 0x00000019 +#define DDRSS_PI_139_DATA 0x00000100 +#define DDRSS_PI_140_DATA 0x00000000 +#define DDRSS_PI_141_DATA 0x00000000 +#define DDRSS_PI_142_DATA 0x00000000 +#define DDRSS_PI_143_DATA 0x00000000 +#define DDRSS_PI_144_DATA 0x01000000 +#define DDRSS_PI_145_DATA 0x00010003 +#define DDRSS_PI_146_DATA 0x02000101 +#define DDRSS_PI_147_DATA 0x01030001 +#define DDRSS_PI_148_DATA 0x00010400 +#define DDRSS_PI_149_DATA 0x06000105 +#define DDRSS_PI_150_DATA 0x01070001 +#define DDRSS_PI_151_DATA 0x00000000 +#define DDRSS_PI_152_DATA 0x00000000 +#define DDRSS_PI_153_DATA 0x00000000 +#define DDRSS_PI_154_DATA 0x00010001 +#define DDRSS_PI_155_DATA 0x00000000 +#define DDRSS_PI_156_DATA 0x00000000 +#define DDRSS_PI_157_DATA 0x00000000 +#define DDRSS_PI_158_DATA 0x00000000 +#define DDRSS_PI_159_DATA 0x00000401 +#define DDRSS_PI_160_DATA 0x00000000 +#define DDRSS_PI_161_DATA 0x00010000 +#define DDRSS_PI_162_DATA 0x00000000 +#define DDRSS_PI_163_DATA 0x20200200 +#define DDRSS_PI_164_DATA 0x00000034 +#define DDRSS_PI_165_DATA 0x00000058 +#define DDRSS_PI_166_DATA 0x00020058 +#define DDRSS_PI_167_DATA 0x02000200 +#define DDRSS_PI_168_DATA 0x380E0C04 +#define DDRSS_PI_169_DATA 0x0010380E +#define DDRSS_PI_170_DATA 0x000000CE +#define DDRSS_PI_171_DATA 0x000001C0 +#define DDRSS_PI_172_DATA 0x00001858 +#define DDRSS_PI_173_DATA 0x000001C0 +#define DDRSS_PI_174_DATA 0x04001858 +#define DDRSS_PI_175_DATA 0x01010404 +#define DDRSS_PI_176_DATA 0x00001501 +#define DDRSS_PI_177_DATA 0x00150015 +#define DDRSS_PI_178_DATA 0x01000100 +#define DDRSS_PI_179_DATA 0x00000100 +#define DDRSS_PI_180_DATA 0x00000000 +#define DDRSS_PI_181_DATA 0x01010101 +#define DDRSS_PI_182_DATA 0x00000101 +#define DDRSS_PI_183_DATA 0x00000000 +#define DDRSS_PI_184_DATA 0x00000000 +#define DDRSS_PI_185_DATA 0x10040000 +#define DDRSS_PI_186_DATA 0x0A0A0210 +#define DDRSS_PI_187_DATA 0x00040402 +#define DDRSS_PI_188_DATA 0x000D0035 +#define DDRSS_PI_189_DATA 0x001C0044 +#define DDRSS_PI_190_DATA 0x001C0044 +#define DDRSS_PI_191_DATA 0x01010101 +#define DDRSS_PI_192_DATA 0x0003000E +#define DDRSS_PI_193_DATA 0x00030190 +#define DDRSS_PI_194_DATA 0x01000190 +#define DDRSS_PI_195_DATA 0x000F000F +#define DDRSS_PI_196_DATA 0x01910100 +#define DDRSS_PI_197_DATA 0x01000191 +#define DDRSS_PI_198_DATA 0x01910191 +#define DDRSS_PI_199_DATA 0x32103200 +#define DDRSS_PI_200_DATA 0x01013210 +#define DDRSS_PI_201_DATA 0x0A070601 +#define DDRSS_PI_202_DATA 0x180F090D +#define DDRSS_PI_203_DATA 0x180F0911 +#define DDRSS_PI_204_DATA 0x0000C011 +#define DDRSS_PI_205_DATA 0x00C01000 +#define DDRSS_PI_206_DATA 0x00C01000 +#define DDRSS_PI_207_DATA 0x00021000 +#define DDRSS_PI_208_DATA 0x001E000E +#define DDRSS_PI_209_DATA 0x001E0190 +#define DDRSS_PI_210_DATA 0x00110190 +#define DDRSS_PI_211_DATA 0x32000056 +#define DDRSS_PI_212_DATA 0x00000301 +#define DDRSS_PI_213_DATA 0x005A0030 +#define DDRSS_PI_214_DATA 0x03013212 +#define DDRSS_PI_215_DATA 0x00003000 +#define DDRSS_PI_216_DATA 0x3212005A +#define DDRSS_PI_217_DATA 0x09000301 +#define DDRSS_PI_218_DATA 0x04010504 +#define DDRSS_PI_219_DATA 0x040006C9 +#define DDRSS_PI_220_DATA 0x0A032001 +#define DDRSS_PI_221_DATA 0x21250D0A +#define DDRSS_PI_222_DATA 0x00002216 +#define DDRSS_PI_223_DATA 0x4800C570 +#define DDRSS_PI_224_DATA 0x17182006 +#define DDRSS_PI_225_DATA 0x21250D10 +#define DDRSS_PI_226_DATA 0x00002216 +#define DDRSS_PI_227_DATA 0x4800C570 +#define DDRSS_PI_228_DATA 0x17182006 +#define DDRSS_PI_229_DATA 0x00019C10 +#define DDRSS_PI_230_DATA 0x00001018 +#define DDRSS_PI_231_DATA 0x000030B0 +#define DDRSS_PI_232_DATA 0x0001E6E0 +#define DDRSS_PI_233_DATA 0x000030B0 +#define DDRSS_PI_234_DATA 0x0001E6E0 +#define DDRSS_PI_235_DATA 0x01CC0010 +#define DDRSS_PI_236_DATA 0x030301CC +#define DDRSS_PI_237_DATA 0x002AF803 +#define DDRSS_PI_238_DATA 0x0001ADAF +#define DDRSS_PI_239_DATA 0x00000005 +#define DDRSS_PI_240_DATA 0x0000006E +#define DDRSS_PI_241_DATA 0x00000010 +#define DDRSS_PI_242_DATA 0x0004E200 +#define DDRSS_PI_243_DATA 0x0001ADAF +#define DDRSS_PI_244_DATA 0x00000005 +#define DDRSS_PI_245_DATA 0x00000C80 +#define DDRSS_PI_246_DATA 0x000001CC +#define DDRSS_PI_247_DATA 0x0004E200 +#define DDRSS_PI_248_DATA 0x0001ADAF +#define DDRSS_PI_249_DATA 0x00000005 +#define DDRSS_PI_250_DATA 0x00000C80 +#define DDRSS_PI_251_DATA 0x010001CC +#define DDRSS_PI_252_DATA 0x00370040 +#define DDRSS_PI_253_DATA 0x00010008 +#define DDRSS_PI_254_DATA 0x06400040 +#define DDRSS_PI_255_DATA 0x00010030 +#define DDRSS_PI_256_DATA 0x06400040 +#define DDRSS_PI_257_DATA 0x00000330 +#define DDRSS_PI_258_DATA 0x00500050 +#define DDRSS_PI_259_DATA 0x08040404 +#define DDRSS_PI_260_DATA 0x00000055 +#define DDRSS_PI_261_DATA 0x55083C5A +#define DDRSS_PI_262_DATA 0x5A000000 +#define DDRSS_PI_263_DATA 0x0055083C +#define DDRSS_PI_264_DATA 0x3C5A0000 +#define DDRSS_PI_265_DATA 0x00005508 +#define DDRSS_PI_266_DATA 0x0C3C5A00 +#define DDRSS_PI_267_DATA 0x080F0E0D +#define DDRSS_PI_268_DATA 0x000B0A09 +#define DDRSS_PI_269_DATA 0x00030201 +#define DDRSS_PI_270_DATA 0x01000000 +#define DDRSS_PI_271_DATA 0x04020201 +#define DDRSS_PI_272_DATA 0x00080804 +#define DDRSS_PI_273_DATA 0x00000000 +#define DDRSS_PI_274_DATA 0x00000000 +#define DDRSS_PI_275_DATA 0x45AB0084 +#define DDRSS_PI_276_DATA 0x001D0F27 +#define DDRSS_PI_277_DATA 0x45AB2DD4 +#define DDRSS_PI_278_DATA 0x001D0F27 +#define DDRSS_PI_279_DATA 0x45AB2DD4 +#define DDRSS_PI_280_DATA 0x001D0F27 +#define DDRSS_PI_281_DATA 0x45AB0084 +#define DDRSS_PI_282_DATA 0x001D0F27 +#define DDRSS_PI_283_DATA 0x45AB2DD4 +#define DDRSS_PI_284_DATA 0x001D0F27 +#define DDRSS_PI_285_DATA 0x45AB2DD4 +#define DDRSS_PI_286_DATA 0x001D0F27 +#define DDRSS_PI_287_DATA 0x45AB0084 +#define DDRSS_PI_288_DATA 0x001D0F27 +#define DDRSS_PI_289_DATA 0x45AB2DD4 +#define DDRSS_PI_290_DATA 0x001D0F27 +#define DDRSS_PI_291_DATA 0x45AB2DD4 +#define DDRSS_PI_292_DATA 0x001D0F27 +#define DDRSS_PI_293_DATA 0x45AB0084 +#define DDRSS_PI_294_DATA 0x001D0F27 +#define DDRSS_PI_295_DATA 0x45AB2DD4 +#define DDRSS_PI_296_DATA 0x001D0F27 +#define DDRSS_PI_297_DATA 0x45AB2DD4 +#define DDRSS_PI_298_DATA 0x001D0F27 +#define DDRSS_PI_299_DATA 0x00000000 + +#define DDRSS_PHY_00_DATA 0x000004F0 +#define DDRSS_PHY_01_DATA 0x00000000 +#define DDRSS_PHY_02_DATA 0x00030200 +#define DDRSS_PHY_03_DATA 0x00000000 +#define DDRSS_PHY_04_DATA 0x00000000 +#define DDRSS_PHY_05_DATA 0x01030000 +#define DDRSS_PHY_06_DATA 0x00010000 +#define DDRSS_PHY_07_DATA 0x01030004 +#define DDRSS_PHY_08_DATA 0x01000000 +#define DDRSS_PHY_09_DATA 0x00000000 +#define DDRSS_PHY_10_DATA 0x00000000 +#define DDRSS_PHY_11_DATA 0x01000001 +#define DDRSS_PHY_12_DATA 0x00000100 +#define DDRSS_PHY_13_DATA 0x000800C0 +#define DDRSS_PHY_14_DATA 0x060100CC +#define DDRSS_PHY_15_DATA 0x00030066 +#define DDRSS_PHY_16_DATA 0x00000000 +#define DDRSS_PHY_17_DATA 0x00000301 +#define DDRSS_PHY_18_DATA 0x0000AAAA +#define DDRSS_PHY_19_DATA 0x00005555 +#define DDRSS_PHY_20_DATA 0x0000B5B5 +#define DDRSS_PHY_21_DATA 0x00004A4A +#define DDRSS_PHY_22_DATA 0x00005656 +#define DDRSS_PHY_23_DATA 0x0000A9A9 +#define DDRSS_PHY_24_DATA 0x0000A9A9 +#define DDRSS_PHY_25_DATA 0x0000B5B5 +#define DDRSS_PHY_26_DATA 0x00000000 +#define DDRSS_PHY_27_DATA 0x00000000 +#define DDRSS_PHY_28_DATA 0x2A000000 +#define DDRSS_PHY_29_DATA 0x00000808 +#define DDRSS_PHY_30_DATA 0x0F000000 +#define DDRSS_PHY_31_DATA 0x00000F0F +#define DDRSS_PHY_32_DATA 0x10400000 +#define DDRSS_PHY_33_DATA 0x0C002006 +#define DDRSS_PHY_34_DATA 0x00000000 +#define DDRSS_PHY_35_DATA 0x00000000 +#define DDRSS_PHY_36_DATA 0x55555555 +#define DDRSS_PHY_37_DATA 0xAAAAAAAA +#define DDRSS_PHY_38_DATA 0x55555555 +#define DDRSS_PHY_39_DATA 0xAAAAAAAA +#define DDRSS_PHY_40_DATA 0x00005555 +#define DDRSS_PHY_41_DATA 0x01000100 +#define DDRSS_PHY_42_DATA 0x00800180 +#define DDRSS_PHY_43_DATA 0x00000001 +#define DDRSS_PHY_44_DATA 0x00000000 +#define DDRSS_PHY_45_DATA 0x00000000 +#define DDRSS_PHY_46_DATA 0x00000000 +#define DDRSS_PHY_47_DATA 0x00000000 +#define DDRSS_PHY_48_DATA 0x00000000 +#define DDRSS_PHY_49_DATA 0x00000000 +#define DDRSS_PHY_50_DATA 0x00000000 +#define DDRSS_PHY_51_DATA 0x00000000 +#define DDRSS_PHY_52_DATA 0x00000000 +#define DDRSS_PHY_53_DATA 0x00000000 +#define DDRSS_PHY_54_DATA 0x00000000 +#define DDRSS_PHY_55_DATA 0x00000000 +#define DDRSS_PHY_56_DATA 0x00000000 +#define DDRSS_PHY_57_DATA 0x00000000 +#define DDRSS_PHY_58_DATA 0x00000000 +#define DDRSS_PHY_59_DATA 0x00000000 +#define DDRSS_PHY_60_DATA 0x00000000 +#define DDRSS_PHY_61_DATA 0x00000000 +#define DDRSS_PHY_62_DATA 0x00000000 +#define DDRSS_PHY_63_DATA 0x00000000 +#define DDRSS_PHY_64_DATA 0x00000000 +#define DDRSS_PHY_65_DATA 0x00000000 +#define DDRSS_PHY_66_DATA 0x00000104 +#define DDRSS_PHY_67_DATA 0x00000120 +#define DDRSS_PHY_68_DATA 0x00000000 +#define DDRSS_PHY_69_DATA 0x00000000 +#define DDRSS_PHY_70_DATA 0x00000000 +#define DDRSS_PHY_71_DATA 0x00000000 +#define DDRSS_PHY_72_DATA 0x00000000 +#define DDRSS_PHY_73_DATA 0x00000000 +#define DDRSS_PHY_74_DATA 0x00000000 +#define DDRSS_PHY_75_DATA 0x00000001 +#define DDRSS_PHY_76_DATA 0x07FF0000 +#define DDRSS_PHY_77_DATA 0x0080081F +#define DDRSS_PHY_78_DATA 0x00081020 +#define DDRSS_PHY_79_DATA 0x04010000 +#define DDRSS_PHY_80_DATA 0x00000000 +#define DDRSS_PHY_81_DATA 0x00000000 +#define DDRSS_PHY_82_DATA 0x00000000 +#define DDRSS_PHY_83_DATA 0x00000100 +#define DDRSS_PHY_84_DATA 0x01BB0B01 +#define DDRSS_PHY_85_DATA 0x1003BB0B +#define DDRSS_PHY_86_DATA 0x20000140 +#define DDRSS_PHY_87_DATA 0x07FF0200 +#define DDRSS_PHY_88_DATA 0x0000DD01 +#define DDRSS_PHY_89_DATA 0x10100303 +#define DDRSS_PHY_90_DATA 0x10101010 +#define DDRSS_PHY_91_DATA 0x10101010 +#define DDRSS_PHY_92_DATA 0x00021010 +#define DDRSS_PHY_93_DATA 0x00100010 +#define DDRSS_PHY_94_DATA 0x00100010 +#define DDRSS_PHY_95_DATA 0x00100010 +#define DDRSS_PHY_96_DATA 0x00100010 +#define DDRSS_PHY_97_DATA 0x00050010 +#define DDRSS_PHY_98_DATA 0x51517041 +#define DDRSS_PHY_99_DATA 0x31C06000 +#define DDRSS_PHY_100_DATA 0x07AB0340 +#define DDRSS_PHY_101_DATA 0x00C0C001 +#define DDRSS_PHY_102_DATA 0x0B0A0001 +#define DDRSS_PHY_103_DATA 0x10001000 +#define DDRSS_PHY_104_DATA 0x0C073E42 +#define DDRSS_PHY_105_DATA 0x0F0C2D01 +#define DDRSS_PHY_106_DATA 0x01000140 +#define DDRSS_PHY_107_DATA 0x0C000420 +#define DDRSS_PHY_108_DATA 0x00000198 +#define DDRSS_PHY_109_DATA 0x0A0000D0 +#define DDRSS_PHY_110_DATA 0x00030200 +#define DDRSS_PHY_111_DATA 0x02800000 +#define DDRSS_PHY_112_DATA 0x80800000 +#define DDRSS_PHY_113_DATA 0x000B2010 +#define DDRSS_PHY_114_DATA 0x76543210 +#define DDRSS_PHY_115_DATA 0x00000008 +#define DDRSS_PHY_116_DATA 0x02800280 +#define DDRSS_PHY_117_DATA 0x02800280 +#define DDRSS_PHY_118_DATA 0x02800280 +#define DDRSS_PHY_119_DATA 0x02800280 +#define DDRSS_PHY_120_DATA 0x00000280 +#define DDRSS_PHY_121_DATA 0x0000A000 +#define DDRSS_PHY_122_DATA 0x00A000A0 +#define DDRSS_PHY_123_DATA 0x00A000A0 +#define DDRSS_PHY_124_DATA 0x00A000A0 +#define DDRSS_PHY_125_DATA 0x00A000A0 +#define DDRSS_PHY_126_DATA 0x00A000A0 +#define DDRSS_PHY_127_DATA 0x00A000A0 +#define DDRSS_PHY_128_DATA 0x00A000A0 +#define DDRSS_PHY_129_DATA 0x00A000A0 +#define DDRSS_PHY_130_DATA 0x011900A0 +#define DDRSS_PHY_131_DATA 0x01A00004 +#define DDRSS_PHY_132_DATA 0x00000000 +#define DDRSS_PHY_133_DATA 0x00000000 +#define DDRSS_PHY_134_DATA 0x00080200 +#define DDRSS_PHY_135_DATA 0x00000000 +#define DDRSS_PHY_136_DATA 0x20202000 +#define DDRSS_PHY_137_DATA 0x20202020 +#define DDRSS_PHY_138_DATA 0xF0F02020 +#define DDRSS_PHY_139_DATA 0x00000000 +#define DDRSS_PHY_140_DATA 0x00000000 +#define DDRSS_PHY_141_DATA 0x00000000 +#define DDRSS_PHY_142_DATA 0x00000000 +#define DDRSS_PHY_143_DATA 0x00000000 +#define DDRSS_PHY_144_DATA 0x00000000 +#define DDRSS_PHY_145_DATA 0x00000000 +#define DDRSS_PHY_146_DATA 0x00000000 +#define DDRSS_PHY_147_DATA 0x00000000 +#define DDRSS_PHY_148_DATA 0x00000000 +#define DDRSS_PHY_149_DATA 0x00000000 +#define DDRSS_PHY_150_DATA 0x00000000 +#define DDRSS_PHY_151_DATA 0x00000000 +#define DDRSS_PHY_152_DATA 0x00000000 +#define DDRSS_PHY_153_DATA 0x00000000 +#define DDRSS_PHY_154_DATA 0x00000000 +#define DDRSS_PHY_155_DATA 0x00000000 +#define DDRSS_PHY_156_DATA 0x00000000 +#define DDRSS_PHY_157_DATA 0x00000000 +#define DDRSS_PHY_158_DATA 0x00000000 +#define DDRSS_PHY_159_DATA 0x00000000 +#define DDRSS_PHY_160_DATA 0x00000000 +#define DDRSS_PHY_161_DATA 0x00000000 +#define DDRSS_PHY_162_DATA 0x00000000 +#define DDRSS_PHY_163_DATA 0x00000000 +#define DDRSS_PHY_164_DATA 0x00000000 +#define DDRSS_PHY_165_DATA 0x00000000 +#define DDRSS_PHY_166_DATA 0x00000000 +#define DDRSS_PHY_167_DATA 0x00000000 +#define DDRSS_PHY_168_DATA 0x00000000 +#define DDRSS_PHY_169_DATA 0x00000000 +#define DDRSS_PHY_170_DATA 0x00000000 +#define DDRSS_PHY_171_DATA 0x00000000 +#define DDRSS_PHY_172_DATA 0x00000000 +#define DDRSS_PHY_173_DATA 0x00000000 +#define DDRSS_PHY_174_DATA 0x00000000 +#define DDRSS_PHY_175_DATA 0x00000000 +#define DDRSS_PHY_176_DATA 0x00000000 +#define DDRSS_PHY_177_DATA 0x00000000 +#define DDRSS_PHY_178_DATA 0x00000000 +#define DDRSS_PHY_179_DATA 0x00000000 +#define DDRSS_PHY_180_DATA 0x00000000 +#define DDRSS_PHY_181_DATA 0x00000000 +#define DDRSS_PHY_182_DATA 0x00000000 +#define DDRSS_PHY_183_DATA 0x00000000 +#define DDRSS_PHY_184_DATA 0x00000000 +#define DDRSS_PHY_185_DATA 0x00000000 +#define DDRSS_PHY_186_DATA 0x00000000 +#define DDRSS_PHY_187_DATA 0x00000000 +#define DDRSS_PHY_188_DATA 0x00000000 +#define DDRSS_PHY_189_DATA 0x00000000 +#define DDRSS_PHY_190_DATA 0x00000000 +#define DDRSS_PHY_191_DATA 0x00000000 +#define DDRSS_PHY_192_DATA 0x00000000 +#define DDRSS_PHY_193_DATA 0x00000000 +#define DDRSS_PHY_194_DATA 0x00000000 +#define DDRSS_PHY_195_DATA 0x00000000 +#define DDRSS_PHY_196_DATA 0x00000000 +#define DDRSS_PHY_197_DATA 0x00000000 +#define DDRSS_PHY_198_DATA 0x00000000 +#define DDRSS_PHY_199_DATA 0x00000000 +#define DDRSS_PHY_200_DATA 0x00000000 +#define DDRSS_PHY_201_DATA 0x00000000 +#define DDRSS_PHY_202_DATA 0x00000000 +#define DDRSS_PHY_203_DATA 0x00000000 +#define DDRSS_PHY_204_DATA 0x00000000 +#define DDRSS_PHY_205_DATA 0x00000000 +#define DDRSS_PHY_206_DATA 0x00000000 +#define DDRSS_PHY_207_DATA 0x00000000 +#define DDRSS_PHY_208_DATA 0x00000000 +#define DDRSS_PHY_209_DATA 0x00000000 +#define DDRSS_PHY_210_DATA 0x00000000 +#define DDRSS_PHY_211_DATA 0x00000000 +#define DDRSS_PHY_212_DATA 0x00000000 +#define DDRSS_PHY_213_DATA 0x00000000 +#define DDRSS_PHY_214_DATA 0x00000000 +#define DDRSS_PHY_215_DATA 0x00000000 +#define DDRSS_PHY_216_DATA 0x00000000 +#define DDRSS_PHY_217_DATA 0x00000000 +#define DDRSS_PHY_218_DATA 0x00000000 +#define DDRSS_PHY_219_DATA 0x00000000 +#define DDRSS_PHY_220_DATA 0x00000000 +#define DDRSS_PHY_221_DATA 0x00000000 +#define DDRSS_PHY_222_DATA 0x00000000 +#define DDRSS_PHY_223_DATA 0x00000000 +#define DDRSS_PHY_224_DATA 0x00000000 +#define DDRSS_PHY_225_DATA 0x00000000 +#define DDRSS_PHY_226_DATA 0x00000000 +#define DDRSS_PHY_227_DATA 0x00000000 +#define DDRSS_PHY_228_DATA 0x00000000 +#define DDRSS_PHY_229_DATA 0x00000000 +#define DDRSS_PHY_230_DATA 0x00000000 +#define DDRSS_PHY_231_DATA 0x00000000 +#define DDRSS_PHY_232_DATA 0x00000000 +#define DDRSS_PHY_233_DATA 0x00000000 +#define DDRSS_PHY_234_DATA 0x00000000 +#define DDRSS_PHY_235_DATA 0x00000000 +#define DDRSS_PHY_236_DATA 0x00000000 +#define DDRSS_PHY_237_DATA 0x00000000 +#define DDRSS_PHY_238_DATA 0x00000000 +#define DDRSS_PHY_239_DATA 0x00000000 +#define DDRSS_PHY_240_DATA 0x00000000 +#define DDRSS_PHY_241_DATA 0x00000000 +#define DDRSS_PHY_242_DATA 0x00000000 +#define DDRSS_PHY_243_DATA 0x00000000 +#define DDRSS_PHY_244_DATA 0x00000000 +#define DDRSS_PHY_245_DATA 0x00000000 +#define DDRSS_PHY_246_DATA 0x00000000 +#define DDRSS_PHY_247_DATA 0x00000000 +#define DDRSS_PHY_248_DATA 0x00000000 +#define DDRSS_PHY_249_DATA 0x00000000 +#define DDRSS_PHY_250_DATA 0x00000000 +#define DDRSS_PHY_251_DATA 0x00000000 +#define DDRSS_PHY_252_DATA 0x00000000 +#define DDRSS_PHY_253_DATA 0x00000000 +#define DDRSS_PHY_254_DATA 0x00000000 +#define DDRSS_PHY_255_DATA 0x00000000 +#define DDRSS_PHY_256_DATA 0x000004F0 +#define DDRSS_PHY_257_DATA 0x00000000 +#define DDRSS_PHY_258_DATA 0x00030200 +#define DDRSS_PHY_259_DATA 0x00000000 +#define DDRSS_PHY_260_DATA 0x00000000 +#define DDRSS_PHY_261_DATA 0x01030000 +#define DDRSS_PHY_262_DATA 0x00010000 +#define DDRSS_PHY_263_DATA 0x01030004 +#define DDRSS_PHY_264_DATA 0x01000000 +#define DDRSS_PHY_265_DATA 0x00000000 +#define DDRSS_PHY_266_DATA 0x00000000 +#define DDRSS_PHY_267_DATA 0x01000001 +#define DDRSS_PHY_268_DATA 0x00000100 +#define DDRSS_PHY_269_DATA 0x000800C0 +#define DDRSS_PHY_270_DATA 0x060100CC +#define DDRSS_PHY_271_DATA 0x00030066 +#define DDRSS_PHY_272_DATA 0x00000000 +#define DDRSS_PHY_273_DATA 0x00000301 +#define DDRSS_PHY_274_DATA 0x0000AAAA +#define DDRSS_PHY_275_DATA 0x00005555 +#define DDRSS_PHY_276_DATA 0x0000B5B5 +#define DDRSS_PHY_277_DATA 0x00004A4A +#define DDRSS_PHY_278_DATA 0x00005656 +#define DDRSS_PHY_279_DATA 0x0000A9A9 +#define DDRSS_PHY_280_DATA 0x0000A9A9 +#define DDRSS_PHY_281_DATA 0x0000B5B5 +#define DDRSS_PHY_282_DATA 0x00000000 +#define DDRSS_PHY_283_DATA 0x00000000 +#define DDRSS_PHY_284_DATA 0x2A000000 +#define DDRSS_PHY_285_DATA 0x00000808 +#define DDRSS_PHY_286_DATA 0x0F000000 +#define DDRSS_PHY_287_DATA 0x00000F0F +#define DDRSS_PHY_288_DATA 0x10400000 +#define DDRSS_PHY_289_DATA 0x0C002006 +#define DDRSS_PHY_290_DATA 0x00000000 +#define DDRSS_PHY_291_DATA 0x00000000 +#define DDRSS_PHY_292_DATA 0x55555555 +#define DDRSS_PHY_293_DATA 0xAAAAAAAA +#define DDRSS_PHY_294_DATA 0x55555555 +#define DDRSS_PHY_295_DATA 0xAAAAAAAA +#define DDRSS_PHY_296_DATA 0x00005555 +#define DDRSS_PHY_297_DATA 0x01000100 +#define DDRSS_PHY_298_DATA 0x00800180 +#define DDRSS_PHY_299_DATA 0x00000000 +#define DDRSS_PHY_300_DATA 0x00000000 +#define DDRSS_PHY_301_DATA 0x00000000 +#define DDRSS_PHY_302_DATA 0x00000000 +#define DDRSS_PHY_303_DATA 0x00000000 +#define DDRSS_PHY_304_DATA 0x00000000 +#define DDRSS_PHY_305_DATA 0x00000000 +#define DDRSS_PHY_306_DATA 0x00000000 +#define DDRSS_PHY_307_DATA 0x00000000 +#define DDRSS_PHY_308_DATA 0x00000000 +#define DDRSS_PHY_309_DATA 0x00000000 +#define DDRSS_PHY_310_DATA 0x00000000 +#define DDRSS_PHY_311_DATA 0x00000000 +#define DDRSS_PHY_312_DATA 0x00000000 +#define DDRSS_PHY_313_DATA 0x00000000 +#define DDRSS_PHY_314_DATA 0x00000000 +#define DDRSS_PHY_315_DATA 0x00000000 +#define DDRSS_PHY_316_DATA 0x00000000 +#define DDRSS_PHY_317_DATA 0x00000000 +#define DDRSS_PHY_318_DATA 0x00000000 +#define DDRSS_PHY_319_DATA 0x00000000 +#define DDRSS_PHY_320_DATA 0x00000000 +#define DDRSS_PHY_321_DATA 0x00000000 +#define DDRSS_PHY_322_DATA 0x00000104 +#define DDRSS_PHY_323_DATA 0x00000120 +#define DDRSS_PHY_324_DATA 0x00000000 +#define DDRSS_PHY_325_DATA 0x00000000 +#define DDRSS_PHY_326_DATA 0x00000000 +#define DDRSS_PHY_327_DATA 0x00000000 +#define DDRSS_PHY_328_DATA 0x00000000 +#define DDRSS_PHY_329_DATA 0x00000000 +#define DDRSS_PHY_330_DATA 0x00000000 +#define DDRSS_PHY_331_DATA 0x00000001 +#define DDRSS_PHY_332_DATA 0x07FF0000 +#define DDRSS_PHY_333_DATA 0x0080081F +#define DDRSS_PHY_334_DATA 0x00081020 +#define DDRSS_PHY_335_DATA 0x04010000 +#define DDRSS_PHY_336_DATA 0x00000000 +#define DDRSS_PHY_337_DATA 0x00000000 +#define DDRSS_PHY_338_DATA 0x00000000 +#define DDRSS_PHY_339_DATA 0x00000100 +#define DDRSS_PHY_340_DATA 0x01BB0B01 +#define DDRSS_PHY_341_DATA 0x1003BB0B +#define DDRSS_PHY_342_DATA 0x20000140 +#define DDRSS_PHY_343_DATA 0x07FF0200 +#define DDRSS_PHY_344_DATA 0x0000DD01 +#define DDRSS_PHY_345_DATA 0x10100303 +#define DDRSS_PHY_346_DATA 0x10101010 +#define DDRSS_PHY_347_DATA 0x10101010 +#define DDRSS_PHY_348_DATA 0x00021010 +#define DDRSS_PHY_349_DATA 0x00100010 +#define DDRSS_PHY_350_DATA 0x00100010 +#define DDRSS_PHY_351_DATA 0x00100010 +#define DDRSS_PHY_352_DATA 0x00100010 +#define DDRSS_PHY_353_DATA 0x00050010 +#define DDRSS_PHY_354_DATA 0x51517041 +#define DDRSS_PHY_355_DATA 0x31C06000 +#define DDRSS_PHY_356_DATA 0x07AB0340 +#define DDRSS_PHY_357_DATA 0x00C0C001 +#define DDRSS_PHY_358_DATA 0x0B0A0001 +#define DDRSS_PHY_359_DATA 0x10001000 +#define DDRSS_PHY_360_DATA 0x0C073E42 +#define DDRSS_PHY_361_DATA 0x0F0C2D01 +#define DDRSS_PHY_362_DATA 0x01000140 +#define DDRSS_PHY_363_DATA 0x0C000420 +#define DDRSS_PHY_364_DATA 0x00000198 +#define DDRSS_PHY_365_DATA 0x0A0000D0 +#define DDRSS_PHY_366_DATA 0x00030200 +#define DDRSS_PHY_367_DATA 0x02800000 +#define DDRSS_PHY_368_DATA 0x80800000 +#define DDRSS_PHY_369_DATA 0x000B2010 +#define DDRSS_PHY_370_DATA 0x76543210 +#define DDRSS_PHY_371_DATA 0x00000008 +#define DDRSS_PHY_372_DATA 0x02800280 +#define DDRSS_PHY_373_DATA 0x02800280 +#define DDRSS_PHY_374_DATA 0x02800280 +#define DDRSS_PHY_375_DATA 0x02800280 +#define DDRSS_PHY_376_DATA 0x00000280 +#define DDRSS_PHY_377_DATA 0x0000A000 +#define DDRSS_PHY_378_DATA 0x00A000A0 +#define DDRSS_PHY_379_DATA 0x00A000A0 +#define DDRSS_PHY_380_DATA 0x00A000A0 +#define DDRSS_PHY_381_DATA 0x00A000A0 +#define DDRSS_PHY_382_DATA 0x00A000A0 +#define DDRSS_PHY_383_DATA 0x00A000A0 +#define DDRSS_PHY_384_DATA 0x00A000A0 +#define DDRSS_PHY_385_DATA 0x00A000A0 +#define DDRSS_PHY_386_DATA 0x011900A0 +#define DDRSS_PHY_387_DATA 0x01A00004 +#define DDRSS_PHY_388_DATA 0x00000000 +#define DDRSS_PHY_389_DATA 0x00000000 +#define DDRSS_PHY_390_DATA 0x00080200 +#define DDRSS_PHY_391_DATA 0x00000000 +#define DDRSS_PHY_392_DATA 0x20202000 +#define DDRSS_PHY_393_DATA 0x20202020 +#define DDRSS_PHY_394_DATA 0xF0F02020 +#define DDRSS_PHY_395_DATA 0x00000000 +#define DDRSS_PHY_396_DATA 0x00000000 +#define DDRSS_PHY_397_DATA 0x00000000 +#define DDRSS_PHY_398_DATA 0x00000000 +#define DDRSS_PHY_399_DATA 0x00000000 +#define DDRSS_PHY_400_DATA 0x00000000 +#define DDRSS_PHY_401_DATA 0x00000000 +#define DDRSS_PHY_402_DATA 0x00000000 +#define DDRSS_PHY_403_DATA 0x00000000 +#define DDRSS_PHY_404_DATA 0x00000000 +#define DDRSS_PHY_405_DATA 0x00000000 +#define DDRSS_PHY_406_DATA 0x00000000 +#define DDRSS_PHY_407_DATA 0x00000000 +#define DDRSS_PHY_408_DATA 0x00000000 +#define DDRSS_PHY_409_DATA 0x00000000 +#define DDRSS_PHY_410_DATA 0x00000000 +#define DDRSS_PHY_411_DATA 0x00000000 +#define DDRSS_PHY_412_DATA 0x00000000 +#define DDRSS_PHY_413_DATA 0x00000000 +#define DDRSS_PHY_414_DATA 0x00000000 +#define DDRSS_PHY_415_DATA 0x00000000 +#define DDRSS_PHY_416_DATA 0x00000000 +#define DDRSS_PHY_417_DATA 0x00000000 +#define DDRSS_PHY_418_DATA 0x00000000 +#define DDRSS_PHY_419_DATA 0x00000000 +#define DDRSS_PHY_420_DATA 0x00000000 +#define DDRSS_PHY_421_DATA 0x00000000 +#define DDRSS_PHY_422_DATA 0x00000000 +#define DDRSS_PHY_423_DATA 0x00000000 +#define DDRSS_PHY_424_DATA 0x00000000 +#define DDRSS_PHY_425_DATA 0x00000000 +#define DDRSS_PHY_426_DATA 0x00000000 +#define DDRSS_PHY_427_DATA 0x00000000 +#define DDRSS_PHY_428_DATA 0x00000000 +#define DDRSS_PHY_429_DATA 0x00000000 +#define DDRSS_PHY_430_DATA 0x00000000 +#define DDRSS_PHY_431_DATA 0x00000000 +#define DDRSS_PHY_432_DATA 0x00000000 +#define DDRSS_PHY_433_DATA 0x00000000 +#define DDRSS_PHY_434_DATA 0x00000000 +#define DDRSS_PHY_435_DATA 0x00000000 +#define DDRSS_PHY_436_DATA 0x00000000 +#define DDRSS_PHY_437_DATA 0x00000000 +#define DDRSS_PHY_438_DATA 0x00000000 +#define DDRSS_PHY_439_DATA 0x00000000 +#define DDRSS_PHY_440_DATA 0x00000000 +#define DDRSS_PHY_441_DATA 0x00000000 +#define DDRSS_PHY_442_DATA 0x00000000 +#define DDRSS_PHY_443_DATA 0x00000000 +#define DDRSS_PHY_444_DATA 0x00000000 +#define DDRSS_PHY_445_DATA 0x00000000 +#define DDRSS_PHY_446_DATA 0x00000000 +#define DDRSS_PHY_447_DATA 0x00000000 +#define DDRSS_PHY_448_DATA 0x00000000 +#define DDRSS_PHY_449_DATA 0x00000000 +#define DDRSS_PHY_450_DATA 0x00000000 +#define DDRSS_PHY_451_DATA 0x00000000 +#define DDRSS_PHY_452_DATA 0x00000000 +#define DDRSS_PHY_453_DATA 0x00000000 +#define DDRSS_PHY_454_DATA 0x00000000 +#define DDRSS_PHY_455_DATA 0x00000000 +#define DDRSS_PHY_456_DATA 0x00000000 +#define DDRSS_PHY_457_DATA 0x00000000 +#define DDRSS_PHY_458_DATA 0x00000000 +#define DDRSS_PHY_459_DATA 0x00000000 +#define DDRSS_PHY_460_DATA 0x00000000 +#define DDRSS_PHY_461_DATA 0x00000000 +#define DDRSS_PHY_462_DATA 0x00000000 +#define DDRSS_PHY_463_DATA 0x00000000 +#define DDRSS_PHY_464_DATA 0x00000000 +#define DDRSS_PHY_465_DATA 0x00000000 +#define DDRSS_PHY_466_DATA 0x00000000 +#define DDRSS_PHY_467_DATA 0x00000000 +#define DDRSS_PHY_468_DATA 0x00000000 +#define DDRSS_PHY_469_DATA 0x00000000 +#define DDRSS_PHY_470_DATA 0x00000000 +#define DDRSS_PHY_471_DATA 0x00000000 +#define DDRSS_PHY_472_DATA 0x00000000 +#define DDRSS_PHY_473_DATA 0x00000000 +#define DDRSS_PHY_474_DATA 0x00000000 +#define DDRSS_PHY_475_DATA 0x00000000 +#define DDRSS_PHY_476_DATA 0x00000000 +#define DDRSS_PHY_477_DATA 0x00000000 +#define DDRSS_PHY_478_DATA 0x00000000 +#define DDRSS_PHY_479_DATA 0x00000000 +#define DDRSS_PHY_480_DATA 0x00000000 +#define DDRSS_PHY_481_DATA 0x00000000 +#define DDRSS_PHY_482_DATA 0x00000000 +#define DDRSS_PHY_483_DATA 0x00000000 +#define DDRSS_PHY_484_DATA 0x00000000 +#define DDRSS_PHY_485_DATA 0x00000000 +#define DDRSS_PHY_486_DATA 0x00000000 +#define DDRSS_PHY_487_DATA 0x00000000 +#define DDRSS_PHY_488_DATA 0x00000000 +#define DDRSS_PHY_489_DATA 0x00000000 +#define DDRSS_PHY_490_DATA 0x00000000 +#define DDRSS_PHY_491_DATA 0x00000000 +#define DDRSS_PHY_492_DATA 0x00000000 +#define DDRSS_PHY_493_DATA 0x00000000 +#define DDRSS_PHY_494_DATA 0x00000000 +#define DDRSS_PHY_495_DATA 0x00000000 +#define DDRSS_PHY_496_DATA 0x00000000 +#define DDRSS_PHY_497_DATA 0x00000000 +#define DDRSS_PHY_498_DATA 0x00000000 +#define DDRSS_PHY_499_DATA 0x00000000 +#define DDRSS_PHY_500_DATA 0x00000000 +#define DDRSS_PHY_501_DATA 0x00000000 +#define DDRSS_PHY_502_DATA 0x00000000 +#define DDRSS_PHY_503_DATA 0x00000000 +#define DDRSS_PHY_504_DATA 0x00000000 +#define DDRSS_PHY_505_DATA 0x00000000 +#define DDRSS_PHY_506_DATA 0x00000000 +#define DDRSS_PHY_507_DATA 0x00000000 +#define DDRSS_PHY_508_DATA 0x00000000 +#define DDRSS_PHY_509_DATA 0x00000000 +#define DDRSS_PHY_510_DATA 0x00000000 +#define DDRSS_PHY_511_DATA 0x00000000 +#define DDRSS_PHY_512_DATA 0x000004F0 +#define DDRSS_PHY_513_DATA 0x00000000 +#define DDRSS_PHY_514_DATA 0x00030200 +#define DDRSS_PHY_515_DATA 0x00000000 +#define DDRSS_PHY_516_DATA 0x00000000 +#define DDRSS_PHY_517_DATA 0x01030000 +#define DDRSS_PHY_518_DATA 0x00010000 +#define DDRSS_PHY_519_DATA 0x01030004 +#define DDRSS_PHY_520_DATA 0x01000000 +#define DDRSS_PHY_521_DATA 0x00000000 +#define DDRSS_PHY_522_DATA 0x00000000 +#define DDRSS_PHY_523_DATA 0x01000001 +#define DDRSS_PHY_524_DATA 0x00000100 +#define DDRSS_PHY_525_DATA 0x000800C0 +#define DDRSS_PHY_526_DATA 0x060100CC +#define DDRSS_PHY_527_DATA 0x00030066 +#define DDRSS_PHY_528_DATA 0x00000000 +#define DDRSS_PHY_529_DATA 0x00000301 +#define DDRSS_PHY_530_DATA 0x0000AAAA +#define DDRSS_PHY_531_DATA 0x00005555 +#define DDRSS_PHY_532_DATA 0x0000B5B5 +#define DDRSS_PHY_533_DATA 0x00004A4A +#define DDRSS_PHY_534_DATA 0x00005656 +#define DDRSS_PHY_535_DATA 0x0000A9A9 +#define DDRSS_PHY_536_DATA 0x0000A9A9 +#define DDRSS_PHY_537_DATA 0x0000B5B5 +#define DDRSS_PHY_538_DATA 0x00000000 +#define DDRSS_PHY_539_DATA 0x00000000 +#define DDRSS_PHY_540_DATA 0x2A000000 +#define DDRSS_PHY_541_DATA 0x00000808 +#define DDRSS_PHY_542_DATA 0x0F000000 +#define DDRSS_PHY_543_DATA 0x00000F0F +#define DDRSS_PHY_544_DATA 0x10400000 +#define DDRSS_PHY_545_DATA 0x0C002006 +#define DDRSS_PHY_546_DATA 0x00000000 +#define DDRSS_PHY_547_DATA 0x00000000 +#define DDRSS_PHY_548_DATA 0x55555555 +#define DDRSS_PHY_549_DATA 0xAAAAAAAA +#define DDRSS_PHY_550_DATA 0x55555555 +#define DDRSS_PHY_551_DATA 0xAAAAAAAA +#define DDRSS_PHY_552_DATA 0x00005555 +#define DDRSS_PHY_553_DATA 0x01000100 +#define DDRSS_PHY_554_DATA 0x00800180 +#define DDRSS_PHY_555_DATA 0x00000001 +#define DDRSS_PHY_556_DATA 0x00000000 +#define DDRSS_PHY_557_DATA 0x00000000 +#define DDRSS_PHY_558_DATA 0x00000000 +#define DDRSS_PHY_559_DATA 0x00000000 +#define DDRSS_PHY_560_DATA 0x00000000 +#define DDRSS_PHY_561_DATA 0x00000000 +#define DDRSS_PHY_562_DATA 0x00000000 +#define DDRSS_PHY_563_DATA 0x00000000 +#define DDRSS_PHY_564_DATA 0x00000000 +#define DDRSS_PHY_565_DATA 0x00000000 +#define DDRSS_PHY_566_DATA 0x00000000 +#define DDRSS_PHY_567_DATA 0x00000000 +#define DDRSS_PHY_568_DATA 0x00000000 +#define DDRSS_PHY_569_DATA 0x00000000 +#define DDRSS_PHY_570_DATA 0x00000000 +#define DDRSS_PHY_571_DATA 0x00000000 +#define DDRSS_PHY_572_DATA 0x00000000 +#define DDRSS_PHY_573_DATA 0x00000000 +#define DDRSS_PHY_574_DATA 0x00000000 +#define DDRSS_PHY_575_DATA 0x00000000 +#define DDRSS_PHY_576_DATA 0x00000000 +#define DDRSS_PHY_577_DATA 0x00000000 +#define DDRSS_PHY_578_DATA 0x00000104 +#define DDRSS_PHY_579_DATA 0x00000120 +#define DDRSS_PHY_580_DATA 0x00000000 +#define DDRSS_PHY_581_DATA 0x00000000 +#define DDRSS_PHY_582_DATA 0x00000000 +#define DDRSS_PHY_583_DATA 0x00000000 +#define DDRSS_PHY_584_DATA 0x00000000 +#define DDRSS_PHY_585_DATA 0x00000000 +#define DDRSS_PHY_586_DATA 0x00000000 +#define DDRSS_PHY_587_DATA 0x00000001 +#define DDRSS_PHY_588_DATA 0x07FF0000 +#define DDRSS_PHY_589_DATA 0x0080081F +#define DDRSS_PHY_590_DATA 0x00081020 +#define DDRSS_PHY_591_DATA 0x04010000 +#define DDRSS_PHY_592_DATA 0x00000000 +#define DDRSS_PHY_593_DATA 0x00000000 +#define DDRSS_PHY_594_DATA 0x00000000 +#define DDRSS_PHY_595_DATA 0x00000100 +#define DDRSS_PHY_596_DATA 0x01BB0B01 +#define DDRSS_PHY_597_DATA 0x1003BB0B +#define DDRSS_PHY_598_DATA 0x20000140 +#define DDRSS_PHY_599_DATA 0x07FF0200 +#define DDRSS_PHY_600_DATA 0x0000DD01 +#define DDRSS_PHY_601_DATA 0x10100303 +#define DDRSS_PHY_602_DATA 0x10101010 +#define DDRSS_PHY_603_DATA 0x10101010 +#define DDRSS_PHY_604_DATA 0x00021010 +#define DDRSS_PHY_605_DATA 0x00100010 +#define DDRSS_PHY_606_DATA 0x00100010 +#define DDRSS_PHY_607_DATA 0x00100010 +#define DDRSS_PHY_608_DATA 0x00100010 +#define DDRSS_PHY_609_DATA 0x00050010 +#define DDRSS_PHY_610_DATA 0x51517041 +#define DDRSS_PHY_611_DATA 0x31C06000 +#define DDRSS_PHY_612_DATA 0x07AB0340 +#define DDRSS_PHY_613_DATA 0x00C0C001 +#define DDRSS_PHY_614_DATA 0x0B0A0001 +#define DDRSS_PHY_615_DATA 0x10001000 +#define DDRSS_PHY_616_DATA 0x0C073E42 +#define DDRSS_PHY_617_DATA 0x0F0C2D01 +#define DDRSS_PHY_618_DATA 0x01000140 +#define DDRSS_PHY_619_DATA 0x0C000420 +#define DDRSS_PHY_620_DATA 0x00000198 +#define DDRSS_PHY_621_DATA 0x0A0000D0 +#define DDRSS_PHY_622_DATA 0x00030200 +#define DDRSS_PHY_623_DATA 0x02800000 +#define DDRSS_PHY_624_DATA 0x80800000 +#define DDRSS_PHY_625_DATA 0x000B2010 +#define DDRSS_PHY_626_DATA 0x76543210 +#define DDRSS_PHY_627_DATA 0x00000008 +#define DDRSS_PHY_628_DATA 0x02800280 +#define DDRSS_PHY_629_DATA 0x02800280 +#define DDRSS_PHY_630_DATA 0x02800280 +#define DDRSS_PHY_631_DATA 0x02800280 +#define DDRSS_PHY_632_DATA 0x00000280 +#define DDRSS_PHY_633_DATA 0x0000A000 +#define DDRSS_PHY_634_DATA 0x00A000A0 +#define DDRSS_PHY_635_DATA 0x00A000A0 +#define DDRSS_PHY_636_DATA 0x00A000A0 +#define DDRSS_PHY_637_DATA 0x00A000A0 +#define DDRSS_PHY_638_DATA 0x00A000A0 +#define DDRSS_PHY_639_DATA 0x00A000A0 +#define DDRSS_PHY_640_DATA 0x00A000A0 +#define DDRSS_PHY_641_DATA 0x00A000A0 +#define DDRSS_PHY_642_DATA 0x011900A0 +#define DDRSS_PHY_643_DATA 0x01A00004 +#define DDRSS_PHY_644_DATA 0x00000000 +#define DDRSS_PHY_645_DATA 0x00000000 +#define DDRSS_PHY_646_DATA 0x00080200 +#define DDRSS_PHY_647_DATA 0x00000000 +#define DDRSS_PHY_648_DATA 0x20202000 +#define DDRSS_PHY_649_DATA 0x20202020 +#define DDRSS_PHY_650_DATA 0xF0F02020 +#define DDRSS_PHY_651_DATA 0x00000000 +#define DDRSS_PHY_652_DATA 0x00000000 +#define DDRSS_PHY_653_DATA 0x00000000 +#define DDRSS_PHY_654_DATA 0x00000000 +#define DDRSS_PHY_655_DATA 0x00000000 +#define DDRSS_PHY_656_DATA 0x00000000 +#define DDRSS_PHY_657_DATA 0x00000000 +#define DDRSS_PHY_658_DATA 0x00000000 +#define DDRSS_PHY_659_DATA 0x00000000 +#define DDRSS_PHY_660_DATA 0x00000000 +#define DDRSS_PHY_661_DATA 0x00000000 +#define DDRSS_PHY_662_DATA 0x00000000 +#define DDRSS_PHY_663_DATA 0x00000000 +#define DDRSS_PHY_664_DATA 0x00000000 +#define DDRSS_PHY_665_DATA 0x00000000 +#define DDRSS_PHY_666_DATA 0x00000000 +#define DDRSS_PHY_667_DATA 0x00000000 +#define DDRSS_PHY_668_DATA 0x00000000 +#define DDRSS_PHY_669_DATA 0x00000000 +#define DDRSS_PHY_670_DATA 0x00000000 +#define DDRSS_PHY_671_DATA 0x00000000 +#define DDRSS_PHY_672_DATA 0x00000000 +#define DDRSS_PHY_673_DATA 0x00000000 +#define DDRSS_PHY_674_DATA 0x00000000 +#define DDRSS_PHY_675_DATA 0x00000000 +#define DDRSS_PHY_676_DATA 0x00000000 +#define DDRSS_PHY_677_DATA 0x00000000 +#define DDRSS_PHY_678_DATA 0x00000000 +#define DDRSS_PHY_679_DATA 0x00000000 +#define DDRSS_PHY_680_DATA 0x00000000 +#define DDRSS_PHY_681_DATA 0x00000000 +#define DDRSS_PHY_682_DATA 0x00000000 +#define DDRSS_PHY_683_DATA 0x00000000 +#define DDRSS_PHY_684_DATA 0x00000000 +#define DDRSS_PHY_685_DATA 0x00000000 +#define DDRSS_PHY_686_DATA 0x00000000 +#define DDRSS_PHY_687_DATA 0x00000000 +#define DDRSS_PHY_688_DATA 0x00000000 +#define DDRSS_PHY_689_DATA 0x00000000 +#define DDRSS_PHY_690_DATA 0x00000000 +#define DDRSS_PHY_691_DATA 0x00000000 +#define DDRSS_PHY_692_DATA 0x00000000 +#define DDRSS_PHY_693_DATA 0x00000000 +#define DDRSS_PHY_694_DATA 0x00000000 +#define DDRSS_PHY_695_DATA 0x00000000 +#define DDRSS_PHY_696_DATA 0x00000000 +#define DDRSS_PHY_697_DATA 0x00000000 +#define DDRSS_PHY_698_DATA 0x00000000 +#define DDRSS_PHY_699_DATA 0x00000000 +#define DDRSS_PHY_700_DATA 0x00000000 +#define DDRSS_PHY_701_DATA 0x00000000 +#define DDRSS_PHY_702_DATA 0x00000000 +#define DDRSS_PHY_703_DATA 0x00000000 +#define DDRSS_PHY_704_DATA 0x00000000 +#define DDRSS_PHY_705_DATA 0x00000000 +#define DDRSS_PHY_706_DATA 0x00000000 +#define DDRSS_PHY_707_DATA 0x00000000 +#define DDRSS_PHY_708_DATA 0x00000000 +#define DDRSS_PHY_709_DATA 0x00000000 +#define DDRSS_PHY_710_DATA 0x00000000 +#define DDRSS_PHY_711_DATA 0x00000000 +#define DDRSS_PHY_712_DATA 0x00000000 +#define DDRSS_PHY_713_DATA 0x00000000 +#define DDRSS_PHY_714_DATA 0x00000000 +#define DDRSS_PHY_715_DATA 0x00000000 +#define DDRSS_PHY_716_DATA 0x00000000 +#define DDRSS_PHY_717_DATA 0x00000000 +#define DDRSS_PHY_718_DATA 0x00000000 +#define DDRSS_PHY_719_DATA 0x00000000 +#define DDRSS_PHY_720_DATA 0x00000000 +#define DDRSS_PHY_721_DATA 0x00000000 +#define DDRSS_PHY_722_DATA 0x00000000 +#define DDRSS_PHY_723_DATA 0x00000000 +#define DDRSS_PHY_724_DATA 0x00000000 +#define DDRSS_PHY_725_DATA 0x00000000 +#define DDRSS_PHY_726_DATA 0x00000000 +#define DDRSS_PHY_727_DATA 0x00000000 +#define DDRSS_PHY_728_DATA 0x00000000 +#define DDRSS_PHY_729_DATA 0x00000000 +#define DDRSS_PHY_730_DATA 0x00000000 +#define DDRSS_PHY_731_DATA 0x00000000 +#define DDRSS_PHY_732_DATA 0x00000000 +#define DDRSS_PHY_733_DATA 0x00000000 +#define DDRSS_PHY_734_DATA 0x00000000 +#define DDRSS_PHY_735_DATA 0x00000000 +#define DDRSS_PHY_736_DATA 0x00000000 +#define DDRSS_PHY_737_DATA 0x00000000 +#define DDRSS_PHY_738_DATA 0x00000000 +#define DDRSS_PHY_739_DATA 0x00000000 +#define DDRSS_PHY_740_DATA 0x00000000 +#define DDRSS_PHY_741_DATA 0x00000000 +#define DDRSS_PHY_742_DATA 0x00000000 +#define DDRSS_PHY_743_DATA 0x00000000 +#define DDRSS_PHY_744_DATA 0x00000000 +#define DDRSS_PHY_745_DATA 0x00000000 +#define DDRSS_PHY_746_DATA 0x00000000 +#define DDRSS_PHY_747_DATA 0x00000000 +#define DDRSS_PHY_748_DATA 0x00000000 +#define DDRSS_PHY_749_DATA 0x00000000 +#define DDRSS_PHY_750_DATA 0x00000000 +#define DDRSS_PHY_751_DATA 0x00000000 +#define DDRSS_PHY_752_DATA 0x00000000 +#define DDRSS_PHY_753_DATA 0x00000000 +#define DDRSS_PHY_754_DATA 0x00000000 +#define DDRSS_PHY_755_DATA 0x00000000 +#define DDRSS_PHY_756_DATA 0x00000000 +#define DDRSS_PHY_757_DATA 0x00000000 +#define DDRSS_PHY_758_DATA 0x00000000 +#define DDRSS_PHY_759_DATA 0x00000000 +#define DDRSS_PHY_760_DATA 0x00000000 +#define DDRSS_PHY_761_DATA 0x00000000 +#define DDRSS_PHY_762_DATA 0x00000000 +#define DDRSS_PHY_763_DATA 0x00000000 +#define DDRSS_PHY_764_DATA 0x00000000 +#define DDRSS_PHY_765_DATA 0x00000000 +#define DDRSS_PHY_766_DATA 0x00000000 +#define DDRSS_PHY_767_DATA 0x00000000 +#define DDRSS_PHY_768_DATA 0x000004F0 +#define DDRSS_PHY_769_DATA 0x00000000 +#define DDRSS_PHY_770_DATA 0x00030200 +#define DDRSS_PHY_771_DATA 0x00000000 +#define DDRSS_PHY_772_DATA 0x00000000 +#define DDRSS_PHY_773_DATA 0x01030000 +#define DDRSS_PHY_774_DATA 0x00010000 +#define DDRSS_PHY_775_DATA 0x01030004 +#define DDRSS_PHY_776_DATA 0x01000000 +#define DDRSS_PHY_777_DATA 0x00000000 +#define DDRSS_PHY_778_DATA 0x00000000 +#define DDRSS_PHY_779_DATA 0x01000001 +#define DDRSS_PHY_780_DATA 0x00000100 +#define DDRSS_PHY_781_DATA 0x000800C0 +#define DDRSS_PHY_782_DATA 0x060100CC +#define DDRSS_PHY_783_DATA 0x00030066 +#define DDRSS_PHY_784_DATA 0x00000000 +#define DDRSS_PHY_785_DATA 0x00000301 +#define DDRSS_PHY_786_DATA 0x0000AAAA +#define DDRSS_PHY_787_DATA 0x00005555 +#define DDRSS_PHY_788_DATA 0x0000B5B5 +#define DDRSS_PHY_789_DATA 0x00004A4A +#define DDRSS_PHY_790_DATA 0x00005656 +#define DDRSS_PHY_791_DATA 0x0000A9A9 +#define DDRSS_PHY_792_DATA 0x0000A9A9 +#define DDRSS_PHY_793_DATA 0x0000B5B5 +#define DDRSS_PHY_794_DATA 0x00000000 +#define DDRSS_PHY_795_DATA 0x00000000 +#define DDRSS_PHY_796_DATA 0x2A000000 +#define DDRSS_PHY_797_DATA 0x00000808 +#define DDRSS_PHY_798_DATA 0x0F000000 +#define DDRSS_PHY_799_DATA 0x00000F0F +#define DDRSS_PHY_800_DATA 0x10400000 +#define DDRSS_PHY_801_DATA 0x0C002006 +#define DDRSS_PHY_802_DATA 0x00000000 +#define DDRSS_PHY_803_DATA 0x00000000 +#define DDRSS_PHY_804_DATA 0x55555555 +#define DDRSS_PHY_805_DATA 0xAAAAAAAA +#define DDRSS_PHY_806_DATA 0x55555555 +#define DDRSS_PHY_807_DATA 0xAAAAAAAA +#define DDRSS_PHY_808_DATA 0x00005555 +#define DDRSS_PHY_809_DATA 0x01000100 +#define DDRSS_PHY_810_DATA 0x00800180 +#define DDRSS_PHY_811_DATA 0x00000000 +#define DDRSS_PHY_812_DATA 0x00000000 +#define DDRSS_PHY_813_DATA 0x00000000 +#define DDRSS_PHY_814_DATA 0x00000000 +#define DDRSS_PHY_815_DATA 0x00000000 +#define DDRSS_PHY_816_DATA 0x00000000 +#define DDRSS_PHY_817_DATA 0x00000000 +#define DDRSS_PHY_818_DATA 0x00000000 +#define DDRSS_PHY_819_DATA 0x00000000 +#define DDRSS_PHY_820_DATA 0x00000000 +#define DDRSS_PHY_821_DATA 0x00000000 +#define DDRSS_PHY_822_DATA 0x00000000 +#define DDRSS_PHY_823_DATA 0x00000000 +#define DDRSS_PHY_824_DATA 0x00000000 +#define DDRSS_PHY_825_DATA 0x00000000 +#define DDRSS_PHY_826_DATA 0x00000000 +#define DDRSS_PHY_827_DATA 0x00000000 +#define DDRSS_PHY_828_DATA 0x00000000 +#define DDRSS_PHY_829_DATA 0x00000000 +#define DDRSS_PHY_830_DATA 0x00000000 +#define DDRSS_PHY_831_DATA 0x00000000 +#define DDRSS_PHY_832_DATA 0x00000000 +#define DDRSS_PHY_833_DATA 0x00000000 +#define DDRSS_PHY_834_DATA 0x00000104 +#define DDRSS_PHY_835_DATA 0x00000120 +#define DDRSS_PHY_836_DATA 0x00000000 +#define DDRSS_PHY_837_DATA 0x00000000 +#define DDRSS_PHY_838_DATA 0x00000000 +#define DDRSS_PHY_839_DATA 0x00000000 +#define DDRSS_PHY_840_DATA 0x00000000 +#define DDRSS_PHY_841_DATA 0x00000000 +#define DDRSS_PHY_842_DATA 0x00000000 +#define DDRSS_PHY_843_DATA 0x00000001 +#define DDRSS_PHY_844_DATA 0x07FF0000 +#define DDRSS_PHY_845_DATA 0x0080081F +#define DDRSS_PHY_846_DATA 0x00081020 +#define DDRSS_PHY_847_DATA 0x04010000 +#define DDRSS_PHY_848_DATA 0x00000000 +#define DDRSS_PHY_849_DATA 0x00000000 +#define DDRSS_PHY_850_DATA 0x00000000 +#define DDRSS_PHY_851_DATA 0x00000100 +#define DDRSS_PHY_852_DATA 0x01BB0B01 +#define DDRSS_PHY_853_DATA 0x1003BB0B +#define DDRSS_PHY_854_DATA 0x20000140 +#define DDRSS_PHY_855_DATA 0x07FF0200 +#define DDRSS_PHY_856_DATA 0x0000DD01 +#define DDRSS_PHY_857_DATA 0x10100303 +#define DDRSS_PHY_858_DATA 0x10101010 +#define DDRSS_PHY_859_DATA 0x10101010 +#define DDRSS_PHY_860_DATA 0x00021010 +#define DDRSS_PHY_861_DATA 0x00100010 +#define DDRSS_PHY_862_DATA 0x00100010 +#define DDRSS_PHY_863_DATA 0x00100010 +#define DDRSS_PHY_864_DATA 0x00100010 +#define DDRSS_PHY_865_DATA 0x00050010 +#define DDRSS_PHY_866_DATA 0x51517041 +#define DDRSS_PHY_867_DATA 0x31C06000 +#define DDRSS_PHY_868_DATA 0x07AB0340 +#define DDRSS_PHY_869_DATA 0x00C0C001 +#define DDRSS_PHY_870_DATA 0x0B0A0001 +#define DDRSS_PHY_871_DATA 0x10001000 +#define DDRSS_PHY_872_DATA 0x0C073E42 +#define DDRSS_PHY_873_DATA 0x0F0C2D01 +#define DDRSS_PHY_874_DATA 0x01000140 +#define DDRSS_PHY_875_DATA 0x0C000420 +#define DDRSS_PHY_876_DATA 0x00000198 +#define DDRSS_PHY_877_DATA 0x0A0000D0 +#define DDRSS_PHY_878_DATA 0x00030200 +#define DDRSS_PHY_879_DATA 0x02800000 +#define DDRSS_PHY_880_DATA 0x80800000 +#define DDRSS_PHY_881_DATA 0x000B2010 +#define DDRSS_PHY_882_DATA 0x76543210 +#define DDRSS_PHY_883_DATA 0x00000008 +#define DDRSS_PHY_884_DATA 0x02800280 +#define DDRSS_PHY_885_DATA 0x02800280 +#define DDRSS_PHY_886_DATA 0x02800280 +#define DDRSS_PHY_887_DATA 0x02800280 +#define DDRSS_PHY_888_DATA 0x00000280 +#define DDRSS_PHY_889_DATA 0x0000A000 +#define DDRSS_PHY_890_DATA 0x00A000A0 +#define DDRSS_PHY_891_DATA 0x00A000A0 +#define DDRSS_PHY_892_DATA 0x00A000A0 +#define DDRSS_PHY_893_DATA 0x00A000A0 +#define DDRSS_PHY_894_DATA 0x00A000A0 +#define DDRSS_PHY_895_DATA 0x00A000A0 +#define DDRSS_PHY_896_DATA 0x00A000A0 +#define DDRSS_PHY_897_DATA 0x00A000A0 +#define DDRSS_PHY_898_DATA 0x011900A0 +#define DDRSS_PHY_899_DATA 0x01A00004 +#define DDRSS_PHY_900_DATA 0x00000000 +#define DDRSS_PHY_901_DATA 0x00000000 +#define DDRSS_PHY_902_DATA 0x00080200 +#define DDRSS_PHY_903_DATA 0x00000000 +#define DDRSS_PHY_904_DATA 0x20202000 +#define DDRSS_PHY_905_DATA 0x20202020 +#define DDRSS_PHY_906_DATA 0xF0F02020 +#define DDRSS_PHY_907_DATA 0x00000000 +#define DDRSS_PHY_908_DATA 0x00000000 +#define DDRSS_PHY_909_DATA 0x00000000 +#define DDRSS_PHY_910_DATA 0x00000000 +#define DDRSS_PHY_911_DATA 0x00000000 +#define DDRSS_PHY_912_DATA 0x00000000 +#define DDRSS_PHY_913_DATA 0x00000000 +#define DDRSS_PHY_914_DATA 0x00000000 +#define DDRSS_PHY_915_DATA 0x00000000 +#define DDRSS_PHY_916_DATA 0x00000000 +#define DDRSS_PHY_917_DATA 0x00000000 +#define DDRSS_PHY_918_DATA 0x00000000 +#define DDRSS_PHY_919_DATA 0x00000000 +#define DDRSS_PHY_920_DATA 0x00000000 +#define DDRSS_PHY_921_DATA 0x00000000 +#define DDRSS_PHY_922_DATA 0x00000000 +#define DDRSS_PHY_923_DATA 0x00000000 +#define DDRSS_PHY_924_DATA 0x00000000 +#define DDRSS_PHY_925_DATA 0x00000000 +#define DDRSS_PHY_926_DATA 0x00000000 +#define DDRSS_PHY_927_DATA 0x00000000 +#define DDRSS_PHY_928_DATA 0x00000000 +#define DDRSS_PHY_929_DATA 0x00000000 +#define DDRSS_PHY_930_DATA 0x00000000 +#define DDRSS_PHY_931_DATA 0x00000000 +#define DDRSS_PHY_932_DATA 0x00000000 +#define DDRSS_PHY_933_DATA 0x00000000 +#define DDRSS_PHY_934_DATA 0x00000000 +#define DDRSS_PHY_935_DATA 0x00000000 +#define DDRSS_PHY_936_DATA 0x00000000 +#define DDRSS_PHY_937_DATA 0x00000000 +#define DDRSS_PHY_938_DATA 0x00000000 +#define DDRSS_PHY_939_DATA 0x00000000 +#define DDRSS_PHY_940_DATA 0x00000000 +#define DDRSS_PHY_941_DATA 0x00000000 +#define DDRSS_PHY_942_DATA 0x00000000 +#define DDRSS_PHY_943_DATA 0x00000000 +#define DDRSS_PHY_944_DATA 0x00000000 +#define DDRSS_PHY_945_DATA 0x00000000 +#define DDRSS_PHY_946_DATA 0x00000000 +#define DDRSS_PHY_947_DATA 0x00000000 +#define DDRSS_PHY_948_DATA 0x00000000 +#define DDRSS_PHY_949_DATA 0x00000000 +#define DDRSS_PHY_950_DATA 0x00000000 +#define DDRSS_PHY_951_DATA 0x00000000 +#define DDRSS_PHY_952_DATA 0x00000000 +#define DDRSS_PHY_953_DATA 0x00000000 +#define DDRSS_PHY_954_DATA 0x00000000 +#define DDRSS_PHY_955_DATA 0x00000000 +#define DDRSS_PHY_956_DATA 0x00000000 +#define DDRSS_PHY_957_DATA 0x00000000 +#define DDRSS_PHY_958_DATA 0x00000000 +#define DDRSS_PHY_959_DATA 0x00000000 +#define DDRSS_PHY_960_DATA 0x00000000 +#define DDRSS_PHY_961_DATA 0x00000000 +#define DDRSS_PHY_962_DATA 0x00000000 +#define DDRSS_PHY_963_DATA 0x00000000 +#define DDRSS_PHY_964_DATA 0x00000000 +#define DDRSS_PHY_965_DATA 0x00000000 +#define DDRSS_PHY_966_DATA 0x00000000 +#define DDRSS_PHY_967_DATA 0x00000000 +#define DDRSS_PHY_968_DATA 0x00000000 +#define DDRSS_PHY_969_DATA 0x00000000 +#define DDRSS_PHY_970_DATA 0x00000000 +#define DDRSS_PHY_971_DATA 0x00000000 +#define DDRSS_PHY_972_DATA 0x00000000 +#define DDRSS_PHY_973_DATA 0x00000000 +#define DDRSS_PHY_974_DATA 0x00000000 +#define DDRSS_PHY_975_DATA 0x00000000 +#define DDRSS_PHY_976_DATA 0x00000000 +#define DDRSS_PHY_977_DATA 0x00000000 +#define DDRSS_PHY_978_DATA 0x00000000 +#define DDRSS_PHY_979_DATA 0x00000000 +#define DDRSS_PHY_980_DATA 0x00000000 +#define DDRSS_PHY_981_DATA 0x00000000 +#define DDRSS_PHY_982_DATA 0x00000000 +#define DDRSS_PHY_983_DATA 0x00000000 +#define DDRSS_PHY_984_DATA 0x00000000 +#define DDRSS_PHY_985_DATA 0x00000000 +#define DDRSS_PHY_986_DATA 0x00000000 +#define DDRSS_PHY_987_DATA 0x00000000 +#define DDRSS_PHY_988_DATA 0x00000000 +#define DDRSS_PHY_989_DATA 0x00000000 +#define DDRSS_PHY_990_DATA 0x00000000 +#define DDRSS_PHY_991_DATA 0x00000000 +#define DDRSS_PHY_992_DATA 0x00000000 +#define DDRSS_PHY_993_DATA 0x00000000 +#define DDRSS_PHY_994_DATA 0x00000000 +#define DDRSS_PHY_995_DATA 0x00000000 +#define DDRSS_PHY_996_DATA 0x00000000 +#define DDRSS_PHY_997_DATA 0x00000000 +#define DDRSS_PHY_998_DATA 0x00000000 +#define DDRSS_PHY_999_DATA 0x00000000 +#define DDRSS_PHY_1000_DATA 0x00000000 +#define DDRSS_PHY_1001_DATA 0x00000000 +#define DDRSS_PHY_1002_DATA 0x00000000 +#define DDRSS_PHY_1003_DATA 0x00000000 +#define DDRSS_PHY_1004_DATA 0x00000000 +#define DDRSS_PHY_1005_DATA 0x00000000 +#define DDRSS_PHY_1006_DATA 0x00000000 +#define DDRSS_PHY_1007_DATA 0x00000000 +#define DDRSS_PHY_1008_DATA 0x00000000 +#define DDRSS_PHY_1009_DATA 0x00000000 +#define DDRSS_PHY_1010_DATA 0x00000000 +#define DDRSS_PHY_1011_DATA 0x00000000 +#define DDRSS_PHY_1012_DATA 0x00000000 +#define DDRSS_PHY_1013_DATA 0x00000000 +#define DDRSS_PHY_1014_DATA 0x00000000 +#define DDRSS_PHY_1015_DATA 0x00000000 +#define DDRSS_PHY_1016_DATA 0x00000000 +#define DDRSS_PHY_1017_DATA 0x00000000 +#define DDRSS_PHY_1018_DATA 0x00000000 +#define DDRSS_PHY_1019_DATA 0x00000000 +#define DDRSS_PHY_1020_DATA 0x00000000 +#define DDRSS_PHY_1021_DATA 0x00000000 +#define DDRSS_PHY_1022_DATA 0x00000000 +#define DDRSS_PHY_1023_DATA 0x00000000 +#define DDRSS_PHY_1024_DATA 0x00000000 +#define DDRSS_PHY_1025_DATA 0x00000000 +#define DDRSS_PHY_1026_DATA 0x00000000 +#define DDRSS_PHY_1027_DATA 0x00000000 +#define DDRSS_PHY_1028_DATA 0x00000000 +#define DDRSS_PHY_1029_DATA 0x00000100 +#define DDRSS_PHY_1030_DATA 0x00000200 +#define DDRSS_PHY_1031_DATA 0x00000000 +#define DDRSS_PHY_1032_DATA 0x00000000 +#define DDRSS_PHY_1033_DATA 0x00000000 +#define DDRSS_PHY_1034_DATA 0x00000000 +#define DDRSS_PHY_1035_DATA 0x00400000 +#define DDRSS_PHY_1036_DATA 0x00000080 +#define DDRSS_PHY_1037_DATA 0x00DCBA98 +#define DDRSS_PHY_1038_DATA 0x03000000 +#define DDRSS_PHY_1039_DATA 0x00200000 +#define DDRSS_PHY_1040_DATA 0x00000000 +#define DDRSS_PHY_1041_DATA 0x00000000 +#define DDRSS_PHY_1042_DATA 0x00000000 +#define DDRSS_PHY_1043_DATA 0x00000000 +#define DDRSS_PHY_1044_DATA 0x00000000 +#define DDRSS_PHY_1045_DATA 0x0000002A +#define DDRSS_PHY_1046_DATA 0x00000015 +#define DDRSS_PHY_1047_DATA 0x00000015 +#define DDRSS_PHY_1048_DATA 0x0000002A +#define DDRSS_PHY_1049_DATA 0x00000033 +#define DDRSS_PHY_1050_DATA 0x0000000C +#define DDRSS_PHY_1051_DATA 0x0000000C +#define DDRSS_PHY_1052_DATA 0x00000033 +#define DDRSS_PHY_1053_DATA 0x00543210 +#define DDRSS_PHY_1054_DATA 0x003F0000 +#define DDRSS_PHY_1055_DATA 0x000F013F +#define DDRSS_PHY_1056_DATA 0x20202003 +#define DDRSS_PHY_1057_DATA 0x00202020 +#define DDRSS_PHY_1058_DATA 0x20008008 +#define DDRSS_PHY_1059_DATA 0x00000810 +#define DDRSS_PHY_1060_DATA 0x00000F00 +#define DDRSS_PHY_1061_DATA 0x00000000 +#define DDRSS_PHY_1062_DATA 0x00000000 +#define DDRSS_PHY_1063_DATA 0x00000000 +#define DDRSS_PHY_1064_DATA 0x000305FF +#define DDRSS_PHY_1065_DATA 0x00030000 +#define DDRSS_PHY_1066_DATA 0x00000300 +#define DDRSS_PHY_1067_DATA 0x00000300 +#define DDRSS_PHY_1068_DATA 0x00000300 +#define DDRSS_PHY_1069_DATA 0x00000300 +#define DDRSS_PHY_1070_DATA 0x00000300 +#define DDRSS_PHY_1071_DATA 0x42080010 +#define DDRSS_PHY_1072_DATA 0x0000803E +#define DDRSS_PHY_1073_DATA 0x00000001 +#define DDRSS_PHY_1074_DATA 0x01000102 +#define DDRSS_PHY_1075_DATA 0x00008000 +#define DDRSS_PHY_1076_DATA 0x00000000 +#define DDRSS_PHY_1077_DATA 0x00000000 +#define DDRSS_PHY_1078_DATA 0x00000000 +#define DDRSS_PHY_1079_DATA 0x00000000 +#define DDRSS_PHY_1080_DATA 0x00000000 +#define DDRSS_PHY_1081_DATA 0x00000000 +#define DDRSS_PHY_1082_DATA 0x00000000 +#define DDRSS_PHY_1083_DATA 0x00000000 +#define DDRSS_PHY_1084_DATA 0x00000000 +#define DDRSS_PHY_1085_DATA 0x00000000 +#define DDRSS_PHY_1086_DATA 0x00000000 +#define DDRSS_PHY_1087_DATA 0x00000000 +#define DDRSS_PHY_1088_DATA 0x00000000 +#define DDRSS_PHY_1089_DATA 0x00000000 +#define DDRSS_PHY_1090_DATA 0x00000000 +#define DDRSS_PHY_1091_DATA 0x00000000 +#define DDRSS_PHY_1092_DATA 0x00000000 +#define DDRSS_PHY_1093_DATA 0x00000000 +#define DDRSS_PHY_1094_DATA 0x00000000 +#define DDRSS_PHY_1095_DATA 0x00000000 +#define DDRSS_PHY_1096_DATA 0x00000000 +#define DDRSS_PHY_1097_DATA 0x00000000 +#define DDRSS_PHY_1098_DATA 0x00000000 +#define DDRSS_PHY_1099_DATA 0x00000000 +#define DDRSS_PHY_1100_DATA 0x00000000 +#define DDRSS_PHY_1101_DATA 0x00000000 +#define DDRSS_PHY_1102_DATA 0x00000000 +#define DDRSS_PHY_1103_DATA 0x00000000 +#define DDRSS_PHY_1104_DATA 0x00000000 +#define DDRSS_PHY_1105_DATA 0x00000000 +#define DDRSS_PHY_1106_DATA 0x00000000 +#define DDRSS_PHY_1107_DATA 0x00000000 +#define DDRSS_PHY_1108_DATA 0x00000000 +#define DDRSS_PHY_1109_DATA 0x00000000 +#define DDRSS_PHY_1110_DATA 0x00000000 +#define DDRSS_PHY_1111_DATA 0x00000000 +#define DDRSS_PHY_1112_DATA 0x00000000 +#define DDRSS_PHY_1113_DATA 0x00000000 +#define DDRSS_PHY_1114_DATA 0x00000000 +#define DDRSS_PHY_1115_DATA 0x00000000 +#define DDRSS_PHY_1116_DATA 0x00000000 +#define DDRSS_PHY_1117_DATA 0x00000000 +#define DDRSS_PHY_1118_DATA 0x00000000 +#define DDRSS_PHY_1119_DATA 0x00000000 +#define DDRSS_PHY_1120_DATA 0x00000000 +#define DDRSS_PHY_1121_DATA 0x00000000 +#define DDRSS_PHY_1122_DATA 0x00000000 +#define DDRSS_PHY_1123_DATA 0x00000000 +#define DDRSS_PHY_1124_DATA 0x00000000 +#define DDRSS_PHY_1125_DATA 0x00000000 +#define DDRSS_PHY_1126_DATA 0x00000000 +#define DDRSS_PHY_1127_DATA 0x00000000 +#define DDRSS_PHY_1128_DATA 0x00000000 +#define DDRSS_PHY_1129_DATA 0x00000000 +#define DDRSS_PHY_1130_DATA 0x00000000 +#define DDRSS_PHY_1131_DATA 0x00000000 +#define DDRSS_PHY_1132_DATA 0x00000000 +#define DDRSS_PHY_1133_DATA 0x00000000 +#define DDRSS_PHY_1134_DATA 0x00000000 +#define DDRSS_PHY_1135_DATA 0x00000000 +#define DDRSS_PHY_1136_DATA 0x00000000 +#define DDRSS_PHY_1137_DATA 0x00000000 +#define DDRSS_PHY_1138_DATA 0x00000000 +#define DDRSS_PHY_1139_DATA 0x00000000 +#define DDRSS_PHY_1140_DATA 0x00000000 +#define DDRSS_PHY_1141_DATA 0x00000000 +#define DDRSS_PHY_1142_DATA 0x00000000 +#define DDRSS_PHY_1143_DATA 0x00000000 +#define DDRSS_PHY_1144_DATA 0x00000000 +#define DDRSS_PHY_1145_DATA 0x00000000 +#define DDRSS_PHY_1146_DATA 0x00000000 +#define DDRSS_PHY_1147_DATA 0x00000000 +#define DDRSS_PHY_1148_DATA 0x00000000 +#define DDRSS_PHY_1149_DATA 0x00000000 +#define DDRSS_PHY_1150_DATA 0x00000000 +#define DDRSS_PHY_1151_DATA 0x00000000 +#define DDRSS_PHY_1152_DATA 0x00000000 +#define DDRSS_PHY_1153_DATA 0x00000000 +#define DDRSS_PHY_1154_DATA 0x00000000 +#define DDRSS_PHY_1155_DATA 0x00000000 +#define DDRSS_PHY_1156_DATA 0x00000000 +#define DDRSS_PHY_1157_DATA 0x00000000 +#define DDRSS_PHY_1158_DATA 0x00000000 +#define DDRSS_PHY_1159_DATA 0x00000000 +#define DDRSS_PHY_1160_DATA 0x00000000 +#define DDRSS_PHY_1161_DATA 0x00000000 +#define DDRSS_PHY_1162_DATA 0x00000000 +#define DDRSS_PHY_1163_DATA 0x00000000 +#define DDRSS_PHY_1164_DATA 0x00000000 +#define DDRSS_PHY_1165_DATA 0x00000000 +#define DDRSS_PHY_1166_DATA 0x00000000 +#define DDRSS_PHY_1167_DATA 0x00000000 +#define DDRSS_PHY_1168_DATA 0x00000000 +#define DDRSS_PHY_1169_DATA 0x00000000 +#define DDRSS_PHY_1170_DATA 0x00000000 +#define DDRSS_PHY_1171_DATA 0x00000000 +#define DDRSS_PHY_1172_DATA 0x00000000 +#define DDRSS_PHY_1173_DATA 0x00000000 +#define DDRSS_PHY_1174_DATA 0x00000000 +#define DDRSS_PHY_1175_DATA 0x00000000 +#define DDRSS_PHY_1176_DATA 0x00000000 +#define DDRSS_PHY_1177_DATA 0x00000000 +#define DDRSS_PHY_1178_DATA 0x00000000 +#define DDRSS_PHY_1179_DATA 0x00000000 +#define DDRSS_PHY_1180_DATA 0x00000000 +#define DDRSS_PHY_1181_DATA 0x00000000 +#define DDRSS_PHY_1182_DATA 0x00000000 +#define DDRSS_PHY_1183_DATA 0x00000000 +#define DDRSS_PHY_1184_DATA 0x00000000 +#define DDRSS_PHY_1185_DATA 0x00000000 +#define DDRSS_PHY_1186_DATA 0x00000000 +#define DDRSS_PHY_1187_DATA 0x00000000 +#define DDRSS_PHY_1188_DATA 0x00000000 +#define DDRSS_PHY_1189_DATA 0x00000000 +#define DDRSS_PHY_1190_DATA 0x00000000 +#define DDRSS_PHY_1191_DATA 0x00000000 +#define DDRSS_PHY_1192_DATA 0x00000000 +#define DDRSS_PHY_1193_DATA 0x00000000 +#define DDRSS_PHY_1194_DATA 0x00000000 +#define DDRSS_PHY_1195_DATA 0x00000000 +#define DDRSS_PHY_1196_DATA 0x00000000 +#define DDRSS_PHY_1197_DATA 0x00000000 +#define DDRSS_PHY_1198_DATA 0x00000000 +#define DDRSS_PHY_1199_DATA 0x00000000 +#define DDRSS_PHY_1200_DATA 0x00000000 +#define DDRSS_PHY_1201_DATA 0x00000000 +#define DDRSS_PHY_1202_DATA 0x00000000 +#define DDRSS_PHY_1203_DATA 0x00000000 +#define DDRSS_PHY_1204_DATA 0x00000000 +#define DDRSS_PHY_1205_DATA 0x00000000 +#define DDRSS_PHY_1206_DATA 0x00000000 +#define DDRSS_PHY_1207_DATA 0x00000000 +#define DDRSS_PHY_1208_DATA 0x00000000 +#define DDRSS_PHY_1209_DATA 0x00000000 +#define DDRSS_PHY_1210_DATA 0x00000000 +#define DDRSS_PHY_1211_DATA 0x00000000 +#define DDRSS_PHY_1212_DATA 0x00000000 +#define DDRSS_PHY_1213_DATA 0x00000000 +#define DDRSS_PHY_1214_DATA 0x00000000 +#define DDRSS_PHY_1215_DATA 0x00000000 +#define DDRSS_PHY_1216_DATA 0x00000000 +#define DDRSS_PHY_1217_DATA 0x00000000 +#define DDRSS_PHY_1218_DATA 0x00000000 +#define DDRSS_PHY_1219_DATA 0x00000000 +#define DDRSS_PHY_1220_DATA 0x00000000 +#define DDRSS_PHY_1221_DATA 0x00000000 +#define DDRSS_PHY_1222_DATA 0x00000000 +#define DDRSS_PHY_1223_DATA 0x00000000 +#define DDRSS_PHY_1224_DATA 0x00000000 +#define DDRSS_PHY_1225_DATA 0x00000000 +#define DDRSS_PHY_1226_DATA 0x00000000 +#define DDRSS_PHY_1227_DATA 0x00000000 +#define DDRSS_PHY_1228_DATA 0x00000000 +#define DDRSS_PHY_1229_DATA 0x00000000 +#define DDRSS_PHY_1230_DATA 0x00000000 +#define DDRSS_PHY_1231_DATA 0x00000000 +#define DDRSS_PHY_1232_DATA 0x00000000 +#define DDRSS_PHY_1233_DATA 0x00000000 +#define DDRSS_PHY_1234_DATA 0x00000000 +#define DDRSS_PHY_1235_DATA 0x00000000 +#define DDRSS_PHY_1236_DATA 0x00000000 +#define DDRSS_PHY_1237_DATA 0x00000000 +#define DDRSS_PHY_1238_DATA 0x00000000 +#define DDRSS_PHY_1239_DATA 0x00000000 +#define DDRSS_PHY_1240_DATA 0x00000000 +#define DDRSS_PHY_1241_DATA 0x00000000 +#define DDRSS_PHY_1242_DATA 0x00000000 +#define DDRSS_PHY_1243_DATA 0x00000000 +#define DDRSS_PHY_1244_DATA 0x00000000 +#define DDRSS_PHY_1245_DATA 0x00000000 +#define DDRSS_PHY_1246_DATA 0x00000000 +#define DDRSS_PHY_1247_DATA 0x00000000 +#define DDRSS_PHY_1248_DATA 0x00000000 +#define DDRSS_PHY_1249_DATA 0x00000000 +#define DDRSS_PHY_1250_DATA 0x00000000 +#define DDRSS_PHY_1251_DATA 0x00000000 +#define DDRSS_PHY_1252_DATA 0x00000000 +#define DDRSS_PHY_1253_DATA 0x00000000 +#define DDRSS_PHY_1254_DATA 0x00000000 +#define DDRSS_PHY_1255_DATA 0x00000000 +#define DDRSS_PHY_1256_DATA 0x00000000 +#define DDRSS_PHY_1257_DATA 0x00000000 +#define DDRSS_PHY_1258_DATA 0x00000000 +#define DDRSS_PHY_1259_DATA 0x00000000 +#define DDRSS_PHY_1260_DATA 0x00000000 +#define DDRSS_PHY_1261_DATA 0x00000000 +#define DDRSS_PHY_1262_DATA 0x00000000 +#define DDRSS_PHY_1263_DATA 0x00000000 +#define DDRSS_PHY_1264_DATA 0x00000000 +#define DDRSS_PHY_1265_DATA 0x00000000 +#define DDRSS_PHY_1266_DATA 0x00000000 +#define DDRSS_PHY_1267_DATA 0x00000000 +#define DDRSS_PHY_1268_DATA 0x00000000 +#define DDRSS_PHY_1269_DATA 0x00000000 +#define DDRSS_PHY_1270_DATA 0x00000000 +#define DDRSS_PHY_1271_DATA 0x00000000 +#define DDRSS_PHY_1272_DATA 0x00000000 +#define DDRSS_PHY_1273_DATA 0x00000000 +#define DDRSS_PHY_1274_DATA 0x00000000 +#define DDRSS_PHY_1275_DATA 0x00000000 +#define DDRSS_PHY_1276_DATA 0x00000000 +#define DDRSS_PHY_1277_DATA 0x00000000 +#define DDRSS_PHY_1278_DATA 0x00000000 +#define DDRSS_PHY_1279_DATA 0x00000000 +#define DDRSS_PHY_1280_DATA 0x00000000 +#define DDRSS_PHY_1281_DATA 0x00010100 +#define DDRSS_PHY_1282_DATA 0x00000000 +#define DDRSS_PHY_1283_DATA 0x00000000 +#define DDRSS_PHY_1284_DATA 0x00050000 +#define DDRSS_PHY_1285_DATA 0x04000000 +#define DDRSS_PHY_1286_DATA 0x00000055 +#define DDRSS_PHY_1287_DATA 0x00000000 +#define DDRSS_PHY_1288_DATA 0x00000000 +#define DDRSS_PHY_1289_DATA 0x00000000 +#define DDRSS_PHY_1290_DATA 0x00000000 +#define DDRSS_PHY_1291_DATA 0x00002001 +#define DDRSS_PHY_1292_DATA 0x0000400F +#define DDRSS_PHY_1293_DATA 0x50020028 +#define DDRSS_PHY_1294_DATA 0x01010000 +#define DDRSS_PHY_1295_DATA 0x80080001 +#define DDRSS_PHY_1296_DATA 0x10200000 +#define DDRSS_PHY_1297_DATA 0x00000008 +#define DDRSS_PHY_1298_DATA 0x00000000 +#define DDRSS_PHY_1299_DATA 0x01090E00 +#define DDRSS_PHY_1300_DATA 0x00040101 +#define DDRSS_PHY_1301_DATA 0x0000010F +#define DDRSS_PHY_1302_DATA 0x00000000 +#define DDRSS_PHY_1303_DATA 0x0000FFFF +#define DDRSS_PHY_1304_DATA 0x00000000 +#define DDRSS_PHY_1305_DATA 0x01010000 +#define DDRSS_PHY_1306_DATA 0x01080402 +#define DDRSS_PHY_1307_DATA 0x01200F02 +#define DDRSS_PHY_1308_DATA 0x00194280 +#define DDRSS_PHY_1309_DATA 0x00000004 +#define DDRSS_PHY_1310_DATA 0x00052000 +#define DDRSS_PHY_1311_DATA 0x00000000 +#define DDRSS_PHY_1312_DATA 0x00000000 +#define DDRSS_PHY_1313_DATA 0x00000000 +#define DDRSS_PHY_1314_DATA 0x00000000 +#define DDRSS_PHY_1315_DATA 0x00000000 +#define DDRSS_PHY_1316_DATA 0x00000000 +#define DDRSS_PHY_1317_DATA 0x01000000 +#define DDRSS_PHY_1318_DATA 0x00000705 +#define DDRSS_PHY_1319_DATA 0x00000054 +#define DDRSS_PHY_1320_DATA 0x00030820 +#define DDRSS_PHY_1321_DATA 0x00010820 +#define DDRSS_PHY_1322_DATA 0x00010820 +#define DDRSS_PHY_1323_DATA 0x00010820 +#define DDRSS_PHY_1324_DATA 0x00010820 +#define DDRSS_PHY_1325_DATA 0x00010820 +#define DDRSS_PHY_1326_DATA 0x00010820 +#define DDRSS_PHY_1327_DATA 0x00010820 +#define DDRSS_PHY_1328_DATA 0x00010820 +#define DDRSS_PHY_1329_DATA 0x00000000 +#define DDRSS_PHY_1330_DATA 0x00000074 +#define DDRSS_PHY_1331_DATA 0x00000400 +#define DDRSS_PHY_1332_DATA 0x00000108 +#define DDRSS_PHY_1333_DATA 0x00000000 +#define DDRSS_PHY_1334_DATA 0x00000000 +#define DDRSS_PHY_1335_DATA 0x00000000 +#define DDRSS_PHY_1336_DATA 0x00000000 +#define DDRSS_PHY_1337_DATA 0x00000000 +#define DDRSS_PHY_1338_DATA 0x03000000 +#define DDRSS_PHY_1339_DATA 0x00000000 +#define DDRSS_PHY_1340_DATA 0x00000000 +#define DDRSS_PHY_1341_DATA 0x00000000 +#define DDRSS_PHY_1342_DATA 0x04102006 +#define DDRSS_PHY_1343_DATA 0x00041020 +#define DDRSS_PHY_1344_DATA 0x01C98C98 +#define DDRSS_PHY_1345_DATA 0x3F400000 +#define DDRSS_PHY_1346_DATA 0x3F3F1F3F +#define DDRSS_PHY_1347_DATA 0x0000001F +#define DDRSS_PHY_1348_DATA 0x00000000 +#define DDRSS_PHY_1349_DATA 0x00000000 +#define DDRSS_PHY_1350_DATA 0x00000000 +#define DDRSS_PHY_1351_DATA 0x00010000 +#define DDRSS_PHY_1352_DATA 0x00000000 +#define DDRSS_PHY_1353_DATA 0x00000000 +#define DDRSS_PHY_1354_DATA 0x00000000 +#define DDRSS_PHY_1355_DATA 0x00000000 +#define DDRSS_PHY_1356_DATA 0x76543210 +#define DDRSS_PHY_1357_DATA 0x00010198 +#define DDRSS_PHY_1358_DATA 0x00000000 +#define DDRSS_PHY_1359_DATA 0x00000000 +#define DDRSS_PHY_1360_DATA 0x00000000 +#define DDRSS_PHY_1361_DATA 0x00040700 +#define DDRSS_PHY_1362_DATA 0x00000000 +#define DDRSS_PHY_1363_DATA 0x00000000 +#define DDRSS_PHY_1364_DATA 0x00000000 +#define DDRSS_PHY_1365_DATA 0x00000000 +#define DDRSS_PHY_1366_DATA 0x00000000 +#define DDRSS_PHY_1367_DATA 0x00000002 +#define DDRSS_PHY_1368_DATA 0x00000000 +#define DDRSS_PHY_1369_DATA 0x00000000 +#define DDRSS_PHY_1370_DATA 0x00000000 +#define DDRSS_PHY_1371_DATA 0x00000000 +#define DDRSS_PHY_1372_DATA 0x00000000 +#define DDRSS_PHY_1373_DATA 0x00000000 +#define DDRSS_PHY_1374_DATA 0x00080000 +#define DDRSS_PHY_1375_DATA 0x000007FF +#define DDRSS_PHY_1376_DATA 0x00000000 +#define DDRSS_PHY_1377_DATA 0x00000000 +#define DDRSS_PHY_1378_DATA 0x00000000 +#define DDRSS_PHY_1379_DATA 0x00000000 +#define DDRSS_PHY_1380_DATA 0x00000000 +#define DDRSS_PHY_1381_DATA 0x00000000 +#define DDRSS_PHY_1382_DATA 0x000FFFFF +#define DDRSS_PHY_1383_DATA 0x000FFFFF +#define DDRSS_PHY_1384_DATA 0x0000FFFF +#define DDRSS_PHY_1385_DATA 0xFFFFFFF0 +#define DDRSS_PHY_1386_DATA 0x030FFFFF +#define DDRSS_PHY_1387_DATA 0x01FFFFFF +#define DDRSS_PHY_1388_DATA 0x0000FFFF +#define DDRSS_PHY_1389_DATA 0x00000000 +#define DDRSS_PHY_1390_DATA 0x00000000 +#define DDRSS_PHY_1391_DATA 0x00000000 +#define DDRSS_PHY_1392_DATA 0x00000000 +#define DDRSS_PHY_1393_DATA 0x0001F7C0 +#define DDRSS_PHY_1394_DATA 0x00000003 +#define DDRSS_PHY_1395_DATA 0x00000000 +#define DDRSS_PHY_1396_DATA 0x00001142 +#define DDRSS_PHY_1397_DATA 0x010207AB +#define DDRSS_PHY_1398_DATA 0x01000080 +#define DDRSS_PHY_1399_DATA 0x03900390 +#define DDRSS_PHY_1400_DATA 0x03900390 +#define DDRSS_PHY_1401_DATA 0x00000390 +#define DDRSS_PHY_1402_DATA 0x00000390 +#define DDRSS_PHY_1403_DATA 0x00000390 +#define DDRSS_PHY_1404_DATA 0x00000390 +#define DDRSS_PHY_1405_DATA 0x00000005 +#define DDRSS_PHY_1406_DATA 0x01813FFF +#define DDRSS_PHY_1407_DATA 0x000000FF +#define DDRSS_PHY_1408_DATA 0x0C000DFF +#define DDRSS_PHY_1409_DATA 0x30000DFF +#define DDRSS_PHY_1410_DATA 0x3F0DFF11 +#define DDRSS_PHY_1411_DATA 0x000100F0 +#define DDRSS_PHY_1412_DATA 0x780DFFFF +#define DDRSS_PHY_1413_DATA 0x00007E31 +#define DDRSS_PHY_1414_DATA 0x000CBF11 +#define DDRSS_PHY_1415_DATA 0x01FF0010 +#define DDRSS_PHY_1416_DATA 0x000CBF11 +#define DDRSS_PHY_1417_DATA 0x01FF0010 +#define DDRSS_PHY_1418_DATA 0x3F0DFF11 +#define DDRSS_PHY_1419_DATA 0x01FF00F0 +#define DDRSS_PHY_1420_DATA 0x3F0DFF11 +#define DDRSS_PHY_1421_DATA 0x01FF00F0 +#define DDRSS_PHY_1422_DATA 0x20040006 diff --git a/arch/arm/dts/k3-j721e-r5-beagleboneai64.dts b/arch/arm/dts/k3-j721e-r5-beagleboneai64.dts new file mode 100644 index 000000000000..fc0fa3e24394 --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-beagleboneai64.dts @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * https://beagleboard.org/ai-64 + * + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022 Jason Kridner, BeagleBoard.org Foundation + * Copyright (C) 2022-2023 Robert Nelson, BeagleBoard.org Foundation + */ + +#include "k3-j721e-beagleboneai64.dts" +#include "k3-j721e-ddr-beagleboneai64-lp4-3200.dtsi" +#include "k3-j721e-ddr.dtsi" + +#include "k3-j721e-beagleboneai64-u-boot.dtsi" + +/ { + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a72_0; + }; + + chosen { + tick-timer = &mcu_timer0; + }; + + a72_0: a72@0 { + compatible = "ti,am654-rproc"; + reg = <0x0 0x00a90000 0x0 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 202 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 4 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 202 0>; + clocks = <&k3_clks 61 1>; + assigned-clocks = <&k3_clks 202 2>, <&k3_clks 61 1>; + assigned-clock-rates = <2000000000>, <200000000>; + ti,sci = <&dmsc>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + bootph-pre-ram; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <3>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&secure_proxy_mcu 21>, + <&secure_proxy_mcu 23>; + bootph-pre-ram; + }; +}; + +&dmsc { + mboxes= <&secure_proxy_mcu 6>, + <&secure_proxy_mcu 8>, + <&secure_proxy_mcu 5>; + mbox-names = "rx", "tx", "notify"; + ti,host-id = <4>; + ti,secure-host; +}; + +&mcu_timer0 { + status = "okay"; + bootph-pre-ram; +}; + +&secure_proxy_mcu { + bootph-pre-ram; + /* We require this for boot handshake */ + status = "okay"; +}; + +&cbass_mcu_wakeup { + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_mcu 4>, <&secure_proxy_mcu 5>; + mbox-names = "tx", "rx"; + bootph-pre-ram; + }; +}; + +&mcu_ringacc { + ti,sci = <&dm_tifs>; +}; + +&mcu_udmap { + ti,sci = <&dm_tifs>; +}; + +&wkup_uart0_pins_default { + bootph-pre-ram; +}; + +&wkup_i2c0 { + bootph-pre-ram; +}; diff --git a/board/ti/j721e/MAINTAINERS b/board/ti/j721e/MAINTAINERS index f5ca7d06a347..8b79724dca39 100644 --- a/board/ti/j721e/MAINTAINERS +++ b/board/ti/j721e/MAINTAINERS @@ -1,3 +1,10 @@ +BEAGLEBONE-AI64 BOARD +M: Nishanth Menon nm@ti.com +M: Robert Nelson robertcnelson@gmail.com +M: Tom Rini trini@konsulko.com +S: Maintained +N: beagleboneai64 + J721E BOARD M: Tom Rini trini@konsulko.com S: Maintained
Add defconfig fragments for J721E based BeagleBone AI-64 and corresponding customized environment.
Signed-off-by: Nishanth Menon nm@ti.com --- board/ti/j721e/beagleboneai64.env | 19 ++++++++ board/ti/j721e/beagleboneai64_a72.config | 55 ++++++++++++++++++++++++ board/ti/j721e/beagleboneai64_r5.config | 19 ++++++++ 3 files changed, 93 insertions(+) create mode 100644 board/ti/j721e/beagleboneai64.env create mode 100644 board/ti/j721e/beagleboneai64_a72.config create mode 100644 board/ti/j721e/beagleboneai64_r5.config
diff --git a/board/ti/j721e/beagleboneai64.env b/board/ti/j721e/beagleboneai64.env new file mode 100644 index 000000000000..4f0a94a8113e --- /dev/null +++ b/board/ti/j721e/beagleboneai64.env @@ -0,0 +1,19 @@ +#include <env/ti/ti_common.env> +#include <env/ti/default_findfdt.env> +#include <env/ti/mmc.env> + +name_kern=Image +console=ttyS2,115200n8 +args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 +run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr} +set_led_state_fail_load= led led-0 off; led led-1 on; + led led-2 off; led led-3 on; led led-4 off +set_led_state_start_load=led led-0 on; led led-1 off; + led led-2 on; led led-3 off; led led-4 on +boot=mmc +mmcdev=1 +bootpart=1:1 +bootdir=/boot +boot_targets=mmc1 mmc0 usb pxe +bootmeths=script extlinux efi pxe +rd_spec=- diff --git a/board/ti/j721e/beagleboneai64_a72.config b/board/ti/j721e/beagleboneai64_a72.config new file mode 100644 index 000000000000..926f725508e5 --- /dev/null +++ b/board/ti/j721e/beagleboneai64_a72.config @@ -0,0 +1,55 @@ +# Defconfig fragment to apply on top of j721e_evm_a72_defconfig + +CONFIG_DEFAULT_DEVICE_TREE="k3-j721e-beagleboneai64" +CONFIG_SPL_OF_LIST="k3-j721e-beagleboneai64" +CONFIG_OF_LIST="k3-j721e-beagleboneai64" +CONFIG_BOOTCOMMAND="run set_led_state_start_load;run findfdt; run envboot; bootflow scan -lb;run set_led_state_fail_load" +CONFIG_EXT4_WRITE=y +CONFIG_LZO=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " + +# No Flash +CONFIG_HBMC_AM654=n +CONFIG_UFS=n + +# Sierra disabled for now till stability +CONFIG_PHY_CADENCE_SIERRA=n +CONFIG_PHY_J721E_WIZ=n +# Torrent only for DP. no DP splash screen +CONFIG_PHY_CADENCE_TORRENT=n + +# Use the Beaglebone-AI64 env file +CONFIG_ENV_SOURCE_FILE="beagleboneai64" +# No dependency on EEPROM detection +CONFIG_TI_I2C_BOARD_DETECT=n +# No board fixup to do +CONFIG_OF_BOARD_SETUP=n + +# Do not use emmc boot - use FS only +CONFIG_SUPPORT_EMMC_BOOT=n +CONFIG_MMC_IO_VOLTAGE=y +# CONFIG_SPL_MMC_IO_VOLTAGE is not set +CONFIG_MMC_UHS_SUPPORT=y +# CONFIG_SPL_MMC_UHS_SUPPORT is not set +CONFIG_MMC_HS200_SUPPORT=y +# CONFIG_SPL_MMC_HS200_SUPPORT is not set + +# Enable GPIO control +CONFIG_DM_GPIO=y +CONFIG_SPL_GPIO=y +CONFIG_DA8XX_GPIO=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPIO_READ=y +# Enable LEDs +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_SPL_LED=y +CONFIG_SPL_LED_GPIO=y +# Enable I2C bus +CONFIG_SPL_I2C=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_OMAP24XX=y +CONFIG_CMD_I2C=y diff --git a/board/ti/j721e/beagleboneai64_r5.config b/board/ti/j721e/beagleboneai64_r5.config new file mode 100644 index 000000000000..cf124fb70cf1 --- /dev/null +++ b/board/ti/j721e/beagleboneai64_r5.config @@ -0,0 +1,19 @@ +# Defconfig fragment to apply on top of: +# j721e_evm_r5_defconfig + +CONFIG_DEFAULT_DEVICE_TREE="k3-j721e-r5-beagleboneai64" +CONFIG_SPL_OF_LIST="k3-j721e-r5-beagleboneai64" + +# No ESM, PMIC or AVS adjustment till PMIC is enabled +CONFIG_ESM_K3=n +CONFIG_K3_AVS0=n +CONFIG_ESM_PMIC=n + +# Do not use emmc boot - we will use FS only +CONFIG_SUPPORT_EMMC_BOOT=n + +CONFIG_HBMC_AM654=n +# No dependency on EEPROM detection +CONFIG_TI_I2C_BOARD_DETECT=n +# No board fixup to do +CONFIG_OF_BOARD_SETUP=n
Beagle boards are not TI boards, add the board support to board/beagle/
Andrew
- led led-2 off; led led-3 on; led led-4 off
- led led-2 on; led led-3 off; led led-4 on
Huh, why bring in commercials and organization changes here? am335x and am62 are under the TI umbrella.
$ git grep beagle board/|cut -d ':' -f1|sort -u board/ti/am335x/board.c board/ti/am335x/board.h board/ti/am57xx/board.c board/ti/am62x/beagleplay_a53.config board/ti/am62x/beagleplay_r5.config board/ti/am62x/MAINTAINERS board/ti/beagle/beagle.c board/ti/beagle/Kconfig board/ti/beagle/led.c board/ti/beagle/MAINTAINERS board/ti/beagle/Makefile board/ti/j721e/beagleboneai64_a72.config board/ti/j721e/beagleboneai64_r5.config board/ti/j721e/MAINTAINERS board/timll/devkit8000/README
The SoCs used are yes, the boards are not, we only make our EVM/SK line of boards in house.
We did AM335x wrong, in board/ti/am335x/board.c we tried to support like 11 different boards in one file. And while it might have made adding our own extra EVMs easier, it only made things less clear for folks trying to add their own AM335x based boards[0].
We don't integrate support for any other board partner like this. Our friends over at Toradex or Phytec are currently upstreaming boards based on K3 SoCs and in doing so have shown us some areas we can improve.
We focus on these little short-cuts to make adding our EVMs (or boards that look like our EVMs) easy. But that only leads to extra work and code duplication for external boards.
If something is actually common to the SoC then lets move it to arch/arm/mach-k3/j721e. Tricks like board-variants.c only hide the issue and doesn't help folks wanting to add their boards based on our SoCs to their board/<vendor>/ directory.
Andrew
[0] See "Software Design" https://jaycarlson.net/embedded-linux/#am335x
Hello Andrew, All,
I'm starting a new custom board bring-up based on a j721e SoC (without any SOM) and adding a now board variant from the u-boot provided in the TI SDK (based on 2023.04) is far from easy for the reasons mentioned above (extra work and code duplication for external boards).
Also the build break for j7200/j721e SoC as soon as CONFIG_TARGET_J721E_A72_EVM and CONFIG_TARGET_J7200_A72_EVM are undefined:
https://source.denx.de/u-boot/u-boot/-/blob/v2023.10/arch/arm/mach-k3/arm64-...
I always wonder if I should work on top of EVMs board or create a new board/<vendor>/ directory for customer boards.
Best regards, Romain
Andrew
On 11/17/23 8:27 AM, Romain Naour wrote:
Hello Andrew, All,
The issue is we didn't properly split J7200 support from J721e and now that there are differences between the two, the only way we have to check which is which is to check the TARGET board, not the SOC (as there is no SOC_K3_J7200, but we are working on that [0]). So currently adding new J721E/J7200 TARGET boards breaks things :(
New board/<vendor>/ would be preferred, we do things in our EVM board/ti/ dir that are specific to our EVMs, and there will be more churn, etc..
If adding a new board/<vendor>/ for our SoCs is difficult just let us know, we are working several issues to make it more easy going forward and guiding feedback always helps.
Andrew
[0] https://lore.kernel.org/all/20231106165044.xrmlxoyfbnkmpb5v@revolt/
Andrew
Hello Andrew, All,
Hello Andrew, All,
Ok, I understand.
Ok, maybe I'll work on top of the EVM board support for the first try and create a new board/<vendor>/ while cleaning for the final release.
Thanks, for now I only have the SK-TDA4VM board and I'll receive the customer board in several weeks.
For now the main difficulty is to remove CONFIG_TARGET_J721E_{R6,A72}_EVM from the u-boot config file without breaking stuff.
Also I'm wondering if yaml files in board/ti/j721e/*-cfg.yaml are generic enough to avoid to copy them to board/<vendor>/. (I'm not yet familiar with binman tool).
Andrew
Andrew
So, yeah, we've been bad about this historically for a few kinds of reasons, but it makes more sense now to have board/beagle/{x,y,z} than it does to have board/ti/... for these platforms.
OK. I will respin.
Add base documentation for BeagleBone AI-64.
Signed-off-by: Nishanth Menon nm@ti.com --- doc/board/ti/j721e_beagleboneai64.rst | 327 ++++++++++++++++++++++++++ doc/board/ti/k3.rst | 1 + 2 files changed, 328 insertions(+) create mode 100644 doc/board/ti/j721e_beagleboneai64.rst
diff --git a/doc/board/ti/j721e_beagleboneai64.rst b/doc/board/ti/j721e_beagleboneai64.rst new file mode 100644 index 000000000000..18e154bd417a --- /dev/null +++ b/doc/board/ti/j721e_beagleboneai64.rst @@ -0,0 +1,327 @@ +.. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +.. sectionauthor:: Nishanth Menon nm@ti.com + +J721E/TDA4VM Beagleboard.org BeagleBone AI-64 +============================================= + +Introduction: +------------- + +BeagleBoard.org BeagleBone AI-64 is an open source hardware single +board computer based on the Texas Instruments TDA4VM SoC featuring +dual-core 2.0GHz Arm Cortex-A72 processor, C7x+MMA and 2 C66x +floating-point VLIW DSPs, 3x dual ARM Cortex-R5 co-processors, +2x 6-core Programmable Real-Time Unit and Industrial Communication +SubSystem, PowerVR Rogue 8XE GE8430 3D GPU. The board features 4GB +DDR4, USB3.0 Type-C, 2x USB SS Type-A, miniDisplayPort, 2x 4-lane +CSI, DSI, 16GB eMMC flash, 1G Ethernet, M.2 E-key for WiFi/BT, and +BeagleBone expansion headers. + +Further information can be found at: + +* Product Page: https://beagleboard.org/ai-64 +* Hardware documentation: https://git.beagleboard.org/beagleboard/beaglebone-ai-64 + +Boot Flow: +---------- +Below is the pictorial representation of boot flow: + +.. image:: img/boot_diagram_j721e.svg + :alt: Boot flow diagram + +- On this platform, DMSC runs 'TI Foundational Security' (TIFS) which + functions as the security enclave master. The 'Device Manager' (DM), + also known as the 'TISCI server' in "TI terminology", running on boot + R5F, offers all the essential services required for device management. + The A72, C7x, C6x or R5F (Aux cores) sends requests to TIFS/DM to + accomplish the needed services, as illustrated in the diagram above. + +Sources: +-------- +.. include:: k3.rst + :start-after: .. k3_rst_include_start_boot_sources + :end-before: .. k3_rst_include_end_boot_sources + +Build procedure: +---------------- +0. Setup the environment variables: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_desc + :end-before: .. k3_rst_include_end_common_env_vars_desc + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_board_env_vars_desc + :end-before: .. k3_rst_include_end_board_env_vars_desc + +Set the variables corresponding to this platform: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_defn + :end-before: .. k3_rst_include_end_common_env_vars_defn +.. prompt:: bash $ + + export UBOOT_CFG_CORTEXR="j721e_evm_r5_defconfig beagleboneai64_r5.config" + export UBOOT_CFG_CORTEXA="j721e_evm_a72_defconfig beagleboneai64_a72.config" + export TFA_BOARD=generic + # we dont use any extra TFA parameters + unset TFA_EXTRA_ARGS + export OPTEE_PLATFORM=k3-j721e + # we dont use any extra OP-TEE parameters + unset OPTEE_EXTRA_ARGS + +.. include:: j721e_evm.rst + :start-after: .. j721e_evm_rst_include_start_build_steps + :end-before: .. j721e_evm_rst_include_end_build_steps + +Target Images +-------------- +Copy the below images to an SD card and boot: + +* tiboot3-j721e-gp-evm.bin from R5 build as tiboot3.bin +* tispl.bin_unsigned from Cortex-A build as tispl.bin +* u-boot.img_unsigned from Cortex-A build as u-boot.img + +Image formats +------------- + +- tiboot3.bin + +.. image:: img/no_multi_cert_tiboot3.bin.svg + :alt: tiboot3.bin image format + +- tispl.bin + +.. image:: img/dm_tispl.bin.svg + :alt: tispl.bin image format + +- sysfw.itb + +.. image:: img/sysfw.itb.svg + :alt: sysfw.itb image format + +Additional hardware for U-Boot development +------------------------------------------ + +* Serial Console is critical for U-Boot development on BeagleBone AI-64. See + `BeagleBone AI-64 connector documentation + https://docs.beagleboard.org/latest/boards/beaglebone/ai-64/ch07.html`_. +* uSD is preferred option over eMMC, and a SD/MMC reader will be needed. +* (optionally) JTAG is useful when working with very early stages of boot. + +Default storage options +----------------------- + +There are multiple storage media options on BeagleBone AI-64, but primarily: + +* Onboard eMMC (default) - reliable, fast and meant for deployment use. +* SD/MMC card interface (hold 'BOOT' switch and power on) - Entirely + depends on the SD card quality. + +Flash to uSD card or how to deal with "bricked" Board +-------------------------------------------------------- + +When deploying or working on Linux, it's common to use the onboard +eMMC. However, avoiding the eMMC and using the uSD card is safer when +working with U-Boot. + +If you choose to hand format your own bootable uSD card, be +aware that it can be difficult. The following information +may be helpful, but remember that it is only sometimes +reliable, and partition options can cause issues. These +can potentially help: + +* https://git.ti.com/cgit/arago-project/tisdk-setup-scripts/tree/create-sdcard... +* https://elinux.org/Beagleboard:Expanding_File_System_Partition_On_A_microSD + +The simplest option is to start with a standard distribution +image like those in `BeagleBoard.org Distros Page +https://www.beagleboard.org/distros`_ and download a disk image for +BeagleBone AI-64. Pick a 16GB+ uSD card to be on the safer side. + +With an SD/MMC Card reader and `Balena Etcher +https://etcher.balena.io/`_, having a functional setup in minutes is +a trivial matter, and it works on almost all Host Operating Systems. +Yes Windows users, Windows Subsystem for Linux(WSL) based development +with U-Boot and update uSD card is practical. + +Updating U-Boot is a matter of copying the tiboot3.bin, tispl.bin and +u-boot.img to the "BOOT" partition of the uSD card. Remember to sync +and unmount (or Eject - depending on the Operating System) the uSD +card prior to physically removing from SD card reader. + +Also see following section on switch setting used for booting using +uSD card. + +.. note:: + Great news! If the board has not been damaged physically, there's no + need to worry about it being "bricked" on this platform. You only have + to flash an uSD card, plug it in, and reinstall the image on eMMC. This + means that even if you make a mistake, you can quickly fix it and rest + easy. + + If you are frequently working with uSD cards, you might find the + following useful: + + * `USB-SD-Mux https://www.linux-automation.com/en/products/usb-sd-mux.html`_ + * `SD-Wire https://wiki.tizen.org/SDWire`_ + +Flash to eMMC +------------- + +The eMMC layout selected is user-friendly for developers. The +boot hardware partition of the eMMC only contains the fixed-size +tiboot3.bin image. This is because the contents of the boot partitions +need to run from the SoC's internal SRAM, which remains a fixed size +constant. The other components of the boot sequence, such as tispl.bin +and u-boot.img, are located in the /BOOT partition in the User Defined +Area (UDA) hardware partition of the eMMC. These components can vary +significantly in size. The choice of keeping tiboot3.bin in boot0 or +boot1 partition depends on A/B update requirements. + +.. image:: img/beagleplay_emmc.svg + :alt: eMMC partitions and boot file organization for BeagleBone AI-64 + +The following are the steps from Linux shell to program eMMC: + +.. prompt:: bash # + + # Enable Boot0 boot + mmc bootpart enable 1 2 /dev/mmcblk0 + mmc bootbus set single_backward x1 x8 /dev/mmcblk0 + mmc hwreset enable /dev/mmcblk0 + + # Clear eMMC boot0 + echo '0' >> /sys/class/block/mmcblk0boot0/force_ro + dd if=/dev/zero of=/dev/mmcblk0boot0 count=32 bs=128k + # Write tiboot3.bin + dd if=tiboot3.bin of=/dev/mmcblk0boot0 bs=128k + + # Copy the rest of the boot binaries + mount /dev/mmcblk0p1 /boot/firmware + cp tispl.bin /boot/firmware + cp u-boot.img /boot/firmware + sync + +.. warning :: + + U-Boot is configured to prioritize booting from an SD card if it + detects a valid boot partition and boot files on it, even if the + system initially booted from eMMC. The boot order is set as follows: + + * SD/MMC + * eMMC + * USB + * PXE + +LED patterns during boot +------------------------ + +.. list-table:: USR LED status indication + :widths: 16 16 + :header-rows: 1 + + * - USR LEDs (012345) + - Indicates + + * - 00000 + - Boot failure or R5 image not started up + + * - 11111 + - A53 SPL/U-boot has started up + + * - 10101 + - OS boot process has been initiated + + * - 01010 + - OS boot process failed and drops to U-Boot shell + +.. note :: + + In the table above, 0 indicates LED switched off and 1 indicates LED + switched ON. + +.. warning :: + + The green LED very next to the serial connector labelled "WKUP UART0" + is the power LED (LED6). This is the same color as the rest of the USR + LEDs. If the "green" LED6 power LED is not glowing, the system power + supply is not functional. Please refer to `BeagleBone AI-64 documentation + https://beagleboard.org/ai-64/`_ for further information. + +Switch Setting for Boot Mode +---------------------------- + +The boot time option is configured via "BOOT" button on the board. +See `BeagleBone AI-64 Schematics https://git.beagleboard.org/beagleboard/beaglebone-ai-64/-/blob/main/BeagleBone_AI-64_SCH.pdf`_ +for details. + +.. list-table:: Boot Modes + :widths: 16 16 16 + :header-rows: 1 + + * - BOOT Switch Position + - Primary Boot + - Secondary Boot + + * - Not Pressed + - eMMC + - SD Card + + * - Pressed + - SD Card + - SD Card + +To switch to SD card boot mode, hold the BOOT button while powering on +with Type-C power supply, then release when power LED lights up. + +Debugging U-Boot +---------------- + +See :ref:`Common Debugging environment - OpenOCD<k3_rst_refer_openocd>`: for +detailed setup and debugging information. + +.. warning:: + + **OpenOCD support since**: v0.12.0 + + If the default package version of OpenOCD in your development + environment's distribution needs to be updated, it might be necessary to + build OpenOCD from the source. + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_connect_tag_connect + :end-before: .. k3_rst_include_end_openocd_connect_tag_connect + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_cfg_external_intro + :end-before: .. k3_rst_include_end_openocd_cfg_external_intro + +For example, with BeagleBone AI-64 (J721e platform), the openocd_connect.cfg: + +.. code-block:: tcl + + # TUMPA example: + # http://www.tiaowiki.com/w/TIAO_USB_Multi_Protocol_Adapter_User%27s_Manual + source [find interface/ftdi/tumpa.cfg] + + transport select jtag + + # default JTAG configuration has only SRST and no TRST + reset_config srst_only srst_push_pull + + # delay after SRST goes inactive + adapter srst delay 20 + + if { ![info exists SOC] } { + # Set the SoC of interest + set SOC j721e + } + + source [find target/ti_k3.cfg] + + ftdi tdo_sample_edge falling + + # Speeds for FT2232H are in multiples of 2, and 32MHz is tops + # max speed we seem to achieve is ~20MHz.. so we pick 16MHz + adapter speed 16000 diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 89d70db88647..52a5d4a095f2 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -36,6 +36,7 @@ K3 Based SoCs am64x_evm am65x_evm j7200_evm + j721e_beagleboneai64 j721e_evm j721s2_evm
On Thu, Nov 02, 2023 at 07:37:50PM -0500, Nishanth Menon wrote:
Cleanups for J721e/J7200 and add support for BeagleBone AI-64
Based off: master 07fe79c93c5c Merge tag 'i2cfixes-for-v2024-01-rc2' of https://source.denx.de/u-boot/custodians/u-boot-i2c
Boot Logs: J721e-SK: https://gist.github.com/nmenon/c144e64f1da9fd49997ef5794b056bb0 J721e-EVM: https://gist.github.com/nmenon/e79bed6807da05c723e71687fb3c0b90 J7200-HSEVM: https://gist.github.com/nmenon/5658dd6fa2f67bce915c77b25c02f897
BeagleBone AI-64: SD/MMC boot: https://gist.github.com/nmenon/1e07858fb8ca39ca87e40d3894e4d9b7 eMMC boot: https://gist.github.com/nmenon/9b0602df1f1be2c6b512d135b0afae60 eMMC boot with SDcard detected: https://gist.github.com/nmenon/82058014f4b2f6b9ed21431bc675e12a
U-Boot CI: https://github.com/u-boot/u-boot/pull/444
Looking at the end result of the code, the split of evm.c looks good. One small thing is dropping common.h from the board files.
participants (6)
Andrew Davis
Kumar, Udit
Manorit Chawdhry
Nishanth Menon
Romain Naour
