[U-Boot] [PATCH 1/3][v5] mtd: move & update nand_ecclayout structure
nand_ecclayout is present in mtd.h at Linux. Move this structure to mtd.h to comply with Linux.
Also, increase the ecc placement locations to 640 to suport device having writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone up to 640 bytes and consequently the maximum ecc placement locations have also gone up to 640.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com CC: Vipin Kumar vipin.kumar@st.com --- Changes for v2: Incorporated Scott's comments - move nand_ecclayout to mtd.h - updated OOBFREE, ECCPOS max entries
Changes for v3: Sending as it is Changes for v4: Sending as it is Changes for v5: Sending as it is
include/linux/mtd/mtd.h | 14 ++++++++++++++ include/mtd/mtd-abi.h | 12 ------------ 2 files changed, 14 insertions(+), 12 deletions(-)
diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 6f44abd..3a18f8f 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -96,6 +96,20 @@ struct mtd_oob_ops { uint8_t *oobbuf; };
+#define MTD_MAX_OOBFREE_ENTRIES 32 +#define MTD_MAX_ECCPOS_ENTRIES 640 + +/* + * ECC layout control structure. Exported to userspace for + * diagnosis and to allow creation of raw images + */ +struct nand_ecclayout { + uint32_t eccbytes; + uint32_t eccpos[MTD_MAX_ECCPOS_ENTRIES]; + uint32_t oobavail; + struct nand_oobfree oobfree[MTD_MAX_OOBFREE_ENTRIES]; +}; + struct mtd_info { u_char type; u_int32_t flags; diff --git a/include/mtd/mtd-abi.h b/include/mtd/mtd-abi.h index d51c1ab..ac3c298 100644 --- a/include/mtd/mtd-abi.h +++ b/include/mtd/mtd-abi.h @@ -155,18 +155,6 @@ struct nand_oobfree { uint32_t length; };
-#define MTD_MAX_OOBFREE_ENTRIES 8 -/* - * ECC layout control structure. Exported to userspace for - * diagnosis and to allow creation of raw images - */ -struct nand_ecclayout { - uint32_t eccbytes; - uint32_t eccpos[128]; - uint32_t oobavail; - struct nand_oobfree oobfree[MTD_MAX_OOBFREE_ENTRIES]; -}; - /** * struct mtd_ecc_stats - error correction stats *
This breaks the tricorder build due to the expanded eccpos violating SPL size constraints:
Configuring for tricorder board... make[1]: *** [/tmp/u-boot-arm/spl/u-boot-spl] Error 1 make: *** [/tmp/u-boot-arm/spl/u-boot-spl.bin] Error 2 text data bss dec hex filename 352879 27592 217888 598359 92157 /tmp/u-boot-arm/u-boot armv7a-ld.bfd: u-boot-spl section `.data' will not fit in region `.sram' armv7a-ld.bfd: region `.sram' overflowed by 140 bytes make[1]: *** [/tmp/u-boot-arm/spl/u-boot-spl] Error 1 make: *** [/tmp/u-boot-arm/spl/u-boot-spl.bin] Error 2 make: *** Waiting for unfinished jobs....
-Scott
Prabhakar Kushwaha
Scott Wood
