[U-Boot] [UBOOT PATCH] env: Added support to save env to spi through Kconfig
This patch added support to enable CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET and CONFIG_ENV_SECT_SIZE through Kconfig for Zynq and Zynqmp.
Signed-off-by: Vipul Kumar vipul.kumar@xilinx.com --- env/Kconfig | 27 +++++++++++++++++++++++++++ include/configs/xilinx_zynqmp.h | 3 --- include/configs/zynq-common.h | 13 ------------- 3 files changed, 27 insertions(+), 16 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 8618376..640a43f 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -480,6 +480,33 @@ config ENV_SIZE
endif
+if ARCH_ZYNQMP || ARCH_ZYNQ + +config ENV_OFFSET + hex "Environment Offset" + depends on !ENV_IS_NOWHERE + default 0x1E00000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP + default 0xE0000 if ARCH_ZYNQ + help + Offset from the start of the device (or partition) + +config ENV_SIZE + hex "Environment Size" + default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP + default 0x8000 if !ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP + default 0x20000 if ARCH_ZYNQ + help + Size of the environment storage area. + +config ENV_SECT_SIZE + hex "Environment Sector-Size" + default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP + default 0x20000 if !ENV_IS_NOWHERE && ARCH_ZYNQ + help + Size of the sector containing the environment. + +endif + config USE_DEFAULT_ENV_FILE bool "Create default environment from file" help diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index e9086f9..7add9ea 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -102,9 +102,6 @@ # define PARTS_DEFAULT #endif
-/* Do not preserve environment */ -#define CONFIG_ENV_SIZE 0x8000 - /* Monitor Command Prompt */ /* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 2048 diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 55b983f..16426a7 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -125,22 +125,9 @@ # define CONFIG_SYS_EEPROM_SIZE 1024 /* Bytes */ #endif
-/* Total Size of Environment Sector */ -#ifndef CONFIG_ENV_SIZE -# define CONFIG_ENV_SIZE (128 << 10) -#endif - /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
-/* Environment */ -#ifndef CONFIG_ENV_IS_NOWHERE -# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -# ifndef CONFIG_ENV_OFFSET -# define CONFIG_ENV_OFFSET 0xE0000 -# endif -#endif - /* enable preboot to be loaded before CONFIG_BOOTDELAY */ #define CONFIG_PREBOOT
-- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
endif
+config ENV_OFFSET
- hex "Environment Offset"
- depends on !ENV_IS_NOWHERE
- default 0x1E00000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP
- default 0xE0000 if ARCH_ZYNQ
- help
+config ENV_SIZE
- hex "Environment Size"
- default 0x40000 if ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP
- default 0x8000 if !ENV_IS_IN_SPI_FLASH && ARCH_ZYNQMP
Isn't it enough just? default 0x8000 if ARCH_ZYNQMP
- default 0x20000 if ARCH_ZYNQ
- help
- hex "Environment Sector-Size"
- default 0x20000 if !ENV_IS_NOWHERE && ARCH_ZYNQ
There should be default value .config:633:warning: symbol value '' invalid for ENV_SECT_SIZE
Please check if this macro is used for that ENV_IS options.
Maybe simple default 0x40000 if ARCH_ZYNQMP default 0x20000 if ARCH_ZYNQ should be enough.
- help
+endif
Thanks, Michal
Michal Simek
Vipul Kumar
