[PATCH v3 00/19] vbe: Series part E
This includes various patches towards implementing the VBE abrec bootmeth in U-Boot. It mostly focuses on SPL tweaks and adjusting what fatures are available in VPL.
Changes in v3: - Add new patch to avoid size growth in spl_mmc_find_device() debug - Use strlcpy() instead of strncpy() - Rebase to master
Changes in v2: - Add field names into the message - Fix 'depends on SPL' to depend on TPL - Depend on TPL/VPL as well - Drop patch 'serial: ns16550: Allow clocks to be missing'
Simon Glass (19): spl: mmc: Avoid size growth in spl_mmc_find_device() debug image: Add a prototype for fit_image_get_phase() boot: Allow FIT to fall back from best-match option bootstd: Avoid sprintf() in SPL when creating bootdevs boot: Respect the load_op in fit_image_load() malloc: Show amount of used space when memory runs out malloc: Provide a simple malloc for VPL Support setting a maximum size for the VPL image spl: Report a loader failure spl: Allow serial to be disabled in any XPL phase spl: Support a relocated stack in any XPL phase spl: Drop use of uintptr_t spl: Drop a duplicate variable in boot_from_devices() spl: Add some more debugging to load_simple_fit() spl: lib: Allow for decompression in any SPL build boot: Allow use of FIT in TPL and VPL lib: Allow crc8 in TPL and VPL boot: Imply CRC8 with VBE hash: Plumb crc8 into the hash functions
boot/Kconfig | 71 ++++++++++++++++++++++++++++++++++- boot/bootdev-uclass.c | 10 ++++- boot/image-fit.c | 29 ++++++++------ common/hash.c | 8 ++++ common/malloc_simple.c | 3 +- common/spl/Kconfig.vpl | 17 +++++++++ common/spl/spl.c | 15 +++++--- common/spl/spl_atf.c | 36 +++++++++--------- common/spl/spl_fit.c | 12 +++++- common/spl/spl_legacy.c | 8 ++-- common/spl/spl_mmc.c | 6 ++- configs/sandbox_vpl_defconfig | 2 + include/image.h | 16 +++++++- include/spl.h | 28 +++++++------- include/u-boot/crc.h | 3 ++ lib/Kconfig | 53 ++++++++++++++++++++++++++ lib/Makefile | 12 +++--- lib/crc8.c | 6 +++ 18 files changed, 267 insertions(+), 68 deletions(-)
The for() loop ends up being in the code even if the log_debug() does nothing. Add a condition to fix this.
common/spl/spl_mmc.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 1f696593216..fe4230170a0 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -81,8 +81,10 @@ static int spl_mmc_find_device(struct mmc **mmcp, int mmc_dev) struct uclass *uc;
log_debug("Selecting MMC dev %d; seqs:\n", mmc_dev); - uclass_id_foreach_dev(UCLASS_MMC, dev, uc) - log_debug("%d: %s\n", dev_seq(dev), dev->name); + if (_LOG_DEBUG) { + uclass_id_foreach_dev(UCLASS_MMC, dev, uc) + log_debug("%d: %s\n", dev_seq(dev), dev->name); + } ret = mmc_init_device(mmc_dev); #else ret = mmc_initialize(NULL);
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, December 8, 2024 2:24 AM The for() loop ends up being in the code even if the log_debug() does nothing. Add a condition to fix this.
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes in v3:
- if (_LOG_DEBUG) {
- } ret = mmc_init_device(mmc_dev);
#else ret = mmc_initialize(NULL); -- 2.34.1
This function exists but is not exported. Add a prototype so it can be used elsewhere.
(no changes since v1)
include/image.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/image.h b/include/image.h index 9be5acd8158..bb15ef69871 100644 --- a/include/image.h +++ b/include/image.h @@ -1171,6 +1171,18 @@ int fit_image_get_data_size_unciphered(const void *fit, int noffset, int fit_image_get_data_and_size(const void *fit, int noffset, const void **data, size_t *size);
+/** + * fit_image_get_phase() - Get the phase from a FIT image + * + * @fit: FIT to read from + * @offset: offset node to read + * @phasep: Returns phase, if any + * Return: 0 if read OK and *phasep is value, -ENOENT if there was no phase + * property in the node, other -ve value on other error + */ +int fit_image_get_phase(const void *fit, int offset, + enum image_phase_t *phasep); + /** * fit_get_data_node() - Get verified image data for an image * @fit: Pointer to the FIT format image header
When the best-match feature fails to find something, use the provided config name as a fallback. The allows SPL to select a suitable config when best-match is enabled.
boot/image-fit.c | 19 ++++++++++--------- include/image.h | 4 +++- 2 files changed, 13 insertions(+), 10 deletions(-)
diff --git a/boot/image-fit.c b/boot/image-fit.c index 7d56f0b5e6e..439ff51edf6 100644 --- a/boot/image-fit.c +++ b/boot/image-fit.c @@ -1729,13 +1729,13 @@ int fit_conf_find_compat(const void *fit, const void *fdt) images_noffset = fdt_path_offset(fit, FIT_IMAGES_PATH); if (confs_noffset < 0 || images_noffset < 0) { debug("Can't find configurations or images nodes.\n"); - return -1; + return -EINVAL; }
fdt_compat = fdt_getprop(fdt, 0, "compatible", &fdt_compat_len); if (!fdt_compat) { debug("Fdt for comparison has no "compatible" property.\n"); - return -1; + return -ENXIO; }
/* @@ -1812,7 +1812,7 @@ int fit_conf_find_compat(const void *fit, const void *fdt) } if (!best_match_offset) { debug("No match found.\n"); - return -1; + return -ENOENT; }
return best_match_offset; @@ -2095,17 +2095,18 @@ int fit_image_load(struct bootm_headers *images, ulong addr, * fit_conf_get_node() will try to find default config node */ bootstage_mark(bootstage_id + BOOTSTAGE_SUB_NO_UNIT_NAME); - if (IS_ENABLED(CONFIG_FIT_BEST_MATCH) && !fit_uname_config) { - cfg_noffset = fit_conf_find_compat(fit, gd_fdt_blob()); - } else { - cfg_noffset = fit_conf_get_node(fit, fit_uname_config); - } - if (cfg_noffset < 0) { + ret = -ENXIO; + if (IS_ENABLED(CONFIG_FIT_BEST_MATCH) && !fit_uname_config) + ret = fit_conf_find_compat(fit, gd_fdt_blob()); + if (ret < 0 && ret != -EINVAL) + ret = fit_conf_get_node(fit, fit_uname_config); + if (ret < 0) { puts("Could not find configuration node\n"); bootstage_error(bootstage_id + BOOTSTAGE_SUB_NO_UNIT_NAME); return -ENOENT; } + cfg_noffset = ret;
fit_base_uname_config = fdt_get_name(fit, cfg_noffset, NULL); printf(" Using '%s' configuration\n", fit_base_uname_config); diff --git a/include/image.h b/include/image.h index bb15ef69871..ab96510f62c 100644 --- a/include/image.h +++ b/include/image.h @@ -1411,7 +1411,9 @@ int fit_check_format(const void *fit, ulong size); * copied into the configuration node in the FIT image. This is required to * match configurations with compressed FDTs. * - * Returns: offset to the configuration to use if one was found, -1 otherwise + * Returns: offset to the configuration to use if one was found, -EINVAL if + * there a /configurations or /images node is missing, -ENOENT if no match was + * found, -ENXIO if the FDT node has no compatible string */ int fit_conf_find_compat(const void *fit, const void *fdt);
The name of the bootdev device is not that important, particular in SPL. Save a little code space by using a simpler name.
Changes in v3: - Use strlcpy() instead of strncpy()
boot/bootdev-uclass.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/boot/bootdev-uclass.c b/boot/bootdev-uclass.c index 65a3b89e40c..c39147940b6 100644 --- a/boot/bootdev-uclass.c +++ b/boot/bootdev-uclass.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <part.h> #include <sort.h> +#include <spl.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/uclass-internal.h> @@ -261,8 +262,13 @@ int bootdev_setup_for_sibling_blk(struct udevice *blk, const char *drv_name) int ret, len;
len = bootdev_get_suffix_start(blk, ".blk"); - snprintf(dev_name, sizeof(dev_name), "%.*s.%s", len, blk->name, - "bootdev"); + if (xpl_phase() < PHASE_BOARD_R) { + strlcpy(dev_name, blk->name, sizeof(dev_name) - 5); + strcat(dev_name, ".sib"); + } else { + snprintf(dev_name, sizeof(dev_name), "%.*s.%s", len, blk->name, + "bootdev"); + }
parent = dev_get_parent(blk); ret = device_find_child_by_name(parent, dev_name, &dev);
Some code has crept in which ignores this parameter. Fix this and add a little debugging.
boot/image-fit.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/boot/image-fit.c b/boot/image-fit.c index 439ff51edf6..db7fb61bca9 100644 --- a/boot/image-fit.c +++ b/boot/image-fit.c @@ -2226,6 +2226,7 @@ int fit_image_load(struct bootm_headers *images, ulong addr, data = map_to_sysmem(buf); load = data; if (load_op == FIT_LOAD_IGNORED) { + log_debug("load_op: not loading\n"); /* Don't load */ } else if (fit_image_get_load(fit, noffset, &load)) { if (load_op == FIT_LOAD_REQUIRED) { @@ -2262,10 +2263,13 @@ int fit_image_load(struct bootm_headers *images, ulong addr, /* Kernel images get decompressed later in bootm_load_os(). */ if (!fit_image_get_comp(fit, noffset, &comp) && comp != IH_COMP_NONE && + load_op != FIT_LOAD_IGNORED && !(image_type == IH_TYPE_KERNEL || image_type == IH_TYPE_KERNEL_NOLOAD || image_type == IH_TYPE_RAMDISK)) { ulong max_decomp_len = len * 20; + + log_debug("decompressing image\n"); if (load == data) { loadbuf = malloc(max_decomp_len); load = map_to_sysmem(loadbuf); @@ -2280,6 +2284,7 @@ int fit_image_load(struct bootm_headers *images, ulong addr, } len = load_end - load; } else if (load != data) { + log_debug("copying\n"); loadbuf = map_sysmem(load, len); memcpy(loadbuf, buf, len); } @@ -2289,8 +2294,9 @@ int fit_image_load(struct bootm_headers *images, ulong addr, " please fix your .its file!\n");
/* verify that image data is a proper FDT blob */ - if (image_type == IH_TYPE_FLATDT && fdt_check_header(loadbuf)) { - puts("Subimage data is not a FDT"); + if (load_op != FIT_LOAD_IGNORED && image_type == IH_TYPE_FLATDT && + fdt_check_header(loadbuf)) { + puts("Subimage data is not a FDT\n"); return -ENOEXEC; }
Show a bit more information when malloc() space is exhausted and debugging is enabled.
(no changes since v2)
common/malloc_simple.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/malloc_simple.c b/common/malloc_simple.c index 5a8ec538f8f..f0f90a095bd 100644 --- a/common/malloc_simple.c +++ b/common/malloc_simple.c @@ -26,7 +26,8 @@ static void *alloc_simple(size_t bytes, int align) log_debug("size=%lx, ptr=%lx, limit=%x: ", (ulong)bytes, new_ptr, gd->malloc_limit); if (new_ptr > gd->malloc_limit) { - log_err("alloc space exhausted\n"); + log_err("alloc space exhausted ptr %lx limit %x\n", new_ptr, + gd->malloc_limit); return NULL; }
The VPL phase may want to use the smaller malloc() implementation, so add an option for this.
common/spl/Kconfig.vpl | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/common/spl/Kconfig.vpl b/common/spl/Kconfig.vpl index d06f36d4ee4..3dc0e95e09f 100644 --- a/common/spl/Kconfig.vpl +++ b/common/spl/Kconfig.vpl @@ -222,6 +222,15 @@ config VPL_SPI_FLASH_SUPPORT lines). This enables the drivers in drivers/mtd/spi as part of a VPL build. This normally requires VPL_SPI_SUPPORT.
+config VPL_SYS_MALLOC_SIMPLE + bool "Only use malloc_simple functions in the VPL" + default y + help + Say Y here to only use the *_simple malloc functions from + malloc_simple.c, rather then using the versions from dlmalloc.c; + this will make the VPL binary smaller at the cost of more heap + usage as the *_simple malloc functions do not re-use free-ed mem. + config VPL_TEXT_BASE hex "VPL Text Base" default 0x0
Add a size limit for VPL, to match those for SPL and TPL
common/spl/Kconfig.vpl | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/common/spl/Kconfig.vpl b/common/spl/Kconfig.vpl index 3dc0e95e09f..eb57dfabea5 100644 --- a/common/spl/Kconfig.vpl +++ b/common/spl/Kconfig.vpl @@ -237,6 +237,14 @@ config VPL_TEXT_BASE help The address in memory that VPL will be running from.
+config VPL_MAX_SIZE + hex "Maximum size (in bytes) for the VPL stage" + default 0x2e000 if ROCKCHIP_RK3399 + default 0x0 + help + The maximum size (in bytes) of the TPL stage. This size is determined + by the amount of internal SRAM memory. + config VPL_BINMAN_SYMBOLS bool "Declare binman symbols in VPL" depends on VPL_FRAMEWORK && BINMAN
If a loader returns an error code it is silently ignored. Show a message to at least provide some feedback to the user.
common/spl/spl.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 1ceb63daf31..7c57eb8539b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -612,6 +612,7 @@ static int boot_from_devices(struct spl_image_info *spl_image, for (i = 0; i < count && spl_boot_list[i] != BOOT_DEVICE_NONE; i++) { struct spl_image_loader *loader; int bootdev = spl_boot_list[i]; + int ret;
if (CONFIG_IS_ENABLED(SHOW_ERRORS)) ret = -ENXIO; @@ -631,10 +632,13 @@ static int boot_from_devices(struct spl_image_info *spl_image, "Unsupported Boot Device!\n"); } } - if (loader && - !spl_load_image(spl_image, loader)) { - spl_image->boot_device = bootdev; - return 0; + if (loader) { + ret = spl_load_image(spl_image, loader); + if (!ret) { + spl_image->boot_device = bootdev; + return 0; + } + printf("Error: %d\n", ret); } } }
The current check looks only at SPL, but TPL or VPL might have a different setting. Update the condition.
common/spl/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 7c57eb8539b..91ee07f7079 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -837,7 +837,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) */ void preloader_console_init(void) { -#ifdef CONFIG_SPL_SERIAL +#if CONFIG_IS_ENABLED(SERIAL) gd->baudrate = CONFIG_BAUDRATE;
serial_init(); /* serial communications setup */
diff --git a/common/spl/spl.c b/common/spl/spl.c index 91ee07f7079..702920bd2f7 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -896,7 +896,7 @@ __weak void spl_relocate_stack_check(void) */ ulong spl_relocate_stack_gd(void) { -#ifdef CONFIG_SPL_STACK_R +#if CONFIG_IS_ENABLED(STACK_R) gd_t *new_gd; ulong ptr = CONFIG_SPL_STACK_R_ADDR;
U-Boot uses ulong for addresses. It is confusing to use uintptr_t in a few places, since it makes people wonder if the types are compatible. Change the few occurences in SPL to use ulong
common/spl/spl_atf.c | 36 ++++++++++++++++++------------------ common/spl/spl_fit.c | 2 +- common/spl/spl_legacy.c | 8 ++++---- include/spl.h | 28 ++++++++++++++-------------- 4 files changed, 37 insertions(+), 37 deletions(-)
diff --git a/common/spl/spl_atf.c b/common/spl/spl_atf.c index 0397b86a33b..8bc5db77395 100644 --- a/common/spl/spl_atf.c +++ b/common/spl/spl_atf.c @@ -41,9 +41,9 @@ struct bl2_to_bl31_params_mem_v2 { struct entry_point_info bl31_ep_info; };
-struct bl31_params *bl2_plat_get_bl31_params_default(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr) +struct bl31_params *bl2_plat_get_bl31_params_default(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr) { static struct bl2_to_bl31_params_mem bl31_params_mem; struct bl31_params *bl2_to_bl31_params; @@ -100,17 +100,17 @@ struct bl31_params *bl2_plat_get_bl31_params_default(uintptr_t bl32_entry, return bl2_to_bl31_params; }
-__weak struct bl31_params *bl2_plat_get_bl31_params(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr) +__weak struct bl31_params *bl2_plat_get_bl31_params(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr) { return bl2_plat_get_bl31_params_default(bl32_entry, bl33_entry, fdt_addr); }
-struct bl_params *bl2_plat_get_bl31_params_v2_default(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr) +struct bl_params *bl2_plat_get_bl31_params_v2_default(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr) { static struct bl2_to_bl31_params_mem_v2 bl31_params_mem; struct bl_params *bl_params; @@ -173,9 +173,9 @@ struct bl_params *bl2_plat_get_bl31_params_v2_default(uintptr_t bl32_entry, return bl_params; }
-__weak struct bl_params *bl2_plat_get_bl31_params_v2(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr) +__weak struct bl_params *bl2_plat_get_bl31_params_v2(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr) { return bl2_plat_get_bl31_params_v2_default(bl32_entry, bl33_entry, fdt_addr); @@ -188,8 +188,8 @@ static inline void raw_write_daif(unsigned int daif)
typedef void __noreturn (*atf_entry_t)(struct bl31_params *params, void *plat_params);
-static void __noreturn bl31_entry(uintptr_t bl31_entry, uintptr_t bl32_entry, - uintptr_t bl33_entry, uintptr_t fdt_addr) +static void __noreturn bl31_entry(ulong bl31_entry, ulong bl32_entry, + ulong bl33_entry, ulong fdt_addr) { atf_entry_t atf_entry = (atf_entry_t)bl31_entry; void *bl31_params; @@ -238,7 +238,7 @@ static int spl_fit_images_find(void *blob, int os) return -FDT_ERR_NOTFOUND; }
-uintptr_t spl_fit_images_get_entry(void *blob, int node) +ulong spl_fit_images_get_entry(void *blob, int node) { ulong val; int ret; @@ -253,10 +253,10 @@ uintptr_t spl_fit_images_get_entry(void *blob, int node)
void __noreturn spl_invoke_atf(struct spl_image_info *spl_image) { - uintptr_t bl32_entry = 0; - uintptr_t bl33_entry = CONFIG_TEXT_BASE; + ulong bl32_entry = 0; + ulong bl33_entry = CONFIG_TEXT_BASE; void *blob = spl_image->fdt_addr; - uintptr_t platform_param = (uintptr_t)blob; + ulong platform_param = (ulong)blob; int node;
/* diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 3160f573bfb..ef40a50082c 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -862,7 +862,7 @@ int spl_load_fit_image(struct spl_image_info *spl_image, { struct bootm_headers images; const char *fit_uname_config = NULL; - uintptr_t fdt_hack; + ulong fdt_hack; const char *uname; ulong fw_data = 0, dt_data = 0, img_data = 0; ulong fw_len = 0, dt_len = 0, img_len = 0; diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index 9252b3a3de0..b3efb3e630e 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -16,11 +16,11 @@
#define LZMA_LEN (1 << 20)
-static void spl_parse_legacy_validate(uintptr_t start, uintptr_t size) +static void spl_parse_legacy_validate(ulong start, ulong size) { - uintptr_t spl_start = (uintptr_t)_start; - uintptr_t spl_end = (uintptr_t)&_image_binary_end; - uintptr_t end = start + size; + ulong spl_start = (ulong)_start; + ulong spl_end = (ulong)&_image_binary_end; + ulong end = start + size;
if ((start >= spl_start && start < spl_end) || (end > spl_start && end <= spl_end) || diff --git a/include/spl.h b/include/spl.h index 269e36bb441..43b344dbc55 100644 --- a/include/spl.h +++ b/include/spl.h @@ -268,8 +268,8 @@ enum spl_sandbox_flags { struct spl_image_info { const char *name; u8 os; - uintptr_t load_addr; - uintptr_t entry_point; + ulong load_addr; + ulong entry_point; #if CONFIG_IS_ENABLED(LOAD_FIT) || CONFIG_IS_ENABLED(LOAD_FIT_FULL) void *fdt_addr; #endif @@ -951,9 +951,9 @@ void __noreturn spl_invoke_atf(struct spl_image_info *spl_image); * * Return: bl31 params structure pointer */ -struct bl31_params *bl2_plat_get_bl31_params(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr); +struct bl31_params *bl2_plat_get_bl31_params(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr);
/** * bl2_plat_get_bl31_params_default() - prepare params for bl31. @@ -972,9 +972,9 @@ struct bl31_params *bl2_plat_get_bl31_params(uintptr_t bl32_entry, * * Return: bl31 params structure pointer */ -struct bl31_params *bl2_plat_get_bl31_params_default(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr); +struct bl31_params *bl2_plat_get_bl31_params_default(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr);
/** * bl2_plat_get_bl31_params_v2() - return params for bl31 @@ -988,9 +988,9 @@ struct bl31_params *bl2_plat_get_bl31_params_default(uintptr_t bl32_entry, * * Return: bl31 params structure pointer */ -struct bl_params *bl2_plat_get_bl31_params_v2(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr); +struct bl_params *bl2_plat_get_bl31_params_v2(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr);
/** * bl2_plat_get_bl31_params_v2_default() - prepare params for bl31. @@ -1007,9 +1007,9 @@ struct bl_params *bl2_plat_get_bl31_params_v2(uintptr_t bl32_entry, * * Return: bl31 params structure pointer */ -struct bl_params *bl2_plat_get_bl31_params_v2_default(uintptr_t bl32_entry, - uintptr_t bl33_entry, - uintptr_t fdt_addr); +struct bl_params *bl2_plat_get_bl31_params_v2_default(ulong bl32_entry, + ulong bl33_entry, + ulong fdt_addr); /** * spl_optee_entry - entry function for optee *
The variable 'ret' is defined twice, which is not intended. This may have been a local merge error.
Signed-off-by: Simon Glass sjg@chromium.org Fixes: 2eefeb6d893 ("spl: Report a loader failure") ---
common/spl/spl.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 702920bd2f7..ad31a2f8b6c 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -612,7 +612,6 @@ static int boot_from_devices(struct spl_image_info *spl_image, for (i = 0; i < count && spl_boot_list[i] != BOOT_DEVICE_NONE; i++) { struct spl_image_loader *loader; int bootdev = spl_boot_list[i]; - int ret;
Add debugging of image-loading progress. Fix a stale comment in the function comment while we are here.
common/spl/spl_fit.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index ef40a50082c..ac8462577ff 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -190,7 +190,7 @@ static int get_aligned_image_size(struct spl_load_info *info, int data_size, /** * load_simple_fit(): load the image described in a certain FIT node * @info: points to information about the device to load data from - * @sector: the start sector of the FIT image on the device + * @fit_offset: the offset of the FIT image on the device * @ctx: points to the FIT context structure * @node: offset of the DT node describing the image to load (relative * to @fit) @@ -243,11 +243,14 @@ static int load_simple_fit(struct spl_load_info *info, ulong fit_offset, if (!fit_image_get_data_position(fit, node, &offset)) { external_data = true; } else if (!fit_image_get_data_offset(fit, node, &offset)) { + log_debug("read offset %x = offset from fit %lx\n", + offset, (ulong)offset + ctx->ext_data_offset); offset += ctx->ext_data_offset; external_data = true; }
if (external_data) { + ulong read_offset; void *src_ptr;
/* External data */ @@ -270,6 +273,10 @@ static int load_simple_fit(struct spl_load_info *info, ulong fit_offset,
overhead = get_aligned_image_overhead(info, offset); size = get_aligned_image_size(info, length, offset); + read_offset = fit_offset + get_aligned_image_offset(info, + offset); + log_debug("reading from offset %x / %lx size %lx to %p: ", + offset, read_offset, size, src_ptr);
if (info->read(info, fit_offset + @@ -336,6 +343,7 @@ static int load_simple_fit(struct spl_load_info *info, ulong fit_offset, else image_info->entry_point = FDT_ERROR; } + log_debug("- done loading\n");
upl_add_image(fit, node, load_addr, length);
Add Kconfig symbols and update the Makefile rules so that decompression can be used in TPL and VPL
lib/Kconfig | 35 +++++++++++++++++++++++++++++++++++ lib/Makefile | 12 ++++++------ 2 files changed, 41 insertions(+), 6 deletions(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 56ffdfa1839..3fa580ab1eb 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -832,12 +832,36 @@ config SPL_LZ4 fast compression and decompression speed. It belongs to the LZ77 family of byte-oriented compression schemes.
+config TPL_LZ4 + bool "Enable LZ4 decompression support in TPL" + depends on TPL + help + This enables support for the LZ4 decompression algorithm in TPL. LZ4 + is a lossless data compression algorithm that is focused on + fast compression and decompression speed. It belongs to the LZ77 + family of byte-oriented compression schemes. + +config VPL_LZ4 + bool "Enable LZ4 decompression support in VPL" + depends on VPL + help + This enables support for the LZ4 decompression algorithm in VPL. LZ4 + is a lossless data compression algorithm that is focused on + fast compression and decompression speed. It belongs to the LZ77 + family of byte-oriented compression schemes. + config SPL_LZMA bool "Enable LZMA decompression support for SPL build" depends on SPL help This enables support for LZMA compression algorithm for SPL boot.
+config TPL_LZMA + bool "Enable LZMA decompression support for TPL build" + depends on TPL + help + This enables support for LZMA compression algorithm for TPL boot. + config VPL_LZMA bool "Enable LZMA decompression support for VPL build" default y if LZMA @@ -856,11 +880,22 @@ config SPL_GZIP help This enables support for the GZIP compression algorithm for SPL boot.
+config TPL_GZIP + bool "Enable gzip decompression support for SPL build" + select TPL_ZLIB + help + This enables support for the GZIP compression algorithm for TPL + config SPL_ZLIB bool help This enables compression lib for SPL boot.
+config TPL_ZLIB + bool + help + This enables compression lib for TPL + config SPL_ZSTD bool "Enable Zstandard decompression support in SPL" depends on SPL diff --git a/lib/Makefile b/lib/Makefile index dbcfa87ebd6..31cfbb67aa0 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -83,12 +83,12 @@ obj-$(CONFIG_$(XPL_)SHA512_LEGACY) += sha512.o obj-$(CONFIG_CRYPT_PW) += crypt/ obj-$(CONFIG_$(XPL_)ASN1_DECODER_LEGACY) += asn1_decoder.o
-obj-$(CONFIG_$(XPL_)ZLIB) += zlib/ -obj-$(CONFIG_$(XPL_)ZSTD) += zstd/ -obj-$(CONFIG_$(XPL_)GZIP) += gunzip.o -obj-$(CONFIG_$(XPL_)LZO) += lzo/ -obj-$(CONFIG_$(XPL_)LZMA) += lzma/ -obj-$(CONFIG_$(XPL_)LZ4) += lz4_wrapper.o +obj-$(CONFIG_$(PHASE_)ZLIB) += zlib/ +obj-$(CONFIG_$(PHASE_)ZSTD) += zstd/ +obj-$(CONFIG_$(PHASE_)GZIP) += gunzip.o +obj-$(CONFIG_$(PHASE_)LZO) += lzo/ +obj-$(CONFIG_$(PHASE_)LZMA) += lzma/ +obj-$(CONFIG_$(PHASE_)LZ4) += lz4_wrapper.o
obj-$(CONFIG_$(XPL_)LIB_RATIONAL) += rational.o
With VBE we want to use FIT in all phases of the boot. Add Kconfig options to support this.
Disable the options for sandbox_vpl for now.
boot/Kconfig | 69 ++++++++++++++++++++++++++++++++++- configs/sandbox_vpl_defconfig | 2 + 2 files changed, 70 insertions(+), 1 deletion(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 705947cfa95..e8f87e48ee6 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -163,6 +163,18 @@ config SPL_FIT select SPL_HASH select SPL_OF_LIBFDT
+config VPL_FIT + bool "Support Flattened Image Tree within VPL" + depends on VPL + select VPL_HASH + select VPL_OF_LIBFDT + +config TPL_FIT + bool "Support Flattened Image Tree within TPL" + depends on TPL + select TPL_HASH + select TPL_OF_LIBFDT + config SPL_FIT_PRINT bool "Support FIT printing within SPL" depends on SPL_FIT @@ -268,6 +280,28 @@ config SPL_LOAD_FIT_FULL particular it can handle selecting from multiple device tree and passing the correct one to U-Boot.
+config TPL_LOAD_FIT + bool "Enable TPL loading U-Boot as a FIT (basic fitImage features)" + depends on TPL + select TPL_FIT + help + Normally with the SPL framework a legacy image is generated as part + of the build. This contains U-Boot along with information as to + where it should be loaded. This option instead enables generation + of a FIT (Flat Image Tree) which provides more flexibility. In + particular it can handle selecting from multiple device tree + and passing the correct one to U-Boot. + + This path has the following limitations: + + 1. "loadables" images, other than FDTs, which do not have a "load" + property will not be loaded. This limitation also applies to FPGA + images with the correct "compatible" string. + 2. For FPGA images, the supported "compatible" list is in the + doc/uImage.FIT/source_file_format.txt. + 3. FDTs are only loaded for images with an "os" property of "u-boot". + "linux" images are also supported with Falcon boot mode. + config SPL_FIT_IMAGE_POST_PROCESS bool "Enable post-processing of FIT artifacts after loading by the SPL" depends on SPL_LOAD_FIT @@ -307,6 +341,22 @@ config VPL_FIT select VPL_HASH select VPL_OF_LIBFDT
+config VPL_LOAD_FIT + bool "Enable VPL loading U-Boot as a FIT (basic fitImage features)" + select VPL_FIT + default y + +config VPL_LOAD_FIT_FULL + bool "Enable SPL loading U-Boot as a FIT (full fitImage features)" + select VPL_FIT + help + Normally with the SPL framework a legacy image is generated as part + of the build. This contains U-Boot along with information as to + where it should be loaded. This option instead enables generation + of a FIT (Flat Image Tree) which provides more flexibility. In + particular it can handle selecting from multiple device tree + and passing the correct one to U-Boot. + config VPL_FIT_PRINT bool "Support FIT printing within VPL" depends on VPL_FIT @@ -649,6 +699,15 @@ config VPL_BOOTMETH_VBE supports selection of various firmware components, selection of an OS to boot as well as updating these using fwupd.
+config TPL_BOOTMETH_VBE + bool "Bootdev support for Verified Boot for Embedded (TPL)" + depends on TPL + default y + help + Enables support for VBE boot. This is a standard boot method which + supports selection of various firmware components, seleciton of an OS to + boot as well as updating these using fwupd. + if BOOTMETH_VBE
config BOOTMETH_VBE_REQUEST @@ -727,7 +786,15 @@ config VPL_BOOTMETH_VBE_SIMPLE_FW This option enabled for VPL, since it is the phase where the SPL decision is made.
-endif # BOOTMETH_VBE +config TPL_BOOTMETH_VBE_SIMPLE_FW + bool "Bootdev support for VBE 'simple' method firmware phase (TPL)" + depends on VPL + default y + help + Enables support for the firmware parts of VBE 'simple' boot, in TPL. + TPL loads a FIT containing the VPL binary and a suitable devicetree. + +endif # BOOTMETH_VBE_SIMPLE
config EXPO bool "Support for expos - groups of scenes displaying a UI" diff --git a/configs/sandbox_vpl_defconfig b/configs/sandbox_vpl_defconfig index 84df2b85260..46329395ba5 100644 --- a/configs/sandbox_vpl_defconfig +++ b/configs/sandbox_vpl_defconfig @@ -27,6 +27,8 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_TPL_BOOTMETH_VBE is not set +# CONFIG_TPL_BOOTMETH_VBE_SIMPLE_FW is not set CONFIG_UPL=y CONFIG_UPL_IN=y CONFIG_BOOTSTAGE=y
Provide options to enable the CRC8 feature in TPL and VPL builds.
Changes in v2: - Fix 'depends on SPL' to depend on TPL
lib/Kconfig | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/lib/Kconfig b/lib/Kconfig index 3fa580ab1eb..c8ac99df78e 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -719,6 +719,24 @@ config SPL_CRC8 checksum with feedback to produce an 8-bit result. The code is small and it does not require a lookup table (unlike CRC32).
+config TPL_CRC8 + bool "Support CRC8 in TPL" + depends on TPL + help + Enables CRC8 support in TPL. This is not normally required. CRC8 is + a simple and fast checksumming algorithm which does a bytewise + checksum with feedback to produce an 8-bit result. The code is small + and it does not require a lookup table (unlike CRC32). + +config VPL_CRC8 + bool "Support CRC8 in VPL" + depends on VPL + help + Enables CRC8 support in VPL. This is not normally required. CRC8 is + a simple and fast checksumming algorithm which does a bytewise + checksum with feedback to produce an 8-bit result. The code is small + and it does not require a lookup table (unlike CRC32). + config SPL_CRC16 bool "Support CRC16 in SPL" depends on SPL
VBE uses a crc8 checksum to verify that the nvdata is valid, so make sure it is available if VBE is enabled.
Changes in v2: - Depend on TPL/VPL as well
boot/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/boot/Kconfig b/boot/Kconfig index e8f87e48ee6..73106f7a617 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -733,6 +733,8 @@ config SPL_BOOTMETH_VBE_REQUEST config BOOTMETH_VBE_SIMPLE bool "Bootdev support for VBE 'simple' method" default y + imply SPL_CRC8 if SPL + imply VPL_CRC8 if VPL help Enables support for VBE 'simple' boot. This allows updating a single firmware image in boot media such as MMC. It does not support any sort
Add an entry for crc8, with watchdog handling.
Changes in v3: - Rebase to master
Changes in v2: - Drop patch 'serial: ns16550: Allow clocks to be missing'
common/hash.c | 8 ++++++++ include/u-boot/crc.h | 3 +++ lib/crc8.c | 6 ++++++ 3 files changed, 17 insertions(+)
diff --git a/common/hash.c b/common/hash.c index db6925d6782..5d389420eff 100644 --- a/common/hash.c +++ b/common/hash.c @@ -304,6 +304,14 @@ static struct hash_algo hash_algo[] = { .hash_update = hash_update_crc16_ccitt, .hash_finish = hash_finish_crc16_ccitt, }, +#if CONFIG_IS_ENABLED(CRC8) + { + .name = "crc8", + .digest_size = 1, + .chunk_size = CHUNKSZ_CRC32, + .hash_func_ws = crc8_wd_buf, + }, +#endif #if CONFIG_IS_ENABLED(CRC32) { .name = "crc32", diff --git a/include/u-boot/crc.h b/include/u-boot/crc.h index 5174bd7ac41..b2badaf6a97 100644 --- a/include/u-boot/crc.h +++ b/include/u-boot/crc.h @@ -25,6 +25,9 @@ */ unsigned int crc8(unsigned int crc_start, const unsigned char *vptr, int len);
+void crc8_wd_buf(const unsigned char *input, unsigned int len, + unsigned char output[1], unsigned int chunk_sz); + /* lib/crc16.c - 16 bit CRC with polynomial x^16 + x^15 + x^2 + 1 */ uint16_t crc16(uint16_t crc, const unsigned char *buffer, size_t len);
diff --git a/lib/crc8.c b/lib/crc8.c index 20d46d16147..811e19917b4 100644 --- a/lib/crc8.c +++ b/lib/crc8.c @@ -32,3 +32,9 @@ unsigned int crc8(unsigned int crc, const unsigned char *vptr, int len)
return crc; } + +void crc8_wd_buf(const unsigned char *input, unsigned int len, + unsigned char output[1], unsigned int chunk_sz) +{ + *output = crc8(0, input, len); +}
Changes in v3:
- Rebase to master
Changes in v3:
- Rebase to master
And, ugh, I missed that CI was failing for real. This causes rcar3_salvator-x to fail to link due to size growth, so I'm reverting this for now, sorry. I thought the CI failure I saw was due to something else at the time.
Hi Tom,
Changes in v3:
- Rebase to master
Hmm, sorry about that...it passed CI when I sent it!
The growth is quite alarming and I am not sure how to make sense of it. Here is the last patch:
21: hash: Plumb crc8 into the hash functions aarch64: + rcar3_salvator-x aarch64: (for 1/1 boards) all +2109.0 bss -48.0 data +56.0 rodata +5.0 text +2096.0 rcar3_salvator-x: all +2109 bss -48 data +56 rodata +5 text +2096 u-boot: add: 1/0, grow: 1/0 bytes: 136/0 (136) function old new delta crc8_wd_buf - 80 +80 hash_algo 280 336 +56
So perhaps apply all but the final patch? Then I can sort out things from there.
On Thu, Dec 12, 2024 at 08:24:06PM -0700, Simon Glass wrote:
Hi Tom,
Changes in v3:
- Rebase to master
I tried that before going off for the night without remembering that the problem is: +(rcar3_salvator-x) u-boot.img exceeds file size limit: +(rcar3_salvator-x) limit: 0x100000 bytes +(rcar3_salvator-x) actual: 0x100392 bytes +(rcar3_salvator-x) excess: 0x392 bytes
So no, just the last patch alone is not enough. You need to sync up with Marek about what can/can't be disabled on the platform (or more likely really, r-car gen3 platforms overall0.
Hi Tom,
Hi Tom,
Changes in v3:
- Rebase to master
I don't really like the size growth and I think it might be better to put my hash addition behind a Kconfig. While these boards are inconvenient, they do keep us honest, on code size.
Jaehoon Chung
