[PULL next] u-boot-at91-2022.01-a
Hello Tom,
Please pull tag u-boot-at91-2022.01-a , the first set of features for the next cycle 2022.01 . The PR is rebased on -next .
This feature set includes : the support for CPU driver for arm926 (sam9x60 device); changes required for OP-TEE boot for sama5d2_xplained and sama5d27_som1_ek boards; QSPI boot configuration for sama5d2_icp; starting to remove old Kconfig unused symbols from config_whitelist.txt (work will take more time); also small fixes and updates in mach, DT, configs, etc.
Thanks, Eugen
The following changes since commit 44131caa4025455a659e958281f0e337bdf83f89:
scripts/config_whitelist.txt: Fix after merging (2021-09-16 13:18:21 -0400)
https://source.denx.de/u-boot/custodians/u-boot-at91.git tags/u-boot-at91-2022.01-a
for you to fetch changes up to d65b84a1d0dc116010a3842dc13661976ef92629:
ARM: dts: at91: update flexcom defines using include file (2021-09-21 10:08:24 +0300)
---------------------------------------------------------------- First set of u-boot-at91 features for the 2022.01 cycle
---------------------------------------------------------------- Claudiu Beznea (4): clk: at91: clk-master: split master clock in pres and divider cpu: at91: add compatible for ARM9260EJ-S ARM: dts: at91: sam9x60: add bindings for CPU configs: sam9x60ek: enable CONFIG_CPU
Clément Léger (6): ARM: mach-at91: armv7: fix multiple cpu_reset definition when enabling SYSRESET board: sama5d27_som1_ek: Get dram size and base from device tree board: sama5d27_som1_ek: Modify load addresses ARM: dts: at91: sama5d2_xplained: Add memory node in devicetree board: sama5d2_xplained: Get dram size and base from device tree board: sama5d2_xplained: Modify load addresses
Eugen Hristev (8): ARM: dts: at91: sama5d2_icp: cosmetic arrangement of the nodes ARM: dts: at91: sama5d2: fix dtc warning for ohci and ehci board: atmel: sama7g5ek: avoid rewriting of configured CONFIG_BOOTCOMMAND board: pm926x: remove unused CONFIG_SYS_AT91_CPU_NAME ARM: at91: remove references to RM9200DK net: remove unused CONFIG_DRIVER_AT91EMAC_* include: dt-bindings: mfd: add atmel flexcom include file ARM: dts: at91: update flexcom defines using include file
Hari Prasath (1): ARM: at91: Add chip ID of SAMA5D29
Mihai Sain (2): ARM: dts: at91: sama5d2_icp: add QSPI1 device configs: sama5d2: add qspi config for QSPI1
Reto Schneider (1): configs: gardena-smart-gateway-at91sam: Adjust to production values
MAINTAINERS | 1 + README | 11 - arch/arm/cpu/arm920t/start.S | 14 - arch/arm/dts/at91-sama5d27_som1_ek.dts | 4 +- arch/arm/dts/at91-sama5d2_icp-u-boot.dtsi | 23 +- arch/arm/dts/at91-sama5d2_icp.dts | 48 ++- arch/arm/dts/at91-sama5d2_ptc_ek.dts | 4 +- arch/arm/dts/at91-sama5d2_xplained.dts | 8 +- arch/arm/dts/sam9x60.dtsi | 12 + arch/arm/dts/sam9x60ek.dts | 3 +- arch/arm/dts/sama5d2.dtsi | 4 +- arch/arm/dts/sama7g5ek.dts | 3 +- arch/arm/include/asm/mach-types.h | 1 - arch/arm/mach-at91/armv7/Makefile | 4 +- arch/arm/mach-at91/armv7/sama5d2_devices.c | 2 + arch/arm/mach-at91/include/mach/sama5d2.h | 1 + board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 12 +- board/atmel/sama5d2_icp/MAINTAINERS | 1 + board/atmel/sama5d2_xplained/sama5d2_xplained.c | 11 +- configs/gardena-smart-gateway-at91sam_defconfig | 15 +- configs/sam9x60ek_mmc_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sam9x60ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_qspiflash_defconfig | 103 +++++ configs/sama7g5ek_mmc1_defconfig | 2 + configs/sama7g5ek_mmc_defconfig | 2 + drivers/clk/at91/clk-master.c | 107 ++++- drivers/clk/at91/pmc.h | 7 +- drivers/clk/at91/sam9x60.c | 44 +- drivers/clk/at91/sama7g5.c | 36 +- drivers/cpu/at91_cpu.c | 1 + drivers/net/Makefile | 1 - drivers/net/at91_emac.c | 519 ------------------------ include/configs/pm9261.h | 2 - include/configs/pm9263.h | 2 - include/configs/sama5d27_som1_ek.h | 12 +- include/configs/sama5d2_xplained.h | 24 +- include/configs/sama7g5ek.h | 6 +- include/dt-bindings/mfd/atmel-flexcom.h | 15 + include/netdev.h | 1 - scripts/config_whitelist.txt | 3 - 41 files changed, 413 insertions(+), 659 deletions(-) create mode 100644 configs/sama5d2_icp_qspiflash_defconfig delete mode 100644 drivers/net/at91_emac.c create mode 100644 include/dt-bindings/mfd/atmel-flexcom.h
On Wed, Sep 22, 2021 at 09:03:50AM +0000, Eugen.Hristev@microchip.com wrote:
Hello Tom,
Thanks, Eugen
