[U-Boot] [PATCH] vsprintf.c: add GUID printing
This works (roughly) the same way as linux's, but we currently always print lower-case (ie. we just keep %pUB and %pUL for compat with linux), mostly just because that is what uuid_bin_to_str() supports.
%pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10
It will be used by a later efi_loader paths for efi variables and for device-path-to-text protocol, and also quite useful for debug prints of protocol GUIDs.
Signed-off-by: Rob Clark robdclark@gmail.com --- This replaces "efi_loader: add guidstr helper" in my "enough UEFI for standard distro boot" patchset, and could also replace Heinrich's "efi_loader: write protocol GUID in OpenProtocol" with a single one- line debug() print.
include/config_fallbacks.h | 1 + lib/vsprintf.c | 46 ++++++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 45 insertions(+), 2 deletions(-)
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 961a83d758..56b9de09f2 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -57,6 +57,7 @@
#if (CONFIG_IS_ENABLED(PARTITION_UUIDS) || \ CONFIG_IS_ENABLED(EFI_PARTITION) || \ + CONFIG_IS_ENABLED(EFI_LOADER) || \ defined(CONFIG_RANDOM_UUID) || \ defined(CONFIG_CMD_UUID) || \ defined(CONFIG_BOOTP_PXE)) && \ diff --git a/lib/vsprintf.c b/lib/vsprintf.c index 0c40f852ce..156fda5ad6 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -18,6 +18,7 @@
#include <common.h> #include <charset.h> +#include <uuid.h>
#include <div64.h> #define noinline __attribute__((noinline)) @@ -366,6 +367,40 @@ static char *ip4_addr_string(char *buf, char *end, u8 *addr, int field_width, } #endif
+#ifdef CONFIG_LIB_UUID +/* + * This works (roughly) the same way as linux's, but we currently always + * print lower-case (ie. we just keep %pUB and %pUL for compat with linux), + * mostly just because that is what uuid_bin_to_str() supports. + * + * %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 + * %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 + */ +static char *uuid_string(char *buf, char *end, u8 *addr, int field_width, + int precision, int flags, const char *fmt) +{ + char uuid[UUID_STR_LEN + 1]; + int str_format = UUID_STR_FORMAT_STD; + + switch (*(++fmt)) { + case 'L': + case 'l': + str_format = UUID_STR_FORMAT_GUID; + break; + case 'B': + case 'b': + /* this is the default */ + break; + default: + break; + } + + uuid_bin_to_str(addr, uuid, str_format); + + return string(buf, end, uuid, field_width, precision, flags); +} +#endif + /* * Show a '%p' thing. A kernel extension is that the '%p' is followed * by an extra set of alphanumeric characters that are extended format @@ -399,8 +434,8 @@ static char *pointer(const char *fmt, char *buf, char *end, void *ptr, flags); #endif
-#ifdef CONFIG_CMD_NET switch (*fmt) { +#ifdef CONFIG_CMD_NET case 'a': flags |= SPECIAL | ZEROPAD;
@@ -430,8 +465,15 @@ static char *pointer(const char *fmt, char *buf, char *end, void *ptr, precision, flags); flags &= ~SPECIAL; break; - } #endif +#ifdef CONFIG_LIB_UUID + case 'U': + return uuid_string(buf, end, ptr, field_width, precision, + flags, fmt); +#endif + default: + break; + } flags |= SMALL; if (field_width == -1) { field_width = 2*sizeof(void *);
- CONFIG_IS_ENABLED(EFI_LOADER) || \ defined(CONFIG_RANDOM_UUID) || \ defined(CONFIG_CMD_UUID) || \ defined(CONFIG_BOOTP_PXE)) && \
- This works (roughly) the same way as linux's, but we currently always
- print lower-case (ie. we just keep %pUB and %pUL for compat with linux),
- mostly just because that is what uuid_bin_to_str() supports.
- %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10
- %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10
- char uuid[UUID_STR_LEN + 1];
- int str_format = UUID_STR_FORMAT_STD;
- switch (*(++fmt)) {
- case 'L':
- case 'l':
break;
- case 'B':
- case 'b':
break;
- default:
break;
- uuid_bin_to_str(addr, uuid, str_format);
- return string(buf, end, uuid, field_width, precision, flags);
+} +#endif
- Show a '%p' thing. A kernel extension is that the '%p' is followed
- by an extra set of alphanumeric characters that are extended format
- case 'U':
flags, fmt);
- default:
break;
- } flags |= SMALL; if (field_width == -1) { field_width = 2*sizeof(void *);
I was not able to apply the patch to v2017.09-rc1 nor to git HEAD.
Applying: vsprintf.c: add GUID printing error: patch failed: lib/vsprintf.c:18 error: lib/vsprintf.c: patch does not apply
This is my lib/vsprintf.c: 14 #include <stdarg.h> 15 #include <linux/types.h> 16 #include <linux/string.h> 17 #include <linux/ctype.h> 18 19 #include <common.h> 20 21 #include <div64.h>
There is no line with #include <charset.h>.
Best regards
On Tue, Aug 8, 2017 at 12:56 PM, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
[snip]
that comes from the previous patch which adds utf16 support.. I think that should be the only conflicting hunk, the later bits are far enough away from the utf16 related hunks.
BR, -R
Rob Clark
