[U-Boot] [PATCH 0/3] dm: mmc: Tidy up use of block devices
A recent series added a patch to avoid probing block devices in find_mmc_device(). This is because callers should obtain the block device itself, not the MMC device. But for now the environment code has not been converted.
The patch caused problems on some boards so was dropped.
This series reinstates that patch, but ensures that the block device is probed first.
Simon Glass (3): dm: blk: Add a way to obtain a block device from its parent dm: mmc: Ensure that block device is probed dm: mmc: Avoid probing block devices in find_mmc_device()
common/env_mmc.c | 7 ++++++- drivers/block/blk-uclass.c | 26 ++++++++++++++++++++++++++ drivers/mmc/mmc-uclass.c | 6 ++++-- include/blk.h | 7 +++++++ test/dm/blk.c | 18 ++++++++++++++++++ 5 files changed, 61 insertions(+), 3 deletions(-)
Many devices support a child block device (e.g. MMC, USB). Add a convenient way to get this device given the parent device.
drivers/block/blk-uclass.c | 26 ++++++++++++++++++++++++++ include/blk.h | 7 +++++++ test/dm/blk.c | 18 ++++++++++++++++++ 3 files changed, 51 insertions(+)
diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index 6145675271..23f131b7ad 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -453,6 +453,32 @@ int blk_prepare_device(struct udevice *dev) return 0; }
+int blk_get_from_parent(struct udevice *parent, struct udevice **devp) +{ + struct udevice *dev; + enum uclass_id id; + int ret; + + device_find_first_child(parent, &dev); + if (!dev) { + debug("%s: No block device found for parent '%s'\n", __func__, + parent->name); + return -ENODEV; + } + id = device_get_uclass_id(dev); + if (id != UCLASS_BLK) { + debug("%s: Incorrect uclass %s for block device '%s'\n", + __func__, uclass_get_name(id), dev->name); + return -ENOTBLK; + } + ret = device_probe(dev); + if (ret) + return ret; + *devp = dev; + + return 0; +} + int blk_find_max_devnum(enum if_type if_type) { struct udevice *dev; diff --git a/include/blk.h b/include/blk.h index a128ee4841..4d60987f61 100644 --- a/include/blk.h +++ b/include/blk.h @@ -616,4 +616,11 @@ ulong blk_write_devnum(enum if_type if_type, int devnum, lbaint_t start, */ int blk_select_hwpart_devnum(enum if_type if_type, int devnum, int hwpart);
+/** + * blk_get_from_parent() - obtain a block device by looking up its parent + * + * All devices with + */ +int blk_get_from_parent(struct udevice *parent, struct udevice **devp); + #endif diff --git a/test/dm/blk.c b/test/dm/blk.c index 5c5eb829a0..923e8d95f0 100644 --- a/test/dm/blk.c +++ b/test/dm/blk.c @@ -150,3 +150,21 @@ static int dm_test_blk_devnum(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_blk_devnum, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test that we can get a block from its parent */ +static int dm_test_blk_get_from_parent(struct unit_test_state *uts) +{ + struct udevice *dev, *blk; + + ut_assertok(uclass_get_device(UCLASS_MMC, 0, &dev)); + ut_assertok(blk_get_from_parent(dev, &blk)); + + ut_assertok(uclass_get_device(UCLASS_I2C, 0, &dev)); + ut_asserteq(-ENOTBLK, blk_get_from_parent(dev, &blk)); + + ut_assertok(uclass_get_device(UCLASS_GPIO, 0, &dev)); + ut_asserteq(-ENODEV, blk_get_from_parent(dev, &blk)); + + return 0; +} +DM_TEST(dm_test_blk_get_from_parent, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Hi Simon,
- struct udevice *dev;
- enum uclass_id id;
- int ret;
- device_find_first_child(parent, &dev);
- if (!dev) {
parent->name);
return -ENODEV;
- id = device_get_uclass_id(dev);
- if (id != UCLASS_BLK) {
return -ENOTBLK;
- ret = device_probe(dev);
- if (ret)
return ret;
- *devp = dev;
- blk_get_from_parent() - obtain a block device by looking up its parent
- All devices with
Don't need to consider whether CONFIG_BLK is defined or not? blk_get_from_parent() is declared in blk-uclass.c
Best Regards, Jaehoon Chung
- struct udevice *dev, *blk;
- ut_assertok(uclass_get_device(UCLASS_MMC, 0, &dev));
- ut_assertok(blk_get_from_parent(dev, &blk));
- ut_assertok(uclass_get_device(UCLASS_I2C, 0, &dev));
- ut_asserteq(-ENOTBLK, blk_get_from_parent(dev, &blk));
- ut_assertok(uclass_get_device(UCLASS_GPIO, 0, &dev));
- ut_asserteq(-ENODEV, blk_get_from_parent(dev, &blk));
Hi Jaehoon,
On 6 June 2017 at 21:49, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Simon,
enum uclass_id id;
int ret;
if (!dev) {
parent->name);
return -ENODEV;
return -ENOTBLK;
if (ret)
return ret;
*devp = dev;
- All devices with
Well in that case this function will not be called, so I think it is OK.
- Simon
On 06/09/2017 12:06 PM, Simon Glass wrote:
Hi Jaehoon,
Hi Simon,
enum uclass_id id;
int ret;
if (!dev) {
parent->name);
return -ENODEV;
return -ENOTBLK;
if (ret)
return ret;
*devp = dev;
- All devices with
include/blk.h:624:32: warning: 'struct udevice' declared inside parameter list will not be visible outside of this definition or declaration int blk_get_from_parent(struct udevice *parent, struct udevice **devp);
Plz, check this.. :)
- Simon
Hi Jaehoon,
Hi Jaehoon,
Hi Simon,
enum uclass_id id;
int ret;
if (!dev) {
parent->name);
return -ENODEV;
return -ENOTBLK;
if (ret)
return ret;
*devp = dev;
- All devices with
Which board is this, please?
Make sure that we probe the block device before using it when reading the environment.
common/env_mmc.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/common/env_mmc.c b/common/env_mmc.c index 1611886e22..3763b12278 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -98,7 +98,12 @@ static const char *init_mmc_for_env(struct mmc *mmc) if (!mmc) return "!No MMC card found";
-#ifndef CONFIG_BLK +#ifdef CONFIG_BLK + struct udevice *dev; + + if (blk_get_from_parent(mmc->dev, &dev)) + return "!No block device"; +#else if (mmc_init(mmc)) return "!MMC init failed"; #endif
We do not need to probe the block device here, so avoid doing so. The MMC device itself must be active, but the block device can come later.
drivers/mmc/mmc-uclass.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 4dc3925fe6..994d2686f4 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -97,7 +97,7 @@ struct mmc *find_mmc_device(int dev_num) struct udevice *dev, *mmc_dev; int ret;
- ret = blk_get_device(IF_TYPE_MMC, dev_num, &dev); + ret = blk_find_device(IF_TYPE_MMC, dev_num, &dev);
if (ret) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) @@ -108,7 +108,9 @@ struct mmc *find_mmc_device(int dev_num)
mmc_dev = dev_get_parent(dev);
- return mmc_get_mmc_dev(mmc_dev); + struct mmc *mmc = mmc_get_mmc_dev(mmc_dev); + + return mmc; }
int get_mmc_num(void)
if (ret) {
- struct mmc *mmc = mmc_get_mmc_dev(mmc_dev);
- return mmc;
We should declare new variables at the top of the function here, thanks!
Hi Simon,
Is there a patch before applying these patches? When i tried to apply patches from patchwork, it doesn't apply.
Hi Jaehoon,
On 1 June 2017 at 21:18, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Simon,
Yes - it is at u-boot-dm/mmc-working. I think the prerequisites will land in master tonight.
Jaehoon Chung
