[U-Boot] [PATCH] t2080qds/ddr: update ddr parameters
- Optimize UDIMM parameters for whole range from 1500MT/s to 2140MT/s. - Remove unused patameters: 'cpo', 'wrdata delay', '2T', which are unrelated to DDR3/3L.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- board/freescale/t2080qds/ddr.c | 12 ++------ board/freescale/t2080qds/ddr.h | 65 +++++++++++++++++------------------------- 2 files changed, 28 insertions(+), 49 deletions(-)
diff --git a/board/freescale/t2080qds/ddr.c b/board/freescale/t2080qds/ddr.c index 9f6c9c4..b4def3c 100644 --- a/board/freescale/t2080qds/ddr.c +++ b/board/freescale/t2080qds/ddr.c @@ -24,7 +24,7 @@ void fsl_ddr_board_options(memctl_options_t *popts, const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; ulong ddr_freq;
- if (ctrl_num > 2) { + if (ctrl_num > 1) { printf("Not supported controller number %d\n", ctrl_num); return; } @@ -40,8 +40,7 @@ void fsl_ddr_board_options(memctl_options_t *popts, else pbsp = udimms[0];
- - /* Get clk_adjust, cpo, write_data_delay,2T, according to the board ddr + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr * freqency and n_banks specified in board_specific_parameters table. */ ddr_freq = get_ddr_freq(0) / 1000000; @@ -49,14 +48,10 @@ void fsl_ddr_board_options(memctl_options_t *popts, if (pbsp->n_ranks == pdimm->n_ranks && (pdimm->rank_density >> 30) >= pbsp->rank_gb) { if (ddr_freq <= pbsp->datarate_mhz_high) { - popts->cpo_override = pbsp->cpo; - popts->write_data_delay = - pbsp->write_data_delay; popts->clk_adjust = pbsp->clk_adjust; popts->wrlvl_start = pbsp->wrlvl_start; popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - popts->twot_en = pbsp->force_2t; goto found; } pbsp_highest = pbsp; @@ -69,13 +64,10 @@ void fsl_ddr_board_options(memctl_options_t *popts, printf("for data rate %lu MT/s\n", ddr_freq); printf("Trying to use the highest speed (%u) parameters\n", pbsp_highest->datarate_mhz_high); - popts->cpo_override = pbsp_highest->cpo; - popts->write_data_delay = pbsp_highest->write_data_delay; popts->clk_adjust = pbsp_highest->clk_adjust; popts->wrlvl_start = pbsp_highest->wrlvl_start; popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - popts->twot_en = pbsp_highest->force_2t; } else { panic("DIMM is not supported by this board"); } diff --git a/board/freescale/t2080qds/ddr.h b/board/freescale/t2080qds/ddr.h index 964eaad..9fc879a 100644 --- a/board/freescale/t2080qds/ddr.h +++ b/board/freescale/t2080qds/ddr.h @@ -14,9 +14,6 @@ struct board_specific_parameters { u32 wrlvl_start; u32 wrlvl_ctl_2; u32 wrlvl_ctl_3; - u32 cpo; - u32 write_data_delay; - u32 force_2t; };
/* @@ -28,58 +25,48 @@ struct board_specific_parameters { static const struct board_specific_parameters udimm0[] = { /* * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ - {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, - {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, - {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1800, 2, 5, 6, 0x06070709, 0x110a0b08, 0xff, 2, 0}, - {1, 1866, 2, 4, 6, 0x06060708, 0x09090a07, 0xff, 2, 0}, - {1, 1900, 2, 4, 6, 0x06060708, 0x09090a07, 0xff, 2, 0}, - {1, 2000, 2, 4, 8, 0x090a0b0d, 0x0e0f110b, 0xff, 2, 0}, - {1, 2133, 2, 4, 8, 0x090a0b0d, 0x0e0f110b, 0xff, 2, 0}, + {2, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, + {2, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, + {2, 1600, 2, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, + {2, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, + {2, 1900, 2, 5, 9, 0x0a0b0c0e, 0x0f10120c}, + {2, 2140, 2, 4, 8, 0x090a0b0d, 0x0e0f110b}, + {1, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, + {1, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, + {1, 1600, 2, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, + {1, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, + {1, 1900, 2, 5, 9, 0x0a0b0c0e, 0x0f10120c}, + {1, 2140, 2, 4, 8, 0x090a0b0d, 0x0e0f110b}, {} };
static const struct board_specific_parameters rdimm0[] = { /* * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ - {4, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, - {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906, 0xff, 2, 0}, - {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, - {2, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, - {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, - {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, - {1, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, - {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, - {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, + /* TODO: need tuning these parameters if RDIMM is used */ + {4, 1350, 0, 5, 9, 0x08070605, 0x06070806}, + {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906}, + {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, + {2, 1350, 0, 5, 9, 0x08070605, 0x06070806}, + {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, + {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, + {1, 1350, 0, 5, 9, 0x08070605, 0x06070806}, + {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, + {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07}, {} };
-/* - * The three slots have slightly different timing. The center values are good - * for all slots. We use identical speed tables for them. In future use, if - * DIMMs require separated tables, make more entries as needed. - */ static const struct board_specific_parameters *udimms[] = { udimm0, };
-/* - * The three slots have slightly different timing. See comments above. - */ static const struct board_specific_parameters *rdimms[] = { rdimm0, }; - - #endif
First, please remember to update the version number when you submit an updated patch. Second, please add change log.
Please add information about tested conditions, including DIMM model and speed.
York
Shengzhou Liu
York Sun
