[U-Boot] [PATCH v3] sandbox: fix compiler warning
Add back return statement to fix compiler warning about control flow reaching end of non void function that was introduced with:
e05e5de arm: move C runtime setup code in crt0.S
Signed-off-by: Allen Martin amartin@nvidia.com Acked-by: Simon Glass sjg@chromium.org --- arch/sandbox/cpu/start.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 7603bf9..5287fd5 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -122,4 +122,7 @@ int main(int argc, char *argv[]) * never return. */ board_init_f(0); + + /* NOTREACHED - board_init_f() does not return */ + return 0; }
Hi Allen,
- /* NOTREACHED - board_init_f() does not return */
Shouldn't the function be given '__attribute__((noreturn))' rather than adding a non-executed 'return 0' to it?
Amicalement,
On Tue, Jan 22, 2013 at 10:46:03PM -0800, Albert ARIBAUD wrote:
Hi Allen,
The function in question is sandbox main(), and it can return if there was an error prior to calling board_init_f(). Here's the whole function for context:
int main(int argc, char *argv[]) { struct sandbox_state *state; int err;
err = state_init(); if (err) return err;
state = state_get_current(); if (os_parse_args(state, argc, argv)) return 1;
/* * Do pre- and post-relocation init, then start up U-Boot. This will * never return. */ board_init_f(0);
/* NOTREACHED - board_init_f() does not return */ return 0; }
-Allen
Hi Allen,
int main(int argc, char *argv[]) [...]
Makes sense, thanks.
-Allen
Amicalement,
On Thu, Jan 24, 2013 at 4:45 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Allen,
-Allen
Amicalement,
Albert.
Applied to x86/master.
Albert ARIBAUD
Allen Martin
