[PATCH] gpio: uclass: Introduce gpio-hog-optional property
gpio_hog_probe_all is invoked by init_sequence_r in board_r.c. If device_probe fails for any gpio-hog, boot hangs with the following error:
initcall sequence 00000000fffc8e18 failed at call 000000004023b320 (err=-121) ### ERROR ### Please RESET the board ###
gpio-hog-optional allows the boot sequence to continue if device_probe fails for optional gpio-hog(s).
Signed-off-by: Nate Drude nate.d@variscite.com --- doc/device-tree-bindings/gpio/gpio.txt | 1 + drivers/gpio/gpio-uclass.c | 4 +++- 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/doc/device-tree-bindings/gpio/gpio.txt b/doc/device-tree-bindings/gpio/gpio.txt index 1481ed607d..02d296316b 100644 --- a/doc/device-tree-bindings/gpio/gpio.txt +++ b/doc/device-tree-bindings/gpio/gpio.txt @@ -189,6 +189,7 @@ gpio-controller's driver probe function. Each GPIO hog definition is represented as a child node of the GPIO controller. Required properties: - gpio-hog: A property specifying that this child node represents a GPIO hog. +- gpio-hog-optional: A property specifying to continue boot when device_probe fails in gpio_hog_probe_all - gpios: Store the GPIO information (id, flags, ...) for each GPIO to affect. Shall contain an integer multiple of the number of cells specified in its parent node (GPIO controller node). diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 0ed32b7217..7ef9f4abc8 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -329,7 +329,9 @@ int gpio_hog_probe_all(void) if (ret) { printf("Failed to probe device %s err: %d\n", dev->name, ret); - retval = ret; + if (!dev_read_bool(dev, "gpio-hog-optional")) { + retval = ret; + } } } }
nit below
retval = ret;
retval = ret;
Should not have {} for single-line statements
-- 2.37.3
Hi Nate and Simon,
gpio-hog-optional property does not exist in Linux.
If this property is introduced then U-Boot and Linux devicetrees will not be in sync.
Can this be fixed differently?
On Mon, 12 Sept 2022 at 12:48, Fabio Estevam festevam@gmail.com wrote:
Hi Nate and Simon,
Nate, can you send a patch to Linux with the binding update?
Hi Simon and Fabio,
Hi Nate and Simon,
Thanks for your responses and feedback.
I don't think gpio-hog-optional is relevant to Linux.
The problem is if gpio_hog_probe_all returns an error, board_init_r will hang()
See: - https://github.com/u-boot/u-boot/blob/v2022.07/common/board_r.c#L824-L825 - https://github.com/u-boot/u-boot/blob/v2022.07/common/board_r.c#L763 - https://github.com/u-boot/u-boot/blob/v2022.07/drivers/gpio/gpio-uclass.c#L3...
A practical example of how this may occur is when an i2c gpio expander (e.g. nxp,pca9534) uses gpio-hog, but the gpio expander is depopulated.
Arguably, the best solution is to use a different device tree when the gpio expander is not populated. This patch allows the gpio-hog to fail gracefully and continue booting if gpio-hog-optional is used.
Do you have any suggestions for a better approach? Does it make sense for gpio_hog_probe_all to cause a fatal error when the gpio hog probe fails (most devices, including the gpio-expander, will not cause a hang if they fail to probe)?
Regards, Nate
Hi Nate,
On Mon, 12 Sept 2022 at 14:57, Nate Drude nate.d@variscite.com wrote:
Hi Simon and Fabio,
Hi Nate and Simon,
Sure, but Linux is (for better or worse) the main repo for the device tree bindings.
See:
I think your approach is fine as is.
Hi Simon,
On 9/14/22 7:49 AM, Simon Glass wrote:
Hi Nate,
Hi Simon and Fabio,
Hi Nate and Simon,
I am not understanding the action. I think you're suggesting I update the Linux device tree bindings so they stay aligned with U-Boot, adding a property gpio-hog-optional after this line: https://github.com/torvalds/linux/blob/v6.0-rc5/Documentation/devicetree/bin...
However, since it's not relevant to Linux, I think it will be confusing since it will have no effect and won't be be used in any Linux code.
Can you please advise what description I should use for the gpio-hog-optional property so that the Linux maintainers would accept such a patch?
See:
- https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com...
An alternate approach is to modify the default behavior so that gpio_hog_probe_all will not trigger a fatal error. Do you think this is better?
Thanks, Nate
Hi Nate,
IMHO that would be better, as we could keep using the same devicetree files from Linux.
Thanks
On Wed, Sep 14, 2022 at 08:59:52AM -0500, Nate Drude wrote:
Hi Simon,
Hi Nate,
Hi Simon and Fabio,
Hi Nate and Simon,
> initcall sequence 00000000fffc8e18 failed at call 000000004023b320 (err=-121) > ### ERROR ### Please RESET the board ###
Yes, that would be one way to go about this, and there are other non-Linux bindings in the Linux kernel tree, but this might be the first property of an existing binding, so that might also be a bit challenging to get accepted, or find out what the preferred solution is.
[snip]
This too would be acceptable.
Hi All,
Hi Simon,
Hi Nate,
Hi Simon and Fabio,
Hi Nate and Simon,
On Mon, Sep 12, 2022 at 2:55 PM Nate Drude nate.d@variscite.com wrote: > > gpio_hog_probe_all is invoked by init_sequence_r in board_r.c. > If device_probe fails for any gpio-hog, boot hangs with the following error: > >> initcall sequence 00000000fffc8e18 failed at call 000000004023b320 (err=-121) >> ### ERROR ### Please RESET the board ### > > gpio-hog-optional allows the boot sequence to continue if device_probe > fails for optional gpio-hog(s). > > Signed-off-by: Nate Drude nate.d@variscite.com > --- > doc/device-tree-bindings/gpio/gpio.txt | 1 + > drivers/gpio/gpio-uclass.c | 4 +++- > 2 files changed, 4 insertions(+), 1 deletion(-) > > diff --git a/doc/device-tree-bindings/gpio/gpio.txt b/doc/device-tree-bindings/gpio/gpio.txt > index 1481ed607d..02d296316b 100644 > --- a/doc/device-tree-bindings/gpio/gpio.txt > +++ b/doc/device-tree-bindings/gpio/gpio.txt > @@ -189,6 +189,7 @@ gpio-controller's driver probe function. > Each GPIO hog definition is represented as a child node of the GPIO controller. > Required properties: > - gpio-hog: A property specifying that this child node represents a GPIO hog. > +- gpio-hog-optional: A property specifying to continue boot when device_probe fails in gpio_hog_probe_all
[snip]
Thanks for the discussion and feedback. I prefer to avoid changing the bindings in Linux if possible.
Would it be acceptable if I rework gpio_hog_probe_all so that it prints an error "Failed to probe device..." if any device_probe fails, but always returns 0 to avoid a fatal error in board_init_r? I can submit a v2 patch, but I want to screen any problems with the approach first.
Thanks, Nate
On Wed, 14 Sept 2022 at 08:31, Nate Drude nate.d@variscite.com wrote:
Hi All,
Hi Simon,
Hi Nate,
Hi Simon and Fabio,
On Mon, 12 Sept 2022 at 12:48, Fabio Estevam festevam@gmail.com wrote: > > Hi Nate and Simon, > > On Mon, Sep 12, 2022 at 2:55 PM Nate Drude nate.d@variscite.com wrote: >> >> gpio_hog_probe_all is invoked by init_sequence_r in board_r.c. >> If device_probe fails for any gpio-hog, boot hangs with the following error: >> >>> initcall sequence 00000000fffc8e18 failed at call 000000004023b320 (err=-121) >>> ### ERROR ### Please RESET the board ### >> >> gpio-hog-optional allows the boot sequence to continue if device_probe >> fails for optional gpio-hog(s). >> >> Signed-off-by: Nate Drude nate.d@variscite.com >> --- >> doc/device-tree-bindings/gpio/gpio.txt | 1 + >> drivers/gpio/gpio-uclass.c | 4 +++- >> 2 files changed, 4 insertions(+), 1 deletion(-) >> >> diff --git a/doc/device-tree-bindings/gpio/gpio.txt b/doc/device-tree-bindings/gpio/gpio.txt >> index 1481ed607d..02d296316b 100644 >> --- a/doc/device-tree-bindings/gpio/gpio.txt >> +++ b/doc/device-tree-bindings/gpio/gpio.txt >> @@ -189,6 +189,7 @@ gpio-controller's driver probe function. >> Each GPIO hog definition is represented as a child node of the GPIO controller. >> Required properties: >> - gpio-hog: A property specifying that this child node represents a GPIO hog. >> +- gpio-hog-optional: A property specifying to continue boot when device_probe fails in gpio_hog_probe_all > > gpio-hog-optional property does not exist in Linux. > > If this property is introduced then U-Boot and Linux devicetrees will > not be in sync. > > Can this be fixed differently?
You can mention why it is needed and use a u-boot, property-name prefix perhaps.
[snip]
I don't like this as it introduces undefined behaviour and may cause the boot to fail with no indication of what has happened, nor any way for higher-level code to resolve the issue.
Anything we do here should be deterministic. Failures should be ignored only when the board vendor wants that.
How would this be controlled? One option might be to add a binding to the /options node. I don't like it, but it could be a fallback if you get push-back on this binding.
Hi Nate,
Does the patch from Marek help? https://patchwork.ozlabs.org/project/uboot/patch/20220919194502.106252-1-mar...
Fabio Estevam
Nate Drude
