[U-Boot] [PATCH] arm: socfpga: stratix10: add sgmii in phymode setup
Additional sgmii phymode is added in socfpga_phymode_setup() along with a minor fix for maximum number of GMACs.
Signed-off-by: Ooi, Joyce joyce.ooi@intel.com --- arch/arm/mach-socfpga/misc_s10.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c index 918baac..e599362 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -36,7 +36,8 @@ static u32 socfpga_phymode_setup(u32 gmac_index, const char *phymode) if (!phymode) return -EINVAL;
- if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii")) + if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii") || + !strcmp(phymode, "sgmii")) modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; else if (!strcmp(phymode, "rgmii")) modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; @@ -58,7 +59,7 @@ static int socfpga_set_phymode(void) struct fdtdec_phandle_args args; const char *phy_mode; u32 gmac_index; - int nodes[2]; /* Max. 3 GMACs */ + int nodes[3]; /* Max. 3 GMACs */ int ret, count; int i, node;
CCing Ley and Dinh.
Applied, thanks.
- if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii") ||
modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; else if (!strcmp(phymode, "rgmii")) modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII;!strcmp(phymode, "sgmii"))
- int nodes[3]; /* Max. 3 GMACs */ int ret, count; int i, node;
Ooi, Joyce
