[U-Boot] Pull request: u-boot-arm/master
Hi Tom,
The following changes since commit 785881f775252940185e10fbb2d5299c9ffa6bce:
env: Add redundant env support to UBI env (2013-04-11 15:52:55 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 8960af8ba9488fc54e2e4733cbada26d3cece225:
cosmetic: fix CONFIG_SPL_BSS_MAX_SIZE typo in README (2013-04-14 17:04:43 +0200)
---------------------------------------------------------------- Abbas Raza (1): mmc: i.MX6: fsl_esdhc: Define maximum bus width supported by a board
Ajay Kumar (13): video: exynos_fb: Remove callbacks from the driver video: exynos_dp: Remove callbacks from the driver video: exynos_fb: Make fimd_ctrl global EXYNOS: FDT: Add compatible strings for FIMD video: exynos_fb: add DT support for FIMD driver EXYNOS5: Add device node for FIMD SMDK5250: Add device node for FIMD video: exynos_dp: Make dp_regs global EXYNOS5: FDT: Add compatible strings for FIMD video: exynos_dp: Add function to parse DP DT node EXYNOS5: Add device node for DP SMDK5250: Add device node for DP SMDK5250: Use statically defined structures only in non DT case
Akshay Saraswat (8): Exynos: clock: Fix a bug in PLL lock check condition Exynos: Add hardware accelerated SHA256 and SHA1 Exynos: config: Enable ACE HW for SHA 256 for Exynos gen: Add sha h/w acceleration to hash Exynos: config: Enable hash command Exynos5: clock: Fix a typo bug in exynos clock init Exynos5: config: enable time command Exynos: pwm: Remove dead code of function exynos5_get_pwm_clk
Albert ARIBAUD (13): Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master' Merge branch 'u-boot-ti/master' into 'u-boot-arm/master' Merge branch 'u-boot/master' into 'u-boot-arm/master' Merge branch 'u-boot-ti/master' into 'u-boot-arm/master' ARM: Fix __bss_start and __bss_end in linker scripts Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' ARM: fix CONFIG_SPL_MAX_SIZE semantics cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINT da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINT smdk5250, snow: convert to CONFIG_SPL_MAX_FOOTPRINT cosmetic: fix CONFIG_SPL_BSS_MAX_SIZE typo in README
Alexandre Pereira da Silva (1): mx23_olinuxino: Fix netboot console
Andreas Bießmann (6): omap3/cpu.h: add BCH support asm/omap_gpmc.h: consolidate common defines omap3/omap_gpmc.h: add ooblayout for BCH8 as in kernel omap_gpmc: change nandecc command omap_gpmc: add support for hw assisted BCH8 tricorder: enable hw assisted BCH8 in SPL and u-boot
Andrew Gabbasov (1): fsl_esdhc: Fix DMA transfer completion waiting loop
Benoît Thébaudeau (29): mx25pdk: Enable imxdi RTC nand: mxc: Prepare to add support for i.MX5 nand: mxc: Add support for i.MX5 imx: mx5: lowlevel_init: Simplify code imx: mx53ard: Add support for NAND Flash nand: mxc: Fix debug trace in mxc_nand_read_oob_syndrome() nand: mxc: Use appropriate page number in syndrome functions arm: start.S: Fix _TEXT_BASE for SPL arm: relocate_code() is no longer noreturn arm1136: Remove redundant relocate_code() return arm: relocate_code(): Remove useless relocation offset computation arm: relocate_code(): Use __image_copy_end for end of relocation arm: crt0.S: Remove bogus .globl autoconfig.mk: Make it possible to define configs from other configs Makefile: Change CONFIG_SPL_PAD_TO to image offset imx: Fix automatic make targets for imx images nand: mxc: Switch NAND SPL to generic SPL arm926ejs: Remove deprecated and now unused NAND SPL arm: Remove unused relocate_code() parameters Makefile: Move SHELL setup to config.mk .gitignore: Add /SPL imx: Add u-boot-with-spl.imx make target imx: Add u-boot-with-nand-spl.imx make target arm: Remove support for smdk6400 Revert "mkconfig: start deprecating Makefile config targets" arm: Remove support for unused s3c64xx arm: Remove deprecated and now unused NAND SPL arm1176: Remove unused MMU setup from start.S arm: Make all linker scripts compatible with per-symbol sections
Bin Liu (2): musb: am335x: disable bulk split-combine feature musb: set MUSB speed based on CONFIG
Che-Liang Chiou (1): Exynos: Add timer_get_us function
Dirk Behme (1): spi: mxc_spi: Fix ECSPI reset handling
Eric Nelson (3): i.MX6: Add hdmidet command to detect attached HDMI monitor i.MX6: mx6qsabrelite: discard override of CONFIG_ARP_TIMEOUT fsl_esdhc: flush cache after IO completion
Fabio Estevam (14): mxs: spl_mem_init: Align DDR2 init with FSL bootlets source configs: mx28evk: Use single-line comments mx28evk: Disable CONFIG_CMD_I2C Add initial support for Wandboard dual lite and solo. mx28evk: Introduce a new target for saving env vars to NAND mx6qsabrelite: README: No need to pass 'u-boot.imx' mx6: Fix get_board_rev() for the mx6 solo case wandboard: Remove duplicate 'mmc dev' mx6qsabrelite: Remove duplicate 'mmc dev' wandboard: Remove CONFIG_SYS_FSL_USDHC_NUM mtd: nand: Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT mtd: nand: mxc_nand: Fix is_16bit_nand() mx31pdk: Remove watchdog support spi: mxc_spi: Set master mode for all channels
Gabe Black (3): Exynos: pwm: Fix two bugs in the exynos pwm configuration code Exynos: Avoid a divide by zero by specifying a non-zero period for pwm 4 Exynos: Tidy up the pwm_config function in the exynos pwm driver
Gerlando Falauto (1): kirkwood_nand: allow usage of NAND_ECC_SOFT_BCH
Holger Brunck (3): arm/km: rename BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT arm/km: use CONFIG_NAND_ECC_BCH arm/km: add support for kmsuv31 board
Hunter, Jon (4): omap2420-h4: Fix DRAM initialisation omap2420-h4: Fix booting from NOR flash omap2420-h4: Add device tree support omap2420-h4: Fix get_timer() and CONFIG_SYS_HZ
Javier Martinez Canillas (1): i.MX6: mx6qsabrelite: README: don't pass chip-select to sf probe command
Jon Hunter (5): omap5912-osk: Fix DRAM initialisation omap5912-osk: Fix booting from NOR flash omap5912-osk: Fix device initialisation omap5912-osk: Increase flash partition for u-boot omap5912-osk: Fix get_timer() and CONFIG_SYS_HZ
Josh Wu (1): logo: update to the new logo for ATMEL
Knut Wohlrab (1): imx-common: timer: fix 32-bit overflow
Lars Poeschel (1): pcm051: Enable DDR PHY dynamic power down bit
Linus Walleij (1): integrator: enable device tree
Lokesh Vutla (1): arm: omap4: Fix SDRAM AUTO DETECTION
Lubomir Popov (2): OMAP: Fix copy-paste bug that did not enable UART4 clock OMAP4: Fix bug in omap4460_volts struct
Manfred Huber (1): omap3_beagle: Flush UART3 xmit on enable if TEMT is broken
Minkyu Kang (1): exynos: change indentation of defines in cpu.h
Nishanth Menon (1): omap5: Allow use of a plain text env file
Otavio Salvador (5): mx6qsabresd: Document the mapping of USDHC[2-4] mx6qsabresd: Fix card detection for invalid card id case mx6qsabre{sd,auto}: Add boot mode select mx23_olinuxino: Change definitions to use spaces instead of tabs mx6qsabre{sd, auto}: Fix environment as 'mmc rescan' takes no arguments
Padmavathi Venna (4): Exynos: Add peripherial id for pwm Exynos: clock: Add generic api to get the clk freq Exynos: clock: Correct pwm source clk selection Exynos: pwm: Use generic api to get pwm clk freq
Przemyslaw Marczak (1): spl:falcon:trats: Fix SPL image size computing.
Rajeshwari Shinde (1): EXYNOS5: Add L2 Cache Support.
SRICHARAN R (4): ARM: OMAP5: Rename omap5_evm to omap5_uevm ARM: OMAP5: Set fdt_high to enable booting with Device tree ARM: OMAP4/5: Change the default boot command to work with device tree ARM: OMAP4/5: Make bootz as the default boot command
Simon Glass (1): Exynos: Change get_timer() to work correctly
Stephen Warren (1): ARM: bcm2835: fix get_timer() to return ms
Tetsuyuki Kobayashi (1): BUGFIX: arm: data abort in get_bad_stack_swi
Tom Rini (11): am335x: Enable MMC1 clock doc/feature-removal-schedule.txt: Add CONFIG_SYS_(CLOCKS|PADS)_ENABLE_ALL OMAP3/4/5/AM33xx: Correct logic for checking FAT or RAW MMC omap5_uevm.h: Move uEVM-specific choices to omap5_uevm.h omap5_common.h: Use fallback CONFIG_SYS_BAUDRATE_TABLE am335x/ti814x: Correct MMC_BOOT_DEVICES_START/END am335x: Update timings for the beaglebone again omap5_uevm: Correct to 2MiB aligned partitions on eMMC am335x: Really correct DDR timings on new BeagleBone part omap5_common.h: Switch to ext4 VCMA9: Enable CONFIG_CMD_NAND_YAFFS
Vivek Gautam (2): SMDK5250: Fix compiler warning for non-dt systems spi: exynos: Fix compiler warnings for non-dt systems
man.huber@arcor.de (1): omap3: Display MHz instead of mHz on the console
.gitignore | 3 + MAINTAINERS | 5 +- Makefile | 40 ++---- README | 43 ++++-- arch/arm/config.mk | 2 - arch/arm/cpu/arm1136/config.mk | 7 + arch/arm/cpu/arm1136/omap24xx/timer.c | 8 +- arch/arm/cpu/arm1136/start.S | 31 ++-- arch/arm/cpu/arm1136/u-boot-spl.lds | 2 +- arch/arm/cpu/arm1176/bcm2835/timer.c | 14 +- arch/arm/cpu/arm1176/s3c64xx/config.mk | 34 ----- arch/arm/cpu/arm1176/s3c64xx/cpu_init.S | 135 ----------------- arch/arm/cpu/arm1176/s3c64xx/init.c | 26 ---- arch/arm/cpu/arm1176/s3c64xx/reset.S | 34 ----- arch/arm/cpu/arm1176/s3c64xx/speed.c | 145 ------------------- arch/arm/cpu/arm1176/s3c64xx/timer.c | 160 --------------------- arch/arm/cpu/arm1176/start.S | 131 +++-------------- arch/arm/cpu/arm720t/start.S | 26 ++-- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 13 +- arch/arm/cpu/arm920t/start.S | 28 ++-- arch/arm/cpu/arm925t/start.S | 28 ++-- arch/arm/cpu/arm926ejs/config.mk | 8 +- arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 18 +-- arch/arm/cpu/arm926ejs/mxs/start.S | 4 + arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds | 6 +- arch/arm/cpu/arm926ejs/omap/timer.c | 15 +- arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 6 +- arch/arm/cpu/arm926ejs/start.S | 40 ++---- arch/arm/cpu/arm946es/start.S | 28 ++-- arch/arm/cpu/arm_intcm/start.S | 30 ++-- arch/arm/cpu/armv7/am33xx/clock_am33xx.c | 5 + arch/arm/cpu/armv7/am33xx/elm.c | 2 +- arch/arm/cpu/armv7/config.mk | 6 + arch/arm/cpu/armv7/exynos/clock.c | 167 ++++++++++++++++++--- arch/arm/cpu/armv7/exynos/soc.c | 36 +++++ arch/arm/cpu/armv7/mx5/lowlevel_init.S | 8 +- arch/arm/cpu/armv7/mx6/soc.c | 12 ++ arch/arm/cpu/armv7/omap-common/clocks-common.c | 4 +- arch/arm/cpu/armv7/omap-common/emif-common.c | 29 ++-- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 10 +- arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 2 +- arch/arm/cpu/armv7/omap3/board.c | 31 ++-- arch/arm/cpu/armv7/omap3/sys_info.c | 4 +- arch/arm/cpu/armv7/omap4/emif.c | 1 - arch/arm/cpu/armv7/omap4/hw_data.c | 8 +- arch/arm/cpu/armv7/omap5/emif.c | 1 - arch/arm/cpu/armv7/s5p-common/pwm.c | 42 +++--- arch/arm/cpu/armv7/s5p-common/timer.c | 117 +++++++-------- arch/arm/cpu/armv7/socfpga/u-boot-spl.lds | 2 +- arch/arm/cpu/armv7/start.S | 29 ++-- arch/arm/cpu/ixp/start.S | 28 ++-- arch/arm/cpu/ixp/u-boot.lds | 16 ++- arch/arm/cpu/pxa/start.S | 29 ++-- arch/arm/cpu/s3c44b0/start.S | 28 ++-- arch/arm/cpu/sa1100/start.S | 28 ++-- arch/arm/cpu/u-boot-spl.lds | 24 ++-- arch/arm/cpu/u-boot.lds | 18 +-- arch/arm/dts/exynos5250.dtsi | 13 ++ arch/arm/imx-common/Makefile | 18 +++ drivers/usb/host/s3c64xx-hcd.c => arch/arm/imx-common/cmd_hdmidet.c | 32 ++--- arch/arm/imx-common/timer.c | 26 +--- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 22 +-- arch/arm/include/asm/arch-am33xx/omap_gpmc.h | 58 +------- arch/arm/include/asm/arch-am33xx/spl.h | 8 ++ arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 +- arch/arm/include/asm/arch-bcm2835/timer.h | 2 + arch/arm/include/asm/arch-exynos/clk.h | 15 ++ arch/arm/include/asm/arch-exynos/cpu.h | 10 +- arch/arm/include/asm/arch-exynos/dp_info.h | 1 - arch/arm/include/asm/arch-exynos/periph.h | 5 + arch/arm/include/asm/arch-mx5/imx-regs.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 1 + arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 3 + arch/arm/include/asm/arch-omap24xx/omap2420.h | 6 +- arch/arm/include/asm/arch-omap3/cpu.h | 6 + arch/arm/include/asm/arch-omap3/omap_gpmc.h | 68 ++------- arch/arm/include/asm/arch-omap3/spl.h | 3 + arch/arm/include/asm/arch-omap3/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap4/omap.h | 1 - arch/arm/include/asm/arch-omap4/spl.h | 2 + arch/arm/include/asm/arch-omap5/omap.h | 1 - arch/arm/include/asm/arch-omap5/spl.h | 2 + arch/arm/include/asm/arch-s3c64xx/hardware.h | 63 -------- arch/arm/include/asm/arch-s3c64xx/s3c6400.h | 895 ----------------------------------------------------------------------------------------------------------------- arch/arm/include/asm/arch-s3c64xx/s3c64x0.h | 90 ------------ arch/arm/include/asm/emif.h | 1 - arch/arm/include/asm/mach-types.h | 13 -- arch/arm/include/asm/omap_gpmc.h | 87 +++++++++++ arch/arm/lib/crt0.S | 52 ++----- board/actux1/u-boot.lds | 17 ++- board/actux2/u-boot.lds | 17 ++- board/actux3/u-boot.lds | 17 ++- board/ait/cam_enc_4xx/u-boot-spl.lds | 4 +- board/boundary/nitrogen6x/nitrogen6x.c | 8 +- board/davinci/da8xxevm/u-boot-spl-da850evm.lds | 4 +- board/davinci/da8xxevm/u-boot-spl-hawk.lds | 9 +- board/dvlhost/u-boot.lds | 17 ++- board/freescale/mx31ads/u-boot.lds | 32 +++-- board/freescale/mx31pdk/Makefile | 3 + board/freescale/mx31pdk/config.mk | 5 - board/freescale/mx31pdk/mx31pdk.c | 8 ++ board/freescale/mx53ard/mx53ard.c | 66 +++++++++ board/freescale/mx6qsabreauto/mx6qsabreauto.c | 18 +++ board/freescale/mx6qsabrelite/README | 4 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 8 +- board/freescale/mx6qsabresd/mx6qsabresd.c | 48 +++++-- board/isee/igep00x0/igep00x0.c | 2 +- board/karo/tx25/Makefile | 4 +- board/karo/tx25/config.mk | 5 - board/karo/tx25/tx25.c | 8 ++ board/overo/overo.c | 2 +- board/phytec/pcm051/board.c | 3 +- board/samsung/dts/exynos5250-smdk5250.dts | 40 ++++++ board/samsung/smdk5250/clock_init.c | 22 +-- board/samsung/smdk5250/setup.h | 2 +- board/samsung/smdk5250/smdk5250-uboot-spl.lds | 4 +- board/samsung/smdk5250/smdk5250.c | 19 ++- board/samsung/smdk6400/.gitignore | 5 - board/samsung/smdk6400/Makefile | 48 ------- board/samsung/smdk6400/config.mk | 30 ---- board/samsung/smdk6400/lowlevel_init.S | 323 ----------------------------------------- board/samsung/smdk6400/smdk6400.c | 134 ----------------- board/samsung/smdk6400/smdk6400_nand_spl.c | 37 ----- board/samsung/smdk6400/u-boot-nand.lds | 86 ----------- board/samsung/trats/trats.c | 6 +- board/samsung/universal_c210/universal.c | 23 +-- board/ti/am335x/board.c | 2 +- board/ti/omap2420h4/config.mk | 4 +- board/ti/omap2420h4/mem.c | 13 -- board/ti/omap2420h4/omap2420h4.c | 24 +++- board/ti/omap5912osk/config.mk | 12 +- board/ti/omap5912osk/lowlevel_init.S | 20 +++ board/ti/omap5912osk/omap5912osk.c | 23 ++- board/ti/{omap5_evm => omap5_uevm}/Makefile | 0 board/ti/{omap5_evm => omap5_uevm}/evm.c | 0 board/ti/{omap5_evm => omap5_uevm}/mux_data.h | 0 board/vpac270/u-boot-spl.lds | 6 +- board/wandboard/Makefile | 29 ++++ board/wandboard/README | 40 ++++++ board/wandboard/wandboard.c | 178 +++++++++++++++++++++++ boards.cfg | 10 +- common/hash.c | 18 +++ config.mk | 7 + doc/README.arm-relocation | 14 +- doc/README.mx28evk | 18 +++ doc/README.omap3 | 28 ++++ doc/README.scrapyard | 1 + doc/device-tree-bindings/video/exynos-dp.txt | 69 +++++++++ doc/device-tree-bindings/video/exynos-fb.txt | 92 ++++++++++++ doc/driver-model/UDM-serial.txt | 42 +++--- doc/feature-removal-schedule.txt | 32 ++--- {arch/arm/cpu/arm1176/s3c64xx => drivers/crypto}/Makefile | 27 ++-- drivers/crypto/ace_sha.c | 126 ++++++++++++++++ drivers/crypto/ace_sha.h | 325 +++++++++++++++++++++++++++++++++++++++++ drivers/mmc/bcm2835_sdhci.c | 5 +- drivers/mmc/fsl_esdhc.c | 15 +- drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/kirkwood_nand.c | 4 + drivers/mtd/nand/mxc_nand.c | 260 ++++++++++++++++++++------------- drivers/mtd/nand/mxc_nand.h | 225 +++++++++++++++++++++++++++++ nand_spl/nand_boot_fsl_nfc.c => drivers/mtd/nand/mxc_nand_spl.c | 130 ++++++++++++----- drivers/mtd/nand/ndfc.c | 4 +- drivers/mtd/nand/omap_gpmc.c | 424 +++++++++++++++++++++++++++++++++++++++--------------- drivers/mtd/nand/s3c64xx.c | 295 ------------------------------------- drivers/mtd/onenand/onenand_base.c | 4 - drivers/mtd/onenand/samsung.c | 60 +------- drivers/serial/Makefile | 1 - drivers/serial/ns16550.c | 18 ++- drivers/serial/s3c64xx.c | 187 ------------------------ drivers/serial/serial.c | 2 - drivers/spi/exynos_spi.c | 2 + drivers/spi/mxc_spi.c | 17 +-- drivers/usb/host/Makefile | 1 - drivers/usb/host/ohci-hcd.c | 1 - drivers/usb/musb-new/musb_core.c | 7 + drivers/usb/musb-new/musb_uboot.c | 2 +- drivers/video/exynos_dp.c | 76 +++++++++- drivers/video/exynos_dp_lowlevel.c | 69 ++++----- drivers/video/exynos_dp_lowlevel.h | 1 + drivers/video/exynos_fb.c | 228 ++++++++++++++++++++++++++--- drivers/video/exynos_fimd.c | 44 +++--- include/common.h | 7 +- include/config_fallbacks.h | 16 +++ include/configs/MPC8313ERDB.h | 2 +- include/configs/VCMA9.h | 1 + include/configs/am335x_evm.h | 1 + include/configs/cam_enc_4xx.h | 2 +- include/configs/da850evm.h | 2 +- include/configs/dra7xx_evm.h | 2 + include/configs/exynos5250-dt.h | 10 +- include/configs/igep00x0.h | 3 - include/configs/integrator-common.h | 1 + include/configs/km/km_arm.h | 5 +- include/configs/km_kirkwood.h | 8 ++ include/configs/mx23_olinuxino.h | 162 ++++++++++----------- include/configs/mx25pdk.h | 4 + include/configs/mx28evk.h | 92 ++++++------ include/configs/mx31pdk.h | 23 +-- include/configs/mx53ard.h | 10 ++ include/configs/mx6qsabre_common.h | 4 +- include/configs/mx6qsabrelite.h | 3 - include/configs/omap2420h4.h | 5 +- include/configs/omap4_common.h | 22 ++- include/configs/omap5912osk.h | 15 +- include/configs/omap5_common.h | 53 ++++--- include/configs/{omap5_evm.h => omap5_uevm.h} | 17 +++ include/configs/p1_p2_rdb_pc.h | 2 +- include/configs/rpi_b.h | 2 +- include/configs/smdk6400.h | 296 -------------------------------------- include/configs/tegra-common.h | 2 +- include/configs/trats.h | 1 + include/configs/tricorder.h | 13 +- include/configs/tx25.h | 22 +-- include/configs/wandboard.h | 209 +++++++++++++++++++++++++++ include/fdtdec.h | 2 + include/fsl_esdhc.h | 5 +- include/fsl_nfc.h | 170 ---------------------- include/hw_sha.h | 50 +++++++ include/lcd.h | 9 -- include/onenand_uboot.h | 4 - lib/Makefile | 2 +- lib/fdtdec.c | 2 + mkconfig | 9 -- nand_spl/board/freescale/mx31pdk/Makefile | 63 -------- nand_spl/board/freescale/mx31pdk/u-boot.lds | 87 ----------- nand_spl/board/karo/tx25/Makefile | 84 ----------- nand_spl/board/karo/tx25/config.mk | 1 - nand_spl/board/karo/tx25/u-boot.lds | 85 ----------- nand_spl/board/samsung/smdk6400/Makefile | 117 --------------- nand_spl/board/samsung/smdk6400/config.mk | 40 ------ nand_spl/board/samsung/smdk6400/u-boot.lds | 80 ----------- tools/logos/atmel.bmp | Bin 26334 -> 15478 bytes tools/scripts/define2mk.sed | 2 + 233 files changed, 4058 insertions(+), 5369 deletions(-) delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/config.mk delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/cpu_init.S delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/init.c delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/reset.S delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/speed.c delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/timer.c rename drivers/usb/host/s3c64xx-hcd.c => arch/arm/imx-common/cmd_hdmidet.c (65%) delete mode 100644 arch/arm/include/asm/arch-s3c64xx/hardware.h delete mode 100644 arch/arm/include/asm/arch-s3c64xx/s3c6400.h delete mode 100644 arch/arm/include/asm/arch-s3c64xx/s3c64x0.h create mode 100644 arch/arm/include/asm/omap_gpmc.h delete mode 100644 board/freescale/mx31pdk/config.mk delete mode 100644 board/karo/tx25/config.mk delete mode 100644 board/samsung/smdk6400/.gitignore delete mode 100644 board/samsung/smdk6400/Makefile delete mode 100644 board/samsung/smdk6400/config.mk delete mode 100644 board/samsung/smdk6400/lowlevel_init.S delete mode 100644 board/samsung/smdk6400/smdk6400.c delete mode 100644 board/samsung/smdk6400/smdk6400_nand_spl.c delete mode 100644 board/samsung/smdk6400/u-boot-nand.lds rename board/ti/{omap5_evm => omap5_uevm}/Makefile (100%) rename board/ti/{omap5_evm => omap5_uevm}/evm.c (100%) rename board/ti/{omap5_evm => omap5_uevm}/mux_data.h (100%) create mode 100644 board/wandboard/Makefile create mode 100644 board/wandboard/README create mode 100644 board/wandboard/wandboard.c create mode 100644 doc/device-tree-bindings/video/exynos-dp.txt create mode 100644 doc/device-tree-bindings/video/exynos-fb.txt rename {arch/arm/cpu/arm1176/s3c64xx => drivers/crypto}/Makefile (69%) create mode 100644 drivers/crypto/ace_sha.c create mode 100644 drivers/crypto/ace_sha.h create mode 100644 drivers/mtd/nand/mxc_nand.h rename nand_spl/nand_boot_fsl_nfc.c => drivers/mtd/nand/mxc_nand_spl.c (65%) delete mode 100644 drivers/mtd/nand/s3c64xx.c delete mode 100644 drivers/serial/s3c64xx.c rename include/configs/{omap5_evm.h => omap5_uevm.h} (71%) delete mode 100644 include/configs/smdk6400.h create mode 100644 include/configs/wandboard.h delete mode 100644 include/fsl_nfc.h create mode 100644 include/hw_sha.h delete mode 100644 nand_spl/board/freescale/mx31pdk/Makefile delete mode 100644 nand_spl/board/freescale/mx31pdk/u-boot.lds delete mode 100644 nand_spl/board/karo/tx25/Makefile delete mode 100644 nand_spl/board/karo/tx25/config.mk delete mode 100644 nand_spl/board/karo/tx25/u-boot.lds delete mode 100644 nand_spl/board/samsung/smdk6400/Makefile delete mode 100644 nand_spl/board/samsung/smdk6400/config.mk delete mode 100644 nand_spl/board/samsung/smdk6400/u-boot.lds
Amicalement,
On Sun, Apr 14, 2013 at 09:32:04PM +0200, Albert ARIBAUD wrote:
Hi Tom,
Andreas Bie??mann (6): omap3/cpu.h: add BCH support asm/omap_gpmc.h: consolidate common defines omap3/omap_gpmc.h: add ooblayout for BCH8 as in kernel omap_gpmc: change nandecc command omap_gpmc: add support for hw assisted BCH8 tricorder: enable hw assisted BCH8 in SPL and u-boot
Beno??t Th??baudeau (29): mx25pdk: Enable imxdi RTC nand: mxc: Prepare to add support for i.MX5 nand: mxc: Add support for i.MX5 imx: mx5: lowlevel_init: Simplify code imx: mx53ard: Add support for NAND Flash nand: mxc: Fix debug trace in mxc_nand_read_oob_syndrome() nand: mxc: Use appropriate page number in syndrome functions arm: start.S: Fix _TEXT_BASE for SPL arm: relocate_code() is no longer noreturn arm1136: Remove redundant relocate_code() return arm: relocate_code(): Remove useless relocation offset computation arm: relocate_code(): Use __image_copy_end for end of relocation arm: crt0.S: Remove bogus .globl autoconfig.mk: Make it possible to define configs from other configs Makefile: Change CONFIG_SPL_PAD_TO to image offset imx: Fix automatic make targets for imx images nand: mxc: Switch NAND SPL to generic SPL arm926ejs: Remove deprecated and now unused NAND SPL arm: Remove unused relocate_code() parameters Makefile: Move SHELL setup to config.mk .gitignore: Add /SPL imx: Add u-boot-with-spl.imx make target imx: Add u-boot-with-nand-spl.imx make target arm: Remove support for smdk6400 Revert "mkconfig: start deprecating Makefile config targets" arm: Remove support for unused s3c64xx arm: Remove deprecated and now unused NAND SPL arm1176: Remove unused MMU setup from start.S arm: Make all linker scripts compatible with per-symbol sections
Albert ARIBAUD
