[U-Boot] [PATCH 3/4] x86: Support platform PIRQ routing
On x86 boards, platform chipset receives up to four different interrupt signals from PCI devices (INTA/B/C/D), which in turn will be routed to chipset internal PIRQ lines then routed to 8259 PIC finally if configuring the whole system to work under the so-called PIC mode (in contrast to symmetric IO mode which uses IOAPIC).
We add two major APIs to aid this, one for routing PIRQ and the other one for generating a PIRQ routing table.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/Kconfig | 31 ++++++++ arch/x86/include/asm/pirq_routing.h | 139 ++++++++++++++++++++++++++++++++++++ arch/x86/lib/Makefile | 1 + arch/x86/lib/pirq_routing.c | 129 +++++++++++++++++++++++++++++++++ 4 files changed, 300 insertions(+) create mode 100644 arch/x86/include/asm/pirq_routing.h create mode 100644 arch/x86/lib/pirq_routing.c
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 3f1401a..aaceaef 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -442,6 +442,37 @@ config TSC_FREQ_IN_MHZ help The running frequency in MHz of Time-Stamp Counter (TSC).
+menu "System tables" + +config GENERATE_PIRQ_TABLE + bool "Generate a PIRQ table" + default n + help + Generate a PIRQ routing table for this board. The PIRQ routing table + is generated by U-Boot in the system memory from 0xf0000 to 0xfffff + at every 16-byte boundary with a PCI IRQ routing signature ("$PIR"). + It specifies the interrupt router information as well how all the PCI + devices' interrupt pins are wired to PIRQs. + +endmenu + +config MAX_PIRQ_LINKS + int + default 8 + help + This variable specifies the number of PIRQ interrupt links which are + routable. On most older chipsets, this is 4, PIRQA through PIRQD. + Some newer chipsets offer more than four links, commonly up to PIRQH. + +config IRQ_SLOT_COUNT + int + default 128 + help + U-Boot can support up to 254 IRQ slot info in the PIRQ routing table + which in turns forms a table of exact 4KiB. The default value 128 + should be enough for most boards. If this does not fit your board, + change it according to your needs. + source "board/coreboot/coreboot/Kconfig"
source "board/google/chromebook_link/Kconfig" diff --git a/arch/x86/include/asm/pirq_routing.h b/arch/x86/include/asm/pirq_routing.h new file mode 100644 index 0000000..ddc08e1 --- /dev/null +++ b/arch/x86/include/asm/pirq_routing.h @@ -0,0 +1,139 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * Ported from coreboot src/arch/x86/include/arch/pirq_routing.h + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PIRQ_ROUTING_H_ +#define _PIRQ_ROUTING_H_ + +/* + * This is the maximum number on interrupt entries that a PCI device may have. + * This is NOT the number of slots or devices in the system + * This is NOT the number of entries in the PIRQ table + * + * This tells us that in the PIRQ table, we are going to have 4 link-bitmap + * entries per PCI device which is fixed at 4: INTA, INTB, INTC, and INTD. + * + * CAUTION: If you change this, PIRQ routing will not work correctly. + */ +#define MAX_INTX_ENTRIES 4 + +#define PIRQ_SIGNATURE \ + (('$' << 0) + ('P' << 8) + ('I' << 16) + ('R' << 24)) +#define PIRQ_VERSION 0x0100 + +struct __packed irq_info { + u8 bus; /* Bus number */ + u8 devfn; /* Device and function number */ + struct __packed { + u8 link; /* IRQ line ID, 0=not routed */ + u16 bitmap; /* Available IRQs */ + } irq[MAX_INTX_ENTRIES]; + u8 slot; /* Slot number, 0=onboard */ + u8 rfu; +}; + +struct __packed irq_routing_table { + u32 signature; /* PIRQ_SIGNATURE */ + u16 version; /* PIRQ_VERSION */ + u16 size; /* Table size in bytes */ + u8 rtr_bus; /* busno of the interrupt router */ + u8 rtr_devfn; /* devfn of the interrupt router */ + u16 exclusive_irqs; /* IRQs devoted exclusively to PCI usage */ + u16 rtr_vendor; /* Vendor ID of the interrupt router */ + u16 rtr_device; /* Device ID of the interrupt router */ + u32 miniport_data; + u8 rfu[11]; + u8 checksum; /* Modulo 256 checksum must give zero */ + struct irq_info slots[CONFIG_IRQ_SLOT_COUNT]; +}; + +/** + * get_irq_slot_count() - Get the number of entries in the irq_info table + * + * This calculates the number of entries for the irq_info table. + * + * @rt: pointer to the base address of the struct irq_info + * @return: number of entries + */ +static inline int get_irq_slot_count(struct irq_routing_table *rt) +{ + return (rt->size - 32) / sizeof(struct irq_info); +} + +/** + * pirq_check_irq_routed() - Check whether an IRQ is routed to 8259 PIC + * + * This function checks whether an IRQ is routed to 8259 PIC for a given link. + * + * Note: this function should be provided by the platform codes, as the + * implementation of interrupt router may be different. + * + * @link: link number which represents a PIRQ + * @irq: the 8259 IRQ number + * @return: true if the irq is already routed to 8259 for a given link, + * false elsewise + */ +bool pirq_check_irq_routed(int link, u8 irq); + +/** + * pirq_translate_link() - Translate a link value + * + * This function translates a platform-specific link value to a link number. + * On Intel platforms, the link value is normally a offset into the PCI + * configuration space into the legacy bridge. + * + * Note: this function should be provided by the platform codes, as the + * implementation of interrupt router may be different. + * + * @link: platform-specific link value + * @return: link number which represents a PIRQ + */ +int pirq_translate_link(int link); + +/** + * pirq_assign_irq() - Assign an IRQ to a PIRQ link + * + * This function assigns the IRQ to a PIRQ link so that the PIRQ is routed to + * the 8259 PIC. + * + * Note: this function should be provided by the platform codes, as the + * implementation of interrupt router may be different. + * + * @link: link number which represents a PIRQ + * @irq: IRQ to which the PIRQ is routed + */ +void pirq_assign_irq(int link, u8 irq); + +/** + * pirq_route_irqs() - Route PIRQs to 8259 PIC + * + * This function configures all PCI devices' interrupt pins and maps them to + * PIRQs and finally 8259 PIC. The routed irq number is written to interrupt + * line register in the configuration space of the PCI device for OS to use. + * The configuration source is taken from a struct irq_info table, the format + * of which is defined in PIRQ routing table spec and PCI BIOS spec. + * + * @irq: pointer to the base address of the struct irq_info + * @num: number of entries in the struct irq_info + */ +void pirq_route_irqs(struct irq_info *irq, int num); + +/** + * copy_pirq_routing_table() - Copy a PIRQ routing table + * + * This helper function copies the given PIRQ routing table to a given address. + * Before copying, it does several sanity tests against the PIRQ routing table. + * It also fixes up the table checksum and align the given address to a 16 byte + * boundary to meet the PIRQ routing table spec requirements. + * + * @addr: address to store the copied PIRQ routing table + * @rt: pointer to the PIRQ routing table to copy from + * @return: end address of the copied PIRQ routing table + */ +u32 copy_pirq_routing_table(u32 addr, struct irq_routing_table *rt); + +#endif /* _PIRQ_ROUTING_H_ */ diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 0de0d89..0178fe1 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -22,6 +22,7 @@ ifndef CONFIG_DM_PCI obj-$(CONFIG_PCI) += pci_type1.o endif obj-y += pch-uclass.o +obj-y += pirq_routing.o obj-y += relocate.o obj-y += physmem.o obj-$(CONFIG_X86_RAMTEST) += ramtest.o diff --git a/arch/x86/lib/pirq_routing.c b/arch/x86/lib/pirq_routing.c new file mode 100644 index 0000000..5a2591a --- /dev/null +++ b/arch/x86/lib/pirq_routing.c @@ -0,0 +1,129 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * Part of this file is ported from coreboot src/arch/x86/boot/pirq_routing.c + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <pci.h> +#include <asm/pci.h> +#include <asm/pirq_routing.h> +#include <asm/tables.h> + +static bool irq_already_routed[16]; + +static u8 pirq_get_next_free_irq(u8 *pirq, u16 bitmap) +{ + int i, link; + u8 irq = 0; + + /* IRQ sharing starts from IRQ#3 */ + for (i = 3; i < 16; i++) { + /* Can we assign this IRQ? */ + if (!((bitmap >> i) & 1)) + continue; + + /* We can, now let's assume we can use this IRQ */ + irq = i; + + /* Have we already routed it? */ + if (irq_already_routed[irq]) + continue; + + for (link = 0; link < CONFIG_MAX_PIRQ_LINKS; link++) { + if (pirq_check_irq_routed(link, irq)) { + irq_already_routed[irq] = true; + break; + } + } + + /* If it's not yet routed, use it */ + if (!irq_already_routed[irq]) { + irq_already_routed[irq] = true; + break; + } + + /* But if it was already routed, try the next one */ + } + + /* Now we get our IRQ */ + return irq; +} + +void pirq_route_irqs(struct irq_info *irq, int num) +{ + unsigned char irq_slot[MAX_INTX_ENTRIES]; + unsigned char pirq[CONFIG_MAX_PIRQ_LINKS]; + int i, intx; + + memset(pirq, 0, CONFIG_MAX_PIRQ_LINKS); + + /* Set PCI IRQs */ + for (i = 0; i < num; i++) { + debug("PIRQ Entry %d Dev: %d.%x.%d\n", i, + irq->bus, irq->devfn >> 3, irq->devfn & 7); + + for (intx = 0; intx < MAX_INTX_ENTRIES; intx++) { + int link = irq->irq[intx].link; + int bitmap = irq->irq[intx].bitmap; + int irq = 0; + + debug("INT%c link: %x bitmap: %x ", + 'A' + intx, link, bitmap); + + if (!bitmap || !link) { + debug("not routed\n"); + irq_slot[intx] = irq; + continue; + } + + /* translate link value to link number */ + link = pirq_translate_link(link); + + /* yet not routed */ + if (!pirq[link]) { + irq = pirq_get_next_free_irq(pirq, bitmap); + pirq[link] = irq; + } else { + irq = pirq[link]; + } + + debug("IRQ: %d\n", irq); + irq_slot[intx] = irq; + + /* Assign IRQ in the interrupt router */ + pirq_assign_irq(link, irq); + } + + /* Bus, device, slots IRQs for {A,B,C,D} */ + pci_assign_irqs(irq->bus, irq->devfn >> 3, irq->devfn & 7, + irq_slot); + + irq++; + } + + for (i = 0; i < CONFIG_MAX_PIRQ_LINKS; i++) + debug("PIRQ%c: %d\n", 'A' + i, pirq[i]); +} + +u32 copy_pirq_routing_table(u32 addr, struct irq_routing_table *rt) +{ + if (rt->signature != PIRQ_SIGNATURE || rt->version != PIRQ_VERSION || + rt->size % 16) { + debug("Interrupt Routing Table not valid\n"); + return addr; + } + + /* Fix up the table checksum */ + rt->checksum = table_compute_checksum(rt, rt->size); + + /* Align the table to be 16 byte aligned */ + addr = ALIGN(addr, 16); + + debug("Copying Interrupt Routing Table to 0x%x\n", addr); + memcpy((void *)addr, rt, rt->size); + + return addr + rt->size; +}
Bin Meng
