[U-Boot] [PATCH 1/1] blk: set log2blksz in blk_create_device()
The ext4 file system requires log2blksz to be set. So when setting the block size on the block descriptor we should fill this field too.
This fixes a problem with EFI block devices providing ext4 partitions, cf. https://lists.denx.de/pipermail/u-boot/2019-October/387702.html.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/block/blk-uclass.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index e8f58b3f5e..ca8978f0e1 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -580,6 +580,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name, desc = dev_get_uclass_platdata(dev); desc->if_type = if_type; desc->blksz = blksz; + desc->log2blksz = LOG2(desc->blksz); desc->lba = lba; desc->part_type = PART_TYPE_UNKNOWN; desc->bdev = dev; -- 2.23.0
Hi Heinrich,
But I wonder if blk_create_device() should change to take log2blksz as its parameter and calculate blksz?
-- 2.23.0
On 10/30/19 2:49 AM, Simon Glass wrote:
Hi Heinrich,
CD-ROM mode 2 has 2336 data bytes, CD-ROM XA Mode 2, Form 2 has 2324 data bytes according to https://en.wikipedia.org/wiki/CD-ROM.
So we cannot assume that blksz is a power of two in the general case.
LOG2() is behaving a bit erratically for numbers that are not a power of two (in contrast to what ilog2() does):
LOG2(2048) = 11 LOG2(2049) = 11 LOG2(2324) = 15 LOG2(2336) = 15 LOG2(3072) = 11 LOG2(4096) = 12
ilog2(2048) = 11 ilog2(2049) = 11 ilog2(2324) = 11 ilog2(2336) = 11 ilog2(3072) = 11 ilog2(4096) = 12
But if we ever add an ISO 9660 file system driver, we will not be able to use log2blksz anyway. So I think we can stick with LOG2().
Best regards
Heinrich
-- 2.23.0
