[U-Boot] [PATCH 1/9] spi: zynq_qspi: Add quad support for zynq qspi
Add quad commands supports for zynq qspi driver
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- - Tested on zc702 board --- drivers/spi/zynq_qspi.c | 14 ++++++++++++++ 1 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index b98663c..e636244 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -11,7 +11,9 @@ #include <dm.h> #include <malloc.h> #include <spi.h> +#include <spi_flash.h> #include <asm/io.h> +#include "../mtd/spi/sf_internal.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -156,6 +158,17 @@ static void zynq_qspi_init_hw(struct zynq_qspi_priv *priv) writel(ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); }
+static int zynq_qspi_child_pre_probe(struct udevice *bus) +{ + struct spi_slave *slave = dev_get_parent_priv(bus); + + slave->mode_rx = QUAD_OUTPUT_FAST; + slave->mode = SPI_TX_QUAD; + slave->no_all_quad = 1; + + return 0; +} + static int zynq_qspi_probe(struct udevice *bus) { struct zynq_qspi_platdata *plat = dev_get_platdata(bus); @@ -627,4 +640,5 @@ U_BOOT_DRIVER(zynq_qspi) = { .platdata_auto_alloc_size = sizeof(struct zynq_qspi_platdata), .priv_auto_alloc_size = sizeof(struct zynq_qspi_priv), .probe = zynq_qspi_probe, + .child_pre_probe = zynq_qspi_child_pre_probe, };
Add Dual parallel and dual stacked supports for zynq qspi driver. The is-dual property defines the dual parallel mode and num-cs, numbere of chip selects defines dual stacked mode if its value is 2
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/spi/zynq_qspi.c | 47 +++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 47 insertions(+), 0 deletions(-)
diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index e636244..44057ba 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -52,6 +52,10 @@ DECLARE_GLOBAL_DATA_PTR; #define CONFIG_SYS_ZYNQ_QSPI_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
+#define ZYNQ_QSPI_LCR_TWO_MEM_MASK BIT(30) /* QSPI Enable Bit Mask */ +#define ZYNQ_QSPI_LCR_SEP_BUS_MASK BIT(29) /* QSPI Enable Bit Mask */ +#define ZYNQ_QSPI_LCR_U_PAGE BIT(28) /* QSPI Upper memory set */ + /* zynq qspi register set */ struct zynq_qspi_regs { u32 cr; /* 0x00 */ @@ -96,6 +100,8 @@ struct zynq_qspi_priv { int bytes_to_transfer; int bytes_to_receive; unsigned int is_inst; + unsigned int is_dual; + unsigned int u_page; unsigned cs_change:1; };
@@ -154,6 +160,14 @@ static void zynq_qspi_init_hw(struct zynq_qspi_priv *priv) confr &= ~ZYNQ_QSPI_LQSPICFG_LQMODE_MASK; writel(confr, ®s->lqspicfg);
+ if (priv->is_dual == SF_DUAL_PARALLEL_FLASH) + writel(ZYNQ_QSPI_LCR_TWO_MEM_MASK | + ZYNQ_QSPI_LCR_SEP_BUS_MASK, + ®s->lqspicfg); + else if (priv->is_dual == SF_DUAL_STACKED_FLASH) + writel(ZYNQ_QSPI_LCR_TWO_MEM_MASK, + ®s->lqspicfg); + /* Enable SPI */ writel(ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); } @@ -161,7 +175,9 @@ static void zynq_qspi_init_hw(struct zynq_qspi_priv *priv) static int zynq_qspi_child_pre_probe(struct udevice *bus) { struct spi_slave *slave = dev_get_parent_priv(bus); + struct zynq_qspi_priv *priv = dev_get_priv(bus->parent);
+ slave->option = priv->is_dual; slave->mode_rx = QUAD_OUTPUT_FAST; slave->mode = SPI_TX_QUAD; slave->no_all_quad = 1; @@ -173,10 +189,23 @@ static int zynq_qspi_probe(struct udevice *bus) { struct zynq_qspi_platdata *plat = dev_get_platdata(bus); struct zynq_qspi_priv *priv = dev_get_priv(bus); + const void *blob = gd->fdt_blob; + int node = bus->of_offset; + u8 is_dual = 0; + u8 num_cs = 0;
priv->regs = plat->regs; priv->fifo_depth = ZYNQ_QSPI_FIFO_DEPTH;
+ is_dual = fdtdec_get_int(blob, node, "is-dual", 0); + if (is_dual) { + priv->is_dual = SF_DUAL_PARALLEL_FLASH; + } else { + num_cs = fdtdec_get_int(blob, node, "num-cs", 1); + if (num_cs == 2) + priv->is_dual = SF_DUAL_STACKED_FLASH; + } + /* init the zynq spi hw */ zynq_qspi_init_hw(priv);
@@ -437,6 +466,7 @@ static int zynq_qspi_irq_poll(struct zynq_qspi_priv *priv) */ static int zynq_qspi_start_transfer(struct zynq_qspi_priv *priv) { + static u8 current_u_page; u32 data = 0; struct zynq_qspi_regs *regs = priv->regs;
@@ -446,6 +476,18 @@ static int zynq_qspi_start_transfer(struct zynq_qspi_priv *priv) priv->bytes_to_transfer = priv->len; priv->bytes_to_receive = priv->len;
+ if (priv->is_inst && (priv->is_dual == SF_DUAL_STACKED_FLASH) && + (current_u_page != priv->u_page)) { + if (priv->u_page) + writel(ZYNQ_QSPI_LCR_TWO_MEM_MASK | + ZYNQ_QSPI_LCR_U_PAGE, + ®s->lqspicfg); + else + writel(ZYNQ_QSPI_LCR_TWO_MEM_MASK, + ®s->lqspicfg); + current_u_page = priv->u_page; + } + if (priv->len < 4) zynq_qspi_fill_tx_fifo(priv, priv->len); else @@ -555,6 +597,11 @@ static int zynq_qspi_xfer(struct udevice *dev, unsigned int bitlen, else priv->cs_change = 0;
+ if (flags & SPI_XFER_U_PAGE) + priv->u_page = 1; + else + priv->u_page = 0; + zynq_qspi_transfer(priv);
Add SF_DUAL_FLASH config entry with help description This is needed to support dual parallel and stacked modes.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/spi/Kconfig | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 3f7433c..61cd607 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -128,4 +128,12 @@ config SPI_FLASH_MTD
If unsure, say N
+config SF_DUAL_FLASH + bool "SPI Flash Dual support" + depends on SPI_FLASH + help + Enables the dual modes support for spi flash layer, this is required + to handle dual parallel and stacked modes during sf read, write and + erase ops. + endmenu # menu "SPI Flash Support"
Update qspi node with properties is-dual and num-cs QSPI flash devices on zc706 connected in dual paralle mode hence is-dual is 1 and num-cs is 1. The property is-dual expalins the dual parallel connection mode The property num-cs defines number of chip selects whose value is 1 incase of dual parllel connection
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/dts/zynq-zc706.dts | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/zynq-zc706.dts b/arch/arm/dts/zynq-zc706.dts index d04880a..ee58128 100644 --- a/arch/arm/dts/zynq-zc706.dts +++ b/arch/arm/dts/zynq-zc706.dts @@ -309,6 +309,8 @@ &qspi { u-boot,dm-pre-reloc; status = "okay"; + is-dual = <1>; + num-cs = <1>; };
&sdhci0 {
Add QSPI dual mode support for zc706 by enabling the config option SF_DUAL_FLASH
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- configs/zynq_zc706_defconfig | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 3539f05..f0cc474 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SF_DUAL_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y
Dont need to double the size while calculating the flash size as the sector size calculation already takes care of doubling the size incase of dual modes
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/spi/spi_flash.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 5b22ae2..e4c7ff5 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1094,7 +1094,7 @@ int spi_flash_scan(struct spi_flash *flash) } flash->page_size <<= flash->shift; flash->sector_size = params->sector_size << flash->shift; - flash->size = flash->sector_size * params->nr_sectors << flash->shift; + flash->size = flash->sector_size * params->nr_sectors; #ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash & SF_DUAL_STACKED_FLASH) flash->size <<= 1;
Correct the bank selection issue incase of Dual stacked mode. This fix corrects the wrong bank selection if banks are accessed as below. 1. Access the bank2 in upper flash. 2. Access the bank1 in lower flash. 3. Now access the bank1 in upper flash. But here in the step3, the present code was accessing the bank2 in upper flash not bank1. This was because the code thinks the bank1 was already selected as part of step2 but it was not taking care of upper or lower flash.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/spi/spi_flash.c | 20 +++++++++++++++++--- include/spi_flash.h | 1 + 2 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index e4c7ff5..93980bd 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -146,12 +146,26 @@ static int write_evcr(struct spi_flash *flash, u8 evcr) #ifdef CONFIG_SPI_FLASH_BAR static int spi_flash_write_bar(struct spi_flash *flash, u32 offset) { - u8 cmd, bank_sel; + u8 cmd, bank_sel, upage_curr; int ret;
bank_sel = offset / (SPI_FLASH_16MB_BOUN << flash->shift); - if (bank_sel == flash->bank_curr) - goto bar_end; + + upage_curr = flash->spi->flags & SPI_XFER_U_PAGE; + + if (flash->dual_flash != SF_DUAL_STACKED_FLASH) { + if (flash->bank_curr == bank_sel) { + debug("SF: not require to enable bank%d\n", bank_sel); + goto bar_end; + } + } else if (flash->upage_prev == upage_curr) { + if (flash->bank_curr == bank_sel) { + debug("SF: not require to enable bank%d\n", bank_sel); + goto bar_end; + } + } else { + flash->upage_prev = upage_curr; + }
cmd = flash->bank_write_cmd; ret = spi_flash_write_common(flash, &cmd, 1, &bank_sel, 1); diff --git a/include/spi_flash.h b/include/spi_flash.h index d0ce9e7..83052e0 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -78,6 +78,7 @@ struct spi_flash { u8 bank_read_cmd; u8 bank_write_cmd; u8 bank_curr; + u8 upage_prev; #endif u8 erase_cmd; u8 read_cmd;
In Dual parallel connection the bank selection calculation should be performed using offset and not the calculated address
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/spi/spi_flash.c | 21 +++++++++++++++------ 1 files changed, 15 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 93980bd..2de2a35 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -340,7 +340,7 @@ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd,
int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) { - u32 erase_size, erase_addr; + u32 erase_size, erase_addr, bank_addr; u8 cmd[SPI_FLASH_CMD_LEN]; int ret = -1;
@@ -361,13 +361,16 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) cmd[0] = flash->erase_cmd; while (len) { erase_addr = offset; + bank_addr = offset;
#ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash > SF_SINGLE_FLASH) spi_flash_dual(flash, &erase_addr); + if (flash->dual_flash == SF_DUAL_STACKED_FLASH) + bank_addr = erase_addr; #endif #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, erase_addr); + ret = spi_flash_write_bar(flash, bank_addr); if (ret < 0) return ret; #endif @@ -394,7 +397,7 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, { struct spi_slave *spi = flash->spi; unsigned long byte_addr, page_size; - u32 write_addr; + u32 write_addr, bank_addr; size_t chunk_len, actual; u8 cmd[SPI_FLASH_CMD_LEN]; int ret = -1; @@ -412,13 +415,16 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, cmd[0] = flash->write_cmd; for (actual = 0; actual < len; actual += chunk_len) { write_addr = offset; + bank_addr = offset;
#ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash > SF_SINGLE_FLASH) spi_flash_dual(flash, &write_addr); + if (flash->dual_flash == SF_DUAL_STACKED_FLASH) + bank_addr = write_addr; #endif #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, write_addr); + ret = spi_flash_write_bar(flash, bank_addr); if (ret < 0) return ret; #endif @@ -488,7 +494,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, { struct spi_slave *spi = flash->spi; u8 *cmd, cmdsz; - u32 remain_len, read_len, read_addr; + u32 remain_len, read_len, read_addr, bank_addr; int bank_sel = 0; int ret = -1;
@@ -516,13 +522,16 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, cmd[0] = flash->read_cmd; while (len) { read_addr = offset; + bank_addr = offset;
#ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash > SF_SINGLE_FLASH) spi_flash_dual(flash, &read_addr); + if (flash->dual_flash == SF_DUAL_STACKED_FLASH) + bank_addr = read_addr; #endif #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, read_addr); + ret = spi_flash_write_bar(flash, bank_addr); if (ret < 0) return ret; bank_sel = flash->bank_curr;
Set quad enable for upper flash incase of Dual stacked mode.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/spi/spi_flash.c | 11 +++++++++++ 1 files changed, 11 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 2de2a35..7caf905 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1164,6 +1164,17 @@ int spi_flash_scan(struct spi_flash *flash) debug("SF: Fail to set QEB for %02x\n", idcode[0]); return -EINVAL; } +#ifdef CONFIG_SF_DUAL_FLASH + if (flash->dual_flash & SF_DUAL_STACKED_FLASH) { + flash->spi->flags |= SPI_XFER_U_PAGE; + if (set_quad_mode(flash, idcode[0])) { + debug("SF: Fail to set QEB Upper Flash %02x\n", + idcode[0]); + return 0; + } + flash->spi->flags &= ~SPI_XFER_U_PAGE; + } +#endif }
/* Read dummy_byte: dummy byte is determined based on the
-----Original Message----- From: Siva Durga Prasad Paladugu [mailto:siva.durga.paladugu@xilinx.com] Sent: Monday, June 06, 2016 3:15 PM To: u-boot@lists.denx.de Cc: Michal Simek michals@xilinx.com; jagannadh.teki@gmail.com; Siva Durga Prasad Paladugu sivadur@xilinx.com Subject: [PATCH 1/9] spi: zynq_qspi: Add quad support for zynq qspi
Hi Jagan,
Any comments on this series. If not, Please take this series.
Regards, Siva
+static int zynq_qspi_child_pre_probe(struct udevice *bus) { + struct spi_slave *slave = dev_get_parent_priv(bus); + + slave->mode_rx = QUAD_OUTPUT_FAST; + slave->mode = SPI_TX_QUAD; + slave->no_all_quad = 1; + + return 0; +} + static int zynq_qspi_probe(struct udevice *bus) { struct zynq_qspi_platdata *plat = dev_get_platdata(bus); @@ -627,4 +640,5 @@ U_BOOT_DRIVER(zynq_qspi) = { .platdata_auto_alloc_size = sizeof(struct zynq_qspi_platdata), .priv_auto_alloc_size = sizeof(struct zynq_qspi_priv), .probe = zynq_qspi_probe, + .child_pre_probe = zynq_qspi_child_pre_probe, }; -- 1.7.1
Hi Tom,
-----Original Message----- From: Siva Durga Prasad Paladugu Sent: Tuesday, June 14, 2016 2:49 PM To: u-boot@lists.denx.de; jagannadh.teki@gmail.com Cc: Michal Simek michals@xilinx.com; 'Siva Durga Prasad Paladugu' siva.durga.paladugu@xilinx.com Subject: RE: [PATCH 1/9] spi: zynq_qspi: Add quad support for zynq qspi
Hi Jagan,
Regards, Siva
Same is the case with this series too, If Jagan is busy, Is it possible to get it Acked/Reviewed by some other person and can go through your tree/Michal tree.
Regards, Siva
1.7.1
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
On 21 June 2016 at 17:24, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
Hi Tom,
Hi Jagan,
Please wait I will back with my comments.
Regards, Siva
1.7.1
Hi Tom,
I couldn't find the series cover letter or I missed it, please resend the series again.
thanks!
Jagan Teki
