[PATCH v2 0/3] PolarFire SoC clock devicetree rework
Here's a U-Boot implementation of the changes I'm trying to make in https://lore.kernel.org/all/20241002-private-unequal-33cfa6101338@spud/ that affect how the clocks are described in devicetree for PolarFire SoC. There's been no complaints about the only part that impacts U-Boot, so I figured it was time to send patches here.
I've implemented things here in a backwards compatible manner, so that these changes can be applied now without the relevant devicetree patches (since the dust has not settled on all aspects of the rework) and the revised devicetree can make its way into U-Boot via a regular OF_UPSTREAM update once merged "upstream".
~There's minor duplication with Hal's work in patch 3, but I think that's~ ~not particularly important, given it is the addition of a trivial~ ~Makefile we both require:~ ~https://lore.kernel.org/all/20240930155919.111738-1-hal.feng@starfivetech.co...
In v2, I rebased on top of master as Sumit suggested to pick up the movement of some dts Makefile, so while there's still a bit of duplication, what's here is "better" than what's linked above.
Cheers, Conor.
CC: Rick Chen rick@andestech.com CC: Leo ycliang@andestech.com CC: Tom Rini trini@konsulko.com CC: Conor Dooley conor.dooley@microchip.com CC: Cyril Jean cyril.jean@microchip.com CC: Lukasz Majewski lukma@denx.de CC: Sean Anderson seanga2@gmail.com CC: Sumit Garg sumit.garg@linaro.org CC: u-boot@lists.denx.de
Conor Dooley (3): clk: microchip: mpfs: support new syscon based devicetree configuration board: mpfs_icicle: imply new clk driver dependencies riscv: dts: mpfs: migrate to OF_UPSTREAM
arch/riscv/dts/Makefile | 1 - arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi | 71 --- arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi | 14 - arch/riscv/dts/mpfs-icicle-kit.dts | 208 --------- arch/riscv/dts/mpfs.dtsi | 511 --------------------- board/microchip/mpfs_icicle/Kconfig | 2 + configs/microchip_mpfs_icicle_defconfig | 4 +- drivers/clk/microchip/Kconfig | 2 + drivers/clk/microchip/mpfs_clk.c | 63 ++- drivers/clk/microchip/mpfs_clk.h | 5 +- drivers/clk/microchip/mpfs_clk_cfg.c | 16 +- drivers/clk/microchip/mpfs_clk_periph.c | 37 +- dts/upstream/src/riscv/Makefile | 6 + 13 files changed, 91 insertions(+), 849 deletions(-) delete mode 100644 arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi delete mode 100644 arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi delete mode 100644 arch/riscv/dts/mpfs-icicle-kit.dts delete mode 100644 arch/riscv/dts/mpfs.dtsi create mode 100644 dts/upstream/src/riscv/Makefile
Why get a devicetree description wrong once when you can get it wrong twice? The original mistake, which the driver supports was failing to describe the main PLL that the "cfg" and "periph" clocks parented by. The second mistake was describing the "cfg" and "periph" clocks a reg region within the clock controller, rather as two registers within a syscon region that also contains pinctrl, interrupt muxing controls and other functions.
Make up for lost time and describe these regions as they should have been originally, preserving support for the existing two configurations for the sake of existing systems with firmware-provided devicetrees.
Signed-off-by: Conor Dooley conor.dooley@microchip.com --- drivers/clk/microchip/Kconfig | 2 + drivers/clk/microchip/mpfs_clk.c | 63 ++++++++++++++++++++----- drivers/clk/microchip/mpfs_clk.h | 5 +- drivers/clk/microchip/mpfs_clk_cfg.c | 16 +++---- drivers/clk/microchip/mpfs_clk_periph.c | 37 +++++++-------- 5 files changed, 81 insertions(+), 42 deletions(-)
diff --git a/drivers/clk/microchip/Kconfig b/drivers/clk/microchip/Kconfig index b70241559db..62072e100b1 100644 --- a/drivers/clk/microchip/Kconfig +++ b/drivers/clk/microchip/Kconfig @@ -1,5 +1,7 @@ config CLK_MPFS bool "Clock support for Microchip PolarFire SoC" depends on CLK && CLK_CCF + depends on SYSCON + depends on REGMAP help This enables support clock driver for Microchip PolarFire SoC platform. diff --git a/drivers/clk/microchip/mpfs_clk.c b/drivers/clk/microchip/mpfs_clk.c index 0a82777ff74..2c6694f0035 100644 --- a/drivers/clk/microchip/mpfs_clk.c +++ b/drivers/clk/microchip/mpfs_clk.c @@ -9,25 +9,39 @@ #include <log.h> #include <dm/device.h> #include <dm/devres.h> +#include <dm/ofnode.h> #include <dm/uclass.h> +#include <regmap.h> +#include <syscon.h> #include <dt-bindings/clock/microchip-mpfs-clock.h> #include <linux/err.h>
#include "mpfs_clk.h"
-static int mpfs_clk_probe(struct udevice *dev) +static int mpfs_clk_syscon_probe(struct udevice *dev, void __iomem **msspll_base, + struct regmap **regmap) +{ + ofnode node; + + node = ofnode_by_compatible(ofnode_null(), "microchip,mpfs-mss-top-sysreg"); + if (!ofnode_valid(node)) + return -ENODEV; + + *regmap = syscon_node_to_regmap(node); + if (IS_ERR(regmap)) + return PTR_ERR(regmap); + + *msspll_base = dev_read_addr_index_ptr(dev, 0); + + return 0; +} + +static int mpfs_clk_old_format_probe(struct udevice *dev, void __iomem **msspll_base, + struct regmap **regmap) { - struct clk *parent_clk = dev_get_priv(dev); - struct clk clk_msspll = { .id = CLK_MSSPLL }; - void __iomem *base; - void __iomem *msspll_base; int ret;
- base = dev_read_addr_index_ptr(dev, 0); - if (!base) - return -EINVAL; - - ret = clk_get_by_index(dev, 0, parent_clk); + ret = regmap_init_mem_index(dev_ofnode(dev), regmap, 0); if (ret) return ret;
@@ -40,7 +54,30 @@ static int mpfs_clk_probe(struct udevice *dev) * Otherwise, skip registering it & pass the reference clock directly * to the cfg clock registration function. */ - msspll_base = dev_read_addr_index_ptr(dev, 1); + *msspll_base = dev_read_addr_index_ptr(dev, 1); + + return 0; +} + +static int mpfs_clk_probe(struct udevice *dev) +{ + struct clk *parent_clk = dev_get_priv(dev); + struct clk clk_msspll = { .id = CLK_MSSPLL }; + struct regmap *regmap; + void __iomem *msspll_base; + int ret; + + ret = clk_get_by_index(dev, 0, parent_clk); + if (ret) + return ret; + + ret = mpfs_clk_syscon_probe(dev, &msspll_base, ®map); + if (ret) { + ret = mpfs_clk_old_format_probe(dev, &msspll_base, ®map); + if (ret) + return ret; + } + if (msspll_base) { ret = mpfs_clk_register_msspll(msspll_base, parent_clk); if (ret) @@ -50,11 +87,11 @@ static int mpfs_clk_probe(struct udevice *dev) parent_clk = &clk_msspll; }
- ret = mpfs_clk_register_cfgs(base, parent_clk); + ret = mpfs_clk_register_cfgs(parent_clk, regmap); if (ret) return ret;
- ret = mpfs_clk_register_periphs(base, dev); + ret = mpfs_clk_register_periphs(dev, regmap);
return ret; } diff --git a/drivers/clk/microchip/mpfs_clk.h b/drivers/clk/microchip/mpfs_clk.h index 72288cc971b..b8ad3ea7616 100644 --- a/drivers/clk/microchip/mpfs_clk.h +++ b/drivers/clk/microchip/mpfs_clk.h @@ -7,6 +7,7 @@ #define __MICROCHIP_MPFS_CLK_H
#include <linux/clk-provider.h> +#include <regmap.h> /** * mpfs_clk_register_cfgs() - register configuration clocks * @@ -14,7 +15,7 @@ * @parent: a pointer to parent clock. * Return: zero on success, or a negative error code. */ -int mpfs_clk_register_cfgs(void __iomem *base, struct clk *parent); +int mpfs_clk_register_cfgs(struct clk *parent, struct regmap *regmap); /** * mpfs_clk_register_msspll() - register the mss pll * @@ -30,7 +31,7 @@ int mpfs_clk_register_msspll(void __iomem *base, struct clk *parent); * @dev: udevice representing the clock controller. * Return: zero on success, or a negative error code. */ -int mpfs_clk_register_periphs(void __iomem *base, struct udevice *dev); +int mpfs_clk_register_periphs(struct udevice *dev, struct regmap *regmap); /** * divider_get_val() - get the clock divider value * diff --git a/drivers/clk/microchip/mpfs_clk_cfg.c b/drivers/clk/microchip/mpfs_clk_cfg.c index 5e8fb995289..7da1fc77120 100644 --- a/drivers/clk/microchip/mpfs_clk_cfg.c +++ b/drivers/clk/microchip/mpfs_clk_cfg.c @@ -9,6 +9,7 @@ #include <dm/device.h> #include <dm/devres.h> #include <dm/uclass.h> +#include <regmap.h> #include <dt-bindings/clock/microchip-mpfs-clock.h> #include <linux/err.h>
@@ -57,7 +58,7 @@ struct mpfs_cfg_clock { */ struct mpfs_cfg_hw_clock { struct mpfs_cfg_clock cfg; - void __iomem *sys_base; + struct regmap *regmap; u32 prate; struct clk hw; }; @@ -68,11 +69,11 @@ static ulong mpfs_cfg_clk_recalc_rate(struct clk *hw) { struct mpfs_cfg_hw_clock *cfg_hw = to_mpfs_cfg_clk(hw); struct mpfs_cfg_clock *cfg = &cfg_hw->cfg; - void __iomem *base_addr = cfg_hw->sys_base; unsigned long rate; u32 val;
- val = readl(base_addr + REG_CLOCK_CONFIG_CR) >> cfg->shift; + regmap_read(cfg_hw->regmap, REG_CLOCK_CONFIG_CR, &val); + val >>= cfg->shift; val &= clk_div_mask(cfg->width); rate = cfg_hw->prate / (1u << val); hw->rate = rate; @@ -84,7 +85,6 @@ static ulong mpfs_cfg_clk_set_rate(struct clk *hw, ulong rate) { struct mpfs_cfg_hw_clock *cfg_hw = to_mpfs_cfg_clk(hw); struct mpfs_cfg_clock *cfg = &cfg_hw->cfg; - void __iomem *base_addr = cfg_hw->sys_base; u32 val; int divider_setting;
@@ -93,10 +93,10 @@ static ulong mpfs_cfg_clk_set_rate(struct clk *hw, ulong rate) if (divider_setting < 0) return divider_setting;
- val = readl(base_addr + REG_CLOCK_CONFIG_CR); + regmap_read(cfg_hw->regmap, REG_CLOCK_CONFIG_CR, &val); val &= ~(clk_div_mask(cfg->width) << cfg_hw->cfg.shift); val |= divider_setting << cfg->shift; - writel(val, base_addr + REG_CLOCK_CONFIG_CR); + regmap_write(cfg_hw->regmap, REG_CLOCK_CONFIG_CR, val);
return clk_get_rate(hw); } @@ -116,7 +116,7 @@ static struct mpfs_cfg_hw_clock mpfs_cfg_clks[] = { CLK_CFG(CLK_AHB, "clk_ahb", 4, 2, mpfs_div_ahb_table, 0), };
-int mpfs_clk_register_cfgs(void __iomem *base, struct clk *parent) +int mpfs_clk_register_cfgs(struct clk *parent, struct regmap *regmap) { int ret; int i, id, num_clks; @@ -126,7 +126,7 @@ int mpfs_clk_register_cfgs(void __iomem *base, struct clk *parent) num_clks = ARRAY_SIZE(mpfs_cfg_clks); for (i = 0; i < num_clks; i++) { hw = &mpfs_cfg_clks[i].hw; - mpfs_cfg_clks[i].sys_base = base; + mpfs_cfg_clks[i].regmap = regmap; mpfs_cfg_clks[i].prate = clk_get_rate(parent); name = mpfs_cfg_clks[i].cfg.name; ret = clk_register(hw, MPFS_CFG_CLOCK, name, parent->dev->name); diff --git a/drivers/clk/microchip/mpfs_clk_periph.c b/drivers/clk/microchip/mpfs_clk_periph.c index 41c6df4fb97..b734f49d81a 100644 --- a/drivers/clk/microchip/mpfs_clk_periph.c +++ b/drivers/clk/microchip/mpfs_clk_periph.c @@ -9,6 +9,7 @@ #include <dm/device.h> #include <dm/devres.h> #include <dm/uclass.h> +#include <regmap.h> #include <dt-bindings/clock/microchip-mpfs-clock.h> #include <linux/err.h>
@@ -50,7 +51,7 @@ struct mpfs_periph_clock { */ struct mpfs_periph_hw_clock { struct mpfs_periph_clock periph; - void __iomem *sys_base; + struct regmap *regmap; u32 prate; struct clk hw; }; @@ -61,17 +62,16 @@ static int mpfs_periph_clk_enable(struct clk *hw) { struct mpfs_periph_hw_clock *periph_hw = to_mpfs_periph_clk(hw); struct mpfs_periph_clock *periph = &periph_hw->periph; - void __iomem *base_addr = periph_hw->sys_base; - u32 reg, val; + u32 reg;
if (periph->flags != CLK_IS_CRITICAL) { - reg = readl(base_addr + REG_SUBBLK_RESET_CR); - val = reg & ~(1u << periph->shift); - writel(val, base_addr + REG_SUBBLK_RESET_CR); + regmap_read(periph_hw->regmap, REG_SUBBLK_RESET_CR, ®); + reg &= ~(1u << periph->shift); + regmap_write(periph_hw->regmap, REG_SUBBLK_RESET_CR, reg);
- reg = readl(base_addr + REG_SUBBLK_CLOCK_CR); - val = reg | (1u << periph->shift); - writel(val, base_addr + REG_SUBBLK_CLOCK_CR); + regmap_read(periph_hw->regmap, REG_SUBBLK_CLOCK_CR, ®); + reg |= (1u << periph->shift); + regmap_write(periph_hw->regmap, REG_SUBBLK_CLOCK_CR, reg); }
return 0; @@ -81,17 +81,16 @@ static int mpfs_periph_clk_disable(struct clk *hw) { struct mpfs_periph_hw_clock *periph_hw = to_mpfs_periph_clk(hw); struct mpfs_periph_clock *periph = &periph_hw->periph; - void __iomem *base_addr = periph_hw->sys_base; - u32 reg, val; + u32 reg;
if (periph->flags != CLK_IS_CRITICAL) { - reg = readl(base_addr + REG_SUBBLK_RESET_CR); - val = reg | (1u << periph->shift); - writel(val, base_addr + REG_SUBBLK_RESET_CR); + regmap_read(periph_hw->regmap, REG_SUBBLK_RESET_CR, ®); + reg |= (1u << periph->shift); + regmap_write(periph_hw->regmap, REG_SUBBLK_RESET_CR, reg);
- reg = readl(base_addr + REG_SUBBLK_CLOCK_CR); - val = reg & ~(1u << periph->shift); - writel(val, base_addr + REG_SUBBLK_CLOCK_CR); + regmap_read(periph_hw->regmap, REG_SUBBLK_CLOCK_CR, ®); + reg &= ~(1u << periph->shift); + regmap_write(periph_hw->regmap, REG_SUBBLK_CLOCK_CR, reg); }
return 0; @@ -159,7 +158,7 @@ static struct mpfs_periph_hw_clock mpfs_periph_clks[] = { CLK_PERIPH(CLK_CFM, "clk_periph_cfm", CLK_AHB, 29, 0), };
-int mpfs_clk_register_periphs(void __iomem *base, struct udevice *dev) +int mpfs_clk_register_periphs(struct udevice *dev, struct regmap *regmap) { int ret; int i, id, num_clks; @@ -172,7 +171,7 @@ int mpfs_clk_register_periphs(void __iomem *base, struct udevice *dev)
clk_request(dev, &parent); hw = &mpfs_periph_clks[i].hw; - mpfs_periph_clks[i].sys_base = base; + mpfs_periph_clks[i].regmap = regmap; mpfs_periph_clks[i].prate = clk_get_rate(&parent); name = mpfs_periph_clks[i].periph.name; ret = clk_register(hw, MPFS_PERIPH_CLOCK, name, parent.dev->name);
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
The clock driver for PolarFire SoC now requires syscon and regmap features, so imply them to preserve implication of the clock driver.
Signed-off-by: Conor Dooley conor.dooley@microchip.com --- board/microchip/mpfs_icicle/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/microchip/mpfs_icicle/Kconfig b/board/microchip/mpfs_icicle/Kconfig index 4309f7528bb..6e8c479e955 100644 --- a/board/microchip/mpfs_icicle/Kconfig +++ b/board/microchip/mpfs_icicle/Kconfig @@ -24,6 +24,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply SMP imply CLK_CCF imply CLK_MPFS + imply REGMAP + imply SYSCON imply SYS_NS16550 imply CMD_DHCP imply CMD_EXT2
The U-Boot copy of the mpfs devicetree has, in general, been neglected somewhat in comparison to the one in Linux. Moving to OF_UPSTREAM to keep both in sync should serve to eliminate that discrepancy.
Additionally, moving to OF_UPSTREAM will let U-Boot automatically pick up the devicetree rework that is in progress at [1].
Link: https://lore.kernel.org/all/20241002-private-unequal-33cfa6101338@spud/ [1] Signed-off-by: Conor Dooley conor.dooley@microchip.com --- v2: - rebase on master, drop !DTC_FLAGS from Makefile --- arch/riscv/dts/Makefile | 1 - arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi | 71 --- arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi | 14 - arch/riscv/dts/mpfs-icicle-kit.dts | 208 --------- arch/riscv/dts/mpfs.dtsi | 511 --------------------- configs/microchip_mpfs_icicle_defconfig | 4 +- dts/upstream/src/riscv/Makefile | 6 + 7 files changed, 8 insertions(+), 807 deletions(-) delete mode 100644 arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi delete mode 100644 arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi delete mode 100644 arch/riscv/dts/mpfs-icicle-kit.dts delete mode 100644 arch/riscv/dts/mpfs.dtsi create mode 100644 dts/upstream/src/riscv/Makefile
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index f3dfd751cb4..bf32ead01b0 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,7 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-$(CONFIG_TARGET_ANDES_AE350) += ae350_32.dtb ae350_64.dtb -dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += mpfs-icicle-kit.dtb dtb-$(CONFIG_TARGET_MILKV_DUO) += cv1800b-milkv-duo.dtb dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt32.dtb qemu-virt64.dtb dtb-$(CONFIG_TARGET_OPENPITON_RISCV64) += openpiton-riscv64.dtb diff --git a/arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi b/arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi deleted file mode 100644 index 1069134f2e1..00000000000 --- a/arch/riscv/dts/mpfs-icicle-kit-fabric.dtsi +++ /dev/null @@ -1,71 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* Copyright (c) 2020-2021 Microchip Technology Inc */ - -/ { - compatible = "microchip,mpfs-icicle-reference-rtlv2210", "microchip,mpfs-icicle-kit", - "microchip,mpfs"; - - core_pwm0: pwm@40000000 { - compatible = "microchip,corepwm-rtl-v4"; - reg = <0x0 0x40000000 0x0 0xF0>; - microchip,sync-update-mask = /bits/ 32 <0>; - #pwm-cells = <3>; - clocks = <&ccc_nw CLK_CCC_PLL0_OUT3>; - status = "disabled"; - }; - - i2c2: i2c@40000200 { - compatible = "microchip,corei2c-rtl-v7"; - reg = <0x0 0x40000200 0x0 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&ccc_nw CLK_CCC_PLL0_OUT3>; - interrupt-parent = <&plic>; - interrupts = <122>; - clock-frequency = <100000>; - status = "disabled"; - }; - - pcie: pcie@3000000000 { - compatible = "microchip,pcie-host-1.0"; - #address-cells = <0x3>; - #interrupt-cells = <0x1>; - #size-cells = <0x2>; - device_type = "pci"; - reg = <0x30 0x0 0x0 0x8000000>, <0x0 0x43000000 0x0 0x10000>; - reg-names = "cfg", "apb"; - bus-range = <0x0 0x7f>; - interrupt-parent = <&plic>; - interrupts = <119>; - interrupt-map = <0 0 0 1 &pcie_intc 0>, - <0 0 0 2 &pcie_intc 1>, - <0 0 0 3 &pcie_intc 2>, - <0 0 0 4 &pcie_intc 3>; - interrupt-map-mask = <0 0 0 7>; - clocks = <&ccc_nw CLK_CCC_PLL0_OUT1>, <&ccc_nw CLK_CCC_PLL0_OUT3>; - clock-names = "fic1", "fic3"; - ranges = <0x3000000 0x0 0x8000000 0x30 0x8000000 0x0 0x80000000>; - dma-ranges = <0x02000000 0x0 0x00000000 0x0 0x00000000 0x1 0x00000000>; - msi-parent = <&pcie>; - msi-controller; - status = "disabled"; - pcie_intc: interrupt-controller { - #address-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - }; - }; - - refclk_ccc: cccrefclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - }; -}; - -&ccc_nw { - clocks = <&refclk_ccc>, <&refclk_ccc>, <&refclk_ccc>, <&refclk_ccc>, - <&refclk_ccc>, <&refclk_ccc>; - clock-names = "pll0_ref0", "pll0_ref1", "pll1_ref0", "pll1_ref1", - "dll0_ref", "dll1_ref"; - status = "okay"; -}; diff --git a/arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi b/arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi deleted file mode 100644 index f60283fb6b3..00000000000 --- a/arch/riscv/dts/mpfs-icicle-kit-u-boot.dtsi +++ /dev/null @@ -1,14 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* - * Copyright (C) 2020 Microchip Technology Inc. - * Padmarao Begari padmarao.begari@microchip.com - */ - -/ { - aliases { - cpu1 = &cpu1; - cpu2 = &cpu2; - cpu3 = &cpu3; - cpu4 = &cpu4; - }; -}; diff --git a/arch/riscv/dts/mpfs-icicle-kit.dts b/arch/riscv/dts/mpfs-icicle-kit.dts deleted file mode 100644 index 8aa5fb17d64..00000000000 --- a/arch/riscv/dts/mpfs-icicle-kit.dts +++ /dev/null @@ -1,208 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2021-2022 Microchip Technology Inc. - * Padmarao Begari padmarao.begari@microchip.com - */ - -/dts-v1/; - -#include "mpfs.dtsi" -#include "mpfs-icicle-kit-fabric.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> - -/* Clock frequency (in Hz) of the rtcclk */ -#define RTCCLK_FREQ 1000000 - -/ { - model = "Microchip PolarFire-SoC Icicle Kit"; - compatible = "microchip,mpfs-icicle-reference-rtlv2210", "microchip,mpfs-icicle-kit", - "microchip,mpfs"; - - aliases { - ethernet0 = &mac1; - serial0 = &mmuart0; - serial1 = &mmuart1; - serial2 = &mmuart2; - serial3 = &mmuart3; - serial4 = &mmuart4; - }; - - chosen { - stdout-path = "serial1:115200n8"; - }; - - cpus { - timebase-frequency = <RTCCLK_FREQ>; - }; - - leds { - compatible = "gpio-leds"; - - led-1 { - gpios = <&gpio2 16 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_RED>; - label = "led1"; - }; - - led-2 { - gpios = <&gpio2 17 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_RED>; - label = "led2"; - }; - - led-3 { - gpios = <&gpio2 18 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_AMBER>; - label = "led3"; - }; - - led-4 { - gpios = <&gpio2 19 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_AMBER>; - label = "led4"; - }; - }; - - ddrc_cache_lo: memory@80000000 { - device_type = "memory"; - reg = <0x0 0x80000000 0x0 0x40000000>; - status = "okay"; - }; - - ddrc_cache_hi: memory@1040000000 { - device_type = "memory"; - reg = <0x10 0x40000000 0x0 0x40000000>; - status = "okay"; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - hss_payload: region@BFC00000 { - reg = <0x0 0xBFC00000 0x0 0x400000>; - no-map; - }; - }; -}; - -&core_pwm0 { - status = "okay"; -}; - -&gpio2 { - interrupts = <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>, - <53>, <53>, <53>, <53>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&mac0 { - phy-mode = "sgmii"; - phy-handle = <&phy0>; - status = "enabled"; -}; - -&mac1 { - phy-mode = "sgmii"; - phy-handle = <&phy1>; - status = "okay"; - - phy1: ethernet-phy@9 { - reg = <9>; - }; - - phy0: ethernet-phy@8 { - reg = <8>; - }; -}; - -&mbox { - status = "okay"; -}; - -&mmc { - bus-width = <4>; - disable-wp; - cap-sd-highspeed; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&mmuart1 { - status = "okay"; -}; - -&mmuart2 { - status = "okay"; -}; - -&mmuart3 { - status = "okay"; -}; - -&mmuart4 { - status = "okay"; -}; - -&pcie { - status = "okay"; -}; - -&qspi { - status = "okay"; -}; - -&refclk { - clock-frequency = <125000000>; -}; - -&refclk_ccc { - clock-frequency = <50000000>; -}; - -&rtc { - status = "okay"; -}; - -&spi0 { - status = "okay"; -}; - -&spi1 { - status = "okay"; -}; - -&syscontroller { - status = "okay"; -}; - -&usb { - status = "okay"; - dr_mode = "host"; -}; diff --git a/arch/riscv/dts/mpfs.dtsi b/arch/riscv/dts/mpfs.dtsi deleted file mode 100644 index 6012a285070..00000000000 --- a/arch/riscv/dts/mpfs.dtsi +++ /dev/null @@ -1,511 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* Copyright (c) 2020-2021 Microchip Technology Inc */ - -#include "dt-bindings/clock/microchip-mpfs-clock.h" - -/ { - #address-cells = <2>; - #size-cells = <2>; - model = "Microchip PolarFire SoC"; - compatible = "microchip,mpfs"; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - compatible = "sifive,e51", "sifive,rocket0", "riscv"; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <128>; - i-cache-size = <16384>; - reg = <0>; - riscv,isa = "rv64imac"; - clocks = <&clkcfg CLK_CPU>; - status = "disabled"; - - cpu0_intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - - cpu1: cpu@1 { - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <1>; - riscv,isa = "rv64imafdc"; - clocks = <&clkcfg CLK_CPU>; - tlb-split; - next-level-cache = <&cctrllr>; - status = "okay"; - - cpu1_intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - - cpu2: cpu@2 { - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <2>; - riscv,isa = "rv64imafdc"; - clocks = <&clkcfg CLK_CPU>; - tlb-split; - next-level-cache = <&cctrllr>; - status = "okay"; - - cpu2_intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - - cpu3: cpu@3 { - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <3>; - riscv,isa = "rv64imafdc"; - clocks = <&clkcfg CLK_CPU>; - tlb-split; - next-level-cache = <&cctrllr>; - status = "okay"; - - cpu3_intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - - cpu4: cpu@4 { - compatible = "sifive,u54-mc", "sifive,rocket0", "riscv"; - d-cache-block-size = <64>; - d-cache-sets = <64>; - d-cache-size = <32768>; - d-tlb-sets = <1>; - d-tlb-size = <32>; - device_type = "cpu"; - i-cache-block-size = <64>; - i-cache-sets = <64>; - i-cache-size = <32768>; - i-tlb-sets = <1>; - i-tlb-size = <32>; - mmu-type = "riscv,sv39"; - reg = <4>; - riscv,isa = "rv64imafdc"; - clocks = <&clkcfg CLK_CPU>; - tlb-split; - next-level-cache = <&cctrllr>; - status = "okay"; - cpu4_intc: interrupt-controller { - #interrupt-cells = <1>; - compatible = "riscv,cpu-intc"; - interrupt-controller; - }; - }; - - cpu-map { - cluster0 { - core0 { - cpu = <&cpu0>; - }; - - core1 { - cpu = <&cpu1>; - }; - - core2 { - cpu = <&cpu2>; - }; - - core3 { - cpu = <&cpu3>; - }; - - core4 { - cpu = <&cpu4>; - }; - }; - }; - }; - - refclk: mssrefclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - }; - - syscontroller: syscontroller { - compatible = "microchip,mpfs-sys-controller"; - mboxes = <&mbox 0>; - }; - - soc { - #address-cells = <2>; - #size-cells = <2>; - compatible = "simple-bus"; - ranges; - - cctrllr: cache-controller@2010000 { - compatible = "microchip,mpfs-ccache", "sifive,fu540-c000-ccache", "cache"; - reg = <0x0 0x2010000 0x0 0x1000>; - cache-block-size = <64>; - cache-level = <2>; - cache-sets = <1024>; - cache-size = <2097152>; - cache-unified; - interrupt-parent = <&plic>; - interrupts = <1>, <3>, <4>, <2>; - }; - - clint: clint@2000000 { - compatible = "sifive,fu540-c000-clint", "sifive,clint0"; - reg = <0x0 0x2000000 0x0 0xC000>; - interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>, - <&cpu1_intc 3>, <&cpu1_intc 7>, - <&cpu2_intc 3>, <&cpu2_intc 7>, - <&cpu3_intc 3>, <&cpu3_intc 7>, - <&cpu4_intc 3>, <&cpu4_intc 7>; - }; - - plic: interrupt-controller@c000000 { - compatible = "sifive,fu540-c000-plic", "sifive,plic-1.0.0"; - reg = <0x0 0xc000000 0x0 0x4000000>; - #address-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - interrupts-extended = <&cpu0_intc 11>, - <&cpu1_intc 11>, <&cpu1_intc 9>, - <&cpu2_intc 11>, <&cpu2_intc 9>, - <&cpu3_intc 11>, <&cpu3_intc 9>, - <&cpu4_intc 11>, <&cpu4_intc 9>; - riscv,ndev = <186>; - }; - - pdma: dma-controller@3000000 { - compatible = "sifive,fu540-c000-pdma", "sifive,pdma0"; - reg = <0x0 0x3000000 0x0 0x8000>; - interrupt-parent = <&plic>; - interrupts = <5 6>, <7 8>, <9 10>, <11 12>; - dma-channels = <4>; - #dma-cells = <1>; - }; - - clkcfg: clkcfg@20002000 { - compatible = "microchip,mpfs-clkcfg"; - reg = <0x0 0x20002000 0x0 0x1000>, <0x0 0x3E001000 0x0 0x1000>; - clocks = <&refclk>; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - ccc_se: clock-controller@38010000 { - compatible = "microchip,mpfs-ccc"; - reg = <0x0 0x38010000 0x0 0x1000>, <0x0 0x38020000 0x0 0x1000>, - <0x0 0x39010000 0x0 0x1000>, <0x0 0x39020000 0x0 0x1000>; - #clock-cells = <1>; - status = "disabled"; - }; - - ccc_ne: clock-controller@38040000 { - compatible = "microchip,mpfs-ccc"; - reg = <0x0 0x38040000 0x0 0x1000>, <0x0 0x38080000 0x0 0x1000>, - <0x0 0x39040000 0x0 0x1000>, <0x0 0x39080000 0x0 0x1000>; - #clock-cells = <1>; - status = "disabled"; - }; - - ccc_nw: clock-controller@38100000 { - compatible = "microchip,mpfs-ccc"; - reg = <0x0 0x38100000 0x0 0x1000>, <0x0 0x38200000 0x0 0x1000>, - <0x0 0x39100000 0x0 0x1000>, <0x0 0x39200000 0x0 0x1000>; - #clock-cells = <1>; - status = "disabled"; - }; - - ccc_sw: clock-controller@38400000 { - compatible = "microchip,mpfs-ccc"; - reg = <0x0 0x38400000 0x0 0x1000>, <0x0 0x38800000 0x0 0x1000>, - <0x0 0x39400000 0x0 0x1000>, <0x0 0x39800000 0x0 0x1000>; - #clock-cells = <1>; - status = "disabled"; - }; - - mmuart0: serial@20000000 { - compatible = "ns16550a"; - reg = <0x0 0x20000000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <90>; - current-speed = <115200>; - clocks = <&clkcfg CLK_MMUART0>; - status = "disabled"; /* Reserved for the HSS */ - }; - - mmuart1: serial@20100000 { - compatible = "ns16550a"; - reg = <0x0 0x20100000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <91>; - current-speed = <115200>; - clocks = <&clkcfg CLK_MMUART1>; - status = "disabled"; - }; - - mmuart2: serial@20102000 { - compatible = "ns16550a"; - reg = <0x0 0x20102000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <92>; - current-speed = <115200>; - clocks = <&clkcfg CLK_MMUART2>; - status = "disabled"; - }; - - mmuart3: serial@20104000 { - compatible = "ns16550a"; - reg = <0x0 0x20104000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <93>; - current-speed = <115200>; - clocks = <&clkcfg CLK_MMUART3>; - status = "disabled"; - }; - - mmuart4: serial@20106000 { - compatible = "ns16550a"; - reg = <0x0 0x20106000 0x0 0x400>; - reg-io-width = <4>; - reg-shift = <2>; - interrupt-parent = <&plic>; - interrupts = <94>; - clocks = <&clkcfg CLK_MMUART4>; - current-speed = <115200>; - status = "disabled"; - }; - - /* Common node entry for emmc/sd */ - mmc: mmc@20008000 { - compatible = "microchip,mpfs-sd4hc", "cdns,sd4hc"; - reg = <0x0 0x20008000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <88>; - clocks = <&clkcfg CLK_MMC>; - max-frequency = <200000000>; - status = "disabled"; - }; - - spi0: spi@20108000 { - compatible = "microchip,mpfs-spi"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x0 0x20108000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <54>; - clocks = <&clkcfg CLK_SPI0>; - status = "disabled"; - }; - - spi1: spi@20109000 { - compatible = "microchip,mpfs-spi"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x0 0x20109000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <55>; - clocks = <&clkcfg CLK_SPI1>; - status = "disabled"; - }; - - qspi: spi@21000000 { - compatible = "microchip,mpfs-qspi", "microchip,coreqspi-rtl-v2"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x0 0x21000000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <85>; - clocks = <&clkcfg CLK_QSPI>; - status = "disabled"; - }; - - i2c0: i2c@2010a000 { - compatible = "microchip,mpfs-i2c", "microchip,corei2c-rtl-v7"; - reg = <0x0 0x2010a000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - interrupt-parent = <&plic>; - interrupts = <58>; - clocks = <&clkcfg CLK_I2C0>; - clock-frequency = <100000>; - status = "disabled"; - }; - - i2c1: i2c@2010b000 { - compatible = "microchip,mpfs-i2c", "microchip,corei2c-rtl-v7"; - reg = <0x0 0x2010b000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - interrupt-parent = <&plic>; - interrupts = <61>; - clocks = <&clkcfg CLK_I2C1>; - clock-frequency = <100000>; - status = "disabled"; - }; - - can0: can@2010c000 { - compatible = "microchip,mpfs-can"; - reg = <0x0 0x2010c000 0x0 0x1000>; - clocks = <&clkcfg CLK_CAN0>; - interrupt-parent = <&plic>; - interrupts = <56>; - status = "disabled"; - }; - - can1: can@2010d000 { - compatible = "microchip,mpfs-can"; - reg = <0x0 0x2010d000 0x0 0x1000>; - clocks = <&clkcfg CLK_CAN1>; - interrupt-parent = <&plic>; - interrupts = <57>; - status = "disabled"; - }; - - mac0: ethernet@20110000 { - compatible = "microchip,mpfs-macb", "cdns,macb"; - reg = <0x0 0x20110000 0x0 0x2000>; - #address-cells = <1>; - #size-cells = <0>; - interrupt-parent = <&plic>; - interrupts = <64>, <65>, <66>, <67>, <68>, <69>; - local-mac-address = [00 00 00 00 00 00]; - clocks = <&clkcfg CLK_MAC0>, <&clkcfg CLK_AHB>; - clock-names = "pclk", "hclk"; - resets = <&clkcfg CLK_MAC0>; - status = "disabled"; - }; - - mac1: ethernet@20112000 { - compatible = "microchip,mpfs-macb", "cdns,macb"; - reg = <0x0 0x20112000 0x0 0x2000>; - #address-cells = <1>; - #size-cells = <0>; - interrupt-parent = <&plic>; - interrupts = <70>, <71>, <72>, <73>, <74>, <75>; - local-mac-address = [00 00 00 00 00 00]; - clocks = <&clkcfg CLK_MAC1>, <&clkcfg CLK_AHB>; - clock-names = "pclk", "hclk"; - resets = <&clkcfg CLK_MAC1>; - status = "disabled"; - }; - - gpio0: gpio@20120000 { - compatible = "microchip,mpfs-gpio"; - reg = <0x0 0x20120000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupt-controller; - #interrupt-cells = <1>; - clocks = <&clkcfg CLK_GPIO0>; - gpio-controller; - #gpio-cells = <2>; - status = "disabled"; - }; - - gpio1: gpio@20121000 { - compatible = "microchip,mpfs-gpio"; - reg = <0x0 0x20121000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupt-controller; - #interrupt-cells = <1>; - clocks = <&clkcfg CLK_GPIO1>; - gpio-controller; - #gpio-cells = <2>; - status = "disabled"; - }; - - gpio2: gpio@20122000 { - compatible = "microchip,mpfs-gpio"; - reg = <0x0 0x20122000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupt-controller; - #interrupt-cells = <1>; - clocks = <&clkcfg CLK_GPIO2>; - gpio-controller; - #gpio-cells = <2>; - status = "disabled"; - }; - - rtc: rtc@20124000 { - compatible = "microchip,mpfs-rtc"; - reg = <0x0 0x20124000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <80>, <81>; - clocks = <&clkcfg CLK_RTC>, <&clkcfg CLK_RTCREF>; - clock-names = "rtc", "rtcref"; - status = "disabled"; - }; - - usb: usb@20201000 { - compatible = "microchip,mpfs-musb"; - reg = <0x0 0x20201000 0x0 0x1000>; - interrupt-parent = <&plic>; - interrupts = <86>, <87>; - clocks = <&clkcfg CLK_USB>; - interrupt-names = "dma","mc"; - status = "disabled"; - }; - - mbox: mailbox@37020000 { - compatible = "microchip,mpfs-mailbox"; - reg = <0x0 0x37020000 0x0 0x58>, <0x0 0x2000318C 0x0 0x40>, - <0x0 0x37020800 0x0 0x100>; - interrupt-parent = <&plic>; - interrupts = <96>; - #mbox-cells = <1>; - status = "disabled"; - }; - }; -}; diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig index 94952a96762..a35721a8a89 100644 --- a/configs/microchip_mpfs_icicle_defconfig +++ b/configs/microchip_mpfs_icicle_defconfig @@ -4,8 +4,8 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 CONFIG_ENV_SIZE=0x2000 -CONFIG_DEFAULT_DEVICE_TREE="mpfs-icicle-kit" -CONFIG_SYS_BOOTM_LEN=0x4000000 +CONFIG_DEFAULT_DEVICE_TREE="microchip/mpfs-icicle-kit" +CONFIG_OF_UPSTREAM=y CONFIG_SYS_LOAD_ADDR=0x80200000 CONFIG_SYS_MEM_TOP_HIDE=0x400000 CONFIG_TARGET_MICROCHIP_ICICLE=y diff --git a/dts/upstream/src/riscv/Makefile b/dts/upstream/src/riscv/Makefile new file mode 100644 index 00000000000..980617e6de3 --- /dev/null +++ b/dts/upstream/src/riscv/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ + +include $(srctree)/scripts/Makefile.dts + +DTC_FLAGS += -R 4 -p 0x1000 +
v2:
Reviewed-by: Sumit Garg sumit.garg@linaro.org
-Sumit
"microchip,mpfs";
#pwm-cells = <3>;
#size-cells = <0>;
interrupts = <122>;
interrupts = <119>;
msi-controller;
#clock-cells = <0>;
-&ccc_nw {
status = "okay";
- Copyright (C) 2020 Microchip Technology Inc.
- Padmarao Begari padmarao.begari@microchip.com
aliases {
cpu1 = &cpu1;
cpu2 = &cpu2;
cpu3 = &cpu3;
cpu4 = &cpu4;
- Copyright (C) 2021-2022 Microchip Technology Inc.
-/dts-v1/;
"microchip,mpfs";
aliases {
ethernet0 = &mac1;
serial0 = &mmuart0;
serial1 = &mmuart1;
serial2 = &mmuart2;
serial3 = &mmuart3;
serial4 = &mmuart4;
chosen {
cpus {
leds {
led-1 {
label = "led1";
led-2 {
label = "led2";
led-3 {
label = "led3";
led-4 {
label = "led4";
status = "okay";
status = "okay";
reserved-memory {
#size-cells = <2>;
ranges;
no-map;
-&core_pwm0 {
status = "okay";
-&gpio2 {
status = "okay";
-&i2c0 {
status = "okay";
-&i2c1 {
status = "okay";
-&i2c2 {
status = "okay";
-&mac0 {
phy-mode = "sgmii";
status = "enabled";
-&mac1 {
phy-mode = "sgmii";
status = "okay";
reg = <9>;
reg = <8>;
-&mbox {
status = "okay";
-&mmc {
bus-width = <4>;
disable-wp;
cap-sd-highspeed;
cap-mmc-highspeed;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
sd-uhs-sdr12;
sd-uhs-sdr25;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
-&mmuart1 {
status = "okay";
-&mmuart2 {
status = "okay";
-&mmuart3 {
status = "okay";
-&mmuart4 {
status = "okay";
-&pcie {
status = "okay";
-&qspi {
status = "okay";
-&refclk {
-&refclk_ccc {
-&rtc {
status = "okay";
-&spi0 {
status = "okay";
-&spi1 {
status = "okay";
-&syscontroller {
status = "okay";
-&usb {
status = "okay";
dr_mode = "host";
#size-cells = <2>;
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
cpu1: cpu@1 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <1>;
tlb-split;
status = "okay";
cpu2: cpu@2 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <2>;
tlb-split;
status = "okay";
cpu3: cpu@3 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <3>;
tlb-split;
status = "okay";
cpu4: cpu@4 {
d-tlb-sets = <1>;
d-tlb-size = <32>;
i-tlb-sets = <1>;
i-tlb-size = <32>;
reg = <4>;
tlb-split;
status = "okay";
cpu-map {
cluster0 {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
core2 {
cpu = <&cpu2>;
core3 {
cpu = <&cpu3>;
core4 {
cpu = <&cpu4>;
refclk: mssrefclk {
#clock-cells = <0>;
mboxes = <&mbox 0>;
soc {
#size-cells = <2>;
ranges;
cache-level = <2>;
cache-unified;
riscv,ndev = <186>;
dma-channels = <4>;
#dma-cells = <1>;
clocks = <&refclk>;
#clock-cells = <1>;
#reset-cells = <1>;
#clock-cells = <1>;
#clock-cells = <1>;
#clock-cells = <1>;
#clock-cells = <1>;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <90>;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <91>;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <92>;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <93>;
reg-io-width = <4>;
reg-shift = <2>;
interrupts = <94>;
mmc: mmc@20008000 {
interrupts = <88>;
#size-cells = <0>;
interrupts = <54>;
#size-cells = <0>;
interrupts = <55>;
#size-cells = <0>;
interrupts = <85>;
#size-cells = <0>;
interrupts = <58>;
#size-cells = <0>;
interrupts = <61>;
interrupts = <56>;
interrupts = <57>;
#size-cells = <0>;
#size-cells = <0>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
rtc: rtc@20124000 {
usb: usb@20201000 {
interrupts = <96>;
#mbox-cells = <1>;
-- 2.45.2
Conor Dooley
Leo Liang
Sumit Garg
