[U-Boot] [PATCH 1/3] omap3: Move to select SUPPORT_SPL for all
In reality all omap3 platforms support SPL so move the select for this up a level.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 1 + arch/arm/cpu/armv7/omap3/Kconfig | 19 ------------------- 2 files changed, 1 insertion(+), 19 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4a62d4b..a9e1e7a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -553,6 +553,7 @@ config TARGET_MX53SMD config OMAP34XX bool "OMAP34XX SoC" select CPU_V7 + select SUPPORT_SPL
config OMAP44XX bool "OMAP44XX SoC" diff --git a/arch/arm/cpu/armv7/omap3/Kconfig b/arch/arm/cpu/armv7/omap3/Kconfig index 85d6436..daf5411 100644 --- a/arch/arm/cpu/armv7/omap3/Kconfig +++ b/arch/arm/cpu/armv7/omap3/Kconfig @@ -6,55 +6,45 @@ choice
config TARGET_AM3517_EVM bool "AM3517 EVM" - select SUPPORT_SPL
config TARGET_MT_VENTOUX bool "TeeJet Mt.Ventoux" - select SUPPORT_SPL
config TARGET_OMAP3_BEAGLE bool "TI OMAP3 BeagleBoard" - select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO
config TARGET_CM_T35 bool "CompuLab CM-T3530 and CM-T3730 boards" - select SUPPORT_SPL
config TARGET_CM_T3517 bool "CompuLab CM-T3517 boards"
config TARGET_DEVKIT8000 bool "TimLL OMAP3 Devkit8000" - select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO
config TARGET_OMAP3_EVM bool "TI OMAP3 EVM" - select SUPPORT_SPL
config TARGET_OMAP3_EVM_QUICK_MMC bool "TI OMAP3 EVM Quick MMC" - select SUPPORT_SPL
config TARGET_OMAP3_EVM_QUICK_NAND bool "TI OMAP3 EVM Quick NAND" - select SUPPORT_SPL
config TARGET_OMAP3_IGEP00X0 bool "IGEP" - select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO
config TARGET_OMAP3_OVERO bool "OMAP35xx Gumstix Overo" - select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO @@ -67,51 +57,42 @@ config TARGET_OMAP3_ZOOM1
config TARGET_AM3517_CRANE bool "am3517_crane" - select SUPPORT_SPL
config TARGET_OMAP3_PANDORA bool "OMAP3 Pandora"
config TARGET_ECO5PK bool "ECO5PK" - select SUPPORT_SPL
config TARGET_TRICORDER bool "Tricorder" - select SUPPORT_SPL
config TARGET_MCX bool "MCX" - select SUPPORT_SPL
config TARGET_OMAP3_LOGIC bool "OMAP3 Logic" select DM select DM_SERIAL select DM_GPIO - select SUPPORT_SPL
config TARGET_NOKIA_RX51 bool "Nokia RX51"
config TARGET_TAO3530 bool "TAO3530" - select SUPPORT_SPL
config TARGET_TWISTER bool "Twister" - select SUPPORT_SPL
config TARGET_OMAP3_CAIRO bool "QUIPOS CAIRO" - select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO
config TARGET_SNIPER bool "LG Optimus Black" - select SUPPORT_SPL select DM select DM_SERIAL select DM_GPIO
In the case of omap3 we have a number of platforms that are close to exceeding SRAM limits, depending on compiler. Move to USE_TINY_PRINTF to give them more room. OMAP4 will soon enough be in a similar place, so enable that now.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index a9e1e7a..ad48a2f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -554,11 +554,13 @@ config OMAP34XX bool "OMAP34XX SoC" select CPU_V7 select SUPPORT_SPL + select USE_TINY_PRINTF
config OMAP44XX bool "OMAP44XX SoC" select CPU_V7 select SUPPORT_SPL + select USE_TINY_PRINTF
config OMAP54XX bool "OMAP54XX SoC"
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
- select USE_TINY_PRINTF
These config targets were added well before the Kconfig migration began as a way to demonstrate how to make these platforms work with cut down features. At this point in time they no longer serve a good purpose so remove them.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv7/omap3/Kconfig | 6 --- board/ti/evm/Kconfig | 26 ---------- board/ti/evm/MAINTAINERS | 4 -- configs/omap3_evm_quick_mmc_defconfig | 30 ----------- configs/omap3_evm_quick_nand_defconfig | 28 ----------- include/configs/omap3_evm_quick_mmc.h | 89 --------------------------------- include/configs/omap3_evm_quick_nand.h | 91 ---------------------------------- 7 files changed, 274 deletions(-) delete mode 100644 configs/omap3_evm_quick_mmc_defconfig delete mode 100644 configs/omap3_evm_quick_nand_defconfig delete mode 100644 include/configs/omap3_evm_quick_mmc.h delete mode 100644 include/configs/omap3_evm_quick_nand.h
diff --git a/arch/arm/cpu/armv7/omap3/Kconfig b/arch/arm/cpu/armv7/omap3/Kconfig index daf5411..99a25f9 100644 --- a/arch/arm/cpu/armv7/omap3/Kconfig +++ b/arch/arm/cpu/armv7/omap3/Kconfig @@ -31,12 +31,6 @@ config TARGET_DEVKIT8000 config TARGET_OMAP3_EVM bool "TI OMAP3 EVM"
-config TARGET_OMAP3_EVM_QUICK_MMC - bool "TI OMAP3 EVM Quick MMC" - -config TARGET_OMAP3_EVM_QUICK_NAND - bool "TI OMAP3 EVM Quick NAND" - config TARGET_OMAP3_IGEP00X0 bool "IGEP" select DM diff --git a/board/ti/evm/Kconfig b/board/ti/evm/Kconfig index f02aa31..4f490dd 100644 --- a/board/ti/evm/Kconfig +++ b/board/ti/evm/Kconfig @@ -10,29 +10,3 @@ config SYS_CONFIG_NAME default "omap3_evm"
endif - -if TARGET_OMAP3_EVM_QUICK_MMC - -config SYS_BOARD - default "evm" - -config SYS_VENDOR - default "ti" - -config SYS_CONFIG_NAME - default "omap3_evm_quick_mmc" - -endif - -if TARGET_OMAP3_EVM_QUICK_NAND - -config SYS_BOARD - default "evm" - -config SYS_VENDOR - default "ti" - -config SYS_CONFIG_NAME - default "omap3_evm_quick_nand" - -endif diff --git a/board/ti/evm/MAINTAINERS b/board/ti/evm/MAINTAINERS index 90c3f6b..612a08a 100644 --- a/board/ti/evm/MAINTAINERS +++ b/board/ti/evm/MAINTAINERS @@ -3,8 +3,4 @@ M: Tom Rini trini@konsulko.com S: Maintained F: board/ti/evm/ F: include/configs/omap3_evm.h -F: include/configs/omap3_evm_quick_mmc.h -F: include/configs/omap3_evm_quick_nand.h F: configs/omap3_evm_defconfig -F: configs/omap3_evm_quick_mmc_defconfig -F: configs/omap3_evm_quick_nand_defconfig diff --git a/configs/omap3_evm_quick_mmc_defconfig b/configs/omap3_evm_quick_mmc_defconfig deleted file mode 100644 index ebdc105..0000000 --- a/configs/omap3_evm_quick_mmc_defconfig +++ /dev/null @@ -1,30 +0,0 @@ -CONFIG_ARM=y -CONFIG_OMAP34XX=y -CONFIG_TARGET_OMAP3_EVM_QUICK_MMC=y -CONFIG_SPL=y -CONFIG_BOOTDELAY=-2 -CONFIG_SYS_PROMPT="OMAP3_EVM # " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_BOOTD is not set -# CONFIG_CMD_RUN is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_EDITENV is not set -# CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set -# CONFIG_CMD_MEMORY is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_ECHO is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -# CONFIG_CMD_MISC is not set -CONFIG_CMD_FAT=y -CONFIG_SYS_NS16550=y diff --git a/configs/omap3_evm_quick_nand_defconfig b/configs/omap3_evm_quick_nand_defconfig deleted file mode 100644 index 52b08b8..0000000 --- a/configs/omap3_evm_quick_nand_defconfig +++ /dev/null @@ -1,28 +0,0 @@ -CONFIG_ARM=y -CONFIG_OMAP34XX=y -CONFIG_TARGET_OMAP3_EVM_QUICK_NAND=y -CONFIG_SPL=y -CONFIG_BOOTDELAY=-2 -CONFIG_SYS_PROMPT="OMAP3_EVM # " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_BOOTD is not set -# CONFIG_CMD_RUN is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_EDITENV is not set -# CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set -# CONFIG_CMD_MEMORY is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_ECHO is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -# CONFIG_CMD_MISC is not set -CONFIG_SYS_NS16550=y diff --git a/include/configs/omap3_evm_quick_mmc.h b/include/configs/omap3_evm_quick_mmc.h deleted file mode 100644 index b7d8765..0000000 --- a/include/configs/omap3_evm_quick_mmc.h +++ /dev/null @@ -1,89 +0,0 @@ -/* - * Configuration settings for quick boot from MMC on OMAP3 EVM. - * - * Copyright (C) 2006-2010 Texas Instruments Incorporated - http://www.ti.com/ - * - * Author : - * Sanjeev Premi premi@ti.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __OMAP3_EVM_QUICK_MMC_H -#define __OMAP3_EVM_QUICK_MMC_H - -#include <asm/arch/cpu.h> -#include <asm/arch/omap.h> - -/* ---------------------------------------------------------------------------- - * Supported U-Boot commands - * ---------------------------------------------------------------------------- - */ - -/* - * Board revision is detected by probing the Ethernet chip. - * - * When revision is statically configured via CONFIG_STATIC_BOARD_REV, - * this option can be removed. Generated binary is leaner by ~16Kbytes. - */ - -/* ---------------------------------------------------------------------------- - * Supported U-Boot features - * ---------------------------------------------------------------------------- - */ -#define CONFIG_SILENT_CONSOLE -#define CONFIG_ENV_IS_NOWHERE - -/* ---------------------------------------------------------------------------- - * Supported hardware - * ---------------------------------------------------------------------------- - */ - -/* MMC */ -#define CONFIG_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION - -/* ----------------------------------------------------------------------------- - * Include common board configuration - * ----------------------------------------------------------------------------- - */ -#include "omap3_evm_common.h" - -/* ----------------------------------------------------------------------------- - * Default environment - * ----------------------------------------------------------------------------- - */ - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=no\0" \ - "silent=1" - -#define CONFIG_BOOTCOMMAND \ - "mmc rescan 0; " \ - "fatload mmc 0 0x82000000 uImage; " \ - "bootm 0x82000000;" - -/* - * Update the bootargs as necessary e.g. size of memory, partition and fstype - */ -#define CONFIG_BOOTARGS \ - "quiet " \ - "console=ttyO0,115200n8 " \ - "mem=128M " \ - "noinitrd " \ - "root=/dev/mmcblk0p2 rw " \ - "rootfstype=ext3 rootwait" - -/* - * SPL - */ -#define CONFIG_SPL_MMC_SUPPORT -#define CONFIG_SPL_FAT_SUPPORT -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ -#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ -#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#endif /* __OMAP3_EVM_QUICK_MMC_H */ diff --git a/include/configs/omap3_evm_quick_nand.h b/include/configs/omap3_evm_quick_nand.h deleted file mode 100644 index da5d325..0000000 --- a/include/configs/omap3_evm_quick_nand.h +++ /dev/null @@ -1,91 +0,0 @@ -/* - * Configuration settings for quick boot from NAND on OMAP3 EVM. - * - * Copyright (C) 2006-2010 Texas Instruments Incorporated - http://www.ti.com/ - * - * Author : - * Sanjeev Premi premi@ti.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __OMAP3_EVM_QUICK_NAND_H -#define __OMAP3_EVM_QUICK_NAND_H - -#include <asm/arch/cpu.h> -#include <asm/arch/omap.h> - -/* ---------------------------------------------------------------------------- - * Supported U-Boot commands - * ---------------------------------------------------------------------------- - */ -#define CONFIG_CMD_NAND - -/* - * Board revision is detected by probing the Ethernet chip. - * - * When revision is statically configured via CONFIG_STATIC_BOARD_REV, - * this option can be removed. Generated binary is leaner by ~16Kbytes. - */ - -/* ---------------------------------------------------------------------------- - * Supported U-Boot features - * ---------------------------------------------------------------------------- - */ -#define CONFIG_SILENT_CONSOLE -#define CONFIG_ENV_IS_NOWHERE - -/* ----------------------------------------------------------------------------- - * Include common board configuration - * ----------------------------------------------------------------------------- - */ -#include "omap3_evm_common.h" - -/* ----------------------------------------------------------------------------- - * Default environment - * ----------------------------------------------------------------------------- - */ - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=no\0" \ - "silent=1" - -#define CONFIG_BOOTCOMMAND \ - "nandecc hw; " \ - "nand read.i 0x80000000 280000 300000; " \ - "bootm 0x80000000;" - -/* - * Update the bootargs as necessary e.g. size of memory, partition and fstype - */ -#define CONFIG_BOOTARGS \ - "quiet " \ - "console=ttyO0,115200n8 " \ - "mem=128M " \ - "noinitrd " \ - "root=/dev/mtdblock4 rw " \ - "rootfstype=jffs2 " - -/* - * SPL - */ -#define CONFIG_SPL_NAND_SIMPLE -#define CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_BASE -#define CONFIG_SPL_NAND_DRIVERS -#define CONFIG_SPL_NAND_ECC -#define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 -#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ - 10, 11, 12, 13} -#define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 - -#endif /* __OMAP3_EVM_QUICK_NAND_H */
endif
-config SYS_BOARD
- default "evm"
-config SYS_VENDOR
- default "ti"
-endif
-config SYS_BOARD
- default "evm"
-config SYS_VENDOR
- default "ti"
- Configuration settings for quick boot from MMC on OMAP3 EVM.
- Copyright (C) 2006-2010 Texas Instruments Incorporated - http://www.ti.com/
- Author :
Sanjeev Premi <premi@ti.com>
- Supported U-Boot commands
- Board revision is detected by probing the Ethernet chip.
- When revision is statically configured via CONFIG_STATIC_BOARD_REV,
- this option can be removed. Generated binary is leaner by ~16Kbytes.
- Supported U-Boot features
- Supported hardware
- Include common board configuration
- Default environment
- "verify=no\0" \
- "silent=1"
- Update the bootargs as necessary e.g. size of memory, partition and fstype
- "quiet " \
- "mem=128M " \
- "noinitrd " \
- SPL
- Configuration settings for quick boot from NAND on OMAP3 EVM.
- Author :
- "verify=no\0" \
- "silent=1"
- "nandecc hw; " \
- "quiet " \
- "mem=128M " \
- "noinitrd " \
- SPL
10, 11, 12, 13}
Along with moving include/configs/omap3_evm_common.h directly in to include/configs/omap3_evm.h now that we don't have 3 separate include/configs/ files, applied to u-boot/master, thanks!
Lokesh Vutla
